MOAB: Mesh Oriented datABase
(version 5.4.1)
#include <iostream>#include <fstream>#include <cstdlib>#include "mcnpmit.hpp"#include "moab/CartVect.hpp"#include <cmath>
Include dependency graph for mcnpmit.cpp:Go to the source code of this file.
Functions | |
| moab::Interface * | mb_instance () |
| MCNPError | next_number (std::string, double &, int &) |
| int | how_many_numbers (std::string) |
| MCNPError | read_numbers (std::string, int, std::vector< double > &) |
Variables | |
| const double | c2pi = 0.1591549430918954 |
| int how_many_numbers | ( | std::string | s | ) |
Definition at line 391 of file mcnpmit.cpp.
References DONE, MCNP_SUCCESS, and next_number().
Referenced by McnpData::read_mcnpfile().
int n = -1;
int fpos = 0;
double d = 0;
MCNPError result = MCNP_SUCCESS;
while( result != DONE )
result = next_number( s, d, fpos );
n++;
return n;
Definition at line 453 of file main.cpp.
static moab::Core inst;
return &inst;
| MCNPError next_number | ( | std::string | s, |
| double & | d, | ||
| int & | p | ||
Definition at line 365 of file mcnpmit.cpp.
References DONE, and MCNP_SUCCESS.
Referenced by McnpData::extract_tally_data(), how_many_numbers(), read_numbers(), and McnpData::read_rotation_matrix().
unsigned int slen = s.length();
unsigned int j;
for( unsigned int i = p; i < slen; i++ )
if( ( ( s[i] >= 48 ) && ( s[i] <= 57 ) ) || ( s[i] == 45 ) )
j = s.find( " ", i );
if( j > slen ) j = slen;
// Extract the number out of the string
d = std::atof( s.substr( i, j - i ).c_str() );
p = j + 1;
return MCNP_SUCCESS;
return DONE;
| MCNPError read_numbers | ( | std::string | s, |
| int | n, | ||
| std::vector< double > & | x | ||
Definition at line 408 of file mcnpmit.cpp.
References MCNP_FAILURE, MCNP_SUCCESS, and next_number().
MCNPError result;
int fpos = 0;
double d;
for( int i = 0; i < n; i++ )
if( result == MCNP_FAILURE ) return MCNP_FAILURE;
x.push_back( d );
| const double c2pi = 0.1591549430918954 |
Definition at line 12 of file mcnpmit.cpp.
Referenced by McnpData::transform_point().
