MOAB: Mesh Oriented datABase
(version 5.4.1)
00001 #include "moab/Core.hpp" 00002 #include "moab/Range.hpp" 00003 #include <iostream> 00004 #define MCNP mc_instance() 00005 #define BOXMIN_TAG "BOXMIN_TAG" 00006 #define BOXMAX_TAG "BOXMAX_TAG" 00007 #define TALLY_TAG "TALLY_TAG" 00008 #define ERROR_TAG "ERROR_TAG" 00009 00010 #define MBI mb_instance() 00011 00012 enum MCNPError 00013 { 00014 MCNP_SUCCESS, 00015 MCNP_FAILURE, 00016 DONE 00017 }; 00018 enum 00019 { 00020 NOSYS, 00021 CARTESIAN, 00022 CYLINDRICAL, 00023 SPHERICAL 00024 }; 00025 00026 class McnpData 00027 { 00028 00029 public: 00030 // Constructor and Destructor 00031 McnpData(); 00032 ~McnpData(); 00033 00034 // Coordinate system and rotation matrix 00035 int coord_system; 00036 double rotation_matrix[16]; 00037 00038 // Vertices and elements 00039 std::vector< moab::EntityHandle > MCNP_vertices; 00040 std::vector< moab::EntityHandle > MCNP_elems; 00041 moab::Range vert_handles; 00042 moab::Range elem_handles; 00043 00044 // Tally data 00045 moab::Tag box_min_tag, box_max_tag; 00046 moab::Tag tally_tag; 00047 moab::Tag relerr_tag; 00048 00049 // MCNP Meshtal file name 00050 std::string MCNP_filename; 00051 00052 // Setting and retrieving coordinate sysem 00053 MCNPError set_coord_system( int ); 00054 int get_coord_system(); 00055 00056 // Setting and retrieving roation matrix 00057 MCNPError set_rotation_matrix( double[16] ); 00058 double* get_rotation_matrix(); 00059 00060 // Set the filename 00061 MCNPError set_filename( std::string ); 00062 std::string get_filename(); 00063 00064 // MCNP reading routines 00065 MCNPError read_mcnpfile( bool ); 00066 MCNPError read_coord_system( std::string ); 00067 MCNPError read_rotation_matrix( std::string, int ); 00068 MCNPError make_elements( std::vector< double >[3], int* ); 00069 MCNPError make_adjacencies( int* ); 00070 MCNPError initialize_tags(); 00071 MCNPError extract_tally_data( std::string, moab::EntityHandle ); 00072 00073 // Transformation routine 00074 MCNPError transform_point( double*, double*, int, double* ); 00075 };
