MOAB: Mesh Oriented datABase
(version 5.4.1)
#include <iostream>#include <cstdlib>#include <cstdio>#include "moab/Core.hpp"#include "moab/Interface.hpp"#include "moab/Range.hpp"#include "moab/AdaptiveKDTree.hpp"#include "moab/ElemEvaluator.hpp"#include "moab/CN.hpp"#include "moab/SpatialLocator.hpp"
Include dependency graph for PointInElementSearch.cpp:Go to the source code of this file.
Functions | |
| int | main (int argc, char **argv) |
Variables | |
| string | test_file_name = string( MESH_DIR ) + string( "/mbtest1.vtk" ) |
| int main | ( | int | argc, |
| char ** | argv | ||
Definition at line 29 of file PointInElementSearch.cpp.
References moab::CartVect::array(), moab::Range::begin(), moab::BoundBox::bMax, moab::BoundBox::bMin, box(), moab::CN::EntityTypeName(), ErrorCode, moab::Core::get_entities_by_dimension(), moab::Core::load_file(), moab::SpatialLocator::local_box(), moab::SpatialLocator::locate_point(), mb, MB_CHK_ERR, MB_CHK_SET_ERR, moab::Range::size(), test_file_name, tree, and moab::Core::type_from_handle().
int num_queries = 1000000;
if( argc > 3 )
cout << "Usage: " << argv[0] << " <filename> [num_queries]" << endl;
return 0;
else if( argc == 3 )
test_file_name = argv[1];
num_queries = atoi( argv[2] );
else
num_queries = 100;
// Instantiate
Core mb;
// Load the file
ErrorCode rval = mb.load_file( test_file_name.c_str() );MB_CHK_SET_ERR( rval, "Error loading file" );
// Get all 3d elements in the file
Range elems;
rval = mb.get_entities_by_dimension( 0, 3, elems );MB_CHK_SET_ERR( rval, "Error getting 3d elements" );
// Create a tree to use for the location service
AdaptiveKDTree tree( &mb );
// Specify an evaluator based on linear hexes
ElemEvaluator el_eval( &mb );
// Build the SpatialLocator
SpatialLocator sl( &mb, elems, &tree );
// Get the box extents
CartVect box_extents, pos;
BoundBox box = sl.local_box();
box_extents = box.bMax - box.bMin;
// Query at random places in the tree
CartVect params;
int is_inside = 0;
int num_inside = 0;
EntityHandle elem;
for( int i = 0; i < num_queries; i++ )
pos = box.bMin + CartVect( box_extents[0] * .01 * ( rand() % 100 ), box_extents[1] * .01 * ( rand() % 100 ),
box_extents[2] * .01 * ( rand() % 100 ) );
rval = sl.locate_point( pos.array(), elem, params.array(), &is_inside, 0.0, 0.0 );MB_CHK_ERR( rval );
if( is_inside ) num_inside++;
cout << "Mesh contains " << elems.size() << " elements of type "
<< CN::EntityTypeName( mb.type_from_handle( *elems.begin() ) ) << endl;
cout << "Bounding box min-max = (" << box.bMin[0] << "," << box.bMin[1] << "," << box.bMin[2] << ")-("
<< box.bMax[0] << "," << box.bMax[1] << "," << box.bMax[2] << ")" << endl;
cout << "Queries inside box = " << num_inside << "/" << num_queries << " = "
<< 100.0 * ( (double)num_inside ) / num_queries << "%" << endl;
return 0;
| string test_file_name = string( MESH_DIR ) + string( "/mbtest1.vtk" ) |
Definition at line 27 of file PointInElementSearch.cpp.
