MOAB: Mesh Oriented datABase
(version 5.4.1)
00001 /** 00002 * MOAB, a Mesh-Oriented datABase, is a software component for creating, 00003 * storing and accessing finite element mesh data. 00004 * 00005 * Copyright 2004 Sandia Corporation. Under the terms of Contract 00006 * DE-AC04-94AL85000 with Sandia Corporation, the U.S. Government 00007 * retains certain rights in this software. 00008 * 00009 * This library is free software; you can redistribute it and/or 00010 * modify it under the terms of the GNU Lesser General Public 00011 * License as published by the Free Software Foundation; either 00012 * version 2.1 of the License, or (at your option) any later version. 00013 * 00014 */ 00015 00016 /** 00017 * \class moab::CN 00018 * \author Tim Tautges 00019 * \date April 2004 00020 * 00021 * \brief Canonical numbering data and functions 00022 * This class represents canonical ordering of finite-element meshes. 00023 * Elements in the finite element "zoo" are represented. Canonical numbering 00024 * denotes the vertex, edge, and face numbers making up each kind of element, 00025 * and the vertex numbers defining those entities. Functions for evaluating 00026 * adjacencies and other things based on vertex numbering are also provided. 00027 * By default, this class defines a zero-based numbering system. 00028 * For a complete description of this class, see the document "MOAB Canonical 00029 * Numbering Conventions", Timothy J. Tautges, Sandia National Laboratories 00030 * Report #SAND2004-xxxx. 00031 */ 00032 #ifndef MOAB_CN_HPP 00033 #define MOAB_CN_HPP 00034 00035 #include <vector> 00036 #include <algorithm> 00037 #include <cassert> 00038 00039 #include "moab/EntityType.hpp" 00040 00041 #include "moab/win32_config.h" 00042 00043 namespace moab 00044 { 00045 00046 enum 00047 { 00048 //! the maximum number n-1 dimension adjacencies a element may have 00049 MAX_SUB_ENTITIES = 12, 00050 //! the maximum number of nodes an n-1 dimensional element may have 00051 MAX_SUB_ENTITY_VERTICES = 9 00052 }; 00053 00054 typedef std::pair< EntityType, EntityType > DimensionPair; 00055 00056 class CN 00057 { 00058 private: 00059 //! entity names 00060 static MOAB_EXPORT const char* entityTypeNames[]; 00061 00062 //! declare private constructor, since we don't want to create any of these 00063 CN(); 00064 00065 //! the basis of the numbering system (normally 0 or 1, 0 by default) 00066 static MOAB_EXPORT short int numberBasis; 00067 00068 //! switch the basis 00069 static void SwitchBasis( const int old_basis, const int new_basis ); 00070 00071 static MOAB_EXPORT short increasingInts[]; 00072 00073 public: 00074 enum 00075 { 00076 MAX_NODES_PER_ELEMENT = 27 00077 }; 00078 enum 00079 { 00080 MID_EDGE_BIT = 1 << 1, 00081 MID_FACE_BIT = 1 << 2, 00082 MID_REGION_BIT = 1 << 3 00083 }; 00084 00085 //! enum used to specify operation type 00086 enum 00087 { 00088 INTERSECT = 0, 00089 UNION 00090 }; 00091 00092 // each entity type has two ConnMap objects, holding information about the bounding 00093 // edges and faces for each entity; see comment for mConnectivityMap 00094 // (this struct not documented with Doxygen) 00095 struct ConnMap 00096 { 00097 // Topological dimension of this entry 00098 short int topo_dimension; 00099 00100 // Number of sub-elements of this dimension 00101 short int num_sub_elements; 00102 00103 // Number of nodes in each sub-element of this dimension 00104 short int num_corners_per_sub_element[MAX_SUB_ENTITIES]; 00105 00106 // Type of each sub-element 00107 EntityType target_type[MAX_SUB_ENTITIES]; 00108 00109 // Connectivity of each of the sub-elements 00110 short int conn[MAX_SUB_ENTITIES][MAX_SUB_ENTITY_VERTICES]; 00111 }; 00112 00113 // mConnectivityMap[i=entity type][j=0,1,2]: 00114 // num_sub_elements = # bounding edges(j=0) or faces(j=1) for entity type i, or self (j=2) 00115 // num_corners_per_sub_element[k] (k=0..num_sub_elements-1) = number of nodes in sub-facet k 00116 // (can vary over sub-facets, e.g. faces bounding a pyramid) or self (j=2) 00117 // target_type[k] = entity type of sub-facet k (e.g. MBTRI or MBQUAD bounding a pyramid) or 00118 // self (j=2) conn[k][l] (l=0..CN::VerticesPerEntity[target_type[k]]) = vertex connectivity of 00119 // sub-facet k, 00120 // with respect to entity i's canonical vertex ordering, or self (j=2) 00121 // (not documented with Doxygen) 00122 static MOAB_EXPORT const ConnMap mConnectivityMap[MBMAXTYPE][3]; 00123 00124 // structure used to define reverse canonical ordering information 00125 // (not documented with Doxygen) 00126 struct UpConnMap 00127 { 00128 // Number of higher-dimensional entities using each sub-entity 00129 short int num_targets_per_source_element[MAX_SUB_ENTITIES]; 00130 00131 // Higher-dimensional entities using each sub-entity 00132 short int targets_per_source_element[MAX_SUB_ENTITIES][MAX_SUB_ENTITIES]; 00133 }; 00134 00135 // Reverse canonical numbering, duplicates data in mConnectivityMap, but 00136 // connectivity data in this table must be in ascending order (used for 00137 // efficient sorting) 00138 // (not documented with Doxygen) 00139 static const UpConnMap mUpConnMap[MBMAXTYPE][4][4]; 00140 00141 // Mid-node bits indexed by number of nodes in element 00142 static MOAB_EXPORT const unsigned char midNodesPerType[MBMAXTYPE][MAX_NODES_PER_ELEMENT + 1]; 00143 00144 //! Permutation and reverse permutation vectors 00145 static short int permuteVec[MBMAXTYPE][3][MAX_SUB_ENTITIES + 1]; 00146 static short int revPermuteVec[MBMAXTYPE][3][MAX_SUB_ENTITIES + 1]; 00147 00148 //! this const vector defines the starting and ending EntityType for 00149 //! each dimension, e.g. TypeDimensionMap[2] returns a pair of EntityTypes 00150 //! bounding dimension 2. 00151 static MOAB_EXPORT const DimensionPair TypeDimensionMap[]; 00152 00153 /// Get the dimension pair corresponding to a dimension 00154 static DimensionPair getDimPair( int entity_type ); 00155 00156 //! get the basis of the numbering system 00157 static short int GetBasis(); 00158 00159 //! set the basis of the numbering system 00160 static void SetBasis( const int in_basis ); 00161 00162 //! return the string type name for this type 00163 static const char* EntityTypeName( const EntityType this_type ); 00164 00165 //! given a name, find the corresponding entity type 00166 static EntityType EntityTypeFromName( const char* name ); 00167 00168 //! return the topological entity dimension 00169 static short int Dimension( const EntityType t ); 00170 00171 //! return the number of (corner) vertices contained in the specified type. 00172 static short int VerticesPerEntity( const EntityType t ); 00173 00174 //! return the number of sub-entities bounding the entity. 00175 static short int NumSubEntities( const EntityType t, const int d ); 00176 00177 //! return the type of a particular sub-entity. 00178 //! \param this_type Type of entity for which sub-entity type is being queried 00179 //! \param sub_dimension Topological dimension of sub-entity whose type is being queried 00180 //! \param index Index of sub-entity whose type is being queried 00181 //! \return type Entity type of sub-entity with specified dimension and index 00182 static EntityType SubEntityType( const EntityType this_type, const int sub_dimension, const int index ); 00183 00184 //! return the vertex indices of the specified sub-entity. 00185 //! \param this_type Type of entity for which sub-entity connectivity is being queried 00186 //! \param sub_dimension Dimension of sub-entity 00187 //! \param sub_index Index of sub-entity 00188 //! \param sub_entity_conn Connectivity of sub-entity (returned to calling function) 00189 static void inline SubEntityVertexIndices( const EntityType this_type, 00190 const int sub_dimension, 00191 const int sub_index, 00192 int sub_entity_conn[] ); 00193 00194 //! return the vertex indices of the specified sub-entity. 00195 //! \param this_type Type of entity for which sub-entity connectivity is being queried 00196 //! \param sub_dimension Dimension of sub-entity 00197 //! \param sub_index Index of sub-entity 00198 //! \param num_sub_ent_vertices the number of vertices in the sub-entity 00199 static const short* SubEntityVertexIndices( const EntityType this_type, 00200 const int sub_dimension, 00201 const int sub_index, 00202 EntityType& sub_type, 00203 int& num_sub_ent_vertices ); 00204 00205 //! return the node indices of the specified sub-entity. 00206 //! \param this_topo The topology of the queried element type 00207 //! \param num_nodes The number of nodes in the queried element type. 00208 //! \param sub_dimension Dimension of sub-entity 00209 //! \param sub_index Index of sub-entity 00210 //! \param sub_entity_topo (Output) Topology of requested sub-entity. 00211 //! \param num_sub_entity_nodes (Output) Number of nodes in the requested sub-entity. 00212 //! \param sub_entity_conn (Output) Connectivity of sub-entity 00213 static void SubEntityNodeIndices( const EntityType this_topo, 00214 const int num_nodes, 00215 const int sub_dimension, 00216 const int sub_index, 00217 EntityType& sub_entity_topo, 00218 int& num_sub_entity_nodes, 00219 int sub_entity_conn[] ); 00220 00221 //! return the vertices of the specified sub entity 00222 //! \param parent_conn Connectivity of parent entity 00223 //! \param parent_type Entity type of parent entity 00224 //! \param sub_dimension Dimension of sub-entity being queried 00225 //! \param sub_index Index of sub-entity being queried 00226 //! \param sub_entity_conn Connectivity of sub-entity, based on parent_conn and canonical 00227 //! ordering for parent_type 00228 //! \param num_sub_vertices Number of vertices in sub-entity 00229 static void SubEntityConn( const void* parent_conn, 00230 const EntityType parent_type, 00231 const int sub_dimension, 00232 const int sub_index, 00233 void* sub_entity_conn, 00234 int& num_sub_vertices ); 00235 00236 //! For a specified set of sides of given dimension, return the intersection 00237 //! or union of all sides of specified target dimension adjacent to those sides. 00238 //! \param this_type Type of entity for which sub-entity connectivity is being queried 00239 //! \param source_indices Indices of sides being queried 00240 //! \param num_source_indices Number of entries in <em>source_indices</em> 00241 //! \param source_dim Dimension of source entity 00242 //! \param target_dim Dimension of target entity 00243 //! \param index_list Indices of target entities (returned) 00244 //! \param operation_type Specify either CN::INTERSECT or CN::UNION to get intersection 00245 //! or union of target entity lists over source entities 00246 static short int AdjacentSubEntities( const EntityType this_type, 00247 const int* source_indices, 00248 const int num_source_indices, 00249 const int source_dim, 00250 const int target_dim, 00251 std::vector< int >& index_list, 00252 const int operation_type = CN::INTERSECT ); 00253 00254 //! return the side index represented in the input sub-entity connectivity in the input 00255 //! parent entity connectivity array. 00256 //! \param parent_conn Connectivity of parent entity being queried 00257 //! \param parent_type Entity type of parent entity 00258 //! \param child_conn Connectivity of child whose index is being queried 00259 //! \param child_num_verts Number of vertices in <em>child_conn</em> 00260 //! \param child_dim Dimension of child entity being queried 00261 //! \param side_number Side number of child entity (returned) 00262 //! \param sense Sense of child entity with respect to order in <em>child_conn</em> (returned) 00263 //! \param offset Offset of <em>child_conn</em> with respect to canonical ordering data 00264 //! (returned) \return status Returns zero if successful, -1 if not 00265 static short int SideNumber( const EntityType parent_type, 00266 const int* parent_conn, 00267 const int* child_conn, 00268 const int child_num_verts, 00269 const int child_dim, 00270 int& side_number, 00271 int& sense, 00272 int& offset ); 00273 static short int SideNumber( const EntityType parent_type, 00274 const unsigned int* parent_conn, 00275 const unsigned int* child_conn, 00276 const int child_num_verts, 00277 const int child_dim, 00278 int& side_number, 00279 int& sense, 00280 int& offset ); 00281 static short int SideNumber( const EntityType parent_type, 00282 const long* parent_conn, 00283 const long* child_conn, 00284 const int child_num_verts, 00285 const int child_dim, 00286 int& side_number, 00287 int& sense, 00288 int& offset ); 00289 static short int SideNumber( const EntityType parent_type, 00290 const unsigned long* parent_conn, 00291 const unsigned long* child_conn, 00292 const int child_num_verts, 00293 const int child_dim, 00294 int& side_number, 00295 int& sense, 00296 int& offset ); 00297 static short int SideNumber( const EntityType parent_type, 00298 const unsigned long long* parent_conn, 00299 const unsigned long long* child_conn, 00300 const int child_num_verts, 00301 const int child_dim, 00302 int& side_number, 00303 int& sense, 00304 int& offset ); 00305 static short int SideNumber( const EntityType parent_type, 00306 void* const* parent_conn, 00307 void* const* child_conn, 00308 const int child_num_verts, 00309 const int child_dim, 00310 int& side_number, 00311 int& sense, 00312 int& offset ); 00313 00314 //! return the side index represented in the input sub-entity connectivity 00315 //! \param parent_type Entity type of parent entity 00316 //! \param child_conn_indices Child connectivity to query, specified as indices 00317 //! into the connectivity list of the parent. 00318 //! \param child_num_verts Number of values in <em>child_conn_indices</em> 00319 //! \param child_dim Dimension of child entity being queried 00320 //! \param side_number Side number of child entity (returned) 00321 //! \param sense Sense of child entity with respect to order in <em>child_conn</em> (returned) 00322 //! \param offset Offset of <em>child_conn</em> with respect to canonical ordering data 00323 //! (returned) \return status Returns zero if successful, -1 if not 00324 static short int SideNumber( const EntityType parent_type, 00325 const int* child_conn_indices, 00326 const int child_num_verts, 00327 const int child_dim, 00328 int& side_number, 00329 int& sense, 00330 int& offset ); 00331 00332 //! return the dimension and index of the opposite side, given parent entity type and child 00333 //! dimension and index. This function is only defined for certain types of parent/child types: 00334 //! (Parent, Child dim->Opposite dim): 00335 //! (Tri, 1->0), (Tri, 0->1), (Quad, 1->1), (Quad, 0->0), 00336 //! (Tet, 2->0), (Tet, 1->1), (Tet, 0->2), 00337 //! (Hex, 2->2), (Hex, 1->1)(diagonally across element), (Hex, 0->0) (diagonally across 00338 //! element) 00339 //! All other parent types and child dimensions return an error. 00340 //! 00341 //! \param parent_type The type of parent element 00342 //! \param child_type The type of child element 00343 //! \param child_index The index of the child element 00344 //! \param opposite_index The index of the opposite element 00345 //! \return status Returns 0 if successful, -1 if not 00346 static short int OppositeSide( const EntityType parent_type, 00347 const int child_index, 00348 const int child_dim, 00349 int& opposite_index, 00350 int& opposite_dim ); 00351 00352 //! given two connectivity arrays, determine whether or not they represent the same entity. 00353 //! \param conn1 Connectivity array of first entity 00354 //! \param conn2 Connectivity array of second entity 00355 //! \param num_vertices Number of entries in <em>conn1</em> and <em>conn2</em> 00356 //! \param direct If positive, entities have the same sense (returned) 00357 //! \param offset Offset of <em>conn2</em>'s first vertex in <em>conn1</em> 00358 //! \return bool Returns true if <em>conn1</em> and <em>conn2</em> match 00359 static bool ConnectivityMatch( const int* conn1, 00360 const int* conn2, 00361 const int num_vertices, 00362 int& direct, 00363 int& offset ); 00364 static bool ConnectivityMatch( const unsigned int* conn1, 00365 const unsigned int* conn2, 00366 const int num_vertices, 00367 int& direct, 00368 int& offset ); 00369 static bool ConnectivityMatch( const long* conn1, 00370 const long* conn2, 00371 const int num_vertices, 00372 int& direct, 00373 int& offset ); 00374 static bool ConnectivityMatch( const unsigned long* conn1, 00375 const unsigned long* conn2, 00376 const int num_vertices, 00377 int& direct, 00378 int& offset ); 00379 static bool ConnectivityMatch( const unsigned long long* conn1, 00380 const unsigned long long* conn2, 00381 const int num_vertices, 00382 int& direct, 00383 int& offset ); 00384 static bool ConnectivityMatch( void* const* conn1, 00385 void* const* conn2, 00386 const int num_vertices, 00387 int& direct, 00388 int& offset ); 00389 00390 //! Set permutation or reverse permutation vector 00391 //! Forward permutation is from CN's numbering into application's ordering; 00392 //! that is, if i is CN's index, pvec[i] is application's index. This 00393 //! function stores the permutation vector for this type and facet dimension, 00394 //! which then is used in calls to permuteThis or revPermuteThis. 00395 //! \param t EntityType for which to set permutation 00396 //! \param dim Dimension of facets whose permutation array is being set 00397 //! \param pvec Permutation array 00398 //! \param num_entries Number of indicies in permutation array 00399 //! \param is_reverse Array is reverse permutation 00400 static inline void setPermutation( const EntityType t, 00401 const int dim, 00402 short int* pvec, 00403 const int num_entries, 00404 const bool is_reverse = false ); 00405 00406 //! Reset permutation or reverse permutation vector 00407 //! \param t EntityType whose permutation vector is being reset 00408 //! \param dim Dimension of facets being reset; if -1 is input, all dimensions are reset 00409 static inline void resetPermutation( const EntityType t, const int dim ); 00410 00411 //! Permute a handle array according to permutation vector set with setPermute; 00412 //! permutation is done in-place 00413 //! \param t EntityType of handles in pvec 00414 //! \param dim Dimension of handles in pvec 00415 //! \param pvec Handle array being permuted 00416 //! \param indices_per_ent Number of indices per entity 00417 //! \param num_entries Number of entities in pvec 00418 static int permuteThis( const EntityType t, 00419 const int dim, 00420 int* pvec, 00421 const int indices_per_ent, 00422 const int num_entries ); 00423 static int permuteThis( const EntityType t, 00424 const int dim, 00425 unsigned int* pvec, 00426 const int indices_per_ent, 00427 const int num_entries ); 00428 static int permuteThis( const EntityType t, 00429 const int dim, 00430 long* pvec, 00431 const int indices_per_ent, 00432 const int num_entries ); 00433 static int permuteThis( const EntityType t, 00434 const int dim, 00435 void** pvec, 00436 const int indices_per_ent, 00437 const int num_entries ); 00438 00439 //! Reverse permute a handle array according to reverse permutation vector set with setPermute; 00440 //! reverse permutation is done in-place 00441 //! \param t EntityType of handles in pvec 00442 //! \param dim Dimension of handles in pvec 00443 //! \param pvec Handle array being reverse permuted 00444 //! \param indices_per_ent Number of indices per entity 00445 //! \param num_entries Number of entities in pvec 00446 static int revPermuteThis( const EntityType t, 00447 const int dim, 00448 int* pvec, 00449 const int indices_per_ent, 00450 const int num_entries ); 00451 static int revPermuteThis( const EntityType t, 00452 const int dim, 00453 unsigned int* pvec, 00454 const int indices_per_ent, 00455 const int num_entries ); 00456 static int revPermuteThis( const EntityType t, 00457 const int dim, 00458 long* pvec, 00459 const int indices_per_ent, 00460 const int num_entries ); 00461 static int revPermuteThis( const EntityType t, 00462 const int dim, 00463 void** pvec, 00464 const int indices_per_ent, 00465 const int num_entries ); 00466 00467 //! true if entities of a given type and number of nodes indicates mid edge nodes are present. 00468 //! \param this_type Type of entity for which sub-entity connectivity is being queried 00469 //! \param num_verts Number of nodes defining entity 00470 //! \return bool Returns true if <em>this_type</em> combined with <em>num_nodes</em> indicates 00471 //! mid-edge nodes are likely 00472 static inline bool HasMidEdgeNodes( const EntityType this_type, const int num_verts ); 00473 00474 //! true if entities of a given type and number of nodes indicates mid face nodes are present. 00475 //! \param this_type Type of entity for which sub-entity connectivity is being queried 00476 //! \param num_verts Number of nodes defining entity 00477 //! \return bool Returns true if <em>this_type</em> combined with <em>num_nodes</em> indicates 00478 //! mid-face nodes are likely 00479 static inline bool HasMidFaceNodes( const EntityType this_type, const int num_verts ); 00480 00481 //! true if entities of a given type and number of nodes indicates mid region nodes are present. 00482 //! \param this_type Type of entity for which sub-entity connectivity is being queried 00483 //! \param num_verts Number of nodes defining entity 00484 //! \return bool Returns true if <em>this_type</em> combined with <em>num_nodes</em> indicates 00485 //! mid-region nodes are likely 00486 static inline bool HasMidRegionNodes( const EntityType this_type, const int num_verts ); 00487 00488 //! true if entities of a given type and number of nodes indicates mid edge/face/region nodes 00489 //! are present. 00490 //! \param this_type Type of entity for which sub-entity connectivity is being queried 00491 //! \param num_verts Number of nodes defining entity 00492 //! \param mid_nodes If <em>mid_nodes[i], i=1..2</em> is non-zero, indicates that mid-edge 00493 //! (i=1), mid-face (i=2), and/or mid-region (i=3) nodes are likely 00494 static inline void HasMidNodes( const EntityType this_type, const int num_verts, int mid_nodes[4] ); 00495 00496 //! Same as above, except returns a single integer with the bits, from 00497 //! least significant to most significant set to one if the corresponding 00498 //! mid nodes on sub entities of the least dimension (0) to the highest 00499 //! dimension (3) are present in the elment type. 00500 static inline int HasMidNodes( const EntityType this_type, const int num_verts ); 00501 00502 //! given data about an element and a vertex in that element, return the dimension 00503 //! and index of the sub-entity that the vertex resolves. If it does not resolve a 00504 //! sub-entity, either because it's a corner node or it's not in the element, -1 is 00505 //! returned in both return values. 00506 //! \param elem_type Type of entity being queried 00507 //! \param num_nodes The number of nodes in the element connectivity 00508 //! \param ho_node_index The position of the HO node in the connectivity list (zero based) 00509 //! \param parent_dim Dimension of sub-entity high-order node resolves (returned) 00510 //! \param parent_index Index of sub-entity high-order node resolves (returned) 00511 static void HONodeParent( EntityType elem_type, 00512 int num_nodes, 00513 int ho_node_index, 00514 int& parent_dim, 00515 int& parent_index ); 00516 00517 //! for an entity of this type with num_verts vertices, and a specified subfacet 00518 //! (dimension and index), return the index of the higher order node for that entity 00519 //! in this entity's connectivity array 00520 //! \param this_type Type of entity being queried 00521 //! \param num_verts Number of vertices for the entity being queried 00522 //! \param subfacet_dim Dimension of sub-entity being queried 00523 //! \param subfacet_index Index of sub-entity being queried 00524 //! \return index Index of sub-entity's higher-order node 00525 static short int HONodeIndex( const EntityType this_type, 00526 const int num_verts, 00527 const int subfacet_dim, 00528 const int subfacet_index ); 00529 }; 00530 00531 //! get the basis of the numbering system 00532 inline short int CN::GetBasis() 00533 { 00534 return numberBasis; 00535 } 00536 00537 //! return the connectivity of the specified sub-entity. 00538 inline void CN::SubEntityVertexIndices( const EntityType this_type, 00539 const int sub_dimension, 00540 const int index, 00541 int sub_entity_conn[] ) 00542 { 00543 EntityType type; 00544 int n; 00545 const short* indices = SubEntityVertexIndices( this_type, sub_dimension, index, type, n ); 00546 std::copy( indices, indices + n, sub_entity_conn ); 00547 } 00548 00549 inline bool CN::HasMidEdgeNodes( const EntityType this_type, const int num_nodes ) 00550 { 00551 const int bits = HasMidNodes( this_type, num_nodes ); 00552 return static_cast< bool >( ( bits & ( 1 << 1 ) ) >> 1 ); 00553 } 00554 00555 inline bool CN::HasMidFaceNodes( const EntityType this_type, const int num_nodes ) 00556 { 00557 const int bits = HasMidNodes( this_type, num_nodes ); 00558 return static_cast< bool >( ( bits & ( 1 << 2 ) ) >> 2 ); 00559 } 00560 00561 inline bool CN::HasMidRegionNodes( const EntityType this_type, const int num_nodes ) 00562 { 00563 const int bits = HasMidNodes( this_type, num_nodes ); 00564 return static_cast< bool >( ( bits & ( 1 << 3 ) ) >> 3 ); 00565 } 00566 00567 inline int CN::HasMidNodes( const EntityType this_type, const int num_nodes ) 00568 { 00569 assert( (unsigned)num_nodes <= (unsigned)MAX_NODES_PER_ELEMENT ); 00570 return midNodesPerType[this_type][num_nodes]; 00571 } 00572 00573 inline void CN::HasMidNodes( const EntityType this_type, const int num_nodes, int mid_nodes[4] ) 00574 { 00575 const int bits = HasMidNodes( this_type, num_nodes ); 00576 mid_nodes[0] = 0; 00577 mid_nodes[1] = ( bits & ( 1 << 1 ) ) >> 1; 00578 mid_nodes[2] = ( bits & ( 1 << 2 ) ) >> 2; 00579 mid_nodes[3] = ( bits & ( 1 << 3 ) ) >> 3; 00580 } 00581 00582 //! Set permutation or reverse permutation vector 00583 inline void CN::setPermutation( const EntityType t, 00584 const int dim, 00585 short int* pvec, 00586 const int num_entries, 00587 const bool is_reverse ) 00588 { 00589 short int *this_vec = permuteVec[t][dim], *that_vec = revPermuteVec[t][dim]; 00590 if( is_reverse ) 00591 { 00592 this_vec = revPermuteVec[t][dim]; 00593 that_vec = permuteVec[t][dim]; 00594 } 00595 00596 for( short int i = 0; i < num_entries; i++ ) 00597 { 00598 this_vec[i] = pvec[i]; 00599 that_vec[pvec[i]] = i; 00600 } 00601 00602 this_vec[MAX_SUB_ENTITIES] = that_vec[MAX_SUB_ENTITIES] = (short)num_entries; 00603 } 00604 00605 //! Reset permutation or reverse permutation vector 00606 inline void CN::resetPermutation( const EntityType t, const int dim ) 00607 { 00608 if( -1 == dim ) 00609 { 00610 for( unsigned int i = 0; i < 3; i++ ) 00611 resetPermutation( t, i ); 00612 return; 00613 } 00614 00615 for( short unsigned int i = 0; i < MAX_SUB_ENTITIES; i++ ) 00616 { 00617 revPermuteVec[t][dim][i] = permuteVec[t][dim][i] = i; 00618 } 00619 00620 revPermuteVec[t][dim][MAX_SUB_ENTITIES] = permuteVec[t][dim][MAX_SUB_ENTITIES] = MAX_SUB_ENTITIES + 1; 00621 } 00622 00623 } // namespace moab 00624 00625 #endif
