MOAB: Mesh Oriented datABase
(version 5.4.1)
00001 #ifndef ELEM_EVALUATOR_HPP 00002 #define ELEM_EVALUATOR_HPP 00003 00004 #include "moab/Interface.hpp" 00005 #include "moab/CartVect.hpp" 00006 #include "moab/Matrix3.hpp" 00007 #include "moab/CN.hpp" 00008 00009 #include <vector> 00010 00011 namespace moab 00012 { 00013 00014 typedef ErrorCode ( *EvalFcn )( const double* params, 00015 const double* field, 00016 const int ndim, 00017 const int num_tuples, 00018 double* work, 00019 double* result ); 00020 00021 typedef ErrorCode ( *JacobianFcn )( const double* params, 00022 const double* verts, 00023 const int nverts, 00024 const int ndim, 00025 double* work, 00026 double* result ); 00027 00028 typedef ErrorCode ( *IntegrateFcn )( const double* field, 00029 const double* verts, 00030 const int nverts, 00031 const int ndim, 00032 const int num_tuples, 00033 double* work, 00034 double* result ); 00035 00036 typedef ErrorCode ( *InitFcn )( const double* verts, const int nverts, double*& work ); 00037 00038 typedef int ( *InsideFcn )( const double* verts, const int ndims, const double tol ); 00039 00040 typedef ErrorCode ( *ReverseEvalFcn )( EvalFcn eval, 00041 JacobianFcn jacob, 00042 InsideFcn ins, 00043 const double* posn, 00044 const double* verts, 00045 const int nverts, 00046 const int ndim, 00047 const double iter_tol, 00048 const double inside_tol, 00049 double* work, 00050 double* params, 00051 int* is_inside ); 00052 00053 typedef ErrorCode ( 00054 *NormalFcn )( const int ientDim, const int facet, const int nverts, const double* verts, double normal[3] ); 00055 00056 class EvalSet 00057 { 00058 public: 00059 /** \brief Forward-evaluation of field at parametric coordinates */ 00060 EvalFcn evalFcn; 00061 00062 /** \brief Reverse-evaluation of parametric coordinates at physical space position */ 00063 ReverseEvalFcn reverseEvalFcn; 00064 00065 /** \brief Evaluate the normal at a local facet (edge/face for 2D/3D) */ 00066 NormalFcn normalFcn; 00067 00068 /** \brief Evaluate the jacobian at a specified parametric position */ 00069 JacobianFcn jacobianFcn; 00070 00071 /** \brief Forward-evaluation of field at parametric coordinates */ 00072 IntegrateFcn integrateFcn; 00073 00074 /** \brief Initialization function for an element */ 00075 InitFcn initFcn; 00076 00077 /** \brief Function that returns whether or not the parameters are inside the natural space of 00078 * the element */ 00079 InsideFcn insideFcn; 00080 00081 /** \brief Bare constructor */ 00082 EvalSet() 00083 : evalFcn( NULL ), reverseEvalFcn( NULL ), normalFcn( NULL ), jacobianFcn( NULL ), integrateFcn( NULL ), 00084 initFcn( NULL ), insideFcn( NULL ) 00085 { 00086 } 00087 00088 /** \brief Constructor */ 00089 EvalSet( EvalFcn eval, 00090 ReverseEvalFcn rev, 00091 NormalFcn normal, 00092 JacobianFcn jacob, 00093 IntegrateFcn integ, 00094 InitFcn initf, 00095 InsideFcn insidef ) 00096 : evalFcn( eval ), reverseEvalFcn( rev ), normalFcn( normal ), jacobianFcn( jacob ), integrateFcn( integ ), 00097 initFcn( initf ), insideFcn( insidef ) 00098 { 00099 } 00100 00101 /** \brief Copy constructor */ 00102 EvalSet( EvalSet const& eval ) 00103 : evalFcn( eval.evalFcn ), reverseEvalFcn( eval.reverseEvalFcn ), normalFcn( eval.normalFcn ), 00104 jacobianFcn( eval.jacobianFcn ), integrateFcn( eval.integrateFcn ), initFcn( eval.initFcn ), 00105 insideFcn( eval.insideFcn ) 00106 { 00107 } 00108 00109 /** \brief Given an entity handle, get an appropriate eval set, based on type & #vertices */ 00110 static ErrorCode get_eval_set( Interface* mb, EntityHandle eh, EvalSet& eval_set ); 00111 00112 /** \brief Given type & #vertices, get an appropriate eval set */ 00113 static ErrorCode get_eval_set( EntityType tp, unsigned int num_vertices, EvalSet& eval_set ); 00114 00115 /** \brief Operator= */ 00116 EvalSet& operator=( const EvalSet& eval ) 00117 { 00118 evalFcn = eval.evalFcn; 00119 reverseEvalFcn = eval.reverseEvalFcn; 00120 normalFcn = eval.normalFcn; 00121 jacobianFcn = eval.jacobianFcn; 00122 integrateFcn = eval.integrateFcn; 00123 initFcn = eval.initFcn; 00124 insideFcn = eval.insideFcn; 00125 return *this; 00126 } 00127 00128 /** \brief Common function to do reverse evaluation based on evaluation and jacobian functions 00129 */ 00130 static ErrorCode evaluate_reverse( EvalFcn eval, 00131 JacobianFcn jacob, 00132 InsideFcn inside_f, 00133 const double* posn, 00134 const double* verts, 00135 const int nverts, 00136 const int ndim, 00137 const double iter_tol, 00138 const double inside_tol, 00139 double* work, 00140 double* params, 00141 int* inside ); 00142 /** \brief Common function that returns true if params is in [-1,1]^ndims */ 00143 static int inside_function( const double* params, const int ndims, const double tol ); 00144 }; 00145 00146 /** \brief Given an entity handle, get an appropriate eval set, based on type & #vertices */ 00147 inline ErrorCode EvalSet::get_eval_set( Interface* mb, EntityHandle eh, EvalSet& eval_set ) 00148 { 00149 int nv; 00150 EntityType tp = mb->type_from_handle( eh ); 00151 const EntityHandle* connect; 00152 std::vector< EntityHandle > dum_vec; 00153 ErrorCode rval = mb->get_connectivity( eh, connect, nv, false, &dum_vec ); 00154 if( MB_SUCCESS != rval ) return rval; 00155 00156 return get_eval_set( tp, nv, eval_set ); 00157 } 00158 00159 /**\brief Class facilitating local discretization-related functions 00160 * \class ElemEvaluator 00161 * This class implements discretization-related functionality operating 00162 * on data in MOAB. A member of this class caches certain data about the element 00163 * it's currently operating on, but is not meant to be instantiated one-per-element, 00164 * but rather one-per-search (or other operation on a collection of elements). 00165 * 00166 * Actual discretization functionality is accessed through function pointers, 00167 * allowing applications to specialize the implementation of specific functions 00168 * while still using this class. 00169 * 00170 * This class depends on MOAB functionality for gathering entity-based data; the functions 00171 * it calls through function pointers depend only on POD (plain old data, or intrinsic data types). 00172 * This allows the use of other packages for serving these functions, without having to modify 00173 * them to get data through MOAB. This should also promote efficiency, since in many cases they 00174 * will be able to read data from its native storage locations. 00175 */ 00176 00177 class ElemEvaluator 00178 { 00179 public: 00180 /** \brief Constructor 00181 * \param impl MOAB instance 00182 * \param ent Entity handle to cache on the evaluator; if non-zero, calls set_ent_handle, which 00183 * does some other stuff. \param tag Tag to cache on the evaluator; if non-zero, calls 00184 * set_tag_handle, which does some other stuff too. \param tagged_ent_dim Dimension of entities 00185 * to be tagged to cache on the evaluator 00186 */ 00187 ElemEvaluator( Interface* impl, EntityHandle ent = 0, Tag tag = 0, int tagged_ent_dim = -1 ); 00188 ~ElemEvaluator(); 00189 00190 /** \brief Evaluate cached tag at a given parametric location within the cached entity 00191 * If evaluating coordinates, call set_tag(0, 0), which indicates coords instead of a tag. 00192 * \param params Parameters at which to evaluate field 00193 * \param result Result of evaluation 00194 * \param num_tuples Size of evaluated field, in number of values 00195 */ 00196 ErrorCode eval( const double* params, double* result, int num_tuples = -1 ) const; 00197 00198 /** \brief Reverse-evaluate the cached entity at a given physical position 00199 * \param posn Position at which to evaluate parameters 00200 * \param iter_tol Tolerance of reverse evaluation non-linear iteration, usually 10^-10 or so 00201 * \param inside_tol Tolerance of is_inside evaluation, usually 10^-6 or so 00202 * \param params Result of evaluation 00203 * \param is_inside If non-NULL, returns true of resulting parameters place the point inside the 00204 * element (in most cases, within [-1]*(dim) 00205 */ 00206 ErrorCode reverse_eval( const double* posn, 00207 double iter_tol, 00208 double inside_tol, 00209 double* params, 00210 int* is_inside = NULL ) const; 00211 00212 /** 00213 * \brief Evaluate the normal to a facet of an entity 00214 * \param ientDim Dimension of the facet. Should be (d-1) for d-dimensional entities 00215 * \param facet Local id of the facet w.r.t the entity 00216 * \param normal Returns the normal. 00217 */ 00218 ErrorCode get_normal( const int ientDim, const int facet, double normal[3] ) const; 00219 00220 /** \brief Evaluate the jacobian of the cached entity at a given parametric location 00221 * \param params Parameters at which to evaluate jacobian 00222 * \param result Result of evaluation, in the form of a 3x3 matrix, stored in column-major order 00223 */ 00224 ErrorCode jacobian( const double* params, double* result ) const; 00225 00226 /** \brief Integrate the cached tag over the cached entity 00227 * \param result Result of the integration 00228 */ 00229 ErrorCode integrate( double* result ) const; 00230 00231 /** \brief Return whether a physical position is inside the cached entity to within a tolerance 00232 * \param params Parameters at which to query the element 00233 * \param tol Tolerance, usually 10^-6 or so 00234 */ 00235 int inside( const double* params, const double tol ) const; 00236 00237 /** \brief Given a list of entities, return the entity the point is in, or none 00238 * This function reverse-evaluates the entities, returning the first entity containing the 00239 * point. If no entity contains the point, containing_ent is returned as 0 and params are 00240 * unchanged. This function returns something other than MB_SUCCESS only when queries go wrong 00241 * for some reason. num_evals, if non-NULL, is always incremented for each call to reverse_eval. 00242 * This function calls set_ent_handle for each entity before calling reverse_eval, so the 00243 * ElemEvaluator object is changed. \param entities Entities tested \param point Point tested, 00244 * must have 3 dimensions, even for edge and face entities \param iter_tol Tolerance for 00245 * non-linear reverse evaluation \param inside_tol Tolerance for is_inside test \param 00246 * containing_ent Entity containing the point, returned 0 if no entity \param params Parameters 00247 * of point in containing entity, unchanged if no containing entity \param num_evals If 00248 * non-NULL, incremented each time reverse_eval is called \return Returns non-success only if 00249 * evaulation failed for some reason (point not in element is NOT a reason for failure) 00250 */ 00251 ErrorCode find_containing_entity( Range& entities, 00252 const double* point, 00253 const double iter_tol, 00254 const double inside_tol, 00255 EntityHandle& containing_ent, 00256 double* params, 00257 unsigned int* num_evals = NULL ); 00258 00259 /** \brief Given an entity set, return the contained entity the point is in, or none 00260 * This function reverse-evaluates the entities, returning the first entity containing the 00261 * point. If no entity contains the point, containing_ent is returned as 0 and params are 00262 * unchanged. This function returns something other than MB_SUCCESS only when queries go wrong 00263 * for some reason. num_evals, if non-NULL, is always incremented for each call to reverse_eval. 00264 * This function calls set_ent_handle for each entity before calling reverse_eval, so the 00265 * ElemEvaluator object is changed. \param ent_set Entity set containing the entities to be 00266 * tested \param point Point tested, must have 3 dimensions, even for edge and face entities 00267 * \param iter_tol Tolerance for non-linear reverse evaluation 00268 * \param inside_tol Tolerance for is_inside test 00269 * \param containing_ent Entity containing the point, returned 0 if no entity 00270 * \param params Parameters of point in containing entity, unchanged if no containing entity 00271 * \param num_evals If non-NULL, incremented each time reverse_eval is called 00272 * \return Returns non-success only if evaulation failed for some reason (point not in element 00273 * is NOT a reason for failure) 00274 */ 00275 ErrorCode find_containing_entity( EntityHandle ent_set, 00276 const double* point, 00277 const double iter_tol, 00278 const double inside_tol, 00279 EntityHandle& containing_ent, 00280 double* params, 00281 unsigned int* num_evals = NULL ); 00282 00283 /** \brief Set the eval set for a given type entity 00284 * \param tp Entity type for which to set the eval set 00285 * \param eval_set Eval set object to use 00286 */ 00287 ErrorCode set_eval_set( EntityType tp, const EvalSet& eval_set ); 00288 00289 /** \brief Set the eval set using a given entity handle 00290 * This function queries the entity type and number of vertices on the entity to decide which 00291 * type of shape function to use. NOTE: this function should only be called after setting a 00292 * valid MOAB instance on the evaluator \param eh Entity handle whose type and #vertices are 00293 * queried 00294 */ 00295 ErrorCode set_eval_set( const EntityHandle eh ); 00296 00297 /** \brief Get the eval set for a given type entity */ 00298 inline EvalSet get_eval_set( EntityType tp ) 00299 { 00300 return evalSets[tp]; 00301 } 00302 00303 /** \brief Set entity handle & cache connectivty & vertex positions */ 00304 inline ErrorCode set_ent_handle( EntityHandle ent ); 00305 00306 /** \brief Get entity handle for this ElemEval */ 00307 inline EntityHandle get_ent_handle() const 00308 { 00309 return entHandle; 00310 } 00311 00312 /* \brief Get vertex positions cached on this EE 00313 */ 00314 inline double* get_vert_pos() 00315 { 00316 return vertPos[0].array(); 00317 } 00318 00319 /* \brief Get the vertex handles cached here */ 00320 inline const EntityHandle* get_vert_handles() const 00321 { 00322 return vertHandles; 00323 } 00324 00325 /* \brief Get the number of vertices for the cached entity */ 00326 inline int get_num_verts() const 00327 { 00328 return numVerts; 00329 } 00330 00331 /* \brief Get the tag handle cached on this entity */ 00332 inline Tag get_tag_handle() const 00333 { 00334 return tagHandle; 00335 }; 00336 00337 /* \brief Set the tag handle to cache on this evaluator 00338 * To designate that vertex coordinates are the desired tag, pass in a tag handle of 0 00339 * and a tag dimension of 0. 00340 * \param tag Tag handle to cache, or 0 to cache vertex positions 00341 * \param tagged_ent_dim Dimension of entities tagged with this tag 00342 */ 00343 inline ErrorCode set_tag_handle( Tag tag, int tagged_ent_dim = -1 ); 00344 00345 /* \brief Set the name of the tag to cache on this evaluator 00346 * To designate that vertex coordinates are the desired tag, pass in "COORDS" as the name 00347 * and a tag dimension of 0. 00348 * \param tag_name Tag handle to cache, or 0 to cache vertex positions 00349 * \param tagged_ent_dim Dimension of entities tagged with this tag 00350 */ 00351 inline ErrorCode set_tag( const char* tag_name, int tagged_ent_dim = -1 ); 00352 00353 /* \brief Get the dimension of the entities on which tag is set */ 00354 inline int get_tagged_ent_dim() const 00355 { 00356 return taggedEntDim; 00357 }; 00358 00359 /* \brief Set the dimension of entities having the tag */ 00360 inline ErrorCode set_tagged_ent_dim( int dim ); 00361 00362 /* \brief Get work space, sometimes this is useful for evaluating data you don't want to set as 00363 * tags on entities Can't be const because most of the functions (evaluate, integrate, etc.) 00364 * take non-const work space *'s 00365 */ 00366 inline double* get_work_space() 00367 { 00368 return workSpace; 00369 } 00370 00371 /* \brief MOAB interface cached on this evaluator */ 00372 inline Interface* get_moab() 00373 { 00374 return mbImpl; 00375 } 00376 00377 private: 00378 /** \brief Interface */ 00379 Interface* mbImpl; 00380 00381 /** \brief Entity handle being evaluated */ 00382 EntityHandle entHandle; 00383 00384 /** \brief Entity type */ 00385 EntityType entType; 00386 00387 /** \brief Entity dimension */ 00388 int entDim; 00389 00390 /** \brief Number of vertices cached here */ 00391 int numVerts; 00392 00393 /** \brief Cached copy of vertex handle ptr */ 00394 const EntityHandle* vertHandles; 00395 00396 /** \brief Cached copy of vertex positions */ 00397 CartVect vertPos[CN::MAX_NODES_PER_ELEMENT]; 00398 00399 /** \brief Tag being evaluated */ 00400 Tag tagHandle; 00401 00402 /** \brief Whether tag is coordinates or something else */ 00403 bool tagCoords; 00404 00405 /** \brief Number of values in this tag */ 00406 int numTuples; 00407 00408 /** \brief Dimension of entities from which to grab tag */ 00409 int taggedEntDim; 00410 00411 /** \brief Tag space */ 00412 std::vector< unsigned char > tagSpace; 00413 00414 /** \brief Evaluation methods for elements of various topologies */ 00415 EvalSet evalSets[MBMAXTYPE]; 00416 00417 /** \brief Work space for element-specific data */ 00418 double* workSpace; 00419 00420 }; // class ElemEvaluator 00421 00422 inline ElemEvaluator::ElemEvaluator( Interface* impl, EntityHandle ent, Tag tag, int tagged_ent_dim ) 00423 : mbImpl( impl ), entHandle( 0 ), entType( MBMAXTYPE ), entDim( -1 ), numVerts( 0 ), vertHandles( NULL ), 00424 tagHandle( 0 ), tagCoords( false ), numTuples( 0 ), taggedEntDim( 0 ), workSpace( NULL ) 00425 { 00426 if( ent ) set_ent_handle( ent ); 00427 if( tag ) set_tag_handle( tag, tagged_ent_dim ); 00428 } 00429 00430 inline ElemEvaluator::~ElemEvaluator() 00431 { 00432 if( workSpace ) delete[] workSpace; 00433 } 00434 00435 inline ErrorCode ElemEvaluator::set_ent_handle( EntityHandle ent ) 00436 { 00437 entHandle = ent; 00438 if( workSpace ) 00439 { 00440 delete[] workSpace; 00441 workSpace = NULL; 00442 } 00443 00444 entType = mbImpl->type_from_handle( ent ); 00445 entDim = mbImpl->dimension_from_handle( ent ); 00446 00447 std::vector< EntityHandle > dum_vec; 00448 ErrorCode rval = mbImpl->get_connectivity( ent, vertHandles, numVerts, false, &dum_vec ); 00449 if( MB_SUCCESS != rval ) return rval; 00450 00451 if( !evalSets[entType].evalFcn ) EvalSet::get_eval_set( entType, numVerts, evalSets[entType] ); 00452 00453 rval = mbImpl->get_coords( vertHandles, numVerts, vertPos[0].array() ); 00454 if( MB_SUCCESS != rval ) return rval; 00455 00456 if( tagHandle ) 00457 { 00458 rval = set_tag_handle( tagHandle ); 00459 if( MB_SUCCESS != rval ) return rval; 00460 } 00461 if( evalSets[entType].initFcn ) return ( *evalSets[entType].initFcn )( vertPos[0].array(), numVerts, workSpace ); 00462 return MB_SUCCESS; 00463 } 00464 00465 inline ErrorCode ElemEvaluator::set_tag_handle( Tag tag, int tagged_ent_dim ) 00466 { 00467 ErrorCode rval = MB_SUCCESS; 00468 if( !tag && !tagged_ent_dim ) 00469 { 00470 tagCoords = true; 00471 numTuples = 3; 00472 taggedEntDim = 0; 00473 tagHandle = 0; 00474 return rval; 00475 } 00476 else if( tagHandle != tag ) 00477 { 00478 tagHandle = tag; 00479 rval = mbImpl->tag_get_length( tagHandle, numTuples ); 00480 if( MB_SUCCESS != rval ) return rval; 00481 int sz; 00482 rval = mbImpl->tag_get_bytes( tag, sz ); 00483 if( MB_SUCCESS != rval ) return rval; 00484 tagSpace.resize( CN::MAX_NODES_PER_ELEMENT * sz ); 00485 tagCoords = false; 00486 } 00487 00488 taggedEntDim = ( -1 == tagged_ent_dim ? 0 : tagged_ent_dim ); 00489 00490 if( entHandle ) 00491 { 00492 if( 0 == taggedEntDim ) 00493 { 00494 rval = mbImpl->tag_get_data( tagHandle, vertHandles, numVerts, &tagSpace[0] ); 00495 if( MB_SUCCESS != rval ) return rval; 00496 } 00497 else if( taggedEntDim == entDim ) 00498 { 00499 rval = mbImpl->tag_get_data( tagHandle, &entHandle, 1, &tagSpace[0] ); 00500 if( MB_SUCCESS != rval ) return rval; 00501 } 00502 } 00503 00504 return rval; 00505 } 00506 00507 inline ErrorCode ElemEvaluator::set_tag( const char* tag_name, int tagged_ent_dim ) 00508 { 00509 ErrorCode rval = MB_SUCCESS; 00510 if( !tag_name || strlen( tag_name ) == 0 ) return MB_FAILURE; 00511 Tag tag; 00512 if( !strcmp( tag_name, "COORDS" ) ) 00513 { 00514 tagCoords = true; 00515 taggedEntDim = 0; 00516 numTuples = 3; 00517 tagHandle = 0; 00518 // can return here, because vertex coords already cached when entity handle set 00519 return rval; 00520 } 00521 else 00522 { 00523 rval = mbImpl->tag_get_handle( tag_name, tag ); 00524 if( MB_SUCCESS != rval ) return rval; 00525 00526 if( tagHandle != tag ) 00527 { 00528 tagHandle = tag; 00529 rval = mbImpl->tag_get_length( tagHandle, numTuples ); 00530 if( MB_SUCCESS != rval ) return rval; 00531 int sz; 00532 rval = mbImpl->tag_get_bytes( tag, sz ); 00533 if( MB_SUCCESS != rval ) return rval; 00534 tagSpace.reserve( CN::MAX_NODES_PER_ELEMENT * sz ); 00535 tagCoords = false; 00536 } 00537 00538 taggedEntDim = ( -1 == tagged_ent_dim ? entDim : tagged_ent_dim ); 00539 } 00540 00541 if( entHandle ) 00542 { 00543 if( 0 == taggedEntDim ) 00544 { 00545 rval = mbImpl->tag_get_data( tagHandle, vertHandles, numVerts, &tagSpace[0] ); 00546 if( MB_SUCCESS != rval ) return rval; 00547 } 00548 else if( taggedEntDim == entDim ) 00549 { 00550 rval = mbImpl->tag_get_data( tagHandle, &entHandle, 1, &tagSpace[0] ); 00551 if( MB_SUCCESS != rval ) return rval; 00552 } 00553 } 00554 00555 return rval; 00556 } 00557 00558 inline ErrorCode ElemEvaluator::set_eval_set( EntityType tp, const EvalSet& eval_set ) 00559 { 00560 evalSets[tp] = eval_set; 00561 if( entHandle && evalSets[entType].initFcn ) 00562 { 00563 ErrorCode rval = ( *evalSets[entType].initFcn )( vertPos[0].array(), numVerts, workSpace ); 00564 if( MB_SUCCESS != rval ) return rval; 00565 } 00566 return MB_SUCCESS; 00567 } 00568 00569 inline ErrorCode ElemEvaluator::eval( const double* params, double* result, int num_tuples ) const 00570 { 00571 assert( entHandle && MBMAXTYPE != entType ); 00572 return ( *evalSets[entType].evalFcn )( 00573 params, ( tagCoords ? (const double*)vertPos[0].array() : (const double*)&tagSpace[0] ), entDim, 00574 ( -1 == num_tuples ? numTuples : num_tuples ), workSpace, result ); 00575 } 00576 00577 inline ErrorCode ElemEvaluator::reverse_eval( const double* posn, 00578 const double iter_tol, 00579 const double inside_tol, 00580 double* params, 00581 int* ins ) const 00582 { 00583 assert( entHandle && MBMAXTYPE != entType ); 00584 return ( *evalSets[entType].reverseEvalFcn )( evalSets[entType].evalFcn, evalSets[entType].jacobianFcn, 00585 evalSets[entType].insideFcn, posn, vertPos[0].array(), numVerts, 00586 entDim, iter_tol, inside_tol, workSpace, params, ins ); 00587 } 00588 00589 /** \brief Evaluate the normal of the cached entity at a given facet */ 00590 inline ErrorCode ElemEvaluator::get_normal( const int ientDim, const int facet, double normal[] ) const 00591 { 00592 assert( entHandle && MBMAXTYPE != entType ); 00593 return ( *evalSets[entType].normalFcn )( ientDim, facet, numVerts, vertPos[0].array(), normal ); 00594 } 00595 00596 /** \brief Evaluate the jacobian of the cached entity at a given parametric location */ 00597 inline ErrorCode ElemEvaluator::jacobian( const double* params, double* result ) const 00598 { 00599 assert( entHandle && MBMAXTYPE != entType ); 00600 return ( *evalSets[entType].jacobianFcn )( params, vertPos[0].array(), numVerts, entDim, workSpace, result ); 00601 } 00602 00603 /** \brief Integrate the cached tag over the cached entity */ 00604 inline ErrorCode ElemEvaluator::integrate( double* result ) const 00605 { 00606 assert( entHandle && MBMAXTYPE != entType && ( tagCoords || tagHandle ) ); 00607 ErrorCode rval = MB_SUCCESS; 00608 if( !tagCoords ) 00609 { 00610 if( 0 == taggedEntDim ) 00611 rval = mbImpl->tag_get_data( tagHandle, vertHandles, numVerts, (void*)&tagSpace[0] ); 00612 else 00613 rval = mbImpl->tag_get_data( tagHandle, &entHandle, 1, (void*)&tagSpace[0] ); 00614 if( MB_SUCCESS != rval ) return rval; 00615 } 00616 return ( *evalSets[entType].integrateFcn )( ( tagCoords ? vertPos[0].array() : (const double*)&tagSpace[0] ), 00617 vertPos[0].array(), numVerts, entDim, numTuples, workSpace, result ); 00618 } 00619 00620 inline ErrorCode ElemEvaluator::find_containing_entity( EntityHandle ent_set, 00621 const double* point, 00622 const double iter_tol, 00623 const double inside_tol, 00624 EntityHandle& containing_ent, 00625 double* params, 00626 unsigned int* num_evals ) 00627 { 00628 assert( mbImpl->type_from_handle( ent_set ) == MBENTITYSET ); 00629 Range entities; 00630 ErrorCode rval = mbImpl->get_entities_by_handle( ent_set, entities ); 00631 if( MB_SUCCESS != rval ) 00632 return rval; 00633 else 00634 return find_containing_entity( entities, point, iter_tol, inside_tol, containing_ent, params, num_evals ); 00635 } 00636 00637 inline int ElemEvaluator::inside( const double* params, const double tol ) const 00638 { 00639 return ( *evalSets[entType].insideFcn )( params, entDim, tol ); 00640 } 00641 00642 inline ErrorCode ElemEvaluator::set_eval_set( const EntityHandle eh ) 00643 { 00644 EvalSet eset; 00645 ErrorCode rval = EvalSet::get_eval_set( mbImpl, eh, evalSets[mbImpl->type_from_handle( eh )] ); 00646 return rval; 00647 } 00648 00649 } // namespace moab 00650 00651 #endif /*MOAB_ELEM_EVALUATOR_HPP*/
