moab::ElemEvaluator Class Reference
Class facilitating local discretization-related functionsThis class implements discretization-related functionality operating on data in MOAB. A member of this class caches certain data about the element it's currently operating on, but is not meant to be instantiated one-per-element, but rather one-per-search (or other operation on a collection of elements). More...
#include <ElemEvaluator.hpp>
+ Collaboration diagram for moab::ElemEvaluator:
Public Member Functions
 ElemEvaluator (Interface *impl, EntityHandle ent=0, Tag tag=0, int tagged_ent_dim=-1)
 Constructor.
 ~ElemEvaluator ()
ErrorCode eval (const double *params, double *result, int num_tuples=-1) const
 Evaluate cached tag at a given parametric location within the cached entity If evaluating coordinates, call set_tag(0, 0), which indicates coords instead of a tag.
ErrorCode reverse_eval (const double *posn, double iter_tol, double inside_tol, double *params, int *is_inside=NULL) const
 Reverse-evaluate the cached entity at a given physical position.
ErrorCode get_normal (const int ientDim, const int facet, double normal[3]) const
 Evaluate the normal to a facet of an entity.
ErrorCode jacobian (const double *params, double *result) const
 Evaluate the jacobian of the cached entity at a given parametric location.
ErrorCode integrate (double *result) const
 Integrate the cached tag over the cached entity.
int inside (const double *params, const double tol) const
 Return whether a physical position is inside the cached entity to within a tolerance.
ErrorCode find_containing_entity (Range &entities, const double *point, const double iter_tol, const double inside_tol, EntityHandle &containing_ent, double *params, unsigned int *num_evals=NULL)
 Given a list of entities, return the entity the point is in, or none This function reverse-evaluates the entities, returning the first entity containing the point. If no entity contains the point, containing_ent is returned as 0 and params are unchanged. This function returns something other than MB_SUCCESS only when queries go wrong for some reason. num_evals, if non-NULL, is always incremented for each call to reverse_eval. This function calls set_ent_handle for each entity before calling reverse_eval, so the ElemEvaluator object is changed.
ErrorCode find_containing_entity (EntityHandle ent_set, const double *point, const double iter_tol, const double inside_tol, EntityHandle &containing_ent, double *params, unsigned int *num_evals=NULL)
 Given an entity set, return the contained entity the point is in, or none This function reverse-evaluates the entities, returning the first entity containing the point. If no entity contains the point, containing_ent is returned as 0 and params are unchanged. This function returns something other than MB_SUCCESS only when queries go wrong for some reason. num_evals, if non-NULL, is always incremented for each call to reverse_eval. This function calls set_ent_handle for each entity before calling reverse_eval, so the ElemEvaluator object is changed.
ErrorCode set_eval_set (EntityType tp, const EvalSet &eval_set)
 Set the eval set for a given type entity.
ErrorCode set_eval_set (const EntityHandle eh)
 Set the eval set using a given entity handle This function queries the entity type and number of vertices on the entity to decide which type of shape function to use. NOTE: this function should only be called after setting a valid MOAB instance on the evaluator.
EvalSet get_eval_set (EntityType tp)
 Get the eval set for a given type entity.
ErrorCode set_ent_handle (EntityHandle ent)
 Set entity handle & cache connectivty & vertex positions.
EntityHandle get_ent_handle () const
 Get entity handle for this ElemEval.
double * get_vert_pos ()
const EntityHandle * get_vert_handles () const
int get_num_verts () const
Tag get_tag_handle () const
ErrorCode set_tag_handle (Tag tag, int tagged_ent_dim=-1)
ErrorCode set_tag (const char *tag_name, int tagged_ent_dim=-1)
int get_tagged_ent_dim () const
ErrorCode set_tagged_ent_dim (int dim)
double * get_work_space ()
Interface * get_moab ()
Private Attributes
Interface * mbImpl
 Interface.
EntityHandle entHandle
 Entity handle being evaluated.
EntityType entType
 Entity type.
int entDim
 Entity dimension.
int numVerts
 Number of vertices cached here.
const EntityHandle * vertHandles
 Cached copy of vertex handle ptr.
CartVect vertPos [CN::MAX_NODES_PER_ELEMENT]
 Cached copy of vertex positions.
Tag tagHandle
 Tag being evaluated.
bool tagCoords
 Whether tag is coordinates or something else.
int numTuples
 Number of values in this tag.
int taggedEntDim
 Dimension of entities from which to grab tag.
std::vector< unsigned char > tagSpace
 Tag space.
EvalSet evalSets [MBMAXTYPE]
 Evaluation methods for elements of various topologies.
double * workSpace
 Work space for element-specific data.
Detailed Description
Actual discretization functionality is accessed through function pointers, allowing applications to specialize the implementation of specific functions while still using this class.
This class depends on MOAB functionality for gathering entity-based data; the functions it calls through function pointers depend only on POD (plain old data, or intrinsic data types). This allows the use of other packages for serving these functions, without having to modify them to get data through MOAB. This should also promote efficiency, since in many cases they will be able to read data from its native storage locations.
Definition at line 177 of file ElemEvaluator.hpp.
moab::ElemEvaluator::ElemEvaluator ( Interface *  impl,
EntityHandle  ent = 0,
Tag  tag = 0,
int  tagged_ent_dim = -1
) [inline]
Constructor.
Parameters:
implMOAB instance
entEntity handle to cache on the evaluator; if non-zero, calls set_ent_handle, which does some other stuff.
tagTag to cache on the evaluator; if non-zero, calls set_tag_handle, which does some other stuff too.
tagged_ent_dimDimension of entities to be tagged to cache on the evaluator
Definition at line 422 of file ElemEvaluator.hpp.
References set_ent_handle(), and set_tag_handle().
    : mbImpl( impl ), entHandle( 0 ), entType( MBMAXTYPE ), entDim( -1 ), numVerts( 0 ), vertHandles( NULL ),
      tagHandle( 0 ), tagCoords( false ), numTuples( 0 ), taggedEntDim( 0 ), workSpace( NULL )
    if( ent ) set_ent_handle( ent );
    if( tag ) set_tag_handle( tag, tagged_ent_dim );
Definition at line 430 of file ElemEvaluator.hpp.
References workSpace.
    if( workSpace ) delete[] workSpace;
Member Function Documentation
ErrorCode moab::ElemEvaluator::eval ( const double *  params,
double *  result,
int  num_tuples = -1
) const [inline]
Parameters:
paramsParameters at which to evaluate field
resultResult of evaluation
num_tuplesSize of evaluated field, in number of values
Definition at line 569 of file ElemEvaluator.hpp.
References entDim, entHandle, entType, evalSets, MBMAXTYPE, numTuples, tagCoords, tagSpace, vertPos, and workSpace.
Referenced by moab::DataCoupler::interpolate(), test_eval(), and time_forward_eval().
    assert( entHandle && MBMAXTYPE != entType );
    return ( *evalSets[entType].evalFcn )(
        params, ( tagCoords ? (const double*)vertPos[0].array() : (const double*)&tagSpace[0] ), entDim,
        ( -1 == num_tuples ? numTuples : num_tuples ), workSpace, result );
ErrorCode moab::ElemEvaluator::find_containing_entity ( Range &  entities,
const double *  point,
EntityHandle &  containing_ent,
double *  params,
unsigned int *  num_evals = NULL
Parameters:
entitiesEntities tested
pointPoint tested, must have 3 dimensions, even for edge and face entities
iter_tolTolerance for non-linear reverse evaluation
inside_tolTolerance for is_inside test
containing_entEntity containing the point, returned 0 if no entity
paramsParameters of point in containing entity, unchanged if no containing entity
num_evalsIf non-NULL, incremented each time reverse_eval is called
Returns:
Returns non-success only if evaulation failed for some reason (point not in element is NOT a reason for failure)
Definition at line 137 of file ElemEvaluator.cpp.
References moab::Range::begin(), moab::Range::end(), ErrorCode, MB_SUCCESS, reverse_eval(), and set_ent_handle().
Referenced by moab::BVHTree::bruteforce_find(), moab::BVHTree::distance_search(), moab::AdaptiveKDTree::distance_search(), find_containing_entity(), moab::AdaptiveKDTree::point_search(), and moab::BVHTree::point_search().
    int is_inside;
    ErrorCode rval      = MB_SUCCESS;
    unsigned int nevals = 0;
    Range::iterator i;
    for( i = entities.begin(); i != entities.end(); ++i )
        nevals++;
        set_ent_handle( *i );
        rval = reverse_eval( point, iter_tol, inside_tol, params, &is_inside );
        if( MB_SUCCESS != rval ) return rval;
        if( is_inside ) break;
    containing_ent = ( i == entities.end() ? 0 : *i );
    if( num_evals ) *num_evals += nevals;
    return MB_SUCCESS;
ErrorCode moab::ElemEvaluator::find_containing_entity ( EntityHandle  ent_set,
double *  params,
) [inline]
Parameters:
ent_setEntity set containing the entities to be tested
Returns:
Definition at line 620 of file ElemEvaluator.hpp.
References entities, ErrorCode, find_containing_entity(), moab::Interface::get_entities_by_handle(), MB_SUCCESS, MBENTITYSET, mbImpl, and moab::Interface::type_from_handle().
    assert( mbImpl->type_from_handle( ent_set ) == MBENTITYSET );
    Range entities;
    ErrorCode rval = mbImpl->get_entities_by_handle( ent_set, entities );
        return rval;
    else
        return find_containing_entity( entities, point, iter_tol, inside_tol, containing_ent, params, num_evals );
Definition at line 307 of file ElemEvaluator.hpp.
References entHandle.
Referenced by test_eval().
        return entHandle;
EvalSet moab::ElemEvaluator::get_eval_set ( EntityType  tp) [inline]
Definition at line 298 of file ElemEvaluator.hpp.
References evalSets.
Referenced by set_ent_handle(), and set_eval_set().
        return evalSets[tp];
Definition at line 372 of file ElemEvaluator.hpp.
References mbImpl.
        return mbImpl;
ErrorCode moab::ElemEvaluator::get_normal ( const int  ientDim,
const int  facet,
double  normal[3]
) const [inline]
Evaluate the normal of the cached entity at a given facet.
Parameters:
ientDimDimension of the facet. Should be (d-1) for d-dimensional entities
facetLocal id of the facet w.r.t the entity
normalReturns the normal.
Definition at line 590 of file ElemEvaluator.hpp.
References moab::CartVect::array(), entHandle, entType, evalSets, MBMAXTYPE, numVerts, and vertPos.
Referenced by test_normal_linear_hex(), test_normal_linear_quad(), test_normal_linear_tet(), and test_normal_linear_tri().
    return ( *evalSets[entType].normalFcn )( ientDim, facet, numVerts, vertPos[0].array(), normal );
int moab::ElemEvaluator::get_num_verts ( ) const [inline]
Definition at line 326 of file ElemEvaluator.hpp.
References numVerts.
        return numVerts;
Definition at line 332 of file ElemEvaluator.hpp.
References tagHandle.
        return tagHandle;
Definition at line 354 of file ElemEvaluator.hpp.
References taggedEntDim.
        return taggedEntDim;
Definition at line 320 of file ElemEvaluator.hpp.
References vertHandles.
        return vertHandles;
double* moab::ElemEvaluator::get_vert_pos ( ) [inline]
Definition at line 314 of file ElemEvaluator.hpp.
References moab::CartVect::array(), and vertPos.
        return vertPos[0].array();
Definition at line 366 of file ElemEvaluator.hpp.
        return workSpace;
int moab::ElemEvaluator::inside ( const double *  params,
const double  tol
) const [inline]
Parameters:
paramsParameters at which to query the element
tolTolerance, usually 10^-6 or so
Definition at line 637 of file ElemEvaluator.hpp.
References entDim, entType, and evalSets.
    return ( *evalSets[entType].insideFcn )( params, entDim, tol );
ErrorCode moab::ElemEvaluator::integrate ( double *  result) const [inline]
Parameters:
resultResult of the integration
Definition at line 604 of file ElemEvaluator.hpp.
References moab::CartVect::array(), entDim, entHandle, entType, ErrorCode, evalSets, MB_SUCCESS, mbImpl, MBMAXTYPE, numTuples, numVerts, moab::Interface::tag_get_data(), tagCoords, taggedEntDim, tagHandle, tagSpace, vertHandles, vertPos, and workSpace.
Referenced by test_eval(), test_evals(), and time_integrate().
    assert( entHandle && MBMAXTYPE != entType && ( tagCoords || tagHandle ) );
    if( !tagCoords )
        if( 0 == taggedEntDim )
            rval = mbImpl->tag_get_data( tagHandle, vertHandles, numVerts, (void*)&tagSpace[0] );
        else
            rval = mbImpl->tag_get_data( tagHandle, &entHandle, 1, (void*)&tagSpace[0] );
    return ( *evalSets[entType].integrateFcn )( ( tagCoords ? vertPos[0].array() : (const double*)&tagSpace[0] ),
                                                vertPos[0].array(), numVerts, entDim, numTuples, workSpace, result );
ErrorCode moab::ElemEvaluator::jacobian ( const double *  params,
double *  result
) const [inline]
Parameters:
paramsParameters at which to evaluate jacobian
resultResult of evaluation, in the form of a 3x3 matrix, stored in column-major order
Definition at line 597 of file ElemEvaluator.hpp.
References moab::CartVect::array(), entDim, entHandle, entType, evalSets, MBMAXTYPE, numVerts, vertPos, and workSpace.
Referenced by test_eval(), and time_jacobian().
    return ( *evalSets[entType].jacobianFcn )( params, vertPos[0].array(), numVerts, entDim, workSpace, result );
ErrorCode moab::ElemEvaluator::reverse_eval ( const double *  posn,
double  iter_tol,
double  inside_tol,
double *  params,
int *  is_inside = NULL
) const [inline]
Parameters:
posnPosition at which to evaluate parameters
iter_tolTolerance of reverse evaluation non-linear iteration, usually 10^-10 or so
inside_tolTolerance of is_inside evaluation, usually 10^-6 or so
paramsResult of evaluation
is_insideIf non-NULL, returns true of resulting parameters place the point inside the element (in most cases, within [-1]*(dim)
Definition at line 577 of file ElemEvaluator.hpp.
References moab::CartVect::array(), entDim, entHandle, entType, moab::EvalSet::evalFcn, evalSets, moab::EvalSet::insideFcn, moab::EvalSet::jacobianFcn, MBMAXTYPE, numVerts, vertPos, and workSpace.
Referenced by find_containing_entity(), moab::BVHTree::find_point(), test_eval(), and time_reverse_eval().
    return ( *evalSets[entType].reverseEvalFcn )( evalSets[entType].evalFcn, evalSets[entType].jacobianFcn,
                                                  evalSets[entType].insideFcn, posn, vertPos[0].array(), numVerts,
                                                  entDim, iter_tol, inside_tol, workSpace, params, ins );
Definition at line 435 of file ElemEvaluator.hpp.
References moab::CartVect::array(), moab::Interface::dimension_from_handle(), entDim, entHandle, entType, ErrorCode, evalSets, moab::Interface::get_connectivity(), moab::Interface::get_coords(), get_eval_set(), MB_SUCCESS, mbImpl, numVerts, set_tag_handle(), tagHandle, moab::Interface::type_from_handle(), vertHandles, vertPos, and workSpace.
Referenced by ElemEvaluator(), find_containing_entity(), moab::BVHTree::find_point(), moab::DataCoupler::interpolate(), test_evals(), test_normal_linear_hex(), test_normal_linear_quad(), test_normal_linear_tet(), test_normal_linear_tri(), time_forward_eval(), time_integrate(), time_jacobian(), and time_reverse_eval().
    entHandle = ent;
    if( workSpace )
        delete[] workSpace;
        workSpace = NULL;
    entType = mbImpl->type_from_handle( ent );
    entDim  = mbImpl->dimension_from_handle( ent );
    std::vector< EntityHandle > dum_vec;
    ErrorCode rval = mbImpl->get_connectivity( ent, vertHandles, numVerts, false, &dum_vec );
    if( !evalSets[entType].evalFcn ) EvalSet::get_eval_set( entType, numVerts, evalSets[entType] );
    rval = mbImpl->get_coords( vertHandles, numVerts, vertPos[0].array() );
    if( tagHandle )
        rval = set_tag_handle( tagHandle );
    if( evalSets[entType].initFcn ) return ( *evalSets[entType].initFcn )( vertPos[0].array(), numVerts, workSpace );
    return MB_SUCCESS;
ErrorCode moab::ElemEvaluator::set_eval_set ( EntityType  tp,
const EvalSet &  eval_set
) [inline]
Parameters:
tpEntity type for which to set the eval set
eval_setEval set object to use
Definition at line 558 of file ElemEvaluator.hpp.
References entHandle, entType, ErrorCode, evalSets, moab::EvalSet::initFcn, MB_SUCCESS, numVerts, vertPos, and workSpace.
Referenced by moab::DataCoupler::DataCoupler(), main(), test_linear_hex(), test_linear_quad(), test_linear_tet(), test_normal_linear_hex(), test_normal_linear_quad(), test_normal_linear_tet(), test_normal_linear_tri(), test_quadratic_hex(), time_forward_eval(), time_integrate(), time_jacobian(), and time_reverse_eval().
    evalSets[tp] = eval_set;
    if( entHandle && evalSets[entType].initFcn )
        ErrorCode rval = ( *evalSets[entType].initFcn )( vertPos[0].array(), numVerts, workSpace );
    return MB_SUCCESS;
Parameters:
ehEntity handle whose type and #vertices are queried
Definition at line 642 of file ElemEvaluator.hpp.
References ErrorCode, evalSets, get_eval_set(), mbImpl, and moab::Interface::type_from_handle().
    EvalSet eset;
    ErrorCode rval = EvalSet::get_eval_set( mbImpl, eh, evalSets[mbImpl->type_from_handle( eh )] );
    return rval;
ErrorCode moab::ElemEvaluator::set_tag ( const char *  tag_name,
) [inline]
Definition at line 507 of file ElemEvaluator.hpp.
References entDim, entHandle, ErrorCode, moab::CN::MAX_NODES_PER_ELEMENT, MB_SUCCESS, mbImpl, numTuples, numVerts, moab::Interface::tag_get_bytes(), moab::Interface::tag_get_data(), moab::Interface::tag_get_handle(), moab::Interface::tag_get_length(), tagCoords, taggedEntDim, tagHandle, tagSpace, and vertHandles.
    if( !tag_name || strlen( tag_name ) == 0 ) return MB_FAILURE;
    Tag tag;
    if( !strcmp( tag_name, "COORDS" ) )
        tagCoords    = true;
        taggedEntDim = 0;
        numTuples    = 3;
        tagHandle    = 0;
        // can return here, because vertex coords already cached when entity handle set
        return rval;
    else
        rval = mbImpl->tag_get_handle( tag_name, tag );
        if( tagHandle != tag )
            tagHandle = tag;
            rval      = mbImpl->tag_get_length( tagHandle, numTuples );
            int sz;
            rval = mbImpl->tag_get_bytes( tag, sz );
            tagSpace.reserve( CN::MAX_NODES_PER_ELEMENT * sz );
            tagCoords = false;
        taggedEntDim = ( -1 == tagged_ent_dim ? entDim : tagged_ent_dim );
    if( entHandle )
            rval = mbImpl->tag_get_data( tagHandle, vertHandles, numVerts, &tagSpace[0] );
        else if( taggedEntDim == entDim )
            rval = mbImpl->tag_get_data( tagHandle, &entHandle, 1, &tagSpace[0] );
    return rval;
ErrorCode moab::ElemEvaluator::set_tag_handle ( Tag  tag,
) [inline]
Definition at line 465 of file ElemEvaluator.hpp.
References entDim, entHandle, ErrorCode, moab::CN::MAX_NODES_PER_ELEMENT, MB_SUCCESS, mbImpl, numTuples, numVerts, moab::Interface::tag_get_bytes(), moab::Interface::tag_get_data(), moab::Interface::tag_get_length(), tagCoords, taggedEntDim, tagHandle, tagSpace, and vertHandles.
Referenced by ElemEvaluator(), moab::DataCoupler::interpolate(), set_ent_handle(), test_eval(), test_evals(), test_linear_hex(), test_linear_quad(), test_linear_tet(), test_quadratic_hex(), time_forward_eval(), time_integrate(), time_jacobian(), and time_reverse_eval().
    if( !tag && !tagged_ent_dim )
        tagCoords    = true;
        numTuples    = 3;
        taggedEntDim = 0;
        tagHandle    = 0;
        return rval;
    else if( tagHandle != tag )
        tagHandle = tag;
        int sz;
        tagSpace.resize( CN::MAX_NODES_PER_ELEMENT * sz );
        tagCoords = false;
    taggedEntDim = ( -1 == tagged_ent_dim ? 0 : tagged_ent_dim );
    if( entHandle )
    return rval;
Member Data Documentation
Entity dimension.
Definition at line 388 of file ElemEvaluator.hpp.
Referenced by eval(), inside(), integrate(), jacobian(), reverse_eval(), set_ent_handle(), set_tag(), and set_tag_handle().
EntityType moab::ElemEvaluator::entType [private]
Entity type.
Definition at line 385 of file ElemEvaluator.hpp.
Referenced by eval(), get_normal(), inside(), integrate(), jacobian(), reverse_eval(), set_ent_handle(), and set_eval_set().
Definition at line 415 of file ElemEvaluator.hpp.
Referenced by eval(), get_eval_set(), get_normal(), inside(), integrate(), jacobian(), reverse_eval(), set_ent_handle(), and set_eval_set().
Definition at line 406 of file ElemEvaluator.hpp.
Referenced by eval(), integrate(), set_tag(), and set_tag_handle().
Definition at line 391 of file ElemEvaluator.hpp.
Referenced by get_normal(), get_num_verts(), integrate(), jacobian(), reverse_eval(), set_ent_handle(), set_eval_set(), set_tag(), and set_tag_handle().
Definition at line 403 of file ElemEvaluator.hpp.
Definition at line 409 of file ElemEvaluator.hpp.
Referenced by get_tagged_ent_dim(), integrate(), set_tag(), and set_tag_handle().
Definition at line 400 of file ElemEvaluator.hpp.
Referenced by get_tag_handle(), integrate(), set_ent_handle(), set_tag(), and set_tag_handle().
std::vector< unsigned char > moab::ElemEvaluator::tagSpace [private]
Tag space.
Definition at line 412 of file ElemEvaluator.hpp.
Definition at line 394 of file ElemEvaluator.hpp.
Referenced by get_vert_handles(), integrate(), set_ent_handle(), set_tag(), and set_tag_handle().
double* moab::ElemEvaluator::workSpace [private]
Definition at line 418 of file ElemEvaluator.hpp.
Referenced by eval(), get_work_space(), integrate(), jacobian(), reverse_eval(), set_ent_handle(), set_eval_set(), and ~ElemEvaluator().
List of all members.
