moab::EvalSet Class Reference
#include <ElemEvaluator.hpp>
Public Member Functions
 EvalSet ()
 Bare constructor.
 EvalSet (EvalFcn eval, ReverseEvalFcn rev, NormalFcn normal, JacobianFcn jacob, IntegrateFcn integ, InitFcn initf, InsideFcn insidef)
 Constructor.
 EvalSet (EvalSet const &eval)
 Copy constructor.
EvalSet & operator= (const EvalSet &eval)
 Operator=.
Static Public Member Functions
static ErrorCode get_eval_set (Interface *mb, EntityHandle eh, EvalSet &eval_set)
 Given an entity handle, get an appropriate eval set, based on type & #vertices.
static ErrorCode get_eval_set (EntityType tp, unsigned int num_vertices, EvalSet &eval_set)
 Given type & #vertices, get an appropriate eval set.
static ErrorCode evaluate_reverse (EvalFcn eval, JacobianFcn jacob, InsideFcn inside_f, const double *posn, const double *verts, const int nverts, const int ndim, const double iter_tol, const double inside_tol, double *work, double *params, int *inside)
 Common function to do reverse evaluation based on evaluation and jacobian functions.
static int inside_function (const double *params, const int ndims, const double tol)
 Common function that returns true if params is in [-1,1]^ndims.
Public Attributes
EvalFcn evalFcn
 Forward-evaluation of field at parametric coordinates.
ReverseEvalFcn reverseEvalFcn
 Reverse-evaluation of parametric coordinates at physical space position.
NormalFcn normalFcn
 Evaluate the normal at a local facet (edge/face for 2D/3D)
JacobianFcn jacobianFcn
 Evaluate the jacobian at a specified parametric position.
IntegrateFcn integrateFcn
InitFcn initFcn
 Initialization function for an element.
InsideFcn insideFcn
 Function that returns whether or not the parameters are inside the natural space of the element.
Detailed Description
Definition at line 56 of file ElemEvaluator.hpp.
moab::EvalSet::EvalSet ( ) [inline]
Bare constructor.
Definition at line 82 of file ElemEvaluator.hpp.
        : evalFcn( NULL ), reverseEvalFcn( NULL ), normalFcn( NULL ), jacobianFcn( NULL ), integrateFcn( NULL ),
          initFcn( NULL ), insideFcn( NULL )
moab::EvalSet::EvalSet ( EvalFcn  eval,
ReverseEvalFcn  rev,
NormalFcn  normal,
JacobianFcn  jacob,
IntegrateFcn  integ,
InitFcn  initf,
InsideFcn  insidef
) [inline]
Constructor.
Definition at line 89 of file ElemEvaluator.hpp.
        : evalFcn( eval ), reverseEvalFcn( rev ), normalFcn( normal ), jacobianFcn( jacob ), integrateFcn( integ ),
          initFcn( initf ), insideFcn( insidef )
moab::EvalSet::EvalSet ( EvalSet const &  eval) [inline]
Copy constructor.
Definition at line 102 of file ElemEvaluator.hpp.
        : evalFcn( eval.evalFcn ), reverseEvalFcn( eval.reverseEvalFcn ), normalFcn( eval.normalFcn ),
          jacobianFcn( eval.jacobianFcn ), integrateFcn( eval.integrateFcn ), initFcn( eval.initFcn ),
          insideFcn( eval.insideFcn )
Member Function Documentation
ErrorCode moab::EvalSet::evaluate_reverse ( EvalFcn  eval,
JacobianFcn  jacob,
InsideFcn  inside_f,
const double *  posn,
const double *  verts,
const int  nverts,
const int  ndim,
double *  work,
double *  params,
int *  inside
) [static]
Definition at line 19 of file ElemEvaluator.cpp.
References moab::CartVect::array(), moab::Matrix3::array(), moab::Matrix3::determinant(), moab::dum, ErrorCode, moab::Matrix3::inverse(), MB_INDEX_OUT_OF_RANGE, and MB_SUCCESS.
Referenced by moab::QuadraticHex::reverseEvalFcn(), moab::LinearHex::reverseEvalFcn(), and moab::LinearQuad::reverseEvalFcn().
    // TODO: should differentiate between epsilons used for
    // Newton Raphson iteration, and epsilons used for curved boundary geometry errors
    // right now, fix the tolerance used for NR
    const double error_tol_sqr = iter_tol * iter_tol;
    CartVect* cvparams         = reinterpret_cast< CartVect* >( params );
    const CartVect* cvposn     = reinterpret_cast< const CartVect* >( posn );
    // initialize to center of element
    *cvparams = CartVect( -.4 );
    CartVect new_pos;
    // evaluate that first guess to get a new position
    ErrorCode rval = ( *eval )( cvparams->array(), verts, ndim,
                                3,  // hardwire to num_tuples to 3 since the field is coords
                                work, new_pos.array() );
    if( MB_SUCCESS != rval ) return rval;
    // residual is diff between old and new pos; need to minimize that
    CartVect res = new_pos - *cvposn;
    Matrix3 J;
    int dum, *tmp_inside = ( inside ? inside : &dum );
    int iters = 0;
    // while |res| larger than tol
    while( res % res > error_tol_sqr )
        if( ++iters > 10 )
            // if we haven't converged but we're outside, that's defined as success
            *tmp_inside = ( *inside_f )( params, ndim, inside_tol );
            if( !( *tmp_inside ) )
                return MB_SUCCESS;
            else
                return MB_FAILURE;
        // get jacobian at current params
        rval       = ( *jacob )( cvparams->array(), verts, nverts, ndim, work, J.array() );
        double det = J.determinant();
        if( det < std::numeric_limits< double >::epsilon() )
                return MB_SUCCESS;
            else
                return MB_INDEX_OUT_OF_RANGE;
        // new params tries to eliminate residual
        *cvparams -= J.inverse() * res;
        // get the new forward-evaluated position, and its difference from the target pt
        rval = ( *eval )( params, verts, ndim,
    if( inside ) *inside = ( *inside_f )( params, ndim, inside_tol );
    return MB_SUCCESS;
}  // Map::evaluate_reverse()
ErrorCode moab::EvalSet::get_eval_set ( Interface *  mb,
EntityHandle  eh,
EvalSet &  eval_set
) [inline, static]
Definition at line 147 of file ElemEvaluator.hpp.
References ErrorCode, moab::Interface::get_connectivity(), MB_SUCCESS, and moab::Interface::type_from_handle().
Referenced by test_eval().
    int nv;
    EntityType tp = mb->type_from_handle( eh );
    const EntityHandle* connect;
    std::vector< EntityHandle > dum_vec;
    ErrorCode rval = mb->get_connectivity( eh, connect, nv, false, &dum_vec );
    return get_eval_set( tp, nv, eval_set );
ErrorCode moab::EvalSet::get_eval_set ( EntityType  tp,
EvalSet &  eval_set
) [static]
Definition at line 107 of file ElemEvaluator.cpp.
References moab::QuadraticHex::compatible(), moab::LinearQuad::compatible(), moab::LinearHex::compatible(), moab::LinearTet::compatible(), moab::LinearTri::compatible(), MB_NOT_IMPLEMENTED, MB_SUCCESS, MBEDGE, MBHEX, MBQUAD, MBTET, and MBTRI.
    switch( tp )
        case MBEDGE:
            break;
        case MBTRI:
            if( LinearTri::compatible( tp, num_vertices, eval_set ) ) return MB_SUCCESS;
            break;
        case MBQUAD:
            if( LinearQuad::compatible( tp, num_vertices, eval_set ) ) return MB_SUCCESS;
            //            if (SpectralQuad::compatible(tp, num_vertices, eval_set)) return
            //            MB_SUCCESS;
            break;
        case MBTET:
            if( LinearTet::compatible( tp, num_vertices, eval_set ) ) return MB_SUCCESS;
            break;
        case MBHEX:
            if( LinearHex::compatible( tp, num_vertices, eval_set ) ) return MB_SUCCESS;
            if( QuadraticHex::compatible( tp, num_vertices, eval_set ) ) return MB_SUCCESS;
            //            if (SpectralHex::compatible(tp, num_vertices, eval_set)) return
            //            MB_SUCCESS;
            break;
        default:
            break;
    return MB_NOT_IMPLEMENTED;
int moab::EvalSet::inside_function ( const double *  params,
const int  ndims,
const double  tol
) [static]
Definition at line 96 of file ElemEvaluator.cpp.
Referenced by moab::QuadraticHex::insideFcn(), moab::LinearHex::insideFcn(), and moab::LinearQuad::insideFcn().
    if( params[0] >= -1 - tol && params[0] <= 1 + tol &&
        ( ndims < 2 || ( params[1] >= -1 - tol && params[1] <= 1 + tol ) ) &&
        ( ndims < 3 || ( params[2] >= -1 - tol && params[2] <= 1 + tol ) ) )
        return true;
    else
        return false;
EvalSet& moab::EvalSet::operator= ( const EvalSet &  eval) [inline]
Operator=.
Definition at line 116 of file ElemEvaluator.hpp.
References evalFcn, initFcn, insideFcn, integrateFcn, jacobianFcn, normalFcn, and reverseEvalFcn.
        evalFcn        = eval.evalFcn;
        reverseEvalFcn = eval.reverseEvalFcn;
        normalFcn      = eval.normalFcn;
        jacobianFcn    = eval.jacobianFcn;
        integrateFcn   = eval.integrateFcn;
        initFcn        = eval.initFcn;
        insideFcn      = eval.insideFcn;
        return *this;
Member Data Documentation
Definition at line 60 of file ElemEvaluator.hpp.
Referenced by operator=(), and moab::ElemEvaluator::reverse_eval().
Definition at line 75 of file ElemEvaluator.hpp.
Referenced by operator=(), and moab::ElemEvaluator::set_eval_set().
Definition at line 79 of file ElemEvaluator.hpp.
Definition at line 72 of file ElemEvaluator.hpp.
Referenced by operator=(), and test_eval().
Definition at line 69 of file ElemEvaluator.hpp.
Definition at line 66 of file ElemEvaluator.hpp.
Referenced by operator=().
Definition at line 63 of file ElemEvaluator.hpp.
List of all members.
