moab::WriteGMV Class Reference
Output Exodus File for VERDE. More...
#include <WriteGMV.hpp>
+ Inheritance diagram for moab::WriteGMV:
+ Collaboration diagram for moab::WriteGMV:
Public Member Functions
 WriteGMV (Interface *impl)
 Constructor.
virtual ~WriteGMV ()
 Destructor.
ErrorCode write_file (const char *filename, const bool overwite, const FileOptions &opts, const EntityHandle *output_sets, const int num_output_sets, const std::vector< std::string > &qa_list, const Tag *tag_list=NULL, int num_tags=0, int requested_dimension=3)
 Export mesh to a file.
ErrorCode write_file (const char *file_name, const EntityHandle output_set, const int user_dimension=3, const bool mesh=true, const bool poly_mesh=true)
 writes out a mesh file
Static Public Member Functions
static WriterIface * factory (Interface *)
Private Member Functions
ErrorCode local_write_mesh (const char *file_name, const EntityHandle output_set, const int user_dimension, const bool mesh, const bool poly_mesh)
Private Attributes
Interface * mbImpl
 interface instance
WriteUtilIface * mWriteIface
Tag mMaterialSetTag
Tag mDirichletSetTag
Tag mNeumannSetTag
Tag mHasMidNodesTag
Tag mGeomDimensionTag
Tag mGlobalIdTag
Static Private Attributes
static const char * gmvTypeNames [MBMAXTYPE] = { "", "line", "tri", "quad", "", "tet", "pyramid", "prism", "", "hex", "", "" }
Detailed Description
Definition at line 41 of file WriteGMV.hpp.
Constructor.
get and cache predefined tag handles
Definition at line 45 of file WriteGMV.cpp.
References DIRICHLET_SET_TAG_NAME, moab::Interface::globalId_tag(), HAS_MID_NODES_TAG_NAME, MATERIAL_SET_TAG_NAME, MB_TAG_CREAT, MB_TAG_SPARSE, MB_TYPE_INTEGER, mDirichletSetTag, mGeomDimensionTag, mGlobalIdTag, mHasMidNodesTag, mMaterialSetTag, mNeumannSetTag, mWriteIface, NEUMANN_SET_TAG_NAME, moab::Interface::query_interface(), and moab::Interface::tag_get_handle().
Referenced by factory().
                                    : mbImpl( impl )
    assert( impl != NULL );
    impl->query_interface( mWriteIface );
    // initialize in case tag_get_handle fails below
    mMaterialSetTag   = 0;
    mDirichletSetTag  = 0;
    mNeumannSetTag    = 0;
    mHasMidNodesTag   = 0;
    mGeomDimensionTag = 0;
    mGlobalIdTag      = 0;
    //! get and cache predefined tag handles
    int negone = -1;
    impl->tag_get_handle( MATERIAL_SET_TAG_NAME, 1, MB_TYPE_INTEGER, mMaterialSetTag, MB_TAG_SPARSE | MB_TAG_CREAT,
                          &negone );
    impl->tag_get_handle( DIRICHLET_SET_TAG_NAME, 1, MB_TYPE_INTEGER, mDirichletSetTag, MB_TAG_SPARSE | MB_TAG_CREAT,
                          &negone );
    impl->tag_get_handle( NEUMANN_SET_TAG_NAME, 1, MB_TYPE_INTEGER, mNeumannSetTag, MB_TAG_SPARSE | MB_TAG_CREAT,
                          &negone );
    mGlobalIdTag = impl->globalId_tag();
    int dum_val_array[] = { -1, -1, -1, -1 };
    impl->tag_get_handle( HAS_MID_NODES_TAG_NAME, 4, MB_TYPE_INTEGER, mHasMidNodesTag, MB_TAG_SPARSE | MB_TAG_CREAT,
                          dum_val_array );
Destructor.
Definition at line 79 of file WriteGMV.cpp.
References mbImpl, mWriteIface, and moab::Interface::release_interface().
Member Function Documentation
Definition at line 40 of file WriteGMV.cpp.
References WriteGMV().
Referenced by moab::ReaderWriterSet::ReaderWriterSet().
    return new WriteGMV( iface );
ErrorCode moab::WriteGMV::local_write_mesh ( const char *  file_name,
const bool  mesh,
) [private]
Definition at line 136 of file WriteGMV.cpp.
References moab::WriteUtilIface::assign_ids(), moab::Range::begin(), moab::Range::clear(), moab::CREATE_HANDLE(), moab::Range::end(), ErrorCode, moab::GeomUtil::first(), moab::Interface::get_adjacencies(), moab::Interface::get_connectivity(), moab::WriteUtilIface::get_element_connect(), moab::Interface::get_entities_by_type(), moab::WriteUtilIface::get_node_coords(), gmvTypeNames, moab::Range::lower_bound(), MB_START_ID, MB_SUCCESS, mbImpl, MBPOLYGON, MBPOLYHEDRON, mGlobalIdTag, mWriteIface, ofile, moab::Range::rbegin(), moab::Range::size(), moab::Interface::tag_get_data(), moab::CN::TypeDimensionMap, moab::Interface::UNION, and moab::CN::VerticesPerEntity().
Referenced by write_file().
    std::ofstream ofile;
    ErrorCode result;
    if( mesh )
        // need to insert ".gmv"
        std::string tmp_name( file_name );
        tmp_name += ".gmv";
        ofile.open( tmp_name.c_str() );
    else if( poly_mesh )
        // need to insert ".poly.gmv"
        tmp_name += ".poly.gmv";
    ofile << "gmvinput ascii" << std::endl;
    // get elements to be output
    Range dum_range, elements, all_verts;
    EntityType otype;
    if( poly_mesh )
        result = mbImpl->get_entities_by_type( output_set, MBPOLYGON, elements, true );
        if( MB_SUCCESS != result ) return result;
    else
        for( otype = CN::TypeDimensionMap[user_dimension].first; otype <= CN::TypeDimensionMap[user_dimension].second;
             otype++ )
            if( otype == MBPOLYGON || otype == MBPOLYHEDRON ) continue;
            dum_range.clear();
            result = mbImpl->get_entities_by_type( output_set, otype, dum_range, true );
            std::copy( dum_range.begin(), dum_range.end(), range_inserter( elements ) );
    // gather the vertices in these elements
    result = mbImpl->get_adjacencies( elements, 0, false, all_verts, Interface::UNION );
    int num_verts = all_verts.size();
    // allocate coordinate arrays and put pointers to them in a list
    double* xcoord = new double[num_verts];
    double* ycoord = new double[num_verts];
    double* zcoord = new double[num_verts];
    std::vector< double* > coord_arrays;
    coord_arrays.push_back( xcoord );
    coord_arrays.push_back( ycoord );
    coord_arrays.push_back( zcoord );
    // fill them in, writing id tags at the same time
    result = mWriteIface->get_node_coords( 3, num_verts, all_verts, mGlobalIdTag, 1, coord_arrays );
    int i, j;
    // WRITE COORDINATE DATA TO FILE HERE
    ofile << "nodev " << num_verts << std::endl;
    for( i = 0; i < num_verts; i++ )
        ofile << xcoord[i] << " " << ycoord[i] << " " << zcoord[i] << std::endl;
    delete[] xcoord;
    delete[] ycoord;
    delete[] zcoord;
    // iterate over types in selected dimension
    std::vector< int > connect;
    std::vector< EntityHandle > connecth;
    if( mesh )
        Range sub_range;
        ofile << "cells " << elements.size() << std::endl;
             otype++ )
            // get the first element of this type in the range, and one past the last
            Range::iterator lower =
                Range::lower_bound( elements.begin(), elements.end(), CREATE_HANDLE( otype, MB_START_ID, i ) );
            Range::iterator upper =
                Range::lower_bound( elements.begin(), elements.end(), CREATE_HANDLE( otype + 1, MB_START_ID, i ) );
            if( lower == upper ) continue;
            // copy these elements into a subrange
            sub_range.clear();
            std::copy( lower, upper, range_inserter( sub_range ) );
            // make sure the connectivity array is big enough
            int verts_per = CN::VerticesPerEntity( otype );
            if( connect.size() < verts_per * sub_range.size() ) connect.resize( verts_per * sub_range.size() );
            // get the connectivity
            result = mWriteIface->get_element_connect( sub_range.size(), verts_per, mGlobalIdTag, sub_range,
                                                       mGlobalIdTag, 1, &connect[0] );
            // WRITE CONNECTIVITY DATA TO FILE HERE
            for( i = 0; i < (int)sub_range.size(); i++ )
                ofile << gmvTypeNames[otype] << " " << verts_per << std::endl;
                for( j = i * verts_per; j < (int)( i + 1 ) * verts_per; j++ )
                    ofile << connect[j] << " ";
                ofile << std::endl;
        // write polygons/hedra, if any
        Range polygons, polyhedra;
        result = mbImpl->get_entities_by_type( output_set, MBPOLYGON, polygons, true );
        result = mbImpl->get_entities_by_type( output_set, MBPOLYHEDRON, polyhedra, true );
        if( polygons.size() == 0 ) return result;
        // mark polyhedra with global ids
        result = mWriteIface->assign_ids( polyhedra, mGlobalIdTag, 1 );
        ofile << "faces " << polygons.size() << " " << polyhedra.size() << std::endl;
        for( Range::iterator rit = polygons.begin(); rit != polygons.end(); ++rit )
            // get the vertices
            connecth.clear();
            result = mbImpl->get_connectivity( &( *rit ), 1, connecth, true );
            if( 0 == connecth.size() ) continue;
            // get the polyhedra, if any
            if( user_dimension == 3 )
                polyhedra.clear();
                result = mbImpl->get_adjacencies( Range( *rit, *rit ), 3, false, polyhedra );
                // put them in the connect array
                connecth.push_back( ( polyhedra.size() > 0 ? *polyhedra.begin() : 0 ) );
                connecth.push_back( ( polyhedra.size() > 1 ? *polyhedra.rbegin() : 0 ) );
            // replace handles with ids
            connect.resize( connecth.size() + 2 );
            // pre-set polyhedra ids in case there aren't any
            connect[connecth.size()]     = 0;
            connect[connecth.size() + 1] = 0;
            result =
                mbImpl->tag_get_data( mGlobalIdTag, &connecth[0], connecth.size() - 2 + polyhedra.size(), &connect[0] );
            // write the data
            ofile << connecth.size() - 2;
            for( i = 0; i < (int)connecth.size(); i++ )
                ofile << " " << connect[i];
            ofile << std::endl;
    ofile << std::endl << "endgmv" << std::endl;
    ofile.close();
    return MB_SUCCESS;
ErrorCode moab::WriteGMV::write_file ( const char *  file_name,
const bool  overwrite,
const FileOptions &  opts,
const EntityHandle *  meshset_list,
const int  num_sets,
const std::vector< std::string > &  qa_records,
const Tag *  tag_list = NULL,
int  num_tags = 0,
int  requested_output_dimension = 3
) [virtual]
Method all writers must provide to export a mesh.
Parameters:
file_nameThe name of the file to create.
overwriteIf false, reader should fail if the file already exists.
meshset_listA list of meshsets to export, or NULL if the whole mesh is to be exported.
num_setsThe length of meshset_list or zero if the whole mesh is to be exported.
qa_recordsFile history metadata
tag_listArray of handles for tags to write. If null, write all tags. If non-NULL but num_tags is zero, write no tags.
requseted_output_dimensionThe geometric dimension of the output mesh (coord values per vertex.) If zero, the dimension of the mesh as returned from Interface should be used.
Author:
Jason Kraftcheck
Implements moab::WriterIface.
Definition at line 111 of file WriteGMV.cpp.
References moab::Interface::get_dimension(), and mbImpl.
    EntityHandle output_set = 0;
    if( output_sets && num_output_sets > 0 )
        if( num_output_sets > 1 ) return MB_FAILURE;
        output_set = output_sets[0];
    if( dimension == 0 )
        mbImpl->get_dimension( dimension );
    return write_file( filename, output_set, dimension, true, true );
const int  user_dimension = 3,
const bool  mesh = true,
const bool  poly_mesh = true
Definition at line 84 of file WriteGMV.cpp.
References ErrorCode, local_write_mesh(), and MB_SUCCESS.
    // general function for writing a mesh
    ErrorCode result = MB_SUCCESS;
    // initialize file
    if( mesh )
        result = local_write_mesh( file_name, output_set, user_dimension, true, false );
    if( poly_mesh )
        result = local_write_mesh( file_name, output_set, user_dimension, false, true );
    return result;
Member Data Documentation
const char * moab::WriteGMV::gmvTypeNames = { "", "line", "tri", "quad", "", "tet", "pyramid", "prism", "", "hex", "", "" } [static, private]
Definition at line 85 of file WriteGMV.hpp.
Referenced by local_write_mesh().
interface instance
Definition at line 73 of file WriteGMV.hpp.
Referenced by local_write_mesh(), write_file(), and ~WriteGMV().
Definition at line 79 of file WriteGMV.hpp.
Referenced by WriteGMV().
Definition at line 82 of file WriteGMV.hpp.
Definition at line 83 of file WriteGMV.hpp.
Referenced by local_write_mesh(), and WriteGMV().
Definition at line 81 of file WriteGMV.hpp.
Cached tags for reading. Note that all these tags are defined when the core is initialized.
Definition at line 78 of file WriteGMV.hpp.
Definition at line 80 of file WriteGMV.hpp.
Definition at line 74 of file WriteGMV.hpp.
Referenced by local_write_mesh(), WriteGMV(), and ~WriteGMV().
List of all members.
