moab::ReadABAQUS Class Reference
#include <ReadABAQUS.hpp>
+ Inheritance diagram for moab::ReadABAQUS:
+ Collaboration diagram for moab::ReadABAQUS:
Public Member Functions
void tokenize (const std::string &str, std::vector< std::string > &tokens, const char *delimiters)
ErrorCode load_file (const char *file_name, const EntityHandle *file_set, const FileOptions &opts, const SubsetList *subset_list=0, const Tag *file_id_tag=0)
 Load an ABAQUS file.
ErrorCode read_tag_values (const char *file_name, const char *tag_name, const FileOptions &opts, std::vector< int > &tag_values_out, const SubsetList *subset_list=0)
 Read tag values from a file.
 ReadABAQUS (Interface *impl=NULL)
 Constructor.
virtual ~ReadABAQUS ()
 Destructor.
Static Public Member Functions
static ReaderIface * factory (Interface *)
Private Member Functions
void reset ()
ErrorCode read_heading (EntityHandle file_set)
ErrorCode read_part (EntityHandle file_set)
ErrorCode read_assembly (EntityHandle file_set)
ErrorCode read_unsupported (EntityHandle file_set)
ErrorCode read_node_list (EntityHandle parent_set, EntityHandle assembly_set=0)
ErrorCode read_element_list (EntityHandle parent_set, EntityHandle assembly_set=0)
ErrorCode read_node_set (EntityHandle parent_set, EntityHandle file_set=0, EntityHandle assembly_set=0)
ErrorCode read_element_set (EntityHandle parent_set, EntityHandle file_set=0, EntityHandle assembly_set=0)
ErrorCode read_solid_section (EntityHandle parent_set)
ErrorCode read_instance (EntityHandle assembly_set, EntityHandle file_set)
ErrorCode get_elements_by_id (EntityHandle parent_set, std::vector< int > element_ids_subset, Range &element_range)
ErrorCode get_nodes_by_id (EntityHandle parent_set, std::vector< int > node_ids_subset, Range &node_range)
ErrorCode get_set_by_name (EntityHandle parent_set, int ABQ_set_type, const std::string &set_name, EntityHandle &set_handle)
ErrorCode get_set_elements (EntityHandle set_handle, Range &element_range)
ErrorCode get_set_elements_by_name (EntityHandle parent_set, int ABQ_set_type, const std::string &set_name, Range &element_range)
ErrorCode get_set_nodes (EntityHandle parent_set, int ABQ_set_type, const std::string &set_name, Range &node_range)
ErrorCode add_entity_set (EntityHandle parent_set, int ABQ_set_type, const std::string &set_name, EntityHandle &entity_set)
ErrorCode create_instance_of_part (const EntityHandle file_set, const EntityHandle parent_set, const std::string &part_name, const std::string &instance_name, EntityHandle &entity_set, const std::vector< double > &translation, const std::vector< double > &rotation)
Tag get_tag (const char *tag_name, int tag_size, TagType tag_type, DataType tag_data_type, const void *def_val=0)
void cyl2rect (std::vector< double > coord_list)
void sph2rect (std::vector< double > coord_list)
abaqus_line_types get_next_line_type ()
abaqus_keyword_type get_keyword ()
template<class T >
std::string match (const std::string &token, std::map< std::string, T > &tokenList)
void stringToUpper (const std::string &toBeConverted, std::string &converted)
void extract_keyword_parameters (const std::vector< std::string > &tokens, std::map< std::string, std::string > &params)
Private Attributes
Interface * mdbImpl
 Interface instance.
ReadUtilIface * readMeshIface
 Read mesh interface.
std::ifstream abFile
std::string readline
unsigned lineNo
Tag mMaterialSetTag
Tag mDirichletSetTag
Tag mNeumannSetTag
Tag mHasMidNodesTag
Tag mSetTypeTag
Tag mPartHandleTag
Tag mInstancePIDTag
Tag mInstanceGIDTag
Tag mLocalIDTag
Tag mInstanceHandleTag
Tag mAssemblyHandleTag
Tag mSetNameTag
Tag mMatNameTag
abaqus_line_types next_line_type
std::map< EntityHandle,
unsigned int >
num_part_instances
unsigned int >
num_assembly_instances
unsigned int >
matIDmap
unsigned mat_id
Detailed Description
Definition at line 349 of file ReadABAQUS.hpp.
Constructor.
Get and cache predefined tag handles
Definition at line 53 of file ReadABAQUS.cpp.
References ABAQUS_ASSEMBLY_HANDLE_TAG_NAME, ABAQUS_INSTANCE_GLOBAL_ID_TAG_NAME, ABAQUS_INSTANCE_HANDLE_TAG_NAME, ABAQUS_INSTANCE_PART_ID_TAG_NAME, ABAQUS_LOCAL_ID_TAG_NAME, ABAQUS_MAT_NAME_LENGTH, ABAQUS_MAT_NAME_TAG_NAME, ABAQUS_PART_HANDLE_TAG_NAME, ABAQUS_SET_NAME_LENGTH, ABAQUS_SET_NAME_TAG_NAME, ABAQUS_SET_TYPE_TAG_NAME, DIRICHLET_SET_TAG_NAME, get_tag(), HAS_MID_NODES_TAG_NAME, mAssemblyHandleTag, MATERIAL_SET_TAG_NAME, MB_TAG_DENSE, MB_TAG_SPARSE, MB_TYPE_HANDLE, MB_TYPE_INTEGER, MB_TYPE_OPAQUE, mDirichletSetTag, mHasMidNodesTag, mInstanceGIDTag, mInstanceHandleTag, mInstancePIDTag, mLocalIDTag, mMaterialSetTag, mMatNameTag, mNeumannSetTag, mPartHandleTag, mSetNameTag, mSetTypeTag, NEUMANN_SET_TAG_NAME, moab::Interface::query_interface(), readMeshIface, and reset().
Referenced by factory().
    : mdbImpl( impl ), readMeshIface( NULL ), lineNo( 0 ), next_line_type( abq_undefined_line ), mat_id( 0 )
    assert( impl != NULL );
    reset();
    impl->query_interface( readMeshIface );
    // Initialize in case tag_get_handle fails below
    mMaterialSetTag  = 0;
    mDirichletSetTag = 0;
    mNeumannSetTag   = 0;
    mHasMidNodesTag  = 0;
    mSetTypeTag        = 0;
    mPartHandleTag     = 0;
    mInstancePIDTag    = 0;
    mInstanceGIDTag    = 0;
    mLocalIDTag        = 0;
    mInstanceHandleTag = 0;
    mAssemblyHandleTag = 0;
    mSetNameTag        = 0;
    mMatNameTag        = 0;
    //! Get and cache predefined tag handles
    int negone = -1, negonearr[] = { -1, -1, -1, -1 };
    mMaterialSetTag  = get_tag( MATERIAL_SET_TAG_NAME, 1, MB_TAG_SPARSE, MB_TYPE_INTEGER, &negone );
    mDirichletSetTag = get_tag( DIRICHLET_SET_TAG_NAME, 1, MB_TAG_SPARSE, MB_TYPE_INTEGER, &negone );
    mNeumannSetTag   = get_tag( NEUMANN_SET_TAG_NAME, 1, MB_TAG_SPARSE, MB_TYPE_INTEGER, &negone );
    mHasMidNodesTag  = get_tag( HAS_MID_NODES_TAG_NAME, 4, MB_TAG_SPARSE, MB_TYPE_INTEGER, negonearr );
    mSetTypeTag        = get_tag( ABAQUS_SET_TYPE_TAG_NAME, 1, MB_TAG_SPARSE, MB_TYPE_INTEGER );
    mPartHandleTag     = get_tag( ABAQUS_PART_HANDLE_TAG_NAME, 1, MB_TAG_SPARSE, MB_TYPE_HANDLE );
    mInstanceHandleTag = get_tag( ABAQUS_INSTANCE_HANDLE_TAG_NAME, 1, MB_TAG_DENSE, MB_TYPE_HANDLE );
    mAssemblyHandleTag = get_tag( ABAQUS_ASSEMBLY_HANDLE_TAG_NAME, 1, MB_TAG_DENSE, MB_TYPE_HANDLE );
    mInstancePIDTag    = get_tag( ABAQUS_INSTANCE_PART_ID_TAG_NAME, 1, MB_TAG_SPARSE, MB_TYPE_INTEGER );
    mInstanceGIDTag    = get_tag( ABAQUS_INSTANCE_GLOBAL_ID_TAG_NAME, 1, MB_TAG_SPARSE, MB_TYPE_INTEGER, &negone );
    mLocalIDTag        = get_tag( ABAQUS_LOCAL_ID_TAG_NAME, 1, MB_TAG_DENSE, MB_TYPE_INTEGER );
    mSetNameTag        = get_tag( ABAQUS_SET_NAME_TAG_NAME, ABAQUS_SET_NAME_LENGTH, MB_TAG_SPARSE, MB_TYPE_OPAQUE, 0 );
    mMatNameTag        = get_tag( ABAQUS_MAT_NAME_TAG_NAME, ABAQUS_MAT_NAME_LENGTH, MB_TAG_SPARSE, MB_TYPE_OPAQUE, 0 );
Destructor.
Definition at line 97 of file ReadABAQUS.cpp.
References abFile, mdbImpl, readMeshIface, and moab::Interface::release_interface().
    mdbImpl->release_interface( readMeshIface );
    if( abFile.fail() ) abFile.close();
Member Function Documentation
ErrorCode moab::ReadABAQUS::add_entity_set ( EntityHandle  parent_set,
int  ABQ_set_type,
const std::string &  set_name,
EntityHandle &  entity_set
) [private]
ErrorCode moab::ReadABAQUS::create_instance_of_part ( const EntityHandle  file_set,
const std::string &  part_name,
const std::string &  instance_name,
EntityHandle &  entity_set,
const std::vector< double > &  translation,
const std::vector< double > &  rotation
) [private]
Definition at line 1591 of file ReadABAQUS.cpp.
References ABAQUS_SET_NAME_LENGTH, ABQ_ELEMENT_SET, ABQ_NODE_SET, ABQ_PART_SET, moab::Interface::add_entities(), add_entity_set(), moab::Range::begin(), moab::Range::clear(), moab::Interface::create_element(), DEG2RAD, dim, moab::Range::end(), ErrorCode, moab::Interface::get_connectivity(), moab::Interface::get_coords(), moab::Interface::get_entities_by_dimension(), moab::Interface::get_entities_by_type_and_tag(), moab::ReadUtilIface::get_node_coords(), get_set_by_name(), get_set_elements(), moab::Range::insert(), mAssemblyHandleTag, MB_RETURN_IF_FAIL, MB_START_ID, MB_SUCCESS, MB_TAG_NOT_FOUND, MBENTITYSET, mdbImpl, mInstanceGIDTag, mInstanceHandleTag, mInstancePIDTag, mLocalIDTag, mMaterialSetTag, mMatNameTag, mPartHandleTag, mSetNameTag, mSetTypeTag, num_assembly_instances, num_part_instances, readMeshIface, moab::AffineXform::rotation(), moab::Range::size(), moab::Interface::tag_get_data(), moab::Interface::tag_set_data(), moab::Interface::type_from_handle(), and moab::AffineXform::xform_vector().
Referenced by read_instance().
    ErrorCode status;
    EntityHandle part_set;
    status = get_set_by_name( file_set, ABQ_PART_SET, part_name, part_set );
    MB_RETURN_IF_FAIL;
    // Cross-reference
    status = mdbImpl->tag_set_data( mPartHandleTag, &instance_set, 1, &part_set );
    MB_RETURN_IF_FAIL;
    int instance_id = ++num_part_instances[part_set];
    status          = mdbImpl->tag_set_data( mInstancePIDTag, &instance_set, 1, &instance_id );
    MB_RETURN_IF_FAIL;
    status = mdbImpl->tag_set_data( mAssemblyHandleTag, &instance_set, 1, &assembly_set );
    MB_RETURN_IF_FAIL;
    instance_id = ++num_assembly_instances[assembly_set];
    status      = mdbImpl->tag_set_data( mInstanceGIDTag, &instance_set, 1, &instance_id );
    MB_RETURN_IF_FAIL;
    // Create maps to cross-reference the part and instance versions of each entity
    std::map< EntityHandle, EntityHandle > p2i_nodes, p2i_elements;
    // ---- NODES ----
    // Get all nodes and IDs
    Range part_node_list;
    status = mdbImpl->get_entities_by_dimension( part_set, 0, part_node_list );
    MB_RETURN_IF_FAIL;
    if( 0 < part_node_list.size() )
        std::vector< int > node_ids( part_node_list.size() );
        status = mdbImpl->tag_get_data( mLocalIDTag, part_node_list, &node_ids[0] );
        MB_RETURN_IF_FAIL;
        // std::map<int, EntityHandle> nodeIdMap;
        // for (unsigned int idx = 0; idx < part_node_list.size(); idx++)
        // nodeIdMap[node_ids[idx]] = part_node_list[idx];
        // Create new nodes
        std::vector< double* > coord_arrays( 3 );
        EntityHandle start_node = 0;
        status = readMeshIface->get_node_coords( 3, part_node_list.size(), MB_START_ID, start_node, coord_arrays );
        MB_RETURN_IF_FAIL;
        if( 0 == start_node ) return MB_FAILURE;
        // Copy coordinates into new coord_arrays
        status = mdbImpl->get_coords( part_node_list, coord_arrays[0], coord_arrays[1], coord_arrays[2] );
        // Rotate to new position
        double rot_axis[3];
        rot_axis[0] = rotation[3] - rotation[0];
        rot_axis[1] = rotation[4] - rotation[1];
        rot_axis[2] = rotation[5] - rotation[2];
        AffineXform rotationXform;
        if( rotation[6] != 0 ) rotationXform = AffineXform::rotation( rotation[6] * DEG2RAD, rot_axis );
        // Translate to new position
        for( unsigned int idx = 0; idx < part_node_list.size(); idx++ )
            double coords[3];
            // Transform to new location and then shift origin of rotation
            for( unsigned int dim = 0; dim < 3; dim++ )
                coords[dim] = coord_arrays[dim][idx] + translation[dim] - rotation[dim];
            // Rotate around this origin
            if( rotation[6] != 0 ) rotationXform.xform_vector( coords );
            // Transform origin of rotation back
                coord_arrays[dim][idx] = coords[dim] + rotation[dim];
        Range instance_node_list( start_node, start_node + part_node_list.size() - 1 );
        // (DO NOT) add nodes to file_set
        // status = mdbImpl->add_entities(file_set, instance_node_list);
        // MB_RETURN_IF_FAIL;
        // Add nodes to this instance_set
        status = mdbImpl->add_entities( instance_set, instance_node_list );
        MB_RETURN_IF_FAIL;
        // Add nodes to this assembly_set
        status = mdbImpl->add_entities( assembly_set, instance_node_list );
        MB_RETURN_IF_FAIL;
        // Tag nodes with their local ID's
        status = mdbImpl->tag_set_data( mLocalIDTag, instance_node_list, &node_ids[0] );
        MB_RETURN_IF_FAIL;
        // Create a map of old handles to new handles!!!
            p2i_nodes[part_node_list[idx]] = instance_node_list[idx];
    //  ---- ELEMENTS ----
    Range part_element_list;
    status = get_set_elements( part_set, part_element_list );
    MB_RETURN_IF_FAIL;
    if( 0 < part_element_list.size() )
        std::vector< int > part_element_ids( part_element_list.size() );
        status = mdbImpl->tag_get_data( mLocalIDTag, part_element_list, &part_element_ids[0] );
        MB_RETURN_IF_FAIL;
        // std::map<int, EntityHandle> elementIdMap;
        // for (unsigned int idx = 0; idx < part_element_list.size(); idx++)
        // elementIdMap[part_element_ids[idx]] = part_element_list[idx];
        // Create new elements
        Range instance_element_list;
        instance_element_list.clear();
        // Cross-referencing storage and pointers/iterators
        std::vector< int > instance_element_ids;
        std::vector< int >::iterator part_element_id = part_element_ids.begin();
        for( Range::iterator part_element = part_element_list.begin(); part_element != part_element_list.end();
             ++part_element, ++part_element_id )
            EntityType element_type = mdbImpl->type_from_handle( *part_element );
            std::vector< EntityHandle > part_connectivity, instance_connectivity;
            EntityHandle new_element;
            status = mdbImpl->get_connectivity( &( *part_element ), 1, part_connectivity );
            MB_RETURN_IF_FAIL;
            instance_connectivity.clear();
            for( std::vector< EntityHandle >::iterator connectivity_node = part_connectivity.begin();
                 connectivity_node != part_connectivity.end(); ++connectivity_node )
                instance_connectivity.push_back( p2i_nodes[*connectivity_node] );
            status = mdbImpl->create_element( element_type, &instance_connectivity[0], instance_connectivity.size(),
                                              new_element );
            MB_RETURN_IF_FAIL;
            instance_element_list.insert( new_element );
            p2i_elements[*part_element] = new_element;
            instance_element_ids.push_back( *part_element_id );
        // (DO NOT) add elements to file_set
        // status = mdbImpl->add_entities(file_set, instance_element_list);
        // Add elements to this instance_set
        status = mdbImpl->add_entities( instance_set, instance_element_list );
        MB_RETURN_IF_FAIL;
        // Add elements to this assembly_set
        status = mdbImpl->add_entities( assembly_set, instance_element_list );
        MB_RETURN_IF_FAIL;
        // Tag elements with their local ID's
        status = mdbImpl->tag_set_data( mLocalIDTag, instance_element_list, &( instance_element_ids[0] ) );
        MB_RETURN_IF_FAIL;
    // ----- NODE SETS -----
    // Get all node sets in part
    Range part_node_sets;
    int tag_val      = ABQ_NODE_SET;
    void* tag_data[] = { &tag_val };
    status = mdbImpl->get_entities_by_type_and_tag( part_set, MBENTITYSET, &mSetTypeTag, tag_data, 1, part_node_sets );
    MB_RETURN_IF_FAIL;
    Range part_node_set_list, instance_node_set_list;
    for( Range::iterator part_node_set = part_node_sets.begin(); part_node_set != part_node_sets.end();
         ++part_node_set )
        char node_set_name[ABAQUS_SET_NAME_LENGTH];
        std::fill( node_set_name, node_set_name + ABAQUS_SET_NAME_LENGTH, '\0' );
        status = mdbImpl->tag_get_data( mSetNameTag, &( *part_node_set ), 1, &node_set_name[0] );
        if( MB_SUCCESS != status && MB_TAG_NOT_FOUND != status ) return status;
        part_node_set_list.clear();
        status = mdbImpl->get_entities_by_dimension( *part_node_set, 0, part_node_set_list );
        instance_node_set_list.clear();
        for( Range::iterator set_node = part_node_set_list.begin(); set_node != part_node_set_list.end(); ++set_node )
            instance_node_set_list.insert( p2i_nodes[*set_node] );
        EntityHandle instance_node_set;
        status = add_entity_set( instance_set, ABQ_NODE_SET, node_set_name, instance_node_set );
        MB_RETURN_IF_FAIL;
        status = mdbImpl->add_entities( instance_node_set, instance_node_set_list );
        MB_RETURN_IF_FAIL;
        status = mdbImpl->add_entities( assembly_set, &instance_node_set, 1 );
        MB_RETURN_IF_FAIL;
        status = mdbImpl->tag_set_data( mPartHandleTag, &instance_node_set, 1, &part_set );
        MB_RETURN_IF_FAIL;
        status = mdbImpl->tag_set_data( mAssemblyHandleTag, &instance_node_set, 1, &assembly_set );
        MB_RETURN_IF_FAIL;
    // ----- ELEMENT SETS -----
    // Get all element sets in part
    Range part_element_sets;
    tag_val     = ABQ_ELEMENT_SET;
    tag_data[0] = &tag_val;
    status =
        mdbImpl->get_entities_by_type_and_tag( part_set, MBENTITYSET, &mSetTypeTag, tag_data, 1, part_element_sets );
    MB_RETURN_IF_FAIL;
    Range part_element_set_list, instance_element_set_list;
    for( Range::iterator part_element_set = part_element_sets.begin(); part_element_set != part_element_sets.end();
         ++part_element_set )
        char element_set_name[ABAQUS_SET_NAME_LENGTH];
        std::fill( element_set_name, element_set_name + ABAQUS_SET_NAME_LENGTH, '\0' );
        status = mdbImpl->tag_get_data( mSetNameTag, &( *part_element_set ), 1, &element_set_name[0] );
        part_element_set_list.clear();
        status = get_set_elements( *part_element_set, part_element_set_list );
        instance_element_set_list.clear();
        for( Range::iterator set_element = part_element_set_list.begin(); set_element != part_element_set_list.end();
             ++set_element )
            instance_element_set_list.insert( p2i_elements[*set_element] );
        EntityHandle instance_element_set;
        status = add_entity_set( instance_set, ABQ_ELEMENT_SET, element_set_name, instance_element_set );
        MB_RETURN_IF_FAIL;
        // std::cerr << instance_set << "\t" << instance_element_set << std::endl;
        status = mdbImpl->add_entities( instance_element_set, instance_element_set_list );
        MB_RETURN_IF_FAIL;
        status = mdbImpl->add_entities( assembly_set, &instance_element_set, 1 );
        MB_RETURN_IF_FAIL;
        // status = mdbImpl->add_entities(file_set, &instance_element_set, 1);
        status = mdbImpl->tag_set_data( mPartHandleTag, &instance_element_set, 1, &part_set );
        MB_RETURN_IF_FAIL;
        status = mdbImpl->tag_set_data( mAssemblyHandleTag, &instance_element_set, 1, &assembly_set );
        MB_RETURN_IF_FAIL;
        char element_set_matname[ABAQUS_SET_NAME_LENGTH];
        std::fill( element_set_matname, element_set_matname + ABAQUS_SET_NAME_LENGTH, '\0' );
        status = mdbImpl->tag_get_data( mMatNameTag, &( *part_element_set ), 1, &element_set_matname[0] );
        if( MB_TAG_NOT_FOUND != status )
            status = mdbImpl->tag_set_data( mMatNameTag, &instance_element_set, 1, element_set_matname );
            MB_RETURN_IF_FAIL;
        int element_set_mat_id;
        status = mdbImpl->tag_get_data( mMaterialSetTag, &( *part_element_set ), 1, &element_set_mat_id );
            status = mdbImpl->tag_set_data( mMaterialSetTag, &instance_element_set, 1, &element_set_mat_id );
            MB_RETURN_IF_FAIL;
    // Tag everything with their instance handle
    // some nodes are assigned outside of this routine so query final list of all
    // instance nodes, elements, etc
    Range instance_entity_list;
    status = mdbImpl->get_entities_by_dimension( instance_set, 0, instance_entity_list );
    MB_RETURN_IF_FAIL;
    std::vector< EntityHandle > tmp_instance_handles;
    tmp_instance_handles.assign( instance_entity_list.size(), instance_set );
    status = mdbImpl->tag_set_data( mInstanceHandleTag, instance_entity_list, &tmp_instance_handles[0] );
    MB_RETURN_IF_FAIL;
    instance_entity_list.clear();
    status = get_set_elements( instance_set, instance_entity_list );
    MB_RETURN_IF_FAIL;
    tmp_instance_handles.clear();
    MB_RETURN_IF_FAIL;
    // Get all node sets in instance
    status      = mdbImpl->get_entities_by_type_and_tag( instance_set, MBENTITYSET, &mSetTypeTag, tag_data, 1,
    MB_RETURN_IF_FAIL;
    MB_RETURN_IF_FAIL;
    MB_RETURN_IF_FAIL;
    MB_RETURN_IF_FAIL;
    return MB_SUCCESS;
void moab::ReadABAQUS::cyl2rect ( std::vector< double >  coord_list) [private]
Definition at line 1948 of file ReadABAQUS.cpp.
References DEG2RAD, and t.
Referenced by read_node_list().
    int num_nodes = coord_list.size() / 3;
    double x, y, r, t;
    for( int node = 0; node < num_nodes; node++ )
        r = coord_list[3 * node];
        t = coord_list[3 * node + 1] * DEG2RAD;
        x = r * cos( t );
        y = r * sin( t );
        coord_list[3 * node]     = x;
        coord_list[3 * node + 1] = y;
void moab::ReadABAQUS::extract_keyword_parameters ( const std::vector< std::string > &  tokens,
std::map< std::string, std::string > &  params
) [private]
Definition at line 2097 of file ReadABAQUS.cpp.
References stringToUpper().
Referenced by read_assembly(), read_element_list(), read_element_set(), read_instance(), read_node_list(), read_node_set(), read_part(), and read_solid_section().
    std::string key, value;
    // NOTE: skip first token - it is the keyword
    for( std::vector< std::string >::const_iterator token = tokens.begin() + 1; token != tokens.end(); ++token )
        std::string::size_type pos = token->find( '=' );
        stringToUpper( token->substr( 0, pos ), key );
        if( std::string::npos != pos )
            value = token->substr( pos + 1 );
        else
            value = "";
        pos         = key.find_first_not_of( ' ', 0 );
        key         = key.substr( pos );
        params[key] = value;
Definition at line 48 of file ReadABAQUS.cpp.
References ReadABAQUS().
Referenced by moab::ReaderWriterSet::ReaderWriterSet().
    return new ReadABAQUS( iface );
ErrorCode moab::ReadABAQUS::get_elements_by_id ( EntityHandle  parent_set,
Range &  element_range
) [private]
Definition at line 1423 of file ReadABAQUS.cpp.
References ErrorCode, get_set_elements(), moab::Range::insert(), MB_RETURN_IF_FAIL, MB_SUCCESS, mdbImpl, mLocalIDTag, moab::Range::size(), and moab::Interface::tag_get_data().
Referenced by read_element_set().
    ErrorCode status;
    Range all_elements;
    status = get_set_elements( parent_set, all_elements );
    MB_RETURN_IF_FAIL;
    std::vector< int > element_ids( all_elements.size() );
    status = mdbImpl->tag_get_data( mLocalIDTag, all_elements, &element_ids[0] );
    MB_RETURN_IF_FAIL;
    std::map< int, EntityHandle > elementIdMap;
    for( unsigned int idx = 0; idx < all_elements.size(); idx++ )
        elementIdMap[element_ids[idx]] = all_elements[idx];
    for( std::vector< int >::iterator element = element_ids_subset.begin(); element != element_ids_subset.end();
         ++element )
        element_range.insert( elementIdMap[*element] );
    return MB_SUCCESS;
Definition at line 2010 of file ReadABAQUS.cpp.
References ABQ_AMBIGUOUS, moab::abq_ambiguous, moab::abq_assembly, moab::abq_element, moab::abq_elset, moab::abq_end_assembly, moab::abq_end_instance, moab::abq_end_part, moab::abq_heading, moab::abq_instance, moab::abq_node, moab::abq_nset, moab::abq_part, moab::abq_solid_section, match(), readline, stringToUpper(), and tokenize().
Referenced by load_file(), read_assembly(), read_instance(), and read_part().
    std::vector< std::string > tokens;
    std::map< std::string, abaqus_keyword_type > keywords;
    // Set up list of supported keywords
    // Note: any attempt to match something not in the keyword list
    //       using the [] operator will create a new entry in the map
    //       but that entry will have value abq_undefined based on the
    //       definition of the abaqus_keyword_type enum.
    keywords[ABQ_AMBIGUOUS]   = abq_ambiguous;
    keywords["HEADING"]       = abq_heading;
    keywords["PART"]          = abq_part;
    keywords["END PART"]      = abq_end_part;
    keywords["ASSEMBLY"]      = abq_assembly;
    keywords["END ASSEMBLY"]  = abq_end_assembly;
    keywords["NODE"]          = abq_node;
    keywords["ELEMENT"]       = abq_element;
    keywords["NSET"]          = abq_nset;
    keywords["ELSET"]         = abq_elset;
    keywords["SOLID SECTION"] = abq_solid_section;
    keywords["INSTANCE"]      = abq_instance;
    keywords["END INSTANCE"]  = abq_end_instance;
    tokenize( readline, tokens, "*,\n" );
    // Convert to upper case and test for unambiguous match/partial match
    stringToUpper( tokens[0], tokens[0] );
    return keywords[match( tokens[0], keywords )];
Definition at line 1989 of file ReadABAQUS.cpp.
References abFile, moab::abq_blank_line, moab::abq_comment_line, moab::abq_data_line, moab::abq_eof, moab::abq_keyword_line, lineNo, and readline.
Referenced by load_file(), read_assembly(), read_element_list(), read_element_set(), read_heading(), read_instance(), read_node_list(), read_node_set(), read_part(), and read_solid_section().
    readline.clear();
    std::getline( abFile, readline );
    ++lineNo;
    if( abFile.eof() ) return abq_eof;
    std::string::size_type pos = readline.find_first_not_of( ' ' );
    if( std::string::npos == pos ) return abq_blank_line;
    if( '*' == readline[pos] )
        if( '*' == readline[pos + 1] )
            return abq_comment_line;
        else
            return abq_keyword_line;
    else
        return abq_data_line;
ErrorCode moab::ReadABAQUS::get_nodes_by_id ( EntityHandle  parent_set,
Range &  node_range
) [private]
Definition at line 1448 of file ReadABAQUS.cpp.
References ErrorCode, moab::Interface::get_entities_by_type(), moab::Range::insert(), MB_RETURN_IF_FAIL, MB_SUCCESS, MBVERTEX, mdbImpl, mLocalIDTag, moab::Range::size(), and moab::Interface::tag_get_data().
Referenced by read_node_set().
    ErrorCode status;
    Range all_nodes;
    status = mdbImpl->get_entities_by_type( parent_set, MBVERTEX, all_nodes );
    MB_RETURN_IF_FAIL;
    std::vector< int > node_ids( all_nodes.size() );
    status = mdbImpl->tag_get_data( mLocalIDTag, all_nodes, &node_ids[0] );
    MB_RETURN_IF_FAIL;
    std::map< int, EntityHandle > nodeIdMap;
    for( unsigned int idx = 0; idx < all_nodes.size(); idx++ )
        nodeIdMap[node_ids[idx]] = all_nodes[idx];
    for( std::vector< int >::iterator node = node_ids_subset.begin(); node != node_ids_subset.end(); ++node )
        node_range.insert( nodeIdMap[*node] );
    return MB_SUCCESS;
ErrorCode moab::ReadABAQUS::get_set_by_name ( EntityHandle  parent_set,
int  ABQ_set_type,
EntityHandle &  set_handle
) [private]
Definition at line 1470 of file ReadABAQUS.cpp.
References ABAQUS_SET_NAME_LENGTH, moab::Range::begin(), moab::Range::end(), ErrorCode, moab::Interface::get_entities_by_type_and_tag(), MB_CHK_SET_ERR, MB_SET_ERR, MB_SUCCESS, MB_TAG_NOT_FOUND, MBENTITYSET, mdbImpl, mSetNameTag, mSetTypeTag, and moab::Interface::tag_get_data().
Referenced by create_instance_of_part(), get_set_elements_by_name(), get_set_nodes(), read_element_set(), read_node_set(), and read_solid_section().
    ErrorCode status;
    char this_set_name[ABAQUS_SET_NAME_LENGTH];
    set_handle = 0;
    Range sets;
    void* tag_data[] = { &ABQ_set_type };
    status = mdbImpl->get_entities_by_type_and_tag( parent_set, MBENTITYSET, &mSetTypeTag, tag_data, 1, sets );MB_CHK_SET_ERR( status, "Did not find any sets of that type" );
    for( Range::iterator this_set = sets.begin(); this_set != sets.end() && 0 == set_handle; ++this_set )
        std::fill( this_set_name, this_set_name + ABAQUS_SET_NAME_LENGTH, '\0' );
        status = mdbImpl->tag_get_data( mSetNameTag, &( *this_set ), 1, &this_set_name[0] );
        if( set_name == std::string( this_set_name ) ) set_handle = *this_set;
    if( 0 == set_handle )
        MB_SET_ERR( MB_FAILURE, "Did not find requested set" );
    return MB_SUCCESS;
ErrorCode moab::ReadABAQUS::get_set_elements ( EntityHandle  set_handle,
) [private]
Definition at line 1502 of file ReadABAQUS.cpp.
References moab::Range::clear(), dim, ErrorCode, moab::Interface::get_entities_by_dimension(), MB_RETURN_IF_FAIL, MB_SUCCESS, mdbImpl, and moab::Range::merge().
Referenced by create_instance_of_part(), get_elements_by_id(), get_set_elements_by_name(), and load_file().
    ErrorCode status;
    Range dim_ent_list;
    // Could have elements of multiple dimensions in this set???
    for( int dim = 1; dim <= 3; dim++ )
        dim_ent_list.clear();
        status = mdbImpl->get_entities_by_dimension( set_handle, dim, dim_ent_list );
        MB_RETURN_IF_FAIL;
        element_range.merge( dim_ent_list );
    return MB_SUCCESS;
ErrorCode moab::ReadABAQUS::get_set_elements_by_name ( EntityHandle  parent_set,
int  ABQ_set_type,
) [private]
Definition at line 1521 of file ReadABAQUS.cpp.
References ErrorCode, get_set_by_name(), get_set_elements(), MB_RETURN_IF_FAIL, MB_SUCCESS, and moab::Range::size().
    ErrorCode status;
    EntityHandle set_handle;
    status = get_set_by_name( parent_set, ABQ_set_type, set_name, set_handle );
    MB_RETURN_IF_FAIL;
    status = get_set_elements( set_handle, element_range );
    MB_RETURN_IF_FAIL;
    if( element_range.size() == 0 )
        // std::cout << "No elements were found in set " << set_name << std::endl;
    return MB_SUCCESS;
ErrorCode moab::ReadABAQUS::get_set_nodes ( EntityHandle  parent_set,
int  ABQ_set_type,
Range &  node_range
) [private]
Definition at line 1543 of file ReadABAQUS.cpp.
References moab::Range::clear(), dim, ErrorCode, moab::Interface::get_adjacencies(), moab::Interface::get_entities_by_dimension(), get_set_by_name(), MB_RETURN_IF_FAIL, MB_SUCCESS, mdbImpl, moab::Range::merge(), and moab::Range::size().
    ErrorCode status;
    MB_RETURN_IF_FAIL;
    Range ent_list;
    Range dim_ent_list;
    for( int dim = 0; dim <= 3; dim++ )
        MB_RETURN_IF_FAIL;
        ent_list.merge( dim_ent_list );
    status = mdbImpl->get_adjacencies( ent_list, 0, false, node_range );
    MB_RETURN_IF_FAIL;
    if( node_range.size() == 0 )
        std::cout << "No nodes were found in set " << set_name << std::endl;
    return MB_SUCCESS;
Tag moab::ReadABAQUS::get_tag ( const char *  tag_name,
int  tag_size,
TagType  tag_type,
const void *  def_val = 0
) [private]
Definition at line 1577 of file ReadABAQUS.cpp.
References ErrorCode, MB_SUCCESS, MB_TAG_CREAT, mdbImpl, and moab::Interface::tag_get_handle().
Referenced by ReadABAQUS().
    Tag retval;
    ErrorCode rval =
        mdbImpl->tag_get_handle( tag_name, tag_size, tag_data_type, retval, tag_type | MB_TAG_CREAT, def_val );
    assert( MB_SUCCESS == rval );
    return MB_SUCCESS == rval ? retval : 0;
ErrorCode moab::ReadABAQUS::load_file ( const char *  file_name,
const EntityHandle *  file_set,
const FileOptions &  opts,
const SubsetList *  subset_list = 0,
const Tag *  file_id_tag = 0
) [virtual]
Implements moab::ReaderIface.
Definition at line 120 of file ReadABAQUS.cpp.
References abFile, moab::abq_assembly, moab::abq_comment_line, moab::abq_data_line, ABQ_ELEMENT_SET, moab::abq_eof, moab::abq_heading, moab::abq_keyword_line, ABQ_NODE_SET, moab::abq_part, ABQ_PART_SET, moab::Range::begin(), moab::Interface::create_meshset(), moab::Interface::delete_entities(), moab::Range::end(), ErrorCode, moab::Interface::get_entities_by_dimension(), moab::Interface::get_entities_by_type_and_tag(), get_keyword(), get_next_line_type(), get_set_elements(), lineNo, MB_FILE_DOES_NOT_EXIST, MB_RETURN_IF_FAIL, MB_SET_ERR, MB_SUCCESS, MB_UNSUPPORTED_OPERATION, MBENTITYSET, mdbImpl, MESHSET_SET, mSetTypeTag, next_line_type, read_assembly(), read_heading(), read_part(), and moab::Interface::unite_meshset().
    ErrorCode status;
    if( subset_list )
        MB_SET_ERR( MB_UNSUPPORTED_OPERATION, "Reading subset of files not supported for ABAQUS data" );
    // Open file
    lineNo = 0;
    abFile.open( abaqus_file_name );
    if( !abFile ) return MB_FILE_DOES_NOT_EXIST;
    bool in_unsupported = false;
    EntityHandle file_set;
    status = mdbImpl->create_meshset( MESHSET_SET, file_set );
    if( MB_SUCCESS != status ) return status;
    next_line_type = get_next_line_type();
    while( next_line_type != abq_eof )
        switch( next_line_type )
            case abq_keyword_line:
                switch( get_keyword() )
                    case abq_heading:
                        // Read header
                        status = read_heading( file_set );
                        break;
                    case abq_part:
                        // Read parts until done
                        status = read_part( file_set );
                        break;
                    case abq_assembly:
                        // Read assembly (or assemblies?)
                        status = read_assembly( file_set );
                        break;
                    default:
                        // Skip reading other content for now
                        // (e.g. material properties, loads, surface interactions, etc)
                        in_unsupported = true;
                        // std::cout << "Ignoring unsupported keyword: " << readline << std::endl;
                MB_RETURN_IF_FAIL;
                break;
            case abq_comment_line:
                break;
            case abq_data_line:
                if( !in_unsupported )
                    MB_SET_ERR( MB_FAILURE, "Expected Keyword" );
                break;
            default:
                MB_SET_ERR( MB_FAILURE, "Invalid/unrecognized line" );
    // Temporary??? delete parts
    Range part_sets;
    int tag_val      = ABQ_PART_SET;
    status = mdbImpl->get_entities_by_type_and_tag( file_set, MBENTITYSET, &mSetTypeTag, tag_data, 1, part_sets );
    MB_RETURN_IF_FAIL;
    for( Range::iterator part_set = part_sets.begin(); part_set != part_sets.end(); ++part_set )
        Range ent_sets;
        status = mdbImpl->get_entities_by_type_and_tag( *part_set, MBENTITYSET, &mSetTypeTag, tag_data, 1, ent_sets );
        MB_RETURN_IF_FAIL;
        status = mdbImpl->delete_entities( ent_sets );
        MB_RETURN_IF_FAIL;
        MB_RETURN_IF_FAIL;
        MB_RETURN_IF_FAIL;
        Range node_list, ele_list;
        status = get_set_elements( *part_set, ele_list );
        MB_RETURN_IF_FAIL;
        status = mdbImpl->delete_entities( ele_list );
        MB_RETURN_IF_FAIL;
        status = mdbImpl->get_entities_by_dimension( *part_set, 0, node_list );
        MB_RETURN_IF_FAIL;
        status = mdbImpl->delete_entities( node_list );
        MB_RETURN_IF_FAIL;
    if( file_set_ptr )
        status = mdbImpl->unite_meshset( *file_set_ptr, file_set );
        MB_RETURN_IF_FAIL;
    return mdbImpl->delete_entities( &file_set, 1 );
template<typename T >
std::string moab::ReadABAQUS::match ( const std::string &  token,
std::map< std::string, T > &  tokenList
) [private]
Definition at line 2046 of file ReadABAQUS.cpp.
References ABQ_AMBIGUOUS, and ABQ_UNDEFINED.
Referenced by get_keyword(), read_assembly(), read_element_list(), read_element_set(), read_instance(), read_node_list(), read_node_set(), read_part(), and read_solid_section().
    // Initialize with no match and ABQ_UNDEFINED as return string
    bool found_match       = false;
    std::string best_match = ABQ_UNDEFINED;
    // Search the map
    for( typename std::map< std::string, T >::iterator thisToken = tokenList.begin(); thisToken != tokenList.end();
         ++thisToken )
        // If a perfect match break the loop (assume keyword list is unambiguous)
        if( token == ( *thisToken ).first )
            best_match = token;
            break;
        else
            int short_length =
                ( token.length() < ( *thisToken ).first.length() ? token.length() : ( *thisToken ).first.length() );
            // If the token matches the first token.length() characters of the keyword
            // consider this a match
            if( token.substr( short_length ) == ( *thisToken ).first.substr( short_length ) )
                if( !found_match )
                    // If no match already, record match and matching keyword
                    found_match = true;
                    best_match  = ( *thisToken ).first;
                else
                    // If match already set matching keyword to ABQ_AMBIGUOUS
                    best_match = ABQ_AMBIGUOUS;
    // Possible return values: ABQ_UNDEFINED, keyword from list, ABQ_AMBIGUOUS
    return best_match;
Definition at line 253 of file ReadABAQUS.cpp.
References ABQ_AMBIGUOUS, moab::abq_assembly_ambiguous, moab::abq_assembly_name, ABQ_ASSEMBLY_SET, moab::abq_blank_line, moab::abq_comment_line, moab::abq_data_line, moab::abq_end_assembly, moab::abq_eof, moab::abq_instance, moab::abq_keyword_line, moab::abq_nset, add_entity_set(), ErrorCode, extract_keyword_parameters(), get_keyword(), get_next_line_type(), match(), MB_RETURN_IF_FAIL, MB_SUCCESS, next_line_type, num_assembly_instances, read_instance(), read_node_set(), readline, and tokenize().
Referenced by load_file().
    ErrorCode status = MB_SUCCESS;
    std::map< std::string, std::string > params;
    std::map< std::string, abaqus_assembly_params > requiredParams;
    requiredParams["NAME"] = abq_assembly_name;
    std::map< std::string, abaqus_assembly_params > allowableParams;
    allowableParams[ABQ_AMBIGUOUS] = abq_assembly_ambiguous;
    abaqus_assembly_params param;
    std::string assembly_name;
    // Tokenize last line read
    tokenize( readline, tokens, ",\n" );
    extract_keyword_parameters( tokens, params );
    // Search for required parameters
    for( std::map< std::string, abaqus_assembly_params >::iterator thisParam = requiredParams.begin();
         thisParam != requiredParams.end(); ++thisParam )
        std::string param_key = match( ( *thisParam ).first, params );
        param                 = requiredParams[param_key];
        switch( param )
            case abq_assembly_name:
                assembly_name = params[param_key];
                params.erase( param_key );
                // std::cout << "Adding ASSEMBLY with name: " << assembly_name << std::endl; //
                // REMOVE
                break;
            default:
                // std::cout << "Missing required ASSEMBLY parameter " << (*thisParam).first <<
                // std::endl;
                return MB_FAILURE;
    // Process parameters
    for( std::map< std::string, std::string >::iterator thisParam = params.begin(); thisParam != params.end();
         ++thisParam )
        // Look for unambiguous match with this node parameter
        param = allowableParams[match( ( *thisParam ).first, allowableParams )];
        switch( param )
            case abq_assembly_ambiguous:
                // std::cout << "\tIgnoring ambiguous ASSEMBLY parameter: " << (*thisParam).first
                //          << "=" << (*thisParam).second << std::endl;
                break;
            default:
                // std::cout << "\tIgnoring unsupported ASSEMBLY parameter: " << (*thisParam).first
                break;
    EntityHandle assembly_set;
    status = add_entity_set( file_set, ABQ_ASSEMBLY_SET, assembly_name, assembly_set );
    bool end_assembly   = false;
    while( next_line_type != abq_eof && !end_assembly )
                    case abq_end_assembly:
                        end_assembly = true;
                        break;
                    case abq_instance:
                        status = read_instance( assembly_set, file_set );
                        break;
                    case abq_nset:
                        status = read_node_set( assembly_set, file_set );
                        break;
                    default:
                        // std::cout << "\tIgnoring unsupported keyword in this ASSEMBLY: "
                        //          << readline << std::endl;
                        break;
                break;
                break;
            case abq_data_line:
                    // std::cout << "Internal Error: Data lines not allowed in ASSEMBLY keyword."
                    //          << std::endl << readline << std::endl;
                    return MB_FAILURE;
                break;
            case abq_blank_line:
                // std::cout << "Error: Blank lines are not allowed." << std::endl;
                return MB_FAILURE;
            default:
                // std::cout << "Error reading ASSEMBLY " << assembly_name << std::endl;
                return MB_FAILURE;
        MB_RETURN_IF_FAIL;
    num_assembly_instances[assembly_set] = 0;
    return MB_SUCCESS;
ErrorCode moab::ReadABAQUS::read_element_list ( EntityHandle  parent_set,
EntityHandle  assembly_set = 0
) [private]
Definition at line 1072 of file ReadABAQUS.cpp.
References ABQ_AMBIGUOUS, moab::abq_data_line, moab::abq_element_ambiguous, moab::abq_element_elset, ABQ_ELEMENT_SET, moab::abq_element_type, moab::abq_element_undefined, moab::abq_eletype_c3d4, moab::abq_eletype_c3d8r, moab::abq_eletype_dc3d4, moab::abq_eletype_dc3d8, moab::abq_eletype_dcc3d8, moab::abq_eletype_ds4, moab::abq_eletype_unsupported, moab::abq_eof, moab::abq_keyword_line, moab::Interface::add_entities(), add_entity_set(), ErrorCode, extract_keyword_parameters(), moab::ReadUtilIface::get_element_connect(), moab::Interface::get_entities_by_dimension(), get_next_line_type(), mAssemblyHandleTag, match(), MB_RETURN_IF_FAIL, MB_SET_ERR, MB_START_ID, MB_SUCCESS, MBHEX, MBQUAD, MBTET, mdbImpl, mLocalIDTag, next_line_type, readline, readMeshIface, moab::Range::size(), moab::Interface::tag_get_data(), moab::Interface::tag_set_data(), and tokenize().
Referenced by read_instance(), and read_part().
    ErrorCode status;
    std::map< std::string, abaqus_element_params > requiredParams;
    requiredParams["TYPE"] = abq_element_type;
    std::map< std::string, abaqus_element_params > allowableParams;
    allowableParams[ABQ_AMBIGUOUS] = abq_element_ambiguous;
    allowableParams["ELSET"]       = abq_element_elset;
    abaqus_element_params param;
    std::map< std::string, abaqus_element_type > elementTypes;
    std::map< abaqus_element_type, unsigned int > nodes_per_element;
    std::map< abaqus_element_type, EntityType > entityTypeMap;
    elementTypes["DC3D8"]                = abq_eletype_dc3d8;
    nodes_per_element[abq_eletype_dc3d8] = 8;
    entityTypeMap[abq_eletype_dc3d8]     = MBHEX;
    elementTypes["DCC3D8"]                = abq_eletype_dcc3d8;
    nodes_per_element[abq_eletype_dcc3d8] = 8;
    entityTypeMap[abq_eletype_dcc3d8]     = MBHEX;
    elementTypes["C3D4"]                = abq_eletype_c3d4;
    nodes_per_element[abq_eletype_c3d4] = 4;
    entityTypeMap[abq_eletype_c3d4]     = MBTET;
    elementTypes["DC3D4"]                = abq_eletype_dc3d4;
    nodes_per_element[abq_eletype_dc3d4] = 4;
    entityTypeMap[abq_eletype_dc3d4]     = MBTET;
    elementTypes["C3D8R"]                = abq_eletype_c3d8r;
    nodes_per_element[abq_eletype_c3d8r] = 8;
    entityTypeMap[abq_eletype_c3d8r]     = MBHEX;
    elementTypes["DS4"]                = abq_eletype_ds4;
    nodes_per_element[abq_eletype_ds4] = 4;
    entityTypeMap[abq_eletype_ds4]     = MBQUAD;
    abaqus_element_type element_type = abq_eletype_dc3d8;
    bool make_element_set = false;
    std::string element_set_name;
    for( std::map< std::string, abaqus_element_params >::iterator thisParam = requiredParams.begin();
        switch( param )
            case abq_element_type:
                element_type = elementTypes[params[param_key]];
                if( abq_eletype_unsupported == element_type )
                    MB_SET_ERR( MB_FAILURE, "MOAB doesn't currently support this element type" );
                // std::cout << "\tAdding ELEMENTS of type: " << params[param_key] << std::endl; //
                // REMOVE
                break;
            case abq_element_undefined:
                MB_SET_ERR( MB_FAILURE, "Missing required ELEMENT parameter" );
            default:
                break;
         ++thisParam )
        switch( param )
            case abq_element_elset:
                make_element_set = true;
                element_set_name = ( *thisParam ).second;
                break;
            case abq_element_ambiguous:
                // std::cout << "\t\tIgnoring ambiguous ELEMENT parameter: " << (*thisParam).first
                break;
            default:
                // std::cout << "\t\tIgnoring unsupported ELEMENT parameter: " << (*thisParam).first
                break;
    std::vector< int > connect_list, element_ids;
    while( next_line_type != abq_eof && next_line_type != abq_keyword_line )
        if( abq_data_line == next_line_type )
            tokenize( readline, tokens, ", \n" );
            if( tokens.size() < nodes_per_element[element_type] + 1 )
                MB_SET_ERR( MB_FAILURE, "Not enough data on node data line" );
            element_ids.push_back( atoi( tokens[0].c_str() ) );
            for( unsigned int i = 1; i < nodes_per_element[element_type] + 1; i++ )
                connect_list.push_back( atoi( tokens[i].c_str() ) );
    int num_elements = element_ids.size();
    // Get and fill element arrays
    EntityHandle start_element = 0;
    EntityHandle* connect;
    status = readMeshIface->get_element_connect( num_elements, nodes_per_element[element_type],
                                                 entityTypeMap[element_type], MB_START_ID, start_element, connect );
    MB_RETURN_IF_FAIL;
    if( 0 == start_element ) return MB_FAILURE;
    // ASSUME: elements must be defined after nodes!
    // Get list of node entity handles and node IDs
    Range node_list;
    status = mdbImpl->get_entities_by_dimension( parent_set, 0, node_list );
    MB_RETURN_IF_FAIL;
    std::vector< int > node_ids( node_list.size() );
    status = mdbImpl->tag_get_data( mLocalIDTag, node_list, &node_ids[0] );
    MB_RETURN_IF_FAIL;
    for( unsigned int idx = 0; idx < node_list.size(); idx++ )
        nodeIdMap[node_ids[idx]] = node_list[idx];
    for( unsigned int node = 0; node < connect_list.size(); node++ )
        connect[node] = nodeIdMap[connect_list[node]];
    Range element_range( start_element, start_element + num_elements - 1 );
    // Add elements to file_set
    // status = mdbImpl->add_entities(file_set, element_range);
    // Add elements to this parent_set
    status = mdbImpl->add_entities( parent_set, element_range );
    MB_RETURN_IF_FAIL;
    status = mdbImpl->tag_set_data( mLocalIDTag, element_range, &element_ids[0] );
    MB_RETURN_IF_FAIL;
    if( assembly_set )
        status = mdbImpl->add_entities( assembly_set, element_range );
        MB_RETURN_IF_FAIL;
        std::vector< EntityHandle > tmp_assembly_handles;
        tmp_assembly_handles.assign( element_range.size(), assembly_set );
        status = mdbImpl->tag_set_data( mAssemblyHandleTag, element_range, &( tmp_assembly_handles[0] ) );
        MB_RETURN_IF_FAIL;
    // These elements don't know their instance_set (probably not defined)
    if( make_element_set )
        EntityHandle element_set;
        status = add_entity_set( parent_set, ABQ_ELEMENT_SET, element_set_name, element_set );
        MB_RETURN_IF_FAIL;
        status = mdbImpl->add_entities( element_set, element_range );
        MB_RETURN_IF_FAIL;
        // This ad-hoc element set doesn't know its:
        // * part_set (probably parent_set)
        // * instance_set (probably not defined)
        // * assembly_set (probably not defined)
    return MB_SUCCESS;
ErrorCode moab::ReadABAQUS::read_element_set ( EntityHandle  parent_set,
EntityHandle  file_set = 0,
) [private]
Definition at line 747 of file ReadABAQUS.cpp.
References ABQ_AMBIGUOUS, moab::abq_data_line, ABQ_ELEMENT_SET, moab::abq_elset_ambiguous, moab::abq_elset_elset, moab::abq_elset_generate, moab::abq_elset_instance, moab::abq_eof, ABQ_INSTANCE_SET, moab::abq_keyword_line, moab::Interface::add_entities(), add_entity_set(), moab::Range::clear(), ErrorCode, extract_keyword_parameters(), get_elements_by_id(), get_next_line_type(), get_set_by_name(), get_set_elements_by_name(), mAssemblyHandleTag, match(), MB_RETURN_IF_FAIL, MB_SET_ERR, MB_SUCCESS, mdbImpl, moab::Range::merge(), next_line_type, readline, moab::Interface::tag_set_data(), and tokenize().
    ErrorCode status;
    std::map< std::string, abaqus_elset_params > requiredParams;
    requiredParams["ELSET"] = abq_elset_elset;
    std::map< std::string, abaqus_elset_params > allowableParams;
    allowableParams[ABQ_AMBIGUOUS] = abq_elset_ambiguous;
    allowableParams["GENERATE"]    = abq_elset_generate;
    allowableParams["INSTANCE"]    = abq_elset_instance;
    abaqus_elset_params param;
    std::string elset_name;
    bool generate_elset = false;
    std::string instance_name;
    EntityHandle element_container_set = parent_set;
    Range element_range;
    for( std::map< std::string, abaqus_elset_params >::iterator thisParam = requiredParams.begin();
        switch( param )
            case abq_elset_elset:
                elset_name = params[param_key];
                // std::cout << "\tAdding ELSET with name: " << elset_name << std::endl; // REMOVE
                break;
            default:
                MB_SET_ERR( MB_FAILURE, "Missing required ELSET parameter" );
         ++thisParam )
        switch( param )
            case abq_elset_generate:
                generate_elset = true;
                break;
            case abq_elset_instance:
                instance_name = ( *thisParam ).second;
                status        = get_set_by_name( parent_set, ABQ_INSTANCE_SET, instance_name, element_container_set );
                MB_RETURN_IF_FAIL;
                break;
            case abq_elset_ambiguous:
                // std::cout << "\t\tIgnoring ambiguous ELSET parameter: " << (*thisParam).first
                break;
            default:
                // std::cout << "\t\tIgnoring unsupported ELSET parameter: " << (*thisParam).first
                break;
    std::vector< int > element_list;
    Range tmp_element_range;
            if( generate_elset )
                if( tokens.size() != 3 )
                    MB_SET_ERR( MB_FAILURE, "Wrong number of entries on GENERATE element set data line" );
                int e1   = atoi( tokens[0].c_str() );
                int e2   = atoi( tokens[1].c_str() );
                int incr = atoi( tokens[2].c_str() );
                if( ( incr == 0 ) || ( ( ( e2 - e1 ) % incr ) != 0 ) )
                    MB_SET_ERR( MB_FAILURE, "Invalid data on GENERATE element set data line" );
                for( int element_id = e1; element_id <= e2; element_id += incr )
                    element_list.push_back( element_id );
            else
                for( unsigned int idx = 0; idx < tokens.size(); idx++ )
                    if( isalpha( tokens[idx][0] ) )
                        tmp_element_range.clear();
                        status = get_set_elements_by_name( element_container_set, ABQ_ELEMENT_SET, tokens[idx],
                                                           tmp_element_range );
                        MB_RETURN_IF_FAIL;
                        element_range.merge( tmp_element_range );
                    else
                        element_list.push_back( atoi( tokens[idx].c_str() ) );
        }  // if (abq_data_line == next_line_type)
    }  // while (next_line_type != abq_eof && next_line_type != abq_keyword_line)
    status = get_elements_by_id( element_container_set, element_list, tmp_element_range );
    MB_RETURN_IF_FAIL;
    status = add_entity_set( parent_set, ABQ_ELEMENT_SET, elset_name, element_set );
    MB_RETURN_IF_FAIL;
    MB_RETURN_IF_FAIL;
    // SHOULD WE EVER DO THIS???
    if( file_set )
        status = mdbImpl->add_entities( file_set, &element_set, 1 );
        MB_RETURN_IF_FAIL;
    if( assembly_set )
        status = mdbImpl->add_entities( assembly_set, &element_set, 1 );
        MB_RETURN_IF_FAIL;
        status = mdbImpl->tag_set_data( mAssemblyHandleTag, &element_set, 1, &assembly_set );
        MB_RETURN_IF_FAIL;
    return MB_SUCCESS;
Definition at line 240 of file ReadABAQUS.cpp.
References moab::abq_comment_line, moab::abq_data_line, get_next_line_type(), MB_SUCCESS, and next_line_type.
    // Current line is only heading token. get next line
    // Perhaps keep first line and tag geometry with title?
    while( abq_data_line == next_line_type || abq_comment_line == next_line_type )
    return MB_SUCCESS;
ErrorCode moab::ReadABAQUS::read_instance ( EntityHandle  assembly_set,
) [private]
Definition at line 374 of file ReadABAQUS.cpp.
References ABQ_AMBIGUOUS, moab::abq_blank_line, moab::abq_comment_line, moab::abq_data_line, moab::abq_element, moab::abq_elset, moab::abq_end_instance, moab::abq_eof, moab::abq_instance_ambiguous, moab::abq_instance_name, moab::abq_instance_part, ABQ_INSTANCE_SET, moab::abq_keyword_line, moab::abq_node, moab::abq_nset, moab::abq_solid_section, add_entity_set(), create_instance_of_part(), ErrorCode, extract_keyword_parameters(), get_keyword(), get_next_line_type(), match(), MB_RETURN_IF_FAIL, MB_SET_ERR, MB_SUCCESS, next_line_type, read_element_list(), read_element_set(), read_node_list(), read_node_set(), read_solid_section(), readline, and tokenize().
Referenced by read_assembly().
    std::map< std::string, abaqus_instance_params > requiredParams;
    requiredParams["NAME"] = abq_instance_name;
    requiredParams["PART"] = abq_instance_part;
    std::map< std::string, abaqus_instance_params > allowableParams;
    allowableParams[ABQ_AMBIGUOUS] = abq_instance_ambiguous;
    abaqus_instance_params param;
    std::string instance_name, part_name;
    for( std::map< std::string, abaqus_instance_params >::iterator thisParam = requiredParams.begin();
        switch( param )
            case abq_instance_name:
                instance_name = params[param_key];
                break;
            case abq_instance_part:
                part_name = params[param_key];
                break;
            default:
                // std::cout << "Missing required INSTANCE parameter " << (*thisParam).first <<
                // std::endl;
                return MB_FAILURE;
    // std::cout << "\tAdding INSTANCE with name: " << instance_name << " of PART wit name: " <<
    // part_name <<  std::endl; // REMOVE
         ++thisParam )
        switch( param )
            case abq_instance_ambiguous:
                // std::cout << "\t\tIgnoring ambiguous INSTANCE parameter: " << (*thisParam).first
                break;
            default:
                // std::cout << "\t\tIgnoring unsupported INSTANCE parameter: " <<
                // (*thisParam).first
                break;
    bool read_translation = false;
    bool read_rotation    = false;
    std::vector< double > translation( 3, 0 );
    std::vector< double > rotation( 7, 0 );
    bool end_instance   = false;
    EntityHandle instance_set;
    status = add_entity_set( assembly_set, ABQ_INSTANCE_SET, instance_name, instance_set );
    MB_RETURN_IF_FAIL;
    while( next_line_type != abq_eof && !end_instance )
                    case abq_end_instance:
                        end_instance   = true;
                        break;
                    case abq_node:
                        status = read_node_list( instance_set, assembly_set );
                        break;
                    case abq_element:
                        status = read_element_list( instance_set, assembly_set );
                        break;
                    case abq_nset:
                        status = read_node_set( instance_set, file_set, assembly_set );
                        break;
                    case abq_elset:
                        status = read_element_set( instance_set, file_set, assembly_set );
                        break;
                    case abq_solid_section:
                        status = read_solid_section( instance_set );
                        break;
                    default:
                        // std::cout << "\t\tIgnoring unsupported keyword in this INSTANCE: "
                        break;
                break;
                break;
            case abq_data_line:
                    if( !read_translation )
                            MB_SET_ERR( MB_FAILURE, "Wrong number of entries on INSTANCE translation line" );
                        for( unsigned int i = 0; i < 3; i++ )
                            translation[i] = atof( tokens[i].c_str() );
                        read_translation = true;
                    else if( !read_rotation )
                        if( tokens.size() != 7 )
                            MB_SET_ERR( MB_FAILURE, "Wrong number of entries on INSTANCE rotation line" );
                        for( unsigned int i = 0; i < 7; i++ )
                            rotation[i] = atof( tokens[i].c_str() );
                        read_rotation = true;
                    else
                        MB_SET_ERR( MB_FAILURE, "Too many data lines for this INSTANCE" );
                }  // if (!in_unsupported)
                break;
                MB_SET_ERR( MB_FAILURE, "Error: Blank lines are not allowed" );
            default:
                MB_SET_ERR( MB_FAILURE, "Error reading INSTANCE" );
        }  // switch (next_line_type)
    }      // while (next_line_type != abq_eof && !end_instance)
    status = create_instance_of_part( file_set, assembly_set, part_name, instance_name, instance_set, translation,
                                      rotation );
    MB_RETURN_IF_FAIL;
    return MB_SUCCESS;
ErrorCode moab::ReadABAQUS::read_node_list ( EntityHandle  parent_set,
) [private]
Definition at line 1266 of file ReadABAQUS.cpp.
References ABQ_AMBIGUOUS, moab::abq_data_line, moab::abq_eof, moab::abq_keyword_line, moab::abq_node_ambiguous, moab::abq_node_nset, ABQ_NODE_SET, moab::abq_node_system, moab::Interface::add_entities(), add_entity_set(), cyl2rect(), ErrorCode, extract_keyword_parameters(), get_next_line_type(), moab::ReadUtilIface::get_node_coords(), mAssemblyHandleTag, match(), MB_RETURN_IF_FAIL, MB_SET_ERR, MB_START_ID, MB_SUCCESS, mdbImpl, mLocalIDTag, next_line_type, readline, readMeshIface, moab::Range::size(), sph2rect(), moab::Interface::tag_set_data(), and tokenize().
    ErrorCode status;
    std::map< std::string, abaqus_node_params > allowableParams;
    allowableParams[ABQ_AMBIGUOUS] = abq_node_ambiguous;
    allowableParams["NSET"]        = abq_node_nset;
    allowableParams["SYSTEM"]      = abq_node_system;
    abaqus_node_params param;
    bool make_node_set = false;
    std::string node_set_name;
    char coord_system = 'R';
    // std::cout << "\tAdding NODES"  << std::endl; // REMOVE
         ++thisParam )
        switch( param )
            case abq_node_nset:
                make_node_set = true;
                node_set_name = ( *thisParam ).second;
                break;
            case abq_node_system:
                // Store coordinate system
                coord_system = ( *thisParam ).second[0];
                break;
            case abq_node_ambiguous:
                // std::cout << "\t\tIgnoring ambiguous NODE parameter: " << (*thisParam).first
                break;
            default:
                // std::cout << "\t\tIgnoring unsupported NODE parameter: " << (*thisParam).first
                break;
    std::vector< double > coord_list;
    std::vector< int > node_ids;
            if( tokens.size() < 4 )
            node_ids.push_back( atoi( tokens[0].c_str() ) );
            for( unsigned int i = 1; i < 4; i++ )
                coord_list.push_back( atof( tokens[i].c_str() ) );
    unsigned int num_nodes = node_ids.size();
    // Transform coordinate systems
    switch( coord_system )
        case 'R':
            break;
        case 'C':
            cyl2rect( coord_list );
            break;
        case 'S':
            sph2rect( coord_list );
            break;
        default:
            // std::cout << "Treating undefined coordinate system: " << coord_system
            //          << " as rectangular/Cartesian." << std::endl;
            break;
    // Get and fill coordinate arrays
    status                  = readMeshIface->get_node_coords( 3, num_nodes, MB_START_ID, start_node, coord_arrays );
    MB_RETURN_IF_FAIL;
    // Cppcheck warning (false positive): variable coord_arrays is assigned a value that is never
    // used
    for( unsigned int idx = 0; idx < num_nodes; idx++ )
        coord_arrays[0][idx] = coord_list[idx * 3];
        coord_arrays[1][idx] = coord_list[idx * 3 + 1];
        coord_arrays[2][idx] = coord_list[idx * 3 + 2];
    Range node_range( start_node, start_node + num_nodes - 1 );
    // Add nodes to file_set
    // status = mdbImpl->add_entities(file_set, node_range);
    // Add nodes to this parent_set
    status = mdbImpl->add_entities( parent_set, node_range );
    MB_RETURN_IF_FAIL;
    status = mdbImpl->tag_set_data( mLocalIDTag, node_range, &node_ids[0] );
    MB_RETURN_IF_FAIL;
    if( assembly_set )
        status = mdbImpl->add_entities( assembly_set, node_range );
        MB_RETURN_IF_FAIL;
        tmp_assembly_handles.assign( node_range.size(), assembly_set );
        status = mdbImpl->tag_set_data( mAssemblyHandleTag, node_range, &( tmp_assembly_handles[0] ) );
        MB_RETURN_IF_FAIL;
    // These nodes don't know their instance_set (probably not defined)
    if( make_node_set )
        EntityHandle node_set;
        status = add_entity_set( parent_set, ABQ_NODE_SET, node_set_name, node_set );
        MB_RETURN_IF_FAIL;
        status = mdbImpl->add_entities( node_set, node_range );
        MB_RETURN_IF_FAIL;
        // This ad-hoc node set doesn't know its:
    return MB_SUCCESS;
ErrorCode moab::ReadABAQUS::read_node_set ( EntityHandle  parent_set,
) [private]
Definition at line 901 of file ReadABAQUS.cpp.
References ABQ_AMBIGUOUS, moab::abq_data_line, ABQ_ELEMENT_SET, moab::abq_eof, ABQ_INSTANCE_SET, moab::abq_keyword_line, ABQ_NODE_SET, moab::abq_nset_ambiguous, moab::abq_nset_elset, moab::abq_nset_generate, moab::abq_nset_instance, moab::abq_nset_nset, moab::Interface::add_entities(), add_entity_set(), moab::Range::clear(), ErrorCode, extract_keyword_parameters(), get_next_line_type(), get_nodes_by_id(), get_set_by_name(), get_set_nodes(), mAssemblyHandleTag, match(), MB_RETURN_IF_FAIL, MB_SET_ERR, MB_SUCCESS, mdbImpl, moab::Range::merge(), next_line_type, readline, moab::Interface::tag_set_data(), and tokenize().
Referenced by read_assembly(), read_instance(), and read_part().
    ErrorCode status;
    std::map< std::string, abaqus_nset_params > requiredParams;
    requiredParams["NSET"] = abq_nset_nset;
    std::map< std::string, abaqus_nset_params > allowableParams;
    allowableParams[ABQ_AMBIGUOUS] = abq_nset_ambiguous;
    allowableParams["ELSET"]       = abq_nset_elset;
    allowableParams["GENERATE"]    = abq_nset_generate;
    allowableParams["INSTANCE"]    = abq_nset_instance;
    abaqus_nset_params param;
    std::string nset_name;
    bool make_from_elset = false;
    bool generate_nset   = false;
    std::string elset_name, instance_name;
    EntityHandle node_container_set = parent_set;
    Range node_range;
    for( std::map< std::string, abaqus_nset_params >::iterator thisParam = requiredParams.begin();
        switch( param )
            case abq_nset_nset:
                nset_name = params[param_key];
                // std::cout << "\tAdding NSET with name: " << nset_name << std::endl; // REMOVE
                break;
            default:
                MB_SET_ERR( MB_FAILURE, "Missing required NSET parameter" );
         ++thisParam )
        switch( param )
            case abq_nset_elset:
                make_from_elset = true;
                elset_name      = ( *thisParam ).second;
                break;
            case abq_nset_generate:
                generate_nset = true;
                break;
            case abq_nset_instance:
                status        = get_set_by_name( parent_set, ABQ_INSTANCE_SET, instance_name, node_container_set );
                MB_RETURN_IF_FAIL;
                break;
            case abq_nset_ambiguous:
                // std::cout << "\t\tIgnoring ambiguous NSET parameter: " << (*thisParam).first
                break;
            default:
                // std::cout << "\t\tIgnoring unsupported NSET parameter: " << (*thisParam).first
                break;
    if( make_from_elset && generate_nset )
        MB_SET_ERR( MB_FAILURE, "Incompatible NSET parameters ELSET & GENERATE" );
    if( make_from_elset )
        status = get_set_nodes( parent_set, ABQ_ELEMENT_SET, elset_name, node_range );
        MB_RETURN_IF_FAIL;
    else
        std::vector< int > node_list;
        Range tmp_node_range;
                if( generate_nset )
                        MB_SET_ERR( MB_FAILURE, "Wrong number of entries on GENERATE node set data line" );
                    int n1   = atoi( tokens[0].c_str() );
                    int n2   = atoi( tokens[1].c_str() );
                    if( ( incr == 0 ) || ( ( ( n2 - n1 ) % incr ) != 0 ) )
                        MB_SET_ERR( MB_FAILURE, "Invalid data on GENERATE node set data line" );
                    for( int node_id = n1; node_id <= n2; node_id += incr )
                        node_list.push_back( node_id );
                else
                            tmp_node_range.clear();
                            status = get_set_nodes( parent_set, ABQ_NODE_SET, tokens[idx], tmp_node_range );
                            MB_RETURN_IF_FAIL;
                            node_range.merge( tmp_node_range );
                        else
                            node_list.push_back( atoi( tokens[idx].c_str() ) );
        status = get_nodes_by_id( node_container_set, node_list, tmp_node_range );
        MB_RETURN_IF_FAIL;
    status = add_entity_set( parent_set, ABQ_NODE_SET, nset_name, node_set );
    MB_RETURN_IF_FAIL;
    MB_RETURN_IF_FAIL;
    if( file_set )
        status = mdbImpl->add_entities( file_set, &node_set, 1 );
        MB_RETURN_IF_FAIL;
    if( assembly_set )
        status = mdbImpl->add_entities( assembly_set, &node_set, 1 );
        MB_RETURN_IF_FAIL;
        status = mdbImpl->tag_set_data( mAssemblyHandleTag, &node_set, 1, &assembly_set );
        MB_RETURN_IF_FAIL;
    return MB_SUCCESS;
Definition at line 539 of file ReadABAQUS.cpp.
References ABQ_AMBIGUOUS, moab::abq_blank_line, moab::abq_comment_line, moab::abq_data_line, moab::abq_element, moab::abq_elset, moab::abq_end_part, moab::abq_eof, moab::abq_keyword_line, moab::abq_node, moab::abq_nset, moab::abq_part_ambiguous, moab::abq_part_name, ABQ_PART_SET, moab::abq_solid_section, add_entity_set(), ErrorCode, extract_keyword_parameters(), get_keyword(), get_next_line_type(), match(), MB_RETURN_IF_FAIL, MB_SET_ERR, MB_SUCCESS, next_line_type, num_part_instances, read_element_list(), read_element_set(), read_node_list(), read_node_set(), read_solid_section(), readline, and tokenize().
    std::map< std::string, abaqus_part_params > requiredParams;
    requiredParams["NAME"] = abq_part_name;
    std::map< std::string, abaqus_part_params > allowableParams;
    allowableParams[ABQ_AMBIGUOUS] = abq_part_ambiguous;
    abaqus_part_params param;
    std::string part_name;
    for( std::map< std::string, abaqus_part_params >::iterator thisParam = requiredParams.begin();
        switch( param )
            case abq_part_name:
                // std::cout << "Adding PART with name: " << part_name << std::endl; // REMOVE
                break;
            default:
                MB_SET_ERR( MB_FAILURE, "Missing required PART parameter" );
         ++thisParam )
        switch( param )
            case abq_part_ambiguous:
                // std::cout << "\tIgnoring ambiguous PART parameter: " << (*thisParam).first
                break;
            default:
                // std::cout << "\tIgnoring unsupported PART parameter: " << (*thisParam).first
                break;
    status = add_entity_set( file_set, ABQ_PART_SET, part_name, part_set );
    bool end_part       = false;
    while( next_line_type != abq_eof && !end_part )
                    case abq_end_part:
                        end_part = true;
                        break;
                    case abq_node:
                        status = read_node_list( part_set );
                        break;
                    case abq_element:
                        status = read_element_list( part_set );
                        break;
                    case abq_nset:
                        status = read_node_set( part_set );
                        break;
                    case abq_elset:
                        status = read_element_set( part_set );
                        break;
                        status = read_solid_section( part_set );
                        break;
                    default:
                        // std::cout << "\tIgnoring unsupported keyword in this PART: "
                        break;
                MB_RETURN_IF_FAIL;
                break;
                break;
            case abq_data_line:
                    MB_SET_ERR( MB_FAILURE, "Data lines not allowed in PART keyword" );
                break;
                MB_SET_ERR( MB_FAILURE, "Blank lines are not allowed" );
            default:
                MB_SET_ERR( MB_FAILURE, "Error reading PART" );
    num_part_instances[part_set] = 0;
    return MB_SUCCESS;
Definition at line 662 of file ReadABAQUS.cpp.
References ABQ_AMBIGUOUS, ABQ_ELEMENT_SET, moab::abq_eof, moab::abq_keyword_line, moab::abq_solid_section_ambiguous, moab::abq_solid_section_elset, moab::abq_solid_section_matname, ErrorCode, extract_keyword_parameters(), get_next_line_type(), get_set_by_name(), mat_id, match(), matIDmap, MB_RETURN_IF_FAIL, MB_SET_ERR, MB_SUCCESS, mdbImpl, mMaterialSetTag, mMatNameTag, next_line_type, readline, moab::Interface::tag_set_data(), and tokenize().
    ErrorCode status;
    std::map< std::string, abaqus_solid_section_params > requiredParams;
    requiredParams["ELSET"]    = abq_solid_section_elset;
    requiredParams["MATERIAL"] = abq_solid_section_matname;
    std::map< std::string, abaqus_solid_section_params > allowableParams;
    allowableParams[ABQ_AMBIGUOUS] = abq_solid_section_ambiguous;
    abaqus_solid_section_params param;
    std::string elset_name, mat_name;
    for( std::map< std::string, abaqus_solid_section_params >::iterator thisParam = requiredParams.begin();
        switch( param )
            case abq_solid_section_elset:
                break;
            case abq_solid_section_matname:
                mat_name = params[param_key];
                break;
            default:
                MB_SET_ERR( MB_FAILURE, "Missing required SOLID SECTION parameter" );
    // std::cout << "\tAdding SOLID SECTION with to ELEMENT SET: " << elset_name << " with material:
    // " << mat_name << std::endl; // REMOVE
         ++thisParam )
        switch( param )
            case abq_solid_section_ambiguous:
                // std::cout << "\t\tIgnoring ambiguous SOLID_SECTION parameter: " <<
                break;
            default:
                // std::cout << "\t\tIgnoring unsupported SOLID_SECTION parameter: " <<
                break;
    status = get_set_by_name( parent_set, ABQ_ELEMENT_SET, elset_name, set_handle );
    MB_RETURN_IF_FAIL;
    status = mdbImpl->tag_set_data( mMatNameTag, &set_handle, 1, mat_name.c_str() );
    MB_RETURN_IF_FAIL;
    if( 0 == matIDmap[mat_name] ) matIDmap[mat_name] = ++mat_id;
    status = mdbImpl->tag_set_data( mMaterialSetTag, &set_handle, 1, &( matIDmap[mat_name] ) );
    MB_RETURN_IF_FAIL;
    return MB_SUCCESS;
ErrorCode moab::ReadABAQUS::read_tag_values ( const char *  file_name,
std::vector< int > &  tag_values_out,
) [virtual]
Read tag values from a file.
Read the list if all integer tag values from the file for a tag that is a single integer value per entity.
Parameters:
file_nameThe file to read.
tag_nameThe tag for which to read values
tag_values_outOutput: The list of tag values.
subset_listAn array of tag name and value sets specifying the subset of the file to read. If multiple tags are specified, the sets that match all tags (intersection) should be read.
subset_list_lengthThe length of the 'subset_list' array.
Definition at line 111 of file ReadABAQUS.cpp.
References MB_NOT_IMPLEMENTED.
    return MB_NOT_IMPLEMENTED;
void moab::ReadABAQUS::reset ( ) [private]
Definition at line 95 of file ReadABAQUS.cpp.
void moab::ReadABAQUS::sph2rect ( std::vector< double >  coord_list) [private]
Definition at line 1966 of file ReadABAQUS.cpp.
    double x, y, z, r, t, p;
        p = coord_list[3 * node + 2] * DEG2RAD;
        x = r * cos( p ) * cos( t );
        y = r * cos( p ) * sin( t );
        z = r * sin( p );
        coord_list[3 * node + 2] = z;
void moab::ReadABAQUS::stringToUpper ( const std::string &  toBeConverted,
std::string &  converted
) [private]
Definition at line 2088 of file ReadABAQUS.cpp.
Referenced by extract_keyword_parameters(), and get_keyword().
    converted = toBeConverted;
    for( unsigned int i = 0; i < toBeConverted.length(); i++ )
        converted[i] = toupper( toBeConverted[i] );
void moab::ReadABAQUS::tokenize ( const std::string &  str,
const char *  delimiters
Definition at line 2118 of file ReadABAQUS.cpp.
    tokens.clear();
    std::string::size_type pos, last = str.find_first_not_of( delimiters, 0 );
    while( std::string::npos != last )
        pos = str.find_first_of( delimiters, last );
            tokens.push_back( str.substr( last ) );
            last = std::string::npos;
        else
            tokens.push_back( str.substr( last, pos - last ) );
            last = str.find_first_not_of( delimiters, pos );
Member Data Documentation
std::ifstream moab::ReadABAQUS::abFile [private]
Definition at line 452 of file ReadABAQUS.hpp.
Referenced by get_next_line_type(), load_file(), and ~ReadABAQUS().
unsigned moab::ReadABAQUS::lineNo [private]
Definition at line 456 of file ReadABAQUS.hpp.
Referenced by get_next_line_type(), and load_file().
unsigned moab::ReadABAQUS::mat_id [private]
Definition at line 482 of file ReadABAQUS.hpp.
Referenced by read_solid_section().
std::map< std::string, unsigned int > moab::ReadABAQUS::matIDmap [private]
Definition at line 481 of file ReadABAQUS.hpp.
Definition at line 461 of file ReadABAQUS.hpp.
Definition at line 463 of file ReadABAQUS.hpp.
Definition at line 468 of file ReadABAQUS.hpp.
Referenced by create_instance_of_part(), and ReadABAQUS().
Definition at line 471 of file ReadABAQUS.hpp.
Definition at line 467 of file ReadABAQUS.hpp.
Cached tags for reading. Note that all these tags are defined when the core is initialized.
Definition at line 460 of file ReadABAQUS.hpp.
Referenced by create_instance_of_part(), read_solid_section(), and ReadABAQUS().
Definition at line 462 of file ReadABAQUS.hpp.
Definition at line 466 of file ReadABAQUS.hpp.
std::map< EntityHandle, unsigned int > moab::ReadABAQUS::num_assembly_instances [private]
Definition at line 480 of file ReadABAQUS.hpp.
Referenced by create_instance_of_part(), and read_assembly().
std::map< EntityHandle, unsigned int > moab::ReadABAQUS::num_part_instances [private]
Definition at line 479 of file ReadABAQUS.hpp.
Referenced by create_instance_of_part(), and read_part().
List of all members.
