moab::NCHelperHOMME Class Reference
Child helper class for HOMME grid (CAM_SE) More...
#include <NCHelperHOMME.hpp>
+ Inheritance diagram for moab::NCHelperHOMME:
+ Collaboration diagram for moab::NCHelperHOMME:
Public Member Functions
 NCHelperHOMME (ReadNC *readNC, int fileId, const FileOptions &opts, EntityHandle fileSet)
Static Public Member Functions
static bool can_read_file (ReadNC *readNC, int fileId)
Private Member Functions
virtual ErrorCode init_mesh_vals ()
 Implementation of NCHelper::init_mesh_vals()
virtual ErrorCode check_existing_mesh ()
 Implementation of NCHelper::check_existing_mesh()
virtual ErrorCode create_mesh (Range &faces)
 Implementation of NCHelper::create_mesh()
virtual std::string get_mesh_type_name ()
 Implementation of NCHelper::get_mesh_type_name()
virtual ErrorCode read_ucd_variables_to_nonset_allocate (std::vector< ReadNC::VarData > &vdatas, std::vector< int > &tstep_nums)
 Implementation of UcdNCHelper::read_ucd_variables_to_nonset_allocate()
virtual ErrorCode read_ucd_variables_to_nonset (std::vector< ReadNC::VarData > &vdatas, std::vector< int > &tstep_nums)
 Implementation of UcdNCHelper::read_ucd_variables_to_nonset()
Private Attributes
int _spectralOrder
int connectId
bool isConnFile
Detailed Description
Definition at line 18 of file NCHelperHOMME.hpp.
moab::NCHelperHOMME::NCHelperHOMME ( ReadNC *  readNC,
int  fileId,
const FileOptions &  opts,
Definition at line 11 of file NCHelperHOMME.cpp.
References _spectralOrder, moab::ReadNC::fileId, moab::ReadNC::globalAtts, isConnFile, and NCFUNC.
    : UcdNCHelper( readNC, fileId, opts, fileSet ), _spectralOrder( -1 ), connectId( -1 ), isConnFile( false )
    // Calculate spectral order
    std::map< std::string, ReadNC::AttData >::iterator attIt = readNC->globalAtts.find( "np" );
    if( attIt != readNC->globalAtts.end() )
        int success = NCFUNC( get_att_int )( readNC->fileId, attIt->second.attVarId, attIt->second.attName.c_str(),
                                             &_spectralOrder );
        if( 0 == success ) _spectralOrder--;  // Spectral order is one less than np
    else
        // As can_read_file() returns true and there is no global attribute "np", it should be a
        // connectivity file
        isConnFile     = true;
        _spectralOrder = 3;  // Assume np is 4
Member Function Documentation
bool moab::NCHelperHOMME::can_read_file ( ReadNC *  readNC,
int  fileId
) [static]
Definition at line 31 of file NCHelperHOMME.cpp.
References moab::ReadNC::dimNames, moab::ReadNC::globalAtts, and NCFUNC.
Referenced by moab::NCHelper::get_nc_helper().
    // If global attribute "np" exists then it should be the HOMME grid
    if( readNC->globalAtts.find( "np" ) != readNC->globalAtts.end() )
        // Make sure it is CAM grid
        std::map< std::string, ReadNC::AttData >::iterator attIt = readNC->globalAtts.find( "source" );
        if( attIt == readNC->globalAtts.end() ) return false;
        unsigned int sz = attIt->second.attLen;
        std::string att_data;
        att_data.resize( sz + 1 );
        att_data[sz] = '\000';
        int success =
            NCFUNC( get_att_text )( fileId, attIt->second.attVarId, attIt->second.attName.c_str(), &att_data[0] );
        if( success ) return false;
        if( att_data.find( "CAM" ) == std::string::npos ) return false;
        return true;
    else
        // If dimension names "ncol" AND "ncorners" AND "ncells" exist, then it should be the HOMME
        // connectivity file In this case, the mesh can still be created
        std::vector< std::string >& dimNames = readNC->dimNames;
        if( ( std::find( dimNames.begin(), dimNames.end(), std::string( "ncol" ) ) != dimNames.end() ) &&
            ( std::find( dimNames.begin(), dimNames.end(), std::string( "ncorners" ) ) != dimNames.end() ) &&
            ( std::find( dimNames.begin(), dimNames.end(), std::string( "ncells" ) ) != dimNames.end() ) )
            return true;
    return false;
Implements moab::NCHelper.
Definition at line 223 of file NCHelperHOMME.cpp.
References moab::NCHelper::_fileSet, moab::NCHelper::_readNC, moab::Range::empty(), ErrorCode, moab::Interface::get_entities_by_dimension(), moab::UcdNCHelper::localGidVerts, MB_CHK_SET_ERR, MB_SUCCESS, moab::ReadNC::mbImpl, moab::ReadNC::mGlobalIdTag, moab::UcdNCHelper::nLocalVertices, moab::ReadNC::noMesh, moab::Range::size(), and moab::Interface::tag_get_data().
    Interface*& mbImpl = _readNC->mbImpl;
    Tag& mGlobalIdTag  = _readNC->mGlobalIdTag;
    bool& noMesh       = _readNC->noMesh;
    if( noMesh && localGidVerts.empty() )
        // We need to populate localGidVerts range with the gids of vertices from current file set
        // localGidVerts is important in reading the variable data into the nodes
        // Also, for our purposes, localGidVerts is truly the GLOBAL_ID tag data, not other
        // file_id tags that could get passed around in other scenarios for parallel reading
        // Get all vertices from current file set (it is the input set in no_mesh scenario)
        Range local_verts;
        ErrorCode rval = mbImpl->get_entities_by_dimension( _fileSet, 0, local_verts );MB_CHK_SET_ERR( rval, "Trouble getting local vertices in current file set" );
        if( !local_verts.empty() )
            std::vector< int > gids( local_verts.size() );
            // !IMPORTANT : this has to be the GLOBAL_ID tag
            rval = mbImpl->tag_get_data( mGlobalIdTag, local_verts, &gids[0] );MB_CHK_SET_ERR( rval, "Trouble getting local gid values of vertices" );
            // Restore localGidVerts
            std::copy( gids.rbegin(), gids.rend(), range_inserter( localGidVerts ) );
            nLocalVertices = localGidVerts.size();
    return MB_SUCCESS;
ErrorCode moab::NCHelperHOMME::create_mesh ( Range &  faces) [private, virtual]
Definition at line 256 of file NCHelperHOMME.cpp.
References moab::NCHelper::_fileSet, moab::NCHelper::_opts, moab::NCHelper::_readNC, _spectralOrder, moab::Interface::add_entities(), moab::Range::begin(), conn_fname, moab::Interface::connect_iterate(), connectId, moab::ReadUtilIface::create_gather_set(), moab::SpectralMeshTool::create_spectral_elems(), moab::ReadNC::dbgOut, moab::Range::end(), ErrorCode, moab::ReadNC::fileId, moab::ReadNC::fileName, moab::ReadNC::gatherSetRank, moab::ReadNC::get_dimensions(), moab::ReadUtilIface::get_element_connect(), moab::ReadUtilIface::get_node_coords(), moab::FileOptions::get_str_option(), moab::Range::insert(), isConnFile, moab::ReadNC::isParallel, moab::NCHelper::levVals, moab::UcdNCHelper::localGidVerts, MB_CHK_SET_ERR, MB_SET_ERR, MB_SUCCESS, MB_TAG_CREAT, MB_TAG_SPARSE, MB_TYPE_INTEGER, moab::ReadNC::mbImpl, MBQUAD, moab::Range::merge(), moab::ReadNC::mGlobalIdTag, moab::ReadNC::mpFileIdTag, NCDF_SIZE, moab::UcdNCHelper::nCells, NCFUNC, NCFUNCAG, moab::UcdNCHelper::nLocalVertices, moab::UcdNCHelper::nVertices, moab::ProcConfig::proc_comm(), moab::ParallelComm::proc_config(), moab::ProcConfig::proc_rank(), moab::ProcConfig::proc_size(), rank, moab::ReadNC::readMeshIface, moab::Range::size(), moab::SpectralMeshTool::spectral_vertices_tag(), moab::ReadNC::spectralMesh, moab::Interface::tag_get_bytes(), moab::Interface::tag_get_handle(), moab::Interface::tag_iterate(), moab::Interface::tag_set_data(), moab::DebugOutput::tprintf(), moab::ReadNC::trivialPartitionShift, moab::UcdNCHelper::xVertVals, and moab::UcdNCHelper::yVertVals.
    std::string& fileName      = _readNC->fileName;
    const Tag*& mpFileIdTag    = _readNC->mpFileIdTag;
    DebugOutput& dbgOut        = _readNC->dbgOut;
    bool& spectralMesh         = _readNC->spectralMesh;
    int& gatherSetRank         = _readNC->gatherSetRank;
    int& trivialPartitionShift = _readNC->trivialPartitionShift;
    int rank  = 0;
    int procs = 1;
#ifdef MOAB_HAVE_MPI
    bool& isParallel = _readNC->isParallel;
    if( isParallel )
        ParallelComm*& myPcomm = _readNC->myPcomm;
        rank                   = myPcomm->proc_config().proc_rank();
        procs                  = myPcomm->proc_config().proc_size();
#endif
    ErrorCode rval;
    int success = 0;
    // Need to get/read connectivity data before creating elements
    std::string conn_fname;
    if( isConnFile )
        // Connectivity file has already been read
        connectId = _readNC->fileId;
    else
        // Try to open the connectivity file through CONN option, if used
        rval = _opts.get_str_option( "CONN", conn_fname );
        if( MB_SUCCESS != rval )
            // Default convention for reading HOMME is a file HommeMapping.nc in same dir as data
            // file
            conn_fname = std::string( fileName );
            size_t idx = conn_fname.find_last_of( "/" );
            if( idx != std::string::npos )
                conn_fname = conn_fname.substr( 0, idx ).append( "/HommeMapping.nc" );
            else
                conn_fname = "HommeMapping.nc";
#ifdef MOAB_HAVE_PNETCDF
        if( isParallel )
            success =
                NCFUNC( open )( myPcomm->proc_config().proc_comm(), conn_fname.c_str(), 0, MPI_INFO_NULL, &connectId );
        else
            success = NCFUNC( open )( MPI_COMM_SELF, conn_fname.c_str(), 0, MPI_INFO_NULL, &connectId );
#endif
#else
        success = NCFUNC( open )( conn_fname.c_str(), 0, &connectId );
#endif
        if( success ) MB_SET_ERR( MB_FAILURE, "Failed on open" );
    std::vector< std::string > conn_names;
    std::vector< int > conn_vals;
    rval = _readNC->get_dimensions( connectId, conn_names, conn_vals );MB_CHK_SET_ERR( rval, "Failed to get dimensions for connectivity" );
    // Read connectivity into temporary variable
    int num_fine_quads   = 0;
    int num_coarse_quads = 0;
    int start_idx        = 0;
    std::vector< std::string >::iterator vit;
    int idx = 0;
    if( ( vit = std::find( conn_names.begin(), conn_names.end(), "ncells" ) ) != conn_names.end() )
        idx = vit - conn_names.begin();
    else if( ( vit = std::find( conn_names.begin(), conn_names.end(), "ncenters" ) ) != conn_names.end() )
    else
        MB_SET_ERR( MB_FAILURE, "Failed to get number of quads" );
    int num_quads = conn_vals[idx];
    if( !isConnFile && num_quads != nCells )
        dbgOut.tprintf( 1,
                        "Warning: number of quads from %s and cells from %s are inconsistent; "
                        "num_quads = %d, nCells = %d.\n",
                        conn_fname.c_str(), fileName.c_str(), num_quads, nCells );
    // Get the connectivity into tmp_conn2 and permute into tmp_conn
    int cornerVarId;
    success = NCFUNC( inq_varid )( connectId, "element_corners", &cornerVarId );
    if( success ) MB_SET_ERR( MB_FAILURE, "Failed to get variable id of 'element_corners'" );
    NCDF_SIZE tmp_starts[2] = { 0, 0 };
    NCDF_SIZE tmp_counts[2] = { 4, static_cast< NCDF_SIZE >( num_quads ) };
    std::vector< int > tmp_conn( 4 * num_quads ), tmp_conn2( 4 * num_quads );
    success = NCFUNCAG( _vara_int )( connectId, cornerVarId, tmp_starts, tmp_counts, &tmp_conn2[0] );
    if( success ) MB_SET_ERR( MB_FAILURE, "Failed to get temporary connectivity" );
    if( isConnFile )
        // This data/connectivity file will be closed later in ReadNC::load_file()
    else
        success = NCFUNC( close )( connectId );
        if( success ) MB_SET_ERR( MB_FAILURE, "Failed on close" );
    // Permute the connectivity
    for( int i = 0; i < num_quads; i++ )
        tmp_conn[4 * i]     = tmp_conn2[i];
        tmp_conn[4 * i + 1] = tmp_conn2[i + 1 * num_quads];
        tmp_conn[4 * i + 2] = tmp_conn2[i + 2 * num_quads];
        tmp_conn[4 * i + 3] = tmp_conn2[i + 3 * num_quads];
    // Need to know whether we'll be creating gather mesh later, to make sure
    // we allocate enough space in one shot
    bool create_gathers = false;
    if( rank == gatherSetRank ) create_gathers = true;
    // Shift rank to obtain a rotated trivial partition
    int shifted_rank = rank;
    if( procs >= 2 && trivialPartitionShift > 0 ) shifted_rank = ( rank + trivialPartitionShift ) % procs;
    // Compute the number of local quads, accounting for coarse or fine representation
    // spectral_unit is the # fine quads per coarse quad, or spectralOrder^2
    int spectral_unit = ( spectralMesh ? _spectralOrder * _spectralOrder : 1 );
    // num_coarse_quads is the number of quads instantiated in MOAB; if !spectralMesh,
    // num_coarse_quads = num_fine_quads
    num_coarse_quads = int( std::floor( 1.0 * num_quads / ( spectral_unit * procs ) ) );
    // start_idx is the starting index in the HommeMapping connectivity list for this proc, before
    // converting to coarse quad representation
    start_idx = 4 * shifted_rank * num_coarse_quads * spectral_unit;
    // iextra = # coarse quads extra after equal split over procs
    int iextra = num_quads % ( procs * spectral_unit );
    if( shifted_rank < iextra ) num_coarse_quads++;
    start_idx += 4 * spectral_unit * std::min( shifted_rank, iextra );
    // num_fine_quads is the number of quads in the connectivity list in HommeMapping file assigned
    // to this proc
    num_fine_quads = spectral_unit * num_coarse_quads;
    // Now create num_coarse_quads
    EntityHandle* conn_arr;
    EntityHandle start_vertex;
    Range tmp_range;
    // Read connectivity into that space
    EntityHandle* sv_ptr = NULL;
    EntityHandle start_quad;
    SpectralMeshTool smt( mbImpl, _spectralOrder );
    if( !spectralMesh )
        rval = _readNC->readMeshIface->get_element_connect( num_coarse_quads, 4, MBQUAD, 0, start_quad, conn_arr,
                                                            // Might have to create gather mesh later
                                                            ( create_gathers ? num_coarse_quads + num_quads
        : num_coarse_quads ) );MB_CHK_SET_ERR( rval, "Failed to create local quads" );
        tmp_range.insert( start_quad, start_quad + num_coarse_quads - 1 );
        int* tmp_conn_end = ( &tmp_conn[start_idx + 4 * num_fine_quads - 1] ) + 1;
        std::copy( &tmp_conn[start_idx], tmp_conn_end, conn_arr );
        std::copy( conn_arr, conn_arr + 4 * num_fine_quads, range_inserter( localGidVerts ) );
    else
        rval = smt.create_spectral_elems( &tmp_conn[0], num_fine_quads, 2, tmp_range, start_idx, &localGidVerts );MB_CHK_SET_ERR( rval, "Failed to create spectral elements" );
        int count, v_per_e;
        rval = mbImpl->connect_iterate( tmp_range.begin(), tmp_range.end(), conn_arr, v_per_e, count );MB_CHK_SET_ERR( rval, "Failed to get connectivity of spectral elements" );
        rval = mbImpl->tag_iterate( smt.spectral_vertices_tag( true ), tmp_range.begin(), tmp_range.end(), count,
                                    (void*&)sv_ptr );MB_CHK_SET_ERR( rval, "Failed to get fine connectivity of spectral elements" );
    // Create vertices
    std::vector< double* > arrays;
    rval = _readNC->readMeshIface->get_node_coords( 3, nLocalVertices, 0, start_vertex, arrays,
                                                    ( create_gathers ? nLocalVertices + nVertices : nLocalVertices ) );MB_CHK_SET_ERR( rval, "Failed to create local vertices" );
    // Set vertex coordinates
    Range::iterator rit;
    double* xptr = arrays[0];
    double* yptr = arrays[1];
    double* zptr = arrays[2];
    int i;
    for( i = 0, rit = localGidVerts.begin(); i < nLocalVertices; i++, ++rit )
        assert( *rit < xVertVals.size() + 1 );
        xptr[i] = xVertVals[( *rit ) - 1];  // lon
        yptr[i] = yVertVals[( *rit ) - 1];  // lat
    // Convert lon/lat/rad to x/y/z
    const double pideg = acos( -1.0 ) / 180.0;
    double rad         = ( isConnFile ) ? 8000.0 : 8000.0 + levVals[0];
    for( i = 0; i < nLocalVertices; i++ )
        double cosphi = cos( pideg * yptr[i] );
        double zmult  = sin( pideg * yptr[i] );
        double xmult  = cosphi * cos( xptr[i] * pideg );
        double ymult  = cosphi * sin( xptr[i] * pideg );
        xptr[i]       = rad * xmult;
        yptr[i]       = rad * ymult;
        zptr[i]       = rad * zmult;
    // Get ptr to gid memory for vertices
    Range vert_range( start_vertex, start_vertex + nLocalVertices - 1 );
    void* data;
    int count;
    rval = mbImpl->tag_iterate( mGlobalIdTag, vert_range.begin(), vert_range.end(), count, data );MB_CHK_SET_ERR( rval, "Failed to iterate global id tag on local vertices" );
    assert( count == nLocalVertices );
    int* gid_data = (int*)data;
    std::copy( localGidVerts.begin(), localGidVerts.end(), gid_data );
    // Duplicate global id data, which will be used to resolve sharing
    if( mpFileIdTag )
        rval = mbImpl->tag_iterate( *mpFileIdTag, vert_range.begin(), vert_range.end(), count, data );MB_CHK_SET_ERR( rval, "Failed to iterate file id tag on local vertices" );
        int bytes_per_tag = 4;
        rval              = mbImpl->tag_get_bytes( *mpFileIdTag, bytes_per_tag );MB_CHK_SET_ERR( rval, "Can't get number of bytes for file id tag" );
        if( 4 == bytes_per_tag )
        else if( 8 == bytes_per_tag )
        {  // Should be a handle tag on 64 bit machine?
            long* handle_tag_data = (long*)data;
            std::copy( localGidVerts.begin(), localGidVerts.end(), handle_tag_data );
    // Create map from file ids to vertex handles, used later to set connectivity
    std::map< EntityHandle, EntityHandle > vert_handles;
    for( rit = localGidVerts.begin(), i = 0; rit != localGidVerts.end(); ++rit, i++ )
        vert_handles[*rit] = start_vertex + i;
    // Compute proper handles in connectivity using offset
    for( int q = 0; q < 4 * num_coarse_quads; q++ )
        conn_arr[q] = vert_handles[conn_arr[q]];
        assert( conn_arr[q] );
    if( spectralMesh )
        int verts_per_quad = ( _spectralOrder + 1 ) * ( _spectralOrder + 1 );
        for( int q = 0; q < verts_per_quad * num_coarse_quads; q++ )
            sv_ptr[q] = vert_handles[sv_ptr[q]];
            assert( sv_ptr[q] );
    // Add new vertices and quads to current file set
    faces.merge( tmp_range );
    tmp_range.insert( start_vertex, start_vertex + nLocalVertices - 1 );
    rval = mbImpl->add_entities( _fileSet, tmp_range );MB_CHK_SET_ERR( rval, "Failed to add new vertices and quads to current file set" );
    // Mark the set with the spectral order
    Tag sporder;
    rval = mbImpl->tag_get_handle( "SPECTRAL_ORDER", 1, MB_TYPE_INTEGER, sporder, MB_TAG_SPARSE | MB_TAG_CREAT );MB_CHK_SET_ERR( rval, "Trouble creating SPECTRAL_ORDER tag" );
    rval = mbImpl->tag_set_data( sporder, &_fileSet, 1, &_spectralOrder );MB_CHK_SET_ERR( rval, "Trouble setting data to SPECTRAL_ORDER tag" );
    if( create_gathers )
        EntityHandle gather_set;
        rval = _readNC->readMeshIface->create_gather_set( gather_set );MB_CHK_SET_ERR( rval, "Failed to create gather set" );
        // Create vertices
        arrays.clear();
        // Don't need to specify allocation number here, because we know enough verts were created
        // before
        rval = _readNC->readMeshIface->get_node_coords( 3, nVertices, 0, start_vertex, arrays );MB_CHK_SET_ERR( rval, "Failed to create gather set vertices" );
        xptr = arrays[0];
        yptr = arrays[1];
        zptr = arrays[2];
        for( i = 0; i < nVertices; i++ )
            double cosphi = cos( pideg * yVertVals[i] );
            double zmult  = sin( pideg * yVertVals[i] );
            double xmult  = cosphi * cos( xVertVals[i] * pideg );
            double ymult  = cosphi * sin( xVertVals[i] * pideg );
        Range gather_set_verts_range( start_vertex, start_vertex + nVertices - 1 );
        rval = mbImpl->tag_iterate( mGlobalIdTag, gather_set_verts_range.begin(), gather_set_verts_range.end(), count,
                                    data );MB_CHK_SET_ERR( rval, "Failed to iterate global id tag on gather set vertices" );
        assert( count == nVertices );
        for( int j = 1; j <= nVertices; j++ )
            gid_data[j - 1] = j;
        // Set the file id tag too, it should be bigger something not interfering with global id
        if( mpFileIdTag )
            rval = mbImpl->tag_iterate( *mpFileIdTag, gather_set_verts_range.begin(), gather_set_verts_range.end(),
                                        count, data );MB_CHK_SET_ERR( rval, "Failed to iterate file id tag on gather set vertices" );
                    gid_data[j - 1] = nVertices + j;  // Bigger than global id tag
                    handle_tag_data[j - 1] = nVertices + j;  // Bigger than global id tag
        rval = mbImpl->add_entities( gather_set, gather_set_verts_range );MB_CHK_SET_ERR( rval, "Failed to add vertices to the gather set" );
        // Create quads
        Range gather_set_quads_range;
        // Don't need to specify allocation number here, because we know enough quads were created
        // before
        rval = _readNC->readMeshIface->get_element_connect( num_quads, 4, MBQUAD, 0, start_quad, conn_arr );MB_CHK_SET_ERR( rval, "Failed to create gather set quads" );
        gather_set_quads_range.insert( start_quad, start_quad + num_quads - 1 );
        int* tmp_conn_end = ( &tmp_conn[4 * num_quads - 1] ) + 1;
        std::copy( &tmp_conn[0], tmp_conn_end, conn_arr );
        for( i = 0; i != 4 * num_quads; i++ )
            conn_arr[i] += start_vertex - 1;  // Connectivity array is shifted by where the gather verts start
        rval = mbImpl->add_entities( gather_set, gather_set_quads_range );MB_CHK_SET_ERR( rval, "Failed to add quads to the gather set" );
    return MB_SUCCESS;
virtual std::string moab::NCHelperHOMME::get_mesh_type_name ( ) [inline, private, virtual]
Definition at line 32 of file NCHelperHOMME.hpp.
        return "CAM_SE";
Definition at line 64 of file NCHelperHOMME.cpp.
References moab::NCHelper::_fileId, moab::NCHelper::_readNC, moab::NCHelper::create_dummy_variables(), moab::ReadNC::dimLens, moab::ReadNC::dimNames, moab::ReadNC::VarData::entLoc, moab::ReadNC::ENTLOCVERT, ErrorCode, isConnFile, moab::NCHelper::levDim, moab::NCHelper::levVals, MB_CHK_SET_ERR, MB_SET_ERR, MB_SUCCESS, moab::UcdNCHelper::nCells, NCFUNC, moab::NCHelper::nLevels, moab::NCHelper::nTimeSteps, moab::ReadNC::VarData::numLev, moab::UcdNCHelper::nVertices, moab::NCHelper::read_coordinate(), t, moab::NCHelper::tDim, moab::NCHelper::tVals, moab::ReadNC::VarData::varDims, moab::ReadNC::varInfo, moab::UcdNCHelper::vDim, moab::UcdNCHelper::xVertVals, and moab::UcdNCHelper::yVertVals.
    std::vector< std::string >& dimNames              = _readNC->dimNames;
    std::vector< int >& dimLens                       = _readNC->dimLens;
    std::map< std::string, ReadNC::VarData >& varInfo = _readNC->varInfo;
    ErrorCode rval;
    unsigned int idx;
    // Look for time dimension
    if( isConnFile )
        // Connectivity file might not have time dimension
    else
        if( ( vit = std::find( dimNames.begin(), dimNames.end(), "time" ) ) != dimNames.end() )
            idx = vit - dimNames.begin();
        else if( ( vit = std::find( dimNames.begin(), dimNames.end(), "t" ) ) != dimNames.end() )
        else
            MB_SET_ERR( MB_FAILURE, "Couldn't find 'time' or 't' dimension" );
        tDim       = idx;
        nTimeSteps = dimLens[idx];
    // Get number of vertices (labeled as number of columns)
    if( ( vit = std::find( dimNames.begin(), dimNames.end(), "ncol" ) ) != dimNames.end() )
    else
        MB_SET_ERR( MB_FAILURE, "Couldn't find 'ncol' dimension" );
    vDim      = idx;
    nVertices = dimLens[idx];
    // Set number of cells
    nCells = nVertices - 2;
    // Get number of levels
    if( isConnFile )
        // Connectivity file might not have level dimension
    else
        if( ( vit = std::find( dimNames.begin(), dimNames.end(), "lev" ) ) != dimNames.end() )
        else if( ( vit = std::find( dimNames.begin(), dimNames.end(), "ilev" ) ) != dimNames.end() )
        else
            MB_SET_ERR( MB_FAILURE, "Couldn't find 'lev' or 'ilev' dimension" );
        levDim  = idx;
        nLevels = dimLens[idx];
    // Store lon values in xVertVals
    std::map< std::string, ReadNC::VarData >::iterator vmit;
    if( ( vmit = varInfo.find( "lon" ) ) != varInfo.end() && ( *vmit ).second.varDims.size() == 1 )
        rval = read_coordinate( "lon", 0, nVertices - 1, xVertVals );MB_CHK_SET_ERR( rval, "Trouble reading 'lon' variable" );
    else
        MB_SET_ERR( MB_FAILURE, "Couldn't find 'lon' variable" );
    // Store lat values in yVertVals
    if( ( vmit = varInfo.find( "lat" ) ) != varInfo.end() && ( *vmit ).second.varDims.size() == 1 )
        rval = read_coordinate( "lat", 0, nVertices - 1, yVertVals );MB_CHK_SET_ERR( rval, "Trouble reading 'lat' variable" );
    else
        MB_SET_ERR( MB_FAILURE, "Couldn't find 'lat' variable" );
    // Store lev values in levVals
    if( isConnFile )
        // Connectivity file might not have level variable
    else
        if( ( vmit = varInfo.find( "lev" ) ) != varInfo.end() && ( *vmit ).second.varDims.size() == 1 )
            rval = read_coordinate( "lev", 0, nLevels - 1, levVals );MB_CHK_SET_ERR( rval, "Trouble reading 'lev' variable" );
            // Decide whether down is positive
            char posval[10] = { 0 };
            int success     = NCFUNC( get_att_text )( _fileId, ( *vmit ).second.varId, "positive", posval );
            if( 0 == success && !strcmp( posval, "down" ) )
                for( std::vector< double >::iterator dvit = levVals.begin(); dvit != levVals.end(); ++dvit )
                    ( *dvit ) *= -1.0;
        else
            MB_SET_ERR( MB_FAILURE, "Couldn't find 'lev' variable" );
    // Store time coordinate values in tVals
    if( isConnFile )
        // Connectivity file might not have time variable
    else
        if( ( vmit = varInfo.find( "time" ) ) != varInfo.end() && ( *vmit ).second.varDims.size() == 1 )
            rval = read_coordinate( "time", 0, nTimeSteps - 1, tVals );MB_CHK_SET_ERR( rval, "Trouble reading 'time' variable" );
        else if( ( vmit = varInfo.find( "t" ) ) != varInfo.end() && ( *vmit ).second.varDims.size() == 1 )
            rval = read_coordinate( "t", 0, nTimeSteps - 1, tVals );MB_CHK_SET_ERR( rval, "Trouble reading 't' variable" );
        else
            // If expected time variable does not exist, set dummy values to tVals
            for( int t = 0; t < nTimeSteps; t++ )
                tVals.push_back( (double)t );
    // For each variable, determine the entity location type and number of levels
    std::map< std::string, ReadNC::VarData >::iterator mit;
    for( mit = varInfo.begin(); mit != varInfo.end(); ++mit )
        ReadNC::VarData& vd = ( *mit ).second;
        // Default entLoc is ENTLOCSET
        if( std::find( vd.varDims.begin(), vd.varDims.end(), tDim ) != vd.varDims.end() )
            if( std::find( vd.varDims.begin(), vd.varDims.end(), vDim ) != vd.varDims.end() )
                vd.entLoc = ReadNC::ENTLOCVERT;
        // Default numLev is 0
        if( std::find( vd.varDims.begin(), vd.varDims.end(), levDim ) != vd.varDims.end() ) vd.numLev = nLevels;
    // Hack: create dummy variables for dimensions (like ncol) with no corresponding coordinate
    // variables
    rval = create_dummy_variables();MB_CHK_SET_ERR( rval, "Failed to create dummy variables" );
    return MB_SUCCESS;
ErrorCode moab::NCHelperHOMME::read_ucd_variables_to_nonset ( std::vector< ReadNC::VarData > &  vdatas,
std::vector< int > &  tstep_nums
Implements moab::UcdNCHelper.
Definition at line 782 of file NCHelperHOMME.cpp.
References moab::NCHelper::_fileId, moab::NCHelper::_readNC, moab::ReadNC::dbgOut, ErrorCode, moab::DebugOutput::get_verbosity(), moab::UcdNCHelper::kji_to_jik_stride(), moab::UcdNCHelper::localGidVerts, MB_CHK_SET_ERR, MB_SET_ERR, NCDF_SIZE, NCFUNCAG, moab::Range::pair_begin(), moab::Range::pair_end(), moab::DebugOutput::printf(), moab::Range::psize(), read_ucd_variables_to_nonset_allocate(), t, and moab::DebugOutput::tprintf().
    ErrorCode rval = read_ucd_variables_to_nonset_allocate( vdatas, tstep_nums );MB_CHK_SET_ERR( rval, "Trouble allocating space to read non-set variables" );
    // Finally, read into that space
    int success;
    for( unsigned int i = 0; i < vdatas.size(); i++ )
        std::size_t sz = vdatas[i].sz;
        // A typical supported variable: float T(time, lev, ncol)
        // For tag values, need transpose (lev, ncol) to (ncol, lev)
        size_t ni = vdatas[i].readCounts[2];  // ncol
        size_t nj = 1;                        // Here we should just set nj to 1
        size_t nk = vdatas[i].readCounts[1];  // lev
        for( unsigned int t = 0; t < tstep_nums.size(); t++ )
            // Tag data for this timestep
            void* data = vdatas[i].varDatas[t];
            // Set readStart for each timestep along time dimension
            vdatas[i].readStarts[0] = tstep_nums[t];
            switch( vdatas[i].varDataType )
                case NC_FLOAT:
                case NC_DOUBLE: {
                    // Read float as double
                    std::vector< double > tmpdoubledata( sz );
                    // In the case of ucd mesh, and on multiple proc,
                    // we need to read as many times as subranges we have in the
                    // localGidVerts range;
                    // basically, we have to give a different point
                    // for data to start, for every subrange :(
                    size_t indexInDoubleArray = 0;
                    size_t ic = 0;
                    for( Range::pair_iterator pair_iter = localGidVerts.pair_begin();
                         pair_iter != localGidVerts.pair_end(); ++pair_iter, ic++ )
                        EntityHandle starth = pair_iter->first;
                        EntityHandle endh = pair_iter->second;  // Inclusive
                        vdatas[i].readStarts[2] = (NCDF_SIZE)( starth - 1 );
                        vdatas[i].readCounts[2] = (NCDF_SIZE)( endh - starth + 1 );
                        success = NCFUNCAG( _vara_double )( _fileId, vdatas[i].varId, &( vdatas[i].readStarts[0] ),
                                                            &( vdatas[i].readCounts[0] ),
                                                            &( tmpdoubledata[indexInDoubleArray] ) );
                        if( success )
                                        "Failed to read double data in a loop for variable " << vdatas[i].varName );
                        // We need to increment the index in double array for the
                        // next subrange
                        indexInDoubleArray += ( endh - starth + 1 ) * 1 * vdatas[i].numLev;
                    assert( ic == localGidVerts.psize() );
                    if( vdatas[i].numLev > 1 )
                        // Transpose (lev, ncol) to (ncol, lev)
                        kji_to_jik_stride( ni, nj, nk, data, &tmpdoubledata[0], localGidVerts );
                    else
                        for( std::size_t idx = 0; idx != tmpdoubledata.size(); idx++ )
                            ( (double*)data )[idx] = tmpdoubledata[idx];
                    break;
                default:
                    MB_SET_ERR( MB_FAILURE, "Unexpected data type for variable " << vdatas[i].varName );
    // Debug output, if requested
    if( 1 == dbgOut.get_verbosity() )
        dbgOut.printf( 1, "Read variables: %s", vdatas.begin()->varName.c_str() );
        for( unsigned int i = 1; i < vdatas.size(); i++ )
            dbgOut.printf( 1, ", %s ", vdatas[i].varName.c_str() );
        dbgOut.tprintf( 1, "\n" );
    return rval;
ErrorCode moab::NCHelperHOMME::read_ucd_variables_to_nonset_allocate ( std::vector< ReadNC::VarData > &  vdatas,
Definition at line 597 of file NCHelperHOMME.cpp.
References moab::NCHelper::_fileSet, moab::NCHelper::_readNC, moab::Range::begin(), moab::ReadNC::dbgOut, moab::ReadNC::dimLens, moab::Range::end(), moab::ReadNC::ENTLOCVERT, ErrorCode, moab::Interface::get_entities_by_dimension(), moab::NCHelper::get_tag_to_nonset(), moab::UcdNCHelper::localGidVerts, MB_CHK_SET_ERR, MB_INDEX_OUT_OF_RANGE, MB_SET_ERR, moab::ReadNC::mbImpl, moab::UcdNCHelper::nLocalVertices, moab::Range::psize(), moab::Range::size(), t, moab::Interface::tag_iterate(), moab::NCHelper::tDim, and moab::DebugOutput::tprintf().
Referenced by read_ucd_variables_to_nonset().
    Range* range = NULL;
    // Get vertices
    Range verts;
    ErrorCode rval = mbImpl->get_entities_by_dimension( _fileSet, 0, verts );MB_CHK_SET_ERR( rval, "Trouble getting vertices in current file set" );
    assert( "Should only have a single vertex subrange, since they were read in one shot" && verts.psize() == 1 );
        // Support non-set variables with 3 dimensions like (time, lev, ncol)
        assert( 3 == vdatas[i].varDims.size() );
        // For a non-set variable, time should be the first dimension
        assert( tDim == vdatas[i].varDims[0] );
        // Set up readStarts and readCounts
        vdatas[i].readStarts.resize( 3 );
        vdatas[i].readCounts.resize( 3 );
        // First: time
        vdatas[i].readStarts[0] = 0;  // This value is timestep dependent, will be set later
        vdatas[i].readCounts[0] = 1;
        // Next: lev
        vdatas[i].readStarts[1] = 0;
        vdatas[i].readCounts[1] = vdatas[i].numLev;
        // Finally: ncol
        switch( vdatas[i].entLoc )
            case ReadNC::ENTLOCVERT:
                // Vertices
                // Start from the first localGidVerts
                // Actually, this will be reset later on in a loop
                vdatas[i].readStarts[2] = localGidVerts[0] - 1;
                vdatas[i].readCounts[2] = nLocalVertices;
                range                   = &verts;
                break;
            default:
                MB_SET_ERR( MB_FAILURE, "Unexpected entity location type for variable " << vdatas[i].varName );
        // Get variable size
        vdatas[i].sz = 1;
        for( std::size_t idx = 0; idx != 3; idx++ )
            vdatas[i].sz *= vdatas[i].readCounts[idx];
            dbgOut.tprintf( 2, "Reading variable %s, time step %d\n", vdatas[i].varName.c_str(), tstep_nums[t] );
            if( tstep_nums[t] >= dimLens[tDim] )
                MB_SET_ERR( MB_INDEX_OUT_OF_RANGE, "Wrong value for timestep number " << tstep_nums[t] );
            // Get the tag to read into
            if( !vdatas[i].varTags[t] )
                rval = get_tag_to_nonset( vdatas[i], tstep_nums[t], vdatas[i].varTags[t], vdatas[i].numLev );MB_CHK_SET_ERR( rval, "Trouble getting tag for variable " << vdatas[i].varName );
            // Get ptr to tag space
            void* data;
            int count;
            rval = mbImpl->tag_iterate( vdatas[i].varTags[t], range->begin(), range->end(), count, data );MB_CHK_SET_ERR( rval, "Failed to iterate tag for variable " << vdatas[i].varName );
            assert( (unsigned)count == range->size() );
            vdatas[i].varDatas[t] = data;
    return rval;
Member Data Documentation
Definition at line 51 of file NCHelperHOMME.hpp.
Referenced by create_mesh(), and NCHelperHOMME().
Definition at line 52 of file NCHelperHOMME.hpp.
Referenced by create_mesh().
Definition at line 53 of file NCHelperHOMME.hpp.
Referenced by create_mesh(), init_mesh_vals(), and NCHelperHOMME().
List of all members.
