MOAB: Mesh Oriented datABase
(version 5.4.1)
00001 #include "NCHelper.hpp" 00002 #include "NCHelperEuler.hpp" 00003 #include "NCHelperFV.hpp" 00004 #include "NCHelperDomain.hpp" 00005 #include "NCHelperScrip.hpp" 00006 #include "NCHelperHOMME.hpp" 00007 #include "NCHelperMPAS.hpp" 00008 #include "NCHelperGCRM.hpp" 00009 00010 #include <sstream> 00011 00012 #include "MBTagConventions.hpp" 00013 00014 #ifdef WIN32 00015 #ifdef size_t 00016 #undef size_t 00017 #endif 00018 #endif 00019 00020 namespace moab 00021 { 00022 00023 NCHelper* NCHelper::get_nc_helper( ReadNC* readNC, int fileId, const FileOptions& opts, EntityHandle fileSet ) 00024 { 00025 // Check if CF convention is being followed 00026 bool is_CF = false; 00027 00028 std::map< std::string, ReadNC::AttData >& globalAtts = readNC->globalAtts; 00029 std::map< std::string, ReadNC::AttData >::iterator attIt = globalAtts.find( "conventions" ); 00030 if( attIt == globalAtts.end() ) attIt = globalAtts.find( "Conventions" ); 00031 00032 if( attIt != globalAtts.end() ) 00033 { 00034 unsigned int sz = attIt->second.attLen; 00035 std::string att_data; 00036 att_data.resize( sz + 1 ); 00037 att_data[sz] = '\000'; 00038 int success = 00039 NCFUNC( get_att_text )( fileId, attIt->second.attVarId, attIt->second.attName.c_str(), &att_data[0] ); 00040 if( 0 == success && att_data.find( "CF" ) != std::string::npos ) is_CF = true; 00041 } 00042 00043 if( is_CF ) 00044 { 00045 if( NCHelperEuler::can_read_file( readNC, fileId ) ) 00046 return new( std::nothrow ) NCHelperEuler( readNC, fileId, opts, fileSet ); 00047 else if( NCHelperFV::can_read_file( readNC, fileId ) ) 00048 return new( std::nothrow ) NCHelperFV( readNC, fileId, opts, fileSet ); 00049 else if( NCHelperHOMME::can_read_file( readNC, fileId ) ) 00050 return new( std::nothrow ) NCHelperHOMME( readNC, fileId, opts, fileSet ); 00051 else if( NCHelperDomain::can_read_file( readNC, fileId ) ) 00052 return new( std::nothrow ) NCHelperDomain( readNC, fileId, opts, fileSet ); 00053 } 00054 else 00055 { 00056 if( NCHelperMPAS::can_read_file( readNC ) ) 00057 return new( std::nothrow ) NCHelperMPAS( readNC, fileId, opts, fileSet ); 00058 // For a HOMME connectivity file, there might be no CF convention 00059 else if( NCHelperHOMME::can_read_file( readNC, fileId ) ) 00060 return new( std::nothrow ) NCHelperHOMME( readNC, fileId, opts, fileSet ); 00061 // gcrm reader 00062 else if( NCHelperGCRM::can_read_file( readNC ) ) 00063 return new( std::nothrow ) NCHelperGCRM( readNC, fileId, opts, fileSet ); 00064 } 00065 // SCRIP can be CF or non CF, if it comes from MPAS :) 00066 if( NCHelperScrip::can_read_file( readNC, fileId ) ) 00067 return new( std::nothrow ) NCHelperScrip( readNC, fileId, opts, fileSet ); 00068 00069 // Unknown NetCDF grid (will fill this in later for POP, CICE and CLM) 00070 return NULL; 00071 } 00072 00073 ErrorCode NCHelper::create_conventional_tags( const std::vector< int >& tstep_nums ) 00074 { 00075 Interface*& mbImpl = _readNC->mbImpl; 00076 std::vector< std::string >& dimNames = _readNC->dimNames; 00077 std::vector< int >& dimLens = _readNC->dimLens; 00078 std::map< std::string, ReadNC::AttData >& globalAtts = _readNC->globalAtts; 00079 std::map< std::string, ReadNC::VarData >& varInfo = _readNC->varInfo; 00080 DebugOutput& dbgOut = _readNC->dbgOut; 00081 int& partMethod = _readNC->partMethod; 00082 ScdInterface* scdi = _readNC->scdi; 00083 00084 ErrorCode rval; 00085 std::string tag_name; 00086 00087 // <__NUM_DIMS> 00088 Tag numDimsTag = 0; 00089 tag_name = "__NUM_DIMS"; 00090 int numDims = dimNames.size(); 00091 rval = mbImpl->tag_get_handle( tag_name.c_str(), 1, MB_TYPE_INTEGER, numDimsTag, MB_TAG_SPARSE | MB_TAG_CREAT );MB_CHK_SET_ERR( rval, "Trouble creating conventional tag " << tag_name ); 00092 rval = mbImpl->tag_set_data( numDimsTag, &_fileSet, 1, &numDims );MB_CHK_SET_ERR( rval, "Trouble setting data to conventional tag " << tag_name ); 00093 dbgOut.tprintf( 2, "Conventional tag %s created\n", tag_name.c_str() ); 00094 00095 // <__NUM_VARS> 00096 Tag numVarsTag = 0; 00097 tag_name = "__NUM_VARS"; 00098 int numVars = varInfo.size(); 00099 rval = mbImpl->tag_get_handle( tag_name.c_str(), 1, MB_TYPE_INTEGER, numVarsTag, MB_TAG_SPARSE | MB_TAG_CREAT );MB_CHK_SET_ERR( rval, "Trouble creating conventional tag " << tag_name ); 00100 rval = mbImpl->tag_set_data( numVarsTag, &_fileSet, 1, &numVars );MB_CHK_SET_ERR( rval, "Trouble setting data to conventional tag " << tag_name ); 00101 dbgOut.tprintf( 2, "Conventional tag %s created\n", tag_name.c_str() ); 00102 00103 // <__DIM_NAMES> 00104 Tag dimNamesTag = 0; 00105 tag_name = "__DIM_NAMES"; 00106 std::string dimnames; 00107 unsigned int dimNamesSz = dimNames.size(); 00108 for( unsigned int i = 0; i != dimNamesSz; i++ ) 00109 { 00110 dimnames.append( dimNames[i] ); 00111 dimnames.push_back( '\0' ); 00112 } 00113 int dimnamesSz = dimnames.size(); 00114 rval = mbImpl->tag_get_handle( tag_name.c_str(), 0, MB_TYPE_OPAQUE, dimNamesTag, 00115 MB_TAG_CREAT | MB_TAG_SPARSE | MB_TAG_VARLEN );MB_CHK_SET_ERR( rval, "Trouble creating conventional tag " << tag_name ); 00116 const void* ptr = dimnames.c_str(); 00117 rval = mbImpl->tag_set_by_ptr( dimNamesTag, &_fileSet, 1, &ptr, &dimnamesSz );MB_CHK_SET_ERR( rval, "Trouble setting data to conventional tag " << tag_name ); 00118 dbgOut.tprintf( 2, "Conventional tag %s created\n", tag_name.c_str() ); 00119 00120 // <__DIM_LENS> 00121 Tag dimLensTag = 0; 00122 tag_name = "__DIM_LENS"; 00123 int dimLensSz = dimLens.size(); 00124 rval = mbImpl->tag_get_handle( tag_name.c_str(), 0, MB_TYPE_INTEGER, dimLensTag, 00125 MB_TAG_CREAT | MB_TAG_SPARSE | MB_TAG_VARLEN );MB_CHK_SET_ERR( rval, "Trouble creating conventional tag " << tag_name ); 00126 ptr = &( dimLens[0] ); 00127 rval = mbImpl->tag_set_by_ptr( dimLensTag, &_fileSet, 1, &ptr, &dimLensSz );MB_CHK_SET_ERR( rval, "Trouble setting data to conventional tag " << tag_name ); 00128 dbgOut.tprintf( 2, "Conventional tag %s created\n", tag_name.c_str() ); 00129 00130 // <__VAR_NAMES> 00131 Tag varNamesTag = 0; 00132 tag_name = "__VAR_NAMES"; 00133 std::string varnames; 00134 std::map< std::string, ReadNC::VarData >::iterator mapIter; 00135 for( mapIter = varInfo.begin(); mapIter != varInfo.end(); ++mapIter ) 00136 { 00137 varnames.append( mapIter->first ); 00138 varnames.push_back( '\0' ); 00139 } 00140 int varnamesSz = varnames.size(); 00141 rval = mbImpl->tag_get_handle( tag_name.c_str(), 0, MB_TYPE_OPAQUE, varNamesTag, 00142 MB_TAG_CREAT | MB_TAG_SPARSE | MB_TAG_VARLEN );MB_CHK_SET_ERR( rval, "Trouble creating conventional tag " << tag_name ); 00143 ptr = varnames.c_str(); 00144 rval = mbImpl->tag_set_by_ptr( varNamesTag, &_fileSet, 1, &ptr, &varnamesSz );MB_CHK_SET_ERR( rval, "Trouble setting data to conventional tag " << tag_name ); 00145 dbgOut.tprintf( 2, "Conventional tag %s created\n", tag_name.c_str() ); 00146 00147 // __<dim_name>_LOC_MINMAX (for time) 00148 for( unsigned int i = 0; i != dimNamesSz; i++ ) 00149 { 00150 if( dimNames[i] == "time" || dimNames[i] == "Time" || dimNames[i] == "t" ) 00151 { 00152 // some files might have Time dimension as 0, it will not appear in any 00153 // variables, so skip it 00154 if( nTimeSteps == 0 ) continue; 00155 std::stringstream ss_tag_name; 00156 ss_tag_name << "__" << dimNames[i] << "_LOC_MINMAX"; 00157 tag_name = ss_tag_name.str(); 00158 Tag tagh = 0; 00159 std::vector< int > val( 2, 0 ); 00160 val[0] = 0; 00161 val[1] = nTimeSteps - 1; 00162 rval = mbImpl->tag_get_handle( tag_name.c_str(), 2, MB_TYPE_INTEGER, tagh, MB_TAG_SPARSE | MB_TAG_CREAT );MB_CHK_SET_ERR( rval, "Trouble creating conventional tag " << tag_name ); 00163 rval = mbImpl->tag_set_data( tagh, &_fileSet, 1, &val[0] );MB_CHK_SET_ERR( rval, "Trouble setting data to conventional tag " << tag_name ); 00164 dbgOut.tprintf( 2, "Conventional tag %s created\n", tag_name.c_str() ); 00165 } 00166 } 00167 00168 // __<dim_name>_LOC_VALS (for time) 00169 for( unsigned int i = 0; i != dimNamesSz; i++ ) 00170 { 00171 if( dimNames[i] == "time" || dimNames[i] == "Time" || dimNames[i] == "t" ) 00172 { 00173 std::vector< int > val; 00174 if( !tstep_nums.empty() ) 00175 val = tstep_nums; 00176 else 00177 { 00178 // some files might have Time dimension as 0, it will not appear in any 00179 // variables, so skip it 00180 if( tVals.empty() ) continue; 00181 val.resize( tVals.size() ); 00182 for( unsigned int j = 0; j != tVals.size(); j++ ) 00183 val[j] = j; 00184 } 00185 Tag tagh = 0; 00186 std::stringstream ss_tag_name; 00187 ss_tag_name << "__" << dimNames[i] << "_LOC_VALS"; 00188 tag_name = ss_tag_name.str(); 00189 rval = mbImpl->tag_get_handle( tag_name.c_str(), val.size(), MB_TYPE_INTEGER, tagh, 00190 MB_TAG_SPARSE | MB_TAG_CREAT );MB_CHK_SET_ERR( rval, "Trouble creating conventional tag " << tag_name ); 00191 rval = mbImpl->tag_set_data( tagh, &_fileSet, 1, &val[0] );MB_CHK_SET_ERR( rval, "Trouble setting data to conventional tag " << tag_name ); 00192 dbgOut.tprintf( 2, "Conventional tag %s created\n", tag_name.c_str() ); 00193 } 00194 } 00195 00196 // __<var_name>_DIMS 00197 for( mapIter = varInfo.begin(); mapIter != varInfo.end(); ++mapIter ) 00198 { 00199 Tag varNamesDimsTag = 0; 00200 std::stringstream ss_tag_name; 00201 ss_tag_name << "__" << mapIter->first << "_DIMS"; 00202 tag_name = ss_tag_name.str(); 00203 unsigned int varDimSz = varInfo[mapIter->first].varDims.size(); 00204 if( varDimSz == 0 ) continue; 00205 std::vector< Tag > varDimTags( varDimSz ); 00206 for( unsigned int i = 0; i != varDimSz; i++ ) 00207 { 00208 Tag tmptag = 0; 00209 std::string tmptagname = dimNames[varInfo[mapIter->first].varDims[i]]; 00210 rval = mbImpl->tag_get_handle( tmptagname.c_str(), 0, MB_TYPE_OPAQUE, tmptag, MB_TAG_ANY );MB_CHK_SET_ERR( rval, "Trouble getting tag " << tmptagname ); 00211 varDimTags[i] = tmptag; 00212 } 00213 // rval = mbImpl->tag_get_handle(tag_name.c_str(), varDimSz, MB_TYPE_HANDLE, 00214 // varNamesDimsTag, MB_TAG_SPARSE | MB_TAG_CREAT); We should not use MB_TYPE_HANDLE for Tag 00215 // here. Tag is a pointer, which is 4 bytes on 32 bit machines and 8 bytes on 64 bit 00216 // machines. Normally, entity handle is 8 bytes on 64 bit machines, but it can also be 00217 // configured to 4 bytes. 00218 rval = mbImpl->tag_get_handle( tag_name.c_str(), varDimSz * sizeof( Tag ), MB_TYPE_OPAQUE, varNamesDimsTag, 00219 MB_TAG_SPARSE | MB_TAG_CREAT );MB_CHK_SET_ERR( rval, "Trouble creating conventional tag " << tag_name ); 00220 rval = mbImpl->tag_set_data( varNamesDimsTag, &_fileSet, 1, &( varDimTags[0] ) );MB_CHK_SET_ERR( rval, "Trouble setting data to conventional tag " << tag_name ); 00221 dbgOut.tprintf( 2, "Conventional tag %s created\n", tag_name.c_str() ); 00222 } 00223 00224 // <PARTITION_METHOD> 00225 Tag part_tag = scdi->part_method_tag(); 00226 if( !part_tag ) MB_SET_ERR( MB_FAILURE, "Trouble getting PARTITION_METHOD tag" ); 00227 rval = mbImpl->tag_set_data( part_tag, &_fileSet, 1, &partMethod );MB_CHK_SET_ERR( rval, "Trouble setting data to PARTITION_METHOD tag" ); 00228 dbgOut.tprintf( 2, "Conventional tag %s created\n", tag_name.c_str() ); 00229 00230 // <__GLOBAL_ATTRIBS> 00231 tag_name = "__GLOBAL_ATTRIBS"; 00232 Tag globalAttTag = 0; 00233 rval = mbImpl->tag_get_handle( tag_name.c_str(), 0, MB_TYPE_OPAQUE, globalAttTag, 00234 MB_TAG_CREAT | MB_TAG_SPARSE | MB_TAG_VARLEN );MB_CHK_SET_ERR( rval, "Trouble creating conventional tag " << tag_name ); 00235 std::string gattVal; 00236 std::vector< int > gattLen; 00237 rval = create_attrib_string( globalAtts, gattVal, gattLen );MB_CHK_SET_ERR( rval, "Trouble creating global attribute string" ); 00238 const void* gattptr = gattVal.c_str(); 00239 int globalAttSz = gattVal.size(); 00240 rval = mbImpl->tag_set_by_ptr( globalAttTag, &_fileSet, 1, &gattptr, &globalAttSz );MB_CHK_SET_ERR( rval, "Trouble setting data to conventional tag " << tag_name ); 00241 dbgOut.tprintf( 2, "Conventional tag %s created\n", tag_name.c_str() ); 00242 00243 // <__GLOBAL_ATTRIBS_LEN> 00244 tag_name = "__GLOBAL_ATTRIBS_LEN"; 00245 Tag globalAttLenTag = 0; 00246 if( gattLen.size() == 0 ) gattLen.push_back( 0 ); 00247 rval = mbImpl->tag_get_handle( tag_name.c_str(), gattLen.size(), MB_TYPE_INTEGER, globalAttLenTag, 00248 MB_TAG_SPARSE | MB_TAG_CREAT );MB_CHK_SET_ERR( rval, "Trouble creating conventional tag " << tag_name ); 00249 rval = mbImpl->tag_set_data( globalAttLenTag, &_fileSet, 1, &gattLen[0] );MB_CHK_SET_ERR( rval, "Trouble setting data to conventional tag " << tag_name ); 00250 dbgOut.tprintf( 2, "Conventional tag %s created\n", tag_name.c_str() ); 00251 00252 // __<var_name>_ATTRIBS and __<var_name>_ATTRIBS_LEN 00253 for( mapIter = varInfo.begin(); mapIter != varInfo.end(); ++mapIter ) 00254 { 00255 std::stringstream ssTagName; 00256 ssTagName << "__" << mapIter->first << "_ATTRIBS"; 00257 tag_name = ssTagName.str(); 00258 Tag varAttTag = 0; 00259 rval = mbImpl->tag_get_handle( tag_name.c_str(), 0, MB_TYPE_OPAQUE, varAttTag, 00260 MB_TAG_CREAT | MB_TAG_SPARSE | MB_TAG_VARLEN );MB_CHK_SET_ERR( rval, "Trouble creating conventional tag " << tag_name ); 00261 00262 std::string varAttVal; 00263 std::vector< int > varAttLen; 00264 if( mapIter->second.numAtts < 1 ) 00265 { 00266 if( dummyVarNames.find( mapIter->first ) != dummyVarNames.end() ) 00267 { 00268 // This variable is a dummy coordinate variable 00269 varAttVal = "DUMMY_VAR"; 00270 } 00271 else 00272 { 00273 // This variable has no attributes 00274 varAttVal = "NO_ATTRIBS"; 00275 } 00276 } 00277 else 00278 { 00279 rval = create_attrib_string( mapIter->second.varAtts, varAttVal, varAttLen );MB_CHK_SET_ERR( rval, "Trouble creating attribute string for variable " << mapIter->first ); 00280 } 00281 const void* varAttPtr = varAttVal.c_str(); 00282 int varAttSz = varAttVal.size(); 00283 if( 0 == varAttSz ) varAttSz = 1; 00284 rval = mbImpl->tag_set_by_ptr( varAttTag, &_fileSet, 1, &varAttPtr, &varAttSz );MB_CHK_SET_ERR( rval, "Trouble setting data to conventional tag " << tag_name ); 00285 dbgOut.tprintf( 2, "Conventional tag %s created\n", tag_name.c_str() ); 00286 00287 ssTagName << "_LEN"; 00288 tag_name = ssTagName.str(); 00289 Tag varAttLenTag = 0; 00290 if( 0 == varAttLen.size() ) varAttLen.push_back( 0 ); 00291 rval = mbImpl->tag_get_handle( tag_name.c_str(), varAttLen.size(), MB_TYPE_INTEGER, varAttLenTag, 00292 MB_TAG_SPARSE | MB_TAG_CREAT );MB_CHK_SET_ERR( rval, "Trouble creating conventional tag " << tag_name ); 00293 rval = mbImpl->tag_set_data( varAttLenTag, &_fileSet, 1, &varAttLen[0] );MB_CHK_SET_ERR( rval, "Trouble setting data to conventional tag " << tag_name ); 00294 dbgOut.tprintf( 2, "Conventional tag %s created\n", tag_name.c_str() ); 00295 } 00296 00297 // <__VAR_NAMES_LOCATIONS> 00298 tag_name = "__VAR_NAMES_LOCATIONS"; 00299 Tag varNamesLocsTag = 0; 00300 std::vector< int > varNamesLocs( varInfo.size() ); 00301 rval = mbImpl->tag_get_handle( tag_name.c_str(), varNamesLocs.size(), MB_TYPE_INTEGER, varNamesLocsTag, 00302 MB_TAG_CREAT | MB_TAG_SPARSE );MB_CHK_SET_ERR( rval, "Trouble creating conventional tag " << tag_name ); 00303 for( mapIter = varInfo.begin(); mapIter != varInfo.end(); ++mapIter ) 00304 { 00305 varNamesLocs[std::distance( varInfo.begin(), mapIter )] = mapIter->second.entLoc; 00306 } 00307 rval = mbImpl->tag_set_data( varNamesLocsTag, &_fileSet, 1, &varNamesLocs[0] );MB_CHK_SET_ERR( rval, "Trouble setting data to conventional tag " << tag_name ); 00308 dbgOut.tprintf( 2, "Conventional tag %s created\n", tag_name.c_str() ); 00309 00310 // <__MESH_TYPE> 00311 Tag meshTypeTag = 0; 00312 tag_name = "__MESH_TYPE"; 00313 std::string meshTypeName = get_mesh_type_name(); 00314 00315 rval = mbImpl->tag_get_handle( tag_name.c_str(), 0, MB_TYPE_OPAQUE, meshTypeTag, 00316 MB_TAG_CREAT | MB_TAG_SPARSE | MB_TAG_VARLEN );MB_CHK_SET_ERR( rval, "Trouble creating conventional tag " << tag_name ); 00317 ptr = meshTypeName.c_str(); 00318 int leng = meshTypeName.size(); 00319 rval = mbImpl->tag_set_by_ptr( meshTypeTag, &_fileSet, 1, &ptr, &leng );MB_CHK_SET_ERR( rval, "Trouble setting data to conventional tag " << tag_name ); 00320 dbgOut.tprintf( 2, "Conventional tag %s created\n", tag_name.c_str() ); 00321 00322 return MB_SUCCESS; 00323 } 00324 00325 ErrorCode NCHelper::update_time_tag_vals() 00326 { 00327 Interface*& mbImpl = _readNC->mbImpl; 00328 std::vector< std::string >& dimNames = _readNC->dimNames; 00329 00330 ErrorCode rval; 00331 00332 // The time tag might be a dummy one (e.g. 'Time' for MPAS) 00333 std::string time_tag_name = dimNames[tDim]; 00334 if( dummyVarNames.find( time_tag_name ) != dummyVarNames.end() ) return MB_SUCCESS; 00335 00336 Tag time_tag = 0; 00337 const void* data = NULL; 00338 int time_tag_size = 0; 00339 rval = mbImpl->tag_get_handle( time_tag_name.c_str(), 0, MB_TYPE_DOUBLE, time_tag, MB_TAG_VARLEN );MB_CHK_SET_ERR( rval, "Trouble getting tag " << time_tag_name ); 00340 rval = mbImpl->tag_get_by_ptr( time_tag, &_fileSet, 1, &data, &time_tag_size );MB_CHK_SET_ERR( rval, "Trouble getting data of tag " << time_tag_name ); 00341 const double* time_tag_vals = static_cast< const double* >( data ); 00342 00343 // Merge tVals (read from current file) to existing time tag 00344 // Assume that time_tag_vals and tVals are both sorted 00345 std::vector< double > merged_time_vals; 00346 merged_time_vals.reserve( time_tag_size + nTimeSteps ); 00347 int i = 0; 00348 int j = 0; 00349 00350 // Merge time values from time_tag_vals and tVals 00351 while( i < time_tag_size && j < nTimeSteps ) 00352 { 00353 if( time_tag_vals[i] < tVals[j] ) 00354 merged_time_vals.push_back( time_tag_vals[i++] ); 00355 else 00356 merged_time_vals.push_back( tVals[j++] ); 00357 } 00358 00359 // Append remaining time values of time_tag_vals (if any) 00360 while( i < time_tag_size ) 00361 merged_time_vals.push_back( time_tag_vals[i++] ); 00362 00363 // Append remaining time values of tVals (if any) 00364 while( j < nTimeSteps ) 00365 merged_time_vals.push_back( tVals[j++] ); 00366 00367 data = &merged_time_vals[0]; 00368 time_tag_size = merged_time_vals.size(); 00369 rval = mbImpl->tag_set_by_ptr( time_tag, &_fileSet, 1, &data, &time_tag_size );MB_CHK_SET_ERR( rval, "Trouble setting data to tag " << time_tag_name ); 00370 00371 return MB_SUCCESS; 00372 } 00373 00374 ErrorCode NCHelper::read_variables_setup( std::vector< std::string >& var_names, 00375 std::vector< int >& tstep_nums, 00376 std::vector< ReadNC::VarData >& vdatas, 00377 std::vector< ReadNC::VarData >& vsetdatas ) 00378 { 00379 std::map< std::string, ReadNC::VarData >& varInfo = _readNC->varInfo; 00380 std::vector< std::string >& dimNames = _readNC->dimNames; 00381 00382 std::map< std::string, ReadNC::VarData >::iterator mit; 00383 00384 // If empty read them all (except ignored variables) 00385 if( var_names.empty() ) 00386 { 00387 for( mit = varInfo.begin(); mit != varInfo.end(); ++mit ) 00388 { 00389 ReadNC::VarData vd = ( *mit ).second; 00390 00391 // If read all variables at once, skip ignored ones 00392 if( ignoredVarNames.find( vd.varName ) != ignoredVarNames.end() ) continue; 00393 00394 // Coordinate variables (include dummy ones) were read to the file set by default 00395 if( std::find( dimNames.begin(), dimNames.end(), vd.varName ) != dimNames.end() ) continue; 00396 00397 if( vd.entLoc == ReadNC::ENTLOCSET ) 00398 vsetdatas.push_back( vd ); 00399 else 00400 vdatas.push_back( vd ); 00401 } 00402 } 00403 else 00404 { 00405 // Read specified variables (might include ignored ones) 00406 for( unsigned int i = 0; i < var_names.size(); i++ ) 00407 { 00408 mit = varInfo.find( var_names[i] ); 00409 if( mit != varInfo.end() ) 00410 { 00411 ReadNC::VarData vd = ( *mit ).second; 00412 00413 // Upon creation of dummy coordinate variables, tag values have already been set 00414 if( dummyVarNames.find( vd.varName ) != dummyVarNames.end() ) continue; 00415 00416 if( vd.entLoc == ReadNC::ENTLOCSET ) 00417 vsetdatas.push_back( vd ); 00418 else 00419 vdatas.push_back( vd ); 00420 } 00421 else 00422 { 00423 MB_SET_ERR( MB_FAILURE, "Couldn't find specified variable " << var_names[i] ); 00424 } 00425 } 00426 } 00427 00428 if( tstep_nums.empty() && nTimeSteps > 0 ) 00429 { 00430 // No timesteps input, get them all 00431 for( int i = 0; i < nTimeSteps; i++ ) 00432 tstep_nums.push_back( i ); 00433 } 00434 00435 if( !tstep_nums.empty() ) 00436 { 00437 for( unsigned int i = 0; i < vdatas.size(); i++ ) 00438 { 00439 vdatas[i].varTags.resize( tstep_nums.size(), 0 ); 00440 vdatas[i].varDatas.resize( tstep_nums.size() ); 00441 // NC reader assumes that non-set variables always have timesteps 00442 assert( std::find( vdatas[i].varDims.begin(), vdatas[i].varDims.end(), tDim ) != vdatas[i].varDims.end() ); 00443 vdatas[i].has_tsteps = true; 00444 } 00445 00446 for( unsigned int i = 0; i < vsetdatas.size(); i++ ) 00447 { 00448 if( ( std::find( vsetdatas[i].varDims.begin(), vsetdatas[i].varDims.end(), tDim ) != 00449 vsetdatas[i].varDims.end() ) && 00450 ( vsetdatas[i].varName != dimNames[tDim] ) ) 00451 { 00452 // Set variables with timesteps: e.g. xtime(Time) or xtime(Time, StrLen) 00453 vsetdatas[i].varTags.resize( tstep_nums.size(), 0 ); 00454 vsetdatas[i].varDatas.resize( tstep_nums.size() ); 00455 vsetdatas[i].has_tsteps = true; 00456 } 00457 else 00458 { 00459 // Set variables without timesteps: no time dimension, or time itself 00460 vsetdatas[i].varTags.resize( 1, 0 ); 00461 vsetdatas[i].varDatas.resize( 1 ); 00462 vsetdatas[i].has_tsteps = false; 00463 } 00464 } 00465 } 00466 00467 return MB_SUCCESS; 00468 } 00469 00470 ErrorCode NCHelper::read_variables_to_set( std::vector< ReadNC::VarData >& vdatas, std::vector< int >& tstep_nums ) 00471 { 00472 Interface*& mbImpl = _readNC->mbImpl; 00473 DebugOutput& dbgOut = _readNC->dbgOut; 00474 00475 ErrorCode rval = read_variables_to_set_allocate( vdatas, tstep_nums );MB_CHK_SET_ERR( rval, "Trouble allocating space to read set variables" ); 00476 00477 // Finally, read into that space 00478 int success; 00479 for( unsigned int i = 0; i < vdatas.size(); i++ ) 00480 { 00481 // Note, for set variables without timesteps, loop one time and then break 00482 for( unsigned int t = 0; t < tstep_nums.size(); t++ ) 00483 { 00484 void* data = vdatas[i].varDatas[t]; 00485 00486 // Set variables with timesteps, e.g. xtime(Time) or xtime(Time, StrLen) 00487 if( vdatas[i].has_tsteps ) 00488 { 00489 // Set readStart for each timestep along time dimension 00490 vdatas[i].readStarts[0] = tstep_nums[t]; 00491 } 00492 00493 switch( vdatas[i].varDataType ) 00494 { 00495 case NC_BYTE: 00496 case NC_CHAR: 00497 success = NCFUNCAG( _vara_text )( _fileId, vdatas[i].varId, &vdatas[i].readStarts[0], 00498 &vdatas[i].readCounts[0], (char*)data ); 00499 if( success ) 00500 MB_SET_ERR( MB_FAILURE, "Failed to read byte/char data for variable " << vdatas[i].varName ); 00501 break; 00502 case NC_SHORT: 00503 case NC_INT: 00504 success = NCFUNCAG( _vara_int )( _fileId, vdatas[i].varId, &vdatas[i].readStarts[0], 00505 &vdatas[i].readCounts[0], (int*)data ); 00506 if( success ) 00507 MB_SET_ERR( MB_FAILURE, "Failed to read short/int data for variable " << vdatas[i].varName ); 00508 break; 00509 case NC_FLOAT: 00510 case NC_DOUBLE: 00511 success = NCFUNCAG( _vara_double )( _fileId, vdatas[i].varId, &vdatas[i].readStarts[0], 00512 &vdatas[i].readCounts[0], (double*)data ); 00513 if( success ) 00514 MB_SET_ERR( MB_FAILURE, "Failed to read float/double data for variable " << vdatas[i].varName ); 00515 break; 00516 default: 00517 MB_SET_ERR( MB_FAILURE, "Unexpected data type for variable " << vdatas[i].varName ); 00518 } 00519 00520 dbgOut.tprintf( 2, "Setting data for variable %s, time step %d\n", vdatas[i].varName.c_str(), 00521 tstep_nums[t] ); 00522 rval = mbImpl->tag_set_by_ptr( vdatas[i].varTags[t], &_fileSet, 1, &data, &vdatas[i].sz );MB_CHK_SET_ERR( rval, "Trouble setting tag data for variable " << vdatas[i].varName ); 00523 00524 // Memory pointed by pointer data can be deleted, as tag_set_by_ptr() has already copied 00525 // the tag values 00526 switch( vdatas[i].varDataType ) 00527 { 00528 case NC_BYTE: 00529 case NC_CHAR: 00530 delete[]( char* ) data; 00531 break; 00532 case NC_SHORT: 00533 case NC_INT: 00534 delete[]( int* ) data; 00535 break; 00536 case NC_FLOAT: 00537 case NC_DOUBLE: 00538 delete[]( double* ) data; 00539 break; 00540 default: 00541 break; 00542 } 00543 vdatas[i].varDatas[t] = NULL; 00544 00545 // Loop continues only for set variables with timesteps, e.g. xtime(Time) or xtime(Time, 00546 // StrLen) 00547 if( !vdatas[i].has_tsteps ) break; 00548 } 00549 } 00550 00551 // Debug output, if requested 00552 if( 1 == dbgOut.get_verbosity() ) 00553 { 00554 dbgOut.printf( 1, "Read variables: %s", vdatas.begin()->varName.c_str() ); 00555 for( unsigned int i = 1; i < vdatas.size(); i++ ) 00556 dbgOut.printf( 1, ", %s ", vdatas[i].varName.c_str() ); 00557 dbgOut.tprintf( 1, "\n" ); 00558 } 00559 00560 return rval; 00561 } 00562 00563 ErrorCode NCHelper::read_coordinate( const char* var_name, int lmin, int lmax, std::vector< double >& cvals ) 00564 { 00565 std::map< std::string, ReadNC::VarData >& varInfo = _readNC->varInfo; 00566 std::map< std::string, ReadNC::VarData >::iterator vmit = varInfo.find( var_name ); 00567 if( varInfo.end() == vmit ) MB_SET_ERR( MB_FAILURE, "Couldn't find variable " << var_name ); 00568 00569 assert( lmin >= 0 && lmax >= lmin ); 00570 NCDF_SIZE tstart = lmin; 00571 NCDF_SIZE tcount = lmax - lmin + 1; 00572 NCDF_DIFF dum_stride = 1; 00573 int success; 00574 00575 // Check size 00576 if( (std::size_t)tcount != cvals.size() ) cvals.resize( tcount ); 00577 00578 // Check to make sure it's a float or double 00579 switch( ( *vmit ).second.varDataType ) 00580 { 00581 case NC_FLOAT: 00582 case NC_DOUBLE: 00583 // Read float as double 00584 success = 00585 NCFUNCAG( _vars_double )( _fileId, ( *vmit ).second.varId, &tstart, &tcount, &dum_stride, &cvals[0] ); 00586 if( success ) MB_SET_ERR( MB_FAILURE, "Failed to read float/double data for variable " << var_name ); 00587 break; 00588 default: 00589 MB_SET_ERR( MB_FAILURE, "Unexpected data type for variable " << var_name ); 00590 } 00591 00592 return MB_SUCCESS; 00593 } 00594 00595 ErrorCode NCHelper::get_tag_to_set( ReadNC::VarData& var_data, int tstep_num, Tag& tagh ) 00596 { 00597 Interface*& mbImpl = _readNC->mbImpl; 00598 DebugOutput& dbgOut = _readNC->dbgOut; 00599 int& tStepBase = _readNC->tStepBase; 00600 00601 if( tStepBase > 0 ) tstep_num += tStepBase; 00602 00603 std::ostringstream tag_name; 00604 if( var_data.has_tsteps ) 00605 tag_name << var_data.varName << tstep_num; 00606 else 00607 tag_name << var_data.varName; 00608 00609 ErrorCode rval = MB_SUCCESS; 00610 tagh = 0; 00611 switch( var_data.varDataType ) 00612 { 00613 case NC_BYTE: 00614 case NC_CHAR: 00615 rval = mbImpl->tag_get_handle( tag_name.str().c_str(), 0, MB_TYPE_OPAQUE, tagh, 00616 MB_TAG_CREAT | MB_TAG_SPARSE | MB_TAG_VARLEN );MB_CHK_SET_ERR( rval, "Trouble creating tag " << tag_name.str() ); 00617 break; 00618 case NC_SHORT: 00619 case NC_INT: 00620 rval = mbImpl->tag_get_handle( tag_name.str().c_str(), 0, MB_TYPE_INTEGER, tagh, 00621 MB_TAG_CREAT | MB_TAG_SPARSE | MB_TAG_VARLEN );MB_CHK_SET_ERR( rval, "Trouble creating tag " << tag_name.str() ); 00622 break; 00623 case NC_FLOAT: 00624 case NC_DOUBLE: 00625 rval = mbImpl->tag_get_handle( tag_name.str().c_str(), 0, MB_TYPE_DOUBLE, tagh, 00626 MB_TAG_CREAT | MB_TAG_SPARSE | MB_TAG_VARLEN );MB_CHK_SET_ERR( rval, "Trouble creating tag " << tag_name.str() ); 00627 break; 00628 default: 00629 MB_SET_ERR( MB_FAILURE, "Unexpected data type for variable " << var_data.varName ); 00630 } 00631 00632 dbgOut.tprintf( 2, "Tag %s created\n", tag_name.str().c_str() ); 00633 00634 return rval; 00635 } 00636 00637 ErrorCode NCHelper::get_tag_to_nonset( ReadNC::VarData& var_data, int tstep_num, Tag& tagh, int num_lev ) 00638 { 00639 Interface*& mbImpl = _readNC->mbImpl; 00640 DebugOutput& dbgOut = _readNC->dbgOut; 00641 int& tStepBase = _readNC->tStepBase; 00642 00643 if( tStepBase > 0 ) tstep_num += tStepBase; 00644 00645 std::ostringstream tag_name; 00646 tag_name << var_data.varName << tstep_num; 00647 00648 ErrorCode rval = MB_SUCCESS; 00649 tagh = 0; 00650 switch( var_data.varDataType ) 00651 { 00652 case NC_BYTE: 00653 case NC_CHAR: 00654 rval = mbImpl->tag_get_handle( tag_name.str().c_str(), num_lev, MB_TYPE_OPAQUE, tagh, 00655 MB_TAG_DENSE | MB_TAG_CREAT );MB_CHK_SET_ERR( rval, "Trouble creating tag " << tag_name.str() ); 00656 break; 00657 case NC_SHORT: 00658 case NC_INT: 00659 rval = mbImpl->tag_get_handle( tag_name.str().c_str(), num_lev, MB_TYPE_INTEGER, tagh, 00660 MB_TAG_DENSE | MB_TAG_CREAT );MB_CHK_SET_ERR( rval, "Trouble creating tag " << tag_name.str() ); 00661 break; 00662 case NC_FLOAT: 00663 case NC_DOUBLE: 00664 rval = mbImpl->tag_get_handle( tag_name.str().c_str(), num_lev, MB_TYPE_DOUBLE, tagh, 00665 MB_TAG_DENSE | MB_TAG_CREAT );MB_CHK_SET_ERR( rval, "Trouble creating tag " << tag_name.str() ); 00666 break; 00667 default: 00668 MB_SET_ERR( MB_FAILURE, "Unexpected data type for variable " << var_data.varName ); 00669 } 00670 00671 dbgOut.tprintf( 2, "Tag %s created\n", tag_name.str().c_str() ); 00672 00673 return rval; 00674 } 00675 00676 ErrorCode NCHelper::create_attrib_string( const std::map< std::string, ReadNC::AttData >& attMap, 00677 std::string& attVal, 00678 std::vector< int >& attLen ) 00679 { 00680 int success; 00681 std::stringstream ssAtt; 00682 unsigned int sz = 0; 00683 std::map< std::string, ReadNC::AttData >::const_iterator attIt = attMap.begin(); 00684 for( ; attIt != attMap.end(); ++attIt ) 00685 { 00686 ssAtt << attIt->second.attName; 00687 ssAtt << '\0'; 00688 void* attData = NULL; 00689 switch( attIt->second.attDataType ) 00690 { 00691 case NC_BYTE: 00692 case NC_CHAR: 00693 sz = attIt->second.attLen; 00694 attData = (char*)malloc( sz ); 00695 success = NCFUNC( get_att_text )( _fileId, attIt->second.attVarId, attIt->second.attName.c_str(), 00696 (char*)attData ); 00697 if( success ) 00698 MB_SET_ERR( MB_FAILURE, "Failed to read byte/char data for attribute " << attIt->second.attName ); 00699 ssAtt << "char;"; 00700 break; 00701 case NC_SHORT: 00702 sz = attIt->second.attLen * sizeof( short ); 00703 attData = (short*)malloc( sz ); 00704 success = NCFUNC( get_att_short )( _fileId, attIt->second.attVarId, attIt->second.attName.c_str(), 00705 (short*)attData ); 00706 if( success ) 00707 MB_SET_ERR( MB_FAILURE, "Failed to read short data for attribute " << attIt->second.attName ); 00708 ssAtt << "short;"; 00709 break; 00710 case NC_INT: 00711 sz = attIt->second.attLen * sizeof( int ); 00712 attData = (int*)malloc( sz ); 00713 success = NCFUNC( get_att_int )( _fileId, attIt->second.attVarId, attIt->second.attName.c_str(), 00714 (int*)attData ); 00715 if( success ) 00716 MB_SET_ERR( MB_FAILURE, "Failed to read int data for attribute " << attIt->second.attName ); 00717 ssAtt << "int;"; 00718 break; 00719 case NC_FLOAT: 00720 sz = attIt->second.attLen * sizeof( float ); 00721 attData = (float*)malloc( sz ); 00722 success = NCFUNC( get_att_float )( _fileId, attIt->second.attVarId, attIt->second.attName.c_str(), 00723 (float*)attData ); 00724 if( success ) 00725 MB_SET_ERR( MB_FAILURE, "Failed to read float data for attribute " << attIt->second.attName ); 00726 ssAtt << "float;"; 00727 break; 00728 case NC_DOUBLE: 00729 sz = attIt->second.attLen * sizeof( double ); 00730 attData = (double*)malloc( sz ); 00731 success = NCFUNC( get_att_double )( _fileId, attIt->second.attVarId, attIt->second.attName.c_str(), 00732 (double*)attData ); 00733 if( success ) 00734 MB_SET_ERR( MB_FAILURE, "Failed to read double data for attribute " << attIt->second.attName ); 00735 ssAtt << "double;"; 00736 break; 00737 default: 00738 MB_SET_ERR( MB_FAILURE, "Unexpected data type for attribute " << attIt->second.attName ); 00739 } 00740 char* tmpc = (char*)attData; 00741 for( unsigned int counter = 0; counter != sz; ++counter ) 00742 ssAtt << tmpc[counter]; 00743 free( attData ); 00744 ssAtt << ';'; 00745 attLen.push_back( ssAtt.str().size() - 1 ); 00746 } 00747 attVal = ssAtt.str(); 00748 00749 return MB_SUCCESS; 00750 } 00751 00752 ErrorCode NCHelper::create_dummy_variables() 00753 { 00754 Interface*& mbImpl = _readNC->mbImpl; 00755 std::vector< std::string >& dimNames = _readNC->dimNames; 00756 std::vector< int >& dimLens = _readNC->dimLens; 00757 std::map< std::string, ReadNC::VarData >& varInfo = _readNC->varInfo; 00758 DebugOutput& dbgOut = _readNC->dbgOut; 00759 00760 // Hack: look at all dimensions, and see if we have one that does not appear in the list of 00761 // varInfo names Right now, candidates are from unstructured meshes, such as ncol (HOMME) and 00762 // nCells (MPAS) For each of them, create a dummy coordinate variable with a sparse tag to store 00763 // the dimension length 00764 for( unsigned int i = 0; i < dimNames.size(); i++ ) 00765 { 00766 // If there is a variable with this dimension name, skip 00767 if( varInfo.find( dimNames[i] ) != varInfo.end() ) continue; 00768 00769 // Create a dummy coordinate variable 00770 int sizeTotalVar = varInfo.size(); 00771 std::string var_name( dimNames[i] ); 00772 ReadNC::VarData& data = varInfo[var_name]; 00773 data.varName = var_name; 00774 data.varId = sizeTotalVar; 00775 data.varTags.resize( 1, 0 ); 00776 data.varDataType = NC_INT; 00777 data.varDims.resize( 1 ); 00778 data.varDims[0] = (int)i; 00779 data.numAtts = 0; 00780 data.entLoc = ReadNC::ENTLOCSET; 00781 dummyVarNames.insert( var_name ); 00782 dbgOut.tprintf( 2, "Dummy coordinate variable created for dimension %s\n", var_name.c_str() ); 00783 00784 // Create a corresponding sparse tag 00785 Tag tagh; 00786 ErrorCode rval = mbImpl->tag_get_handle( var_name.c_str(), 0, MB_TYPE_INTEGER, tagh, 00787 MB_TAG_CREAT | MB_TAG_SPARSE | MB_TAG_VARLEN );MB_CHK_SET_ERR( rval, "Trouble creating tag for dummy coordinate variable " << var_name ); 00788 00789 // Tag value is the dimension length 00790 const void* ptr = &dimLens[i]; 00791 // Tag size is 1 00792 int size = 1; 00793 rval = mbImpl->tag_set_by_ptr( tagh, &_fileSet, 1, &ptr, &size );MB_CHK_SET_ERR( rval, "Trouble setting tag data for dummy coordinate variable " << var_name ); 00794 00795 dbgOut.tprintf( 2, "Sparse tag created for dimension %s\n", var_name.c_str() ); 00796 } 00797 00798 return MB_SUCCESS; 00799 } 00800 00801 ErrorCode NCHelper::read_variables_to_set_allocate( std::vector< ReadNC::VarData >& vdatas, 00802 std::vector< int >& tstep_nums ) 00803 { 00804 std::vector< int >& dimLens = _readNC->dimLens; 00805 DebugOutput& dbgOut = _readNC->dbgOut; 00806 00807 ErrorCode rval = MB_SUCCESS; 00808 00809 for( unsigned int i = 0; i < vdatas.size(); i++ ) 00810 { 00811 // Set up readStarts and readCounts 00812 if( vdatas[i].has_tsteps ) 00813 { 00814 // First: time 00815 vdatas[i].readStarts.push_back( 0 ); // This value is timestep dependent, will be set later 00816 vdatas[i].readCounts.push_back( 1 ); 00817 00818 // Next: other dimensions 00819 for( unsigned int idx = 1; idx != vdatas[i].varDims.size(); idx++ ) 00820 { 00821 vdatas[i].readStarts.push_back( 0 ); 00822 vdatas[i].readCounts.push_back( dimLens[vdatas[i].varDims[idx]] ); 00823 } 00824 } 00825 else 00826 { 00827 if( vdatas[i].varDims.empty() ) 00828 { 00829 // Scalar variable 00830 vdatas[i].readStarts.push_back( 0 ); 00831 vdatas[i].readCounts.push_back( 1 ); 00832 } 00833 else 00834 { 00835 for( unsigned int idx = 0; idx != vdatas[i].varDims.size(); idx++ ) 00836 { 00837 vdatas[i].readStarts.push_back( 0 ); 00838 vdatas[i].readCounts.push_back( dimLens[vdatas[i].varDims[idx]] ); 00839 } 00840 } 00841 } 00842 00843 // Get variable size 00844 vdatas[i].sz = 1; 00845 for( std::size_t idx = 0; idx != vdatas[i].readCounts.size(); idx++ ) 00846 vdatas[i].sz *= vdatas[i].readCounts[idx]; 00847 00848 // Note, for set variables without timesteps, loop one time and then break 00849 for( unsigned int t = 0; t < tstep_nums.size(); t++ ) 00850 { 00851 dbgOut.tprintf( 2, "Reading variable %s, time step %d\n", vdatas[i].varName.c_str(), tstep_nums[t] ); 00852 00853 if( tstep_nums[t] >= dimLens[tDim] ) 00854 { 00855 MB_SET_ERR( MB_INDEX_OUT_OF_RANGE, "Wrong value for timestep number " << tstep_nums[t] ); 00856 } 00857 00858 // Get the tag to read into 00859 if( !vdatas[i].varTags[t] ) 00860 { 00861 rval = get_tag_to_set( vdatas[i], tstep_nums[t], vdatas[i].varTags[t] );MB_CHK_SET_ERR( rval, "Trouble getting tag to set variable " << vdatas[i].varName ); 00862 } 00863 00864 switch( vdatas[i].varDataType ) 00865 { 00866 case NC_BYTE: 00867 case NC_CHAR: 00868 vdatas[i].varDatas[t] = new char[vdatas[i].sz]; 00869 break; 00870 case NC_SHORT: 00871 case NC_INT: 00872 vdatas[i].varDatas[t] = new int[vdatas[i].sz]; 00873 break; 00874 case NC_FLOAT: 00875 case NC_DOUBLE: 00876 vdatas[i].varDatas[t] = new double[vdatas[i].sz]; 00877 break; 00878 default: 00879 MB_SET_ERR( MB_FAILURE, "Unexpected data type for variable " << vdatas[i].varName ); 00880 } 00881 00882 // Loop continues only for set variables with timesteps, e.g. xtime(Time) or xtime(Time, 00883 // StrLen) 00884 if( !vdatas[i].has_tsteps ) break; 00885 } 00886 } 00887 00888 return rval; 00889 } 00890 00891 ErrorCode ScdNCHelper::check_existing_mesh() 00892 { 00893 Interface*& mbImpl = _readNC->mbImpl; 00894 00895 // Get the number of vertices 00896 int num_verts; 00897 ErrorCode rval = mbImpl->get_number_entities_by_dimension( _fileSet, 0, num_verts );MB_CHK_SET_ERR( rval, "Trouble getting number of vertices" ); 00898 00899 /* 00900 // Check against parameters 00901 // When ghosting is used, this check might fail (to be updated later) 00902 if (num_verts > 0) { 00903 int expected_verts = (lDims[3] - lDims[0] + 1) * (lDims[4] - lDims[1] + 1) * (-1 == lDims[2] ? 00904 1 : lDims[5] - lDims[2] + 1); if (num_verts != expected_verts) { MB_SET_ERR(MB_FAILURE, "Number 00905 of vertices doesn't match"); 00906 } 00907 } 00908 */ 00909 00910 // Check the number of elements too 00911 int num_elems; 00912 rval = mbImpl->get_number_entities_by_dimension( _fileSet, ( -1 == lCDims[2] ? 2 : 3 ), num_elems );MB_CHK_SET_ERR( rval, "Trouble getting number of elements" ); 00913 00914 /* 00915 // Check against parameters 00916 // When ghosting is used, this check might fail (to be updated later) 00917 if (num_elems > 0) { 00918 int expected_elems = (lCDims[3] - lCDims[0] + 1) * (lCDims[4] - lCDims[1] + 1) * (-1 == 00919 lCDims[2] ? 1 : (lCDims[5] - lCDims[2] + 1)); if (num_elems != expected_elems) { 00920 MB_SET_ERR(MB_FAILURE, "Number of elements doesn't match"); 00921 } 00922 } 00923 */ 00924 00925 return MB_SUCCESS; 00926 } 00927 00928 ErrorCode ScdNCHelper::create_mesh( Range& faces ) 00929 { 00930 Interface*& mbImpl = _readNC->mbImpl; 00931 Tag& mGlobalIdTag = _readNC->mGlobalIdTag; 00932 const Tag*& mpFileIdTag = _readNC->mpFileIdTag; 00933 DebugOutput& dbgOut = _readNC->dbgOut; 00934 ScdInterface* scdi = _readNC->scdi; 00935 ScdParData& parData = _readNC->parData; 00936 00937 Range tmp_range; 00938 ScdBox* scd_box; 00939 00940 ErrorCode rval = 00941 scdi->construct_box( HomCoord( lDims[0], lDims[1], lDims[2], 1 ), HomCoord( lDims[3], lDims[4], lDims[5], 1 ), 00942 NULL, 0, scd_box, locallyPeriodic, &parData, true );MB_CHK_SET_ERR( rval, "Trouble creating scd vertex sequence" ); 00943 00944 // Add verts to tmp_range first, so we can duplicate global ids in vertex ids 00945 tmp_range.insert( scd_box->start_vertex(), scd_box->start_vertex() + scd_box->num_vertices() - 1 ); 00946 00947 if( mpFileIdTag ) 00948 { 00949 int count; 00950 void* data; 00951 rval = mbImpl->tag_iterate( *mpFileIdTag, tmp_range.begin(), tmp_range.end(), count, data );MB_CHK_SET_ERR( rval, "Failed to iterate file ID tag on local vertices" ); 00952 assert( count == scd_box->num_vertices() ); 00953 int* fid_data = (int*)data; 00954 rval = mbImpl->tag_iterate( mGlobalIdTag, tmp_range.begin(), tmp_range.end(), count, data );MB_CHK_SET_ERR( rval, "Failed to iterate global ID tag on local vertices" ); 00955 assert( count == scd_box->num_vertices() ); 00956 int* gid_data = (int*)data; 00957 for( int i = 0; i < count; i++ ) 00958 fid_data[i] = gid_data[i]; 00959 } 00960 00961 // Then add box set and elements to the range, then to the file set 00962 tmp_range.insert( scd_box->start_element(), scd_box->start_element() + scd_box->num_elements() - 1 ); 00963 tmp_range.insert( scd_box->box_set() ); 00964 rval = mbImpl->add_entities( _fileSet, tmp_range );MB_CHK_SET_ERR( rval, "Couldn't add new vertices to current file set" ); 00965 00966 dbgOut.tprintf( 1, "scdbox %d quads, %d vertices\n", scd_box->num_elements(), scd_box->num_vertices() ); 00967 00968 // Set the vertex coordinates 00969 double *xc, *yc, *zc; 00970 rval = scd_box->get_coordinate_arrays( xc, yc, zc );MB_CHK_SET_ERR( rval, "Couldn't get vertex coordinate arrays" ); 00971 00972 int i, j, k, il, jl, kl; 00973 int dil = lDims[3] - lDims[0] + 1; 00974 int djl = lDims[4] - lDims[1] + 1; 00975 assert( dil == (int)ilVals.size() && djl == (int)jlVals.size() && 00976 ( -1 == lDims[2] || lDims[5] - lDims[2] + 1 == (int)levVals.size() ) ); 00977 00978 for( kl = lDims[2]; kl <= lDims[5]; kl++ ) 00979 { 00980 k = kl - lDims[2]; 00981 for( jl = lDims[1]; jl <= lDims[4]; jl++ ) 00982 { 00983 j = jl - lDims[1]; 00984 for( il = lDims[0]; il <= lDims[3]; il++ ) 00985 { 00986 i = il - lDims[0]; 00987 unsigned int pos = i + j * dil + k * dil * djl; 00988 xc[pos] = ilVals[i]; 00989 yc[pos] = jlVals[j]; 00990 zc[pos] = ( -1 == lDims[2] ? 0.0 : levVals[k] ); 00991 } 00992 } 00993 } 00994 00995 #ifndef NDEBUG 00996 int num_verts = 00997 ( lDims[3] - lDims[0] + 1 ) * ( lDims[4] - lDims[1] + 1 ) * ( -1 == lDims[2] ? 1 : lDims[5] - lDims[2] + 1 ); 00998 std::vector< int > gids( num_verts ); 00999 Range verts( scd_box->start_vertex(), scd_box->start_vertex() + scd_box->num_vertices() - 1 ); 01000 rval = mbImpl->tag_get_data( mGlobalIdTag, verts, &gids[0] );MB_CHK_SET_ERR( rval, "Trouble getting local gid values of vertices" ); 01001 int vmin = *( std::min_element( gids.begin(), gids.end() ) ), 01002 vmax = *( std::max_element( gids.begin(), gids.end() ) ); 01003 dbgOut.tprintf( 1, "Vertex gids %d-%d\n", vmin, vmax ); 01004 #endif 01005 01006 // Add elements to the range passed in 01007 faces.insert( scd_box->start_element(), scd_box->start_element() + scd_box->num_elements() - 1 ); 01008 01009 if( 2 <= dbgOut.get_verbosity() ) 01010 { 01011 assert( scd_box->boundary_complete() ); 01012 EntityHandle dum_ent = scd_box->start_element(); 01013 rval = mbImpl->list_entities( &dum_ent, 1 );MB_CHK_SET_ERR( rval, "Trouble listing first hex" ); 01014 01015 std::vector< EntityHandle > connect; 01016 rval = mbImpl->get_connectivity( &dum_ent, 1, connect );MB_CHK_SET_ERR( rval, "Trouble getting connectivity" ); 01017 01018 rval = mbImpl->list_entities( &connect[0], connect.size() );MB_CHK_SET_ERR( rval, "Trouble listing element connectivity" ); 01019 } 01020 01021 Range edges; 01022 mbImpl->get_adjacencies( faces, 1, true, edges, Interface::UNION ); 01023 01024 // Create COORDS tag for quads 01025 rval = create_quad_coordinate_tag();MB_CHK_SET_ERR( rval, "Trouble creating COORDS tag for quads" ); 01026 01027 return MB_SUCCESS; 01028 } 01029 01030 ErrorCode ScdNCHelper::read_variables( std::vector< std::string >& var_names, std::vector< int >& tstep_nums ) 01031 { 01032 std::vector< ReadNC::VarData > vdatas; 01033 std::vector< ReadNC::VarData > vsetdatas; 01034 01035 ErrorCode rval = read_variables_setup( var_names, tstep_nums, vdatas, vsetdatas );MB_CHK_SET_ERR( rval, "Trouble setting up to read variables" ); 01036 01037 if( !vsetdatas.empty() ) 01038 { 01039 rval = read_variables_to_set( vsetdatas, tstep_nums );MB_CHK_SET_ERR( rval, "Trouble reading variables to set" ); 01040 } 01041 01042 if( !vdatas.empty() ) 01043 { 01044 rval = read_scd_variables_to_nonset( vdatas, tstep_nums );MB_CHK_SET_ERR( rval, "Trouble reading variables to verts/edges/faces" ); 01045 } 01046 01047 return MB_SUCCESS; 01048 } 01049 01050 ErrorCode ScdNCHelper::read_scd_variables_to_nonset_allocate( std::vector< ReadNC::VarData >& vdatas, 01051 std::vector< int >& tstep_nums ) 01052 { 01053 Interface*& mbImpl = _readNC->mbImpl; 01054 std::vector< int >& dimLens = _readNC->dimLens; 01055 DebugOutput& dbgOut = _readNC->dbgOut; 01056 01057 Range* range = NULL; 01058 01059 // Get vertices 01060 Range verts; 01061 ErrorCode rval = mbImpl->get_entities_by_dimension( _fileSet, 0, verts );MB_CHK_SET_ERR( rval, "Trouble getting vertices in current file set" ); 01062 assert( "Should only have a single vertex subrange, since they were read in one shot" && verts.psize() == 1 ); 01063 01064 Range edges; 01065 rval = mbImpl->get_entities_by_dimension( _fileSet, 1, edges );MB_CHK_SET_ERR( rval, "Trouble getting edges in current file set" ); 01066 01067 // Get faces 01068 Range faces; 01069 rval = mbImpl->get_entities_by_dimension( _fileSet, 2, faces );MB_CHK_SET_ERR( rval, "Trouble getting faces in current file set" ); 01070 assert( "Should only have a single face subrange, since they were read in one shot" && faces.psize() == 1 ); 01071 01072 #ifdef MOAB_HAVE_MPI 01073 moab::Range faces_owned; 01074 bool& isParallel = _readNC->isParallel; 01075 if( isParallel ) 01076 { 01077 ParallelComm*& myPcomm = _readNC->myPcomm; 01078 rval = myPcomm->filter_pstatus( faces, PSTATUS_NOT_OWNED, PSTATUS_NOT, -1, &faces_owned );MB_CHK_SET_ERR( rval, "Trouble getting owned faces in current file set" ); 01079 } 01080 else 01081 faces_owned = faces; // Not running in parallel, but still with MPI 01082 #endif 01083 01084 for( unsigned int i = 0; i < vdatas.size(); i++ ) 01085 { 01086 // Support non-set variables with 4 dimensions like (time, lev, lat, lon) 01087 assert( 4 == vdatas[i].varDims.size() ); 01088 01089 // For a non-set variable, time should be the first dimension 01090 assert( tDim == vdatas[i].varDims[0] ); 01091 01092 // Set up readStarts and readCounts 01093 vdatas[i].readStarts.resize( 4 ); 01094 vdatas[i].readCounts.resize( 4 ); 01095 01096 // First: time 01097 vdatas[i].readStarts[0] = 0; // This value is timestep dependent, will be set later 01098 vdatas[i].readCounts[0] = 1; 01099 01100 // Next: lev 01101 vdatas[i].readStarts[1] = 0; 01102 vdatas[i].readCounts[1] = vdatas[i].numLev; 01103 01104 // Finally: lat (or slat) and lon (or slon) 01105 switch( vdatas[i].entLoc ) 01106 { 01107 case ReadNC::ENTLOCVERT: 01108 // Vertices 01109 vdatas[i].readStarts[2] = lDims[1]; 01110 vdatas[i].readCounts[2] = lDims[4] - lDims[1] + 1; 01111 vdatas[i].readStarts[3] = lDims[0]; 01112 vdatas[i].readCounts[3] = lDims[3] - lDims[0] + 1; 01113 range = &verts; 01114 break; 01115 case ReadNC::ENTLOCNSEDGE: 01116 case ReadNC::ENTLOCEWEDGE: 01117 case ReadNC::ENTLOCEDGE: 01118 // Not implemented yet, set a global error 01119 MB_SET_GLB_ERR( MB_NOT_IMPLEMENTED, "Reading edge data is not implemented yet" ); 01120 case ReadNC::ENTLOCFACE: 01121 // Faces 01122 vdatas[i].readStarts[2] = lCDims[1]; 01123 vdatas[i].readCounts[2] = lCDims[4] - lCDims[1] + 1; 01124 vdatas[i].readStarts[3] = lCDims[0]; 01125 vdatas[i].readCounts[3] = lCDims[3] - lCDims[0] + 1; 01126 #ifdef MOAB_HAVE_MPI 01127 range = &faces_owned; 01128 #else 01129 range = &faces; 01130 #endif 01131 break; 01132 default: 01133 MB_SET_ERR( MB_FAILURE, "Unexpected entity location type for variable " << vdatas[i].varName ); 01134 } 01135 01136 for( unsigned int t = 0; t < tstep_nums.size(); t++ ) 01137 { 01138 dbgOut.tprintf( 2, "Reading variable %s, time step %d\n", vdatas[i].varName.c_str(), tstep_nums[t] ); 01139 01140 if( tstep_nums[t] >= dimLens[tDim] ) 01141 { 01142 MB_SET_ERR( MB_INDEX_OUT_OF_RANGE, "Wrong value for timestep number " << tstep_nums[t] ); 01143 } 01144 01145 // Get the tag to read into 01146 if( !vdatas[i].varTags[t] ) 01147 { 01148 rval = get_tag_to_nonset( vdatas[i], tstep_nums[t], vdatas[i].varTags[t], vdatas[i].numLev );MB_CHK_SET_ERR( rval, "Trouble getting tag to non-set variable " << vdatas[i].varName ); 01149 } 01150 01151 // Get ptr to tag space 01152 void* data; 01153 int count; 01154 rval = mbImpl->tag_iterate( vdatas[i].varTags[t], range->begin(), range->end(), count, data );MB_CHK_SET_ERR( rval, "Failed to iterate tag for non-set variable " << vdatas[i].varName ); 01155 assert( (unsigned)count == range->size() ); 01156 vdatas[i].varDatas[t] = data; 01157 } 01158 01159 // Get variable size 01160 vdatas[i].sz = 1; 01161 for( std::size_t idx = 0; idx != vdatas[i].readCounts.size(); idx++ ) 01162 vdatas[i].sz *= vdatas[i].readCounts[idx]; 01163 } 01164 01165 return rval; 01166 } 01167 01168 ErrorCode ScdNCHelper::read_scd_variables_to_nonset( std::vector< ReadNC::VarData >& vdatas, 01169 std::vector< int >& tstep_nums ) 01170 { 01171 DebugOutput& dbgOut = _readNC->dbgOut; 01172 01173 ErrorCode rval = read_scd_variables_to_nonset_allocate( vdatas, tstep_nums );MB_CHK_SET_ERR( rval, "Trouble allocating space to read non-set variables" ); 01174 01175 // Finally, read into that space 01176 int success; 01177 for( unsigned int i = 0; i < vdatas.size(); i++ ) 01178 { 01179 std::size_t sz = vdatas[i].sz; 01180 01181 // A typical supported variable: float T(time, lev, lat, lon) 01182 // For tag values, need transpose (lev, lat, lon) to (lat, lon, lev) 01183 size_t ni = vdatas[i].readCounts[3]; // lon or slon 01184 size_t nj = vdatas[i].readCounts[2]; // lat or slat 01185 size_t nk = vdatas[i].readCounts[1]; // lev 01186 01187 for( unsigned int t = 0; t < tstep_nums.size(); t++ ) 01188 { 01189 // Tag data for this timestep 01190 void* data = vdatas[i].varDatas[t]; 01191 01192 // Set readStart for each timestep along time dimension 01193 vdatas[i].readStarts[0] = tstep_nums[t]; 01194 01195 switch( vdatas[i].varDataType ) 01196 { 01197 case NC_BYTE: 01198 case NC_CHAR: { 01199 std::vector< char > tmpchardata( sz ); 01200 success = NCFUNCAG( _vara_text )( _fileId, vdatas[i].varId, &vdatas[i].readStarts[0], 01201 &vdatas[i].readCounts[0], &tmpchardata[0] ); 01202 if( success ) 01203 MB_SET_ERR( MB_FAILURE, "Failed to read byte/char data for variable " << vdatas[i].varName ); 01204 if( vdatas[i].numLev > 1 ) 01205 // Transpose (lev, lat, lon) to (lat, lon, lev) 01206 kji_to_jik( ni, nj, nk, data, &tmpchardata[0] ); 01207 else 01208 { 01209 for( std::size_t idx = 0; idx != tmpchardata.size(); idx++ ) 01210 ( (char*)data )[idx] = tmpchardata[idx]; 01211 } 01212 break; 01213 } 01214 case NC_SHORT: 01215 case NC_INT: { 01216 std::vector< int > tmpintdata( sz ); 01217 success = NCFUNCAG( _vara_int )( _fileId, vdatas[i].varId, &vdatas[i].readStarts[0], 01218 &vdatas[i].readCounts[0], &tmpintdata[0] ); 01219 if( success ) 01220 MB_SET_ERR( MB_FAILURE, "Failed to read short/int data for variable " << vdatas[i].varName ); 01221 if( vdatas[i].numLev > 1 ) 01222 // Transpose (lev, lat, lon) to (lat, lon, lev) 01223 kji_to_jik( ni, nj, nk, data, &tmpintdata[0] ); 01224 else 01225 { 01226 for( std::size_t idx = 0; idx != tmpintdata.size(); idx++ ) 01227 ( (int*)data )[idx] = tmpintdata[idx]; 01228 } 01229 break; 01230 } 01231 case NC_FLOAT: 01232 case NC_DOUBLE: { 01233 std::vector< double > tmpdoubledata( sz ); 01234 success = NCFUNCAG( _vara_double )( _fileId, vdatas[i].varId, &vdatas[i].readStarts[0], 01235 &vdatas[i].readCounts[0], &tmpdoubledata[0] ); 01236 if( success ) 01237 MB_SET_ERR( MB_FAILURE, "Failed to read float/double data for variable " << vdatas[i].varName ); 01238 if( vdatas[i].numLev > 1 ) 01239 // Transpose (lev, lat, lon) to (lat, lon, lev) 01240 kji_to_jik( ni, nj, nk, data, &tmpdoubledata[0] ); 01241 else 01242 { 01243 for( std::size_t idx = 0; idx != tmpdoubledata.size(); idx++ ) 01244 ( (double*)data )[idx] = tmpdoubledata[idx]; 01245 } 01246 break; 01247 } 01248 default: 01249 MB_SET_ERR( MB_FAILURE, "Unexpected data type for variable " << vdatas[i].varName ); 01250 } 01251 } 01252 } 01253 01254 // Debug output, if requested 01255 if( 1 == dbgOut.get_verbosity() ) 01256 { 01257 dbgOut.printf( 1, "Read variables: %s", vdatas.begin()->varName.c_str() ); 01258 for( unsigned int i = 1; i < vdatas.size(); i++ ) 01259 dbgOut.printf( 1, ", %s ", vdatas[i].varName.c_str() ); 01260 dbgOut.tprintf( 1, "\n" ); 01261 } 01262 01263 return rval; 01264 } 01265 01266 ErrorCode ScdNCHelper::create_quad_coordinate_tag() 01267 { 01268 Interface*& mbImpl = _readNC->mbImpl; 01269 01270 Range ents; 01271 ErrorCode rval = mbImpl->get_entities_by_type( _fileSet, moab::MBQUAD, ents );MB_CHK_SET_ERR( rval, "Trouble getting quads" ); 01272 01273 std::size_t numOwnedEnts = 0; 01274 #ifdef MOAB_HAVE_MPI 01275 Range ents_owned; 01276 bool& isParallel = _readNC->isParallel; 01277 if( isParallel ) 01278 { 01279 ParallelComm*& myPcomm = _readNC->myPcomm; 01280 rval = myPcomm->filter_pstatus( ents, PSTATUS_NOT_OWNED, PSTATUS_NOT, -1, &ents_owned );MB_CHK_SET_ERR( rval, "Trouble getting owned quads" ); 01281 numOwnedEnts = ents_owned.size(); 01282 } 01283 else 01284 { 01285 numOwnedEnts = ents.size(); 01286 ents_owned = ents; 01287 } 01288 #else 01289 numOwnedEnts = ents.size(); 01290 #endif 01291 01292 if( numOwnedEnts == 0 ) return MB_SUCCESS; 01293 01294 assert( numOwnedEnts == ilCVals.size() * jlCVals.size() ); 01295 std::vector< double > coords( numOwnedEnts * 3 ); 01296 std::size_t pos = 0; 01297 for( std::size_t j = 0; j != jlCVals.size(); ++j ) 01298 { 01299 for( std::size_t i = 0; i != ilCVals.size(); ++i ) 01300 { 01301 pos = j * ilCVals.size() * 3 + i * 3; 01302 coords[pos] = ilCVals[i]; 01303 coords[pos + 1] = jlCVals[j]; 01304 coords[pos + 2] = 0.0; 01305 } 01306 } 01307 std::string tag_name = "COORDS"; 01308 Tag tagh = 0; 01309 rval = mbImpl->tag_get_handle( tag_name.c_str(), 3, MB_TYPE_DOUBLE, tagh, MB_TAG_DENSE | MB_TAG_CREAT );MB_CHK_SET_ERR( rval, "Trouble creating COORDS tag" ); 01310 01311 void* data; 01312 int count; 01313 #ifdef MOAB_HAVE_MPI 01314 rval = mbImpl->tag_iterate( tagh, ents_owned.begin(), ents_owned.end(), count, data );MB_CHK_SET_ERR( rval, "Failed to iterate COORDS tag on quads" ); 01315 #else 01316 rval = mbImpl->tag_iterate( tagh, ents.begin(), ents.end(), count, data );MB_CHK_SET_ERR( rval, "Failed to iterate COORDS tag on quads" ); 01317 #endif 01318 assert( count == (int)numOwnedEnts ); 01319 double* quad_data = (double*)data; 01320 std::copy( coords.begin(), coords.end(), quad_data ); 01321 01322 return MB_SUCCESS; 01323 } 01324 01325 ErrorCode UcdNCHelper::read_variables( std::vector< std::string >& var_names, std::vector< int >& tstep_nums ) 01326 { 01327 std::vector< ReadNC::VarData > vdatas; 01328 std::vector< ReadNC::VarData > vsetdatas; 01329 01330 ErrorCode rval = read_variables_setup( var_names, tstep_nums, vdatas, vsetdatas );MB_CHK_SET_ERR( rval, "Trouble setting up to read variables" ); 01331 01332 if( !vsetdatas.empty() ) 01333 { 01334 rval = read_variables_to_set( vsetdatas, tstep_nums );MB_CHK_SET_ERR( rval, "Trouble reading variables to set" ); 01335 } 01336 01337 if( !vdatas.empty() ) 01338 { 01339 #ifdef MOAB_HAVE_PNETCDF 01340 // With pnetcdf support, we will use async read 01341 rval = read_ucd_variables_to_nonset_async( vdatas, tstep_nums );MB_CHK_SET_ERR( rval, "Trouble reading variables to verts/edges/faces" ); 01342 #else 01343 // Without pnetcdf support, we will use old read 01344 rval = read_ucd_variables_to_nonset( vdatas, tstep_nums );MB_CHK_SET_ERR( rval, "Trouble reading variables to verts/edges/faces" ); 01345 #endif 01346 } 01347 01348 return MB_SUCCESS; 01349 } 01350 01351 static double tolerance = 1.e-12; 01352 // Used to put points in an STL tree-based container 01353 bool NCHelper::Node3D::operator<( const NCHelper::Node3D& other ) const 01354 { 01355 if( coords[0] <= other.coords[0] - tolerance ) 01356 return true; 01357 else if( coords[0] >= other.coords[0] + tolerance ) 01358 return false; 01359 if( coords[1] <= other.coords[1] - tolerance ) 01360 return true; 01361 else if( coords[1] >= other.coords[1] + tolerance ) 01362 return false; 01363 if( coords[2] <= other.coords[2] - tolerance ) 01364 return true; 01365 else if( coords[0] >= other.coords[0] + tolerance ) 01366 return false; 01367 01368 return false; 01369 } 01370 /*bool NCHelper::Node3D::operator == ( const NCHelper::Node3D& other ) const 01371 return ( !(*this < other) && ! ( other < *this) ) ;*/ 01372 } // namespace moab
