MOAB: Mesh Oriented datABase
(version 5.4.1)
#include <iostream>#include "moab/Interface.hpp"#include "TestUtil.hpp"#include "Internals.hpp"#include "moab/Core.hpp"#include "MBTagConventions.hpp"#include "InitCGMA.hpp"#include "GeometryQueryTool.hpp"
Include dependency graph for read_cgm_basic_test.cpp:Go to the source code of this file.
Defines | |
| #define | IS_BUILDING_MB |
| #define | CHKERR(A) |
Functions | |
| void | read_file (Interface *moab, const char *input_file) |
| void | read_cube_verts_test () |
| void | read_cube_curves_test () |
| void | read_cube_tris_test () |
| void | read_cube_surfs_test () |
| void | read_cube_vols_test () |
| void | read_cube_vertex_pos_test () |
| int | main (int, char **) |
Variables | |
| const std::string | input_cube = "unittest/io/cube.sat" |
| #define CHKERR | ( | A | ) |
do \ { \ if( MB_SUCCESS != ( A ) ) \ { \ std::cerr << "Failure (error code " << ( A ) << ") at " __FILE__ ":" << __LINE__ << std::endl; \ return A; \ } \ } while( false )
Definition at line 15 of file read_cgm_basic_test.cpp.
| #define IS_BUILDING_MB |
Definition at line 4 of file read_cgm_basic_test.cpp.
| int main | ( | int | , |
| char ** | |||
Definition at line 43 of file read_cgm_basic_test.cpp.
References read_cube_curves_test(), read_cube_surfs_test(), read_cube_tris_test(), read_cube_vertex_pos_test(), read_cube_verts_test(), read_cube_vols_test(), and RUN_TEST.
int result = 0;
result += RUN_TEST( read_cube_verts_test );
result += RUN_TEST( read_cube_curves_test );
result += RUN_TEST( read_cube_tris_test );
result += RUN_TEST( read_cube_surfs_test );
result += RUN_TEST( read_cube_vols_test );
result += RUN_TEST( read_cube_vertex_pos_test );
return result;
| void read_cube_curves_test | ( | ) |
Definition at line 101 of file read_cgm_basic_test.cpp.
References CHECK_EQUAL, CHECK_ERR, dim, ErrorCode, GEOM_DIMENSION_TAG_NAME, geom_tag, moab::Interface::get_number_entities_by_type_and_tag(), input_cube, mb, MB_TAG_CREAT, MB_TAG_DENSE, MB_TYPE_INTEGER, MBENTITYSET, read_file(), and moab::Interface::tag_get_handle().
Referenced by main().
ErrorCode rval;
// Open the test file
Core moab;
Interface* mb = &moab;
read_file( mb, input_cube.c_str() );
// Get the geometry tag handle from the mesh
Tag geom_tag;
rval = mb->tag_get_handle( GEOM_DIMENSION_TAG_NAME, 1, MB_TYPE_INTEGER, geom_tag,
moab::MB_TAG_DENSE | moab::MB_TAG_CREAT );CHECK_ERR( rval );
// Get the curves from the mesh
int dim = 1;
void* val[] = { &dim };
int number_of_curves;
rval = mb->get_number_entities_by_type_and_tag( 0, MBENTITYSET, &geom_tag, val, 1, number_of_curves );CHECK_ERR( rval );
// For a cube, there should be exactly 12 curves loaded from the file
CHECK_EQUAL( 12, number_of_curves );
| void read_cube_surfs_test | ( | ) |
Definition at line 123 of file read_cgm_basic_test.cpp.
ErrorCode rval;
Core moab;
// Get geometry tag for pulling curve data from the mesh
Tag geom_tag;
// Get the number of surface from the mesh geometry data
int dim = 2;
int number_of_surfs;
rval = mb->get_number_entities_by_type_and_tag( 0, MBENTITYSET, &geom_tag, val, 1, number_of_surfs );CHECK_ERR( rval );
// For a cube, there should be exactly 6 surfaces
CHECK_EQUAL( 6, number_of_surfs );
| void read_cube_tris_test | ( | ) |
Definition at line 83 of file read_cgm_basic_test.cpp.
References CHECK_EQUAL, CHECK_ERR, ErrorCode, moab::Interface::get_number_entities_by_type(), input_cube, mb, MBTRI, and read_file().
ErrorCode rval;
Core moab;
int number_of_tris;
rval = mb->get_number_entities_by_type( 0, MBTRI, number_of_tris );
std::cout << "Number of Triangles = " << number_of_tris << std::endl;CHECK_ERR( rval );
// For a cube, there should be exactly 2 triangles per face
CHECK_EQUAL( 12, number_of_tris );
| void read_cube_vertex_pos_test | ( | ) |
Definition at line 168 of file read_cgm_basic_test.cpp.
References CHECK_EQUAL, CHECK_ERR, ErrorCode, moab::Interface::get_coords(), moab::Interface::get_entities_by_type(), input_cube, mb, MBVERTEX, and read_file().
ErrorCode rval;
Core moab;
// Retrieve all vertex handles from the mesh
Range verts;
rval = mb->get_entities_by_type( 0, MBVERTEX, verts );CHECK_ERR( rval );
int number_of_verts = verts.size();
CHECK_EQUAL( 8, number_of_verts );
// Get the vertex coordinates
double x[8];
double y[8];
double z[8];
rval = mb->get_coords( verts, &x[0], &y[0], &z[0] );CHECK_ERR( rval );
// Check against known locations of the vertices
std::vector< double > x_ref;
std::vector< double > y_ref;
std::vector< double > z_ref;
// Vertex 1
x_ref.push_back( 5 );
y_ref.push_back( -5 );
z_ref.push_back( 5 );
// Vertex 2
y_ref.push_back( 5 );
// Vertex 3
x_ref.push_back( -5 );
// Vertex 4
// Vertex 5
z_ref.push_back( -5 );
// Vertex 6
// Vertex 7
// Vertex 8
std::cout << verts.size() << std::endl;
std::cout << x_ref.size() << std::endl;
for( unsigned int i = 0; i < verts.size(); i++ )
for( unsigned int j = 0; j < x_ref.size(); j++ )
if( x[i] == x_ref[j] && y[i] == y_ref[j] && z[i] == z_ref[j] )
x_ref.erase( x_ref.begin() + j );
y_ref.erase( y_ref.begin() + j );
z_ref.erase( z_ref.begin() + j );
// After looping through each vertex loaded from the mesh
// there should be no entities left in the reference vector
int leftovers = x_ref.size();
CHECK_EQUAL( 0, leftovers );
| void read_cube_verts_test | ( | ) |
Definition at line 67 of file read_cgm_basic_test.cpp.
References CHECK_EQUAL, CHECK_ERR, ErrorCode, moab::Interface::get_number_entities_by_type(), input_cube, mb, MBVERTEX, and read_file().
ErrorCode rval;
Core moab;
int number_of_vertices;
rval = mb->get_number_entities_by_type( 0, MBVERTEX, number_of_vertices );CHECK_ERR( rval );
// For a cube there should be exactly 8 vertices
CHECK_EQUAL( 8, number_of_vertices );
| void read_cube_vols_test | ( | ) |
Definition at line 145 of file read_cgm_basic_test.cpp.
ErrorCode rval;
Core moab;
Tag geom_tag;
// Get the number of volumes from the mesh geometry data
int dim = 3;
int number_of_vols;
rval = mb->get_number_entities_by_type_and_tag( 0, MBENTITYSET, &geom_tag, val, 1, number_of_vols );CHECK_ERR( rval );
CHECK_EQUAL( 1, number_of_vols );
Definition at line 57 of file read_cgm_basic_test.cpp.
InitCGMA::initialize_cgma();
GeometryQueryTool::instance()->delete_geometry();
ErrorCode rval = moab->load_file( input_file );CHECK_ERR( rval );
| const std::string input_cube = "unittest/io/cube.sat" |
Definition at line 28 of file read_cgm_basic_test.cpp.
Referenced by cube_edge_adjacencies_test(), cube_tri_curve_coincidence_test(), cube_tri_vertex_test(), cube_tris_connectivity_test(), cube_verts_connectivity_test(), read_cube_curves_test(), read_cube_surfs_test(), read_cube_tris_test(), read_cube_vertex_pos_test(), read_cube_verts_test(), read_cube_vols_test(), and test_cube_curve_facet().
