MOAB: Mesh Oriented datABase
(version 5.4.1)
00001 #include <iostream> 00002 #include "moab/Interface.hpp" 00003 #ifndef IS_BUILDING_MB 00004 #define IS_BUILDING_MB 00005 #endif 00006 #include "TestUtil.hpp" 00007 #include "Internals.hpp" 00008 #include "moab/Core.hpp" 00009 #include "MBTagConventions.hpp" 00010 #include "InitCGMA.hpp" 00011 #include "GeometryQueryTool.hpp" 00012 #include "moab/MeshTopoUtil.hpp" 00013 using namespace moab; 00014 00015 #define CHKERR( A ) \ 00016 do \ 00017 { \ 00018 if( MB_SUCCESS != ( A ) ) \ 00019 { \ 00020 std::cerr << "Failure (error code " << ( A ) << ") at " __FILE__ ":" << __LINE__ << std::endl; \ 00021 return A; \ 00022 } \ 00023 } while( false ) 00024 00025 #ifdef HAVE_OCC_STEP 00026 std::string input_cube = TestDir + "unittest/io/cube.stp"; 00027 #else 00028 std::string input_cube = TestDir + "unittest/io/cube.sat"; 00029 #endif 00030 00031 // Function used to load the test file 00032 void read_file( Interface* moab, const char* input_file ); 00033 00034 // List of tests in this file 00035 void cube_verts_connectivity_test(); 00036 void cube_tris_connectivity_test(); 00037 void cube_tri_curve_coincidence_test(); 00038 void cube_edge_adjacencies_test(); 00039 void cube_tri_vertex_test(); 00040 00041 // Other functions 00042 void match_tri_edges_w_curve( const Range& tri_edges, const Range& curves ); 00043 00044 int main( int /* argc */, char** /* argv */ ) 00045 { 00046 int result = 0; 00047 00048 result += RUN_TEST( cube_verts_connectivity_test ); 00049 result += RUN_TEST( cube_tris_connectivity_test ); 00050 result += RUN_TEST( cube_tri_curve_coincidence_test ); 00051 result += RUN_TEST( cube_tri_vertex_test ); 00052 00053 return result; 00054 } 00055 00056 void read_file( Interface* moab, const char* input_file ) 00057 { 00058 InitCGMA::initialize_cgma(); 00059 GeometryQueryTool::instance()->delete_geometry(); 00060 00061 ErrorCode rval = moab->load_file( input_file );CHECK_ERR( rval ); 00062 } 00063 00064 // Checks the adjacency of each vertex entity in a simple cube file load 00065 // to make sure it isn't adjacent to too many or too few triangles. 00066 void cube_verts_connectivity_test() 00067 { 00068 00069 ErrorCode rval; 00070 // Open the test file 00071 Core moab; 00072 Interface* mb = &moab; 00073 read_file( mb, input_cube.c_str() ); 00074 00075 // Get all vertex handles from the mesh 00076 Range verts; 00077 rval = mb->get_entities_by_type( 0, MBVERTEX, verts );CHECK_ERR( rval ); 00078 00079 // Check that each vertex connects to at least 4 and no more than 6 triangles 00080 for( Range::const_iterator i = verts.begin(); i != verts.end(); ++i ) 00081 { 00082 std::vector< EntityHandle > adj_tris; 00083 rval = mb->get_adjacencies( &( *i ), 1, 2, false, adj_tris );CHECK_ERR( rval ); 00084 00085 int adj_size = adj_tris.size(); 00086 CHECK( adj_size >= 4 && adj_size <= 6 ); 00087 } 00088 } 00089 00090 // Check that each triangle in the mesh is adjacent to 00091 // exactly three other triangles 00092 void cube_tris_connectivity_test() 00093 { 00094 ErrorCode rval; 00095 // Open the test file 00096 Core moab; 00097 Interface* mb = &moab; 00098 read_file( mb, input_cube.c_str() ); 00099 00100 // Get triangles from the mesh 00101 Range tris; 00102 rval = mb->get_entities_by_type( 0, MBTRI, tris );CHECK_ERR( rval ); 00103 00104 int expected_num_of_adj_tris = 3; 00105 00106 for( Range::const_iterator i = tris.begin() + 1; i != tris.end(); ++i ) 00107 { 00108 Range adj_tris; 00109 moab::MeshTopoUtil mu( mb ); 00110 // Use Triangle edges to get all adjacent triangles 00111 rval = mu.get_bridge_adjacencies( *i, 1, 2, adj_tris );CHECK_ERR( rval ); 00112 CHECK_EQUAL( expected_num_of_adj_tris, (int)adj_tris.size() ); 00113 00114 // Check that the entities we found from bridge_adjacencies 00115 // are triangles 00116 Range adj_tri_test = adj_tris.subset_by_type( MBTRI ); 00117 CHECK_EQUAL( (int)adj_tris.size(), (int)adj_tri_test.size() ); 00118 } 00119 } 00120 00121 // Takes triangle edges and makes sure they match the EntityHandles of 00122 // curves in the case of a cube mesh 00123 void cube_tri_curve_coincidence_test() 00124 { 00125 00126 ErrorCode rval; 00127 // Open the test file 00128 Core moab; 00129 Interface* mb = &moab; 00130 read_file( mb, input_cube.c_str() ); 00131 00132 // Get curves from the mesh 00133 Range curves; 00134 rval = mb->get_entities_by_type( 0, MBEDGE, curves );CHECK_ERR( rval ); 00135 curves.print(); 00136 00137 // Get triangles from the mesh 00138 Range tris; 00139 rval = mb->get_entities_by_type( 0, MBTRI, tris );CHECK_ERR( rval ); 00140 00141 for( Range::const_iterator i = tris.begin(); i != tris.end(); ++i ) 00142 { 00143 // Get the any curve edges that are a part of the triangle 00144 Range tri_edges; 00145 rval = mb->get_adjacencies( &( *i ), 1, 1, false, tri_edges );CHECK_ERR( rval ); 00146 // Check that we've retrieved two edges from get_adjacencies 00147 // For a this file (cube), each triangle should have two curve 00148 // edges 00149 int num_of_tri_edges = tri_edges.size(); 00150 CHECK_EQUAL( 2, num_of_tri_edges ); 00151 match_tri_edges_w_curve( tri_edges, curves );CHECK_ERR( rval ); 00152 } 00153 } 00154 00155 void match_tri_edges_w_curve( const Range& tri_edges, const Range& curves ) 00156 { 00157 int match_counter = 0; 00158 int num_of_tri_edges = tri_edges.size(); 00159 CHECK( num_of_tri_edges ); 00160 for( Range::const_iterator i = tri_edges.begin(); i != tri_edges.end(); ++i ) 00161 { 00162 for( Range::const_iterator j = curves.begin(); j != curves.end(); ++j ) 00163 { 00164 // If the edge handle matches a curve handle, increment the number 00165 // matches 00166 if( *i == *j ) match_counter++; 00167 } 00168 } 00169 // Make sure that each edge returned from triangle edges 00170 // has been matched to a curve 00171 CHECK_EQUAL( num_of_tri_edges, match_counter ); 00172 } 00173 00174 // Ensures that each triangle edge is adjacent to no more than 00175 // two triangles. 00176 void cube_edge_adjacencies_test() 00177 { 00178 ErrorCode rval; 00179 // Open the test file 00180 Core moab; 00181 Interface* mb = &moab; 00182 read_file( mb, input_cube.c_str() ); 00183 00184 // Get the curves 00185 Range curves; 00186 rval = mb->get_entities_by_type( 0, MBEDGE, curves );CHECK_ERR( rval ); 00187 00188 for( Range::const_iterator i = curves.begin(); i != curves.end(); ++i ) 00189 { 00190 // Get triangle adjacent to each edge 00191 Range adj_tris; 00192 rval = mb->get_adjacencies( &( *i ), 1, 2, false, adj_tris );CHECK_ERR( rval ); 00193 00194 int num_adj_tris = adj_tris.size(); 00195 // Ensure that no edge is adjacent to more than two triangles 00196 CHECK( num_adj_tris <= 2 ); 00197 } 00198 } 00199 00200 // Checks, for each triangle, that none of the verices are the same 00201 void cube_tri_vertex_test() 00202 { 00203 ErrorCode rval; 00204 // Open the test file 00205 Core moab; 00206 Interface* mb = &moab; 00207 read_file( mb, input_cube.c_str() ); 00208 00209 // Get all triangles 00210 Range tris; 00211 rval = mb->get_entities_by_type( 0, MBTRI, tris );CHECK_ERR( rval ); 00212 00213 for( Range::const_iterator i = tris.begin(); i != tris.end(); ++i ) 00214 { 00215 // Get all triangle vertices 00216 Range verts; 00217 rval = mb->get_connectivity( &( *i ), 1, verts );CHECK_ERR( rval ); 00218 // Make sure that each vertex making up 00219 // the triangle is different 00220 int number_of_verts = verts.size(); 00221 CHECK( 3 == number_of_verts ); 00222 CHECK( verts[0] != verts[1] ); 00223 CHECK( verts[1] != verts[2] ); 00224 CHECK( verts[2] != verts[0] ); 00225 } 00226 }
