MOAB: Mesh Oriented datABase
(version 5.4.1)
Include dependency graph for read_nc.cpp:Go to the source code of this file.
Functions | |
| void | test_read_eul_all () |
| void | test_read_eul_onevar () |
| void | test_read_eul_onetimestep () |
| void | test_read_eul_nomesh () |
| void | test_read_eul_novars () |
| void | test_read_fv_all () |
| void | test_read_fv_onevar () |
| void | test_read_fv_onetimestep () |
| void | test_read_fv_nomesh () |
| void | test_read_fv_novars () |
| void | test_read_domain () |
| void | test_read_scrip () |
| ErrorCode | get_options (std::string &opts) |
| int | main (int argc, char *argv[]) |
Variables | |
| std::string | example_eul = "unittest/io/eul3x48x96.t.3.nc" |
| std::string | example_fv = "unittest/io/fv3x46x72.t.3.nc" |
| std::string | example_domain = "unittest/io/domain.ocn.ne4np4_oQU240.160614.nc" |
| std::string | example_scrip = "unittest/io/ocean.QU.240km.scrip.151209.nc" |
| const int | levels = 3 |
| ErrorCode get_options | ( | std::string & | opts | ) |
| int main | ( | int | argc, |
| char * | argv[] | ||
Definition at line 42 of file read_nc.cpp.
References moab::fail(), RUN_TEST, test_read_domain(), test_read_eul_all(), test_read_eul_nomesh(), test_read_eul_novars(), test_read_eul_onetimestep(), test_read_eul_onevar(), test_read_fv_nomesh(), test_read_fv_novars(), test_read_fv_onetimestep(), test_read_fv_onevar(), and test_read_scrip().
int result = 0;
#ifdef MOAB_HAVE_MPI
int fail = MPI_Init( &argc, &argv );
if( fail ) return 1;
#else
argv[0] = argv[argc - argc]; // To remove the warnings in serial mode about unused variables
#endif
result += RUN_TEST( test_read_eul_all );
result += RUN_TEST( test_read_eul_onevar );
result += RUN_TEST( test_read_eul_onetimestep );
result += RUN_TEST( test_read_eul_nomesh );
result += RUN_TEST( test_read_eul_novars );
result += RUN_TEST( test_read_domain );
result += RUN_TEST( test_read_scrip );
// Exclude test_read_fv_all() since reading edge data is not implemented in MOAB yet
// result += RUN_TEST(test_read_fv_all);
result += RUN_TEST( test_read_fv_onevar );
result += RUN_TEST( test_read_fv_onetimestep );
result += RUN_TEST( test_read_fv_nomesh );
result += RUN_TEST( test_read_fv_novars );
// Before ghosting issues with ownership were fixed, this test failed on 4 processors
result += RUN_TEST( test_read_fv_ghosting );
#endif
fail = MPI_Finalize();
#endif
return result;
| void test_read_domain | ( | ) |
Definition at line 501 of file read_nc.cpp.
References CHECK_ERR, moab::Interface::create_meshset(), ErrorCode, example_domain, get_options(), moab::Interface::load_file(), and MESHSET_SET.
Referenced by main().
Core moab;
Interface& mb = moab;
// Need a set for nomesh to work right
EntityHandle set;
ErrorCode rval = mb.create_meshset( MESHSET_SET, set );CHECK_ERR( rval );
std::string orig, opts;
rval = get_options( orig );CHECK_ERR( rval );
opts = orig + std::string( ";VARIABLE=" );
rval = mb.load_file( example_domain.c_str(), &set, opts.c_str() );CHECK_ERR( rval );
| void test_read_eul_all | ( | ) |
Definition at line 80 of file read_nc.cpp.
References CHECK_ERR, ErrorCode, example_eul, get_options(), levels, moab::Interface::load_file(), mb, MB_TAG_VARLEN, MB_TYPE_DOUBLE, MB_TYPE_INTEGER, and moab::Interface::tag_get_handle().
Core moab;
std::string opts;
ErrorCode rval = get_options( opts );CHECK_ERR( rval );
rval = mb.load_file( example_eul.c_str(), NULL, opts.c_str() );CHECK_ERR( rval );
// Check for proper tags
Tag Ttag0, Ttag1, coordTag;
rval = mb.tag_get_handle( "T0", levels, MB_TYPE_DOUBLE, Ttag0 );CHECK_ERR( rval );
rval = mb.tag_get_handle( "T1", levels, MB_TYPE_DOUBLE, Ttag1 );CHECK_ERR( rval );
rval = mb.tag_get_handle( "COORDS", 3, MB_TYPE_DOUBLE, coordTag );CHECK_ERR( rval );
// Check for some tags with double underscore in the tag name
Tag tempTag;
rval = mb.tag_get_handle( "__lon_LOC_MINMAX", 2, MB_TYPE_INTEGER, tempTag );CHECK_ERR( rval );
rval = mb.tag_get_handle( "__lon_LOC_VALS", 0, MB_TYPE_DOUBLE, tempTag, MB_TAG_VARLEN );CHECK_ERR( rval );
rval = mb.tag_get_handle( "__lon_GLOBAL_MINMAX", 2, MB_TYPE_INTEGER, tempTag );CHECK_ERR( rval );
| void test_read_eul_nomesh | ( | ) |
Definition at line 208 of file read_nc.cpp.
References CHECK_EQUAL, CHECK_ERR, moab::Interface::create_meshset(), ErrorCode, example_eul, get_options(), levels, moab::Interface::load_file(), mb, MB_TAG_NOT_FOUND, MB_TYPE_DOUBLE, MESHSET_SET, and moab::Interface::tag_get_handle().
Core moab;
EntityHandle set;
opts = orig + std::string( ";VARIABLE=T;TIMESTEP=0" );
rval = mb.load_file( example_eul.c_str(), &set, opts.c_str() );CHECK_ERR( rval );
Tag Ttag0, Ttag1;
CHECK_EQUAL( rval, MB_TAG_NOT_FOUND );
// Now read 2nd timestep with nomesh option
opts = orig + std::string( ";VARIABLE=T;TIMESTEP=1;NOMESH" );
| void test_read_eul_novars | ( | ) |
Definition at line 238 of file read_nc.cpp.
Core moab;
EntityHandle set;
opts = orig + std::string( ";NOMESH;VARIABLE=" );
opts = orig + std::string( ";VARIABLE=;TIMESTEP=0" );
Tag Ttag0, Ttag1;
opts = orig + std::string( ";VARIABLE=T;TIMESTEP=0;NOMESH" );
| void test_read_eul_onetimestep | ( | ) |
Definition at line 190 of file read_nc.cpp.
References CHECK_EQUAL, CHECK_ERR, ErrorCode, example_eul, get_options(), levels, moab::Interface::load_file(), mb, MB_TAG_NOT_FOUND, MB_TYPE_DOUBLE, and moab::Interface::tag_get_handle().
Core moab;
std::string opts;
opts += std::string( ";VARIABLE=T;TIMESTEP=1" );
Tag Ttag0, Ttag1;
| void test_read_eul_onevar | ( | ) |
Definition at line 107 of file read_nc.cpp.
References CHECK_EQUAL, CHECK_ERR, CHECK_REAL_EQUAL, eps, ErrorCode, example_eul, moab::Interface::get_entities_by_type(), get_options(), moab::ParallelComm::get_pcomm(), levels, moab::Interface::load_file(), mb, MB_TYPE_DOUBLE, MBQUAD, moab::ParallelComm::proc_config(), moab::ProcConfig::proc_rank(), moab::ProcConfig::proc_size(), rank, moab::Range::size(), moab::Interface::tag_get_data(), and moab::Interface::tag_get_handle().
Core moab;
std::string opts;
opts += std::string( ";VARIABLE=T" );
Tag Ttag0, Ttag1;
// Check values of tag T0 (first level) at some strategically chosen places below
ParallelComm* pcomm = ParallelComm::get_pcomm( &mb, 0 );
int rank = pcomm->proc_config().proc_rank();
int procs = pcomm->proc_config().proc_size();
#else
int rank = 0;
int procs = 1;
#endif
const double eps = 0.0001;
double val[8 * levels];
if( 1 == procs )
Range global_quads;
rval = mb.get_entities_by_type( 0, MBQUAD, global_quads );CHECK_ERR( rval );
CHECK_EQUAL( (size_t)4608, global_quads.size() );
EntityHandle gloabl_quad_ents[] = { global_quads[0], global_quads[2255], global_quads[2304],
global_quads[4559], global_quads[48], global_quads[2303],
global_quads[2352], global_quads[4607] };
rval = mb.tag_get_data( Ttag0, &gloabl_quad_ents[0], 8, val );
CHECK_REAL_EQUAL( 252.8529, val[0 * levels], eps ); // First global quad
CHECK_REAL_EQUAL( 234.8390, val[1 * levels], eps ); // 2256th global quad
CHECK_REAL_EQUAL( 232.6458, val[2 * levels], eps ); // 2305th global quad
CHECK_REAL_EQUAL( 205.3905, val[3 * levels], eps ); // 4560th global quad
CHECK_REAL_EQUAL( 252.7116, val[4 * levels], eps ); // 49th global quad
CHECK_REAL_EQUAL( 232.6670, val[5 * levels], eps ); // 2304th global quad
CHECK_REAL_EQUAL( 234.6922, val[6 * levels], eps ); // 2353th global quad
CHECK_REAL_EQUAL( 200.6828, val[7 * levels], eps ); // Last global quad
else if( 2 == procs )
Range local_quads;
rval = mb.get_entities_by_type( 0, MBQUAD, local_quads );CHECK_ERR( rval );
CHECK_EQUAL( (size_t)2304, local_quads.size() );
EntityHandle local_quad_ents[] = { local_quads[0], local_quads[1151], local_quads[1152], local_quads[2303] };
rval = mb.tag_get_data( Ttag0, &local_quad_ents[0], 4, val );
if( 0 == rank )
eps ); // First local quad, first global quad
eps ); // Median local quad, 2256th global quad
eps ); // Median local quad, 2305th global quad
eps ); // Last local quad, 4560th global quad
else if( 1 == rank )
CHECK_REAL_EQUAL( 252.7116, val[0 * levels],
eps ); // First local quad, 49th global quad
CHECK_REAL_EQUAL( 232.6670, val[1 * levels],
eps ); // Median local quad, 2304th global quad
CHECK_REAL_EQUAL( 234.6922, val[2 * levels],
eps ); // Median local quad, 2353th global quad
CHECK_REAL_EQUAL( 200.6828, val[3 * levels],
eps ); // Last local quad, last global quad
| void test_read_fv_all | ( | ) |
Definition at line 277 of file read_nc.cpp.
References CHECK_ERR, ErrorCode, example_fv, get_options(), levels, moab::Interface::load_file(), mb, MB_TYPE_DOUBLE, and moab::Interface::tag_get_handle().
Core moab;
std::string opts;
rval = mb.load_file( example_fv.c_str(), NULL, opts.c_str() );CHECK_ERR( rval );
| void test_read_fv_nomesh | ( | ) |
Definition at line 405 of file read_nc.cpp.
References CHECK_EQUAL, CHECK_ERR, moab::Interface::create_meshset(), ErrorCode, example_fv, get_options(), levels, moab::Interface::load_file(), mb, MB_TAG_NOT_FOUND, MB_TYPE_DOUBLE, MESHSET_SET, and moab::Interface::tag_get_handle().
Core moab;
EntityHandle set;
rval = mb.load_file( example_fv.c_str(), &set, opts.c_str() );CHECK_ERR( rval );
Tag Ttag0, Ttag1;
| void test_read_fv_novars | ( | ) |
Definition at line 435 of file read_nc.cpp.
Core moab;
EntityHandle set;
Tag Ttag0, Ttag1;
| void test_read_fv_onetimestep | ( | ) |
Definition at line 379 of file read_nc.cpp.
References CHECK_EQUAL, CHECK_ERR, ErrorCode, example_fv, get_options(), levels, moab::Interface::load_file(), mb, MB_TAG_NOT_FOUND, MB_TAG_VARLEN, MB_TYPE_DOUBLE, MB_TYPE_INTEGER, and moab::Interface::tag_get_handle().
Core moab;
std::string opts;
Tag Ttag0, Ttag1;
Tag tempTag;
| void test_read_fv_onevar | ( | ) |
Definition at line 296 of file read_nc.cpp.
References CHECK_EQUAL, CHECK_ERR, CHECK_REAL_EQUAL, eps, ErrorCode, example_fv, moab::Interface::get_entities_by_type(), get_options(), moab::ParallelComm::get_pcomm(), levels, moab::Interface::load_file(), mb, MB_TYPE_DOUBLE, MBQUAD, moab::ParallelComm::proc_config(), moab::ProcConfig::proc_rank(), moab::ProcConfig::proc_size(), rank, moab::Range::size(), moab::Interface::tag_get_data(), and moab::Interface::tag_get_handle().
Core moab;
std::string opts;
Tag Ttag0, Ttag1;
#else
int rank = 0;
int procs = 1;
#endif
if( 1 == procs )
Range global_quads;
CHECK_EQUAL( (size_t)3312, global_quads.size() );
EntityHandle gloabl_quad_ents[] = { global_quads[0], global_quads[1619], global_quads[1656],
global_quads[3275], global_quads[36], global_quads[1655],
global_quads[1692], global_quads[3311] };
CHECK_REAL_EQUAL( 253.6048, val[0 * levels], eps ); // First global quad
CHECK_REAL_EQUAL( 232.2170, val[1 * levels], eps ); // 1620th global quad
CHECK_REAL_EQUAL( 232.7454, val[2 * levels], eps ); // 1657th global quad
CHECK_REAL_EQUAL( 210.2581, val[3 * levels], eps ); // 3276th global quad
CHECK_REAL_EQUAL( 253.6048, val[4 * levels], eps ); // 37th global quad
CHECK_REAL_EQUAL( 232.9553, val[5 * levels], eps ); // 1656th global quad
CHECK_REAL_EQUAL( 232.1704, val[6 * levels], eps ); // 1693th global quad
CHECK_REAL_EQUAL( 210.2581, val[7 * levels], eps ); // Last global quad
Range local_quads;
CHECK_EQUAL( (size_t)1656, local_quads.size() );
EntityHandle local_quad_ents[] = { local_quads[0], local_quads[827], local_quads[828], local_quads[1655] };
if( 0 == rank )
eps ); // Median local quad, 1620th global quad
eps ); // Median local quad, 1657th global quad
eps ); // Last local quad, 3276th global quad
eps ); // First local quad, 37th global quad
CHECK_REAL_EQUAL( 232.9553, val[1 * levels],
eps ); // Median local quad, 1656th global quad
CHECK_REAL_EQUAL( 232.1704, val[2 * levels],
eps ); // Median local quad, 1693th global quad
| void test_read_scrip | ( | ) |
Definition at line 517 of file read_nc.cpp.
References CHECK_ERR, moab::Interface::create_meshset(), ErrorCode, example_scrip, get_options(), moab::Interface::load_file(), and MESHSET_SET.
Core moab;
EntityHandle set;
rval = mb.load_file( example_scrip.c_str(), &set, opts.c_str() );CHECK_ERR( rval );
| std::string example_domain = "unittest/io/domain.ocn.ne4np4_oQU240.160614.nc" |
Definition at line 8 of file read_nc.cpp.
Referenced by test_read_domain().
| std::string example_eul = "unittest/io/eul3x48x96.t.3.nc" |
Definition at line 6 of file read_nc.cpp.
Referenced by test_eul_check_across_files(), test_eul_check_append(), test_eul_check_T(), test_eul_check_timestep(), test_eul_read_write_append(), test_eul_read_write_T(), test_eul_read_write_timestep(), test_read_eul_all(), test_read_eul_nomesh(), test_read_eul_novars(), test_read_eul_onetimestep(), and test_read_eul_onevar().
| std::string example_fv = "unittest/io/fv3x46x72.t.3.nc" |
Definition at line 7 of file read_nc.cpp.
Referenced by test_fv_check_T(), test_fv_read_write_T(), test_read_fv_all(), test_read_fv_nomesh(), test_read_fv_novars(), test_read_fv_onetimestep(), and test_read_fv_onevar().
| std::string example_scrip = "unittest/io/ocean.QU.240km.scrip.151209.nc" |
Definition at line 9 of file read_nc.cpp.
Referenced by test_read_scrip().
| const int levels = 3 |
Definition at line 40 of file read_nc.cpp.
Referenced by main(), test_eul_check_across_files(), test_eul_check_append(), test_eul_check_T(), test_eul_check_timestep(), test_fv_check_T(), test_gcrm_check_vars(), test_homme_check_T(), test_read_coord_vars(), test_read_eul_all(), test_read_eul_nomesh(), test_read_eul_novars(), test_read_eul_onetimestep(), test_read_eul_onevar(), test_read_fv_all(), test_read_fv_nomesh(), test_read_fv_novars(), test_read_fv_onetimestep(), and test_read_fv_onevar().
