mbfacet_test.cpp File Reference
test mbfacet, a unit test for the FBEngine class, which is providing iGeom like methods to a MOAB db More...
#include "moab/Core.hpp"
#include <iostream>
#include <fstream>
#include <set>
#include <algorithm>
#include <vector>
#include <iterator>
#include <iomanip>
#include <cassert>
#include <cstring>
#include <cmath>
#include "moab/FBEngine.hpp"
#include "moab/GeomTopoTool.hpp"
#include "TestUtil.hpp"
+ Include dependency graph for mbfacet_test.cpp:
Functions
ErrorCode root_set_test (FBEngine *pFacet)
ErrorCode gentityset_test (FBEngine *pFacet)
ErrorCode geometry_evaluation_test (FBEngine *pFacet)
ErrorCode normals_test (FBEngine *pFacet)
ErrorCode ray_test (FBEngine *pFacet)
ErrorCode split_test (Interface *mb, FBEngine *pFacet)
ErrorCode check_split (Interface *mb)
ErrorCode split_quads_test ()
void handle_error_code (ErrorCode rv, int &number_failed, int &number_successful)
int main (int argc, char *argv[])
Variables
std::string filename
std::string filename_out
std::string polygon_file_name
std::string quads_file
double min_dot = 0.8
bool keep_output
int number_tests_successful = 0
int number_tests_failed = 0
Detailed Description
This library is free software; you can redistribute it and/or modify it under the terms of the GNU Lesser General Public License as published by the Free Software Foundation; either version 2.1 of the License, or (at your option) any later version.
Definition in file mbfacet_test.cpp.
Function Documentation
Definition at line 527 of file mbfacet_test.cpp.
References moab::Interface::delete_mesh(), ErrorCode, filename_out, gentityset_test(), geometry_evaluation_test(), handle_error_code(), moab::FBEngine::Init(), moab::Interface::load_file(), MB_CHK_SET_ERR, MB_SUCCESS, normals_test(), number_tests_failed, number_tests_successful, ray_test(), and root_set_test().
Referenced by main().
    // check loading the file in an empty db
    // delete pFacet;// should clean up the FBEngine
    ErrorCode rval = mb->delete_mesh();MB_CHK_SET_ERR( rval, "ERROR : delete mesh failed!" );
    rval = mb->load_file( filename_out.c_str() );MB_CHK_SET_ERR( rval, "ERROR : can't load modified file!" );
    FBEngine* pFacet = new FBEngine( mb, NULL, true );  // smooth facetting, no OBB tree passed
    // repeat tests on modified file
    // should the init be part of constructor or not?
    // this is where the obb tree is constructed, and smooth faceting initialized, too.
    rval = pFacet->Init();MB_CHK_SET_ERR( rval, "failed to initialize smoothing" );
    std::cout << "root set test: ";
    rval = root_set_test( pFacet );
    handle_error_code( rval, number_tests_failed, number_tests_successful );
    std::cout << "\n";
    std::cout << "gentity set test: ";
    rval = gentityset_test( pFacet );
    std::cout << "\n";
    std::cout << "geometry evals test: ";
    rval = geometry_evaluation_test( pFacet );
    std::cout << "\n";
    std::cout << "normal evals test: ";
    rval = normals_test( pFacet );
    std::cout << "\n";
    std::cout << "ray test: ";
    rval = ray_test( pFacet );
    std::cout << "\n";
    delete pFacet;
    pFacet = NULL;
    if( number_tests_failed > 0 ) return MB_FAILURE;
    return MB_SUCCESS;
Definition at line 188 of file mbfacet_test.cpp.
References moab::FBEngine::addEntArrToSet(), moab::FBEngine::addEntSet(), moab::FBEngine::createEntSet(), ErrorCode, moab::FBEngine::getEntities(), moab::FBEngine::getNumEntSets(), moab::FBEngine::getNumOfType(), moab::FBEngine::getRootSet(), moab::FBEngine::gsubtract(), MB_CHK_SET_ERR, MB_SUCCESS, root_set, and moab::Range::size().
    int num_type = 4;
    EntityHandle ges_array[4];
    int number_array[4];
    // int num_all_gentities_super = 0;
    int ent_type = 0;  // iBase_VERTEX;
    EntityHandle root_set;
    ErrorCode rval = pFacet->getRootSet( &root_set );MB_CHK_SET_ERR( rval, "ERROR : getRootSet failed!" );
    // get the number of sets in the whole model
    int all_sets = 0;
    rval         = pFacet->getNumEntSets( root_set, 0, &all_sets );MB_CHK_SET_ERR( rval, "Problem getting the number of all gentity sets in whole model." );  // why do we
        // count all sets
    // add gentities to entitysets by type
    for( ; ent_type < num_type; ent_type++ )
        // initialize the entityset
        rval = pFacet->createEntSet( 1, &ges_array[ent_type] );  // 1 means isList, ordered
        MB_CHK_SET_ERR( rval, "Problem creating entityset." );
        // get entities by type in total "mesh"
        Range gentities;
        rval = pFacet->getEntities( root_set, ent_type, gentities );MB_CHK_SET_ERR( rval, "Failed to get gentities by type in gentityset_test." );
        // add gentities into gentity set
        rval = pFacet->addEntArrToSet( gentities, ges_array[ent_type] );MB_CHK_SET_ERR( rval, "Failed to add gentities in entityset_test." );
        // Check to make sure entity set really has correct number of entities in it
        rval = pFacet->getNumOfType( ges_array[ent_type], ent_type, &number_array[ent_type] );MB_CHK_SET_ERR( rval, "Failed to get number of gentities by type in entityset_test." );
        // compare the number of entities by type
        int num_type_gentity = gentities.size();
        if( number_array[ent_type] != num_type_gentity )
            std::cerr << "Number of gentities by type is not correct" << std::endl;
            return MB_FAILURE;
        // add to number of all entities in super set
        // num_all_gentities_super += num_type_gentity;
    // make a super set having all entitysets
    EntityHandle super_set;
    rval = pFacet->createEntSet( 1, &super_set );  // 1 is list
    MB_CHK_SET_ERR( rval, "Failed to create a super set in gentityset_test." );
    for( int i = 0; i < num_type; i++ )
        rval = pFacet->addEntSet( ges_array[i], super_set );MB_CHK_SET_ERR( rval, "Failed to create a super set in gentityset_test." );
    //----------TEST BOOLEAN OPERATIONS----------------//
    EntityHandle temp_ges1;
    rval = pFacet->createEntSet( 1, &temp_ges1 );MB_CHK_SET_ERR( rval, "Failed to create a super set in gentityset_test." );
    // Subtract
    // add all EDGEs and FACEs to temp_es1
    // get all EDGE entities
    Range gedges, gfaces, temp_gentities1;
    rval = pFacet->getEntities( ges_array[1], /* iBase_EDGE*/ 1, gedges );MB_CHK_SET_ERR( rval, "Failed to get gedge gentities in gentityset_test." );
    // add EDGEs to ges1
    rval = pFacet->addEntArrToSet( gedges, temp_ges1 );MB_CHK_SET_ERR( rval, "Failed to add gedge gentities in gentityset_test." );
    // get all FACE gentities
    rval = pFacet->getEntities( ges_array[2], /*iBase_FACE*/ 2, gfaces );MB_CHK_SET_ERR( rval, "Failed to get gface gentities in gentityset_test." );
    // add FACEs to es1
    rval = pFacet->addEntArrToSet( gfaces, temp_ges1 );MB_CHK_SET_ERR( rval, "Failed to add gface gentities in gentityset_test." );
    // subtract EDGEs
    rval = pFacet->gsubtract( temp_ges1, ges_array[1], temp_ges1 );MB_CHK_SET_ERR( rval, "Failed to subtract gentitysets in gentityset_test." );
    rval = pFacet->getEntities( temp_ges1, 2, temp_gentities1 );MB_CHK_SET_ERR( rval, "Failed to get gface gentities in gentityset_test." );
    if( gfaces.size() != temp_gentities1.size() )
        std::cerr << "Number of entitysets after subtraction not correct \
                  << std::endl;
        return MB_FAILURE;
    // check there's nothing but gfaces in temp_ges1
    int num_gents;
    rval = pFacet->getNumOfType( temp_ges1, 1, &num_gents );MB_CHK_SET_ERR( rval, "Failed to get dimensions of gentities in gentityset_test." );
    if( 0 != num_gents )
        std::cerr << "Subtraction failed to remove all edges" << std::endl;
        return MB_FAILURE;
    return MB_SUCCESS;
Definition at line 289 of file mbfacet_test.cpp.
References moab::Range::begin(), moab::Range::end(), ErrorCode, moab::FBEngine::getEntBoundBox(), moab::FBEngine::getEntClosestPt(), moab::FBEngine::getEntities(), moab::FBEngine::getEntUtoXYZ(), moab::FBEngine::getRootSet(), MB_CHK_SET_ERR, MB_SUCCESS, root_set, and moab::Range::size().
    int i;
    int top          = 0;  // iBase_VERTEX;
    int num_test_top = 4;  // iBase_ALL_TYPES;
    std::vector< std::vector< EntityHandle > > gentity_vectors( num_test_top );
    // fill the vectors of each topology entities
    for( i = top; i < num_test_top; i++ )
        Range gentities;
        rval = pFacet->getEntities( root_set, i, gentities );MB_CHK_SET_ERR( rval, "Failed to get gentities in eval tests." );
        gentity_vectors[i].resize( gentities.size() );
        std::copy( gentities.begin(), gentities.end(), gentity_vectors[i].begin() );
    // check geometries in both directions
    double min[3], max[3], on[3];
    double near[3] = { .0, .0, .0 };
    std::vector< EntityHandle >::iterator vit;
    /*for (i = iBase_REGION; i >= iBase_VERTEX; i--) {
     if (i != iBase_EDGE) {*/
    for( i = 3; i >= 0; i-- )
        if( i != 1 )
            for( vit = gentity_vectors[i].begin(); vit != gentity_vectors[i].end(); ++vit )
                EntityHandle this_gent = *vit;
                rval = pFacet->getEntBoundBox( this_gent, &min[0], &min[1], &min[2], &max[0], &max[1], &max[2] );MB_CHK_SET_ERR( rval, "Failed to get bounding box of entity." );
                for( int j = 0; j < 3; j++ )
                    near[j] = ( min[j] + max[j] ) / 2.;
                rval = pFacet->getEntClosestPt( this_gent, near[0], near[1], near[2], &on[0], &on[1], &on[2] );MB_CHK_SET_ERR( rval, "Failed to get closest point on entity." );
        else
            // for edges, provide a little better help
                // we know that the edge is parametric, with par between 0 and 1
                // some random parameter
                rval = pFacet->getEntUtoXYZ( this_gent, 0.33, near[0], near[1], near[2] );MB_CHK_SET_ERR( rval, "Failed to get a new point" );
                std::cout << " entity of type " << i << " position:\n  " << near[0] << " " << near[1] << " " << near[2]
                          << "\n";
                std::cout << "   close by:  " << on[0] << " " << on[1] << " " << on[2] << "\n";
    return MB_SUCCESS;
void handle_error_code ( ErrorCode  rv,
int &  number_failed,
int &  number_successful
Definition at line 55 of file mbfacet_test.cpp.
References MB_SUCCESS.
    if( rv == MB_SUCCESS )
        std::cout << "Success";
        number_successful++;
    else
        std::cout << "Failure";
        number_failed++;
int main ( int  argc,
char *  argv[]
Definition at line 69 of file mbfacet_test.cpp.
References check_split(), ErrorCode, filename, filename_out, gentityset_test(), geometry_evaluation_test(), handle_error_code(), moab::FBEngine::Init(), keep_output, moab::Interface::load_file(), mb, MB_CHK_SET_ERR, mbcore, min_dot, normals_test(), number_tests_failed, number_tests_successful, polygon_file_name, quads_file, ray_test(), root_set_test(), split_quads_test(), and split_test().
    filename          = TestDir + "unittest/PB.h5m";
    polygon_file_name = TestDir + "unittest/polyPB.txt";
    filename_out      = "PB_facet.h5m";
    quads_file        = TestDir + "unittest/quads.h5m";
    min_dot = 0.8;
    keep_output        = false;
    bool only_cropping = false;
    if( argc == 1 )
        std::cout << "Using default input files: " << filename << " " << polygon_file_name << " " << filename_out << " "
                  << min_dot << " " << quads_file << std::endl;
        std::cout << "    default output file: " << filename_out << " will be deleted \n";
    else if( argc == 5 )
        only_cropping     = true;
        filename          = argv[1];
        polygon_file_name = argv[2];
        filename_out      = argv[3];
        min_dot           = atof( argv[4] );
    else if( argc >= 6 )
        filename          = argv[1];
        quads_file        = argv[5];
        keep_output       = true;
        std::cout << "Using input files: " << filename << " " << polygon_file_name << " " << std::endl;
        std::cout << "    default output file: " << filename_out << " will be saved \n";
        std::cout << " min_dot: " << min_dot << " quads file:" << quads_file << "\n";
    else
        std::cerr << "Usage: " << argv[0] << " [geom_filename] [polygon_file] [output_file] [min_dot] [quads_file]"
                  << std::endl;
        return 1;
    Core mbcore;
    Interface* mb = &mbcore;
    ErrorCode rval = mb->load_file( filename.c_str() );MB_CHK_SET_ERR( rval, "failed to load input file" );
    if( !pFacet ) return 1;  // error
    std::cout << "\n";
    std::cout << "\n";
    std::cout << "\n";
    std::cout << "\n";
    std::cout << "\n";
    std::cout << "split with loop test ";
    rval = split_test( mb, pFacet );
    std::cout << "\n";
    // pFacet has been deleted in split_test(), so we should mark it as NULL
    // Setting pFacet (value parameter) to NULL in split_test() does not work
    pFacet = NULL;
    std::cout << " check split: ";
    rval = check_split( mb );
    std::cout << "\n";
    if( only_cropping ) return number_tests_failed;  // we do not remove the output file, either
    std::cout << " split quads test: ";
    rval = split_quads_test();
    std::cout << "\n";
    // when we are done, remove modified file if we want to
    if( !keep_output )
        remove( filename_out.c_str() );
Definition at line 355 of file mbfacet_test.cpp.
References moab::Range::begin(), moab::Range::end(), ErrorCode, moab::FBEngine::getEntBoundBox(), moab::FBEngine::getEntities(), moab::FBEngine::getEntNrmlXYZ(), moab::FBEngine::getRootSet(), MB_CHK_SET_ERR, MB_SUCCESS, root_set, and moab::Range::size().
    int i;
        Range gentities;
    // check adjacencies in both directions
    double min[3], max[3];
    double normal[3] = { .0, .0, .0 };
    for( i = 3 /*iBase_REGION*/; i > 1 /*iBase_EDGE*/; i-- )
            rval = pFacet->getEntNrmlXYZ( this_gent, ( max[0] + min[0] ) / 2, ( max[1] + min[1] ) / 2,
                                          ( max[2] + min[2] ) / 2, &normal[0], &normal[1], &normal[2] );MB_CHK_SET_ERR( rval, "Failed to get normal to the closest point." );
            std::cout << " entity of type " << i << " closest normal to center:\n  " << normal[0] << " " << normal[1]
                      << " " << normal[2] << "\n";
    return MB_SUCCESS;
ErrorCode ray_test ( FBEngine *  pFacet)
Definition at line 399 of file mbfacet_test.cpp.
References ErrorCode, moab::FBEngine::getEntBoundBox(), moab::FBEngine::getEntities(), moab::FBEngine::getPntRayIntsct(), moab::FBEngine::getRootSet(), moab::Interface::id_from_handle(), MB_CHK_SET_ERR, MB_SUCCESS, moab::FBEngine::moab_instance(), root_set, and moab::Interface::type_from_handle().
    int top = 2;  //  iBase_FACE;
    Range faces;
    rval = pFacet->getEntities( root_set, top, faces );MB_CHK_SET_ERR( rval, "Failed to get faces in ray_test." );
    // check only the first face
    EntityHandle first_face = faces[0];
    rval = pFacet->getEntBoundBox( first_face, &min[0], &min[1], &min[2], &max[0], &max[1], &max[2] );MB_CHK_SET_ERR( rval, "Failed to get bounding box of entity." );
    // assume that the ray shot from the bottom of the box (middle) is a pretty good candidate
    // in z direction
    double x = ( min[0] + max[0] ) / 2, y = ( min[1] + max[1] ) / 2, z = min[2];
    std::vector< EntityHandle > intersect_entity_handles;
    std::vector< double > intersect_coords;
    std::vector< double > param_coords;
    rval = pFacet->getPntRayIntsct( x, y, z,     // shot from
                                    0., 0., 1.,  // direction
                                    intersect_entity_handles,
                                    /*iBase_INTERLEAVED,*/
                                    intersect_coords, param_coords );MB_CHK_SET_ERR( rval, "Failed to find ray intersections points " );
    for( unsigned int i = 0; i < intersect_entity_handles.size(); i++ )
        std::cout << " entity of type " << pFacet->moab_instance()->type_from_handle( intersect_entity_handles[i] )
                  << " id from handle: " << pFacet->moab_instance()->id_from_handle( intersect_entity_handles[i] )
                  << "\n"
                  << intersect_coords[3 * i] << " " << intersect_coords[3 * i + 1] << " " << intersect_coords[3 * i + 2]
                  << "\n"
                  << " distance: " << param_coords[i] << "\n";
    return MB_SUCCESS;
Definition at line 180 of file mbfacet_test.cpp.
References ErrorCode, moab::FBEngine::getRootSet(), MB_CHK_SET_ERR, MB_SUCCESS, and root_set.
Referenced by check_split(), and main().
    return MB_SUCCESS;
Definition at line 575 of file mbfacet_test.cpp.
References moab::FBEngine::delete_smooth_tags(), ErrorCode, gentityset_test(), geometry_evaluation_test(), moab::FBEngine::getEntities(), moab::FBEngine::getRootSet(), handle_error_code(), moab::FBEngine::Init(), keep_output, moab::Interface::load_file(), mb, MB_CHK_SET_ERR, MB_SUCCESS, mbcore, normals_test(), number_tests_failed, number_tests_successful, quads_file, ray_test(), root_set, moab::Range::size(), and moab::Interface::write_file().
    Core mbcore;
    ErrorCode rval = mb->load_file( quads_file.c_str() );MB_CHK_SET_ERR( rval, "failed to load quads file" );
    Range faces;
    rval = pFacet->getEntities( root_set, top, faces );MB_CHK_SET_ERR( rval, "Failed to get faces in split_test." );
    if( faces.size() != 2 )
        std::cout << "num faces after loading quads model:" << faces.size() << "\n";
        return MB_FAILURE;  //
    // multiple tests
    std::cout << "\n";
    std::cout << "\n";
    std::cout << "\n";
    std::cout << "\n";
    // export split triangles model, after deleting the smooth tags
    pFacet->delete_smooth_tags();
    delete pFacet;
    pFacet               = NULL;
    std::string spl_file = "q.split.h5m";
    rval                 = mb->write_file( spl_file.c_str(), 0, 0, &root_set, 1 );MB_CHK_SET_ERR( rval, "can't write result file" );
    if( !keep_output )
        remove( spl_file.c_str() );
    return MB_SUCCESS;
ErrorCode split_test ( Interface *  mb,
FBEngine *  pFacet
Definition at line 449 of file mbfacet_test.cpp.
References moab::FBEngine::delete_smooth_tags(), moab::GeomTopoTool::duplicate_model(), ErrorCode, filename_out, moab::FBEngine::get_gtt(), moab::GeomTopoTool::get_root_model_set(), moab::FBEngine::getEntities(), moab::FBEngine::getRootSet(), MB_CHK_SET_ERR, min_dot, nr, polygon_file_name, root_set, moab::FBEngine::split_surface_with_direction(), and moab::Interface::write_file().
    Range faces;
    // use the polyPB.txt file to get the trimming polygon
    // read the file with the polygon user data
    std::ifstream datafile( polygon_file_name.c_str(), std::ifstream::in );
    if( !datafile )
        std::cout << "can't read file\n";
        return MB_FAILURE;
    char temp[100];
    double direction[3];  // normalized
    double gridSize;
    datafile.getline( temp, 100 );  // first line
    // get direction and mesh size along polygon segments, from file
    sscanf( temp, " %lf %lf %lf %lf ", direction, direction + 1, direction + 2, &gridSize );
    // NORMALIZE(direction);// just to be sure
    std::vector< double > xyz;
    while( !datafile.eof() )
        // int id = 0;
        double x, y, z;
        int nr = sscanf( temp, "%lf %lf %lf", &x, &y, &z );
        if( nr == 3 )
            xyz.push_back( x );
            xyz.push_back( y );
            xyz.push_back( z );
    int sizePolygon = (int)xyz.size() / 3;
    if( sizePolygon < 3 )
        std::cerr << " Not enough points in the polygon" << std::endl;
        return MB_FAILURE;
    EntityHandle newFace;  // first test is with closed surface
    rval = pFacet->split_surface_with_direction( first_face, xyz, direction, /*closed*/ 1, min_dot, newFace );MB_CHK_SET_ERR( rval, "ERROR : splitting surface failed!" );
    // save a new database
    // get a new gtt tool
    // duplicate -- extract a new geom topo tool
    GeomTopoTool* gtt       = pFacet->get_gtt();
    GeomTopoTool* duplicate = NULL;
    std::vector< EntityHandle > gents;
    gents.push_back( newFace );
    rval = gtt->duplicate_model( duplicate, &gents );MB_CHK_SET_ERR( rval, "Failed to extract surface." );
    EntityHandle newRootSet = duplicate->get_root_model_set();
    delete pFacet;
    pFacet = NULL;  // try not to write the obb tree
    rval   = mb->write_file( filename_out.c_str(), NULL, NULL, &newRootSet, 1 );MB_CHK_SET_ERR( rval, "ERROR : writing mesh failed!" );
    delete duplicate;
    return rval;
Variable Documentation
Definition at line 31 of file mbfacet_test.cpp.
Definition at line 32 of file mbfacet_test.cpp.
Referenced by check_split(), main(), split_test(), split_test_across(), and verify_split().
Definition at line 39 of file mbfacet_test.cpp.
Referenced by main(), and split_quads_test().
Definition at line 37 of file mbfacet_test.cpp.
Definition at line 41 of file mbfacet_test.cpp.
Definition at line 40 of file mbfacet_test.cpp.
Definition at line 33 of file mbfacet_test.cpp.
Definition at line 35 of file mbfacet_test.cpp.
