MOAB: Mesh Oriented datABase
(version 5.4.1)
00001 /** 00002 * This library is free software; you can redistribute it and/or 00003 * modify it under the terms of the GNU Lesser General Public 00004 * License as published by the Free Software Foundation; either 00005 * version 2.1 of the License, or (at your option) any later version. 00006 * 00007 */ 00008 /** 00009 * \file mbfacet_test.cpp 00010 * 00011 * \brief test mbfacet, a unit test for the FBEngine class, which is providing iGeom like methods to 00012 * a MOAB db 00013 * 00014 */ 00015 #include "moab/Core.hpp" 00016 #include <iostream> 00017 #include <fstream> 00018 #include <set> 00019 #include <algorithm> 00020 #include <vector> 00021 #include <iterator> 00022 #include <algorithm> 00023 #include <iomanip> 00024 #include <cassert> 00025 #include <cstring> 00026 #include <cmath> 00027 #include "moab/FBEngine.hpp" 00028 #include "moab/GeomTopoTool.hpp" 00029 #include "TestUtil.hpp" 00030 00031 std::string filename; 00032 std::string filename_out; 00033 std::string polygon_file_name; 00034 00035 std::string quads_file; 00036 00037 double min_dot = 0.8; // default 00038 00039 bool keep_output; 00040 int number_tests_successful = 0; 00041 int number_tests_failed = 0; 00042 00043 using namespace moab; 00044 00045 ErrorCode root_set_test( FBEngine* pFacet ); 00046 ErrorCode gentityset_test( FBEngine* pFacet ); 00047 ErrorCode geometry_evaluation_test( FBEngine* pFacet ); 00048 ErrorCode normals_test( FBEngine* pFacet ); 00049 ErrorCode ray_test( FBEngine* pFacet ); 00050 ErrorCode split_test( Interface* mb, FBEngine* pFacet ); 00051 ErrorCode check_split( Interface* mb ); 00052 00053 ErrorCode split_quads_test(); 00054 00055 void handle_error_code( ErrorCode rv, int& number_failed, int& number_successful ) 00056 { 00057 if( rv == MB_SUCCESS ) 00058 { 00059 std::cout << "Success"; 00060 number_successful++; 00061 } 00062 else 00063 { 00064 std::cout << "Failure"; 00065 number_failed++; 00066 } 00067 } 00068 00069 int main( int argc, char* argv[] ) 00070 { 00071 filename = TestDir + "unittest/PB.h5m"; 00072 polygon_file_name = TestDir + "unittest/polyPB.txt"; 00073 filename_out = "PB_facet.h5m"; 00074 quads_file = TestDir + "unittest/quads.h5m"; 00075 00076 min_dot = 0.8; 00077 00078 keep_output = false; 00079 bool only_cropping = false; 00080 if( argc == 1 ) 00081 { 00082 std::cout << "Using default input files: " << filename << " " << polygon_file_name << " " << filename_out << " " 00083 << min_dot << " " << quads_file << std::endl; 00084 std::cout << " default output file: " << filename_out << " will be deleted \n"; 00085 } 00086 else if( argc == 5 ) 00087 { 00088 only_cropping = true; 00089 filename = argv[1]; 00090 polygon_file_name = argv[2]; 00091 filename_out = argv[3]; 00092 min_dot = atof( argv[4] ); 00093 } 00094 else if( argc >= 6 ) 00095 { 00096 filename = argv[1]; 00097 polygon_file_name = argv[2]; 00098 filename_out = argv[3]; 00099 min_dot = atof( argv[4] ); 00100 quads_file = argv[5]; 00101 keep_output = true; 00102 std::cout << "Using input files: " << filename << " " << polygon_file_name << " " << std::endl; 00103 std::cout << " default output file: " << filename_out << " will be saved \n"; 00104 std::cout << " min_dot: " << min_dot << " quads file:" << quads_file << "\n"; 00105 } 00106 else 00107 { 00108 std::cerr << "Usage: " << argv[0] << " [geom_filename] [polygon_file] [output_file] [min_dot] [quads_file]" 00109 << std::endl; 00110 return 1; 00111 } 00112 00113 Core mbcore; 00114 Interface* mb = &mbcore; 00115 00116 ErrorCode rval = mb->load_file( filename.c_str() );MB_CHK_SET_ERR( rval, "failed to load input file" ); 00117 00118 FBEngine* pFacet = new FBEngine( mb, NULL, true ); // smooth facetting, no OBB tree passed 00119 00120 if( !pFacet ) return 1; // error 00121 00122 // should the init be part of constructor or not? 00123 // this is where the obb tree is constructed, and smooth faceting initialized, too. 00124 rval = pFacet->Init();MB_CHK_SET_ERR( rval, "failed to initialize smoothing" ); 00125 00126 std::cout << "root set test: "; 00127 rval = root_set_test( pFacet ); 00128 handle_error_code( rval, number_tests_failed, number_tests_successful ); 00129 std::cout << "\n"; 00130 00131 std::cout << "gentity set test: "; 00132 rval = gentityset_test( pFacet ); 00133 handle_error_code( rval, number_tests_failed, number_tests_successful ); 00134 std::cout << "\n"; 00135 00136 std::cout << "geometry evals test: "; 00137 rval = geometry_evaluation_test( pFacet ); 00138 handle_error_code( rval, number_tests_failed, number_tests_successful ); 00139 std::cout << "\n"; 00140 00141 std::cout << "normal evals test: "; 00142 rval = normals_test( pFacet ); 00143 handle_error_code( rval, number_tests_failed, number_tests_successful ); 00144 std::cout << "\n"; 00145 00146 std::cout << "ray test: "; 00147 rval = ray_test( pFacet ); 00148 handle_error_code( rval, number_tests_failed, number_tests_successful ); 00149 std::cout << "\n"; 00150 00151 std::cout << "split with loop test "; 00152 rval = split_test( mb, pFacet ); 00153 handle_error_code( rval, number_tests_failed, number_tests_successful ); 00154 std::cout << "\n"; 00155 00156 // pFacet has been deleted in split_test(), so we should mark it as NULL 00157 // Setting pFacet (value parameter) to NULL in split_test() does not work 00158 pFacet = NULL; 00159 00160 std::cout << " check split: "; 00161 rval = check_split( mb ); 00162 handle_error_code( rval, number_tests_failed, number_tests_successful ); 00163 std::cout << "\n"; 00164 00165 if( only_cropping ) return number_tests_failed; // we do not remove the output file, either 00166 00167 std::cout << " split quads test: "; 00168 rval = split_quads_test(); 00169 handle_error_code( rval, number_tests_failed, number_tests_successful ); 00170 std::cout << "\n"; 00171 00172 // when we are done, remove modified file if we want to 00173 if( !keep_output ) 00174 { 00175 remove( filename_out.c_str() ); 00176 } 00177 return number_tests_failed; 00178 } 00179 00180 ErrorCode root_set_test( FBEngine* pFacet ) 00181 { 00182 EntityHandle root_set; 00183 ErrorCode rval = pFacet->getRootSet( &root_set );MB_CHK_SET_ERR( rval, "ERROR : getRootSet failed!" ); 00184 00185 return MB_SUCCESS; 00186 } 00187 00188 ErrorCode gentityset_test( FBEngine* pFacet ) 00189 { 00190 int num_type = 4; 00191 EntityHandle ges_array[4]; 00192 int number_array[4]; 00193 // int num_all_gentities_super = 0; 00194 int ent_type = 0; // iBase_VERTEX; 00195 00196 EntityHandle root_set; 00197 ErrorCode rval = pFacet->getRootSet( &root_set );MB_CHK_SET_ERR( rval, "ERROR : getRootSet failed!" ); 00198 00199 // get the number of sets in the whole model 00200 int all_sets = 0; 00201 rval = pFacet->getNumEntSets( root_set, 0, &all_sets );MB_CHK_SET_ERR( rval, "Problem getting the number of all gentity sets in whole model." ); // why do we 00202 // count all sets 00203 00204 // add gentities to entitysets by type 00205 for( ; ent_type < num_type; ent_type++ ) 00206 { 00207 // initialize the entityset 00208 rval = pFacet->createEntSet( 1, &ges_array[ent_type] ); // 1 means isList, ordered 00209 MB_CHK_SET_ERR( rval, "Problem creating entityset." ); 00210 00211 // get entities by type in total "mesh" 00212 Range gentities; 00213 rval = pFacet->getEntities( root_set, ent_type, gentities );MB_CHK_SET_ERR( rval, "Failed to get gentities by type in gentityset_test." ); 00214 00215 // add gentities into gentity set 00216 rval = pFacet->addEntArrToSet( gentities, ges_array[ent_type] );MB_CHK_SET_ERR( rval, "Failed to add gentities in entityset_test." ); 00217 00218 // Check to make sure entity set really has correct number of entities in it 00219 rval = pFacet->getNumOfType( ges_array[ent_type], ent_type, &number_array[ent_type] );MB_CHK_SET_ERR( rval, "Failed to get number of gentities by type in entityset_test." ); 00220 00221 // compare the number of entities by type 00222 int num_type_gentity = gentities.size(); 00223 00224 if( number_array[ent_type] != num_type_gentity ) 00225 { 00226 std::cerr << "Number of gentities by type is not correct" << std::endl; 00227 return MB_FAILURE; 00228 } 00229 00230 // add to number of all entities in super set 00231 // num_all_gentities_super += num_type_gentity; 00232 } 00233 00234 // make a super set having all entitysets 00235 EntityHandle super_set; 00236 rval = pFacet->createEntSet( 1, &super_set ); // 1 is list 00237 MB_CHK_SET_ERR( rval, "Failed to create a super set in gentityset_test." ); 00238 00239 for( int i = 0; i < num_type; i++ ) 00240 { 00241 rval = pFacet->addEntSet( ges_array[i], super_set );MB_CHK_SET_ERR( rval, "Failed to create a super set in gentityset_test." ); 00242 } 00243 00244 //----------TEST BOOLEAN OPERATIONS----------------// 00245 00246 EntityHandle temp_ges1; 00247 rval = pFacet->createEntSet( 1, &temp_ges1 );MB_CHK_SET_ERR( rval, "Failed to create a super set in gentityset_test." ); 00248 00249 // Subtract 00250 // add all EDGEs and FACEs to temp_es1 00251 // get all EDGE entities 00252 Range gedges, gfaces, temp_gentities1; 00253 rval = pFacet->getEntities( ges_array[1], /* iBase_EDGE*/ 1, gedges );MB_CHK_SET_ERR( rval, "Failed to get gedge gentities in gentityset_test." ); 00254 00255 // add EDGEs to ges1 00256 rval = pFacet->addEntArrToSet( gedges, temp_ges1 );MB_CHK_SET_ERR( rval, "Failed to add gedge gentities in gentityset_test." ); 00257 00258 // get all FACE gentities 00259 rval = pFacet->getEntities( ges_array[2], /*iBase_FACE*/ 2, gfaces );MB_CHK_SET_ERR( rval, "Failed to get gface gentities in gentityset_test." ); 00260 00261 // add FACEs to es1 00262 rval = pFacet->addEntArrToSet( gfaces, temp_ges1 );MB_CHK_SET_ERR( rval, "Failed to add gface gentities in gentityset_test." ); 00263 00264 // subtract EDGEs 00265 rval = pFacet->gsubtract( temp_ges1, ges_array[1], temp_ges1 );MB_CHK_SET_ERR( rval, "Failed to subtract gentitysets in gentityset_test." ); 00266 00267 rval = pFacet->getEntities( temp_ges1, 2, temp_gentities1 );MB_CHK_SET_ERR( rval, "Failed to get gface gentities in gentityset_test." ); 00268 00269 if( gfaces.size() != temp_gentities1.size() ) 00270 { 00271 std::cerr << "Number of entitysets after subtraction not correct \ 00272 in gentityset_test." 00273 << std::endl; 00274 return MB_FAILURE; 00275 } 00276 00277 // check there's nothing but gfaces in temp_ges1 00278 int num_gents; 00279 rval = pFacet->getNumOfType( temp_ges1, 1, &num_gents );MB_CHK_SET_ERR( rval, "Failed to get dimensions of gentities in gentityset_test." ); 00280 if( 0 != num_gents ) 00281 { 00282 std::cerr << "Subtraction failed to remove all edges" << std::endl; 00283 return MB_FAILURE; 00284 } 00285 00286 return MB_SUCCESS; 00287 } 00288 00289 ErrorCode geometry_evaluation_test( FBEngine* pFacet ) 00290 { 00291 int i; 00292 EntityHandle root_set; 00293 ErrorCode rval = pFacet->getRootSet( &root_set );MB_CHK_SET_ERR( rval, "ERROR : getRootSet failed!" ); 00294 00295 int top = 0; // iBase_VERTEX; 00296 int num_test_top = 4; // iBase_ALL_TYPES; 00297 std::vector< std::vector< EntityHandle > > gentity_vectors( num_test_top ); 00298 00299 // fill the vectors of each topology entities 00300 // 00301 for( i = top; i < num_test_top; i++ ) 00302 { 00303 Range gentities; 00304 rval = pFacet->getEntities( root_set, i, gentities );MB_CHK_SET_ERR( rval, "Failed to get gentities in eval tests." ); 00305 00306 gentity_vectors[i].resize( gentities.size() ); 00307 std::copy( gentities.begin(), gentities.end(), gentity_vectors[i].begin() ); 00308 } 00309 00310 // check geometries in both directions 00311 double min[3], max[3], on[3]; 00312 double near[3] = { .0, .0, .0 }; 00313 std::vector< EntityHandle >::iterator vit; 00314 /*for (i = iBase_REGION; i >= iBase_VERTEX; i--) { 00315 if (i != iBase_EDGE) {*/ 00316 for( i = 3; i >= 0; i-- ) 00317 { 00318 if( i != 1 ) 00319 { 00320 for( vit = gentity_vectors[i].begin(); vit != gentity_vectors[i].end(); ++vit ) 00321 { 00322 EntityHandle this_gent = *vit; 00323 00324 rval = pFacet->getEntBoundBox( this_gent, &min[0], &min[1], &min[2], &max[0], &max[1], &max[2] );MB_CHK_SET_ERR( rval, "Failed to get bounding box of entity." ); 00325 00326 for( int j = 0; j < 3; j++ ) 00327 near[j] = ( min[j] + max[j] ) / 2.; 00328 rval = pFacet->getEntClosestPt( this_gent, near[0], near[1], near[2], &on[0], &on[1], &on[2] );MB_CHK_SET_ERR( rval, "Failed to get closest point on entity." ); 00329 } 00330 } 00331 else 00332 { 00333 // for edges, provide a little better help 00334 for( vit = gentity_vectors[i].begin(); vit != gentity_vectors[i].end(); ++vit ) 00335 { 00336 EntityHandle this_gent = *vit; 00337 00338 // we know that the edge is parametric, with par between 0 and 1 00339 // some random parameter 00340 rval = pFacet->getEntUtoXYZ( this_gent, 0.33, near[0], near[1], near[2] );MB_CHK_SET_ERR( rval, "Failed to get a new point" ); 00341 00342 std::cout << " entity of type " << i << " position:\n " << near[0] << " " << near[1] << " " << near[2] 00343 << "\n"; 00344 rval = pFacet->getEntClosestPt( this_gent, near[0], near[1], near[2], &on[0], &on[1], &on[2] );MB_CHK_SET_ERR( rval, "Failed to get closest point on entity." ); 00345 00346 std::cout << " close by: " << on[0] << " " << on[1] << " " << on[2] << "\n"; 00347 } 00348 } 00349 } 00350 00351 return MB_SUCCESS; 00352 } 00353 00354 // test normals evaluations on the surface only 00355 ErrorCode normals_test( FBEngine* pFacet ) 00356 { 00357 int i; 00358 EntityHandle root_set; 00359 ErrorCode rval = pFacet->getRootSet( &root_set );MB_CHK_SET_ERR( rval, "ERROR : getRootSet failed!" ); 00360 00361 int top = 0; // iBase_VERTEX; 00362 int num_test_top = 4; // iBase_ALL_TYPES; 00363 std::vector< std::vector< EntityHandle > > gentity_vectors( num_test_top ); 00364 00365 // fill the vectors of each topology entities 00366 // 00367 for( i = top; i < num_test_top; i++ ) 00368 { 00369 Range gentities; 00370 rval = pFacet->getEntities( root_set, i, gentities );MB_CHK_SET_ERR( rval, "Failed to get gentities in eval tests." ); 00371 00372 gentity_vectors[i].resize( gentities.size() ); 00373 std::copy( gentities.begin(), gentities.end(), gentity_vectors[i].begin() ); 00374 } 00375 00376 // check adjacencies in both directions 00377 double min[3], max[3]; 00378 double normal[3] = { .0, .0, .0 }; 00379 std::vector< EntityHandle >::iterator vit; 00380 for( i = 3 /*iBase_REGION*/; i > 1 /*iBase_EDGE*/; i-- ) 00381 { 00382 for( vit = gentity_vectors[i].begin(); vit != gentity_vectors[i].end(); ++vit ) 00383 { 00384 EntityHandle this_gent = *vit; 00385 rval = pFacet->getEntBoundBox( this_gent, &min[0], &min[1], &min[2], &max[0], &max[1], &max[2] );MB_CHK_SET_ERR( rval, "Failed to get bounding box of entity." ); 00386 00387 rval = pFacet->getEntNrmlXYZ( this_gent, ( max[0] + min[0] ) / 2, ( max[1] + min[1] ) / 2, 00388 ( max[2] + min[2] ) / 2, &normal[0], &normal[1], &normal[2] );MB_CHK_SET_ERR( rval, "Failed to get normal to the closest point." ); 00389 00390 std::cout << " entity of type " << i << " closest normal to center:\n " << normal[0] << " " << normal[1] 00391 << " " << normal[2] << "\n"; 00392 } 00393 } 00394 00395 return MB_SUCCESS; 00396 } 00397 00398 // ray test 00399 ErrorCode ray_test( FBEngine* pFacet ) 00400 { 00401 00402 EntityHandle root_set; 00403 ErrorCode rval = pFacet->getRootSet( &root_set );MB_CHK_SET_ERR( rval, "ERROR : getRootSet failed!" ); 00404 00405 int top = 2; // iBase_FACE; 00406 00407 Range faces; 00408 rval = pFacet->getEntities( root_set, top, faces );MB_CHK_SET_ERR( rval, "Failed to get faces in ray_test." ); 00409 00410 // check only the first face 00411 00412 // check adjacencies in both directions 00413 double min[3], max[3]; 00414 00415 EntityHandle first_face = faces[0]; 00416 00417 rval = pFacet->getEntBoundBox( first_face, &min[0], &min[1], &min[2], &max[0], &max[1], &max[2] );MB_CHK_SET_ERR( rval, "Failed to get bounding box of entity." ); 00418 00419 // assume that the ray shot from the bottom of the box (middle) is a pretty good candidate 00420 // in z direction 00421 double x = ( min[0] + max[0] ) / 2, y = ( min[1] + max[1] ) / 2, z = min[2]; 00422 std::vector< EntityHandle > intersect_entity_handles; 00423 std::vector< double > intersect_coords; 00424 std::vector< double > param_coords; 00425 00426 rval = pFacet->getPntRayIntsct( x, y, z, // shot from 00427 0., 0., 1., // direction 00428 intersect_entity_handles, 00429 /*iBase_INTERLEAVED,*/ 00430 intersect_coords, param_coords );MB_CHK_SET_ERR( rval, "Failed to find ray intersections points " ); 00431 00432 for( unsigned int i = 0; i < intersect_entity_handles.size(); i++ ) 00433 { 00434 00435 std::cout << " entity of type " << pFacet->moab_instance()->type_from_handle( intersect_entity_handles[i] ) 00436 << " id from handle: " << pFacet->moab_instance()->id_from_handle( intersect_entity_handles[i] ) 00437 << "\n" 00438 << intersect_coords[3 * i] << " " << intersect_coords[3 * i + 1] << " " << intersect_coords[3 * i + 2] 00439 << "\n" 00440 << " distance: " << param_coords[i] << "\n"; 00441 } 00442 00443 return MB_SUCCESS; 00444 } 00445 00446 // this test is for creating 2 surfaces given a polyline and a direction for piercing. 00447 // this test is for cropping a surface with a closed loop, no intersection 00448 // with initial boundary 00449 ErrorCode split_test( Interface* mb, FBEngine* pFacet ) 00450 { 00451 00452 EntityHandle root_set; 00453 ErrorCode rval = pFacet->getRootSet( &root_set );MB_CHK_SET_ERR( rval, "ERROR : getRootSet failed!" ); 00454 00455 int top = 2; // iBase_FACE; 00456 00457 Range faces; 00458 rval = pFacet->getEntities( root_set, top, faces );MB_CHK_SET_ERR( rval, "Failed to get faces in split_test." ); 00459 00460 // check only the first face 00461 00462 EntityHandle first_face = faces[0]; 00463 // use the polyPB.txt file to get the trimming polygon 00464 ; 00465 // read the file with the polygon user data 00466 00467 std::ifstream datafile( polygon_file_name.c_str(), std::ifstream::in ); 00468 if( !datafile ) 00469 { 00470 std::cout << "can't read file\n"; 00471 return MB_FAILURE; 00472 } 00473 // 00474 char temp[100]; 00475 double direction[3]; // normalized 00476 double gridSize; 00477 datafile.getline( temp, 100 ); // first line 00478 00479 // get direction and mesh size along polygon segments, from file 00480 sscanf( temp, " %lf %lf %lf %lf ", direction, direction + 1, direction + 2, &gridSize ); 00481 // NORMALIZE(direction);// just to be sure 00482 00483 std::vector< double > xyz; 00484 while( !datafile.eof() ) 00485 { 00486 datafile.getline( temp, 100 ); 00487 // int id = 0; 00488 double x, y, z; 00489 int nr = sscanf( temp, "%lf %lf %lf", &x, &y, &z ); 00490 if( nr == 3 ) 00491 { 00492 xyz.push_back( x ); 00493 xyz.push_back( y ); 00494 xyz.push_back( z ); 00495 } 00496 } 00497 int sizePolygon = (int)xyz.size() / 3; 00498 if( sizePolygon < 3 ) 00499 { 00500 std::cerr << " Not enough points in the polygon" << std::endl; 00501 return MB_FAILURE; 00502 } 00503 00504 EntityHandle newFace; // first test is with closed surface 00505 rval = pFacet->split_surface_with_direction( first_face, xyz, direction, /*closed*/ 1, min_dot, newFace );MB_CHK_SET_ERR( rval, "ERROR : splitting surface failed!" ); 00506 00507 // save a new database 00508 pFacet->delete_smooth_tags(); 00509 // get a new gtt tool 00510 00511 // duplicate -- extract a new geom topo tool 00512 GeomTopoTool* gtt = pFacet->get_gtt(); 00513 GeomTopoTool* duplicate = NULL; 00514 std::vector< EntityHandle > gents; 00515 gents.push_back( newFace ); 00516 rval = gtt->duplicate_model( duplicate, &gents );MB_CHK_SET_ERR( rval, "Failed to extract surface." ); 00517 00518 EntityHandle newRootSet = duplicate->get_root_model_set(); 00519 delete pFacet; 00520 pFacet = NULL; // try not to write the obb tree 00521 rval = mb->write_file( filename_out.c_str(), NULL, NULL, &newRootSet, 1 );MB_CHK_SET_ERR( rval, "ERROR : writing mesh failed!" ); 00522 00523 delete duplicate; 00524 return rval; 00525 } 00526 00527 ErrorCode check_split( Interface* mb ) 00528 { 00529 // check loading the file in an empty db 00530 // delete pFacet;// should clean up the FBEngine 00531 ErrorCode rval = mb->delete_mesh();MB_CHK_SET_ERR( rval, "ERROR : delete mesh failed!" ); 00532 00533 rval = mb->load_file( filename_out.c_str() );MB_CHK_SET_ERR( rval, "ERROR : can't load modified file!" ); 00534 00535 FBEngine* pFacet = new FBEngine( mb, NULL, true ); // smooth facetting, no OBB tree passed 00536 00537 // repeat tests on modified file 00538 00539 // should the init be part of constructor or not? 00540 // this is where the obb tree is constructed, and smooth faceting initialized, too. 00541 rval = pFacet->Init();MB_CHK_SET_ERR( rval, "failed to initialize smoothing" ); 00542 00543 std::cout << "root set test: "; 00544 rval = root_set_test( pFacet ); 00545 handle_error_code( rval, number_tests_failed, number_tests_successful ); 00546 std::cout << "\n"; 00547 00548 std::cout << "gentity set test: "; 00549 rval = gentityset_test( pFacet ); 00550 handle_error_code( rval, number_tests_failed, number_tests_successful ); 00551 std::cout << "\n"; 00552 00553 std::cout << "geometry evals test: "; 00554 rval = geometry_evaluation_test( pFacet ); 00555 handle_error_code( rval, number_tests_failed, number_tests_successful ); 00556 std::cout << "\n"; 00557 00558 std::cout << "normal evals test: "; 00559 rval = normals_test( pFacet ); 00560 handle_error_code( rval, number_tests_failed, number_tests_successful ); 00561 std::cout << "\n"; 00562 00563 std::cout << "ray test: "; 00564 rval = ray_test( pFacet ); 00565 handle_error_code( rval, number_tests_failed, number_tests_successful ); 00566 std::cout << "\n"; 00567 00568 delete pFacet; 00569 pFacet = NULL; 00570 if( number_tests_failed > 0 ) return MB_FAILURE; 00571 00572 return MB_SUCCESS; 00573 } 00574 00575 ErrorCode split_quads_test() 00576 { 00577 Core mbcore; 00578 Interface* mb = &mbcore; 00579 00580 ErrorCode rval = mb->load_file( quads_file.c_str() );MB_CHK_SET_ERR( rval, "failed to load quads file" ); 00581 00582 FBEngine* pFacet = new FBEngine( mb, NULL, true ); 00583 00584 rval = pFacet->Init();MB_CHK_SET_ERR( rval, "failed to initialize smoothing" ); 00585 00586 EntityHandle root_set; 00587 rval = pFacet->getRootSet( &root_set );MB_CHK_SET_ERR( rval, "ERROR : getRootSet failed!" ); 00588 int top = 2; // iBase_FACE; 00589 00590 Range faces; 00591 rval = pFacet->getEntities( root_set, top, faces );MB_CHK_SET_ERR( rval, "Failed to get faces in split_test." ); 00592 00593 if( faces.size() != 2 ) 00594 { 00595 std::cout << "num faces after loading quads model:" << faces.size() << "\n"; 00596 return MB_FAILURE; // 00597 } 00598 00599 // multiple tests 00600 std::cout << "gentity set test: "; 00601 rval = gentityset_test( pFacet ); 00602 handle_error_code( rval, number_tests_failed, number_tests_successful ); 00603 std::cout << "\n"; 00604 00605 std::cout << "geometry evals test: "; 00606 rval = geometry_evaluation_test( pFacet ); 00607 handle_error_code( rval, number_tests_failed, number_tests_successful ); 00608 std::cout << "\n"; 00609 00610 std::cout << "normal evals test: "; 00611 rval = normals_test( pFacet ); 00612 handle_error_code( rval, number_tests_failed, number_tests_successful ); 00613 std::cout << "\n"; 00614 00615 std::cout << "ray test: "; 00616 rval = ray_test( pFacet ); 00617 handle_error_code( rval, number_tests_failed, number_tests_successful ); 00618 std::cout << "\n"; 00619 00620 // export split triangles model, after deleting the smooth tags 00621 pFacet->delete_smooth_tags(); 00622 00623 delete pFacet; 00624 pFacet = NULL; 00625 std::string spl_file = "q.split.h5m"; 00626 rval = mb->write_file( spl_file.c_str(), 0, 0, &root_set, 1 );MB_CHK_SET_ERR( rval, "can't write result file" ); 00627 00628 if( !keep_output ) 00629 { 00630 remove( spl_file.c_str() ); 00631 } 00632 00633 if( number_tests_failed > 0 ) return MB_FAILURE; 00634 00635 return MB_SUCCESS; 00636 }
