MOAB: Mesh Oriented datABase
(version 5.4.1)
00001 /** 00002 * This library is free software; you can redistribute it and/or 00003 * modify it under the terms of the GNU Lesser General Public 00004 * License as published by the Free Software Foundation; either 00005 * version 2.1 of the License, or (at your option) any later version. 00006 * 00007 */ 00008 /* 00009 * crop_vol_test.cpp 00010 * \brief Driver to create a volume from 2 surfaces (top and bottom), a user defined polyline 00011 * (contour) and a direction 00012 * 00013 */ 00014 00015 #include "moab/Core.hpp" 00016 #include <iostream> 00017 #include <fstream> 00018 #include <cstring> 00019 #include "moab/FBEngine.hpp" 00020 #include "moab/GeomTopoTool.hpp" 00021 #include "TestUtil.hpp" 00022 00023 std::string filename_top; 00024 std::string filename_bot; 00025 std::string polygon_file_name; 00026 double min_dot = 0.8; 00027 std::string vol_file; 00028 00029 int number_tests_successful = 0; 00030 int number_tests_failed = 0; 00031 00032 using namespace moab; 00033 00034 ErrorCode volume_test( FBEngine* pFacet ); 00035 00036 void handle_error_code( ErrorCode rv, int& number_failed, int& number_successful ) 00037 { 00038 if( rv == MB_SUCCESS ) 00039 { 00040 std::cout << "Success"; 00041 number_successful++; 00042 } 00043 else 00044 { 00045 std::cout << "Failure"; 00046 number_failed++; 00047 } 00048 } 00049 00050 int main( int argc, char* argv[] ) 00051 { 00052 filename_bot = TestDir + "unittest/BedCrop2.h5m"; 00053 filename_top = TestDir + "unittest/SECrop2.h5m"; //"/polyPB.txt"; 00054 polygon_file_name = TestDir + "unittest/poly14.txt"; 00055 vol_file = "volIce.h5m"; // output 00056 00057 number_tests_successful = 0; 00058 bool remove_output = true; 00059 00060 if( argc == 1 ) 00061 { 00062 std::cout << "Using default input files: " << filename_bot << " " << filename_top << " " << polygon_file_name 00063 << " " << min_dot << " " << vol_file << std::endl; 00064 std::cout << " default output file: " << vol_file << " will be deleted \n"; 00065 } 00066 else if( argc == 6 ) 00067 { 00068 remove_output = false; 00069 filename_bot = argv[1]; 00070 filename_top = argv[2]; 00071 polygon_file_name = argv[3]; 00072 min_dot = atof( argv[4] ); 00073 vol_file = argv[5]; 00074 } 00075 else 00076 { 00077 std::cout << " wrong number of arguments\n"; 00078 return 1; // fail 00079 } 00080 Core mbcore; 00081 Interface* mb = &mbcore; 00082 00083 ErrorCode rval = mb->load_file( filename_bot.c_str() );MB_CHK_SET_ERR( rval, "failed to load bed file" ); 00084 00085 rval = mb->load_file( filename_top.c_str() ); // load the second face (we know we have one face in each file) 00086 MB_CHK_SET_ERR( rval, "failed to load top file" ); 00087 00088 FBEngine* pFacet = new FBEngine( mb, NULL, true ); // smooth facetting, no OBB tree passed 00089 00090 if( !pFacet ) return 1; // error 00091 00092 // should the init be part of constructor or not? 00093 // this is where the obb tree is constructed, and smooth faceting initialized, too. 00094 rval = pFacet->Init();MB_CHK_SET_ERR( rval, "failed to initialize smoothing" ); 00095 00096 std::cout << "volume creation test: "; 00097 rval = volume_test( pFacet ); 00098 handle_error_code( rval, number_tests_failed, number_tests_successful ); 00099 std::cout << "\n"; 00100 00101 if( remove_output ) 00102 { 00103 remove( vol_file.c_str() ); 00104 } 00105 return number_tests_failed; 00106 } 00107 00108 ErrorCode volume_test( FBEngine* pFacet ) 00109 { 00110 // there should be 2 faces in the model 00111 std::ifstream datafile( polygon_file_name.c_str(), std::ifstream::in ); 00112 if( !datafile ) 00113 { 00114 std::cout << "can't read file\n"; 00115 return MB_FAILURE; 00116 } 00117 // 00118 char temp[100]; 00119 double direction[3]; // normalized 00120 double gridSize; 00121 datafile.getline( temp, 100 ); // first line 00122 00123 // get direction and mesh size along polygon segments, from file 00124 sscanf( temp, " %lf %lf %lf %lf ", direction, direction + 1, direction + 2, &gridSize ); 00125 // NORMALIZE(direction);// just to be sure 00126 00127 std::vector< double > xyz; 00128 while( !datafile.eof() ) 00129 { 00130 datafile.getline( temp, 100 ); 00131 // int id = 0; 00132 double x, y, z; 00133 int nr = sscanf( temp, "%lf %lf %lf", &x, &y, &z ); 00134 if( nr == 3 ) 00135 { 00136 xyz.push_back( x ); 00137 xyz.push_back( y ); 00138 xyz.push_back( z ); 00139 } 00140 } 00141 int sizePolygon = (int)xyz.size() / 3; 00142 if( sizePolygon < 3 ) 00143 { 00144 std::cerr << " Not enough points in the polygon" << std::endl; 00145 return MB_FAILURE; 00146 } 00147 EntityHandle root_set; 00148 ErrorCode rval = pFacet->getRootSet( &root_set );MB_CHK_SET_ERR( rval, "ERROR : getRootSet failed!" ); 00149 00150 int top = 2; // iBase_FACE; 00151 00152 Range faces; 00153 rval = pFacet->getEntities( root_set, top, faces );MB_CHK_SET_ERR( rval, "Failed to get faces in volume_test." ); 00154 00155 if( 2 != faces.size() ) 00156 { 00157 std::cerr << "expected 2 faces, top and bottom\n"; 00158 return MB_FAILURE; 00159 } 00160 EntityHandle newFace1; // first test is with closed surface 00161 rval = pFacet->split_surface_with_direction( faces[0], xyz, direction, /*closed*/ 1, min_dot, newFace1 );MB_CHK_SET_ERR( rval, "Failed to crop first face." ); 00162 00163 EntityHandle newFace2; // first test is with closed surface 00164 rval = pFacet->split_surface_with_direction( faces[1], xyz, direction, /*closed*/ 1, min_dot, newFace2 );MB_CHK_SET_ERR( rval, "Failed to crop second face." ); 00165 00166 // here we make the assumption that the edges, vertices are matching fine... 00167 EntityHandle volume; 00168 rval = pFacet->create_volume_with_direction( newFace1, newFace2, direction, volume );MB_CHK_SET_ERR( rval, "Failed to create volume." ); 00169 00170 Interface* mb = pFacet->moab_instance(); 00171 pFacet->delete_smooth_tags(); 00172 // duplicate -- extract a new geom topo tool 00173 GeomTopoTool* gtt = pFacet->get_gtt(); 00174 GeomTopoTool* duplicate = NULL; 00175 std::vector< EntityHandle > gents; 00176 gents.push_back( volume ); 00177 rval = gtt->duplicate_model( duplicate, &gents );MB_CHK_SET_ERR( rval, "Failed to extract volume." ); 00178 EntityHandle newRootSet = duplicate->get_root_model_set(); 00179 delete pFacet; 00180 pFacet = NULL; // try not to write the obb tree 00181 delete duplicate; 00182 rval = mb->write_file( vol_file.c_str(), NULL, NULL, &newRootSet, 1 ); 00183 00184 return rval; 00185 }
