MOAB: Mesh Oriented datABase
(version 5.4.1)
#include <iostream>#include <cstdlib>#include <cstdio>#include "moab/Core.hpp"#include "moab/Interface.hpp"#include "moab/Range.hpp"#include "moab/ProgOptions.hpp"#include "moab/CartVect.hpp"#include "moab/IntxMesh/IntxUtils.hpp"
Include dependency graph for ExtractClose.cpp:Go to the source code of this file.
Functions | |
| int | main (int argc, char **argv) |
| int main | ( | int | argc, |
| char ** | argv | ||
Definition at line 30 of file ExtractClose.cpp.
References moab::Core::add_entities(), ProgOptions::addOpt(), moab::Range::begin(), center(), moab::Core::create_meshset(), moab::Range::end(), ErrorCode, moab::Core::get_coords(), moab::Core::get_entities_by_dimension(), moab::Range::insert(), moab::IntxUtils::SphereCoords::lat, length(), moab::Core::load_file(), moab::IntxUtils::SphereCoords::lon, mb, MB_CHK_ERR, MB_CHK_SET_ERR, MESHSET_SET, MPI_COMM_WORLD, numProcesses, ProgOptions::parseCommandLine(), moab::IntxUtils::SphereCoords::R, rank, readopts(), moab::Range::size(), moab::IntxUtils::spherical_to_cart(), test_file_name, and moab::Core::write_file().
ProgOptions opts;
// vertex 25 in filt out (-0.784768, 0.594952, -0.173698)
double x = -0.784768, y = 0.594952, z = -0.173698;
double lat = 28.6551, lon = 61.0204; // from Charlie Zender's page
// https://acme-climate.atlassian.net/wiki/spaces/ED/pages/1347092547/Assessing+and+Addressing+Regridding+Weights+in+Map-Files
string inputFile = test_file_name;
opts.addOpt< string >( "inFile,i", "Specify the input file name string ", &inputFile );
string outFile = "out.h5m";
opts.addOpt< string >( "outFile,o", "Specify the output file name string ", &outFile );
opts.addOpt< double >( string( "xpos,x" ), string( "x position" ), &x );
opts.addOpt< double >( string( "ypos,y" ), string( "y position" ), &y );
opts.addOpt< double >( string( "zpos,z" ), string( "z position" ), &z );
opts.addOpt< double >( string( "latitude,t" ), string( "north latitude in degrees" ), &lat );
opts.addOpt< double >( string( "longitude,w" ), string( "east longitude in degrees" ), &lon );
bool spherical = false;
opts.addOpt< void >( "spherical,s", "use spherical coords input (default false) ", &spherical );
double distance = 0.01;
opts.addOpt< double >( string( "distance,d" ), string( "distance " ), &distance );
opts.parseCommandLine( argc, argv );
int rank = 0;
int numProcesses = 1;
std::string readopts;
#ifdef MOAB_HAVE_MPI
if( MPI_Init( &argc, &argv ) ) return 1;
MPI_Comm_rank( MPI_COMM_WORLD, &rank );
MPI_Comm_size( MPI_COMM_WORLD, &numProcesses );
readopts = string( "PARALLEL=READ_PART;PARTITION=PARALLEL_PARTITION" ); // we do not have to
// resolve shared ents
#endif
// Instantiate
Core mb;
// Load the file into a new file set
EntityHandle fileSet;
ErrorCode rval = mb.create_meshset( MESHSET_SET, fileSet );MB_CHK_SET_ERR( rval, "Error creating file set" );
rval = mb.load_file( inputFile.c_str(), &fileSet, readopts.c_str() );MB_CHK_SET_ERR( rval, "Error loading file" );
if( !rank )
cout << " reading file " << inputFile << " on " << numProcesses << " task";
if( numProcesses > 1 ) cout << "s";
cout << "\n";
// Get all 2d elements in the file set
Range elems;
rval = mb.get_entities_by_dimension( fileSet, 2, elems );MB_CHK_SET_ERR( rval, "Error getting 2d elements" );
// create a meshset with close elements
EntityHandle outSet;
// create meshset
rval = mb.create_meshset( MESHSET_SET, outSet );MB_CHK_ERR( rval );
// double sphere radius is 1
CartVect point( x, y, z );
if( spherical )
std::cout << " use spherical coordinates on the sphere of radius 1.\n";
IntxUtils::SphereCoords pos;
pos.R = 1; // always on the
pos.lat = lat * M_PI / 180; // defined in math.h
pos.lon = lon * M_PI / 180;
point = IntxUtils::spherical_to_cart( pos );
Range closeByCells;
for( Range::iterator it = elems.begin(); it != elems.end(); it++ )
EntityHandle cell = *it;
CartVect center;
rval = mb.get_coords( &cell, 1, &( center[0] ) );MB_CHK_SET_ERR( rval, "Can't get cell center coords" );
double dist = ( center - point ).length();
if( dist <= distance )
closeByCells.insert( cell );
rval = mb.add_entities( outSet, closeByCells );MB_CHK_SET_ERR( rval, "Can't add to entity set" );
int numCells = (int)closeByCells.size();
// Reduce all of the local sums into the global sum
int globalCells;
MPI_Reduce( &numCells, &globalCells, 1, MPI_INT, MPI_SUM, 0, MPI_COMM_WORLD );
numCells = globalCells;
#endif
if( numCells == 0 )
if( !rank )
std::cout << " no close cells to the point " << point << " at distance less than " << distance << "\n";
else
if( !rank )
std::cout << " write file " << outFile << " with cells closer than " << distance << " from " << point
<< "\n";
string writeOpts;
if( numProcesses > 1 ) writeOpts = string( "PARALLEL=WRITE_PART;" );
rval = mb.write_file( outFile.c_str(), 0, writeOpts.c_str(), &outSet, 1 );MB_CHK_SET_ERR( rval, "Can't write file" );
if( MPI_Finalize() ) return 1;
#endif
return 0;
