MOAB: Mesh Oriented datABase
(version 5.4.1)
00001 #include "moab/Core.hpp" 00002 #include "moab/Range.hpp" 00003 #include "moab/CN.hpp" 00004 00005 #include <iostream> 00006 #include <iomanip> 00007 #include <sstream> 00008 #include <string> 00009 #include <cstdio> 00010 #include <cstdlib> 00011 00012 #ifndef _WIN32 00013 #include <sys/times.h> 00014 #include <sys/resource.h> 00015 #include <unistd.h> 00016 #endif 00017 00018 static void usage( const char* argv0, bool help = false ) 00019 { 00020 std::ostream& str = help ? std::cout : std::cerr; 00021 str << "Usage: " << argv0 << " [-H|-b|-k|-m] <filename> [<filename> ...]" << std::endl 00022 << " " << argv0 << " [-H|-b|-k|-m] -T" << std::endl; 00023 if( !help ) 00024 { 00025 str << " " << argv0 << " -h" << std::endl; 00026 std::exit( 1 ); 00027 } 00028 00029 std::cerr << " -H : human readable units" << std::endl 00030 << " -b : bytes" << std::endl 00031 << " -k : kilobytes (1 kB == 1024 bytes)" << std::endl 00032 << " -m : megabytes (1 MB == 1024 kB)" << std::endl 00033 << " -g : gigabytes (1 GB == 1024 MB)" << std::endl 00034 << " -T : test mode" << std::endl 00035 << std::endl; 00036 std::exit( 0 ); 00037 } 00038 00039 enum Units 00040 { 00041 HUMAN, 00042 BYTES, 00043 KILOBYTES, 00044 MEGABYTES, 00045 GIGABYTES 00046 }; 00047 Units UNITS = HUMAN; 00048 00049 // The core functionality of this example 00050 static void print_memory_stats( moab::Interface& mb, 00051 bool per_type = true, 00052 bool per_tag = true, 00053 bool totals = true, 00054 bool sysstats = true ); 00055 00056 // Generate a series of meshes for testing 00057 static void do_test_mode(); 00058 00059 // main routine: read any specified files and call print_memory_stats 00060 int main( int argc, char* argv[] ) 00061 { 00062 moab::ErrorCode rval; 00063 bool no_more_flags = false; 00064 bool test_mode = false; 00065 std::vector< int > input_file_list; 00066 00067 // load each file specified on command line 00068 for( int i = 1; i < argc; ++i ) 00069 { 00070 if( !no_more_flags && argv[i][0] == '-' ) 00071 { 00072 if( !strcmp( argv[i], "-H" ) ) 00073 UNITS = HUMAN; 00074 else if( !strcmp( argv[i], "-b" ) ) 00075 UNITS = BYTES; 00076 else if( !strcmp( argv[i], "-k" ) ) 00077 UNITS = KILOBYTES; 00078 else if( !strcmp( argv[i], "-m" ) ) 00079 UNITS = MEGABYTES; 00080 else if( !strcmp( argv[i], "-g" ) ) 00081 UNITS = GIGABYTES; 00082 else if( !strcmp( argv[i], "-T" ) ) 00083 test_mode = true; 00084 else if( !strcmp( argv[i], "-h" ) ) 00085 usage( argv[0], true ); 00086 else if( !strcmp( argv[i], "--" ) ) 00087 no_more_flags = true; 00088 else 00089 { 00090 std::cerr << argv[0] << ": Invalid flag: \"" << argv[i] << "\"." << std::endl << std::endl; 00091 usage( argv[0] ); 00092 } 00093 } 00094 else 00095 { 00096 input_file_list.push_back( i ); 00097 } 00098 } 00099 00100 if( test_mode ) 00101 { 00102 do_test_mode(); 00103 if( input_file_list.empty() ) return 0; 00104 } 00105 00106 moab::Core mbcore; 00107 moab::Interface& mb = mbcore; 00108 for( std::vector< int >::iterator it = input_file_list.begin(); it != input_file_list.end(); ++it ) 00109 { 00110 rval = mb.load_file( argv[*it] ); 00111 00112 // if file load failed, print some info and exit 00113 if( moab::MB_SUCCESS != rval ) 00114 { 00115 std::string message; 00116 mb.get_last_error( message ); 00117 std::cerr << mb.get_error_string( rval ) << ": " << message << std::endl 00118 << argv[*it] << ": Failed to read file." << std::endl; 00119 return 1; 00120 } 00121 00122 std::cout << "Loaded file: " << argv[*it] << std::endl; 00123 } 00124 00125 // print summary of MOAB's memory use 00126 print_memory_stats( mb ); 00127 return 0; 00128 } 00129 00130 // struct to store memory stats 00131 struct MemStats 00132 { 00133 unsigned long long total_storage; 00134 unsigned long long total_amortized; 00135 unsigned long long entity_storage; 00136 unsigned long long entity_amortized; 00137 unsigned long long adjacency_storage; 00138 unsigned long long adjacency_amortized; 00139 unsigned long long tag_storage; 00140 unsigned long long tag_amortized; 00141 }; 00142 00143 // test if MemStats object indicates no memory 00144 static bool is_zero( const MemStats& stats ); 00145 00146 // populdate a MemStats structg by calling 00147 // moab::Interface::estimated_memory_use 00148 static void get_mem_stats( moab::Interface& mb, MemStats& data, moab::EntityType type = moab::MBMAXTYPE ); 00149 00150 // Formatted string representation of memory size value 00151 static std::string memstr( unsigned long long val ); 00152 00153 // Get string describing tag data type 00154 static std::string tag_type_string( moab::Interface& mb, moab::Tag tag ); 00155 00156 // Get string representation of tag storage type 00157 static std::string tag_storage_string( moab::Interface& mb, moab::Tag tag ); 00158 00159 // Center 00160 static std::string center( const char* str, size_t width ); 00161 00162 void print_memory_stats( moab::Interface& mb, bool per_type, bool per_tag, bool totals, bool sysstats ) 00163 { 00164 moab::ErrorCode rval; 00165 const char ANON_TAG_NAME[] = "(anonymous)"; 00166 const int TYPE_WIDTH = 10; 00167 const int MEM_WIDTH = 7; 00168 const int MEM2_WIDTH = 2 * MEM_WIDTH + 1; 00169 const int MIN_TAG_NAME_WIDTH = strlen( ANON_TAG_NAME ); 00170 const int DTYPE_WIDTH = 12; 00171 const int STORAGE_WIDTH = 8; 00172 00173 // per-entity-type table header 00174 MemStats stats; 00175 00176 if( per_type ) 00177 { 00178 00179 std::cout.fill( ' ' ); 00180 std::cout << std::left << std::setw( TYPE_WIDTH ) << "Type" << ' ' << center( "Total", MEM2_WIDTH ) << ' ' 00181 << center( "Entity", MEM2_WIDTH ) << ' ' << center( "Adjacency", MEM2_WIDTH ) << ' ' 00182 << center( "Tag", MEM2_WIDTH ) << ' ' << std::endl 00183 << std::setw( TYPE_WIDTH ) << " "; 00184 for( int i = 0; i < 4; ++i ) 00185 std::cout << ' ' << std::left << std::setw( MEM_WIDTH ) << "Used" << ' ' << std::left 00186 << std::setw( MEM_WIDTH ) << "Alloc"; 00187 std::cout << std::endl; 00188 std::cout.fill( '-' ); 00189 std::cout << std::setw( TYPE_WIDTH ) << '-'; 00190 for( int i = 0; i < 8; ++i ) 00191 std::cout << ' ' << std::setw( MEM_WIDTH ) << '-'; 00192 std::cout.fill( ' ' ); 00193 std::cout << std::endl; 00194 00195 // per-entity-type memory use 00196 for( moab::EntityType t = moab::MBVERTEX; t != moab::MBMAXTYPE; ++t ) 00197 { 00198 get_mem_stats( mb, stats, t ); 00199 if( is_zero( stats ) ) continue; // skip types with no allocated memory 00200 00201 std::cout << std::left << std::setw( TYPE_WIDTH ) << moab::CN::EntityTypeName( t ) << ' ' << std::right 00202 << std::setw( MEM_WIDTH ) << memstr( stats.total_storage ) << ' ' << std::right 00203 << std::setw( MEM_WIDTH ) << memstr( stats.total_amortized ) << ' ' << std::right 00204 << std::setw( MEM_WIDTH ) << memstr( stats.entity_storage ) << ' ' << std::right 00205 << std::setw( MEM_WIDTH ) << memstr( stats.entity_amortized ) << ' ' << std::right 00206 << std::setw( MEM_WIDTH ) << memstr( stats.adjacency_storage ) << ' ' << std::right 00207 << std::setw( MEM_WIDTH ) << memstr( stats.adjacency_amortized ) << ' ' << std::right 00208 << std::setw( MEM_WIDTH ) << memstr( stats.tag_storage ) << ' ' << std::right 00209 << std::setw( MEM_WIDTH ) << memstr( stats.tag_amortized ) << std::endl; 00210 } 00211 } // end per_type 00212 00213 if( per_tag ) 00214 { 00215 // get list of tags 00216 std::vector< moab::Tag > tags; 00217 std::vector< moab::Tag >::const_iterator ti; 00218 mb.tag_get_tags( tags ); 00219 00220 // figure out required field with to fit longest tag name 00221 unsigned maxlen = MIN_TAG_NAME_WIDTH; 00222 for( ti = tags.begin(); ti != tags.end(); ++ti ) 00223 { 00224 std::string name; 00225 rval = mb.tag_get_name( *ti, name ); 00226 if( moab::MB_SUCCESS != rval ) continue; 00227 if( name.size() > maxlen ) maxlen = name.size(); 00228 } 00229 00230 // print header for per-tag data 00231 if( !tags.empty() ) 00232 { 00233 std::cout.fill( ' ' ); 00234 std::cout << std::endl 00235 << std::left << std::setw( maxlen ) << "Tag Name" << ' ' << std::left << std::setw( DTYPE_WIDTH ) 00236 << "Type" << ' ' << std::left << std::setw( STORAGE_WIDTH ) << "Storage" << ' ' << std::left 00237 << std::setw( MEM_WIDTH ) << "Used" << ' ' << std::left << std::setw( MEM_WIDTH ) << "Alloc" 00238 << std::endl; 00239 std::cout.fill( '-' ); 00240 std::cout << std::setw( maxlen ) << '-' << ' ' << std::setw( DTYPE_WIDTH ) << '-' << ' ' 00241 << std::setw( STORAGE_WIDTH ) << '-' << ' ' << std::setw( MEM_WIDTH ) << '-' << ' ' 00242 << std::setw( MEM_WIDTH ) << '-' << std::endl; 00243 std::cout.fill( ' ' ); 00244 } 00245 00246 // print per-tag memory use 00247 for( ti = tags.begin(); ti != tags.end(); ++ti ) 00248 { 00249 std::string name; 00250 rval = mb.tag_get_name( *ti, name ); 00251 if( moab::MB_SUCCESS != rval || name.empty() ) name = ANON_TAG_NAME; 00252 00253 unsigned long long occupied, allocated; 00254 mb.estimated_memory_use( 0, 0, 0, 0, 0, 0, 0, 0, &*ti, 1, &occupied, &allocated ); 00255 00256 std::cout << std::left << std::setw( maxlen ) << name << ' ' << std::right << std::setw( DTYPE_WIDTH ) 00257 << tag_type_string( mb, *ti ) << ' ' << std::right << std::setw( STORAGE_WIDTH ) 00258 << tag_storage_string( mb, *ti ) << ' ' << std::right << std::setw( MEM_WIDTH ) 00259 << memstr( occupied ) << ' ' << std::right << std::setw( MEM_WIDTH ) << memstr( allocated ) 00260 << std::endl; 00261 } 00262 } // end per_tag 00263 00264 if( totals ) 00265 { 00266 // print summary of overall memory use 00267 get_mem_stats( mb, stats ); 00268 std::cout << std::endl 00269 << "TOTAL: (Used/Allocated)" << std::endl 00270 << "memory: " << memstr( stats.total_storage ) << "/" << memstr( stats.total_amortized ) 00271 << std::endl 00272 << "entity: " << memstr( stats.entity_storage ) << "/" << memstr( stats.entity_amortized ) 00273 << std::endl 00274 << "adjacency: " << memstr( stats.adjacency_storage ) << "/" << memstr( stats.adjacency_amortized ) 00275 << std::endl 00276 << "tag: " << memstr( stats.tag_storage ) << "/" << memstr( stats.tag_amortized ) << std::endl 00277 << std::endl; 00278 00279 } // end totals 00280 00281 if( sysstats ) 00282 { 00283 std::FILE* filp = std::fopen( "/proc/self/stat", "r" ); 00284 unsigned long long vsize; 00285 long rss; 00286 if( filp && 2 == std::fscanf( filp, 00287 "%*d " // pid 00288 "%*s " // comm 00289 "%*c " // state 00290 "%*d " // ppid 00291 "%*d " // pgrp 00292 "%*d " // session 00293 "%*d " // tty_nr 00294 "%*d " // tpgid 00295 "%*u " // flags 00296 "%*u " // minflt 00297 "%*u " // cminflt 00298 "%*u " // majflt 00299 "%*u " // cmajflt 00300 "%*u " // utime 00301 "%*u " // stime 00302 "%*d " // cutime 00303 "%*d " // cstime 00304 "%*d " // priority 00305 "%*d " // nice 00306 "%*d " // num_threads 00307 "%*d " // itrealvalue 00308 "%*u " // starttime 00309 "%llu " // vsize 00310 "%ld", // rss 00311 &vsize, &rss ) ) 00312 { 00313 #ifndef _WIN32 00314 long long tmprss = rss * getpagesize(); 00315 #endif 00316 std::cout << std::endl 00317 << "SYSTEM:" << std::endl 00318 << "Virtual memory: " << memstr( vsize ) 00319 #ifndef _WIN32 00320 << std::endl 00321 << "Resident set size: " << memstr( tmprss ) 00322 #endif 00323 << std::endl; 00324 } 00325 else 00326 { 00327 #ifndef _WIN32 00328 struct rusage sysdata; 00329 if( getrusage( RUSAGE_SELF, &sysdata ) ) 00330 { 00331 std::cerr << "getrusage failed" << std::endl; 00332 } 00333 else 00334 { 00335 rss = sysdata.ru_maxrss; 00336 long long tmprss = rss * getpagesize(); 00337 std::cerr << std::endl 00338 << "SYSTEM:" << std::endl 00339 << "Resident set size: " << memstr( tmprss ) << std::endl; 00340 } 00341 #endif 00342 } 00343 if( filp ) fclose( filp ); 00344 } // end sysstats 00345 } 00346 00347 bool is_zero( const MemStats& stats ) 00348 { 00349 return stats.total_amortized == 0; 00350 } 00351 00352 void get_mem_stats( moab::Interface& mb, MemStats& data, moab::EntityType type ) 00353 { 00354 if( type != moab::MBMAXTYPE ) 00355 { 00356 moab::Range range; 00357 mb.get_entities_by_type( 0, type, range ); 00358 mb.estimated_memory_use( range, &data.total_storage, &data.total_amortized, &data.entity_storage, 00359 &data.entity_amortized, &data.adjacency_storage, &data.adjacency_amortized, 0, 0, 00360 &data.tag_storage, &data.tag_amortized ); 00361 } 00362 else 00363 { 00364 mb.estimated_memory_use( 0, 0, &data.total_storage, &data.total_amortized, &data.entity_storage, 00365 &data.entity_amortized, &data.adjacency_storage, &data.adjacency_amortized, 0, 0, 00366 &data.tag_storage, &data.tag_amortized ); 00367 } 00368 } 00369 00370 // rounded division 00371 static unsigned long long rdiv( unsigned long long num, unsigned long long den ) 00372 { 00373 return ( num + den / 2 ) / den; 00374 } 00375 00376 std::string memstr( unsigned long long val ) 00377 { 00378 const unsigned long long kb = 1024; 00379 const unsigned long long mb = kb * kb; 00380 const unsigned long long gb = kb * mb; 00381 const unsigned long long tb = kb * gb; 00382 00383 std::ostringstream s; 00384 if( UNITS == HUMAN ) 00385 { 00386 if( val >= 10 * tb ) 00387 s << rdiv( val, tb ) << "TB"; 00388 else if( val >= 10 * gb ) 00389 s << rdiv( val, gb ) << "GB"; 00390 else if( val >= 10 * mb ) 00391 s << rdiv( val, mb ) << "MB"; 00392 else if( val >= 10 * kb ) 00393 s << rdiv( val, kb ) << "kB"; 00394 else if( val > 0 ) 00395 s << val << " B"; 00396 else 00397 s << "0 "; 00398 } 00399 else 00400 { 00401 unsigned long long den = 1; 00402 switch( UNITS ) 00403 { 00404 case BYTES: 00405 den = 1; 00406 break; 00407 case KILOBYTES: 00408 den = kb; 00409 break; 00410 case MEGABYTES: 00411 den = mb; 00412 break; 00413 case GIGABYTES: 00414 den = gb; 00415 break; 00416 case HUMAN: 00417 break; // handled above, list here to suppress warning 00418 } 00419 00420 s << rdiv( val, den ); 00421 } 00422 return s.str(); 00423 } 00424 00425 std::string tag_type_string( moab::Interface& mb, moab::Tag tag ) 00426 { 00427 moab::ErrorCode rval; 00428 std::ostringstream s; 00429 00430 moab::DataType type; 00431 rval = mb.tag_get_data_type( tag, type ); 00432 if( moab::MB_SUCCESS != rval ) return std::string(); 00433 00434 int typesize; 00435 std::string typestr; 00436 switch( type ) 00437 { 00438 case moab::MB_TYPE_INTEGER: 00439 typestr = "int"; 00440 typesize = sizeof( int ); 00441 break; 00442 case moab::MB_TYPE_DOUBLE: 00443 typestr = "double"; 00444 typesize = sizeof( double ); 00445 break; 00446 case moab::MB_TYPE_HANDLE: 00447 typestr = "handle"; 00448 typesize = sizeof( moab::EntityHandle ); 00449 break; 00450 case moab::MB_TYPE_BIT: 00451 typesize = 1; 00452 typestr = "bits"; 00453 break; 00454 case moab::MB_TYPE_OPAQUE: 00455 typesize = 1; 00456 typestr = "bytes"; 00457 break; 00458 default: 00459 typesize = 1; 00460 typestr = "???"; 00461 break; 00462 } 00463 00464 int size; 00465 rval = mb.tag_get_length( tag, size ); 00466 if( moab::MB_VARIABLE_DATA_LENGTH == rval ) 00467 s << "VAR " << typestr; 00468 else if( moab::MB_SUCCESS == rval ) 00469 s << size / typesize << " " << typestr; 00470 // else do nothing 00471 00472 return s.str(); 00473 } 00474 00475 std::string tag_storage_string( moab::Interface& mb, moab::Tag tag ) 00476 { 00477 moab::ErrorCode rval; 00478 moab::TagType type; 00479 rval = mb.tag_get_type( tag, type ); 00480 if( moab::MB_SUCCESS != rval ) return std::string(); 00481 00482 switch( type ) 00483 { 00484 case moab::MB_TAG_DENSE: 00485 return "dense"; 00486 case moab::MB_TAG_SPARSE: 00487 return "sparse"; 00488 case moab::MB_TAG_BIT: 00489 return "bit"; 00490 default: 00491 return "(none)"; 00492 } 00493 } 00494 00495 std::string center( const char* str, size_t width ) 00496 { 00497 std::string text( str ); 00498 if( text.size() >= width ) return text; 00499 00500 width -= text.size(); 00501 if( 1u == width ) 00502 { 00503 text += " "; 00504 return text; 00505 } 00506 00507 std::ostringstream s; 00508 s << std::setw( width / 2 ) << ' ' << text << std::setw( width / 2 + width % 2 ) << ' '; 00509 return s.str(); 00510 } 00511 00512 void do_test_mode() 00513 { 00514 const char prefix[] = "****************"; 00515 moab::Core mbcore; 00516 moab::Interface& mb = mbcore; 00517 moab::ErrorCode rval; 00518 moab::Range handles; 00519 moab::EntityHandle h; 00520 moab::Range::iterator jt, it; 00521 const unsigned N = 1000; 00522 00523 // creating some vertices 00524 double coords[3] = { 1, 2, 3 }; 00525 for( unsigned i = 0; i < N; ++i ) 00526 mb.create_vertex( coords, h ); 00527 std::cout << std::endl << prefix << "Created " << N << " vertices" << std::endl; 00528 print_memory_stats( mb, true, false, true, true ); 00529 00530 for( unsigned i = 0; i < N; ++i ) 00531 mb.create_vertex( coords, h ); 00532 std::cout << std::endl << prefix << "Created another " << N << " vertices" << std::endl; 00533 print_memory_stats( mb, true, false, true, true ); 00534 00535 for( int i = 0; i < 100; ++i ) 00536 { 00537 for( unsigned j = 0; j < N; ++j ) 00538 mb.create_vertex( coords, h ); 00539 } 00540 std::cout << std::endl << prefix << "Created another " << 100 * N << " vertices" << std::endl; 00541 print_memory_stats( mb, true, false, true, true ); 00542 00543 // create some elements 00544 handles.clear(); 00545 mb.get_entities_by_type( 0, moab::MBVERTEX, handles ); 00546 it = handles.begin(); 00547 for( unsigned i = 0; i < N - 2; ++i, ++it ) 00548 { 00549 jt = it; 00550 moab::EntityHandle conn[3]; 00551 conn[0] = *jt; 00552 ++jt; 00553 conn[1] = *jt; 00554 ++jt; 00555 conn[2] = *jt; 00556 ++jt; 00557 mb.create_element( moab::MBTRI, conn, 3, h ); 00558 } 00559 std::cout << std::endl << prefix << "Created " << N - 2 << " triangles" << std::endl; 00560 print_memory_stats( mb, true, false, true, true ); 00561 00562 it = handles.begin(); 00563 for( unsigned i = 0; i < N - 3; ++i, ++it ) 00564 { 00565 jt = it; 00566 moab::EntityHandle conn[4]; 00567 conn[0] = *jt; 00568 ++jt; 00569 conn[1] = *jt; 00570 ++jt; 00571 conn[2] = *jt; 00572 ++jt; 00573 conn[3] = *jt; 00574 ++jt; 00575 mb.create_element( moab::MBQUAD, conn, 4, h ); 00576 } 00577 std::cout << std::endl << prefix << "Created " << N - 3 << " quads" << std::endl; 00578 print_memory_stats( mb, true, false, true, true ); 00579 00580 for( int i = 0; i < 100; ++i ) 00581 { 00582 it = handles.begin(); 00583 for( unsigned j = 0; j < N - 3; ++j, ++it ) 00584 { 00585 jt = it; 00586 moab::EntityHandle conn[4]; 00587 conn[0] = *jt; 00588 ++jt; 00589 conn[1] = *jt; 00590 ++jt; 00591 conn[2] = *jt; 00592 ++jt; 00593 conn[3] = *jt; 00594 ++jt; 00595 mb.create_element( moab::MBQUAD, conn, 4, h ); 00596 } 00597 } 00598 std::cout << std::endl << prefix << "Created another " << 100 * ( N - 3 ) << " quads" << std::endl; 00599 print_memory_stats( mb, true, false, true, true ); 00600 00601 // set global ID 00602 moab::Tag tag; 00603 rval = mb.tag_get_handle( "GLOBAL_ID", 1, moab::MB_TYPE_INTEGER, tag ); 00604 if( moab::MB_SUCCESS != rval ) 00605 { 00606 std::cerr << "Failed to get GLOBAL_ID tag handle" << std::endl; 00607 return; 00608 } 00609 handles.clear(); 00610 mb.get_entities_by_type( 0, moab::MBVERTEX, handles ); 00611 int id = 1; 00612 for( it = handles.begin(); it != handles.end(); ++it ) 00613 { 00614 mb.tag_set_data( tag, &*it, 1, &id ); 00615 ++id; 00616 } 00617 std::cout << std::endl << prefix << "Set global ID tag on " << handles.size() << " vertices" << std::endl; 00618 print_memory_stats( mb, true, true, true, true ); 00619 00620 handles.clear(); 00621 mb.get_entities_by_type( 0, moab::MBQUAD, handles ); 00622 id = 1; 00623 for( it = handles.begin(); it != handles.end(); ++it ) 00624 { 00625 mb.tag_set_data( tag, &*it, 1, &id ); 00626 ++id; 00627 } 00628 std::cout << std::endl << prefix << "Set global ID tag on " << handles.size() << " quads" << std::endl; 00629 print_memory_stats( mb, true, true, true, true ); 00630 00631 // create and set a sparse tag 00632 mb.tag_get_handle( "mem_test_tag", 3, moab::MB_TYPE_DOUBLE, tag, moab::MB_TAG_SPARSE | moab::MB_TAG_CREAT ); 00633 handles.clear(); 00634 mb.get_entities_by_type( 0, moab::MBVERTEX, handles ); 00635 for( it = handles.begin(); it != handles.end(); ++it ) 00636 { 00637 mb.get_coords( &*it, 1, coords ); 00638 mb.tag_set_data( tag, &*it, 1, coords ); 00639 } 00640 std::cout << std::endl 00641 << prefix << "Copied vertex coords to sparse tag for " << handles.size() << " vertices" << std::endl; 00642 print_memory_stats( mb, true, true, true, true ); 00643 00644 // create and set bit tag 00645 mb.tag_get_handle( "mem_test_bit", 1, moab::MB_TYPE_BIT, tag, moab::MB_TAG_CREAT ); 00646 handles.clear(); 00647 mb.get_entities_by_type( 0, moab::MBTRI, handles ); 00648 for( it = handles.begin(); it != handles.end(); ++it ) 00649 { 00650 char byte = '\001'; 00651 mb.tag_set_data( tag, &*it, 1, &byte ); 00652 } 00653 std::cout << std::endl << prefix << "Set 1-bit tag for " << handles.size() << " triangles" << std::endl; 00654 print_memory_stats( mb, true, true, true, true ); 00655 00656 // create vertex to element adjacency data 00657 handles.clear(); 00658 mb.get_entities_by_type( 0, moab::MBVERTEX, handles ); 00659 std::vector< moab::EntityHandle > adj_vec; 00660 mb.get_adjacencies( &*handles.begin(), 1, 2, false, adj_vec ); 00661 std::cout << std::endl << prefix << "Created vertex-to-element adjacencies" << std::endl; 00662 print_memory_stats( mb, true, false, true, true ); 00663 std::cout << std::endl; 00664 }
