MOAB: Mesh Oriented datABase
(version 5.4.1)
00001 /** \brief This test shows how to extract mesh from a model, based on distance. 00002 * 00003 * MOAB's It is needed to extract from large mesh files cells close to some point, where we suspect 00004 * errors It would be useful for 9Gb input file that we cannot visualize, but we have overlapped 00005 * elements. 00006 */ 00007 00008 #include <iostream> 00009 #include <cstdlib> 00010 #include <cstdio> 00011 00012 #include "moab/Core.hpp" 00013 #include "moab/Interface.hpp" 00014 #include "moab/Range.hpp" 00015 #include "moab/ProgOptions.hpp" 00016 #include "moab/CartVect.hpp" 00017 #include "moab/IntxMesh/IntxUtils.hpp" 00018 00019 #ifdef MOAB_HAVE_MPI 00020 #include "moab_mpi.h" 00021 #include "moab/ParallelComm.hpp" 00022 #endif 00023 00024 using namespace moab; 00025 using namespace std; 00026 00027 #ifdef MOAB_HAVE_HDF5 00028 string test_file_name = string( MESH_DIR ) + string( "/64bricks_512hex_256part.h5m" ); 00029 #endif 00030 int main( int argc, char** argv ) 00031 { 00032 ProgOptions opts; 00033 00034 // vertex 25 in filt out (-0.784768, 0.594952, -0.173698) 00035 double x = -0.784768, y = 0.594952, z = -0.173698; 00036 double lat = 28.6551, lon = 61.0204; // from Charlie Zender's page 00037 // https://acme-climate.atlassian.net/wiki/spaces/ED/pages/1347092547/Assessing+and+Addressing+Regridding+Weights+in+Map-Files 00038 00039 string inputFile = test_file_name; 00040 opts.addOpt< string >( "inFile,i", "Specify the input file name string ", &inputFile ); 00041 00042 string outFile = "out.h5m"; 00043 opts.addOpt< string >( "outFile,o", "Specify the output file name string ", &outFile ); 00044 00045 opts.addOpt< double >( string( "xpos,x" ), string( "x position" ), &x ); 00046 opts.addOpt< double >( string( "ypos,y" ), string( "y position" ), &y ); 00047 opts.addOpt< double >( string( "zpos,z" ), string( "z position" ), &z ); 00048 00049 opts.addOpt< double >( string( "latitude,t" ), string( "north latitude in degrees" ), &lat ); 00050 opts.addOpt< double >( string( "longitude,w" ), string( "east longitude in degrees" ), &lon ); 00051 00052 bool spherical = false; 00053 opts.addOpt< void >( "spherical,s", "use spherical coords input (default false) ", &spherical ); 00054 00055 double distance = 0.01; 00056 opts.addOpt< double >( string( "distance,d" ), string( "distance " ), &distance ); 00057 00058 opts.parseCommandLine( argc, argv ); 00059 00060 int rank = 0; 00061 int numProcesses = 1; 00062 std::string readopts; 00063 00064 #ifdef MOAB_HAVE_MPI 00065 if( MPI_Init( &argc, &argv ) ) return 1; 00066 MPI_Comm_rank( MPI_COMM_WORLD, &rank ); 00067 MPI_Comm_size( MPI_COMM_WORLD, &numProcesses ); 00068 00069 readopts = string( "PARALLEL=READ_PART;PARTITION=PARALLEL_PARTITION" ); // we do not have to 00070 // resolve shared ents 00071 #endif 00072 // Instantiate 00073 Core mb; 00074 00075 // Load the file into a new file set 00076 EntityHandle fileSet; 00077 ErrorCode rval = mb.create_meshset( MESHSET_SET, fileSet );MB_CHK_SET_ERR( rval, "Error creating file set" ); 00078 rval = mb.load_file( inputFile.c_str(), &fileSet, readopts.c_str() );MB_CHK_SET_ERR( rval, "Error loading file" ); 00079 00080 if( !rank ) 00081 { 00082 cout << " reading file " << inputFile << " on " << numProcesses << " task"; 00083 if( numProcesses > 1 ) cout << "s"; 00084 cout << "\n"; 00085 } 00086 // Get all 2d elements in the file set 00087 Range elems; 00088 rval = mb.get_entities_by_dimension( fileSet, 2, elems );MB_CHK_SET_ERR( rval, "Error getting 2d elements" ); 00089 00090 // create a meshset with close elements 00091 EntityHandle outSet; 00092 00093 // create meshset 00094 rval = mb.create_meshset( MESHSET_SET, outSet );MB_CHK_ERR( rval ); 00095 00096 // double sphere radius is 1 00097 CartVect point( x, y, z ); 00098 if( spherical ) 00099 { 00100 std::cout << " use spherical coordinates on the sphere of radius 1.\n"; 00101 IntxUtils::SphereCoords pos; 00102 pos.R = 1; // always on the 00103 pos.lat = lat * M_PI / 180; // defined in math.h 00104 pos.lon = lon * M_PI / 180; 00105 point = IntxUtils::spherical_to_cart( pos ); 00106 } 00107 00108 Range closeByCells; 00109 for( Range::iterator it = elems.begin(); it != elems.end(); it++ ) 00110 { 00111 EntityHandle cell = *it; 00112 CartVect center; 00113 rval = mb.get_coords( &cell, 1, &( center[0] ) );MB_CHK_SET_ERR( rval, "Can't get cell center coords" ); 00114 double dist = ( center - point ).length(); 00115 if( dist <= distance ) 00116 { 00117 closeByCells.insert( cell ); 00118 } 00119 } 00120 00121 rval = mb.add_entities( outSet, closeByCells );MB_CHK_SET_ERR( rval, "Can't add to entity set" ); 00122 00123 int numCells = (int)closeByCells.size(); 00124 #ifdef MOAB_HAVE_MPI 00125 // Reduce all of the local sums into the global sum 00126 int globalCells; 00127 MPI_Reduce( &numCells, &globalCells, 1, MPI_INT, MPI_SUM, 0, MPI_COMM_WORLD ); 00128 numCells = globalCells; 00129 #endif 00130 if( numCells == 0 ) 00131 { 00132 if( !rank ) 00133 std::cout << " no close cells to the point " << point << " at distance less than " << distance << "\n"; 00134 } 00135 else 00136 { 00137 if( !rank ) 00138 std::cout << " write file " << outFile << " with cells closer than " << distance << " from " << point 00139 << "\n"; 00140 string writeOpts; 00141 if( numProcesses > 1 ) writeOpts = string( "PARALLEL=WRITE_PART;" ); 00142 rval = mb.write_file( outFile.c_str(), 0, writeOpts.c_str(), &outSet, 1 );MB_CHK_SET_ERR( rval, "Can't write file" ); 00143 } 00144 00145 #ifdef MOAB_HAVE_MPI 00146 if( MPI_Finalize() ) return 1; 00147 #endif 00148 return 0; 00149 }
