MOAB: Mesh Oriented datABase
(version 5.4.1)
#include "TestUtil.hpp"#include "TestRunner.hpp"#include "moab/ProgOptions.hpp"#include <limits>#include <cstdlib>#include <iterator>
Include dependency graph for test_prog_opt.cpp:Go to the source code of this file.
Defines | |
| #define | ARGCV(A) ( sizeof( A ) / sizeof( ( A )[0] ) ), const_cast< char** >( A ) |
Functions | |
| void | test_flag_opt_short () |
| void | test_flag_opt_long_short () |
| void | test_flag_opt_long () |
| void | test_flag_cancel () |
| void | test_flag_store_false () |
| void | test_int_opt () |
| void | test_int_arg () |
| void | test_real_opt () |
| void | test_real_arg () |
| void | test_string_opt () |
| void | test_string_arg () |
| void | test_string_rank_subst () |
| void | test_int_vect_opt () |
| void | test_int_vect_arg () |
| void | test_optional_args () |
| void | test_optional_arg () |
| void | test_squashed_short () |
| int | main (int argc, char *argv[]) |
| #define ARGCV | ( | A | ) | ( sizeof( A ) / sizeof( ( A )[0] ) ), const_cast< char** >( A ) |
Definition at line 33 of file test_prog_opt.cpp.
Referenced by test_flag_cancel(), test_flag_opt_long(), test_flag_opt_long_short(), test_flag_opt_short(), test_flag_store_false(), test_int_arg(), test_int_opt(), test_int_vect_arg(), test_int_vect_opt(), test_optional_arg(), test_optional_args(), test_real_arg(), test_real_opt(), test_squashed_short(), test_string_arg(), test_string_opt(), and test_string_rank_subst().
| int main | ( | int | argc, |
| char * | argv[] | ||
Definition at line 35 of file test_prog_opt.cpp.
References REGISTER_TEST, RUN_TESTS, test_flag_cancel(), test_flag_opt_long(), test_flag_opt_long_short(), test_flag_opt_short(), test_flag_store_false(), test_int_arg(), test_int_opt(), test_int_vect_arg(), test_int_vect_opt(), test_optional_arg(), test_optional_args(), test_real_arg(), test_real_opt(), test_squashed_short(), test_string_arg(), test_string_opt(), and test_string_rank_subst().
// make ProgOptions abort() rather than exiting with an
// error code for invalid options so that we can catch
// the signal and continue with later tests
#ifndef WIN32
setenv( "MOAB_PROG_OPT_ABORT", "1", 0 );
#endif
REGISTER_TEST( test_flag_opt_short );
REGISTER_TEST( test_flag_opt_long_short );
REGISTER_TEST( test_flag_opt_long );
REGISTER_TEST( test_flag_cancel );
REGISTER_TEST( test_flag_store_false );
REGISTER_TEST( test_int_opt );
REGISTER_TEST( test_int_arg );
REGISTER_TEST( test_real_opt );
REGISTER_TEST( test_real_arg );
REGISTER_TEST( test_string_opt );
REGISTER_TEST( test_string_arg );
REGISTER_TEST( test_string_rank_subst );
REGISTER_TEST( test_int_vect_opt );
REGISTER_TEST( test_int_vect_arg );
REGISTER_TEST( test_optional_args );
REGISTER_TEST( test_optional_arg );
REGISTER_TEST( test_squashed_short );
#ifdef MOAB_HAVE_MPI
MPI_Init( &argc, &argv );
#endif
int result = RUN_TESTS( argc, argv );
MPI_Finalize();
#endif
return result;
| void test_flag_cancel | ( | ) |
Definition at line 112 of file test_prog_opt.cpp.
References ProgOptions::add_cancel_opt, ProgOptions::addOpt(), ARGCV, CHECK, and ProgOptions::parseCommandLine().
Referenced by main().
ProgOptions opts1;
bool value = false;
opts1.addOpt< void >( "flag", "my flag", &value, ProgOptions::add_cancel_opt );
const char* argv1[] = { "test", "--flag" };
opts1.parseCommandLine( ARGCV( argv1 ) );
CHECK( value );
ProgOptions opts2;
value = true;
opts2.addOpt< void >( "flag", "my flag", &value, ProgOptions::add_cancel_opt );
const char* argv2[] = { "test", "--flag", "--no-flag" };
opts2.parseCommandLine( ARGCV( argv2 ) );
CHECK( !value );
ProgOptions opts3;
value = false;
opts3.addOpt< void >( "flag", "my flag", &value, ProgOptions::add_cancel_opt );
const char* argv3[] = { "test", "--flag", "--no-flag", "--flag" };
opts3.parseCommandLine( ARGCV( argv3 ) );
CHECK( value );
| void test_flag_opt_long | ( | ) |
Definition at line 99 of file test_prog_opt.cpp.
References ProgOptions::addOpt(), ARGCV, CHECK, CHECK_EQUAL, ProgOptions::numOptSet(), and ProgOptions::parseCommandLine().
ProgOptions opts3;
bool value = false;
opts3.addOpt< void >( "long,l", "long opt", &value );
const char* argv3[] = { "prog", "--long", "--long" };
CHECK( value );
CHECK_EQUAL( 2, opts3.numOptSet( ",l" ) );
CHECK_EQUAL( 2, opts3.numOptSet( "long,l" ) );
CHECK_EQUAL( 2, opts3.numOptSet( "long" ) );
| void test_flag_opt_long_short | ( | ) |
Definition at line 86 of file test_prog_opt.cpp.
ProgOptions opts2;
bool value = false;
opts2.addOpt< void >( "long,l", "long opt", &value );
const char* argv2[] = { "prog", "-l", "-l" };
CHECK( value );
CHECK_EQUAL( 2, opts2.numOptSet( ",l" ) );
CHECK_EQUAL( 2, opts2.numOptSet( "long,l" ) );
CHECK_EQUAL( 2, opts2.numOptSet( "long" ) );
| void test_flag_opt_short | ( | ) |
Definition at line 75 of file test_prog_opt.cpp.
ProgOptions opts1;
bool value1 = false;
opts1.addOpt< void >( ",s", "short opt", &value1 );
const char* argv1[] = { "prog", "-s" };
CHECK( value1 );
CHECK_EQUAL( 1, opts1.numOptSet( ",s" ) );
| void test_flag_store_false | ( | ) |
Definition at line 136 of file test_prog_opt.cpp.
References ProgOptions::addOpt(), ARGCV, CHECK, ProgOptions::parseCommandLine(), and ProgOptions::store_false.
ProgOptions opts1;
bool value1 = true;
opts1.addOpt< void >( ",s", "short opt", &value1, ProgOptions::store_false );
CHECK( !value1 );
| void test_int_arg | ( | ) |
Definition at line 171 of file test_prog_opt.cpp.
References ProgOptions::addRequiredArg(), ARGCV, CHECK_EQUAL, ProgOptions::getReqArg(), and ProgOptions::parseCommandLine().
ProgOptions opts;
int val1 = 5;
opts.addRequiredArg( "arg", "my test arg", &val1 );
opts.addRequiredArg< int >( "arg2", "my other test arg" );
const char* argv[] = { "test", "--", "-1", "-010" };
opts.parseCommandLine( ARGCV( argv ) );
CHECK_EQUAL( -1, val1 );
CHECK_EQUAL( -010, opts.getReqArg< int >( "arg2" ) ); // octal -10 == decimal -8
CHECK_EQUAL( -1, opts.getReqArg< int >( "arg" ) );
| void test_int_opt | ( | ) |
Definition at line 146 of file test_prog_opt.cpp.
References ProgOptions::addOpt(), ARGCV, CHECK, CHECK_EQUAL, ProgOptions::getOpt(), ProgOptions::getOptAllArgs(), and ProgOptions::parseCommandLine().
ProgOptions opts;
int val1 = -1;
opts.addOpt( "long,s", "my int opt", &val1 );
const char* argv[] = { "test", "-s", "2", "--long", "-0xA", "--long=5" };
CHECK_EQUAL( 5, val1 );
int val2 = -1;
CHECK( opts.getOpt( ",s", &val2 ) );
CHECK_EQUAL( 5, val2 );
val2 = -1;
CHECK( opts.getOpt( "long,s", &val2 ) );
val2 = -1;
CHECK( opts.getOpt( "long", &val2 ) );
std::vector< int > list;
opts.getOptAllArgs( ",s", list );
CHECK_EQUAL( (size_t)3, list.size() );
CHECK_EQUAL( 2, list[0] );
CHECK_EQUAL( -10, list[1] );
CHECK_EQUAL( 5, list[2] );
| void test_int_vect_arg | ( | ) |
Definition at line 374 of file test_prog_opt.cpp.
References ProgOptions::addRequiredArg(), ARGCV, CHECK_ARRAYS_EQUAL, CHECK_EQUAL, ProgOptions::getReqArg(), and ProgOptions::parseCommandLine().
ProgOptions opts;
std::vector< int > list1;
opts.addRequiredArg( "ints", "int list", &list1 );
const char* argv[] = { "test", "5,6,-3--1,10" };
const int exp1[] = { 5, 6, -3, -2, -1, 10 };
const int exp1_len = sizeof( exp1 ) / sizeof( exp1[0] );
CHECK_ARRAYS_EQUAL( exp1, exp1_len, &list1[0], list1.size() );
CHECK_EQUAL( list1, opts.getReqArg< std::vector< int > >( "ints" ) );
| void test_int_vect_opt | ( | ) |
Definition at line 339 of file test_prog_opt.cpp.
References ProgOptions::addOpt(), ARGCV, CHECK, CHECK_ARRAYS_EQUAL, CHECK_EQUAL, ProgOptions::getOpt(), ProgOptions::getOptAllArgs(), ProgOptions::parseCommandLine(), and size.
ProgOptions opts;
std::vector< int > list1, list2;
opts.addOpt( "ids,d", "id list", &list1 );
const char* argv[] = { "test", "--ids=1,2,3", "--ids", "4-10", "-d", "4-5,2" };
const int exp1[] = { 1, 2, 3 };
const int exp2[] = { 4, 5, 6, 7, 8, 9, 10 };
const int exp2_len = sizeof( exp2 ) / sizeof( exp2[0] );
const int exp3[] = { 4, 5, 2 };
const int exp3_len = sizeof( exp3 ) / sizeof( exp3[0] );
std::vector< int > all;
std::copy( exp1, exp1 + exp1_len, std::back_inserter( all ) );
std::copy( exp2, exp2 + exp2_len, std::back_inserter( all ) );
std::copy( exp3, exp3 + exp3_len, std::back_inserter( all ) );
CHECK_EQUAL( all, list1 );
CHECK( opts.getOpt( ",d", &list2 ) );
CHECK_ARRAYS_EQUAL( exp3, exp3_len, &list2[0], list2.size() );
std::vector< std::vector< int > > lists;
opts.getOptAllArgs( "ids", lists );
CHECK_EQUAL( (size_t)3, lists.size() );
CHECK_ARRAYS_EQUAL( exp1, exp1_len, &lists[0][0], lists[0].size() );
CHECK_ARRAYS_EQUAL( exp2, exp2_len, &lists[1][0], lists[1].size() );
CHECK_ARRAYS_EQUAL( exp3, exp3_len, &lists[2][0], lists[2].size() );
list2.clear();
opts.getOptAllArgs( "ids", list2 );
CHECK_EQUAL( all, list2 );
| void test_optional_arg | ( | ) |
Definition at line 416 of file test_prog_opt.cpp.
References ProgOptions::addOptionalArgs(), ProgOptions::addRequiredArg(), ARGCV, CHECK, CHECK_EQUAL, ProgOptions::getArgs(), init(), and ProgOptions::parseCommandLine().
ProgOptions opts1;
std::string init, fini;
opts1.addRequiredArg( "init", "required initial argument", &init );
opts1.addOptionalArgs< std::string >( 1, "mid", "optional arguments" );
opts1.addRequiredArg( "fini", "required final argument", &fini );
const char* argv1[] = { "test", "arg1", "arg2" };
std::vector< std::string > list;
CHECK_EQUAL( "arg1", init );
CHECK_EQUAL( "arg2", fini );
opts1.getArgs( "mid", list );
CHECK( list.empty() );
ProgOptions opts2;
init.clear();
fini.clear();
opts2.addRequiredArg( "init", "required initial argument", &init );
opts2.addOptionalArgs< std::string >( 1, "mid", "optional arguments" );
opts2.addRequiredArg( "fini", "required final argument", &fini );
const char* argv2[] = { "test", "arg1", "arg2", "arg3" };
CHECK_EQUAL( "arg3", fini );
list.clear();
opts2.getArgs( "mid", list );
CHECK_EQUAL( (size_t)1, list.size() );
CHECK_EQUAL( "arg2", list[0] );
| void test_optional_args | ( | ) |
Definition at line 389 of file test_prog_opt.cpp.
References ProgOptions::addOptionalArgs(), ProgOptions::addRequiredArg(), ARGCV, CHECK, CHECK_EQUAL, ProgOptions::getArgs(), and ProgOptions::parseCommandLine().
ProgOptions opts1;
std::string arg;
opts1.addOptionalArgs< std::string >( 0, "opts", "optional arguments" );
opts1.addRequiredArg( "req", "required final argument", &arg );
const char* argv1[] = { "test", "arg" };
CHECK_EQUAL( "arg", arg );
opts1.getArgs( "opts", list );
ProgOptions opts2;
arg.clear();
opts2.addOptionalArgs< std::string >( 0, "opts", "optional arguments" );
opts2.addRequiredArg( "req", "required final argument", &arg );
const char* argv2[] = { "test", "arg1", "arg2", "arg" };
list.clear();
opts2.getArgs( "opts", list );
CHECK_EQUAL( (size_t)2, list.size() );
CHECK_EQUAL( "arg1", list[0] );
CHECK_EQUAL( "arg2", list[1] );
| void test_real_arg | ( | ) |
Definition at line 210 of file test_prog_opt.cpp.
References ProgOptions::addRequiredArg(), ARGCV, CHECK_REAL_EQUAL, EPS, ProgOptions::getReqArg(), and ProgOptions::parseCommandLine().
const double EPS = std::numeric_limits< double >::epsilon();
ProgOptions opts;
double val1 = 5;
opts.addRequiredArg< double >( "arg2", "my other test arg" );
const char* argv[] = { "test", "--", "-1.2", "1.01e-3" };
CHECK_REAL_EQUAL( -1.2, val1, EPS );
CHECK_REAL_EQUAL( 1.01e-3, opts.getReqArg< double >( "arg2" ), EPS );
CHECK_REAL_EQUAL( -1.2, opts.getReqArg< double >( "arg" ), EPS );
| void test_real_opt | ( | ) |
Definition at line 184 of file test_prog_opt.cpp.
References ProgOptions::addOpt(), ARGCV, CHECK, CHECK_EQUAL, CHECK_REAL_EQUAL, EPS, ProgOptions::getOpt(), ProgOptions::getOptAllArgs(), and ProgOptions::parseCommandLine().
ProgOptions opts;
double val1 = -1;
opts.addOpt( "long,s", "my real opt", &val1 );
const char* argv[] = { "test", "-s", "2", "--long", "2e5", "--long=-0.01" };
CHECK_REAL_EQUAL( -0.01, val1, EPS );
double val2 = -1;
CHECK_REAL_EQUAL( -0.01, val2, EPS );
val2 = -1;
val2 = -1;
std::vector< double > list;
CHECK_REAL_EQUAL( 2, list[0], EPS );
CHECK_REAL_EQUAL( 2e5, list[1], EPS );
CHECK_REAL_EQUAL( -0.01, list[2], EPS );
| void test_squashed_short | ( | ) |
Definition at line 447 of file test_prog_opt.cpp.
References ProgOptions::addOpt(), ARGCV, CHECK, CHECK_EQUAL, CHECK_REAL_EQUAL, ProgOptions::numOptSet(), and ProgOptions::parseCommandLine().
ProgOptions opts;
int intval = 0;
double realval = 0;
bool flagval = false;
std::string strval;
opts.addOpt< void >( ",f", "flag", &flagval );
opts.addOpt( ",i", "int", &intval );
opts.addOpt( ",r", "real", &realval );
opts.addOpt( ",s", "str", &strval );
const char* argv[] = { "test", "-ifsrff", "-0xBEEF", "string", "-1.0e55" };
CHECK_EQUAL( -0xBEEF, intval );
CHECK_REAL_EQUAL( -1.0e55, realval, 1e-6 );
CHECK_EQUAL( "string", strval );
CHECK( flagval );
CHECK_EQUAL( 3, opts.numOptSet( ",f" ) );
CHECK_EQUAL( 1, opts.numOptSet( ",i" ) );
CHECK_EQUAL( 1, opts.numOptSet( ",r" ) );
CHECK_EQUAL( 1, opts.numOptSet( ",s" ) );
| void test_string_arg | ( | ) |
Definition at line 268 of file test_prog_opt.cpp.
ProgOptions opts;
std::string val2;
opts.addRequiredArg< std::string >( "arg", "my test arg" );
opts.addRequiredArg( "arg2", "my other test arg", &val2 );
const char* argv[] = { "test", "my_string", "with spaces" };
CHECK_EQUAL( "with spaces", val2 );
CHECK_EQUAL( "my_string", opts.getReqArg< std::string >( "arg" ) );
CHECK_EQUAL( "with spaces", opts.getReqArg< std::string >( "arg2" ) );
| void test_string_opt | ( | ) |
Definition at line 224 of file test_prog_opt.cpp.
ProgOptions opts;
std::string val1;
opts.addOpt( "long,s", "my first opt", &val1 );
opts.addOpt< std::string >( "second,2", "my second opt" );
const char* argv[] = { "test", "--long", "2", "-s", "foobar", "-2", "two", "--second=testval" };
CHECK_EQUAL( "foobar", val1 );
std::string val2;
CHECK_EQUAL( "foobar", val2 );
val2.clear();
val2.clear();
val2.clear();
CHECK( opts.getOpt( ",2", &val2 ) );
CHECK_EQUAL( "testval", val2 );
val2.clear();
CHECK( opts.getOpt( "second,2", &val2 ) );
val2.clear();
CHECK( opts.getOpt( "second", &val2 ) );
opts.getOptAllArgs( "long", list );
CHECK_EQUAL( "2", list[0] );
CHECK_EQUAL( "foobar", list[1] );
list.clear();
opts.getOptAllArgs( ",2", list );
CHECK_EQUAL( "two", list[0] );
CHECK_EQUAL( "testval", list[1] );
| void test_string_rank_subst | ( | ) |
Definition at line 281 of file test_prog_opt.cpp.
References ProgOptions::addOpt(), ProgOptions::addRequiredArg(), ARGCV, buffer, CHECK, CHECK_EQUAL, ProgOptions::getOpt(), ProgOptions::getOptAllArgs(), ProgOptions::getReqArg(), MPI_COMM_WORLD, ProgOptions::parseCommandLine(), rank, ProgOptions::rank_subst, and size.
std::string exp1 = "ddd%";
std::string exp2 = "%";
std::string exp2b = "foo%bar";
std::string exp3 = "%string%";
std::string exp4 = "file.%";
ProgOptions opts;
std::string val1, val2, val3, val4;
opts.addOpt( ",n", "no subst flag", &val1, 0 );
opts.addOpt( "dosub,s", "subst flag", &val2, ProgOptions::rank_subst );
opts.addRequiredArg( "nos", "no subst arg", &val3, 0 );
opts.addRequiredArg( "sub", "subst arg", &val4, ProgOptions::rank_subst );
std::string eqflg( "--dosub=" );
eqflg += exp2;
const char* argv[] = { "test", exp3.c_str(), exp4.c_str(), "-s", exp2b.c_str(), "-n", exp1.c_str(), eqflg.c_str() };
int rank, size;
MPI_Comm_rank( MPI_COMM_WORLD, &rank );
MPI_Comm_size( MPI_COMM_WORLD, &size );
char buffer[64];
int width = 1;
while( size > 10 )
width++;
size /= 10;
sprintf( buffer, "%0*d", width, rank );
exp2 = buffer;
exp2b = std::string( "foo" ) + buffer + "bar";
exp4 = std::string( "file." ) + buffer;
#endif
CHECK_EQUAL( exp1, val1 );
CHECK_EQUAL( exp2, val2 );
CHECK_EQUAL( exp3, val3 );
CHECK_EQUAL( exp4, val4 );
val1.clear();
val2.clear();
CHECK( opts.getOpt( ",n", &val1 ) );
CHECK( opts.getOpt( "dosub", &val2 ) );
CHECK_EQUAL( exp3, opts.getReqArg< std::string >( "nos" ) );
CHECK_EQUAL( exp4, opts.getReqArg< std::string >( "sub" ) );
CHECK_EQUAL( exp2b, list[0] );
CHECK_EQUAL( exp2, list[1] );
