MOAB: Mesh Oriented datABase
(version 5.4.1)
00001 /** 00002 * MOAB, a Mesh-Oriented datABase, is a software component for creating, 00003 * storing and accessing finite element mesh data. 00004 * 00005 * Copyright 2004 Sandia Corporation. Under the terms of Contract 00006 * DE-AC04-94AL85000 with Sandia Corporation, the U.S. Government 00007 * retains certain rights in this software. 00008 * 00009 * This library is free software; you can redistribute it and/or 00010 * modify it under the terms of the GNU Lesser General Public 00011 * License as published by the Free Software Foundation; either 00012 * version 2.1 of the License, or (at your option) any later version. 00013 * 00014 */ 00015 00016 // MOAB performance tests building mapped mesh with nodes and 00017 // hexes created one at a time. This also creates the node to hex adjacencies. 00018 00019 // Different platforms follow different conventions for usage 00020 #if !defined( _MSC_VER ) && !defined( __MINGW32__ ) 00021 #include <sys/resource.h> 00022 #else 00023 #include <time.h> 00024 #endif 00025 #ifdef SOLARIS 00026 extern "C" int getrusage( int, struct rusage* ); 00027 #ifndef RUSAGE_SELF 00028 #include </usr/ucbinclude/sys/rusage.h> 00029 #endif 00030 #endif 00031 00032 #ifndef IS_BUILDING_MB 00033 #define IS_BUILDING_MB 00034 #endif 00035 00036 #include <cstdlib> 00037 #include <cstdio> 00038 #include <cassert> 00039 #include <iostream> 00040 #include "moab/Core.hpp" 00041 #include "moab/ReadUtilIface.hpp" 00042 #include "VertexSequence.hpp" 00043 #include "StructuredElementSeq.hpp" 00044 #include "EntitySequence.hpp" 00045 #include "SequenceManager.hpp" 00046 #include "moab/HomXform.hpp" 00047 #include "moab/SetIterator.hpp" 00048 00049 using namespace moab; 00050 00051 double LENGTH = 1.0; 00052 00053 void testA( const int nelem, const double* coords ); 00054 void testB( const int nelem, const double* coords, int* connect ); 00055 void testC( const int nelem, const double* coords ); 00056 void testD( const int nelem, const double* coords, int ver ); 00057 void testE( const int nelem, const double* coords, int* connect ); 00058 void print_time( const bool print_em, double& tot_time, double& utime, double& stime, long& imem, long& rmem ); 00059 void query_vert_to_elem(); 00060 void query_elem_to_vert(); 00061 void query_struct_elem_to_vert(); 00062 void query_elem_to_vert_direct(); 00063 void query_vert_to_elem_direct(); 00064 ErrorCode normalize_elems( double* coords ); 00065 void check_answers( const char* ); 00066 00067 #define RC( msg ) \ 00068 if( MB_SUCCESS != result ) do \ 00069 { \ 00070 std::cout << "FAIL in " << ( msg ) << std::endl; \ 00071 return; \ 00072 } while( true ) 00073 #define RR( msg ) \ 00074 if( MB_SUCCESS != result ) do \ 00075 { \ 00076 std::cout << "FAIL in " << ( msg ) << std::endl; \ 00077 return result; \ 00078 } while( true ) 00079 00080 void compute_edge( double* start, const int nelem, const double xint, const int stride ) 00081 { 00082 for( int i = 1; i < nelem; i++ ) 00083 { 00084 start[i * stride] = start[0] + i * xint; 00085 start[nelem + 1 + i * stride] = start[nelem + 1] + i * xint; 00086 start[2 * ( nelem + 1 ) + i * stride] = start[2 * ( nelem + 1 )] + i * xint; 00087 } 00088 } 00089 00090 void compute_face( double* a, const int nelem, const double xint, const int stride1, const int stride2 ) 00091 { 00092 // 2D TFI on a face starting at a, with strides stride1 in ada and stride2 in tse 00093 for( int j = 1; j < nelem; j++ ) 00094 { 00095 double tse = j * xint; 00096 for( int i = 1; i < nelem; i++ ) 00097 { 00098 double ada = i * xint; 00099 00100 a[i * stride1 + j * stride2] = 00101 ( 1.0 - ada ) * a[i * stride1] + ada * a[i * stride1 + nelem * stride2] + 00102 ( 1.0 - tse ) * a[j * stride2] + tse * a[j * stride2 + nelem * stride1] - 00103 ( 1.0 - tse ) * ( 1.0 - ada ) * a[0] - ( 1.0 - tse ) * ada * a[nelem * stride1] - 00104 tse * ( 1.0 - ada ) * a[nelem * stride2] - tse * ada * a[nelem * ( stride1 + stride2 )]; 00105 a[nelem + 1 + i * stride1 + j * stride2] = 00106 ( 1.0 - ada ) * a[nelem + 1 + i * stride1] + ada * a[nelem + 1 + i * stride1 + nelem * stride2] + 00107 ( 1.0 - tse ) * a[nelem + 1 + j * stride2] + tse * a[nelem + 1 + j * stride2 + nelem * stride1] - 00108 ( 1.0 - tse ) * ( 1.0 - ada ) * a[nelem + 1 + 0] - 00109 ( 1.0 - tse ) * ada * a[nelem + 1 + nelem * stride1] - 00110 tse * ( 1.0 - ada ) * a[nelem + 1 + nelem * stride2] - 00111 tse * ada * a[nelem + 1 + nelem * ( stride1 + stride2 )]; 00112 a[2 * ( nelem + 1 ) + i * stride1 + j * stride2] = 00113 ( 1.0 - ada ) * a[2 * ( nelem + 1 ) + i * stride1] + 00114 ada * a[2 * ( nelem + 1 ) + i * stride1 + nelem * stride2] + 00115 ( 1.0 - tse ) * a[2 * ( nelem + 1 ) + j * stride2] + 00116 tse * a[2 * ( nelem + 1 ) + j * stride2 + nelem * stride1] - 00117 ( 1.0 - tse ) * ( 1.0 - ada ) * a[2 * ( nelem + 1 ) + 0] - 00118 ( 1.0 - tse ) * ada * a[2 * ( nelem + 1 ) + nelem * stride1] - 00119 tse * ( 1.0 - ada ) * a[2 * ( nelem + 1 ) + nelem * stride2] - 00120 tse * ada * a[2 * ( nelem + 1 ) + nelem * ( stride1 + stride2 )]; 00121 } 00122 } 00123 } 00124 00125 void build_coords( const int nelem, double*& coords ) 00126 { 00127 double ttime0 = 0.0, ttime1 = 0.0, utime1 = 0.0, stime1 = 0.0; 00128 long imem = 0, rmem = 0; 00129 print_time( false, ttime0, utime1, stime1, imem, rmem ); 00130 // allocate the memory 00131 int numv = nelem + 1; 00132 int numv_sq = numv * numv; 00133 int tot_numv = numv * numv * numv; 00134 coords = new double[3 * tot_numv]; 00135 00136 // use FORTRAN-like indexing 00137 #define VINDEX( i, j, k ) ( ( i ) + ( (j)*numv ) + ( (k)*numv_sq ) ) 00138 int idx; 00139 double scale1, scale2, scale3; 00140 // use these to prevent optimization on 1-scale, etc (real map wouldn't have 00141 // all these equal) 00142 scale1 = LENGTH / nelem; 00143 scale2 = LENGTH / nelem; 00144 scale3 = LENGTH / nelem; 00145 00146 #ifdef REALTFI 00147 // use a real TFI xform to compute coordinates 00148 // compute edges 00149 // i (stride=1) 00150 compute_edge( &coords[VINDEX( 0, 0, 0 )], nelem, scale1, 1 ); 00151 compute_edge( &coords[VINDEX( 0, nelem, 0 )], nelem, scale1, 1 ); 00152 compute_edge( &coords[VINDEX( 0, 0, nelem )], nelem, scale1, 1 ); 00153 compute_edge( &coords[VINDEX( 0, nelem, nelem )], nelem, scale1, 1 ); 00154 // j (stride=numv) 00155 compute_edge( &coords[VINDEX( 0, 0, 0 )], nelem, scale1, numv ); 00156 compute_edge( &coords[VINDEX( nelem, 0, 0 )], nelem, scale1, numv ); 00157 compute_edge( &coords[VINDEX( 0, 0, nelem )], nelem, scale1, numv ); 00158 compute_edge( &coords[VINDEX( nelem, 0, nelem )], nelem, scale1, numv ); 00159 // k (stride=numv^2) 00160 compute_edge( &coords[VINDEX( 0, 0, 0 )], nelem, scale1, numv_sq ); 00161 compute_edge( &coords[VINDEX( nelem, 0, 0 )], nelem, scale1, numv_sq ); 00162 compute_edge( &coords[VINDEX( 0, nelem, 0 )], nelem, scale1, numv_sq ); 00163 compute_edge( &coords[VINDEX( nelem, nelem, 0 )], nelem, scale1, numv_sq ); 00164 00165 // compute faces 00166 // i=0, nelem 00167 compute_face( &coords[VINDEX( 0, 0, 0 )], nelem, scale1, numv, numv_sq ); 00168 compute_face( &coords[VINDEX( nelem, 0, 0 )], nelem, scale1, numv, numv_sq ); 00169 // j=0, nelem 00170 compute_face( &coords[VINDEX( 0, 0, 0 )], nelem, scale1, 1, numv_sq ); 00171 compute_face( &coords[VINDEX( 0, nelem, 0 )], nelem, scale1, 1, numv_sq ); 00172 // k=0, nelem 00173 compute_face( &coords[VINDEX( 0, 0, 0 )], nelem, scale1, 1, numv ); 00174 compute_face( &coords[VINDEX( 0, 0, nelem )], nelem, scale1, 1, numv ); 00175 00176 // initialize corner indices 00177 int i000 = VINDEX( 0, 0, 0 ); 00178 int ia00 = VINDEX( nelem, 0, 0 ); 00179 int i0t0 = VINDEX( 0, nelem, 0 ); 00180 int iat0 = VINDEX( nelem, nelem, 0 ); 00181 int i00g = VINDEX( 0, 0, nelem ); 00182 int ia0g = VINDEX( nelem, 0, nelem ); 00183 int i0tg = VINDEX( 0, nelem, nelem ); 00184 int iatg = VINDEX( nelem, nelem, nelem ); 00185 double cX, cY, cZ; 00186 int adaInts = nelem; 00187 int tseInts = nelem; 00188 int gammaInts = nelem; 00189 00190 for( int i = 1; i < nelem; i++ ) 00191 { 00192 for( int j = 1; j < nelem; j++ ) 00193 { 00194 for( int k = 1; k < nelem; k++ ) 00195 { 00196 // idx = VINDEX(i,j,k); 00197 double tse = i * scale1; 00198 double ada = j * scale2; 00199 double gamma = k * scale3; 00200 double tm1 = 1.0 - tse; 00201 double am1 = 1.0 - ada; 00202 double gm1 = 1.0 - gamma; 00203 00204 cX = gm1 * ( am1 * ( tm1 * coords[i000] + tse * coords[i0t0] ) + 00205 ada * ( tm1 * coords[ia00] + tse * coords[iat0] ) ) + 00206 gamma * ( am1 * ( tm1 * coords[i00g] + tse * coords[i0tg] ) + 00207 ada * ( tm1 * coords[ia0g] + tse * coords[iatg] ) ); 00208 00209 cY = gm1 * ( am1 * ( tm1 * coords[i000] + tse * coords[i0t0] ) + 00210 ada * ( tm1 * coords[ia00] + tse * coords[iat0] ) ) + 00211 gamma * ( am1 * ( tm1 * coords[i00g] + tse * coords[i0tg] ) + 00212 ada * ( tm1 * coords[ia0g] + tse * coords[iatg] ) ); 00213 00214 cZ = gm1 * ( am1 * ( tm1 * coords[i000] + tse * coords[i0t0] ) + 00215 ada * ( tm1 * coords[ia00] + tse * coords[iat0] ) ) + 00216 gamma * ( am1 * ( tm1 * coords[i00g] + tse * coords[i0tg] ) + 00217 ada * ( tm1 * coords[ia0g] + tse * coords[iatg] ) ); 00218 00219 double* ai0k = &coords[VINDEX( k, 0, i )]; 00220 double* aiak = &coords[VINDEX( k, adaInts, i )]; 00221 double* a0jk = &coords[VINDEX( k, j, 0 )]; 00222 double* atjk = &coords[VINDEX( k, j, tseInts )]; 00223 double* aij0 = &coords[VINDEX( 0, j, i )]; 00224 double* aijg = &coords[VINDEX( gammaInts, j, i )]; 00225 00226 coords[VINDEX( i, j, k )] = ( am1 * ai0k[0] + ada * aiak[0] + tm1 * a0jk[0] + tse * atjk[0] + 00227 gm1 * aij0[0] + gamma * aijg[0] ) / 00228 2.0 - 00229 cX / 2.0; 00230 00231 coords[nelem + 1 + VINDEX( i, j, k )] = 00232 ( am1 * ai0k[nelem + 1] + ada * aiak[nelem + 1] + tm1 * a0jk[nelem + 1] + tse * atjk[nelem + 1] + 00233 gm1 * aij0[nelem + 1] + gamma * aijg[nelem + 1] ) / 00234 2.0 - 00235 cY / 2.0; 00236 00237 coords[2 * ( nelem + 1 ) + VINDEX( i, j, k )] = 00238 ( am1 * ai0k[2 * ( nelem + 1 )] + ada * aiak[2 * ( nelem + 1 )] + tm1 * a0jk[2 * ( nelem + 1 )] + 00239 tse * atjk[2 * ( nelem + 1 )] + gm1 * aij0[2 * ( nelem + 1 )] + 00240 gamma * aijg[2 * ( nelem + 1 )] ) / 00241 2.0 - 00242 cZ / 2.0; 00243 } 00244 } 00245 } 00246 00247 #else 00248 for( int i = 0; i < numv; i++ ) 00249 { 00250 for( int j = 0; j < numv; j++ ) 00251 { 00252 for( int k = 0; k < numv; k++ ) 00253 { 00254 idx = VINDEX( i, j, k ); 00255 // blocked coordinate ordering 00256 coords[idx] = i * scale1; 00257 coords[tot_numv + idx] = j * scale2; 00258 coords[2 * tot_numv + idx] = k * scale3; 00259 } 00260 } 00261 } 00262 #endif 00263 print_time( false, ttime1, utime1, stime1, imem, rmem ); 00264 // std::cout << "MOAB: TFI time = " << ttime1-ttime0 << " sec" 00265 // << std::endl; 00266 } 00267 00268 void build_connect( const int nelem, const EntityHandle /*vstart*/, int*& connect ) 00269 { 00270 // allocate the memory 00271 int nume_tot = nelem * nelem * nelem; 00272 connect = new int[8 * nume_tot]; 00273 00274 EntityHandle vijk; 00275 int numv = nelem + 1; 00276 int numv_sq = numv * numv; 00277 int idx = 0; 00278 for( int i = 0; i < nelem; i++ ) 00279 { 00280 for( int j = 0; j < nelem; j++ ) 00281 { 00282 for( int k = 0; k < nelem; k++ ) 00283 { 00284 vijk = VINDEX( i, j, k ); 00285 connect[idx++] = vijk; 00286 connect[idx++] = vijk + 1; 00287 connect[idx++] = vijk + 1 + numv; 00288 connect[idx++] = vijk + numv; 00289 connect[idx++] = vijk + numv * numv; 00290 connect[idx++] = vijk + 1 + numv * numv; 00291 connect[idx++] = vijk + 1 + numv + numv * numv; 00292 connect[idx++] = vijk + numv + numv * numv; 00293 assert( i <= numv * numv * numv ); 00294 } 00295 } 00296 } 00297 } 00298 00299 Interface* gMB; 00300 Tag pos_tag, pos2_tag; 00301 00302 void init() 00303 { 00304 gMB = new Core(); 00305 double def_val[3] = { 0.0, 0.0, 0.0 }; 00306 ErrorCode rval = 00307 gMB->tag_get_handle( "position_tag", 3, MB_TYPE_DOUBLE, pos_tag, MB_TAG_DENSE | MB_TAG_CREAT, def_val ); 00308 assert( MB_SUCCESS == rval ); 00309 if( rval ) 00310 { 00311 } // empty line to remove compiler warning 00312 rval = gMB->tag_get_handle( "position2_tag", 3, MB_TYPE_DOUBLE, pos2_tag, MB_TAG_DENSE | MB_TAG_CREAT, def_val ); 00313 assert( MB_SUCCESS == rval ); 00314 } 00315 00316 int main( int argc, char* argv[] ) 00317 { 00318 int nelem = 20; 00319 if( argc < 3 ) 00320 { 00321 std::cout << "Usage: " << argv[0] << " <ints_per_side> [A|B|C|D [1|2|3|4]|E]" << std::endl; 00322 return 1; 00323 } 00324 00325 char which_test = '\0'; 00326 int ver = 0; 00327 00328 sscanf( argv[1], "%d", &nelem ); 00329 if( argc >= 3 ) sscanf( argv[2], "%c", &which_test ); 00330 if( argc >= 4 ) sscanf( argv[3], "%d", &ver ); 00331 00332 if( 3 <= argc && which_test != 'A' && which_test != 'B' && which_test != 'C' && which_test != 'D' && 00333 which_test != 'E' ) 00334 { 00335 std::cout << "Must indicate A or B, C, D or E for test." << std::endl; 00336 return 1; 00337 } 00338 00339 if( 4 <= argc && which_test == 'D' && ( ver < 1 || ver > 4 ) ) 00340 { 00341 std::cout << "Must indicate version 1, 2, 3, or 4 for test D." << std::endl; 00342 return 1; 00343 } 00344 00345 // std::cout << "number of elements: " << nelem << "; test " 00346 // << which_test << std::endl; 00347 00348 // pre-build the coords array 00349 double* coords = NULL; 00350 build_coords( nelem, coords ); 00351 assert( NULL != coords ); 00352 00353 int* connect = NULL; 00354 00355 // test A: create structured mesh 00356 if( '\0' == which_test || 'A' == which_test ) testA( nelem, coords ); 00357 00358 build_connect( nelem, 1, connect ); 00359 00360 // test B: create mesh using bulk interface 00361 if( '\0' == which_test || 'B' == which_test ) testB( nelem, coords, connect ); 00362 00363 // test C: create mesh using individual interface 00364 if( '\0' == which_test || 'C' == which_test ) testC( nelem, coords ); 00365 00366 // test D: query mesh using iterators 00367 if( '\0' == which_test || 'D' == which_test ) testD( nelem, coords, ver ); 00368 00369 // test E: query mesh using direct access 00370 if( '\0' == which_test || 'E' == which_test ) testE( nelem, coords, connect ); 00371 00372 return 0; 00373 } 00374 00375 void query_elem_to_vert() 00376 { 00377 Range all_hexes; 00378 ErrorCode result = gMB->get_entities_by_type( 0, MBHEX, all_hexes ); 00379 RC( "query_elem_to_vert" ); 00380 const EntityHandle* connect; 00381 int num_connect; 00382 double dum_coords[24]; 00383 for( Range::iterator eit = all_hexes.begin(); eit != all_hexes.end(); ++eit ) 00384 { 00385 result = gMB->get_connectivity( *eit, connect, num_connect ); 00386 RC( "query_elem_to_vert" ); 00387 result = gMB->get_coords( connect, num_connect, dum_coords ); 00388 RC( "query_elem_to_vert" ); 00389 00390 // compute the centroid 00391 double centroid[3] = { 0.0, 0.0, 0.0 }; 00392 for( int j = 0; j < 8; j++ ) 00393 { 00394 centroid[0] += dum_coords[3 * j + 0]; 00395 centroid[1] += dum_coords[3 * j + 1]; 00396 centroid[2] += dum_coords[3 * j + 2]; 00397 } 00398 centroid[0] *= 0.125; 00399 centroid[1] *= 0.125; 00400 centroid[2] *= 0.125; 00401 result = gMB->tag_set_data( pos_tag, &( *eit ), 1, centroid ); 00402 RC( "query_elem_to_vert" ); 00403 } 00404 } 00405 00406 void query_vert_to_elem() 00407 { 00408 Range all_verts; 00409 std::vector< EntityHandle > neighbor_hexes; 00410 std::vector< double > neighbor_pos; 00411 double coords[3]; 00412 neighbor_pos.resize( 3 * 8 ); // average vertex will have 8 adjacent hexes 00413 ErrorCode result = gMB->get_entities_by_type( 0, MBVERTEX, all_verts ); 00414 RC( "query_vert_to_elem" ); 00415 for( Range::iterator vit = all_verts.begin(); vit != all_verts.end(); ++vit ) 00416 { 00417 neighbor_hexes.clear(); 00418 result = gMB->get_coords( &( *vit ), 1, coords ); 00419 RC( "query_vert_to_elem" ); 00420 result = gMB->get_adjacencies( &( *vit ), 1, 3, false, neighbor_hexes ); 00421 RC( "query_vert_to_elem" ); 00422 assert( neighbor_pos.size() >= 3 * neighbor_hexes.size() ); 00423 result = gMB->tag_get_data( pos2_tag, &neighbor_hexes[0], neighbor_hexes.size(), &neighbor_pos[0] ); 00424 RC( "query_vert_to_elem" ); 00425 for( unsigned int i = 0; i < neighbor_hexes.size(); i++ ) 00426 { 00427 neighbor_pos[3 * i] += coords[0]; 00428 neighbor_pos[3 * i + 1] += coords[1]; 00429 neighbor_pos[3 * i + 2] += coords[2]; 00430 } 00431 00432 result = gMB->tag_set_data( pos2_tag, &neighbor_hexes[0], neighbor_hexes.size(), &neighbor_pos[0] ); 00433 RC( "query_vert_to_elem" ); 00434 } 00435 00436 // get all hexes and divide pos_tag by 8; reuse all_verts 00437 result = normalize_elems( coords ); 00438 RC( "query_vert_to_elem" ); 00439 } 00440 00441 void query_elem_to_vert_iters( int chunk_size, 00442 bool check_valid, 00443 std::vector< EntityHandle >& connect, 00444 double* dum_coords, 00445 double* dum_pos ) 00446 { 00447 std::vector< EntityHandle > hexes; 00448 SetIterator* iter; 00449 ErrorCode result = gMB->create_set_iterator( 0, MBHEX, -1, chunk_size, check_valid, iter ); 00450 RC( "query_elem_to_vert_iters" ); 00451 bool atend = false; 00452 while( !atend ) 00453 { 00454 hexes.clear(); 00455 result = iter->get_next_arr( hexes, atend ); 00456 RC( "query_elem_to_vert_iters" ); 00457 result = gMB->get_connectivity( &hexes[0], hexes.size(), connect ); 00458 RC( "query_elem_to_vert_iters" ); 00459 result = gMB->get_coords( &connect[0], connect.size(), dum_coords ); 00460 RC( "query_elem_to_vert_iters" ); 00461 result = gMB->tag_get_data( pos_tag, &hexes[0], hexes.size(), dum_pos ); 00462 RC( "query_elem_to_vert_iters" ); 00463 for( unsigned int i = 0; i < hexes.size(); i++ ) 00464 { 00465 // compute the centroid 00466 for( int j = 0; j < 8; j++ ) 00467 { 00468 dum_pos[3 * i + 0] += dum_coords[24 * i + 3 * j]; 00469 dum_pos[3 * i + 1] += dum_coords[24 * i + 3 * j + 1]; 00470 dum_pos[3 * i + 2] += dum_coords[24 * i + 3 * j + 2]; 00471 } 00472 dum_pos[3 * i + 0] *= 0.125; 00473 dum_pos[3 * i + 1] *= 0.125; 00474 dum_pos[3 * i + 2] *= 0.125; 00475 } 00476 result = gMB->tag_set_data( pos_tag, &hexes[0], hexes.size(), dum_pos ); 00477 RC( "query_elem_to_vert_iters" ); 00478 } 00479 00480 delete iter; 00481 } 00482 00483 void query_vert_to_elem_iters( int chunk_size, 00484 bool check_valid, 00485 std::vector< EntityHandle >& /*connect*/, 00486 double* dum_coords, 00487 double* dum_pos ) 00488 { 00489 std::vector< EntityHandle > verts, neighbor_hexes; 00490 SetIterator* iter; 00491 ErrorCode result = gMB->create_set_iterator( 0, MBVERTEX, -1, chunk_size, check_valid, iter ); 00492 RC( "query_vert_to_elem_iters" ); 00493 assert( MB_SUCCESS == result ); 00494 bool atend = false; 00495 while( !atend ) 00496 { 00497 verts.clear(); 00498 result = iter->get_next_arr( verts, atend ); 00499 RC( "query_vert_to_elem_iters" ); 00500 result = gMB->get_coords( &verts[0], verts.size(), dum_coords ); 00501 RC( "query_vert_to_elem_iters" ); 00502 chunk_size = std::min( (int)verts.size(), chunk_size ); 00503 for( int i = 0; i < chunk_size; i++ ) 00504 { 00505 neighbor_hexes.clear(); 00506 result = gMB->get_adjacencies( &verts[i], 1, 3, false, neighbor_hexes ); 00507 RC( "query_vert_to_elem_iters" ); 00508 result = gMB->tag_get_data( pos2_tag, &neighbor_hexes[0], neighbor_hexes.size(), dum_pos ); 00509 RC( "query_vert_to_elem_iters" ); 00510 for( unsigned int j = 0; j < neighbor_hexes.size(); j++ ) 00511 { 00512 dum_pos[3 * j + 0] += dum_coords[3 * i + 0]; 00513 dum_pos[3 * j + 1] += dum_coords[3 * i + 1]; 00514 dum_pos[3 * j + 2] += dum_coords[3 * i + 2]; 00515 } 00516 result = gMB->tag_set_data( pos2_tag, &neighbor_hexes[0], neighbor_hexes.size(), dum_pos ); 00517 RC( "query_vert_to_elem_iters" ); 00518 } 00519 } 00520 00521 result = normalize_elems( dum_coords ); 00522 RC( "query_vert_to_elem_iters" ); 00523 } 00524 00525 // normalize pos_tag on all elems by 1/8; coords assumed large enough to hold 3 doubles 00526 ErrorCode normalize_elems( double* coords ) 00527 { 00528 // get all hexes and divide pos_tag by 8 00529 Range elems; 00530 ErrorCode result = gMB->get_entities_by_type( 0, MBHEX, elems ); 00531 RR( "normalize" ); 00532 00533 for( Range::iterator vit = elems.begin(); vit != elems.end(); ++vit ) 00534 { 00535 result = gMB->tag_get_data( pos2_tag, &( *vit ), 1, coords ); 00536 RR( "normalize" ); 00537 coords[0] *= 0.125; 00538 coords[1] *= 0.125; 00539 coords[2] *= 0.125; 00540 result = gMB->tag_set_data( pos2_tag, &( *vit ), 1, coords ); 00541 RR( "normalize" ); 00542 } 00543 00544 return result; 00545 } 00546 00547 void query_struct_elem_to_vert() 00548 { 00549 // assumes brick mapped mesh with handles starting at zero 00550 Range all_hexes; 00551 ErrorCode result = gMB->get_entities_by_type( 0, MBHEX, all_hexes ); 00552 RC( "query_struct_elem_to_vert" ); 00553 double dum_coords[24]; 00554 std::vector< EntityHandle > connect; 00555 for( Range::iterator eit = all_hexes.begin(); eit != all_hexes.end(); ++eit ) 00556 { 00557 result = gMB->get_connectivity( &( *eit ), 1, connect ); 00558 RC( "query_struct_elem_to_vert" ); 00559 result = gMB->get_coords( &connect[0], connect.size(), dum_coords ); 00560 RC( "query_struct_elem_to_vert" ); 00561 00562 double centroid[3] = { 0.0, 0.0, 0.0 }; 00563 for( int j = 0; j < 8; j++ ) 00564 { 00565 centroid[0] += dum_coords[3 * j + 0]; 00566 centroid[1] += dum_coords[3 * j + 1]; 00567 centroid[2] += dum_coords[3 * j + 2]; 00568 } 00569 centroid[0] *= 0.125; 00570 centroid[1] *= 0.125; 00571 centroid[2] *= 0.125; 00572 result = gMB->tag_set_data( pos_tag, &( *eit ), 1, centroid ); 00573 RC( "query_struct_elem_to_vert" ); 00574 } 00575 } 00576 00577 #if defined( _MSC_VER ) || defined( __MINGW32__ ) 00578 void print_time( const bool print_em, double& tot_time, double& utime, double& stime, long& imem, long& rmem ) 00579 { 00580 utime = (double)clock() / CLOCKS_PER_SEC; 00581 if( print_em ) std::cout << "Total wall time = " << utime << std::endl; 00582 tot_time = stime = 0; 00583 imem = rmem = 0; 00584 } 00585 #else 00586 void print_time( const bool print_em, double& tot_time, double& utime, double& stime, long& imem, long& rmem ) 00587 { 00588 struct rusage r_usage; 00589 getrusage( RUSAGE_SELF, &r_usage ); 00590 utime = (double)r_usage.ru_utime.tv_sec + ( (double)r_usage.ru_utime.tv_usec / 1.e6 ); 00591 stime = (double)r_usage.ru_stime.tv_sec + ( (double)r_usage.ru_stime.tv_usec / 1.e6 ); 00592 tot_time = utime + stime; 00593 if( print_em ) 00594 std::cout << "User, system, total time = " << utime << ", " << stime << ", " << tot_time << std::endl; 00595 #ifndef LINUX 00596 if( print_em ) 00597 { 00598 std::cout << "Max resident set size = " << r_usage.ru_maxrss << " kbytes" << std::endl; 00599 std::cout << "Int resident set size = " << r_usage.ru_idrss << std::endl; 00600 } 00601 imem = r_usage.ru_idrss; 00602 rmem = r_usage.ru_maxrss; 00603 #else 00604 system( "ps o args,drs,rss | grep perf | grep -v grep" ); // RedHat 9.0 doesnt fill in actual 00605 // memory data 00606 imem = rmem = 0; 00607 #endif 00608 } 00609 #endif 00610 00611 void testA( const int nelem, const double* coords ) 00612 { 00613 double ttime0 = 0.0, ttime1 = 0.0, ttime2 = 0.0, ttime3 = 0.0, ttime4 = 0.0, utime = 0.0, stime = 0.0; 00614 long imem0 = 0, rmem0 = 0, imem1 = 0, rmem1 = 0, imem2 = 0, rmem2 = 0, imem3 = 0, rmem3 = 0, imem4 = 0, rmem4 = 0; 00615 00616 print_time( false, ttime0, utime, stime, imem0, rmem0 ); 00617 00618 // make a 3d block of vertices 00619 EntitySequence* dum_seq = NULL; 00620 ScdVertexData* vseq = NULL; 00621 StructuredElementSeq* eseq = NULL; 00622 init(); 00623 Core* mbcore = dynamic_cast< Core* >( gMB ); 00624 assert( mbcore != NULL ); 00625 SequenceManager* seq_mgr = mbcore->sequence_manager(); 00626 HomCoord vseq_minmax[2] = { HomCoord( 0, 0, 0 ), HomCoord( nelem, nelem, nelem ) }; 00627 EntityHandle vstart, estart; 00628 00629 ErrorCode result = seq_mgr->create_scd_sequence( vseq_minmax[0], vseq_minmax[1], MBVERTEX, 1, vstart, dum_seq ); 00630 RC( "testA" ); 00631 if( NULL != dum_seq ) vseq = dynamic_cast< ScdVertexData* >( dum_seq->data() ); 00632 assert( MB_FAILURE != result && vstart != 0 && dum_seq != NULL && vseq != NULL ); 00633 // now the element sequence 00634 result = seq_mgr->create_scd_sequence( vseq_minmax[0], vseq_minmax[1], MBHEX, 1, estart, dum_seq ); 00635 if( NULL != dum_seq ) eseq = dynamic_cast< StructuredElementSeq* >( dum_seq ); 00636 assert( MB_FAILURE != result && estart != 0 && dum_seq != NULL && eseq != NULL ); 00637 00638 // only need to add one vseq to this, unity transform 00639 // trick: if I know it's going to be unity, just input 3 sets of equivalent points 00640 result = eseq->sdata()->add_vsequence( vseq, vseq_minmax[0], vseq_minmax[0], vseq_minmax[0], vseq_minmax[0], 00641 vseq_minmax[0], vseq_minmax[0] ); 00642 assert( MB_SUCCESS == result ); 00643 00644 // set the coordinates of the vertices 00645 EntityHandle handle; 00646 int i; 00647 double dumv[3]; 00648 int num_verts = ( nelem + 1 ) * ( nelem + 1 ) * ( nelem + 1 ); 00649 for( i = 0, handle = vstart; i < num_verts; i++, handle++ ) 00650 { 00651 dumv[0] = coords[i]; 00652 dumv[1] = coords[num_verts + i]; 00653 dumv[2] = coords[2 * num_verts + i]; 00654 result = gMB->set_coords( &handle, 1, dumv ); 00655 assert( MB_SUCCESS == result ); 00656 } 00657 00658 print_time( false, ttime1, utime, stime, imem1, rmem1 ); 00659 00660 // query the mesh 2 ways 00661 query_struct_elem_to_vert(); 00662 00663 print_time( false, ttime2, utime, stime, imem2, rmem2 ); 00664 00665 query_vert_to_elem(); 00666 00667 print_time( false, ttime3, utime, stime, imem3, rmem3 ); 00668 00669 #ifndef NDEBUG 00670 check_answers( "A" ); 00671 #endif 00672 00673 delete gMB; 00674 00675 print_time( false, ttime4, utime, stime, imem4, rmem4 ); 00676 00677 std::cout << "MOAB_scd:nelem,construct,e_to_v,v_to_e,after_dtor,total= " << nelem << " " << ttime1 - ttime0 << " " 00678 << ttime2 - ttime1 << " " << ttime3 - ttime2 << " " << ttime4 - ttime3 << " " << ttime4 - ttime0 00679 << " seconds" << std::endl; 00680 std::cout << "MOAB_scd_memory(rss):initial,after_construction,e-v,v-e,after_dtor= " << rmem0 << " " << rmem1 << " " 00681 << rmem2 << " " << rmem3 << " " << rmem4 << " kb" << std::endl; 00682 } 00683 00684 void testB( const int nelem, const double* coords, int* connect ) 00685 { 00686 double ttime0 = 0.0, ttime1 = 0.0, ttime2 = 0.0, ttime3 = 0.0, ttime4 = 0.0, utime = 0.0, stime = 0.0; 00687 long imem0 = 0, rmem0 = 0, imem1 = 0, rmem1 = 0, imem2 = 0, rmem2 = 0, imem3 = 0, rmem3 = 0, imem4 = 0, rmem4 = 0; 00688 00689 print_time( false, ttime0, utime, stime, imem0, rmem0 ); 00690 00691 int num_verts = ( nelem + 1 ) * ( nelem + 1 ) * ( nelem + 1 ); 00692 int num_elems = nelem * nelem * nelem; 00693 EntityHandle vstart, estart; 00694 00695 // get the read interface 00696 ReadUtilIface* readMeshIface; 00697 init(); 00698 gMB->query_interface( readMeshIface ); 00699 00700 // create a sequence to hold the node coordinates 00701 // get the current number of entities and start at the next slot 00702 std::vector< double* > coord_arrays; 00703 ErrorCode result = readMeshIface->get_node_coords( 3, num_verts, 1, vstart, coord_arrays ); 00704 RC( "testB" ); 00705 assert( MB_SUCCESS == result && 1 == vstart && coord_arrays[0] && coord_arrays[1] && coord_arrays[2] ); 00706 // memcpy the coordinate data into place 00707 memcpy( coord_arrays[0], coords, sizeof( double ) * num_verts ); 00708 memcpy( coord_arrays[1], &coords[num_verts], sizeof( double ) * num_verts ); 00709 memcpy( coord_arrays[2], &coords[2 * num_verts], sizeof( double ) * num_verts ); 00710 00711 EntityHandle* conn = 0; 00712 result = readMeshIface->get_element_connect( num_elems, 8, MBHEX, 1, estart, conn ); 00713 assert( MB_SUCCESS == result ); 00714 for( int i = 0; i < num_elems * 8; i++ ) 00715 conn[i] = vstart + connect[i]; 00716 00717 delete[] connect; 00718 00719 result = readMeshIface->update_adjacencies( estart, num_elems, 8, conn ); 00720 assert( MB_SUCCESS == result ); 00721 00722 print_time( false, ttime1, utime, stime, imem1, rmem1 ); 00723 00724 // query the mesh 2 ways 00725 query_elem_to_vert(); 00726 00727 print_time( false, ttime2, utime, stime, imem2, rmem2 ); 00728 00729 query_vert_to_elem(); 00730 00731 print_time( false, ttime3, utime, stime, imem3, rmem3 ); 00732 00733 #ifndef NDEBUG 00734 check_answers( "B" ); 00735 #endif 00736 00737 delete gMB; 00738 00739 print_time( false, ttime4, utime, stime, imem4, rmem4 ); 00740 00741 std::cout << "MOAB_ucd_blocked:nelem,construct,e_to_v,v_to_e,after_dtor,total= " << nelem << " " << ttime1 - ttime0 00742 << " " << ttime2 - ttime1 << " " << ttime3 - ttime2 << " " << ttime4 - ttime3 << " " << ttime4 - ttime0 00743 << " seconds" << std::endl; 00744 std::cout << "MOAB_ucdblocked_memory_(rss):initial,after_construction,e-v,v-e,after_dtor= " << rmem0 << " " << rmem1 00745 << " " << rmem2 << " " << rmem3 << " " << rmem4 << " kb" << std::endl; 00746 } 00747 00748 void testC( const int nelem, const double* coords ) 00749 { 00750 double ttime0 = 0.0, ttime1 = 0.0, ttime2 = 0.0, ttime3 = 0.0, ttime4 = 0.0, utime = 0.0, stime = 0.0; 00751 long imem0 = 0, rmem0 = 0, imem1 = 0, rmem1 = 0, imem2 = 0, rmem2 = 0, imem3 = 0, rmem3 = 0, imem4 = 0, rmem4 = 0; 00752 00753 print_time( false, ttime0, utime, stime, imem0, rmem0 ); 00754 00755 // create the vertices; assume we don't need to keep a list of vertex handles, since they'll 00756 // be created in sequence 00757 int numv = nelem + 1; 00758 int numv_sq = numv * numv; 00759 int num_verts = numv * numv * numv; 00760 double dum_coords[3] = { coords[0], coords[num_verts], coords[2 * num_verts] }; 00761 EntityHandle vstart; 00762 00763 init(); 00764 ErrorCode result = gMB->create_vertex( dum_coords, vstart ); 00765 RC( "testC" ); 00766 assert( MB_SUCCESS == result && 1 == vstart ); 00767 00768 EntityHandle dum_vert, vijk; 00769 int i; 00770 for( i = 1; i < num_verts; i++ ) 00771 { 00772 dum_coords[0] = coords[i]; 00773 dum_coords[1] = coords[num_verts + i]; 00774 dum_coords[2] = coords[2 * num_verts + i]; 00775 result = gMB->create_vertex( dum_coords, dum_vert ); 00776 assert( MB_SUCCESS == result ); 00777 } 00778 00779 EntityHandle dum_conn[8]; 00780 for( i = 0; i < nelem; i++ ) 00781 { 00782 for( int j = 0; j < nelem; j++ ) 00783 { 00784 for( int k = 0; k < nelem; k++ ) 00785 { 00786 vijk = vstart + VINDEX( i, j, k ); 00787 dum_conn[0] = vijk; 00788 dum_conn[1] = vijk + 1; 00789 dum_conn[2] = vijk + 1 + numv; 00790 dum_conn[3] = vijk + numv; 00791 dum_conn[4] = vijk + numv * numv; 00792 dum_conn[5] = vijk + 1 + numv * numv; 00793 dum_conn[6] = vijk + 1 + numv + numv * numv; 00794 dum_conn[7] = vijk + numv + numv * numv; 00795 result = gMB->create_element( MBHEX, dum_conn, 8, dum_vert ); 00796 assert( MB_SUCCESS == result ); 00797 } 00798 } 00799 } 00800 00801 print_time( false, ttime1, utime, stime, imem1, rmem1 ); 00802 00803 // query the mesh 2 ways 00804 query_elem_to_vert(); 00805 00806 print_time( false, ttime2, utime, stime, imem2, rmem2 ); 00807 00808 query_vert_to_elem(); 00809 00810 print_time( false, ttime3, utime, stime, imem3, rmem3 ); 00811 00812 #ifndef NDEBUG 00813 check_answers( "C" ); 00814 #endif 00815 00816 delete gMB; 00817 00818 print_time( false, ttime4, utime, stime, imem4, rmem4 ); 00819 00820 std::cout << "MOAB_ucd_indiv:nelem,construct,e_to_v,v_to_e,after_dtor,total= " << nelem << " " << ttime1 - ttime0 00821 << " " << ttime2 - ttime1 << " " << ttime3 - ttime2 << " " << ttime4 - ttime3 << " " << ttime4 - ttime0 00822 << " seconds" << std::endl; 00823 std::cout << "MOAB_ucd_indiv_memory_(rss):initial,after_construction,e-v,v-e,after_dtor= " << rmem0 << " " << rmem1 00824 << " " << rmem2 << " " << rmem3 << " " << rmem4 << " kb" << std::endl; 00825 } 00826 00827 void testD( const int nelem, const double* coords, int ver ) 00828 { 00829 double ttime0 = 0.0, ttime1 = 0.0, ttime2 = 0.0, ttime3 = 0.0, ttime4 = 0.0, ttime5 = 0.0, ttime6 = 0.0, 00830 ttime7 = 0.0, ttime8 = 0.0, ttime9 = 0.0, ttime10 = 0.0, utime = 0.0, stime = 0.0; 00831 long imem0 = 0, rmem0 = 0, imem1 = 0, rmem1 = 0, imem2 = 0, rmem2 = 0, imem3 = 0, rmem3 = 0, imem4 = 0, rmem4 = 0, 00832 imem5 = 0, rmem5 = 0, imem6 = 0, rmem6 = 0, imem7 = 0, rmem7 = 0, imem8 = 0, rmem8 = 0, imem9 = 0, rmem9 = 0, 00833 imem10 = 0, rmem10 = 0; 00834 00835 print_time( false, ttime0, utime, stime, imem0, rmem0 ); 00836 00837 // create the vertices; assume we don't need to keep a list of vertex handles, since they'll 00838 // be created in sequence 00839 int numv = nelem + 1; 00840 int numv_sq = numv * numv; 00841 int num_verts = numv * numv * numv; 00842 std::vector< double > dum_coords( 24 ), dum_pos( 24 ); 00843 dum_coords[0] = coords[0]; 00844 dum_coords[1] = coords[num_verts]; 00845 dum_coords[2] = coords[2 * num_verts]; 00846 EntityHandle vstart; 00847 00848 init(); 00849 ErrorCode result = gMB->create_vertex( &dum_coords[0], vstart ); 00850 RC( "testD" ); 00851 assert( MB_SUCCESS == result && 1 == vstart ); 00852 00853 EntityHandle dum_vert, vijk; 00854 int i; 00855 for( i = 1; i < num_verts; i++ ) 00856 { 00857 dum_coords[0] = coords[i]; 00858 dum_coords[1] = coords[num_verts + i]; 00859 dum_coords[2] = coords[2 * num_verts + i]; 00860 result = gMB->create_vertex( &dum_coords[0], dum_vert ); 00861 assert( MB_SUCCESS == result ); 00862 } 00863 00864 EntityHandle dum_conn[8]; 00865 for( i = 0; i < nelem; i++ ) 00866 { 00867 for( int j = 0; j < nelem; j++ ) 00868 { 00869 for( int k = 0; k < nelem; k++ ) 00870 { 00871 vijk = vstart + VINDEX( i, j, k ); 00872 dum_conn[0] = vijk; 00873 dum_conn[1] = vijk + 1; 00874 dum_conn[2] = vijk + 1 + numv; 00875 dum_conn[3] = vijk + numv; 00876 dum_conn[4] = vijk + numv * numv; 00877 dum_conn[5] = vijk + 1 + numv * numv; 00878 dum_conn[6] = vijk + 1 + numv + numv * numv; 00879 dum_conn[7] = vijk + numv + numv * numv; 00880 result = gMB->create_element( MBHEX, dum_conn, 8, dum_vert ); 00881 assert( MB_SUCCESS == result ); 00882 } 00883 } 00884 } 00885 00886 print_time( false, ttime1, utime, stime, imem1, rmem1 ); 00887 00888 // query the mesh 2 ways with !check_valid 00889 std::vector< EntityHandle > connect( 8 ); 00890 #ifndef NDEBUG 00891 // used only in debug mode 00892 double def_val[3] = { 0.0, 0.0, 0.0 }; 00893 #endif 00894 if( ver == 0 || ver == 1 ) 00895 { 00896 query_elem_to_vert_iters( 1, false, connect, &dum_coords[0], &dum_pos[0] ); 00897 print_time( false, ttime2, utime, stime, imem2, rmem2 ); 00898 query_vert_to_elem_iters( 1, false, connect, &dum_coords[0], &dum_pos[0] ); 00899 print_time( false, ttime3, utime, stime, imem3, rmem3 ); 00900 #ifndef NDEBUG 00901 check_answers( "D" ); 00902 result = gMB->tag_delete( pos_tag ); 00903 assert( MB_SUCCESS == result ); 00904 result = 00905 gMB->tag_get_handle( "position_tag", 3, MB_TYPE_DOUBLE, pos_tag, MB_TAG_DENSE | MB_TAG_CREAT, def_val ); 00906 assert( MB_SUCCESS == result ); 00907 result = gMB->tag_delete( pos2_tag ); 00908 assert( MB_SUCCESS == result ); 00909 result = 00910 gMB->tag_get_handle( "position2_tag", 3, MB_TYPE_DOUBLE, pos2_tag, MB_TAG_DENSE | MB_TAG_CREAT, def_val ); 00911 assert( MB_SUCCESS == result ); 00912 #endif 00913 } 00914 00915 if( ver == 0 || ver == 2 ) 00916 { 00917 if( ver != 0 ) print_time( false, ttime3, utime, stime, imem3, rmem3 ); 00918 query_elem_to_vert_iters( 1, true, connect, &dum_coords[0], &dum_pos[0] ); 00919 print_time( false, ttime4, utime, stime, imem4, rmem4 ); 00920 query_vert_to_elem_iters( 1, true, connect, &dum_coords[0], &dum_pos[0] ); 00921 print_time( false, ttime5, utime, stime, imem5, rmem5 ); 00922 #ifndef NDEBUG 00923 check_answers( "D" ); 00924 result = gMB->tag_delete( pos_tag ); 00925 assert( MB_SUCCESS == result ); 00926 result = 00927 gMB->tag_get_handle( "position_tag", 3, MB_TYPE_DOUBLE, pos_tag, MB_TAG_DENSE | MB_TAG_CREAT, def_val ); 00928 assert( MB_SUCCESS == result ); 00929 result = gMB->tag_delete( pos2_tag ); 00930 assert( MB_SUCCESS == result ); 00931 result = 00932 gMB->tag_get_handle( "position2_tag", 3, MB_TYPE_DOUBLE, pos2_tag, MB_TAG_DENSE | MB_TAG_CREAT, def_val ); 00933 assert( MB_SUCCESS == result ); 00934 #endif 00935 } 00936 00937 if( ver == 0 || ver >= 3 ) 00938 { 00939 dum_coords.resize( 2400 ); 00940 dum_pos.resize( 300 ); 00941 } 00942 if( ver == 0 || ver == 3 ) 00943 { 00944 if( ver != 0 ) print_time( false, ttime5, utime, stime, imem3, rmem3 ); 00945 query_elem_to_vert_iters( 100, false, connect, &dum_coords[0], &dum_pos[0] ); 00946 print_time( false, ttime6, utime, stime, imem6, rmem6 ); 00947 query_vert_to_elem_iters( 100, false, connect, &dum_coords[0], &dum_pos[0] ); 00948 print_time( false, ttime7, utime, stime, imem7, rmem7 ); 00949 #ifndef NDEBUG 00950 check_answers( "D" ); 00951 result = gMB->tag_delete( pos_tag ); 00952 assert( MB_SUCCESS == result ); 00953 result = 00954 gMB->tag_get_handle( "position_tag", 3, MB_TYPE_DOUBLE, pos_tag, MB_TAG_DENSE | MB_TAG_CREAT, def_val ); 00955 assert( MB_SUCCESS == result ); 00956 result = gMB->tag_delete( pos2_tag ); 00957 assert( MB_SUCCESS == result ); 00958 result = 00959 gMB->tag_get_handle( "position2_tag", 3, MB_TYPE_DOUBLE, pos2_tag, MB_TAG_DENSE | MB_TAG_CREAT, def_val ); 00960 assert( MB_SUCCESS == result ); 00961 #endif 00962 } 00963 00964 if( ver == 0 || ver == 4 ) 00965 { 00966 if( ver != 0 ) print_time( false, ttime7, utime, stime, imem3, rmem3 ); 00967 query_elem_to_vert_iters( 100, true, connect, &dum_coords[0], &dum_pos[0] ); 00968 print_time( false, ttime8, utime, stime, imem8, rmem8 ); 00969 query_vert_to_elem_iters( 100, true, connect, &dum_coords[0], &dum_pos[0] ); 00970 print_time( false, ttime9, utime, stime, imem9, rmem9 ); 00971 #ifndef NDEBUG 00972 check_answers( "D" ); 00973 result = gMB->tag_delete( pos_tag ); 00974 assert( MB_SUCCESS == result ); 00975 result = 00976 gMB->tag_get_handle( "position_tag", 3, MB_TYPE_DOUBLE, pos_tag, MB_TAG_DENSE | MB_TAG_CREAT, def_val ); 00977 assert( MB_SUCCESS == result ); 00978 result = gMB->tag_delete( pos2_tag ); 00979 assert( MB_SUCCESS == result ); 00980 result = 00981 gMB->tag_get_handle( "position2_tag", 3, MB_TYPE_DOUBLE, pos2_tag, MB_TAG_DENSE | MB_TAG_CREAT, def_val ); 00982 assert( MB_SUCCESS == result ); 00983 #endif 00984 } 00985 00986 if( ver > 0 && ver < 4 ) print_time( false, ttime9, utime, stime, imem9, rmem9 ); 00987 delete gMB; 00988 00989 print_time( false, ttime10, utime, stime, imem10, rmem10 ); 00990 00991 if( ver == 0 || ver == 1 ) 00992 { 00993 std::cout << "MOAB_ucd_iters_!check_valid_1:nelem,construct,e-v,v-e,after_dtor,total= " << nelem << " " 00994 << ttime1 - ttime0 << " " << ttime2 - ttime1 << " " << ttime3 - ttime2 << " " << ttime10 - ttime9 00995 << " " << ttime3 - ttime0 + ttime10 - ttime9 << std::endl; 00996 std::cout << "MOAB_ucd_iters_memory_(rss)_!check_valid_1:initial,after_construction,e-v,v-" 00997 "e,after_dtor= " 00998 << rmem0 << " " << rmem1 << " " << rmem2 << " " << rmem3 << " " << rmem10 << " kb" << std::endl; 00999 } 01000 if( ver == 0 || ver == 2 ) 01001 { 01002 std::cout << "MOAB_ucd_iters_check_valid_1:nelem,construct,e-v,v-e,after_dtor,total= " << nelem << " " 01003 << ttime1 - ttime0 << " " << ttime4 - ttime3 << " " << ttime5 - ttime4 << " " << ttime10 - ttime9 01004 << " " << ttime1 - ttime0 + ttime5 - ttime3 + ttime10 - ttime9 << std::endl; 01005 std::cout << "MOAB_ucd_iters_memory_(rss)_check_valid_1:initial,after_construction,e-v,v-e," 01006 "after_dtor= " 01007 << rmem0 << " " << rmem1 << " " << rmem2 << " " << rmem3 << " " << rmem10 << " kb" << std::endl; 01008 } 01009 if( ver == 0 || ver == 3 ) 01010 { 01011 std::cout << "MOAB_ucd_iters_!check_valid_100:nelem,construct,e-v,v-e,after_dtor,total= " << nelem << " " 01012 << ttime1 - ttime0 << " " << ttime6 - ttime5 << " " << ttime7 - ttime6 << " " << ttime10 - ttime9 01013 << " " << ttime1 - ttime0 + ttime7 - ttime5 + ttime10 - ttime9 << std::endl; 01014 std::cout << "MOAB_ucd_iters_memory_(rss)_!check_valid_100:initial,after_construction,e-v," 01015 "v-e,after_dtor= " 01016 << rmem0 << " " << rmem1 << " " << rmem6 << " " << rmem7 << " " << rmem10 << " kb" << std::endl; 01017 } 01018 if( ver == 0 || ver == 4 ) 01019 { 01020 std::cout << "MOAB_ucd_iters_check_valid_100:nelem,construct,e-v,v-e,after_dtor,total= " << nelem << " " 01021 << ttime1 - ttime0 << " " << ttime8 - ttime7 << " " << ttime9 - ttime8 << " " << ttime10 - ttime9 01022 << " " << ttime1 - ttime0 + ttime10 - ttime7 << std::endl; 01023 std::cout << "MOAB_ucd_iters_memory_(rss)_check_valid_100:initial,after_construction,e-v,v-" 01024 "e,after_dtor= " 01025 << rmem0 << " " << rmem1 << " " << rmem8 << " " << rmem9 << " " << rmem10 << " kb" << std::endl; 01026 } 01027 } 01028 01029 void testE( const int nelem, const double* coords, int* connect ) 01030 { 01031 double ttime0 = 0.0, ttime1 = 0.0, ttime2 = 0.0, ttime3 = 0.0, ttime4 = 0.0, ttime5 = 0.0, ttime6 = 0.0, 01032 utime = 0.0, stime = 0.0; 01033 long imem0 = 0, rmem0 = 0, imem1 = 0, rmem1 = 0, imem2 = 0, rmem2 = 0, imem3 = 0, rmem3 = 0, imem4 = 0, rmem4 = 0, 01034 imem5 = 0, rmem5 = 0, imem6 = 0, rmem6 = 0; 01035 01036 print_time( false, ttime0, utime, stime, imem0, rmem0 ); 01037 01038 int num_verts = ( nelem + 1 ) * ( nelem + 1 ) * ( nelem + 1 ); 01039 int num_elems = nelem * nelem * nelem; 01040 EntityHandle vstart, estart; 01041 01042 // get the read interface 01043 ReadUtilIface* readMeshIface; 01044 init(); 01045 gMB->query_interface( readMeshIface ); 01046 01047 // create a sequence to hold the node coordinates 01048 // get the current number of entities and start at the next slot 01049 std::vector< double* > coord_arrays; 01050 ErrorCode result = readMeshIface->get_node_coords( 3, num_verts, 1, vstart, coord_arrays ); 01051 RC( "testE" ); 01052 assert( MB_SUCCESS == result && 1 == vstart && coord_arrays[0] && coord_arrays[1] && coord_arrays[2] ); 01053 // memcpy the coordinate data into place 01054 memcpy( coord_arrays[0], coords, sizeof( double ) * num_verts ); 01055 memcpy( coord_arrays[1], &coords[num_verts], sizeof( double ) * num_verts ); 01056 memcpy( coord_arrays[2], &coords[2 * num_verts], sizeof( double ) * num_verts ); 01057 01058 EntityHandle* conn = 0; 01059 result = readMeshIface->get_element_connect( num_elems, 8, MBHEX, 1, estart, conn ); 01060 assert( MB_SUCCESS == result ); 01061 for( int i = 0; i < num_elems * 8; i++ ) 01062 conn[i] = vstart + connect[i]; 01063 01064 delete[] connect; 01065 01066 Range verts( vstart, vstart + num_verts - 1 ), elems( estart, estart + num_elems - 1 ); 01067 01068 result = readMeshIface->update_adjacencies( estart, num_elems, 8, conn ); 01069 assert( MB_SUCCESS == result ); 01070 01071 print_time( false, ttime1, utime, stime, imem1, rmem1 ); 01072 01073 // query the mesh 2 ways 01074 query_elem_to_vert_direct(); 01075 01076 print_time( false, ttime2, utime, stime, imem2, rmem2 ); 01077 01078 query_vert_to_elem_direct(); 01079 01080 print_time( false, ttime3, utime, stime, imem3, rmem3 ); 01081 01082 #ifndef NDEBUG 01083 check_answers( "E" ); 01084 #endif 01085 01086 query_elem_to_vert_direct(); 01087 01088 print_time( false, ttime4, utime, stime, imem4, rmem4 ); 01089 01090 query_vert_to_elem_direct(); 01091 01092 print_time( false, ttime5, utime, stime, imem5, rmem5 ); 01093 01094 #ifndef NDEBUG 01095 check_answers( "E" ); 01096 #endif 01097 01098 delete gMB; 01099 01100 print_time( false, ttime6, utime, stime, imem6, rmem6 ); 01101 01102 std::cout << "MOAB_ucd_direct:nelem,construct,e_to_v,v_to_e,after_dtor,total= " << nelem << " " << ttime1 - ttime0 01103 << " " << ttime2 - ttime1 << " " << ttime3 - ttime2 << " " << ttime6 - ttime5 << " " 01104 << ttime3 - ttime0 + ttime6 - ttime5 << " seconds" << std::endl; 01105 std::cout << "MOAB_ucd_direct_memory_(rss):initial,after_construction,e-v,v-e,after_dtor= " << rmem0 << " " << rmem1 01106 << " " << rmem2 << " " << rmem3 << " " << rmem6 << " kb" << std::endl; 01107 01108 std::cout << "MOAB_ucd_direct2:nelem,construct,e_to_v,v_to_e,after_dtor,total= " << nelem << " " << ttime1 - ttime0 01109 << " " << ttime4 - ttime3 << " " << ttime5 - ttime4 << " " << ttime6 - ttime5 << " " 01110 << ttime1 - ttime0 + ttime6 - ttime3 << " seconds" << std::endl; 01111 std::cout << "MOAB_ucd_direct2_memory_(rss):initial,after_construction,e-v,v-e,after_dtor= " << rmem0 << " " 01112 << rmem1 << " " << rmem4 << " " << rmem5 << " " << rmem6 << " kb" << std::endl; 01113 } 01114 01115 void query_elem_to_vert_direct() 01116 { 01117 Range all_hexes, all_verts; 01118 ErrorCode result = gMB->get_entities_by_type( 0, MBHEX, all_hexes ); 01119 assert( MB_SUCCESS == result ); 01120 result = gMB->get_entities_by_type( 0, MBVERTEX, all_verts ); 01121 RC( "query_elem_to_vert_direct" ); 01122 EntityHandle* connect; 01123 int ecount, vcount, vpere; 01124 double* coords[3]; 01125 01126 result = gMB->connect_iterate( all_hexes.begin(), all_hexes.end(), connect, vpere, ecount ); 01127 if( MB_SUCCESS != result || ecount != (int)all_hexes.size() ) 01128 { 01129 std::cout << "FAILED in connect_iterate!" << std::endl; 01130 return; 01131 } 01132 result = gMB->coords_iterate( all_verts.begin(), all_verts.end(), coords[0], coords[1], coords[2], vcount ); 01133 if( MB_SUCCESS != result || vcount != (int)all_verts.size() ) 01134 { 01135 std::cout << "FAILED in coords_iterate!" << std::endl; 01136 return; 01137 } 01138 double* centroid; 01139 result = gMB->tag_iterate( pos_tag, all_hexes.begin(), all_hexes.end(), ecount, (void*&)centroid ); 01140 if( MB_SUCCESS != result || ecount != (int)all_hexes.size() ) 01141 { 01142 std::cout << "FAILED in connect_iterate!" << std::endl; 01143 return; 01144 } 01145 01146 EntityHandle vstart = *all_verts.begin(); 01147 for( int i = 0; i < ecount; i++ ) 01148 { 01149 // compute the centroid 01150 for( int j = 0; j < vpere; j++ ) 01151 { 01152 int vind = *connect - vstart; 01153 connect++; 01154 centroid[3 * i + 0] += coords[0][vind]; 01155 centroid[3 * i + 1] += coords[1][vind]; 01156 centroid[3 * i + 2] += coords[2][vind]; 01157 } 01158 01159 // now normalize 01160 centroid[3 * i + 0] *= 0.125; 01161 centroid[3 * i + 1] *= 0.125; 01162 centroid[3 * i + 2] *= 0.125; 01163 } 01164 } 01165 01166 void query_vert_to_elem_direct() 01167 { 01168 Range all_verts, tmp_ents; 01169 ErrorCode result = gMB->get_entities_by_type( 0, MBVERTEX, all_verts ); 01170 assert( MB_SUCCESS == result ); 01171 01172 // make sure vertex-element adjacencies are created 01173 result = gMB->get_adjacencies( &( *all_verts.begin() ), 1, 3, false, tmp_ents ); 01174 assert( MB_SUCCESS == result ); 01175 01176 const std::vector< EntityHandle >** adjs; 01177 int count; 01178 result = gMB->adjacencies_iterate( all_verts.begin(), all_verts.end(), adjs, count ); 01179 if( MB_SUCCESS != result && count != (int)all_verts.size() ) 01180 { 01181 std::cout << "FAILED:adjacencies_iterate." << std::endl; 01182 return; 01183 } 01184 01185 double* coords[3]; 01186 result = gMB->coords_iterate( all_verts.begin(), all_verts.end(), coords[0], coords[1], coords[2], count ); 01187 if( MB_SUCCESS != result || count != (int)all_verts.size() ) 01188 { 01189 std::cout << "FAILED in coords_iterate!" << std::endl; 01190 return; 01191 } 01192 // get all hexes, then iterator over pos2_tag 01193 double* centroid; 01194 int ecount; 01195 tmp_ents.clear(); 01196 result = gMB->get_entities_by_type( 0, MBHEX, tmp_ents ); 01197 assert( MB_SUCCESS == result ); 01198 result = gMB->tag_iterate( pos2_tag, tmp_ents.begin(), tmp_ents.end(), ecount, (void*&)centroid ); 01199 if( MB_SUCCESS != result || ecount != (int)tmp_ents.size() ) 01200 { 01201 std::cout << "FAILED in tag_iterate!" << std::endl; 01202 return; 01203 } 01204 01205 int i; 01206 Range::iterator vit; 01207 EntityHandle estart = *tmp_ents.begin(); 01208 for( vit = all_verts.begin(), i = 0; vit != all_verts.end(); ++vit, i++ ) 01209 { 01210 assert( adjs[i] ); 01211 for( std::vector< EntityHandle >::const_iterator vit2 = adjs[i]->begin(); vit2 != adjs[i]->end(); ++vit2 ) 01212 if( *vit >= estart ) 01213 { 01214 int eind = *vit2 - estart; 01215 centroid[3 * eind + 0] += coords[0][i]; 01216 centroid[3 * eind + 1] += coords[1][i]; 01217 centroid[3 * eind + 2] += coords[2][i]; 01218 } 01219 } 01220 01221 // now normalize 01222 for( i = 0; i < (int)tmp_ents.size(); i++ ) 01223 { 01224 centroid[3 * i + 0] *= 0.125; 01225 centroid[3 * i + 1] *= 0.125; 01226 centroid[3 * i + 2] *= 0.125; 01227 } 01228 } 01229 01230 void check_answers( const char* /*test_name*/ ) 01231 { 01232 Range elems; 01233 ErrorCode result = gMB->get_entities_by_type( 0, MBHEX, elems ); 01234 RC( "check_answers" ); 01235 01236 double coords1[3], coords2[3], del[3]; 01237 double diff = 0.0; 01238 for( Range::iterator vit = elems.begin(); vit != elems.end(); ++vit ) 01239 { 01240 result = gMB->tag_get_data( pos_tag, &( *vit ), 1, coords1 ); 01241 RC( "check_answers" ); 01242 result = gMB->tag_get_data( pos2_tag, &( *vit ), 1, coords2 ); 01243 RC( "check_answers" ); 01244 for( int i = 0; i < 3; i++ ) 01245 del[i] = fabs( coords1[i] - coords2[i] ); 01246 if( del[0] || del[1] || del[2] ) 01247 { 01248 double len2 = std::max( coords1[0] * coords1[0] + coords1[1] * coords1[1] + coords1[2] * coords1[2], 01249 coords2[0] * coords2[0] + coords2[1] * coords2[1] + coords2[2] * coords2[2] ), 01250 num = del[0] * del[0] + del[1] * del[1] + del[2] * del[2]; 01251 if( len2 > 0.0 ) 01252 diff = std::max( diff, num / sqrt( len2 ) ); 01253 else if( num > 0.0 ) 01254 diff = sqrt( num ); 01255 } 01256 } 01257 if( diff > 0.0 ) std::cout << "Max relative difference = " << diff << std::endl; 01258 }
