MOAB: Mesh Oriented datABase
(version 5.4.1)
Include dependency graph for dump_sets.c:Go to the source code of this file.
Defines | |
| #define | CHECK |
Functions | |
| void | dump_sets (mhdf_FileHandle file) |
| void | dump_set_contents (long first, long num_sets, const int *flags, const long *end_indices, const long *contents) |
| void | dump_set_list (long id, const long *array, long count) |
| void | dump_set_ranges (long id, const long *array, long count) |
| int | main (int argc, char *argv[]) |
Variables | |
| int | WIDTH |
| #define CHECK |
do \ { \ if( mhdf_isError( &status ) ) \ { \ fprintf( stderr, "mhdf error at %s:%d : \"%s\"\n", __FILE__, __LINE__, mhdf_message( &status ) ); \ exit( 2 ); \ } \ } while( 0 )
Definition at line 6 of file dump_sets.c.
Referenced by dump_sets(), and main().
| void dump_set_contents | ( | long | first, |
| long | num_sets, | ||
| const int * | flags, | ||
| const long * | end_indices, | ||
| const long * | contents | ||
Definition at line 136 of file dump_sets.c.
References dump_set_list(), dump_set_ranges(), and mhdf_SET_RANGE_BIT.
Referenced by dump_sets().
long prev = -1;
long i, end;
for( i = 0; i < num_sets; ++i )
end = end_indices[i];
if( end < prev )
fprintf( stderr, "Invalid end index for set %ld (ID %ld): %ld following %ld\n", i, first + i, end, prev );
exit( 2 );
if( flags && ( flags[i] & mhdf_SET_RANGE_BIT ) )
dump_set_ranges( i + first, contents + prev + 1, end - prev );
else
dump_set_list( i + first, contents + prev + 1, end - prev );
prev = end;
| void dump_set_list | ( | long | id, |
| const long * | array, | ||
| long | count | ||
Definition at line 161 of file dump_sets.c.
References WIDTH.
Referenced by dump_set_contents().
long i;
if( !count ) return; /* skip empty sets */
printf( "%*ld: %ld", WIDTH, id, array[0] );
for( i = 1; i < count; ++i )
printf( ", %ld", array[i] );
printf( " (%ld)\n", count );
| void dump_set_ranges | ( | long | id, |
| long | count | ||
Definition at line 173 of file dump_sets.c.
References WIDTH.
long i, n = 0;
printf( "%*ld:", WIDTH, id );
if( count % 2 )
puts( " <INVALID DATA LENGTH FOR RANGED LIST>\n" );
return;
for( i = 0; i < count; i += 2 )
if( array[i + 1] > 1 )
printf( " %ld-%ld", array[i], array[i] + array[i + 1] - 1 );
else
printf( " %ld", array[i] );
if( i + 2 < count ) putchar( ',' );
n += array[i + 1];
printf( " (%ld)\n", n );
| void dump_sets | ( | mhdf_FileHandle | file | ) |
Definition at line 50 of file dump_sets.c.
References CHECK, dump_set_contents(), moab::GeomUtil::first(), mhdf_closeData(), mhdf_openSetChildren(), mhdf_openSetData(), mhdf_openSetMeta(), mhdf_openSetParents(), mhdf_readSetChildEndIndices(), mhdf_readSetContentEndIndices(), mhdf_readSetData(), mhdf_readSetFlags(), mhdf_readSetParentEndIndices(), and mhdf_readSetParentsChildren().
Referenced by main().
long *end_indices, *data, *new_data;
int* flags;
long num_sets, first, num_data;
hid_t meta, handle;
mhdf_Status status;
meta = mhdf_openSetMeta( file, &num_sets, &first, &status );
CHECK;
end_indices = malloc( num_sets * sizeof( long ) );
printf( "\nSet IDs: %ld - %ld\n", first, first + num_sets - 1 );
puts( "\nSets:\n" );
flags = malloc( num_sets * sizeof( int ) );
mhdf_readSetFlags( meta, 0, num_sets, H5T_NATIVE_INT, flags, &status );
CHECK;
mhdf_readSetContentEndIndices( meta, 0, num_sets, H5T_NATIVE_LONG, end_indices, &status );
CHECK;
handle = mhdf_openSetData( file, &num_data, &status );
CHECK;
data = malloc( num_data * sizeof( long ) );
mhdf_readSetData( handle, 0, num_data, H5T_NATIVE_LONG, data, &status );
CHECK;
mhdf_closeData( file, handle, &status );
CHECK;
dump_set_contents( first, num_sets, flags, end_indices, data );
free( flags );
puts( "\nSet Children:\n" );
mhdf_readSetChildEndIndices( meta, 0, num_sets, H5T_NATIVE_LONG, end_indices, &status );
CHECK;
handle = mhdf_openSetChildren( file, &num_data, &status );
CHECK;
new_data = realloc( data, num_data * sizeof( long ) );
if( !new_data )
fprintf( stderr, "dump_sets.c::dump_sets(): reallocation of data failed\n" );
free( data );
free( end_indices );
CHECK;
mhdf_closeData( file, meta, &status );
CHECK;
return;
else
data = new_data;
mhdf_readSetParentsChildren( handle, 0, num_data, H5T_NATIVE_LONG, data, &status );
CHECK;
CHECK;
dump_set_contents( first, num_sets, NULL, end_indices, data );
puts( "\nSet Parents:\n" );
mhdf_readSetParentEndIndices( meta, 0, num_sets, H5T_NATIVE_LONG, end_indices, &status );
CHECK;
handle = mhdf_openSetParents( file, &num_data, &status );
CHECK;
if( !new_data )
free( data );
CHECK;
CHECK;
return;
else
data = new_data;
CHECK;
CHECK;
free( data );
CHECK;
| int main | ( | int | argc, |
| char * | argv[] | ||
Definition at line 23 of file dump_sets.c.
References CHECK, dump_sets(), mhdf_closeFile(), mhdf_openFile(), and WIDTH.
mhdf_Status status;
mhdf_FileHandle file;
unsigned long max_id;
if( argc != 2 )
fprintf( stderr, "Usage: %s <input_file>\n", argv[0] );
return 1;
file = mhdf_openFile( argv[1], 0, &max_id, -1, &status );
CHECK;
WIDTH = 1;
while( max_id >= 10 )
max_id /= 10;
++WIDTH;
dump_sets( file );
mhdf_closeFile( file, &status );
CHECK;
return 0;
| int WIDTH |
Definition at line 21 of file dump_sets.c.
Referenced by dump_set_list(), dump_set_ranges(), and main().
