MOAB: Mesh Oriented datABase
(version 5.4.1)
#include "moab/Core.hpp"#include "moab_mpi.h"#include "moab/ParallelComm.hpp"#include "MBParallelConventions.h"#include "moab/iMOAB.h"#include "TestUtil.hpp"#include "moab/CpuTimer.hpp"#include "moab/ProgOptions.hpp"#include <iostream>#include <sstream>#include "imoab_coupler_utils.hpp"
Include dependency graph for imoab_setwithGid.cpp:Go to the source code of this file.
Functions | |
| int | main (int argc, char *argv[]) |
| int main | ( | int | argc, |
| char * | argv[] | ||
Definition at line 31 of file imoab_setwithGid.cpp.
References ProgOptions::addOpt(), CHECKIERR, DENSE_DOUBLE, DENSE_INTEGER, fileWriteOptions(), ierr, iMOAB_AppID, iMOAB_DefineTagStorage(), iMOAB_DeregisterApplication(), iMOAB_Finalize(), iMOAB_GetDoubleTagStorage(), iMOAB_GetIntTagStorage(), iMOAB_GetMeshInfo(), iMOAB_Initialize(), iMOAB_LoadMesh(), iMOAB_RegisterApplication(), iMOAB_SetDoubleTagStorageWithGid(), iMOAB_WriteMesh(), jgroup, MPI_COMM_WORLD, nghlay, numProcesses, ProgOptions::parseCommandLine(), rankInGlobalComm, readopts(), and tagname.
int ierr;
int rankInGlobalComm, numProcesses;
MPI_Group jgroup;
std::string readoptsLnd( "PARALLEL=READ_PART;PARTITION=PARALLEL_PARTITION" );
std::string readopts( "PARALLEL=READ_PART;PARTITION=PARALLEL_PARTITION;PARALLEL_RESOLVE_SHARED_ENTS" );
// Timer data
moab::CpuTimer timer;
double timer_ops;
std::string opName;
MPI_Init( &argc, &argv );
MPI_Comm_rank( MPI_COMM_WORLD, &rankInGlobalComm );
MPI_Comm_size( MPI_COMM_WORLD, &numProcesses );
MPI_Comm dup_comm_world;
MPI_Comm_dup( MPI_COMM_WORLD, &dup_comm_world );
std::string lndMoab = TestDir + "unittest/recLand.h5m";
std::string lndMct = TestDir + "unittest/WHOLE_cx_lnd.h5m";
std::string tagname("frac");
int entType = 0;
int ntags = 1;
int nghlay = 0; // no ghosts
ierr = iMOAB_Initialize( argc, argv ); // not really needed anything from argc, argv, yet; maybe we should
CHECKIERR( ierr, "Cannot initialize iMOAB" )
ProgOptions opts;
opts.addOpt< std::string >( "source,s", "mct mesh filename (source)", &lndMct );
opts.addOpt< std::string >( "target,t", "moab mesh filename (target)", &lndMoab );
opts.addOpt< std::string >( "tags,g", "list of tags, colon separated", &tagname );
opts.addOpt< int >( "enttype,e", "entity type for moab mesh (0 point cloud, 1 cells)", &entType );
opts.addOpt< int >( "ntags,n", "number of tags to set", &ntags );
opts.parseCommandLine( argc, argv );
int cplLndAppID = -1, cplLnd2AppID = -1; // -1 means it is not initialized
iMOAB_AppID cplLndPID = &cplLndAppID; // land on coupler PEs, moab dist
iMOAB_AppID cplLnd2PID = &cplLnd2AppID; // land on coupler PEs, MCT dist
int cpllnd = 9, cpllnd2 = 109;
ierr = iMOAB_RegisterApplication( "LNDX", &dup_comm_world, &cpllnd,
cplLndPID ); // mesh on coupler pes
CHECKIERR( ierr, "Cannot register LNDX over coupler PEs" )
ierr = iMOAB_RegisterApplication( "LNDX2", &dup_comm_world, &cpllnd2,
cplLnd2PID ); // mesh on coupler pes, MCT distr, point cloud
CHECKIERR( ierr, "Cannot register LNDX2 over coupler PEs" )
if (entType == 1)
ierr = iMOAB_LoadMesh( cplLndPID, lndMoab.c_str(), readopts.c_str(), &nghlay ); // moab mesh can be cells
else // entType == 0
ierr = iMOAB_LoadMesh( cplLndPID, lndMoab.c_str(), readoptsLnd.c_str(), &nghlay ); // moab mesh is point cloud
CHECKIERR( ierr, "Cannot load moab mesh on coupler pes" )
ierr = iMOAB_LoadMesh( cplLnd2PID, lndMct.c_str(), readoptsLnd.c_str(), &nghlay );
CHECKIERR( ierr, "Cannot load mct point cloud on coupler pes" )
int nverts[3], nelem[3];
int tagType[2] = { DENSE_DOUBLE, DENSE_INTEGER};
int sizeTag = 1;
int tagIndex = -1;
* Each process in the communicator will have access to a local mesh instance, which will
* contain the original cells in the local partition and ghost entities. Number of vertices,
* primary cells, visible blocks, number of sidesets and nodesets boundary conditions will be
* returned in size 3 arrays, for local, ghost and total numbers.
ierr = iMOAB_GetMeshInfo( cplLnd2PID, nverts, nelem, 0, 0, 0 );
CHECKIERR( ierr, "Cannot get info on mct mesh on coupler pes" )
std::vector<int> gids(nverts[0]);
int nvals = nverts[0]*ntags;
std::vector<double> fracts(nvals);
ierr = iMOAB_DefineTagStorage( cplLnd2PID, tagname.c_str(), &tagType[0], &sizeTag, &tagIndex );
CHECKIERR( ierr, "Cannot define frac tag" )
ierr = iMOAB_DefineTagStorage( cplLnd2PID, "GLOBAL_ID", &tagType[1], &sizeTag, &tagIndex );
CHECKIERR( ierr, "Cannot define gid tag" )
int mctEntType = 0; // vertex
ierr = iMOAB_GetDoubleTagStorage( cplLnd2PID, tagname.c_str(), &nvals, &mctEntType, &fracts[0] );
CHECKIERR( ierr, "Cannot get frac tag on lnd2 on coupler pes" )
ierr = iMOAB_GetIntTagStorage( cplLnd2PID, "GLOBAL_ID", &nverts[0], &mctEntType, &gids[0] );
CHECKIERR( ierr, "Cannot get global id tag on lnd2 on coupler pes" )
// now on moab mesh
ierr = iMOAB_DefineTagStorage( cplLndPID, tagname.c_str(), &tagType[0], &sizeTag, &tagIndex );
CHECKIERR( ierr, "Cannot define list of tags" )
ierr = iMOAB_SetDoubleTagStorageWithGid(cplLndPID, tagname.c_str(), &nvals, &entType, &fracts[0], &gids[0] );
CHECKIERR( ierr, "Cannot set double tag with global ids " )
char fileWriteOptions[] = "PARALLEL=WRITE_PART";
char outputFileLnd[] = "recvLnd4.h5m";
ierr = iMOAB_WriteMesh( cplLndPID, outputFileLnd, fileWriteOptions );
CHECKIERR( ierr, "cannot write lnd mesh after setting tag" )
ierr = iMOAB_DeregisterApplication( cplLnd2PID );
CHECKIERR( ierr, "cannot deregister app LNDX2" )
ierr = iMOAB_DeregisterApplication( cplLndPID );
CHECKIERR( ierr, "cannot deregister app LNDX" )
ierr = iMOAB_Finalize();
CHECKIERR( ierr, "did not finalize iMOAB" )
MPI_Comm_free(&dup_comm_world );
MPI_Finalize();
return 0;
