MOAB: Mesh Oriented datABase
(version 5.4.1)
00001 /* 00002 * This imoab_setwithGid test will test the method 00003 * iMOAB_SetDoubleTagStorageWithGid, that is used in parallel 00004 * basically, 2 moab apps have different distribution of the same mesh, and use the method to 00005 * set the tag from one app to the other 00006 * 2 meshes are distributed differently, and each will be loaded in an app. GlobalId tag are the same 00007 * for both 00008 * example came from mct instance, and need to set the frac tag according to our moab variant of the 00009 * coupler distribution of the same mesh. 00010 00011 */ 00012 00013 #include "moab/Core.hpp" 00014 00015 // MPI includes 00016 #include "moab_mpi.h" 00017 #include "moab/ParallelComm.hpp" 00018 #include "MBParallelConventions.h" 00019 00020 #include "moab/iMOAB.h" 00021 #include "TestUtil.hpp" 00022 #include "moab/CpuTimer.hpp" 00023 #include "moab/ProgOptions.hpp" 00024 #include <iostream> 00025 #include <sstream> 00026 // CHECKIERR 00027 #include "imoab_coupler_utils.hpp" 00028 00029 using namespace moab; 00030 00031 int main( int argc, char* argv[] ) 00032 { 00033 int ierr; 00034 int rankInGlobalComm, numProcesses; 00035 MPI_Group jgroup; 00036 std::string readoptsLnd( "PARALLEL=READ_PART;PARTITION=PARALLEL_PARTITION" ); 00037 std::string readopts( "PARALLEL=READ_PART;PARTITION=PARALLEL_PARTITION;PARALLEL_RESOLVE_SHARED_ENTS" ); 00038 00039 // Timer data 00040 moab::CpuTimer timer; 00041 double timer_ops; 00042 std::string opName; 00043 00044 MPI_Init( &argc, &argv ); 00045 MPI_Comm_rank( MPI_COMM_WORLD, &rankInGlobalComm ); 00046 MPI_Comm_size( MPI_COMM_WORLD, &numProcesses ); 00047 00048 MPI_Comm dup_comm_world; 00049 MPI_Comm_dup( MPI_COMM_WORLD, &dup_comm_world ); 00050 00051 std::string lndMoab = TestDir + "unittest/recLand.h5m"; 00052 std::string lndMct = TestDir + "unittest/WHOLE_cx_lnd.h5m"; 00053 std::string tagname("frac"); 00054 int entType = 0; 00055 int ntags = 1; 00056 int nghlay = 0; // no ghosts 00057 00058 ierr = iMOAB_Initialize( argc, argv ); // not really needed anything from argc, argv, yet; maybe we should 00059 CHECKIERR( ierr, "Cannot initialize iMOAB" ) 00060 00061 ProgOptions opts; 00062 opts.addOpt< std::string >( "source,s", "mct mesh filename (source)", &lndMct ); 00063 00064 opts.addOpt< std::string >( "target,t", "moab mesh filename (target)", &lndMoab ); 00065 00066 opts.addOpt< std::string >( "tags,g", "list of tags, colon separated", &tagname ); 00067 00068 opts.addOpt< int >( "enttype,e", "entity type for moab mesh (0 point cloud, 1 cells)", &entType ); 00069 00070 opts.addOpt< int >( "ntags,n", "number of tags to set", &ntags ); 00071 00072 opts.parseCommandLine( argc, argv ); 00073 00074 int cplLndAppID = -1, cplLnd2AppID = -1; // -1 means it is not initialized 00075 iMOAB_AppID cplLndPID = &cplLndAppID; // land on coupler PEs, moab dist 00076 iMOAB_AppID cplLnd2PID = &cplLnd2AppID; // land on coupler PEs, MCT dist 00077 int cpllnd = 9, cpllnd2 = 109; 00078 ierr = iMOAB_RegisterApplication( "LNDX", &dup_comm_world, &cpllnd, 00079 cplLndPID ); // mesh on coupler pes 00080 CHECKIERR( ierr, "Cannot register LNDX over coupler PEs" ) 00081 ierr = iMOAB_RegisterApplication( "LNDX2", &dup_comm_world, &cpllnd2, 00082 cplLnd2PID ); // mesh on coupler pes, MCT distr, point cloud 00083 CHECKIERR( ierr, "Cannot register LNDX2 over coupler PEs" ) 00084 00085 if (entType == 1) 00086 { 00087 ierr = iMOAB_LoadMesh( cplLndPID, lndMoab.c_str(), readopts.c_str(), &nghlay ); // moab mesh can be cells 00088 } 00089 else // entType == 0 00090 { 00091 ierr = iMOAB_LoadMesh( cplLndPID, lndMoab.c_str(), readoptsLnd.c_str(), &nghlay ); // moab mesh is point cloud 00092 } 00093 00094 CHECKIERR( ierr, "Cannot load moab mesh on coupler pes" ) 00095 00096 ierr = iMOAB_LoadMesh( cplLnd2PID, lndMct.c_str(), readoptsLnd.c_str(), &nghlay ); 00097 CHECKIERR( ierr, "Cannot load mct point cloud on coupler pes" ) 00098 00099 int nverts[3], nelem[3]; 00100 int tagType[2] = { DENSE_DOUBLE, DENSE_INTEGER}; 00101 int sizeTag = 1; 00102 int tagIndex = -1; 00103 /* 00104 * Each process in the communicator will have access to a local mesh instance, which will 00105 * contain the original cells in the local partition and ghost entities. Number of vertices, 00106 * primary cells, visible blocks, number of sidesets and nodesets boundary conditions will be 00107 * returned in size 3 arrays, for local, ghost and total numbers. 00108 */ 00109 ierr = iMOAB_GetMeshInfo( cplLnd2PID, nverts, nelem, 0, 0, 0 ); 00110 CHECKIERR( ierr, "Cannot get info on mct mesh on coupler pes" ) 00111 std::vector<int> gids(nverts[0]); 00112 int nvals = nverts[0]*ntags; 00113 std::vector<double> fracts(nvals); 00114 ierr = iMOAB_DefineTagStorage( cplLnd2PID, tagname.c_str(), &tagType[0], &sizeTag, &tagIndex ); 00115 CHECKIERR( ierr, "Cannot define frac tag" ) 00116 00117 ierr = iMOAB_DefineTagStorage( cplLnd2PID, "GLOBAL_ID", &tagType[1], &sizeTag, &tagIndex ); 00118 CHECKIERR( ierr, "Cannot define gid tag" ) 00119 00120 int mctEntType = 0; // vertex 00121 ierr = iMOAB_GetDoubleTagStorage( cplLnd2PID, tagname.c_str(), &nvals, &mctEntType, &fracts[0] ); 00122 CHECKIERR( ierr, "Cannot get frac tag on lnd2 on coupler pes" ) 00123 00124 ierr = iMOAB_GetIntTagStorage( cplLnd2PID, "GLOBAL_ID", &nverts[0], &mctEntType, &gids[0] ); 00125 CHECKIERR( ierr, "Cannot get global id tag on lnd2 on coupler pes" ) 00126 00127 // now on moab mesh 00128 ierr = iMOAB_DefineTagStorage( cplLndPID, tagname.c_str(), &tagType[0], &sizeTag, &tagIndex ); 00129 CHECKIERR( ierr, "Cannot define list of tags" ) 00130 00131 ierr = iMOAB_SetDoubleTagStorageWithGid(cplLndPID, tagname.c_str(), &nvals, &entType, &fracts[0], &gids[0] ); 00132 CHECKIERR( ierr, "Cannot set double tag with global ids " ) 00133 00134 char fileWriteOptions[] = "PARALLEL=WRITE_PART"; 00135 char outputFileLnd[] = "recvLnd4.h5m"; 00136 ierr = iMOAB_WriteMesh( cplLndPID, outputFileLnd, fileWriteOptions ); 00137 CHECKIERR( ierr, "cannot write lnd mesh after setting tag" ) 00138 00139 ierr = iMOAB_DeregisterApplication( cplLnd2PID ); 00140 CHECKIERR( ierr, "cannot deregister app LNDX2" ) 00141 ierr = iMOAB_DeregisterApplication( cplLndPID ); 00142 CHECKIERR( ierr, "cannot deregister app LNDX" ) 00143 00144 ierr = iMOAB_Finalize(); 00145 CHECKIERR( ierr, "did not finalize iMOAB" ) 00146 00147 MPI_Comm_free(&dup_comm_world ); 00148 MPI_Finalize(); 00149 return 0; 00150 }
