MOAB: Mesh Oriented datABase
(version 5.4.1)
#include "ReadNCDF.hpp"#include "netcdf.h"#include <algorithm>#include <string>#include <cassert>#include <cstdio>#include <cstring>#include <cmath>#include <sstream>#include <iostream>#include <map>#include "moab/CN.hpp"#include "moab/Range.hpp"#include "moab/Interface.hpp"#include "ExoIIUtil.hpp"#include "MBTagConventions.hpp"#include "Internals.hpp"#include "moab/ReadUtilIface.hpp"#include "exodus_order.h"#include "moab/FileOptions.hpp"#include "moab/AdaptiveKDTree.hpp"#include "moab/CartVect.hpp"
Include dependency graph for ReadNCDF.cpp:Go to the source code of this file.
Namespaces | |
| namespace | moab |
Class representing axis-aligned bounding box. | |
Defines | |
| #define | INS_ID(stringvar, prefix, id) sprintf( stringvar, prefix, id ) |
| #define | GET_DIM(ncdim, name, val) |
| #define | GET_DIMB(ncdim, name, varname, id, val) |
| #define | GET_VAR(name, id, dims) |
| #define | GET_1D_INT_VAR(name, id, vals) |
| #define | GET_1D_DBL_VAR(name, id, vals) |
| #define GET_1D_DBL_VAR | ( | name, | |
| id, | |||
| vals | |||
std::vector< int > dum_dims; \
GET_VAR( name, id, dum_dims ); \
if( -1 != ( id ) ) \
size_t ntmp; \
int dvfail = nc_inq_dimlen( ncFile, dum_dims[0], &ntmp ); \
if( NC_NOERR != dvfail ) \
MB_SET_ERR( MB_FAILURE, "ReadNCDF:: Couldn't get dimension length" ); \
( vals ).resize( ntmp ); \
size_t ntmp1 = 0; \
dvfail = nc_get_vara_double( ncFile, id, &ntmp1, &ntmp, &( vals )[0] ); \
MB_SET_ERR( MB_FAILURE, "ReadNCDF:: Problem getting variable " << ( name ) ); \
Definition at line 113 of file ReadNCDF.cpp.
Referenced by moab::ReadNCDF::create_ss_elements(), moab::ReadNCDF::read_nodesets(), and moab::ReadNCDF::update().
| #define GET_1D_INT_VAR | ( | name, | |
| id, | |||
| vals | |||
GET_VAR( name, id, vals ); \
size_t ntmp; \
int ivfail = nc_inq_dimlen( ncFile, ( vals )[0], &ntmp ); \
if( NC_NOERR != ivfail ) \
size_t ntmp1 = 0; \
ivfail = nc_get_vara_int( ncFile, id, &ntmp1, &ntmp, &( vals )[0] ); \
Definition at line 92 of file ReadNCDF.cpp.
Referenced by moab::ReadNCDF::read_block_headers(), moab::ReadNCDF::read_face_blocks_headers(), moab::ReadNCDF::read_global_ids(), moab::ReadNCDF::read_nodesets(), moab::ReadNCDF::read_sidesets(), moab::ReadNCDF::read_tag_values(), and moab::ReadNCDF::update().
| #define GET_DIM | ( | ncdim, | |
| name, | |||
| val | |||
int gdfail = nc_inq_dimid( ncFile, name, &( ncdim ) ); \
if( NC_NOERR == gdfail ) \
size_t tmp_val; \
gdfail = nc_inq_dimlen( ncFile, ncdim, &tmp_val ); \
if( NC_NOERR != gdfail ) \
else \
( val ) = tmp_val; \
else \
( val ) = 0; \
Definition at line 50 of file ReadNCDF.cpp.
Referenced by moab::ReadNCDF::read_exodus_header(), moab::ReadNCDF::read_qa_information(), and moab::ReadNCDF::update().
| #define GET_DIMB | ( | ncdim, | |
| name, | |||
| varname, | |||
| id, | |||
| val | |||
INS_ID( name, varname, id ); \ GET_DIM( ncdim, name, val );
Definition at line 68 of file ReadNCDF.cpp.
Referenced by moab::ReadNCDF::read_block_headers(), moab::ReadNCDF::read_elements(), moab::ReadNCDF::read_face_blocks_headers(), moab::ReadNCDF::read_nodesets(), moab::ReadNCDF::read_polyhedra_faces(), and moab::ReadNCDF::read_sidesets().
| #define GET_VAR | ( | name, | |
| id, | |||
| dims | |||
( id ) = -1; \
int gvfail = nc_inq_varid( ncFile, name, &( id ) ); \
if( NC_NOERR == gvfail ) \
int ndims; \
gvfail = nc_inq_varndims( ncFile, id, &ndims ); \
( dims ).resize( ndims ); \
gvfail = nc_inq_vardimid( ncFile, id, &( dims )[0] ); \
if( NC_NOERR != gvfail ) \
MB_SET_ERR( MB_FAILURE, "ReadNCDF:: Couldn't get variable dimension IDs" ); \
Definition at line 72 of file ReadNCDF.cpp.
Referenced by moab::ReadNCDF::read_elements(), moab::ReadNCDF::read_polyhedra_faces(), moab::ReadNCDF::read_qa_string(), and moab::ReadNCDF::update().
| #define INS_ID | ( | stringvar, | |
| prefix, | |||
| id | |||
| ) | sprintf( stringvar, prefix, id ) |
Definition at line 48 of file ReadNCDF.cpp.
Referenced by moab::ReadNCDF::create_ss_elements(), moab::ReadNCDF::read_elements(), moab::ReadNCDF::read_nodesets(), moab::ReadNCDF::read_polyhedra_faces(), and moab::ReadNCDF::read_sidesets().
