MOAB: Mesh Oriented datABase
(version 5.4.1)
00001 /** 00002 * MOAB, a Mesh-Oriented datABase, is a software component for creating, 00003 * storing and accessing finite element mesh data. 00004 * 00005 * Copyright 2004 Sandia Corporation. Under the terms of Contract 00006 * DE-AC04-94AL85000 with Sandia Corporation, the U.S. Government 00007 * retains certain rights in this software. 00008 * 00009 * This library is free software; you can redistribute it and/or 00010 * modify it under the terms of the GNU Lesser General Public 00011 * License as published by the Free Software Foundation; either 00012 * version 2.1 of the License, or (at your option) any later version. 00013 * 00014 */ 00015 00016 #ifndef EXOII_UTIL 00017 #define EXOII_UTIL 00018 00019 // 00020 // ExoIIUtil class: utility class for functions used by both reader 00021 // and writer 00022 00023 #ifndef IS_BUILDING_MB 00024 #error "ExoIIUtil.hpp isn't supposed to be included into an application" 00025 #endif 00026 00027 #include "moab/Forward.hpp" 00028 #include "moab/ExoIIInterface.hpp" 00029 00030 namespace moab 00031 { 00032 00033 class ExoIIUtil : public ExoIIInterface 00034 { 00035 00036 Interface* mMB; 00037 00038 public: 00039 ExoIIUtil( Interface* mdb ) : mMB( mdb ) {} 00040 ~ExoIIUtil() {} 00041 00042 //! given the element name, return the type 00043 virtual ExoIIElementType element_name_to_type( const char* name ) 00044 { 00045 return static_element_name_to_type( name ); 00046 } 00047 00048 //! get the element type of the entity; this entity can either be a meshset, 00049 //! in which case it will be assumed to be a material set meshset, or an 00050 //! individual entity. 00051 virtual ExoIIElementType get_element_type( EntityHandle entity, 00052 Tag mid_nodes_tag, 00053 Tag geom_dimension_tag, 00054 EntityType indiv_entity_type = MBMAXTYPE ) 00055 { 00056 return static_get_element_type( mMB, entity, mid_nodes_tag, geom_dimension_tag, indiv_entity_type ); 00057 } 00058 00059 virtual void has_mid_nodes( ExoIIElementType elem_type, int* array ) 00060 { 00061 array[0] = HasMidNodes[elem_type][0]; 00062 array[1] = HasMidNodes[elem_type][1]; 00063 array[2] = HasMidNodes[elem_type][2]; 00064 array[3] = HasMidNodes[elem_type][3]; 00065 } 00066 00067 virtual int has_mid_nodes( ExoIIElementType elem_type, int dimension ) 00068 { 00069 return HasMidNodes[elem_type][dimension]; 00070 } 00071 00072 virtual int geometric_dimension( const ExoIIElementType elem_type ) 00073 { 00074 return ElementGeometricDimension[elem_type]; 00075 } 00076 00077 virtual const char* element_type_name( ExoIIElementType type ) 00078 { 00079 return ElementTypeNames[type]; 00080 } 00081 00082 //! given the element name, return the type 00083 static ExoIIElementType static_element_name_to_type( const char* name ); 00084 00085 //! get the element type of the entity; this entity can either be a meshset, in which 00086 //! case it will be assumed to be a material set meshset, or an individual entity. If a 00087 //! meshset, and indiv_entity_type is input, that type is used to start the search for 00088 //! the connectivity tag which determines how many vertices per entity are defined for that 00089 //! meshset 00090 static ExoIIElementType static_get_element_type( Interface* mdbImpl, 00091 const EntityHandle entity, 00092 const Tag mid_nodes_tag, 00093 const Tag geom_dimension_tag, 00094 const EntityType indiv_entity_type = MBMAXTYPE ); 00095 00096 //! given the number of vertices in an entity, and optionally the entity type and 00097 //! geometric dimension, return the corresponding exodusII element type; dimension defaults 00098 //! to 3 following TSTT convention 00099 static ExoIIElementType get_element_type_from_num_verts( const int num_verts, 00100 const EntityType entity_type = MBMAXTYPE, 00101 const int dimension = 3 ); 00102 00103 //! the MB entity type used for each element type 00104 static const EntityType ExoIIElementMBEntity[]; 00105 00106 //! names for all the element types that MB ExoII reader supports 00107 static const char* ElementTypeNames[]; 00108 00109 //! number of vertices per element 00110 static const int VerticesPerElement[]; 00111 00112 //! HasMidNode[elem_type][dim] = 1 denotes that elem_type has mid-nodes 00113 //! on sub-entities of dimension dim 00114 static const int HasMidNodes[][4]; 00115 00116 //! geometric dimension of each element 00117 static const int ElementGeometricDimension[]; 00118 }; 00119 00120 //! postfix increment operator for EntityType 00121 inline ExoIIElementType operator++( ExoIIElementType& type, int ) 00122 { 00123 return (ExoIIElementType)( ( (int&)type )++ ); 00124 } 00125 00126 //! prefix increment operator for EntityType 00127 inline ExoIIElementType& operator++( ExoIIElementType& type ) 00128 { 00129 return (ExoIIElementType&)( ++( (int&)type ) ); 00130 } 00131 00132 } // namespace moab 00133 00134 #endif
