MOAB: Mesh Oriented datABase
(version 5.4.1)
Include dependency graph for parse.cpp:Go to the source code of this file.
Functions | |
| void | tag_syntax (std::ostream &s) |
| static bool | is_platform_little_endian () |
| static void * | parse_values (const char *vals, DataType type, int size) |
| static unsigned char * | parse_opaque_value (const char *vals, int size) |
| template<typename T > | |
| T * | parse_values_typed (const char *vals, int size) |
| int | parse_value (const char *&iter, T &value) |
| static int | hexdigit (char c) |
| template<> | |
| int | parse_value< double > (const char *&iter, double &value) |
| int | parse_tag_spec (char *name, TagSpec &result, Interface *iface) |
| int | parse_tag_create (char *name, TagSpec &result, Interface *iface) |
| int hexdigit | ( | char | c | ) | [static] |
Definition at line 100 of file parse.cpp.
Referenced by parse_opaque_value().
if( c >= '0' && c <= '9' )
return c - '0';
else if( c >= 'a' && c <= 'f' )
return 10 + c - 'a';
else if( c >= 'A' && c <= 'F' )
return 10 + c - 'A';
else
return -1;
| static bool is_platform_little_endian | ( | ) | [inline, static] |
Definition at line 65 of file parse.cpp.
static const unsigned int one = 1;
static const bool little = !*( (char*)&one );
return little;
| unsigned char * parse_opaque_value | ( | const char * | vals, |
| int | size | ||
| ) | [static] |
Definition at line 112 of file parse.cpp.
References hexdigit(), is_platform_little_endian(), and size.
Referenced by parse_values().
unsigned char* data = (unsigned char*)malloc( size );
if( vals[0] && vals[0] == '0' && vals[1] && toupper( vals[1] ) == 'X' )
unsigned char *iter, *end;
int step;
if( is_platform_little_endian() )
iter = data;
end = data + size;
step = 1;
else
iter = data + size - 1;
end = data - 1;
step = -1;
const char* vals_end = vals + 1;
const char* vals_iter = vals + strlen( vals ) - 1;
for( ; iter != end; iter += step )
int less = 0;
int most = 0;
if( vals_iter != vals_end )
less = hexdigit( *vals_iter );
--vals_iter;
most = hexdigit( *vals_iter );
--vals_iter;
if( less < 0 || most < 0 )
std::cerr << "Error parsing hex value: " << vals << std::endl;
free( data );
return 0;
*iter = 16 * most + less;
else
memset( data, 0, size );
strcpy( (char*)data, vals + 2 );
return data;
| int parse_tag_create | ( | char * | name, |
| TagSpec & | result, | ||
| Interface * | iface | ||
Definition at line 275 of file parse.cpp.
References ErrorCode, TagSpec::handle, MB_ENTITY_NOT_FOUND, MB_SUCCESS, MB_TAG_ANY, MB_TAG_CREAT, MB_TAG_SPARSE, MB_TYPE_BIT, MB_TYPE_DOUBLE, MB_TYPE_HANDLE, MB_TYPE_INTEGER, MB_TYPE_OPAQUE, parse_values(), moab::Interface::tag_get_data_type(), moab::Interface::tag_get_default_value(), moab::Interface::tag_get_handle(), moab::Interface::tag_get_length(), and TagSpec::value.
Referenced by main().
// split at '=' signs
char* eq1 = strrchr( name, '=' );
if( !eq1 )
std::cerr << "Invalid tag specification: " << name << std::endl;
return 1;
*eq1 = '\0';
++eq1;
char *type_str = eq1, *val = 0;
char* eq2 = strrchr( name, '=' );
if( eq2 )
*eq2 = '\0';
++eq2;
val = ( '\0' == eq1[0] ) ? 0 : eq1;
type_str = eq2;
// parse type data
char* size_str = strchr( type_str, ':' );
if( !size_str )
std::cerr << "Invalid tag type specification: " << type_str << std::endl;
return 1;
*size_str = '\0';
++size_str;
DataType type;
if( !strcmp( type_str, "int" ) )
type = MB_TYPE_INTEGER;
else if( !strcmp( type_str, "double" ) )
type = MB_TYPE_DOUBLE;
else if( !strcmp( type_str, "bit" ) )
type = MB_TYPE_BIT;
else if( !strcmp( type_str, "handle" ) )
type = MB_TYPE_HANDLE;
else if( !strcmp( type_str, "opaque" ) )
type = MB_TYPE_OPAQUE;
else
return 1;
char* end_ptr;
int count = (int)strtol( size_str, &end_ptr, 0 );
if( !*size_str || *end_ptr || count < 1 )
std::cerr << "Invalid tag size specification: " << size_str << std::endl;
return 1;
// parse default value
result.value = 0;
if( val )
result.value = parse_values( val, type, count );
if( !result.value ) return 1;
// check if tag exists
if( MB_SUCCESS == iface->tag_get_handle( name, 0, MB_TYPE_OPAQUE, result.handle, MB_TAG_ANY ) )
// make sure it matches
DataType etype;
int esize;
if( MB_SUCCESS != iface->tag_get_data_type( result.handle, etype ) ||
MB_SUCCESS != iface->tag_get_length( result.handle, esize ) )
std::cerr << "Error accessing properties of tag: " << name << std::endl;
return 3;
if( etype != type || esize != count )
std::cerr << "Tag already exists with different type: " << name << std::endl;
return 1;
std::vector< unsigned char > value( esize );
if( result.value )
ErrorCode rval = iface->tag_get_default_value( result.handle, &value[0] );
if( rval != MB_ENTITY_NOT_FOUND && rval != MB_SUCCESS )
std::cerr << "Error checking default value of tag: " << name << std::endl;
return 3;
else if( rval == MB_ENTITY_NOT_FOUND || memcmp( &value[0], result.value, esize ) )
std::cerr << "Tag already exists and default value doesn't match: " << name << std::endl;
return 1;
else
ErrorCode rval =
iface->tag_get_handle( name, count, type, result.handle, MB_TAG_SPARSE | MB_TAG_CREAT, result.value );
if( MB_SUCCESS != rval )
std::cerr << "Failed to create tag: " << name << std::endl;
return 3;
return 0;
| int parse_tag_spec | ( | char * | name, |
Definition at line 218 of file parse.cpp.
References ErrorCode, TagSpec::handle, MB_SUCCESS, MB_TAG_ANY, MB_TAG_NOT_FOUND, MB_TYPE_OPAQUE, parse_values(), size, moab::Interface::tag_get_data_type(), moab::Interface::tag_get_handle(), moab::Interface::tag_get_length(), and TagSpec::value.
// Separate optional tag value from tag name
char* val = strrchr( name, '=' );
if( val )
// zero-length tag name>
if( val == name )
std::cerr << "Cannot create tag w/out name: " << name << std::endl;
return 1;
*val = '\0';
if( !*++val ) // if name ends with an '=', set val to NULL.
val = 0;
// Get tag
ErrorCode rval = iface->tag_get_handle( name, 0, MB_TYPE_OPAQUE, result.handle, MB_TAG_ANY );
if( MB_TAG_NOT_FOUND == rval )
std::cerr << "Tag not found: " << name << std::endl;
return 2;
else if( MB_SUCCESS != rval )
std::cerr << "Error retrieving tag handle: " << name << std::endl;
return 3;
// Parse tag value
result.value = 0;
if( val )
DataType type;
rval = iface->tag_get_data_type( result.handle, type );
std::cerr << "Error retrieving type for tag: " << name << std::endl;
return 3;
int size;
rval = iface->tag_get_length( result.handle, size );
std::cerr << "Error retrieving size for tag: " << name << std::endl;
return 3;
result.value = parse_values( val, type, size );
return 0;
| int parse_value | ( | const char *& | iter, |
| T & | value | ||
| int parse_value< double > | ( | const char *& | iter, |
| double & | value | ||
| void * parse_values | ( | const char * | vals, |
| DataType | type, | ||
| int | size | ||
| ) | [static] |
Definition at line 198 of file parse.cpp.
References MB_TYPE_BIT, MB_TYPE_DOUBLE, MB_TYPE_HANDLE, MB_TYPE_INTEGER, MB_TYPE_OPAQUE, parse_opaque_value(), and size.
Referenced by parse_tag_create(), and parse_tag_spec().
switch( type )
case MB_TYPE_OPAQUE:
return parse_opaque_value( vals, size );
case MB_TYPE_INTEGER:
return parse_values_typed< int >( vals, size );
case MB_TYPE_DOUBLE:
return parse_values_typed< double >( vals, size );
case MB_TYPE_BIT:
return parse_values_typed< bittype >( vals, size );
case MB_TYPE_HANDLE:
return parse_values_typed< EntityHandle >( vals, size );
default:
std::cerr << "Unknown tag data type: " << (int)type << std::endl;
return 0;
| T * parse_values_typed | ( | const char * | vals, |
| int | size | ||
Definition at line 168 of file parse.cpp.
References T.
if( !count ) return 0;
T* data = (T*)malloc( count * sizeof( T ) );
T* end = data + count;
if( parse_value< T >( vals, *data ) )
free( data );
return 0;
for( T* ptr = data + 1; ptr != end; ++ptr )
if( *vals != ',' )
std::cerr << "Expected ',' separating tag values: " << vals << std::endl;
free( data );
return 0;
++vals;
if( parse_value< T >( vals, *ptr ) )
free( data );
return 0;
return data;
| void tag_syntax | ( | std::ostream & | s | ) |
Definition at line 10 of file parse.cpp.
Referenced by usage().
s << "Tags are specified as <name>=[value], where the tag value " << std::endl
<< "is optional." << std::endl
<< std::endl
<< "Values of integral types (INTEGER, BIT, and HANDLE) are " << std::endl
<< "specified using standard C integer notation (a 0x prefix " << std::endl
<< "for hexidecimal, 0 prefix for octal, and no prefix for " << std::endl
<< "decimal.) The value of an opaque tag is interpreted as " << std::endl
<< "either a integral value or a character string. If the tag " << std::endl
<< "value begins with the prefix 0x it will be interpreted as a " << std::endl
<< "hexidecimal (base-16) number. If the value does not begin " << std::endl
<< "with the 0x prefix, it is interpreted as a character string." << std::endl
<< "Characater strings will be padded with null characters as" << std::endl
<< "necessary to fill the tag." << std::endl
<< "Floating-point (real) values must be specified in base-10." << std::endl
<< "C exponential notation (e.g. 1e-10) is accepted." << std::endl
<< std::endl
<< "If the tag is an array of integral or floating-point values " << std::endl
<< "then the tag value must be specified as a comma-separated " << std::endl
<< "list, with NO spaces." << std::endl
<< std::endl
<< "Tags are created with the syntax name=type:size[=default_value]." << std::endl
<< "where type is one of {int,double,opaque,handle,bit} and size is " << std::endl
<< "the number of values of the specified type, or the number of " << std::endl
<< "bytes if the type is 'opaque', A default value for the tag may " << std::endl
<< "be specified." << std::endl;
