MOAB: Mesh Oriented datABase
(version 5.4.1)
Include dependency graph for TagCompare.hpp:
This graph shows which files directly or indirectly include this file:Go to the source code of this file.
Classes | |
| class | moab::TagBytesEqual |
| class | moab::TagBytesLess |
| class | moab::TagVarBytesEqual |
| class | moab::TagVarBytesLess |
| class | moab::TagTypeEqual< T > |
| class | moab::TagTypeLess< T > |
| class | moab::TagOneTypeEqual< T > |
| class | moab::TagOneTypeLess< T > |
| class | moab::TagVarTypeEqual< T > |
| class | moab::TagVarTypeLess< T > |
| class | moab::ByteArrayIterator |
| class | moab::InsertCount |
Namespaces | |
| namespace | moab |
Class representing axis-aligned bounding box. | |
Typedefs | |
| typedef TagBytesEqual | moab::TagIntsEqual |
| typedef TagVarBytesEqual | moab::TagVarIntsEqual |
| typedef TagTypeLess< int > | moab::TagIntsLess |
| typedef TagVarTypeLess< int > | moab::TagVarIntsLess |
| typedef TagOneTypeEqual< int > | moab::TagOneIntEqual |
| typedef TagOneTypeLess< int > | moab::TagOneIntLess |
| typedef TagBytesEqual | moab::TagHandlesEqual |
| typedef TagVarBytesEqual | moab::TagVarHandlesEqual |
| typedef TagTypeLess< EntityHandle > | moab::TagHandlesLess |
| typedef TagVarTypeLess < EntityHandle > | moab::TagVarHandlesLess |
| typedef TagOneTypeEqual < EntityHandle > | moab::TagOneHandleEqual |
| typedef TagOneTypeLess < EntityHandle > | moab::TagOneHandleLess |
| typedef TagTypeEqual< double > | moab::TagDoublesEqual |
| typedef TagVarTypeEqual< double > | moab::TagVarDoublesEqual |
| typedef TagTypeLess< double > | moab::TagDoublesLess |
| typedef TagVarTypeLess< double > | moab::TagVarDoublesLess |
| typedef TagOneTypeEqual< double > | moab::TagOneDoubleEqual |
| typedef TagOneTypeLess< double > | moab::TagOneDoubleLess |
Functions | |
| template<class Functor , class IteratorType > | |
| static void | moab::find_tag_values (Functor compare, IteratorType begin, IteratorType end, Range &results) |
| static void | moab::find_tag_values (Functor compare, IteratorType begin, IteratorType end, std::vector< EntityHandle > &results) |
| template<class Functor , class TagMap > | |
| static void | moab::find_map_values (Functor compare, Range::const_iterator lower, Range::const_iterator upper, const TagMap &tag_map, Range &results) |
| template<class IteratorType , class ContainerType > | |
| static void | moab::find_tag_values_equal (const TagInfo &tag_info, const void *value, int size, IteratorType begin, IteratorType end, ContainerType &results) |
| static void | moab::find_tag_varlen_values_equal (const TagInfo &tag_info, const void *value, int size, IteratorType begin, IteratorType end, ContainerType &results) |
| template<class TagMap > | |
| static void | moab::find_map_values_equal (const TagInfo &tag_info, const void *value, int size, Range::const_iterator begin, Range::const_iterator end, const TagMap &tag_map, Range &results) |
| static void | moab::find_map_varlen_values_equal (const TagInfo &tag_info, const void *value, int size, Range::const_iterator begin, Range::const_iterator end, const TagMap &tag_map, Range &results) |
| static std::pair< EntityType, EntityType > | moab::type_range (EntityType type) |
