parallel_write_test.cpp File Reference
#include "moab/Core.hpp"
#include "moab/ParallelComm.hpp"
#include "MBTagConventions.hpp"
#include "moab_mpi.h"
#include <cstdlib>
#include <iostream>
#include <ctime>
#include <cstring>
#include <cmath>
#include <cassert>
#include <cstdio>
#include <sstream>
+ Include dependency graph for parallel_write_test.cpp:
Defines
#define TPRINT(A)   tprint( ( A ) )
#define IDX(i, j, k)   ( ( num_interval + 1 ) * ( ( num_interval + 1 ) * ( k ) + ( j ) ) + ( i ) )
Functions
static void tprint (const char *A)
ErrorCode generate_mesh (Interface &moab, int intervals)
void help ()
int main (int argc, char *argv[])
Variables
const int DEFAULT_INTERVALS = 2
const char * DEFAULT_FILE_NAME = "parallel_write_test.h5m"
const char args [] = "[-i <intervals>] [-o <filename>] [-L <filename>] [-g <n>]"
Define Documentation
#define IDX (   i,
  j,
  k
Definition at line 280 of file parallel_write_test.cpp.
Referenced by generate_mesh().
#define TPRINT (   A)    tprint( ( A ) )
Definition at line 16 of file parallel_write_test.cpp.
Referenced by main().
Function Documentation
ErrorCode generate_mesh ( Interface &  moab,
int  intervals
Definition at line 282 of file parallel_write_test.cpp.
References moab::Interface::create_element(), moab::Interface::create_vertex(), ErrorCode, moab::Interface::globalId_tag(), IDX, MB_SUCCESS, MBHEX, MPI_COMM_WORLD, rank, size, and moab::Interface::tag_set_data().
    int rank, size;
    MPI_Comm_rank( MPI_COMM_WORLD, &rank );
    MPI_Comm_size( MPI_COMM_WORLD, &size );
    ErrorCode rval;
    Tag global_id = moab.globalId_tag();
    // Each processor will own one cube of mesh within
    // an 3D grid of cubes.  Calculate the dimensions of
    // that grid in numbers of cubes.
    int root = 1;
    while( root * root * root < size )
        ++root;
    int num_x_blocks = root;
    int num_y_blocks = root - 1;
    int num_z_blocks = root - 1;
    if( num_x_blocks * num_y_blocks * num_z_blocks < size ) ++num_y_blocks;
    if( num_x_blocks * num_y_blocks * num_z_blocks < size ) ++num_z_blocks;
    // calculate position of this processor in grid
    int my_z_block = rank / ( num_x_blocks * num_y_blocks );
    int rem        = rank % ( num_x_blocks * num_y_blocks );
    int my_y_block = rem / num_x_blocks;
    int my_x_block = rem % num_x_blocks;
    // Each processor's cube of mesh will be num_iterval^3 elements
    // and will be 1.0 units on a side
    // create vertices
    const int num_x_vtx = num_interval * num_x_blocks + 1;
    const int num_y_vtx = num_interval * num_y_blocks + 1;
    const int x_offset  = my_x_block * num_interval;
    const int y_offset  = my_y_block * num_interval;
    const int z_offset  = my_z_block * num_interval;
    double step         = 1.0 / num_interval;
    std::vector< EntityHandle > vertices( ( num_interval + 1 ) * ( num_interval + 1 ) * ( num_interval + 1 ) );
    std::vector< EntityHandle >::iterator v = vertices.begin();
    for( int k = 0; k <= num_interval; ++k )
        for( int j = 0; j <= num_interval; ++j )
            for( int i = 0; i <= num_interval; ++i )
                double coords[] = { my_x_block + i * step, my_y_block + j * step, my_z_block + k * step };
                EntityHandle h;
                rval = moab.create_vertex( coords, h );
                if( MB_SUCCESS != rval ) return rval;
                int id = 1 + x_offset + i + ( y_offset + j ) * num_x_vtx + ( z_offset + k ) * num_x_vtx * num_y_vtx;
                rval   = moab.tag_set_data( global_id, &h, 1, &id );
                assert( v != vertices.end() );
                *v++ = h;
    // create hexes
    for( int k = 0; k < num_interval; ++k )
        for( int j = 0; j < num_interval; ++j )
            for( int i = 0; i < num_interval; ++i )
                assert( IDX( i + 1, j + 1, k + 1 ) < (int)vertices.size() );
                const EntityHandle conn[] = { vertices[IDX( i, j, k )],
                                              vertices[IDX( i + 1, j, k )],
                                              vertices[IDX( i + 1, j + 1, k )],
                                              vertices[IDX( i, j + 1, k )],
                                              vertices[IDX( i, j, k + 1 )],
                                              vertices[IDX( i + 1, j, k + 1 )],
                                              vertices[IDX( i + 1, j + 1, k + 1 )],
                                              vertices[IDX( i, j + 1, k + 1 )] };
                EntityHandle elem;
                rval = moab.create_element( MBHEX, conn, 8, elem );
      // create interface quads
    for (int j = 0; j < num_interval; ++j) {
      for (int i = 0; i < num_interval; ++i) {
        EntityHandle h;
        const EntityHandle conn1[] = { vertices[IDX(i,  j,  0)],
                                         vertices[IDX(i+1,j,  0)],
                                         vertices[IDX(i+1,j+1,0)],
                                         vertices[IDX(i,  j+1,0)] };
        rval = moab.create_element( MBQUAD, conn1, 4, h );
        if (MB_SUCCESS != rval)
          return rval;
        const EntityHandle conn2[] = { vertices[IDX(i,  j,  num_interval)],
                                         vertices[IDX(i+1,j,  num_interval)],
                                         vertices[IDX(i+1,j+1,num_interval)],
                                         vertices[IDX(i,  j+1,num_interval)] };
        rval = moab.create_element( MBQUAD, conn2, 4, h );
          return rval;
    for (int k = 0; k < num_interval; ++k) {
        EntityHandle h;
        const EntityHandle conn1[] = { vertices[IDX(i,  0,k  )],
                                         vertices[IDX(i+1,0,k  )],
                                         vertices[IDX(i+1,0,k+1)],
                                         vertices[IDX(i,  0,k+1)] };
          return rval;
        const EntityHandle conn2[] = { vertices[IDX(i,  num_interval,k  )],
                                         vertices[IDX(i+1,num_interval,k  )],
                                         vertices[IDX(i+1,num_interval,k+1)],
                                         vertices[IDX(i,  num_interval,k+1)] };
          return rval;
        EntityHandle h;
        const EntityHandle conn1[] = { vertices[IDX(0,j,  k  )],
                                         vertices[IDX(0,j+1,k  )],
                                         vertices[IDX(0,j+1,k+1)],
                                         vertices[IDX(0,j,  k+1)] };
          return rval;
        const EntityHandle conn2[] = { vertices[IDX(num_interval,j,  k  )],
                                         vertices[IDX(num_interval,j+1,k  )],
                                         vertices[IDX(num_interval,j+1,k+1)],
                                         vertices[IDX(num_interval,j,  k+1)] };
          return rval;
    return MB_SUCCESS;
void help ( )
Definition at line 41 of file parallel_write_test.cpp.
References args, and DEFAULT_INTERVALS.
    std::cout << "parallel_write_test " << args << std::endl
              << "  -i <N>    Each processor owns an NxNxN cube of hex elements (default: " << DEFAULT_INTERVALS << ")"
              << std::endl
              << "  -o <name> Retain output file and name it as specified." << std::endl
              << "  -L <name> Write local mesh to file name prefixed with MPI rank" << std::endl
              << "  -g <n>    Specify writer debug output level" << std::endl
              << "  -R        Skip resolve of shared entities (interface ents will be duplicated in file)" << std::endl
              << std::endl
              << "This program creates a (non-strict) subset of a regular hex mesh "
                 "such that the mesh is already partitioned, and then attempts to "
                 "write that mesh using MOAB's parallel HDF5 writer.  The mesh size "
                 "will scale with the number of processors and the number of elements "
                 "per processor (the latter is a function of the value specified "
                 "with the '-i' flag.)"
              << std::endl
              << std::endl
              << "Let N = ceil(cbrt(P)), where P is the number of processes.  "
                 "The mesh will be some subset of a cube with one corner at the "
                 "origin and the other at (N,N,N).  Each processor will own a "
                 "non-overlapping 1x1x1 unit block of mesh within that cube.  "
                 "If P is a power of 3, then the entire NxNxN cube will be "
                 "filled with hex elements.  Otherwise, some connected subset "
                 "of the cube will be meshed.  Each processor is assigned a "
                 "sub-block of the cube by rank where the blocks are enumerated "
                 "sequentally with x increasing most rapidly and z least rapidly."
              << std::endl
              << std::endl
              << "The size of the mesh owned by each processor is controlled by "
                 "the number of intervals along each edge of its block of mesh.  "
                 "If each block has N intervals, than each processor will have "
                 "N^3 hex elements."
              << std::endl
              << std::endl;
int main ( int  argc,
char *  argv[]
Definition at line 78 of file parallel_write_test.cpp.
References args, buffer, DEFAULT_FILE_NAME, DEFAULT_INTERVALS, ErrorCode, generate_mesh(), moab::Interface::get_entities_by_type(), moab::Interface::get_error_string(), moab::Interface::get_last_error(), help(), ierr, mb, MB_SUCCESS, MBHEX, MPI_COMM_WORLD, rank, moab::ParallelComm::resolve_shared_ents(), size, moab::Range::size(), t, TPRINT, and moab::Interface::write_file().
    int ierr = MPI_Init( &argc, &argv );
    if( ierr )
        std::cerr << "MPI_Init failed with error code: " << ierr << std::endl;
        return ierr;
    int rank;
    ierr = MPI_Comm_rank( MPI_COMM_WORLD, &rank );
    if( ierr )
        std::cerr << "MPI_Comm_rank failed with error code: " << ierr << std::endl;
        return ierr;
    int size;
    ierr = MPI_Comm_size( MPI_COMM_WORLD, &size );
    if( ierr )
        std::cerr << "MPI_Comm_size failed with error code: " << ierr << std::endl;
        return ierr;
    // settings controlled by CL flags
    const char* output_file_name = 0;
    const char* indiv_file_name  = 0;
    int intervals = 0, debug_level = 0;
    // state for CL flag processing
    bool expect_intervals    = false;
    bool expect_file_name    = false;
    bool expect_indiv_file   = false;
    bool skip_resolve_shared = false;
    bool expect_debug_level  = false;
    // process CL args
    for( int i = 1; i < argc; ++i )
        if( expect_intervals )
            char* endptr = 0;
            intervals    = (int)strtol( argv[i], &endptr, 0 );
            if( *endptr || intervals < 1 )
                std::cerr << "Invalid block interval value: " << argv[i] << std::endl;
                return 1;
        else if( expect_indiv_file )
            indiv_file_name   = argv[i];
        else if( expect_file_name )
            output_file_name = argv[i];
        else if( expect_debug_level )
            debug_level = atoi( argv[i] );
            if( debug_level < 1 )
                std::cerr << "Invalid argument following -g flag: \"" << argv[i] << '"' << std::endl;
                return 1;
        else if( !strcmp( "-i", argv[i] ) )
            expect_intervals = true;
        else if( !strcmp( "-o", argv[i] ) )
            expect_file_name = true;
        else if( !strcmp( "-L", argv[i] ) )
            expect_indiv_file = true;
        else if( !strcmp( "-R", argv[i] ) )
            skip_resolve_shared = true;
        else if( !strcmp( "-g", argv[i] ) )
            expect_debug_level = true;
        else if( !strcmp( "-h", argv[i] ) )
            help();
            return 0;
        else
            std::cerr << "Unexpected argument: " << argv[i] << std::endl
                      << "Usage: " << argv[0] << " " << args << std::endl
                      << "       " << argv[0] << " -h" << std::endl
                      << " Try '-h' for help." << std::endl;
            return 1;
    // Check for missing argument after last CL flag
    if( expect_file_name || expect_intervals || expect_indiv_file )
        std::cerr << "Missing argument for '" << argv[argc - 1] << "'" << std::endl;
        return 1;
    // If intervals weren't specified, use default
    if( intervals == 0 )
        std::cout << "Using default interval count: " << DEFAULT_INTERVALS << std::endl;
        intervals = DEFAULT_INTERVALS;
    // If no output file was specified, use default one and note that
    // we need to delete it when the test completes.
    bool keep_output_file = true;
    if( !output_file_name )
        output_file_name = DEFAULT_FILE_NAME;
        keep_output_file = false;
    // Create mesh
    TPRINT( "Generating mesh" );
    double gen_time = MPI_Wtime();
    Core mb;
    Interface& moab = mb;
    ErrorCode rval  = generate_mesh( moab, intervals );
        std::cerr << "Mesh creation failed with error code: " << rval << std::endl;
        return (int)rval;
    gen_time = MPI_Wtime() - gen_time;
    // Write out local mesh on each processor if requested.
    if( indiv_file_name )
        TPRINT( "Writing individual file" );
        char buffer[64];
        int width = (int)ceil( log10( size ) );
        sprintf( buffer, "%0*d-", width, rank );
        std::string name( buffer );
        name += indiv_file_name;
        rval = moab.write_file( name.c_str() );
            std::cerr << "Failed to write file: " << name << std::endl;
            return (int)rval;
    double res_time = MPI_Wtime();
    Range hexes;
    moab.get_entities_by_type( 0, MBHEX, hexes );
    if( !skip_resolve_shared )
        TPRINT( "Resolving shared entities" );
        // Negotiate shared entities using vertex global IDs
        ParallelComm* pcomm = new ParallelComm( &moab, MPI_COMM_WORLD );
        rval                = pcomm->resolve_shared_ents( 0, hexes, 3, 0 );
            std::cerr << "ParallelComm::resolve_shared_ents failed" << std::endl;
            return rval;
    res_time = MPI_Wtime() - res_time;
    TPRINT( "Beginning parallel write" );
    double write_time = MPI_Wtime();
    // Do parallel write
    clock_t t = clock();
    std::ostringstream opts;
    opts << "PARALLEL=WRITE_PART";
    if( debug_level > 0 ) opts << ";DEBUG_IO=" << debug_level;
    rval = moab.write_file( output_file_name, "MOAB", opts.str().c_str() );
    t    = clock() - t;
        std::string msg;
        moab.get_last_error( msg );
        std::cerr << "File creation failed with error code: " << moab.get_error_string( rval ) << std::endl;
        std::cerr << "\t\"" << msg << '"' << std::endl;
        return (int)rval;
    write_time = MPI_Wtime() - write_time;
    double times[3] = { gen_time, res_time, write_time };
    double max[3]   = { 0, 0, 0 };
    MPI_Reduce( times, max, 3, MPI_DOUBLE, MPI_MAX, 0, MPI_COMM_WORLD );
    // Clean up and summarize
    if( 0 == rank )
        double sec = (double)t / CLOCKS_PER_SEC;
        std::cout << "Wrote " << hexes.size() * size << " hexes in " << sec << " seconds." << std::endl;
        if( !keep_output_file )
            TPRINT( "Removing written file" );
            remove( output_file_name );
        std::cout << "Wall time: generate: " << max[0] << ", resovle shared: " << max[1] << ", write_file: " << max[2]
                  << std::endl;
    TPRINT( "Finalizing MPI" );
    return MPI_Finalize();
static void tprint ( const char *  A) [static]
Definition at line 17 of file parallel_write_test.cpp.
References buffer, MPI_COMM_WORLD, and rank.
    int rank;
    char buffer[128];
    sprintf( buffer, "%02d: %6.2f: %s\n", rank, (double)clock() / CLOCKS_PER_SEC, A );
    fputs( buffer, stderr );
Variable Documentation
const char args[] = "[-i <intervals>] [-o <filename>] [-L <filename>] [-g <n>]"
const char* DEFAULT_FILE_NAME = "parallel_write_test.h5m"
Definition at line 27 of file parallel_write_test.cpp.
Definition at line 26 of file parallel_write_test.cpp.
Referenced by help(), main(), and usage().
