MOAB: Mesh Oriented datABase
(version 5.4.1)
00001 #include "moab/Core.hpp" 00002 #include "moab/ParallelComm.hpp" 00003 #include "MBTagConventions.hpp" 00004 #include "moab_mpi.h" 00005 #include <cstdlib> 00006 #include <iostream> 00007 #include <ctime> 00008 #include <cstring> 00009 #include <cmath> 00010 #include <cassert> 00011 #include <cstdio> 00012 #include <sstream> 00013 00014 using namespace moab; 00015 00016 #define TPRINT( A ) tprint( ( A ) ) 00017 static void tprint( const char* A ) 00018 { 00019 int rank; 00020 MPI_Comm_rank( MPI_COMM_WORLD, &rank ); 00021 char buffer[128]; 00022 sprintf( buffer, "%02d: %6.2f: %s\n", rank, (double)clock() / CLOCKS_PER_SEC, A ); 00023 fputs( buffer, stderr ); 00024 } 00025 00026 const int DEFAULT_INTERVALS = 2; 00027 const char* DEFAULT_FILE_NAME = "parallel_write_test.h5m"; 00028 00029 // Create mesh for each processor that is a cube of hexes 00030 // with the specified interval count along each edge. Cubes 00031 // of mesh will be positioned and vertex IDs assigned such that 00032 // there are shared entities. If the cubic root of the number 00033 // of processors is a whole number, then each processors mesh 00034 // will be a cube in a grid with that number of processor blocks 00035 // along each edge. Otherwise processor blocks will be arranged 00036 // within the subset of the grid that is the ceiling of the cubic 00037 // root of the comm size such that there are no disjoint regions. 00038 ErrorCode generate_mesh( Interface& moab, int intervals ); 00039 00040 const char args[] = "[-i <intervals>] [-o <filename>] [-L <filename>] [-g <n>]"; 00041 void help() 00042 { 00043 std::cout << "parallel_write_test " << args << std::endl 00044 << " -i <N> Each processor owns an NxNxN cube of hex elements (default: " << DEFAULT_INTERVALS << ")" 00045 << std::endl 00046 << " -o <name> Retain output file and name it as specified." << std::endl 00047 << " -L <name> Write local mesh to file name prefixed with MPI rank" << std::endl 00048 << " -g <n> Specify writer debug output level" << std::endl 00049 << " -R Skip resolve of shared entities (interface ents will be duplicated in file)" << std::endl 00050 << std::endl 00051 << "This program creates a (non-strict) subset of a regular hex mesh " 00052 "such that the mesh is already partitioned, and then attempts to " 00053 "write that mesh using MOAB's parallel HDF5 writer. The mesh size " 00054 "will scale with the number of processors and the number of elements " 00055 "per processor (the latter is a function of the value specified " 00056 "with the '-i' flag.)" 00057 << std::endl 00058 << std::endl 00059 << "Let N = ceil(cbrt(P)), where P is the number of processes. " 00060 "The mesh will be some subset of a cube with one corner at the " 00061 "origin and the other at (N,N,N). Each processor will own a " 00062 "non-overlapping 1x1x1 unit block of mesh within that cube. " 00063 "If P is a power of 3, then the entire NxNxN cube will be " 00064 "filled with hex elements. Otherwise, some connected subset " 00065 "of the cube will be meshed. Each processor is assigned a " 00066 "sub-block of the cube by rank where the blocks are enumerated " 00067 "sequentally with x increasing most rapidly and z least rapidly." 00068 << std::endl 00069 << std::endl 00070 << "The size of the mesh owned by each processor is controlled by " 00071 "the number of intervals along each edge of its block of mesh. " 00072 "If each block has N intervals, than each processor will have " 00073 "N^3 hex elements." 00074 << std::endl 00075 << std::endl; 00076 } 00077 00078 int main( int argc, char* argv[] ) 00079 { 00080 int ierr = MPI_Init( &argc, &argv ); 00081 if( ierr ) 00082 { 00083 std::cerr << "MPI_Init failed with error code: " << ierr << std::endl; 00084 return ierr; 00085 } 00086 int rank; 00087 ierr = MPI_Comm_rank( MPI_COMM_WORLD, &rank ); 00088 if( ierr ) 00089 { 00090 std::cerr << "MPI_Comm_rank failed with error code: " << ierr << std::endl; 00091 return ierr; 00092 } 00093 int size; 00094 ierr = MPI_Comm_size( MPI_COMM_WORLD, &size ); 00095 if( ierr ) 00096 { 00097 std::cerr << "MPI_Comm_size failed with error code: " << ierr << std::endl; 00098 return ierr; 00099 } 00100 00101 // settings controlled by CL flags 00102 const char* output_file_name = 0; 00103 const char* indiv_file_name = 0; 00104 int intervals = 0, debug_level = 0; 00105 // state for CL flag processing 00106 bool expect_intervals = false; 00107 bool expect_file_name = false; 00108 bool expect_indiv_file = false; 00109 bool skip_resolve_shared = false; 00110 bool expect_debug_level = false; 00111 // process CL args 00112 for( int i = 1; i < argc; ++i ) 00113 { 00114 if( expect_intervals ) 00115 { 00116 char* endptr = 0; 00117 intervals = (int)strtol( argv[i], &endptr, 0 ); 00118 if( *endptr || intervals < 1 ) 00119 { 00120 std::cerr << "Invalid block interval value: " << argv[i] << std::endl; 00121 return 1; 00122 } 00123 expect_intervals = false; 00124 } 00125 else if( expect_indiv_file ) 00126 { 00127 indiv_file_name = argv[i]; 00128 expect_indiv_file = false; 00129 } 00130 else if( expect_file_name ) 00131 { 00132 output_file_name = argv[i]; 00133 expect_file_name = false; 00134 } 00135 else if( expect_debug_level ) 00136 { 00137 debug_level = atoi( argv[i] ); 00138 if( debug_level < 1 ) 00139 { 00140 std::cerr << "Invalid argument following -g flag: \"" << argv[i] << '"' << std::endl; 00141 return 1; 00142 } 00143 expect_debug_level = false; 00144 } 00145 else if( !strcmp( "-i", argv[i] ) ) 00146 expect_intervals = true; 00147 else if( !strcmp( "-o", argv[i] ) ) 00148 expect_file_name = true; 00149 else if( !strcmp( "-L", argv[i] ) ) 00150 expect_indiv_file = true; 00151 else if( !strcmp( "-R", argv[i] ) ) 00152 skip_resolve_shared = true; 00153 else if( !strcmp( "-g", argv[i] ) ) 00154 expect_debug_level = true; 00155 else if( !strcmp( "-h", argv[i] ) ) 00156 { 00157 help(); 00158 return 0; 00159 } 00160 else 00161 { 00162 std::cerr << "Unexpected argument: " << argv[i] << std::endl 00163 << "Usage: " << argv[0] << " " << args << std::endl 00164 << " " << argv[0] << " -h" << std::endl 00165 << " Try '-h' for help." << std::endl; 00166 return 1; 00167 } 00168 } 00169 // Check for missing argument after last CL flag 00170 if( expect_file_name || expect_intervals || expect_indiv_file ) 00171 { 00172 std::cerr << "Missing argument for '" << argv[argc - 1] << "'" << std::endl; 00173 return 1; 00174 } 00175 // If intervals weren't specified, use default 00176 if( intervals == 0 ) 00177 { 00178 std::cout << "Using default interval count: " << DEFAULT_INTERVALS << std::endl; 00179 intervals = DEFAULT_INTERVALS; 00180 } 00181 // If no output file was specified, use default one and note that 00182 // we need to delete it when the test completes. 00183 bool keep_output_file = true; 00184 if( !output_file_name ) 00185 { 00186 output_file_name = DEFAULT_FILE_NAME; 00187 keep_output_file = false; 00188 } 00189 00190 // Create mesh 00191 TPRINT( "Generating mesh" ); 00192 double gen_time = MPI_Wtime(); 00193 Core mb; 00194 Interface& moab = mb; 00195 ErrorCode rval = generate_mesh( moab, intervals ); 00196 if( MB_SUCCESS != rval ) 00197 { 00198 std::cerr << "Mesh creation failed with error code: " << rval << std::endl; 00199 return (int)rval; 00200 } 00201 gen_time = MPI_Wtime() - gen_time; 00202 00203 // Write out local mesh on each processor if requested. 00204 if( indiv_file_name ) 00205 { 00206 TPRINT( "Writing individual file" ); 00207 char buffer[64]; 00208 int width = (int)ceil( log10( size ) ); 00209 sprintf( buffer, "%0*d-", width, rank ); 00210 std::string name( buffer ); 00211 name += indiv_file_name; 00212 rval = moab.write_file( name.c_str() ); 00213 if( MB_SUCCESS != rval ) 00214 { 00215 std::cerr << "Failed to write file: " << name << std::endl; 00216 return (int)rval; 00217 } 00218 } 00219 00220 double res_time = MPI_Wtime(); 00221 Range hexes; 00222 moab.get_entities_by_type( 0, MBHEX, hexes ); 00223 if( !skip_resolve_shared ) 00224 { 00225 TPRINT( "Resolving shared entities" ); 00226 // Negotiate shared entities using vertex global IDs 00227 ParallelComm* pcomm = new ParallelComm( &moab, MPI_COMM_WORLD ); 00228 rval = pcomm->resolve_shared_ents( 0, hexes, 3, 0 ); 00229 if( MB_SUCCESS != rval ) 00230 { 00231 std::cerr << "ParallelComm::resolve_shared_ents failed" << std::endl; 00232 return rval; 00233 } 00234 } 00235 res_time = MPI_Wtime() - res_time; 00236 00237 TPRINT( "Beginning parallel write" ); 00238 double write_time = MPI_Wtime(); 00239 // Do parallel write 00240 clock_t t = clock(); 00241 std::ostringstream opts; 00242 opts << "PARALLEL=WRITE_PART"; 00243 if( debug_level > 0 ) opts << ";DEBUG_IO=" << debug_level; 00244 rval = moab.write_file( output_file_name, "MOAB", opts.str().c_str() ); 00245 t = clock() - t; 00246 if( MB_SUCCESS != rval ) 00247 { 00248 std::string msg; 00249 moab.get_last_error( msg ); 00250 std::cerr << "File creation failed with error code: " << moab.get_error_string( rval ) << std::endl; 00251 std::cerr << "\t\"" << msg << '"' << std::endl; 00252 return (int)rval; 00253 } 00254 write_time = MPI_Wtime() - write_time; 00255 00256 double times[3] = { gen_time, res_time, write_time }; 00257 double max[3] = { 0, 0, 0 }; 00258 MPI_Reduce( times, max, 3, MPI_DOUBLE, MPI_MAX, 0, MPI_COMM_WORLD ); 00259 00260 // Clean up and summarize 00261 if( 0 == rank ) 00262 { 00263 double sec = (double)t / CLOCKS_PER_SEC; 00264 std::cout << "Wrote " << hexes.size() * size << " hexes in " << sec << " seconds." << std::endl; 00265 00266 if( !keep_output_file ) 00267 { 00268 TPRINT( "Removing written file" ); 00269 remove( output_file_name ); 00270 } 00271 00272 std::cout << "Wall time: generate: " << max[0] << ", resovle shared: " << max[1] << ", write_file: " << max[2] 00273 << std::endl; 00274 } 00275 00276 TPRINT( "Finalizing MPI" ); 00277 return MPI_Finalize(); 00278 } 00279 00280 #define IDX( i, j, k ) ( ( num_interval + 1 ) * ( ( num_interval + 1 ) * ( k ) + ( j ) ) + ( i ) ) 00281 00282 ErrorCode generate_mesh( Interface& moab, int num_interval ) 00283 { 00284 int rank, size; 00285 MPI_Comm_rank( MPI_COMM_WORLD, &rank ); 00286 MPI_Comm_size( MPI_COMM_WORLD, &size ); 00287 00288 ErrorCode rval; 00289 Tag global_id = moab.globalId_tag(); 00290 00291 // Each processor will own one cube of mesh within 00292 // an 3D grid of cubes. Calculate the dimensions of 00293 // that grid in numbers of cubes. 00294 int root = 1; 00295 while( root * root * root < size ) 00296 ++root; 00297 int num_x_blocks = root; 00298 int num_y_blocks = root - 1; 00299 int num_z_blocks = root - 1; 00300 if( num_x_blocks * num_y_blocks * num_z_blocks < size ) ++num_y_blocks; 00301 if( num_x_blocks * num_y_blocks * num_z_blocks < size ) ++num_z_blocks; 00302 00303 // calculate position of this processor in grid 00304 int my_z_block = rank / ( num_x_blocks * num_y_blocks ); 00305 int rem = rank % ( num_x_blocks * num_y_blocks ); 00306 int my_y_block = rem / num_x_blocks; 00307 int my_x_block = rem % num_x_blocks; 00308 00309 // Each processor's cube of mesh will be num_iterval^3 elements 00310 // and will be 1.0 units on a side 00311 00312 // create vertices 00313 const int num_x_vtx = num_interval * num_x_blocks + 1; 00314 const int num_y_vtx = num_interval * num_y_blocks + 1; 00315 const int x_offset = my_x_block * num_interval; 00316 const int y_offset = my_y_block * num_interval; 00317 const int z_offset = my_z_block * num_interval; 00318 double step = 1.0 / num_interval; 00319 std::vector< EntityHandle > vertices( ( num_interval + 1 ) * ( num_interval + 1 ) * ( num_interval + 1 ) ); 00320 std::vector< EntityHandle >::iterator v = vertices.begin(); 00321 for( int k = 0; k <= num_interval; ++k ) 00322 { 00323 for( int j = 0; j <= num_interval; ++j ) 00324 { 00325 for( int i = 0; i <= num_interval; ++i ) 00326 { 00327 double coords[] = { my_x_block + i * step, my_y_block + j * step, my_z_block + k * step }; 00328 EntityHandle h; 00329 rval = moab.create_vertex( coords, h ); 00330 if( MB_SUCCESS != rval ) return rval; 00331 00332 int id = 1 + x_offset + i + ( y_offset + j ) * num_x_vtx + ( z_offset + k ) * num_x_vtx * num_y_vtx; 00333 rval = moab.tag_set_data( global_id, &h, 1, &id ); 00334 if( MB_SUCCESS != rval ) return rval; 00335 00336 assert( v != vertices.end() ); 00337 *v++ = h; 00338 } 00339 } 00340 } 00341 00342 // create hexes 00343 for( int k = 0; k < num_interval; ++k ) 00344 { 00345 for( int j = 0; j < num_interval; ++j ) 00346 { 00347 for( int i = 0; i < num_interval; ++i ) 00348 { 00349 assert( IDX( i + 1, j + 1, k + 1 ) < (int)vertices.size() ); 00350 const EntityHandle conn[] = { vertices[IDX( i, j, k )], 00351 vertices[IDX( i + 1, j, k )], 00352 vertices[IDX( i + 1, j + 1, k )], 00353 vertices[IDX( i, j + 1, k )], 00354 vertices[IDX( i, j, k + 1 )], 00355 vertices[IDX( i + 1, j, k + 1 )], 00356 vertices[IDX( i + 1, j + 1, k + 1 )], 00357 vertices[IDX( i, j + 1, k + 1 )] }; 00358 EntityHandle elem; 00359 rval = moab.create_element( MBHEX, conn, 8, elem ); 00360 if( MB_SUCCESS != rval ) return rval; 00361 } 00362 } 00363 } 00364 /* 00365 // create interface quads 00366 for (int j = 0; j < num_interval; ++j) { 00367 for (int i = 0; i < num_interval; ++i) { 00368 EntityHandle h; 00369 00370 const EntityHandle conn1[] = { vertices[IDX(i, j, 0)], 00371 vertices[IDX(i+1,j, 0)], 00372 vertices[IDX(i+1,j+1,0)], 00373 vertices[IDX(i, j+1,0)] }; 00374 rval = moab.create_element( MBQUAD, conn1, 4, h ); 00375 if (MB_SUCCESS != rval) 00376 return rval; 00377 00378 const EntityHandle conn2[] = { vertices[IDX(i, j, num_interval)], 00379 vertices[IDX(i+1,j, num_interval)], 00380 vertices[IDX(i+1,j+1,num_interval)], 00381 vertices[IDX(i, j+1,num_interval)] }; 00382 rval = moab.create_element( MBQUAD, conn2, 4, h ); 00383 if (MB_SUCCESS != rval) 00384 return rval; 00385 } 00386 } 00387 for (int k = 0; k < num_interval; ++k) { 00388 for (int i = 0; i < num_interval; ++i) { 00389 EntityHandle h; 00390 00391 const EntityHandle conn1[] = { vertices[IDX(i, 0,k )], 00392 vertices[IDX(i+1,0,k )], 00393 vertices[IDX(i+1,0,k+1)], 00394 vertices[IDX(i, 0,k+1)] }; 00395 rval = moab.create_element( MBQUAD, conn1, 4, h ); 00396 if (MB_SUCCESS != rval) 00397 return rval; 00398 00399 const EntityHandle conn2[] = { vertices[IDX(i, num_interval,k )], 00400 vertices[IDX(i+1,num_interval,k )], 00401 vertices[IDX(i+1,num_interval,k+1)], 00402 vertices[IDX(i, num_interval,k+1)] }; 00403 rval = moab.create_element( MBQUAD, conn2, 4, h ); 00404 if (MB_SUCCESS != rval) 00405 return rval; 00406 } 00407 } 00408 for (int k = 0; k < num_interval; ++k) { 00409 for (int j = 0; j < num_interval; ++j) { 00410 EntityHandle h; 00411 00412 const EntityHandle conn1[] = { vertices[IDX(0,j, k )], 00413 vertices[IDX(0,j+1,k )], 00414 vertices[IDX(0,j+1,k+1)], 00415 vertices[IDX(0,j, k+1)] }; 00416 rval = moab.create_element( MBQUAD, conn1, 4, h ); 00417 if (MB_SUCCESS != rval) 00418 return rval; 00419 00420 const EntityHandle conn2[] = { vertices[IDX(num_interval,j, k )], 00421 vertices[IDX(num_interval,j+1,k )], 00422 vertices[IDX(num_interval,j+1,k+1)], 00423 vertices[IDX(num_interval,j, k+1)] }; 00424 rval = moab.create_element( MBQUAD, conn2, 4, h ); 00425 if (MB_SUCCESS != rval) 00426 return rval; 00427 } 00428 } 00429 */ 00430 return MB_SUCCESS; 00431 }
