MOAB: Mesh Oriented datABase
(version 5.4.1)
#include <iostream>#include <cstdlib>#include <cstdio>#include "moab/Core.hpp"#include "moab/Interface.hpp"#include "moab/Range.hpp"#include "moab/ProgOptions.hpp"
Include dependency graph for FixPolys.cpp:Go to the source code of this file.
Functions | |
| int | main (int argc, char **argv) |
| int main | ( | int | argc, |
| char ** | argv | ||
Definition at line 23 of file FixPolys.cpp.
References ProgOptions::addOpt(), moab::Range::begin(), moab::Core::create_element(), moab::Core::delete_entities(), moab::Range::end(), ErrorCode, moab::Core::get_connectivity(), moab::Core::get_entities_by_dimension(), moab::Core::globalId_tag(), moab::Range::insert(), moab::Core::load_file(), mb, MB_CHK_SET_ERR, MBPOLYGON, ProgOptions::parseCommandLine(), moab::Range::size(), moab::Core::tag_get_data(), moab::Core::tag_set_data(), test_file_name, and moab::Core::write_file().
ProgOptions opts;
string inputFile = test_file_name;
opts.addOpt< string >( "inFile,i", "Specify the input file name string ", &inputFile );
string outFile = "out.h5m";
opts.addOpt< string >( "outFile,o", "Specify the output file name string ", &outFile );
opts.parseCommandLine( argc, argv );
// Instantiate
Core mb;
ErrorCode rval = mb.load_file( inputFile.c_str() );MB_CHK_SET_ERR( rval, "Error loading file" );
cout << " reading file " << inputFile << "\n";
// Get all 2d elements in the file set
Range elems;
rval = mb.get_entities_by_dimension( 0, 2, elems );MB_CHK_SET_ERR( rval, "Error getting 2d elements" );
cout << "number of cells: " << elems.size() << "\n";
Tag gidTag = mb.globalId_tag();
Range OldCells;
for( Range::iterator it = elems.begin(); it != elems.end(); ++it )
EntityHandle cell = *it;
const EntityHandle* conn;
int number_nodes;
rval = mb.get_connectivity( cell, conn, number_nodes );MB_CHK_SET_ERR( rval, "Error getting connectivity" );
// now check if we have consecutive duplicated vertices, and if so, create a new cell
std::vector< EntityHandle > new_verts;
// push to it, if we do not have duplicates
EntityHandle current = conn[0];
// new_verts.push_back(current);
for( int i = 1; i <= number_nodes; i++ )
EntityHandle nextV;
if( i < number_nodes )
nextV = conn[i];
else
nextV = conn[0]; // first vertex
if( current != nextV )
new_verts.push_back( current );
current = nextV;
if( number_nodes > (int)new_verts.size() )
// create a new poly, and put this in a list to be removed
int gid;
rval = mb.tag_get_data( gidTag, &cell, 1, &gid );MB_CHK_SET_ERR( rval, "Error getting global id tag" );
EntityHandle newCell;
rval = mb.create_element( MBPOLYGON, &new_verts[0], (int)new_verts.size(), newCell );MB_CHK_SET_ERR( rval, "Error creating new polygon " );
rval = mb.tag_set_data( gidTag, &newCell, 1, &gid );MB_CHK_SET_ERR( rval, "Error setting global id tag" );
cout << "delete old cell " << cell << " with num_nodes vertices: " << number_nodes
<< " and with global id: " << gid << "\n";
for( int i = 0; i < number_nodes; i++ )
cout << " " << conn[i];
cout << "\n";
OldCells.insert( cell );
mb.delete_entities( OldCells );
rval = mb.write_file( outFile.c_str() );MB_CHK_SET_ERR( rval, "Error writing file" );
return 0;
