MOAB: Mesh Oriented datABase
(version 5.4.1)
00001 /** \brief This test shows how to fix polygons that have duplicated vertices 00002 * 00003 * We sometimes use padded vertices option, to reduce the number of data sequences 00004 * We identify first the polygons that have padded vertices 00005 * then we set the new ones with reduced number of vertices, but with the same global id tag 00006 */ 00007 00008 #include <iostream> 00009 #include <cstdlib> 00010 #include <cstdio> 00011 00012 #include "moab/Core.hpp" 00013 #include "moab/Interface.hpp" 00014 #include "moab/Range.hpp" 00015 #include "moab/ProgOptions.hpp" 00016 00017 using namespace moab; 00018 using namespace std; 00019 00020 #ifdef MOAB_HAVE_HDF5 00021 string test_file_name = string( MESH_DIR ) + string( "/64bricks_512hex_256part.h5m" ); 00022 #endif 00023 int main( int argc, char** argv ) 00024 { 00025 ProgOptions opts; 00026 00027 string inputFile = test_file_name; 00028 opts.addOpt< string >( "inFile,i", "Specify the input file name string ", &inputFile ); 00029 00030 string outFile = "out.h5m"; 00031 opts.addOpt< string >( "outFile,o", "Specify the output file name string ", &outFile ); 00032 00033 opts.parseCommandLine( argc, argv ); 00034 00035 // Instantiate 00036 Core mb; 00037 00038 ErrorCode rval = mb.load_file( inputFile.c_str() );MB_CHK_SET_ERR( rval, "Error loading file" ); 00039 00040 cout << " reading file " << inputFile << "\n"; 00041 00042 // Get all 2d elements in the file set 00043 Range elems; 00044 rval = mb.get_entities_by_dimension( 0, 2, elems );MB_CHK_SET_ERR( rval, "Error getting 2d elements" ); 00045 00046 cout << "number of cells: " << elems.size() << "\n"; 00047 00048 Tag gidTag = mb.globalId_tag(); 00049 Range OldCells; 00050 for( Range::iterator it = elems.begin(); it != elems.end(); ++it ) 00051 { 00052 EntityHandle cell = *it; 00053 const EntityHandle* conn; 00054 int number_nodes; 00055 rval = mb.get_connectivity( cell, conn, number_nodes );MB_CHK_SET_ERR( rval, "Error getting connectivity" ); 00056 // now check if we have consecutive duplicated vertices, and if so, create a new cell 00057 std::vector< EntityHandle > new_verts; 00058 // push to it, if we do not have duplicates 00059 00060 EntityHandle current = conn[0]; 00061 // new_verts.push_back(current); 00062 for( int i = 1; i <= number_nodes; i++ ) 00063 { 00064 EntityHandle nextV; 00065 if( i < number_nodes ) 00066 nextV = conn[i]; 00067 else 00068 nextV = conn[0]; // first vertex 00069 if( current != nextV ) 00070 { 00071 new_verts.push_back( current ); 00072 current = nextV; 00073 } 00074 } 00075 if( number_nodes > (int)new_verts.size() ) 00076 { 00077 // create a new poly, and put this in a list to be removed 00078 int gid; 00079 rval = mb.tag_get_data( gidTag, &cell, 1, &gid );MB_CHK_SET_ERR( rval, "Error getting global id tag" ); 00080 EntityHandle newCell; 00081 rval = mb.create_element( MBPOLYGON, &new_verts[0], (int)new_verts.size(), newCell );MB_CHK_SET_ERR( rval, "Error creating new polygon " ); 00082 rval = mb.tag_set_data( gidTag, &newCell, 1, &gid );MB_CHK_SET_ERR( rval, "Error setting global id tag" ); 00083 cout << "delete old cell " << cell << " with num_nodes vertices: " << number_nodes 00084 << " and with global id: " << gid << "\n"; 00085 for( int i = 0; i < number_nodes; i++ ) 00086 { 00087 cout << " " << conn[i]; 00088 } 00089 cout << "\n"; 00090 OldCells.insert( cell ); 00091 } 00092 mb.delete_entities( OldCells ); 00093 } 00094 rval = mb.write_file( outFile.c_str() );MB_CHK_SET_ERR( rval, "Error writing file" ); 00095 00096 return 0; 00097 }
