gqt_pointinvol_test.cpp File Reference
#include <iostream>
#include "moab/Interface.hpp"
#include "TestUtil.hpp"
#include "Internals.hpp"
#include "moab/Core.hpp"
#include "moab/GeomQueryTool.hpp"
#include "moab/GeomTopoTool.hpp"
+ Include dependency graph for gqt_pointinvol_test.cpp:
Defines
#define IS_BUILDING_MB
#define CHKERR(A)
Functions
void gqt_setup_test ()
void gqt_point_in ()
int gqt_point_in_vol_dir (double origin[3], double dir[3], int vol_idx)
void gqt_point_in_vol_1 ()
void gqt_point_in_vol_2 ()
void gqt_point_in_vol_3 ()
void gqt_point_in_vol_4 ()
void gqt_point_in_vol_5 ()
void gqt_point_in_vol_6 ()
void gqt_point_on_corner_1 ()
void gqt_point_on_corner_2 ()
void gqt_point_on_corner_3 ()
void gqt_point_on_corner_4 ()
void gqt_point_on_corner_5 ()
void gqt_point_on_corner_6 ()
void gqt_point_on_corner_7 ()
void gqt_point_on_corner_8 ()
int main (int, char **)
Variables
Core * MBI
GeomTopoTool * GTT
GeomQueryTool * GQT
const std::string input_file = "unittest/test_geom.h5m"
Define Documentation
#define CHKERR (   A)
Value:
do        \
        if( MB_SUCCESS != ( A ) )        \
            std::cerr << "Failure (error code " << ( A ) << ") at " __FILE__ ":" << __LINE__ << std::endl; \
            return A;        \
    } while( false )
Definition at line 19 of file gqt_pointinvol_test.cpp.
Definition at line 4 of file gqt_pointinvol_test.cpp.
Function Documentation
void gqt_point_in ( )
Definition at line 41 of file gqt_pointinvol_test.cpp.
References CHECK_EQUAL, CHECK_ERR, moab::GeomTopoTool::entity_by_id(), ErrorCode, GQT, moab::GeomQueryTool::gttool(), and moab::GeomQueryTool::point_in_volume().
Referenced by main().
    int result          = 0;
    int expected_result = 1;
    double xyz[3]       = { 0.0, 0.0, 0.0 };
    int vol_idx         = 1;
    EntityHandle vol_h  = GQT->gttool()->entity_by_id( 3, vol_idx );
    ErrorCode rval      = GQT->point_in_volume( vol_h, xyz, result );CHECK_ERR( rval );
    CHECK_EQUAL( expected_result, result );
Definition at line 79 of file gqt_pointinvol_test.cpp.
References CHECK_EQUAL, FindVolTestResult::dir, gqt_point_in_vol_dir(), and origin.
    double dir[3]       = { -1.0, 0.0, 0.0 };
    double origin[3]    = { 0.0, 0.0, 0.0 };
    int vol_idx         = 1;
    int result = gqt_point_in_vol_dir( origin, dir, vol_idx );
Definition at line 90 of file gqt_pointinvol_test.cpp.
    int vol_idx         = 1;
    double dir[3]       = { 1.0, 0.0, 0.0 };
Definition at line 102 of file gqt_pointinvol_test.cpp.
    int vol_idx         = 1;
    double dir[3]       = { 0.0, -1.0, 0.0 };
Definition at line 114 of file gqt_pointinvol_test.cpp.
    int vol_idx         = 1;
    double dir[3]       = { 0.0, 1.0, 0.0 };
Definition at line 126 of file gqt_pointinvol_test.cpp.
    int vol_idx         = 1;
    double dir[3]       = { 0.0, 0.0, -1.0 };
Definition at line 138 of file gqt_pointinvol_test.cpp.
    int vol_idx         = 1;
    double dir[3]       = { 0.0, 0.0, 1.0 };
int gqt_point_in_vol_dir ( double  origin[3],
double  dir[3],
int  vol_idx
Definition at line 52 of file gqt_pointinvol_test.cpp.
References CHECK_ERR, moab::GeomTopoTool::entity_by_id(), ErrorCode, GQT, moab::GeomQueryTool::gttool(), moab::GeomQueryTool::point_in_volume(), and moab::GeomQueryTool::ray_fire().
Referenced by gqt_point_in_vol_1(), gqt_point_in_vol_2(), gqt_point_in_vol_3(), gqt_point_in_vol_4(), gqt_point_in_vol_5(), gqt_point_in_vol_6(), gqt_point_on_corner_1(), gqt_point_on_corner_2(), gqt_point_on_corner_3(), gqt_point_on_corner_4(), gqt_point_on_corner_5(), gqt_point_on_corner_6(), gqt_point_on_corner_7(), and gqt_point_on_corner_8().
    int result         = 0;
    double xyz[3];
    double next_surf_dist;
    EntityHandle next_surf;
    // normalise the vector
    double dir_norm = ( dir[0] * dir[0] ) + ( dir[1] * dir[1] ) + ( dir[2] * dir[2] );
    dir[0] = dir[0] / sqrt( dir_norm );
    dir[1] = dir[1] / sqrt( dir_norm );
    dir[2] = dir[2] / sqrt( dir_norm );
    ErrorCode rval = GQT->ray_fire( vol_h, origin, dir, next_surf, next_surf_dist );CHECK_ERR( rval );
    xyz[0] = origin[0] + ( next_surf_dist * dir[0] );
    xyz[1] = origin[1] + ( next_surf_dist * dir[1] );
    xyz[2] = origin[2] + ( next_surf_dist * dir[2] );
    std::cout << xyz[0] << " " << xyz[1] << " " << xyz[2] << std::endl;
    rval = GQT->point_in_volume( vol_h, xyz, result, dir );CHECK_ERR( rval );
    return result;
Definition at line 150 of file gqt_pointinvol_test.cpp.
    int vol_idx         = 1;
    double dir[3]       = { 1.0, 1.0, 1.0 };
Definition at line 162 of file gqt_pointinvol_test.cpp.
    int vol_idx         = 1;
    double dir[3]       = { -1.0, 1.0, 1.0 };
Definition at line 174 of file gqt_pointinvol_test.cpp.
    int vol_idx         = 1;
    double dir[3]       = { 1.0, 1.0, -1.0 };
Definition at line 186 of file gqt_pointinvol_test.cpp.
    int vol_idx         = 1;
    double dir[3]       = { -1.0, 1.0, -1.0 };
Definition at line 198 of file gqt_pointinvol_test.cpp.
    int vol_idx         = 1;
    double dir[3]       = { 1.0, -1.0, 1.0 };
Definition at line 210 of file gqt_pointinvol_test.cpp.
    int vol_idx         = 1;
    double dir[3]       = { -1.0, -1.0, 1.0 };
Definition at line 222 of file gqt_pointinvol_test.cpp.
    int vol_idx         = 1;
    double dir[3]       = { 1.0, -1.0, -1.0 };
Definition at line 234 of file gqt_pointinvol_test.cpp.
    int vol_idx         = 1;
    double dir[3]       = { -1.0, -1.0, -1.0 };
void gqt_setup_test ( )
Definition at line 31 of file gqt_pointinvol_test.cpp.
References CHECK_ERR, ErrorCode, GQT, GTT, moab::GeomQueryTool::initialize(), input_file, and MBI.
    MBI            = new Core();
    ErrorCode rval = MBI->load_file( input_file.c_str() );CHECK_ERR( rval );
    GTT  = new GeomTopoTool( MBI );
    GQT  = new GeomQueryTool( GTT );
    rval = GQT->initialize();CHECK_ERR( rval );
int main ( int  ,
char **
Definition at line 246 of file gqt_pointinvol_test.cpp.
References GQT, gqt_point_in(), gqt_point_in_vol_1(), gqt_point_in_vol_2(), gqt_point_in_vol_3(), gqt_point_in_vol_4(), gqt_point_in_vol_5(), gqt_point_in_vol_6(), gqt_point_on_corner_1(), gqt_point_on_corner_2(), gqt_point_on_corner_3(), gqt_point_on_corner_4(), gqt_setup_test(), GTT, MBI, and RUN_TEST.
    int result = 0;
    result += RUN_TEST( gqt_setup_test );  // setup problem
    result += RUN_TEST( gqt_point_in );    // point in centre
    // rays fired along cardinal directions
    result += RUN_TEST( gqt_point_in_vol_1 );  // point in centre
    result += RUN_TEST( gqt_point_in_vol_2 );  // point in centre
    result += RUN_TEST( gqt_point_in_vol_3 );  // point in centre
    result += RUN_TEST( gqt_point_in_vol_4 );  // point in centre
    result += RUN_TEST( gqt_point_in_vol_5 );  // point in centre
    result += RUN_TEST( gqt_point_in_vol_6 );  // point in centre
    // rays fired at nodes
    result += RUN_TEST( gqt_point_on_corner_1 );
    result += RUN_TEST( gqt_point_on_corner_2 );
    result += RUN_TEST( gqt_point_on_corner_3 );
    result += RUN_TEST( gqt_point_on_corner_4 );
    // result += RUN_TEST(dagmc_point_in({0.0, 0.0, 5.0}); // point in centre
    // result += RUN_TEST(dagmc_point_in({0.0, 0.0, -5.0}); // point in centre
    // result += RUN_TEST(dagmc_point_in({0.0, 5.0, 0.0}); // point in centre
    // result += RUN_TEST(dagmc_point_in({0.0, -5.0, 0.0}); // point in centre
    // result += RUN_TEST(dagmc_point_in({5.0, 0.0, 0.0}); // point in centre
    // result += RUN_TEST(dagmc_point_in({-5.0, 0.0, 0.0}); // point in centre
    delete GQT;
    delete GTT;
    delete MBI;
    return result;
Variable Documentation
Definition at line 17 of file gqt_pointinvol_test.cpp.
Definition at line 16 of file gqt_pointinvol_test.cpp.
Definition at line 29 of file gqt_pointinvol_test.cpp.
Definition at line 15 of file gqt_pointinvol_test.cpp.
