MOAB: Mesh Oriented datABase
(version 5.4.1)
00001 #include <iostream> 00002 #include "moab/Interface.hpp" 00003 #ifndef IS_BUILDING_MB 00004 #define IS_BUILDING_MB 00005 #endif 00006 #include "TestUtil.hpp" 00007 #include "Internals.hpp" 00008 #include "moab/Core.hpp" 00009 00010 #include "moab/GeomQueryTool.hpp" 00011 #include "moab/GeomTopoTool.hpp" 00012 00013 using namespace moab; 00014 00015 Core* MBI; 00016 GeomTopoTool* GTT; 00017 GeomQueryTool* GQT; 00018 00019 #define CHKERR( A ) \ 00020 do \ 00021 { \ 00022 if( MB_SUCCESS != ( A ) ) \ 00023 { \ 00024 std::cerr << "Failure (error code " << ( A ) << ") at " __FILE__ ":" << __LINE__ << std::endl; \ 00025 return A; \ 00026 } \ 00027 } while( false ) 00028 00029 const std::string input_file = TestDir + "unittest/test_geom.h5m"; 00030 00031 void gqt_setup_test() 00032 { 00033 MBI = new Core(); 00034 ErrorCode rval = MBI->load_file( input_file.c_str() );CHECK_ERR( rval ); 00035 00036 GTT = new GeomTopoTool( MBI ); 00037 GQT = new GeomQueryTool( GTT ); 00038 rval = GQT->initialize();CHECK_ERR( rval ); 00039 } 00040 00041 void gqt_point_in() 00042 { 00043 int result = 0; 00044 int expected_result = 1; 00045 double xyz[3] = { 0.0, 0.0, 0.0 }; 00046 int vol_idx = 1; 00047 EntityHandle vol_h = GQT->gttool()->entity_by_id( 3, vol_idx ); 00048 ErrorCode rval = GQT->point_in_volume( vol_h, xyz, result );CHECK_ERR( rval ); 00049 CHECK_EQUAL( expected_result, result ); 00050 } 00051 00052 int gqt_point_in_vol_dir( double origin[3], double dir[3], int vol_idx ) 00053 { 00054 int result = 0; 00055 EntityHandle vol_h = GQT->gttool()->entity_by_id( 3, vol_idx ); 00056 double xyz[3]; 00057 double next_surf_dist; 00058 EntityHandle next_surf; 00059 00060 // normalise the vector 00061 double dir_norm = ( dir[0] * dir[0] ) + ( dir[1] * dir[1] ) + ( dir[2] * dir[2] ); 00062 00063 dir[0] = dir[0] / sqrt( dir_norm ); 00064 dir[1] = dir[1] / sqrt( dir_norm ); 00065 dir[2] = dir[2] / sqrt( dir_norm ); 00066 00067 ErrorCode rval = GQT->ray_fire( vol_h, origin, dir, next_surf, next_surf_dist );CHECK_ERR( rval ); 00068 00069 xyz[0] = origin[0] + ( next_surf_dist * dir[0] ); 00070 xyz[1] = origin[1] + ( next_surf_dist * dir[1] ); 00071 xyz[2] = origin[2] + ( next_surf_dist * dir[2] ); 00072 00073 std::cout << xyz[0] << " " << xyz[1] << " " << xyz[2] << std::endl; 00074 00075 rval = GQT->point_in_volume( vol_h, xyz, result, dir );CHECK_ERR( rval ); 00076 return result; 00077 } 00078 00079 void gqt_point_in_vol_1() 00080 { 00081 double dir[3] = { -1.0, 0.0, 0.0 }; 00082 double origin[3] = { 0.0, 0.0, 0.0 }; 00083 int vol_idx = 1; 00084 int expected_result = 1; 00085 00086 int result = gqt_point_in_vol_dir( origin, dir, vol_idx ); 00087 CHECK_EQUAL( expected_result, result ); 00088 } 00089 00090 void gqt_point_in_vol_2() 00091 { 00092 int expected_result = 1; 00093 int vol_idx = 1; 00094 double dir[3] = { 1.0, 0.0, 0.0 }; 00095 double origin[3] = { 0.0, 0.0, 0.0 }; 00096 00097 int result = gqt_point_in_vol_dir( origin, dir, vol_idx ); 00098 00099 CHECK_EQUAL( expected_result, result ); 00100 } 00101 00102 void gqt_point_in_vol_3() 00103 { 00104 int expected_result = 1; 00105 int vol_idx = 1; 00106 double dir[3] = { 0.0, -1.0, 0.0 }; 00107 double origin[3] = { 0.0, 0.0, 0.0 }; 00108 00109 int result = gqt_point_in_vol_dir( origin, dir, vol_idx ); 00110 00111 CHECK_EQUAL( expected_result, result ); 00112 } 00113 00114 void gqt_point_in_vol_4() 00115 { 00116 int expected_result = 1; 00117 int vol_idx = 1; 00118 double dir[3] = { 0.0, 1.0, 0.0 }; 00119 double origin[3] = { 0.0, 0.0, 0.0 }; 00120 00121 int result = gqt_point_in_vol_dir( origin, dir, vol_idx ); 00122 00123 CHECK_EQUAL( expected_result, result ); 00124 } 00125 00126 void gqt_point_in_vol_5() 00127 { 00128 int expected_result = 1; 00129 int vol_idx = 1; 00130 double dir[3] = { 0.0, 0.0, -1.0 }; 00131 double origin[3] = { 0.0, 0.0, 0.0 }; 00132 00133 int result = gqt_point_in_vol_dir( origin, dir, vol_idx ); 00134 00135 CHECK_EQUAL( expected_result, result ); 00136 } 00137 00138 void gqt_point_in_vol_6() 00139 { 00140 int expected_result = 1; 00141 int vol_idx = 1; 00142 double dir[3] = { 0.0, 0.0, 1.0 }; 00143 double origin[3] = { 0.0, 0.0, 0.0 }; 00144 00145 int result = gqt_point_in_vol_dir( origin, dir, vol_idx ); 00146 00147 CHECK_EQUAL( expected_result, result ); 00148 } 00149 00150 void gqt_point_on_corner_1() 00151 { 00152 int expected_result = 1; 00153 int vol_idx = 1; 00154 double dir[3] = { 1.0, 1.0, 1.0 }; 00155 double origin[3] = { 0.0, 0.0, 0.0 }; 00156 00157 int result = gqt_point_in_vol_dir( origin, dir, vol_idx ); 00158 00159 CHECK_EQUAL( expected_result, result ); 00160 } 00161 00162 void gqt_point_on_corner_2() 00163 { 00164 int expected_result = 1; 00165 int vol_idx = 1; 00166 double dir[3] = { -1.0, 1.0, 1.0 }; 00167 double origin[3] = { 0.0, 0.0, 0.0 }; 00168 00169 int result = gqt_point_in_vol_dir( origin, dir, vol_idx ); 00170 00171 CHECK_EQUAL( expected_result, result ); 00172 } 00173 00174 void gqt_point_on_corner_3() 00175 { 00176 int expected_result = 1; 00177 int vol_idx = 1; 00178 double dir[3] = { 1.0, 1.0, -1.0 }; 00179 double origin[3] = { 0.0, 0.0, 0.0 }; 00180 00181 int result = gqt_point_in_vol_dir( origin, dir, vol_idx ); 00182 00183 CHECK_EQUAL( expected_result, result ); 00184 } 00185 00186 void gqt_point_on_corner_4() 00187 { 00188 int expected_result = 1; 00189 int vol_idx = 1; 00190 double dir[3] = { -1.0, 1.0, -1.0 }; 00191 double origin[3] = { 0.0, 0.0, 0.0 }; 00192 00193 int result = gqt_point_in_vol_dir( origin, dir, vol_idx ); 00194 00195 CHECK_EQUAL( expected_result, result ); 00196 } 00197 00198 void gqt_point_on_corner_5() 00199 { 00200 int expected_result = 1; 00201 int vol_idx = 1; 00202 double dir[3] = { 1.0, -1.0, 1.0 }; 00203 double origin[3] = { 0.0, 0.0, 0.0 }; 00204 00205 int result = gqt_point_in_vol_dir( origin, dir, vol_idx ); 00206 00207 CHECK_EQUAL( expected_result, result ); 00208 } 00209 00210 void gqt_point_on_corner_6() 00211 { 00212 int expected_result = 1; 00213 int vol_idx = 1; 00214 double dir[3] = { -1.0, -1.0, 1.0 }; 00215 double origin[3] = { 0.0, 0.0, 0.0 }; 00216 00217 int result = gqt_point_in_vol_dir( origin, dir, vol_idx ); 00218 00219 CHECK_EQUAL( expected_result, result ); 00220 } 00221 00222 void gqt_point_on_corner_7() 00223 { 00224 int expected_result = 1; 00225 int vol_idx = 1; 00226 double dir[3] = { 1.0, -1.0, -1.0 }; 00227 double origin[3] = { 0.0, 0.0, 0.0 }; 00228 00229 int result = gqt_point_in_vol_dir( origin, dir, vol_idx ); 00230 00231 CHECK_EQUAL( expected_result, result ); 00232 } 00233 00234 void gqt_point_on_corner_8() 00235 { 00236 int expected_result = 1; 00237 int vol_idx = 1; 00238 double dir[3] = { -1.0, -1.0, -1.0 }; 00239 double origin[3] = { 0.0, 0.0, 0.0 }; 00240 00241 int result = gqt_point_in_vol_dir( origin, dir, vol_idx ); 00242 00243 CHECK_EQUAL( expected_result, result ); 00244 } 00245 00246 int main( int /* argc */, char** /* argv */ ) 00247 { 00248 int result = 0; 00249 00250 result += RUN_TEST( gqt_setup_test ); // setup problem 00251 result += RUN_TEST( gqt_point_in ); // point in centre 00252 // rays fired along cardinal directions 00253 result += RUN_TEST( gqt_point_in_vol_1 ); // point in centre 00254 result += RUN_TEST( gqt_point_in_vol_2 ); // point in centre 00255 result += RUN_TEST( gqt_point_in_vol_3 ); // point in centre 00256 result += RUN_TEST( gqt_point_in_vol_4 ); // point in centre 00257 result += RUN_TEST( gqt_point_in_vol_5 ); // point in centre 00258 result += RUN_TEST( gqt_point_in_vol_6 ); // point in centre 00259 // rays fired at nodes 00260 result += RUN_TEST( gqt_point_on_corner_1 ); 00261 result += RUN_TEST( gqt_point_on_corner_2 ); 00262 result += RUN_TEST( gqt_point_on_corner_3 ); 00263 result += RUN_TEST( gqt_point_on_corner_4 ); 00264 00265 // result += RUN_TEST(dagmc_point_in({0.0, 0.0, 5.0}); // point in centre 00266 // result += RUN_TEST(dagmc_point_in({0.0, 0.0, -5.0}); // point in centre 00267 // result += RUN_TEST(dagmc_point_in({0.0, 5.0, 0.0}); // point in centre 00268 // result += RUN_TEST(dagmc_point_in({0.0, -5.0, 0.0}); // point in centre 00269 // result += RUN_TEST(dagmc_point_in({5.0, 0.0, 0.0}); // point in centre 00270 // result += RUN_TEST(dagmc_point_in({-5.0, 0.0, 0.0}); // point in centre 00271 00272 delete GQT; 00273 delete GTT; 00274 delete MBI; 00275 00276 return result; 00277 }
