MOAB: Mesh Oriented datABase
(version 5.4.1)
#include "TSTT_MB_QueryInterface.h"#include "moab/_RMBSet.hpp"#include <iostream>
Include dependency graph for test_rms.cpp:Go to the source code of this file.
Functions | |
| int | compare_coords (double *xval, double *yval, double *zval, double *nodex, double *nodey, double *nodez, const int num_nodes) |
| int | compare_connect (int *connect1, int *connect2, const int num_comps) |
| int | main () |
| int compare_connect | ( | int * | connect1, |
| int * | connect2, | ||
| const int | num_comps | ||
Definition at line 211 of file test_rms.cpp.
Referenced by main().
int i, result = 0;
for( i = 0; i < num_comps; i++ )
if( connect1[i] != connect2[i] ) result++;
connect2[i] = -1;
return result;
| int compare_coords | ( | double * | xval, |
| double * | yval, | ||
| double * | zval, | ||
| double * | nodex, | ||
| double * | nodey, | ||
| double * | nodez, | ||
| const int | num_nodes | ||
Definition at line 194 of file test_rms.cpp.
int i, result = 0;
for( i = 0; i < num_nodes; i++ )
if( xval[i] != nodex[i] || yval[i] != nodey[i] || zval[i] != nodez[i] ) result++;
xval[i] = yval[i] = zval[i] = -2.0;
return result;
| int main | ( | ) |
Definition at line 32 of file test_rms.cpp.
References compare_connect(), and compare_coords().
// very basic test of RMBSet
// The test: instantiate a mesh with 2 tet elements sharing a face;
// represent just the 5 nodes (1-5) and 2 elements (1234 & 3215)
// nodal coordinates: shared tri in x-y plane with edges on x and y
// axes and a node at the origin, plus nodes at z = +- 1
// x4
// . x1 z
// . .\ /\ /\y
// . . \ E1 . |
// 2x------x3 .---->x
// .E2 .
// x5
// . x6
// . . \ E3
// 7x------x8
// . . E4
// x9
double nodex[] = { 0.0, 0.0, 1.0, 0.0, 0.0, 0.0, 0.0, 1.0, 0.0 };
double nodey[] = { 1.0, 0.0, 0.0, 0.0, 0.0, 1.0, 0.0, 0.0, 0.0 };
double nodez[] = { 0.0, 0.0, 0.0, 1.0, -1.0, -2.0, -2.0, -2.0, -3.0 };
int connect[] = { 1, 2, 3, 4, 3, 2, 1, 5, 6, 7, 8, 5, 8, 7, 6, 9 };
const int NUM_NODES = 9;
// construct the RMS holding the nodes
MB_RMBSet node_rms( NUM_NODES, nodex, nodey, nodez, 1, 0 );
// construct two RMS's holding each pair of elements
MB_RMBSet elem_rms1( 2, connect, 1, TSTT_REGION, TSTT_TETRAHEDRON );
MB_RMBSet elem_rms2( 2, &connect[8], 3, TSTT_REGION, TSTT_TETRAHEDRON );
// now do some querying on this mesh
// INFO FUNCTIONS
int entity_type1 = node_rms.entity_type();
int entity_type2 = elem_rms1.entity_type();
if( entity_type1 != TSTT_VERTEX || entity_type2 != TSTT_REGION )
std::cout << "entity_type() function failed." << std::endl;
int entity_topo = elem_rms1.entity_topology();
if( entity_topo != TSTT_TETRAHEDRON ) std::cout << "entity_topology() function failed." << std::endl;
int num_ents1 = node_rms.num_entities();
int num_ents2 = elem_rms1.num_entities();
if( num_ents1 != NUM_NODES || num_ents2 != 2 )
std::cout << "num_entities() function failed for" << ( num_ents1 != NUM_NODES ? "(nodes)" : "" )
<< ( num_ents2 != 2 ? "(elems)" : "" ) << std::endl;
int vpe = elem_rms1.vertices_per_element();
if( vpe != 4 ) std::cout << "vertices_per_element() failed." << std::endl;
// NODES
// get_coordinates
double coords[15];
coords[1] = node_rms.get_coordinates(1);
coords[2] = node_rms.get_coordinates(2);
coords[3] = node_rms.get_coordinates(3);
coords[4] = node_rms.get_coordinates(4);
coords[5] = node_rms.get_coordinates(5);
int result = compare_coords(coords, nodex, nodey, nodez, 5);
if (result == 0) std::cout << "get_coordinates works." << std::endl;
else std::cout << "get_coordinates didn't work; result = " << result << "." << std::endl;
// node_x, node_y, node_z
int num_nodes = NUM_NODES;
double xval[NUM_NODES], yval[NUM_NODES], zval[NUM_NODES];
double *xvalp = &xval[0], *yvalp = &yval[0], *zvalp = &zval[0];
node_rms.node_x( 1, NUM_NODES, &xvalp, &num_nodes );
node_rms.node_y( 1, NUM_NODES, &yvalp, &num_nodes );
node_rms.node_z( 1, NUM_NODES, &zvalp, &num_nodes );
int result = compare_coords( xval, yval, zval, nodex, nodey, nodez, NUM_NODES );
if( result != 0 ) std::cout << "node_[xyz] didn't work; result = " << result << "." << std::endl;
// set_node_x, set_node_y, set_node_z
int i;
for( i = 1; i <= NUM_NODES; i++ )
nodex[i - 1] = (double)i;
nodey[i - 1] = (double)i;
nodez[i - 1] = (double)i;
node_rms.set_node_x( 1, NUM_NODES, nodex, NUM_NODES );
node_rms.set_node_y( 1, NUM_NODES, nodey, NUM_NODES );
node_rms.set_node_z( 1, NUM_NODES, nodez, NUM_NODES );
// ELEMENTS
// elem_connectivity
int* connect2 = NULL;
int size_connect2 = 0;
bool status = elem_rms1.elem_connectivity( 1, 2, &connect2, &size_connect2 );
if( status != true ) std::cout << "elem_connectivity() RETURN VALUE failed." << std::endl;
if( 8 != size_connect2 ) std::cout << "re-sizing of connect2 vector failed." << std::endl;
result = compare_connect( connect2, connect, 8 );
if( result != 0 ) std::cout << "elem_connectivity() VALUES failed." << std::endl;
// set_elem_connectivity
// reverse the connectivity
for( i = 1; i <= 8; i++ )
connect2[i - 1] = connect[8 - i];
elem_rms1.set_elem_connectivity( 1, 2, connect2, size_connect2 );
if( status != true ) std::cout << "set_elem_connectivity() RETURN VALUE failed." << std::endl;
// RMESHSET FIND FUNCTIONS
// find the rmeshsets for a node, and an element in each set
MB_RMBSet *new_rms1, *new_rms2, *new_rms3;
new_rms1 = MB_RMBSet::find_rmeshset( TSTT_VERTEX, TSTT_LAST_TOPOLOGY, reinterpret_cast< const void* >( 2 ) );
new_rms2 = MB_RMBSet::find_rmeshset( TSTT_REGION, TSTT_TETRAHEDRON, reinterpret_cast< const void* >( 2 ) );
new_rms3 = MB_RMBSet::find_rmeshset( TSTT_REGION, TSTT_TETRAHEDRON, reinterpret_cast< const void* >( 4 ) );
if( new_rms1 != &node_rms || new_rms2 != &elem_rms1 || new_rms3 != &elem_rms2 )
std::cout << "find_rmeshset() function failed." << std::endl;
// now test NULL returns
new_rms1 = MB_RMBSet::find_rmeshset( TSTT_VERTEX, TSTT_LAST_TOPOLOGY, reinterpret_cast< const void* >( 10 ) );
new_rms2 = MB_RMBSet::find_rmeshset( TSTT_REGION, TSTT_TETRAHEDRON, reinterpret_cast< const void* >( 0 ) );
new_rms3 = MB_RMBSet::find_rmeshset( TSTT_REGION, TSTT_TETRAHEDRON, reinterpret_cast< const void* >( 5 ) );
if( NULL != new_rms1 || NULL != new_rms2 || NULL != new_rms3 )
std::cout << "find_rmeshset() for NULL RETURN failed." << std::endl;
// test is_in_rmeshset
bool result1, result2, result3;
result1 = node_rms.is_in_rmeshset( reinterpret_cast< const void* >( 6 ) );
result2 = elem_rms1.is_in_rmeshset( reinterpret_cast< const void* >( 2 ) );
result3 = elem_rms2.is_in_rmeshset( reinterpret_cast< const void* >( 4 ) );
if( false == result1 || false == result2 || false == result3 ) std::cout << "is_in_rmeshset() failed." << std::endl;
result1 = node_rms.is_in_rmeshset( reinterpret_cast< const void* >( 10 ) );
result2 = elem_rms1.is_in_rmeshset( reinterpret_cast< const void* >( 4 ) );
result3 = elem_rms2.is_in_rmeshset( reinterpret_cast< const void* >( 2 ) );
if( true == result1 || true == result2 || true == result3 )
std::cout << "is_in_rmeshset() for NULL RETURN failed." << std::endl;
return 1;
