MOAB: Mesh Oriented datABase
(version 5.4.1)
00001 /** 00002 * MOAB, a Mesh-Oriented datABase, is a software component for creating, 00003 * storing and accessing finite element mesh data. 00004 * 00005 * Copyright 2004 Sandia Corporation. Under the terms of Contract 00006 * DE-AC04-94AL85000 with Sandia Corporation, the U.S. Government 00007 * retains certain rights in this software. 00008 * 00009 * This library is free software; you can redistribute it and/or 00010 * modify it under the terms of the GNU Lesser General Public 00011 * License as published by the Free Software Foundation; either 00012 * version 2.1 of the License, or (at your option) any later version. 00013 * 00014 */ 00015 00016 #include "TSTT_MB_QueryInterface.h" 00017 #include "moab/_RMBSet.hpp" 00018 00019 using namespace moab; 00020 00021 int compare_coords( double* xval, 00022 double* yval, 00023 double* zval, 00024 double* nodex, 00025 double* nodey, 00026 double* nodez, 00027 const int num_nodes ); 00028 int compare_connect( int* connect1, int* connect2, const int num_comps ); 00029 00030 #include <iostream> 00031 00032 int main() 00033 { 00034 // very basic test of RMBSet 00035 // The test: instantiate a mesh with 2 tet elements sharing a face; 00036 // represent just the 5 nodes (1-5) and 2 elements (1234 & 3215) 00037 // 00038 00039 // nodal coordinates: shared tri in x-y plane with edges on x and y 00040 // axes and a node at the origin, plus nodes at z = +- 1 00041 // 00042 // x4 00043 // . . 00044 // . x1 z 00045 // . .\ /\ /\y 00046 // . . \ E1 . | 00047 // .. \ .| 00048 // 2x------x3 .---->x 00049 // . . 00050 // .E2 . 00051 // . . 00052 // x5 00053 // . . 00054 // . x6 00055 // . .\ 00056 // . . \ E3 00057 // .. \ 00058 // 7x------x8 00059 // . . 00060 // . . E4 00061 // . . 00062 // x9 00063 // 00064 // 00065 double nodex[] = { 0.0, 0.0, 1.0, 0.0, 0.0, 0.0, 0.0, 1.0, 0.0 }; 00066 double nodey[] = { 1.0, 0.0, 0.0, 0.0, 0.0, 1.0, 0.0, 0.0, 0.0 }; 00067 double nodez[] = { 0.0, 0.0, 0.0, 1.0, -1.0, -2.0, -2.0, -2.0, -3.0 }; 00068 int connect[] = { 1, 2, 3, 4, 3, 2, 1, 5, 6, 7, 8, 5, 8, 7, 6, 9 }; 00069 00070 const int NUM_NODES = 9; 00071 00072 // construct the RMS holding the nodes 00073 MB_RMBSet node_rms( NUM_NODES, nodex, nodey, nodez, 1, 0 ); 00074 00075 // construct two RMS's holding each pair of elements 00076 MB_RMBSet elem_rms1( 2, connect, 1, TSTT_REGION, TSTT_TETRAHEDRON ); 00077 MB_RMBSet elem_rms2( 2, &connect[8], 3, TSTT_REGION, TSTT_TETRAHEDRON ); 00078 00079 // now do some querying on this mesh 00080 00081 // INFO FUNCTIONS 00082 int entity_type1 = node_rms.entity_type(); 00083 int entity_type2 = elem_rms1.entity_type(); 00084 if( entity_type1 != TSTT_VERTEX || entity_type2 != TSTT_REGION ) 00085 std::cout << "entity_type() function failed." << std::endl; 00086 00087 int entity_topo = elem_rms1.entity_topology(); 00088 if( entity_topo != TSTT_TETRAHEDRON ) std::cout << "entity_topology() function failed." << std::endl; 00089 00090 int num_ents1 = node_rms.num_entities(); 00091 int num_ents2 = elem_rms1.num_entities(); 00092 if( num_ents1 != NUM_NODES || num_ents2 != 2 ) 00093 std::cout << "num_entities() function failed for" << ( num_ents1 != NUM_NODES ? "(nodes)" : "" ) 00094 << ( num_ents2 != 2 ? "(elems)" : "" ) << std::endl; 00095 00096 int vpe = elem_rms1.vertices_per_element(); 00097 if( vpe != 4 ) std::cout << "vertices_per_element() failed." << std::endl; 00098 00099 // NODES 00100 /* 00101 // get_coordinates 00102 double coords[15]; 00103 coords[1] = node_rms.get_coordinates(1); 00104 coords[2] = node_rms.get_coordinates(2); 00105 coords[3] = node_rms.get_coordinates(3); 00106 coords[4] = node_rms.get_coordinates(4); 00107 coords[5] = node_rms.get_coordinates(5); 00108 int result = compare_coords(coords, nodex, nodey, nodez, 5); 00109 if (result == 0) std::cout << "get_coordinates works." << std::endl; 00110 else std::cout << "get_coordinates didn't work; result = " << result << "." << std::endl; 00111 */ 00112 // node_x, node_y, node_z 00113 int num_nodes = NUM_NODES; 00114 double xval[NUM_NODES], yval[NUM_NODES], zval[NUM_NODES]; 00115 double *xvalp = &xval[0], *yvalp = &yval[0], *zvalp = &zval[0]; 00116 node_rms.node_x( 1, NUM_NODES, &xvalp, &num_nodes ); 00117 node_rms.node_y( 1, NUM_NODES, &yvalp, &num_nodes ); 00118 node_rms.node_z( 1, NUM_NODES, &zvalp, &num_nodes ); 00119 int result = compare_coords( xval, yval, zval, nodex, nodey, nodez, NUM_NODES ); 00120 if( result != 0 ) std::cout << "node_[xyz] didn't work; result = " << result << "." << std::endl; 00121 00122 // set_node_x, set_node_y, set_node_z 00123 int i; 00124 for( i = 1; i <= NUM_NODES; i++ ) 00125 { 00126 nodex[i - 1] = (double)i; 00127 nodey[i - 1] = (double)i; 00128 nodez[i - 1] = (double)i; 00129 } 00130 node_rms.set_node_x( 1, NUM_NODES, nodex, NUM_NODES ); 00131 node_rms.set_node_y( 1, NUM_NODES, nodey, NUM_NODES ); 00132 node_rms.set_node_z( 1, NUM_NODES, nodez, NUM_NODES ); 00133 node_rms.node_x( 1, NUM_NODES, &xvalp, &num_nodes ); 00134 node_rms.node_y( 1, NUM_NODES, &yvalp, &num_nodes ); 00135 node_rms.node_z( 1, NUM_NODES, &zvalp, &num_nodes ); 00136 result = compare_coords( xval, yval, zval, nodex, nodey, nodez, NUM_NODES ); 00137 if( result != 0 ) std::cout << "node_[xyz] didn't work; result = " << result << "." << std::endl; 00138 00139 // ELEMENTS 00140 // elem_connectivity 00141 int* connect2 = NULL; 00142 int size_connect2 = 0; 00143 bool status = elem_rms1.elem_connectivity( 1, 2, &connect2, &size_connect2 ); 00144 if( status != true ) std::cout << "elem_connectivity() RETURN VALUE failed." << std::endl; 00145 if( 8 != size_connect2 ) std::cout << "re-sizing of connect2 vector failed." << std::endl; 00146 00147 result = compare_connect( connect2, connect, 8 ); 00148 if( result != 0 ) std::cout << "elem_connectivity() VALUES failed." << std::endl; 00149 00150 // set_elem_connectivity 00151 // reverse the connectivity 00152 for( i = 1; i <= 8; i++ ) 00153 connect2[i - 1] = connect[8 - i]; 00154 elem_rms1.set_elem_connectivity( 1, 2, connect2, size_connect2 ); 00155 status = elem_rms1.elem_connectivity( 1, 2, &connect2, &size_connect2 ); 00156 if( status != true ) std::cout << "set_elem_connectivity() RETURN VALUE failed." << std::endl; 00157 00158 result = compare_connect( connect2, connect, 8 ); 00159 if( result != 0 ) std::cout << "elem_connectivity() VALUES failed." << std::endl; 00160 00161 // RMESHSET FIND FUNCTIONS 00162 // find the rmeshsets for a node, and an element in each set 00163 MB_RMBSet *new_rms1, *new_rms2, *new_rms3; 00164 new_rms1 = MB_RMBSet::find_rmeshset( TSTT_VERTEX, TSTT_LAST_TOPOLOGY, reinterpret_cast< const void* >( 2 ) ); 00165 new_rms2 = MB_RMBSet::find_rmeshset( TSTT_REGION, TSTT_TETRAHEDRON, reinterpret_cast< const void* >( 2 ) ); 00166 new_rms3 = MB_RMBSet::find_rmeshset( TSTT_REGION, TSTT_TETRAHEDRON, reinterpret_cast< const void* >( 4 ) ); 00167 if( new_rms1 != &node_rms || new_rms2 != &elem_rms1 || new_rms3 != &elem_rms2 ) 00168 std::cout << "find_rmeshset() function failed." << std::endl; 00169 00170 // now test NULL returns 00171 new_rms1 = MB_RMBSet::find_rmeshset( TSTT_VERTEX, TSTT_LAST_TOPOLOGY, reinterpret_cast< const void* >( 10 ) ); 00172 new_rms2 = MB_RMBSet::find_rmeshset( TSTT_REGION, TSTT_TETRAHEDRON, reinterpret_cast< const void* >( 0 ) ); 00173 new_rms3 = MB_RMBSet::find_rmeshset( TSTT_REGION, TSTT_TETRAHEDRON, reinterpret_cast< const void* >( 5 ) ); 00174 if( NULL != new_rms1 || NULL != new_rms2 || NULL != new_rms3 ) 00175 std::cout << "find_rmeshset() for NULL RETURN failed." << std::endl; 00176 00177 // test is_in_rmeshset 00178 bool result1, result2, result3; 00179 result1 = node_rms.is_in_rmeshset( reinterpret_cast< const void* >( 6 ) ); 00180 result2 = elem_rms1.is_in_rmeshset( reinterpret_cast< const void* >( 2 ) ); 00181 result3 = elem_rms2.is_in_rmeshset( reinterpret_cast< const void* >( 4 ) ); 00182 if( false == result1 || false == result2 || false == result3 ) std::cout << "is_in_rmeshset() failed." << std::endl; 00183 00184 // test is_in_rmeshset 00185 result1 = node_rms.is_in_rmeshset( reinterpret_cast< const void* >( 10 ) ); 00186 result2 = elem_rms1.is_in_rmeshset( reinterpret_cast< const void* >( 4 ) ); 00187 result3 = elem_rms2.is_in_rmeshset( reinterpret_cast< const void* >( 2 ) ); 00188 if( true == result1 || true == result2 || true == result3 ) 00189 std::cout << "is_in_rmeshset() for NULL RETURN failed." << std::endl; 00190 00191 return 1; 00192 } 00193 00194 int compare_coords( double* xval, 00195 double* yval, 00196 double* zval, 00197 double* nodex, 00198 double* nodey, 00199 double* nodez, 00200 const int num_nodes ) 00201 { 00202 int i, result = 0; 00203 for( i = 0; i < num_nodes; i++ ) 00204 { 00205 if( xval[i] != nodex[i] || yval[i] != nodey[i] || zval[i] != nodez[i] ) result++; 00206 xval[i] = yval[i] = zval[i] = -2.0; 00207 } 00208 return result; 00209 } 00210 00211 int compare_connect( int* connect1, int* connect2, const int num_comps ) 00212 { 00213 int i, result = 0; 00214 for( i = 0; i < num_comps; i++ ) 00215 { 00216 if( connect1[i] != connect2[i] ) result++; 00217 connect2[i] = -1; 00218 } 00219 00220 return result; 00221 }
