MOAB: Mesh Oriented datABase
(version 5.4.1)
#include <iostream>#include <sstream>#include "moab/Core.hpp"#include "moab/Interface.hpp"#include "moab/IntxMesh/IntxUtils.hpp"#include "moab/ProgOptions.hpp"#include "TestUtil.hpp"
Include dependency graph for gnom_project_test.cpp:Go to the source code of this file.
Functions | |
| int | main (int argc, char *argv[]) |
| int main | ( | int | argc, |
| char * | argv[] | ||
Definition at line 19 of file gnom_project_test.cpp.
References ProgOptions::addOpt(), CHECK_ARRAYS_EQUAL, moab::Interface::create_meshset(), ErrorCode, moab::Interface::get_coords(), moab::Interface::get_entities_by_dimension(), moab::IntxUtils::global_gnomonic_projection(), moab::Interface::load_file(), mb, MB_CHK_ERR, MESHSET_SET, ProgOptions::parseCommandLine(), moab::R, STRINGIFY, and moab::Interface::write_file().
string filein = STRINGIFY( MESHDIR ) "/mbcslam/eulerHomme.vtk";
string fileout = "project.vtk";
ProgOptions opts;
opts.addOpt< std::string >( "model,m", "input file ", &filein );
opts.addOpt< std::string >( "output,o", "output filename", &fileout );
opts.parseCommandLine( argc, argv );
Core moab;
Interface* mb = &moab;
EntityHandle sf;
ErrorCode rval = mb->create_meshset( MESHSET_SET, sf );MB_CHK_ERR( rval );
rval = mb->load_file( filein.c_str(), &sf );MB_CHK_ERR( rval );
double R = 1.; // should be input
EntityHandle outSet;
rval = mb->create_meshset( MESHSET_SET, outSet );MB_CHK_ERR( rval );
rval = IntxUtils::global_gnomonic_projection( mb, sf, R, false, outSet );MB_CHK_ERR( rval );
rval = mb->write_file( fileout.c_str(), 0, 0, &outSet, 1 );
// skip the test for 32 bit builds, CHECK_ARRAYS_EQUAL macro is not working correctly
#ifndef MOAB_FORCE_32_BIT_HANDLES
// check first cell position
Range cells;
rval = mb->get_entities_by_dimension( outSet, 2, cells );MB_CHK_ERR( rval );
EntityHandle firstCell = cells[0];
double coords[3];
rval = mb->get_coords( &firstCell, 1, coords );MB_CHK_ERR( rval );
// check position
double values[3] = { -0.78867513420303437, 0.78867513420303437, 0 };
CHECK_ARRAYS_EQUAL( coords, 3, values, 3 );
#endif
return 0;
