DirectAccessNoHoles.cpp File Reference
#include "moab/Core.hpp"
#include "moab/ProgOptions.hpp"
#include "moab/ReadUtilIface.hpp"
#include <map>
#include <iostream>
#include <cassert>
+ Include dependency graph for DirectAccessNoHoles.cpp:
Functions
ErrorCode create_mesh_no_holes (Interface *mbImpl, int nquads)
int main (int argc, char **argv)
Function Documentation
ErrorCode create_mesh_no_holes ( Interface *  mbImpl,
int  nquads
Definition at line 160 of file DirectAccessNoHoles.cpp.
References moab::Range::empty(), ErrorCode, moab::Interface::get_adjacencies(), moab::ReadUtilIface::get_element_connect(), moab::ReadUtilIface::get_node_coords(), MB_CHK_SET_ERR, MB_SUCCESS, MBQUAD, and moab::Interface::query_interface().
    // First make the mesh, a 1d array of quads with left hand side x = elem_num; vertices are
    // numbered in layers
    ReadUtilIface* read_iface;
    ErrorCode rval = mbImpl->query_interface( read_iface );MB_CHK_SET_ERR( rval, "Error in query_interface" );
    vector< double* > coords;
    EntityHandle start_vert, start_elem, *connect;
    // Create verts, num is 2(nquads+1) because they're in a 1d row; will initialize coords in loop
    // over quads later
    rval = read_iface->get_node_coords( 3, 2 * ( nquads + 1 ), 0, start_vert, coords );MB_CHK_SET_ERR( rval, "Error in get_node_arrays" );
    // Create quads
    rval = read_iface->get_element_connect( nquads, 4, MBQUAD, 0, start_elem, connect );MB_CHK_SET_ERR( rval, "Error in get_element_connect" );
    for( int i = 0; i < nquads; i++ )
        coords[0][2 * i] = coords[0][2 * i + 1] = (double)i;  // x values are all i
        coords[1][2 * i]                        = 0.0;
        coords[1][2 * i + 1]                    = 1.0;          // y coords
        coords[2][2 * i] = coords[2][2 * i + 1] = (double)0.0;  // z values, all zero (2d mesh)
        EntityHandle quad_v                     = start_vert + 2 * i;
        connect[4 * i + 0]                      = quad_v;
        connect[4 * i + 1]                      = quad_v + 2;
        connect[4 * i + 2]                      = quad_v + 3;
        connect[4 * i + 3]                      = quad_v + 1;
    // Last two vertices
    // Cppcheck warning (false positive): variable coords is assigned a value that is never used
    coords[0][2 * nquads] = coords[0][2 * nquads + 1] = (double)nquads;
    coords[1][2 * nquads]                             = 0.0;
    coords[1][2 * nquads + 1]                         = 1.0;          // y coords
    coords[2][2 * nquads] = coords[2][2 * nquads + 1] = (double)0.0;  // z values, all zero (2d mesh)
    // Call a vertex-quad adjacencies function to generate vertex-element adjacencies in MOAB
    Range dum_range;
    rval = mbImpl->get_adjacencies( &start_vert, 1, 2, false, dum_range );MB_CHK_SET_ERR( rval, "Error in get_adjacencies" );
    assert( !dum_range.empty() );
    return MB_SUCCESS;
int main ( int  argc,
char **  argv
Definition at line 47 of file DirectAccessNoHoles.cpp.
References ProgOptions::addOpt(), moab::Interface::adjacencies_iterate(), moab::Range::begin(), moab::Interface::connect_iterate(), moab::Interface::coords_iterate(), create_mesh_no_holes(), moab::Range::end(), ErrorCode, moab::Interface::get_entities_by_handle(), MB_CHK_SET_ERR, MB_TAG_CREAT, MB_TAG_DENSE, MB_TYPE_DOUBLE, MB_TYPE_INTEGER, ProgOptions::parseCommandLine(), moab::Range::size(), moab::Range::subset_by_dimension(), moab::Interface::tag_get_handle(), and moab::Interface::tag_iterate().
    // Get MOAB instance
    Interface* mbImpl = new( std::nothrow ) Core;
    if( NULL == mbImpl ) return 1;
    int nquads = 1000;
    // Parse options
    ProgOptions opts;
    opts.addOpt< int >( string( "nquads,n" ), string( "Number of quads in the mesh (default = 1000" ), &nquads );
    opts.parseCommandLine( argc, argv );
    // Create simple structured mesh with hole, but using unstructured representation
    ErrorCode rval = create_mesh_no_holes( mbImpl, nquads );MB_CHK_SET_ERR( rval, "Trouble creating mesh" );
    // Get all vertices and non-vertex entities
    Range verts, quads;
    rval = mbImpl->get_entities_by_handle( 0, quads );MB_CHK_SET_ERR( rval, "Trouble getting all entities" );
    verts = quads.subset_by_dimension( 0 );
    quads -= verts;
    // Create tag1 (element-based avg), tag2 (vertex-based avg), tag3 (# connected verts)
    Tag tag1, tag2, tag3;
    rval = mbImpl->tag_get_handle( "tag1", 3, MB_TYPE_DOUBLE, tag1, MB_TAG_DENSE | MB_TAG_CREAT );MB_CHK_SET_ERR( rval, "Trouble creating tag1" );
    double def_val[3] = { 0.0, 0.0, 0.0 };  // need a default value for tag2 because we sum into it
    rval              = mbImpl->tag_get_handle( "tag2", 3, MB_TYPE_DOUBLE, tag2, MB_TAG_DENSE | MB_TAG_CREAT, def_val );MB_CHK_SET_ERR( rval, "Trouble creating tag2" );
    int def_val_int = 0;  // need a default value for tag3 because we increment it
    rval = mbImpl->tag_get_handle( "tag3", 1, MB_TYPE_INTEGER, tag3, MB_TAG_DENSE | MB_TAG_CREAT, &def_val_int );MB_CHK_SET_ERR( rval, "Trouble creating tag3" );
    // Get pointers to connectivity, coordinate, tag, and adjacency arrays; each of these returns a
    // count, which should be compared to the # entities you expect to verify there's only one chunk
    // (no holes)
    int count, vpere;
    EntityHandle* conn_ptr;
    rval = mbImpl->connect_iterate( quads.begin(), quads.end(), conn_ptr, vpere, count );MB_CHK_SET_ERR( rval, "Error in connect_iterate" );
    assert( count == (int)quads.size() );  // Should end up with just one contiguous chunk of quads
    double *x_ptr, *y_ptr, *z_ptr;
    rval = mbImpl->coords_iterate( verts.begin(), verts.end(), x_ptr, y_ptr, z_ptr, count );MB_CHK_SET_ERR( rval, "Error in coords_iterate" );
    assert( count == (int)verts.size() );  // Should end up with just one contiguous chunk of vertices
    double *tag1_ptr, *tag2_ptr;
    int* tag3_ptr;
    rval = mbImpl->tag_iterate( tag1, quads.begin(), quads.end(), count, (void*&)tag1_ptr );MB_CHK_SET_ERR( rval, "Error in tag1_iterate" );
    rval = mbImpl->tag_iterate( tag2, quads.begin(), quads.end(), count, (void*&)tag2_ptr );MB_CHK_SET_ERR( rval, "Error in tag2_iterate" );
    rval = mbImpl->tag_iterate( tag3, quads.begin(), quads.end(), count, (void*&)tag3_ptr );MB_CHK_SET_ERR( rval, "Error in tag3_iterate" );
    const vector< EntityHandle >** adjs_ptr;
    rval = mbImpl->adjacencies_iterate( verts.begin(), verts.end(), adjs_ptr, count );MB_CHK_SET_ERR( rval, "Error in adjacencies_iterate" );
    // Start_ handles used to compute indices into vertex/quad arrays; can use direct subtraction
    // because we know there aren't any holes in the handle spaces for verts or quads
    EntityHandle start_vert = *verts.begin(), start_quad = *quads.begin();
    // Iterate over elements, computing tag1 from coords positions
        tag1_ptr[3 * i + 0] = tag1_ptr[3 * i + 1] = tag1_ptr[3 * i + 2] = 0.0;  // Initialize position for this element
        for( int j = 0; j < vpere; j++ )
        {                                                        // Loop over vertices in this element
            int v_index = conn_ptr[vpere * i + j] - start_vert;  // vert index is just the offset from start vertex
            tag1_ptr[3 * i + 0] += x_ptr[v_index];
            tag1_ptr[3 * i + 1] += y_ptr[v_index];  // Sum vertex positions into tag1...
            tag1_ptr[3 * i + 2] += z_ptr[v_index];
        tag1_ptr[3 * i + 0] /= vpere;
        tag1_ptr[3 * i + 1] /= vpere;  // Then normalize
        tag1_ptr[3 * i + 2] /= vpere;
    }  // Loop over elements in chunk
    // Iterate through vertices, summing positions into tag2 on connected elements and incrementing
    // vertex count
    for( int v = 0; v < count; v++ )
        const vector< EntityHandle >* avec = *( adjs_ptr + v );
        for( vector< EntityHandle >::const_iterator ait = avec->begin(); ait != avec->end(); ++ait )
            // *ait is the quad handle, its index is computed by subtracting the start quad handle
            int a_ind = *ait - start_quad;
            tag2_ptr[3 * a_ind + 0] += x_ptr[v];  // Tag on each element is 3 doubles, x/y/z
            tag2_ptr[3 * a_ind + 1] += y_ptr[v];
            tag2_ptr[3 * a_ind + 2] += z_ptr[v];
            tag3_ptr[a_ind]++;  // Increment the vertex count
    // Normalize tag2 by vertex count (tag3); loop over elements using same approach as before
    // At the same time, compare values of tag1 and tag2
    int n_dis = 0;
    for( Range::iterator q_it = quads.begin(); q_it != quads.end(); ++q_it )
        int i = *q_it - start_quad;
        for( int j = 0; j < 3; j++ )
            tag2_ptr[3 * i + j] /= (double)tag3_ptr[i];  // Normalize by # verts
        if( tag1_ptr[3 * i] != tag2_ptr[3 * i] || tag1_ptr[3 * i + 1] != tag2_ptr[3 * i + 1] ||
            tag1_ptr[3 * i + 2] != tag2_ptr[3 * i + 2] )
            cout << "Tag1, tag2 disagree for element " << *q_it + i << endl;
            n_dis++;
    if( !n_dis ) cout << "All tags agree, success!" << endl;
    // Ok, we're done, shut down MOAB
    delete mbImpl;
    return 0;
