MOAB: Mesh Oriented datABase
(version 5.4.1)
00001 /** @example DirectAccessNoHoles.cpp \n 00002 * \brief Use direct access to MOAB data to avoid calling through API \n 00003 * 00004 * This example creates a 1d row of quad elements, such that all quad and vertex handles 00005 * are contiguous in the handle space and in the database. Then it shows how to get access 00006 * to pointers to MOAB-native data for vertex coordinates, quad connectivity, tag storage, 00007 * and vertex to quad adjacency lists. This allows applications to access this data directly 00008 * without going through MOAB's API. In cases where the mesh is not changing (or only mesh 00009 * vertices are moving), this can save significant execution time in applications. 00010 * \verbatim 00011 * ---------------------- 00012 * | | | | 00013 * | | | | ... 00014 * | | | | 00015 * ---------------------- 00016 * \endverbatim 00017 * -# Initialize MOAB \n 00018 * -# Create a quad mesh, as depicted above 00019 * -# Create 2 dense tags (tag1, tag2) for avg position to assign to quads, and # verts per quad 00020 * (tag3) 00021 * -# Get connectivity, coordinate, tag1 iterators 00022 * -# Iterate through quads, computing midpoint based on vertex positions, set on quad-based 00023 * tag1 00024 * -# Iterate through vertices, summing positions into tag2 on connected quads and incrementing 00025 * vertex count 00026 * -# Iterate through quads, normalizing tag2 by vertex count and comparing values of tag1 and 00027 * tag2 00028 * 00029 * <b>To compile</b>: \n 00030 * make DirectAccessNoHoles MOAB_DIR=<installdir> \n 00031 * <b>To run</b>: ./DirectAccessNoHoles [-nquads <# quads>]\n 00032 * 00033 */ 00034 00035 #include "moab/Core.hpp" 00036 #include "moab/ProgOptions.hpp" 00037 #include "moab/ReadUtilIface.hpp" 00038 #include <map> 00039 #include <iostream> 00040 #include <cassert> 00041 00042 using namespace moab; 00043 using namespace std; 00044 00045 ErrorCode create_mesh_no_holes( Interface* mbImpl, int nquads ); 00046 00047 int main( int argc, char** argv ) 00048 { 00049 // Get MOAB instance 00050 Interface* mbImpl = new( std::nothrow ) Core; 00051 if( NULL == mbImpl ) return 1; 00052 00053 int nquads = 1000; 00054 00055 // Parse options 00056 ProgOptions opts; 00057 opts.addOpt< int >( string( "nquads,n" ), string( "Number of quads in the mesh (default = 1000" ), &nquads ); 00058 opts.parseCommandLine( argc, argv ); 00059 00060 // Create simple structured mesh with hole, but using unstructured representation 00061 ErrorCode rval = create_mesh_no_holes( mbImpl, nquads );MB_CHK_SET_ERR( rval, "Trouble creating mesh" ); 00062 00063 // Get all vertices and non-vertex entities 00064 Range verts, quads; 00065 rval = mbImpl->get_entities_by_handle( 0, quads );MB_CHK_SET_ERR( rval, "Trouble getting all entities" ); 00066 verts = quads.subset_by_dimension( 0 ); 00067 quads -= verts; 00068 00069 // Create tag1 (element-based avg), tag2 (vertex-based avg), tag3 (# connected verts) 00070 Tag tag1, tag2, tag3; 00071 rval = mbImpl->tag_get_handle( "tag1", 3, MB_TYPE_DOUBLE, tag1, MB_TAG_DENSE | MB_TAG_CREAT );MB_CHK_SET_ERR( rval, "Trouble creating tag1" ); 00072 double def_val[3] = { 0.0, 0.0, 0.0 }; // need a default value for tag2 because we sum into it 00073 rval = mbImpl->tag_get_handle( "tag2", 3, MB_TYPE_DOUBLE, tag2, MB_TAG_DENSE | MB_TAG_CREAT, def_val );MB_CHK_SET_ERR( rval, "Trouble creating tag2" ); 00074 int def_val_int = 0; // need a default value for tag3 because we increment it 00075 rval = mbImpl->tag_get_handle( "tag3", 1, MB_TYPE_INTEGER, tag3, MB_TAG_DENSE | MB_TAG_CREAT, &def_val_int );MB_CHK_SET_ERR( rval, "Trouble creating tag3" ); 00076 00077 // Get pointers to connectivity, coordinate, tag, and adjacency arrays; each of these returns a 00078 // count, which should be compared to the # entities you expect to verify there's only one chunk 00079 // (no holes) 00080 int count, vpere; 00081 EntityHandle* conn_ptr; 00082 rval = mbImpl->connect_iterate( quads.begin(), quads.end(), conn_ptr, vpere, count );MB_CHK_SET_ERR( rval, "Error in connect_iterate" ); 00083 assert( count == (int)quads.size() ); // Should end up with just one contiguous chunk of quads 00084 00085 double *x_ptr, *y_ptr, *z_ptr; 00086 rval = mbImpl->coords_iterate( verts.begin(), verts.end(), x_ptr, y_ptr, z_ptr, count );MB_CHK_SET_ERR( rval, "Error in coords_iterate" ); 00087 assert( count == (int)verts.size() ); // Should end up with just one contiguous chunk of vertices 00088 00089 double *tag1_ptr, *tag2_ptr; 00090 int* tag3_ptr; 00091 rval = mbImpl->tag_iterate( tag1, quads.begin(), quads.end(), count, (void*&)tag1_ptr );MB_CHK_SET_ERR( rval, "Error in tag1_iterate" ); 00092 assert( count == (int)quads.size() ); // Should end up with just one contiguous chunk of quads 00093 rval = mbImpl->tag_iterate( tag2, quads.begin(), quads.end(), count, (void*&)tag2_ptr );MB_CHK_SET_ERR( rval, "Error in tag2_iterate" ); 00094 assert( count == (int)quads.size() ); // Should end up with just one contiguous chunk of quads 00095 rval = mbImpl->tag_iterate( tag3, quads.begin(), quads.end(), count, (void*&)tag3_ptr );MB_CHK_SET_ERR( rval, "Error in tag3_iterate" ); 00096 assert( count == (int)quads.size() ); // Should end up with just one contiguous chunk of quads 00097 00098 const vector< EntityHandle >** adjs_ptr; 00099 rval = mbImpl->adjacencies_iterate( verts.begin(), verts.end(), adjs_ptr, count );MB_CHK_SET_ERR( rval, "Error in adjacencies_iterate" ); 00100 assert( count == (int)verts.size() ); // Should end up with just one contiguous chunk of vertices 00101 // Start_ handles used to compute indices into vertex/quad arrays; can use direct subtraction 00102 // because we know there aren't any holes in the handle spaces for verts or quads 00103 EntityHandle start_vert = *verts.begin(), start_quad = *quads.begin(); 00104 00105 // Iterate over elements, computing tag1 from coords positions 00106 for( int i = 0; i < nquads; i++ ) 00107 { 00108 tag1_ptr[3 * i + 0] = tag1_ptr[3 * i + 1] = tag1_ptr[3 * i + 2] = 0.0; // Initialize position for this element 00109 for( int j = 0; j < vpere; j++ ) 00110 { // Loop over vertices in this element 00111 int v_index = conn_ptr[vpere * i + j] - start_vert; // vert index is just the offset from start vertex 00112 tag1_ptr[3 * i + 0] += x_ptr[v_index]; 00113 tag1_ptr[3 * i + 1] += y_ptr[v_index]; // Sum vertex positions into tag1... 00114 tag1_ptr[3 * i + 2] += z_ptr[v_index]; 00115 } 00116 tag1_ptr[3 * i + 0] /= vpere; 00117 tag1_ptr[3 * i + 1] /= vpere; // Then normalize 00118 tag1_ptr[3 * i + 2] /= vpere; 00119 } // Loop over elements in chunk 00120 00121 // Iterate through vertices, summing positions into tag2 on connected elements and incrementing 00122 // vertex count 00123 for( int v = 0; v < count; v++ ) 00124 { 00125 const vector< EntityHandle >* avec = *( adjs_ptr + v ); 00126 for( vector< EntityHandle >::const_iterator ait = avec->begin(); ait != avec->end(); ++ait ) 00127 { 00128 // *ait is the quad handle, its index is computed by subtracting the start quad handle 00129 int a_ind = *ait - start_quad; 00130 tag2_ptr[3 * a_ind + 0] += x_ptr[v]; // Tag on each element is 3 doubles, x/y/z 00131 tag2_ptr[3 * a_ind + 1] += y_ptr[v]; 00132 tag2_ptr[3 * a_ind + 2] += z_ptr[v]; 00133 tag3_ptr[a_ind]++; // Increment the vertex count 00134 } 00135 } 00136 00137 // Normalize tag2 by vertex count (tag3); loop over elements using same approach as before 00138 // At the same time, compare values of tag1 and tag2 00139 int n_dis = 0; 00140 for( Range::iterator q_it = quads.begin(); q_it != quads.end(); ++q_it ) 00141 { 00142 int i = *q_it - start_quad; 00143 for( int j = 0; j < 3; j++ ) 00144 tag2_ptr[3 * i + j] /= (double)tag3_ptr[i]; // Normalize by # verts 00145 if( tag1_ptr[3 * i] != tag2_ptr[3 * i] || tag1_ptr[3 * i + 1] != tag2_ptr[3 * i + 1] || 00146 tag1_ptr[3 * i + 2] != tag2_ptr[3 * i + 2] ) 00147 { 00148 cout << "Tag1, tag2 disagree for element " << *q_it + i << endl; 00149 n_dis++; 00150 } 00151 } 00152 if( !n_dis ) cout << "All tags agree, success!" << endl; 00153 00154 // Ok, we're done, shut down MOAB 00155 delete mbImpl; 00156 00157 return 0; 00158 } 00159 00160 ErrorCode create_mesh_no_holes( Interface* mbImpl, int nquads ) 00161 { 00162 // First make the mesh, a 1d array of quads with left hand side x = elem_num; vertices are 00163 // numbered in layers 00164 ReadUtilIface* read_iface; 00165 ErrorCode rval = mbImpl->query_interface( read_iface );MB_CHK_SET_ERR( rval, "Error in query_interface" ); 00166 vector< double* > coords; 00167 EntityHandle start_vert, start_elem, *connect; 00168 // Create verts, num is 2(nquads+1) because they're in a 1d row; will initialize coords in loop 00169 // over quads later 00170 rval = read_iface->get_node_coords( 3, 2 * ( nquads + 1 ), 0, start_vert, coords );MB_CHK_SET_ERR( rval, "Error in get_node_arrays" ); 00171 // Create quads 00172 rval = read_iface->get_element_connect( nquads, 4, MBQUAD, 0, start_elem, connect );MB_CHK_SET_ERR( rval, "Error in get_element_connect" ); 00173 for( int i = 0; i < nquads; i++ ) 00174 { 00175 coords[0][2 * i] = coords[0][2 * i + 1] = (double)i; // x values are all i 00176 coords[1][2 * i] = 0.0; 00177 coords[1][2 * i + 1] = 1.0; // y coords 00178 coords[2][2 * i] = coords[2][2 * i + 1] = (double)0.0; // z values, all zero (2d mesh) 00179 EntityHandle quad_v = start_vert + 2 * i; 00180 connect[4 * i + 0] = quad_v; 00181 connect[4 * i + 1] = quad_v + 2; 00182 connect[4 * i + 2] = quad_v + 3; 00183 connect[4 * i + 3] = quad_v + 1; 00184 } 00185 00186 // Last two vertices 00187 // Cppcheck warning (false positive): variable coords is assigned a value that is never used 00188 coords[0][2 * nquads] = coords[0][2 * nquads + 1] = (double)nquads; 00189 coords[1][2 * nquads] = 0.0; 00190 coords[1][2 * nquads + 1] = 1.0; // y coords 00191 coords[2][2 * nquads] = coords[2][2 * nquads + 1] = (double)0.0; // z values, all zero (2d mesh) 00192 00193 // Call a vertex-quad adjacencies function to generate vertex-element adjacencies in MOAB 00194 Range dum_range; 00195 rval = mbImpl->get_adjacencies( &start_vert, 1, 2, false, dum_range );MB_CHK_SET_ERR( rval, "Error in get_adjacencies" ); 00196 assert( !dum_range.empty() ); 00197 00198 return MB_SUCCESS; 00199 }
