affinexform_test.cpp File Reference
#include "AffineXform.hpp"
#include "moab/Interface.hpp"
#include <cassert>
#include <iostream>
+ Include dependency graph for affinexform_test.cpp:
Defines
#define ASSERT_VECTORS_EQUAL(A, B)   assert_vectors_equal( ( A ), ( B ), #A, #B, __LINE__ )
#define ASSERT_DOUBLES_EQUAL(A, B)   assert_doubles_equal( ( A ), ( B ), #A, #B, __LINE__ )
#define ASSERT(B)   assert_bool( ( B ), #B, __LINE__ )
Functions
void assert_vectors_equal (const double *a, const double *b, const char *sa, const char *sb, int lineno)
void assert_vectors_equal (const CartVect &a, const CartVect &b, const char *sa, const char *sb, int lineno)
void assert_doubles_equal (double a, double b, const char *sa, const char *sb, int lineno)
void assert_bool (bool b, const char *sb, int lineno)
void test_none ()
void test_translation ()
void test_rotation ()
void test_rotation_from_vec ()
CartVect refl (const CartVect &vect, const CartVect &norm)
void test_reflection ()
void test_scale ()
void test_scale_point ()
void test_accumulate ()
void test_inversion ()
void test_is_reflection ()
int main ()
Variables
const double TOL = 1e-6
int error_count = 0
const CartVect point1 (0.0, 0.0, 0.0)
const CartVect point2 (3.5, 1000,-200)
const CartVect vect1 (0.0, 0.0,-100.0)
const CartVect vect2 (1.0, 0.0, 1.0)
Define Documentation
#define ASSERT (   B)    assert_bool( ( B ), #B, __LINE__ )
Definition at line 78 of file affinexform_test.cpp.
Referenced by test_is_reflection(), and test_scale().
#define ASSERT_DOUBLES_EQUAL (   A,
  B
Definition at line 77 of file affinexform_test.cpp.
Referenced by test_reflection(), test_rotation(), and test_rotation_from_vec().
Function Documentation
void assert_bool ( bool  b,
const char *  sb,
int  lineno
Definition at line 112 of file affinexform_test.cpp.
References error_count.
    if( !b )
        std::cerr << "Assertion failed at line " << lineno << std::endl << "\t" << sb << std::endl;
        ++error_count;
void assert_doubles_equal ( double  a,
double  b,
const char *  sa,
const char *  sb,
int  lineno
Definition at line 101 of file affinexform_test.cpp.
References error_count, and TOL.
    if( fabs( a - b ) > TOL )
                  << "\t" << sa << " == " << sb << std::endl
                  << "\t" << a << " == " << b << std::endl;
        ++error_count;
void assert_vectors_equal ( const double *  a,
const double *  b,
const char *  sa,
const char *  sb,
int  lineno
Definition at line 84 of file affinexform_test.cpp.
Referenced by assert_vectors_equal().
    if( fabs( a[0] - b[0] ) > TOL || fabs( a[1] - b[1] ) > TOL || fabs( a[2] - b[2] ) > TOL )
                  << "\t[" << a[0] << ", " << a[1] << ", " << a[2] << "] == [" << b[0] << ", " << b[1] << ", " << b[2]
                  << "]" << std::endl;
        ++error_count;
void assert_vectors_equal ( const CartVect &  a,
const CartVect &  b,
const char *  sa,
const char *  sb,
int  lineno
Definition at line 96 of file affinexform_test.cpp.
References moab::CartVect::array(), and assert_vectors_equal().
    assert_vectors_equal( a.array(), b.array(), sa, sb, lineno );
CartVect refl ( const CartVect &  vect,
const CartVect &  norm
Definition at line 265 of file affinexform_test.cpp.
References moab::CartVect::normalize().
Referenced by test_accumulate(), test_inversion(), and test_reflection().
    CartVect n( norm );
    n.normalize();
    double d = vect % n;
    return vect - 2 * d * n;
void test_accumulate ( )
Definition at line 361 of file affinexform_test.cpp.
References moab::AffineXform::accumulate(), moab::CartVect::array(), ASSERT_VECTORS_EQUAL, point1, point2, refl(), moab::AffineXform::reflection(), moab::AffineXform::rotation(), moab::AffineXform::scale(), moab::AffineXform::translation(), vect1, vect2, moab::AffineXform::xform_point(), and moab::AffineXform::xform_vector().
Referenced by main().
    CartVect indiv, accum;
    // build an group of transforms.  make sure translation is somewhere in the middle
    AffineXform move, scal, rot1, rot2, refl;
    move = AffineXform::translation( CartVect( 5, -5, 1 ).array() );
    scal = AffineXform::scale( CartVect( 1, 0.5, 2 ).array() );
    rot1 = AffineXform::rotation( M_PI / 3, CartVect( 0.5, 0.5, 1 ).array() );
    rot2 = AffineXform::rotation( M_PI / 4, CartVect( 1.0, 0.0, 0.0 ).array() );
    refl = AffineXform::reflection( CartVect( -1, -1, 0 ).array() );
    AffineXform accu;
    accu.accumulate( scal );
    accu.accumulate( rot1 );
    accu.accumulate( move );
    accu.accumulate( refl );
    accu.accumulate( rot2 );
    accu.xform_point( point1.array(), accum.array() );
    scal.xform_point( point1.array(), indiv.array() );
    rot1.xform_point( indiv.array() );
    move.xform_point( indiv.array() );
    refl.xform_point( indiv.array() );
    rot2.xform_point( indiv.array() );
    ASSERT_VECTORS_EQUAL( accum, indiv );
    accu.xform_point( point2.array(), accum.array() );
    scal.xform_point( point2.array(), indiv.array() );
    accu.xform_vector( vect1.array(), accum.array() );
    scal.xform_vector( vect1.array(), indiv.array() );
    rot1.xform_vector( indiv.array() );
    move.xform_vector( indiv.array() );
    refl.xform_vector( indiv.array() );
    rot2.xform_vector( indiv.array() );
    accu.xform_vector( vect2.array(), accum.array() );
    scal.xform_vector( vect2.array(), indiv.array() );
void test_inversion ( )
Definition at line 412 of file affinexform_test.cpp.
References moab::AffineXform::accumulate(), moab::CartVect::array(), ASSERT_VECTORS_EQUAL, moab::AffineXform::inverse(), point1, point2, refl(), moab::AffineXform::reflection(), moab::AffineXform::rotation(), moab::AffineXform::scale(), moab::AffineXform::translation(), vect1, vect2, moab::AffineXform::xform_point(), and moab::AffineXform::xform_vector().
    CartVect result;
    AffineXform acc;
    acc.accumulate( scal );
    acc.accumulate( rot1 );
    acc.accumulate( move );
    acc.accumulate( refl );
    acc.accumulate( rot2 );
    AffineXform inv = acc.inverse();
    acc.xform_point( point1.array(), result.array() );
    inv.xform_point( result.array() );
    ASSERT_VECTORS_EQUAL( point1, result );
    acc.xform_point( point2.array(), result.array() );
    ASSERT_VECTORS_EQUAL( point2, result );
    acc.xform_vector( vect1.array(), result.array() );
    inv.xform_vector( result.array() );
    ASSERT_VECTORS_EQUAL( vect1, result );
    acc.xform_vector( vect2.array(), result.array() );
    ASSERT_VECTORS_EQUAL( vect2, result );
Definition at line 449 of file affinexform_test.cpp.
References moab::AffineXform::accumulate(), ASSERT, moab::AffineXform::inverse(), moab::AffineXform::reflection(), moab::AffineXform::rotation(), moab::AffineXform::scale(), and moab::AffineXform::translation().
    AffineXform refl1, refl2, scale;
    refl1 = AffineXform::reflection( CartVect( -1, -1, 0 ).array() );
    refl2 = AffineXform::reflection( CartVect( 1, 0, 0 ).array() );
    scale = AffineXform::scale( CartVect( -1, 1, 1 ).array() );
    ASSERT( refl1.reflection() );
    ASSERT( refl2.reflection() );
    ASSERT( scale.reflection() );
    AffineXform inv1, inv2, inv3;
    inv1 = refl1.inverse();
    inv2 = refl2.inverse();
    inv3 = scale.inverse();
    ASSERT( inv1.reflection() );
    ASSERT( inv2.reflection() );
    ASSERT( inv3.reflection() );
    refl1.accumulate( refl2 );
    refl2.accumulate( scale );
    ASSERT( !refl1.reflection() );
    ASSERT( !refl2.reflection() );
    AffineXform rot, mov;
    rot = AffineXform::rotation( M_PI / 4, CartVect( 1, 1, 1 ).array() );
    mov = AffineXform::translation( CartVect( -5, 6, 7 ).array() );
    ASSERT( !rot.reflection() );
    ASSERT( !mov.reflection() );
void test_none ( )
Definition at line 124 of file affinexform_test.cpp.
References moab::CartVect::array(), ASSERT_VECTORS_EQUAL, output, point1, point2, vect1, vect2, moab::AffineXform::xform_point(), and moab::AffineXform::xform_vector().
    // default xform should do nothing.
    CartVect output;
    AffineXform none;
    none.xform_point( point1.array(), output.array() );
    ASSERT_VECTORS_EQUAL( output, point1 );
    none.xform_point( point2.array(), output.array() );
    ASSERT_VECTORS_EQUAL( output, point2 );
    none.xform_vector( vect1.array(), output.array() );
    ASSERT_VECTORS_EQUAL( output, vect1 );
    none.xform_vector( vect2.array(), output.array() );
    ASSERT_VECTORS_EQUAL( output, vect2 );
void test_reflection ( )
Definition at line 273 of file affinexform_test.cpp.
References moab::CartVect::array(), ASSERT_DOUBLES_EQUAL, ASSERT_VECTORS_EQUAL, moab::Matrix3::determinant(), moab::CartVect::length(), moab::AffineXform::matrix(), output, point1, point2, refl(), moab::AffineXform::reflection(), vect1, vect2, moab::AffineXform::xform_point(), and moab::AffineXform::xform_vector().
    CartVect output;
    // reflect about XY plane
    AffineXform ref = AffineXform::reflection( CartVect( 0, 0, 1 ).array() );
    ASSERT_DOUBLES_EQUAL( ref.matrix().determinant(), -1.0 );
    ref.xform_point( point1.array(), output.array() );
    ref.xform_point( point2.array(), output.array() );
    ASSERT_DOUBLES_EQUAL( output.length(), point2.length() );
    ASSERT_VECTORS_EQUAL( output, CartVect( point2[0], point2[1], -point2[2] ) );
    ref.xform_vector( vect1.array(), output.array() );
    ASSERT_DOUBLES_EQUAL( output.length(), vect1.length() );
    ASSERT_VECTORS_EQUAL( output, -vect1 );
    ref.xform_vector( vect2.array(), output.array() );
    ASSERT_DOUBLES_EQUAL( output.length(), vect2.length() );
    ASSERT_VECTORS_EQUAL( output, CartVect( 1, 0, -1 ) );
    // reflect about arbitrary palne
    CartVect norm( 3, 2, 1 );
    ref = AffineXform::reflection( norm.array() );
    ASSERT_VECTORS_EQUAL( output, refl( point2, norm ) );
    ASSERT_VECTORS_EQUAL( output, refl( vect1, norm ) );
    ASSERT_VECTORS_EQUAL( output, refl( vect2, norm ) );
void test_rotation ( )
Definition at line 159 of file affinexform_test.cpp.
References moab::CartVect::array(), ASSERT_DOUBLES_EQUAL, ASSERT_VECTORS_EQUAL, moab::Matrix3::determinant(), moab::CartVect::length(), moab::AffineXform::matrix(), output, point1, point2, moab::AffineXform::rotation(), vect1, vect2, moab::AffineXform::xform_point(), and moab::AffineXform::xform_vector().
    CartVect output;
    // rotate 90 degress about Z axis
    AffineXform rot = AffineXform::rotation( M_PI / 2.0, CartVect( 0, 0, 1 ).array() );
    ASSERT_DOUBLES_EQUAL( rot.matrix().determinant(), 1.0 );
    rot.xform_point( point1.array(), output.array() );
    ASSERT_VECTORS_EQUAL( output, point1 );  // origin not affected by transform
    CartVect expectedz( -point2[1], point2[0], point2[2] );  // in first quadrant
    rot.xform_point( point2.array(), output.array() );
    ASSERT_VECTORS_EQUAL( output, expectedz );
    rot.xform_vector( vect1.array(), output.array() );
    rot.xform_vector( vect2.array(), output.array() );
    ASSERT_VECTORS_EQUAL( output, CartVect( 0, 1, 1 ) );
    // rotate 90 degress about Y axis
    rot = AffineXform::rotation( M_PI / 2.0, CartVect( 0, 1, 0 ).array() );
    CartVect expectedy( point2[2], point2[1], -point2[0] );  // in second quadrant
    ASSERT_VECTORS_EQUAL( output, expectedy );
    ASSERT_VECTORS_EQUAL( output, CartVect( -100, 0, 0 ) );
    // rotate 90 degress about X axis
    rot = AffineXform::rotation( M_PI / 2.0, CartVect( 1, 0, 0 ).array() );
    CartVect expectedx( point2[0], -point2[2], point2[1] );  // in third quadrant
    ASSERT_VECTORS_EQUAL( output, expectedx );
    ASSERT_VECTORS_EQUAL( output, CartVect( 0, 100, 0 ) );
    ASSERT_VECTORS_EQUAL( output, CartVect( 1, -1, 0 ) );
    // rotate 180 degrees about vector in XY plane
    rot = AffineXform::rotation( M_PI, CartVect( 1, 1, 0 ).array() );
    ASSERT_VECTORS_EQUAL( output, CartVect( point2[1], point2[0], -point2[2] ) );
    ASSERT_VECTORS_EQUAL( output, -vect1 );  // vector is in xy plane
    ASSERT_VECTORS_EQUAL( output, CartVect( 0, 1, -1 ) );
Definition at line 247 of file affinexform_test.cpp.
References moab::CartVect::array(), ASSERT_DOUBLES_EQUAL, ASSERT_VECTORS_EQUAL, moab::CartVect::length(), moab::AffineXform::rotation(), and moab::AffineXform::xform_vector().
    CartVect v1( 1, 1, 1 );
    CartVect v2( 1, 0, 0 );
    AffineXform rot = AffineXform::rotation( v1.array(), v2.array() );
    CartVect result;
    rot.xform_vector( v1.array(), result.array() );
    // vectors should be parallel, but not same length
    ASSERT_DOUBLES_EQUAL( result.length(), v1.length() );
    result.normalize();
    ASSERT_VECTORS_EQUAL( result, v2 );
    double v3[] = { -1, 0, 0 };
    rot         = AffineXform::rotation( v3, v2.array() );
    rot.xform_vector( v3, result.array() );
void test_scale ( )
Definition at line 309 of file affinexform_test.cpp.
References moab::CartVect::array(), ASSERT, ASSERT_VECTORS_EQUAL, output, point1, point2, moab::AffineXform::scale(), vect1, and vect2.
    CartVect output;
    AffineXform scale = AffineXform::scale( 1.0 );
    ASSERT( !scale.scale() );
    scale = AffineXform::scale( -1.0 );
    // scale in X only
    scale = AffineXform::scale( CartVect( 2, 1, 1 ).array() );
    ASSERT( scale.scale() );
    scale.xform_point( point1.array(), output.array() );
    ASSERT_VECTORS_EQUAL( output, CartVect( 2 * point1[0], point1[1], point1[2] ) );
    scale.xform_point( point2.array(), output.array() );
    ASSERT_VECTORS_EQUAL( output, CartVect( 2 * point2[0], point2[1], point2[2] ) );
    scale.xform_vector( vect1.array(), output.array() );
    ASSERT_VECTORS_EQUAL( output, CartVect( 2 * vect1[0], vect1[1], vect1[2] ) );
    scale.xform_vector( vect2.array(), output.array() );
    ASSERT_VECTORS_EQUAL( output, CartVect( 2 * vect2[0], vect2[1], vect2[2] ) );
    // scale in all
    scale = AffineXform::scale( CartVect( 0.5, 0.5, 0.5 ).array() );
    ASSERT_VECTORS_EQUAL( output, 0.5 * point1 );
    ASSERT_VECTORS_EQUAL( output, 0.5 * point2 );
    ASSERT_VECTORS_EQUAL( output, 0.5 * vect1 );
    ASSERT_VECTORS_EQUAL( output, 0.5 * vect2 );
void test_scale_point ( )
Definition at line 343 of file affinexform_test.cpp.
References ASSERT_VECTORS_EQUAL, moab::AffineXform::scale(), and moab::AffineXform::xform_point().
    const double point[] = { 2, 3, 4 };
    const double f[]     = { 0.2, 0.1, 0.3 };
    double result[3];
    AffineXform scale = AffineXform::scale( f, point );
    scale.xform_point( point, result );
    ASSERT_VECTORS_EQUAL( result, point );
    const double delta[3] = { 1, 0, 2 };
    const double pt2[]    = { point[0] + delta[0], point[1] + delta[1], point[2] + delta[2] };
    scale.xform_point( pt2, result );
    const double expected[] = { point[0] + f[0] * delta[0], point[1] + f[1] * delta[1], point[2] + f[2] * delta[2] };
    ASSERT_VECTORS_EQUAL( result, expected );
void test_translation ( )
Definition at line 139 of file affinexform_test.cpp.
References moab::CartVect::array(), ASSERT_VECTORS_EQUAL, output, point1, point2, moab::AffineXform::translation(), vect1, vect2, moab::AffineXform::xform_point(), and moab::AffineXform::xform_vector().
    CartVect offset( 1.0, 2.0, 3.0 );
    CartVect output;
    AffineXform move = AffineXform::translation( offset.array() );
    // test that points are moved by offset
    move.xform_point( point1.array(), output.array() );
    ASSERT_VECTORS_EQUAL( output, point1 + offset );
    move.xform_point( point2.array(), output.array() );
    ASSERT_VECTORS_EQUAL( output, point2 + offset );
    // vectors should not be changed by a translation
    move.xform_vector( vect1.array(), output.array() );
    move.xform_vector( vect2.array(), output.array() );
Variable Documentation
