MOAB: Mesh Oriented datABase
(version 5.4.1)
00001 #include "moab/OrientedBox.hpp" 00002 #include "moab/CartVect.hpp" 00003 #include "moab/Core.hpp" 00004 #include "moab/Range.hpp" 00005 00006 using namespace moab; 00007 00008 #include <cassert> 00009 00010 const double TOL = 1e-6; 00011 int error_count = 0; 00012 00013 static void test_basic(); // test basic properties (volume(), etc.) 00014 static void test_contained(); 00015 static void test_ray_intersect(); 00016 static void test_closest_point(); 00017 static void test_build_from_tri(); 00018 static void test_build_from_pts(); 00019 static void test_save(); 00020 00021 #include <iostream> 00022 #define ASSERT_VECTOR_ELEMENT( A, B ) assert_vector_element( ( A ), ( B ), #A, #B, __LINE__ ) 00023 #define ASSERT_VECTORS_EQUAL( A, B ) assert_vectors_equal( ( A ), ( B ), #A, #B, __LINE__ ) 00024 #define ASSERT_DOUBLES_EQUAL( A, B ) assert_doubles_equal( ( A ), ( B ), #A, #B, __LINE__ ) 00025 #define ASSERT( B ) assert_bool( ( B ), #B, __LINE__ ) 00026 00027 static void assert_vector_element( const CartVect& a, const Matrix3& b, const char* sa, const char* sb, int lineno ); 00028 static void assert_vectors_equal( const CartVect& a, const CartVect& b, const char* sa, const char* sb, int lineno ); 00029 static void assert_doubles_equal( double a, double b, const char* sa, const char* sb, int lineno ); 00030 static void assert_bool( bool b, const char* sb, int lineno ); 00031 00032 int main() 00033 { 00034 test_basic(); 00035 test_contained(); 00036 test_ray_intersect(); 00037 test_closest_point(); 00038 test_build_from_tri(); 00039 test_build_from_pts(); 00040 test_save(); 00041 return error_count; 00042 } 00043 00044 /********************* Declare some boxes to test ***************************/ 00045 00046 // define unit box centered at origin 00047 const CartVect origin( 0.0, 0.0, 0.0 ); 00048 const Matrix3 unitaxes( 0.5, 0.0, 0.0, 0.0, 0.5, 0.0, 0.0, 0.0, 0.5 ); 00049 const OrientedBox unitbox( unitaxes, origin ); 00050 00051 // define axis-aligned unit box outside origin 00052 const CartVect unitcenter( 10, 20, 30 ); 00053 const OrientedBox offsetbox( unitaxes, unitcenter ); 00054 00055 // define non-unit centered at origin 00056 const Matrix3 origaxes( 5 * unitaxes.col( 0 ), 10 * unitaxes.col( 1 ), 0.1 * unitaxes.col( 2 ), true ); 00057 const OrientedBox oblongbox( origaxes, origin ); 00058 00059 // define non-axis-aligned box at origin (non unit) ; 00060 // the constructor of OrientedBox normalizes the vectors, and keeps the scales 00061 const CartVect rotax0 = CartVect( 1.0, 1.0, 0.0 ); 00062 const CartVect rotax1 = CartVect( 1.0, -1.0, 1.0 ); 00063 const CartVect rotax2 = CartVect( 1.0, 1.0, 0.0 ) * CartVect( 1.0, -1.0, 1.0 ); 00064 const CartVect rotax[3] = { rotax0, rotax1, rotax2 }; 00065 const OrientedBox rotbox_cv( rotax, origin ); 00066 00067 const Matrix3 rotaxes( rotax0, 00068 rotax1, 00069 rotax2, 00070 false ); // so these are columns, as in the constructor that takes 3 "CartVect"s 00071 const OrientedBox rotbox( rotaxes, origin ); 00072 00073 /********************* Utility methods for tests ***************************/ 00074 00075 // return point at specified fraction between box center and specified box corner 00076 static CartVect scaled_corner( const OrientedBox& box, int corner, double factor ) 00077 { 00078 static const int signs[][3] = { { 1, 1, -1 }, { -1, 1, -1 }, { -1, -1, -1 }, { 1, -1, -1 }, 00079 { 1, 1, 1 }, { -1, 1, 1 }, { -1, -1, 1 }, { 1, -1, 1 } }; 00080 return box.center + signs[corner][0] * factor * box.scaled_axis( 0 ) + 00081 signs[corner][1] * factor * box.scaled_axis( 1 ) + signs[corner][2] * factor * box.scaled_axis( 2 ); 00082 } 00083 00084 // return point at specified fraction between box center and specified box face 00085 static CartVect scaled_face( const OrientedBox& box, int face, double factor ) 00086 { 00087 assert( face >= 0 && face <= 6 ); 00088 int sign = face % 2 ? -1 : 1; 00089 return box.center + factor * sign * box.scaled_axis( face / 2 ); 00090 } 00091 00092 // get vector containing axis lengths, ordered from smallest to largest 00093 static void axis_dims( const Matrix3& axis, CartVect& dims ) 00094 { 00095 dims = CartVect( axis.col( 0 ).length(), axis.col( 1 ).length(), axis.col( 2 ).length() ); 00096 if( dims[0] > dims[1] ) std::swap( dims[0], dims[1] ); 00097 if( dims[1] > dims[2] ) std::swap( dims[1], dims[2] ); 00098 if( dims[0] > dims[1] ) std::swap( dims[0], dims[1] ); 00099 } 00100 00101 /********************* The Actual Tests ***************************/ 00102 // \test Check all basic Oriented Box tests 00103 static void test_basic() 00104 { 00105 CartVect dims; 00106 00107 axis_dims( unitaxes, dims ); 00108 ASSERT_VECTORS_EQUAL( unitbox.center, origin ); 00109 ASSERT_VECTOR_ELEMENT( unitbox.scaled_axis( 0 ), unitaxes ); 00110 ASSERT_VECTOR_ELEMENT( unitbox.scaled_axis( 1 ), unitaxes ); 00111 ASSERT_VECTOR_ELEMENT( unitbox.scaled_axis( 2 ), unitaxes ); 00112 ASSERT_DOUBLES_EQUAL( unitbox.inner_radius(), dims[0] ); 00113 ASSERT_DOUBLES_EQUAL( unitbox.outer_radius(), dims.length() ); 00114 ASSERT_DOUBLES_EQUAL( unitbox.volume(), 8.0 * dims[0] * dims[1] * dims[2] ); 00115 ASSERT_VECTORS_EQUAL( unitbox.dimensions(), 2 * dims ); 00116 00117 axis_dims( unitaxes, dims ); 00118 ASSERT_VECTORS_EQUAL( offsetbox.center, unitcenter ); 00119 ASSERT_VECTOR_ELEMENT( offsetbox.scaled_axis( 0 ), unitaxes ); 00120 ASSERT_VECTOR_ELEMENT( offsetbox.scaled_axis( 1 ), unitaxes ); 00121 ASSERT_VECTOR_ELEMENT( offsetbox.scaled_axis( 2 ), unitaxes ); 00122 ASSERT_DOUBLES_EQUAL( offsetbox.inner_radius(), dims[0] ); 00123 ASSERT_DOUBLES_EQUAL( offsetbox.outer_radius(), dims.length() ); 00124 ASSERT_DOUBLES_EQUAL( offsetbox.volume(), 8.0 * dims[0] * dims[1] * dims[2] ); 00125 ASSERT_VECTORS_EQUAL( offsetbox.dimensions(), 2 * dims ); 00126 00127 axis_dims( origaxes, dims ); 00128 ASSERT_VECTORS_EQUAL( oblongbox.center, origin ); 00129 ASSERT_VECTOR_ELEMENT( oblongbox.scaled_axis( 0 ), origaxes ); 00130 ASSERT_VECTOR_ELEMENT( oblongbox.scaled_axis( 1 ), origaxes ); 00131 ASSERT_VECTOR_ELEMENT( oblongbox.scaled_axis( 2 ), origaxes ); 00132 ASSERT_DOUBLES_EQUAL( oblongbox.inner_radius(), dims[0] ); 00133 ASSERT_DOUBLES_EQUAL( oblongbox.outer_radius(), dims.length() ); 00134 ASSERT_DOUBLES_EQUAL( oblongbox.volume(), 8.0 * dims[0] * dims[1] * dims[2] ); 00135 ASSERT_VECTORS_EQUAL( oblongbox.dimensions(), 2 * dims ); 00136 00137 // test matrix constructor 00138 axis_dims( rotaxes, dims ); 00139 ASSERT_VECTORS_EQUAL( rotbox.center, origin ); 00140 ASSERT_VECTOR_ELEMENT( rotbox.scaled_axis( 0 ), rotaxes ); 00141 ASSERT_VECTOR_ELEMENT( rotbox.scaled_axis( 1 ), rotaxes ); 00142 ASSERT_VECTOR_ELEMENT( rotbox.scaled_axis( 2 ), rotaxes ); 00143 ASSERT_DOUBLES_EQUAL( rotbox.inner_radius(), dims[0] ); 00144 ASSERT_DOUBLES_EQUAL( rotbox.outer_radius(), dims.length() ); 00145 ASSERT_DOUBLES_EQUAL( rotbox.volume(), 8.0 * dims[0] * dims[1] * dims[2] ); 00146 ASSERT_VECTORS_EQUAL( rotbox.dimensions(), 2 * dims ); 00147 00148 // test cartvect constructor; ordering of the axes by length happens in the constructor 00149 ASSERT_VECTORS_EQUAL( rotbox_cv.center, origin ); 00150 ASSERT_VECTORS_EQUAL( rotbox_cv.scaled_axis( 0 ), rotax0 ); 00151 ASSERT_VECTORS_EQUAL( rotbox_cv.scaled_axis( 1 ), rotax1 ); 00152 ASSERT_VECTORS_EQUAL( rotbox_cv.scaled_axis( 2 ), rotax2 ); 00153 ASSERT_DOUBLES_EQUAL( rotbox_cv.inner_radius(), dims[0] ); 00154 ASSERT_DOUBLES_EQUAL( rotbox_cv.outer_radius(), dims.length() ); 00155 ASSERT_DOUBLES_EQUAL( rotbox_cv.volume(), 8.0 * dims[0] * dims[1] * dims[2] ); 00156 ASSERT_VECTORS_EQUAL( rotbox_cv.dimensions(), 2 * dims ); 00157 } 00158 00159 // \test Check all is_contained Oriented Box tests 00160 static void test_contained() 00161 { 00162 // first do tests of unit box 00163 00164 // test points inside box 00165 ASSERT( unitbox.contained( unitbox.center, TOL ) ); 00166 ASSERT( unitbox.contained( scaled_corner( unitbox, 0, 0.6 ), TOL ) ); 00167 ASSERT( unitbox.contained( scaled_corner( unitbox, 1, 0.6 ), TOL ) ); 00168 ASSERT( unitbox.contained( scaled_corner( unitbox, 2, 0.6 ), TOL ) ); 00169 ASSERT( unitbox.contained( scaled_corner( unitbox, 3, 0.6 ), TOL ) ); 00170 ASSERT( unitbox.contained( scaled_corner( unitbox, 4, 0.6 ), TOL ) ); 00171 ASSERT( unitbox.contained( scaled_corner( unitbox, 5, 0.6 ), TOL ) ); 00172 ASSERT( unitbox.contained( scaled_corner( unitbox, 6, 0.6 ), TOL ) ); 00173 ASSERT( unitbox.contained( scaled_corner( unitbox, 7, 0.6 ), TOL ) ); 00174 00175 // test points at box corners 00176 ASSERT( unitbox.contained( scaled_corner( unitbox, 0, 1.0 ), TOL ) ); 00177 ASSERT( unitbox.contained( scaled_corner( unitbox, 1, 1.0 ), TOL ) ); 00178 ASSERT( unitbox.contained( scaled_corner( unitbox, 2, 1.0 ), TOL ) ); 00179 ASSERT( unitbox.contained( scaled_corner( unitbox, 3, 1.0 ), TOL ) ); 00180 ASSERT( unitbox.contained( scaled_corner( unitbox, 4, 1.0 ), TOL ) ); 00181 ASSERT( unitbox.contained( scaled_corner( unitbox, 5, 1.0 ), TOL ) ); 00182 ASSERT( unitbox.contained( scaled_corner( unitbox, 6, 1.0 ), TOL ) ); 00183 ASSERT( unitbox.contained( scaled_corner( unitbox, 7, 1.0 ), TOL ) ); 00184 00185 // test points at center of each face 00186 ASSERT( unitbox.contained( scaled_face( unitbox, 0, 1.0 ), TOL ) ); 00187 ASSERT( unitbox.contained( scaled_face( unitbox, 1, 1.0 ), TOL ) ); 00188 ASSERT( unitbox.contained( scaled_face( unitbox, 2, 1.0 ), TOL ) ); 00189 ASSERT( unitbox.contained( scaled_face( unitbox, 3, 1.0 ), TOL ) ); 00190 ASSERT( unitbox.contained( scaled_face( unitbox, 4, 1.0 ), TOL ) ); 00191 ASSERT( unitbox.contained( scaled_face( unitbox, 5, 1.0 ), TOL ) ); 00192 00193 // test points beyond each corner 00194 ASSERT( !unitbox.contained( scaled_corner( unitbox, 0, 1.2 ), TOL ) ); 00195 ASSERT( !unitbox.contained( scaled_corner( unitbox, 1, 1.2 ), TOL ) ); 00196 ASSERT( !unitbox.contained( scaled_corner( unitbox, 2, 1.2 ), TOL ) ); 00197 ASSERT( !unitbox.contained( scaled_corner( unitbox, 3, 1.2 ), TOL ) ); 00198 ASSERT( !unitbox.contained( scaled_corner( unitbox, 4, 1.2 ), TOL ) ); 00199 ASSERT( !unitbox.contained( scaled_corner( unitbox, 5, 1.2 ), TOL ) ); 00200 ASSERT( !unitbox.contained( scaled_corner( unitbox, 6, 1.2 ), TOL ) ); 00201 ASSERT( !unitbox.contained( scaled_corner( unitbox, 7, 1.2 ), TOL ) ); 00202 00203 // test points beyond the center of each face 00204 ASSERT( !unitbox.contained( scaled_face( unitbox, 0, 1.3 ), TOL ) ); 00205 ASSERT( !unitbox.contained( scaled_face( unitbox, 1, 1.3 ), TOL ) ); 00206 ASSERT( !unitbox.contained( scaled_face( unitbox, 2, 1.3 ), TOL ) ); 00207 ASSERT( !unitbox.contained( scaled_face( unitbox, 3, 1.3 ), TOL ) ); 00208 ASSERT( !unitbox.contained( scaled_face( unitbox, 4, 1.3 ), TOL ) ); 00209 ASSERT( !unitbox.contained( scaled_face( unitbox, 5, 1.3 ), TOL ) ); 00210 00211 // now do offset box 00212 00213 // test points inside box 00214 ASSERT( offsetbox.contained( offsetbox.center, TOL ) ); 00215 ASSERT( offsetbox.contained( scaled_corner( offsetbox, 0, 0.6 ), TOL ) ); 00216 ASSERT( offsetbox.contained( scaled_corner( offsetbox, 1, 0.6 ), TOL ) ); 00217 ASSERT( offsetbox.contained( scaled_corner( offsetbox, 2, 0.6 ), TOL ) ); 00218 ASSERT( offsetbox.contained( scaled_corner( offsetbox, 3, 0.6 ), TOL ) ); 00219 ASSERT( offsetbox.contained( scaled_corner( offsetbox, 4, 0.6 ), TOL ) ); 00220 ASSERT( offsetbox.contained( scaled_corner( offsetbox, 5, 0.6 ), TOL ) ); 00221 ASSERT( offsetbox.contained( scaled_corner( offsetbox, 6, 0.6 ), TOL ) ); 00222 ASSERT( offsetbox.contained( scaled_corner( offsetbox, 7, 0.6 ), TOL ) ); 00223 00224 // test points at box corners 00225 ASSERT( offsetbox.contained( scaled_corner( offsetbox, 0, 1.0 ), TOL ) ); 00226 ASSERT( offsetbox.contained( scaled_corner( offsetbox, 1, 1.0 ), TOL ) ); 00227 ASSERT( offsetbox.contained( scaled_corner( offsetbox, 2, 1.0 ), TOL ) ); 00228 ASSERT( offsetbox.contained( scaled_corner( offsetbox, 3, 1.0 ), TOL ) ); 00229 ASSERT( offsetbox.contained( scaled_corner( offsetbox, 4, 1.0 ), TOL ) ); 00230 ASSERT( offsetbox.contained( scaled_corner( offsetbox, 5, 1.0 ), TOL ) ); 00231 ASSERT( offsetbox.contained( scaled_corner( offsetbox, 6, 1.0 ), TOL ) ); 00232 ASSERT( offsetbox.contained( scaled_corner( offsetbox, 7, 1.0 ), TOL ) ); 00233 00234 // test points at center of each face 00235 ASSERT( offsetbox.contained( scaled_face( offsetbox, 0, 1.0 ), TOL ) ); 00236 ASSERT( offsetbox.contained( scaled_face( offsetbox, 1, 1.0 ), TOL ) ); 00237 ASSERT( offsetbox.contained( scaled_face( offsetbox, 2, 1.0 ), TOL ) ); 00238 ASSERT( offsetbox.contained( scaled_face( offsetbox, 3, 1.0 ), TOL ) ); 00239 ASSERT( offsetbox.contained( scaled_face( offsetbox, 4, 1.0 ), TOL ) ); 00240 ASSERT( offsetbox.contained( scaled_face( offsetbox, 5, 1.0 ), TOL ) ); 00241 00242 // test points beyond each corner 00243 ASSERT( !offsetbox.contained( scaled_corner( offsetbox, 0, 1.2 ), TOL ) ); 00244 ASSERT( !offsetbox.contained( scaled_corner( offsetbox, 1, 1.2 ), TOL ) ); 00245 ASSERT( !offsetbox.contained( scaled_corner( offsetbox, 2, 1.2 ), TOL ) ); 00246 ASSERT( !offsetbox.contained( scaled_corner( offsetbox, 3, 1.2 ), TOL ) ); 00247 ASSERT( !offsetbox.contained( scaled_corner( offsetbox, 4, 1.2 ), TOL ) ); 00248 ASSERT( !offsetbox.contained( scaled_corner( offsetbox, 5, 1.2 ), TOL ) ); 00249 ASSERT( !offsetbox.contained( scaled_corner( offsetbox, 6, 1.2 ), TOL ) ); 00250 ASSERT( !offsetbox.contained( scaled_corner( offsetbox, 7, 1.2 ), TOL ) ); 00251 00252 // test points beyond the center of each face 00253 ASSERT( !offsetbox.contained( scaled_face( offsetbox, 0, 1.3 ), TOL ) ); 00254 ASSERT( !offsetbox.contained( scaled_face( offsetbox, 1, 1.3 ), TOL ) ); 00255 ASSERT( !offsetbox.contained( scaled_face( offsetbox, 2, 1.3 ), TOL ) ); 00256 ASSERT( !offsetbox.contained( scaled_face( offsetbox, 3, 1.3 ), TOL ) ); 00257 ASSERT( !offsetbox.contained( scaled_face( offsetbox, 4, 1.3 ), TOL ) ); 00258 ASSERT( !offsetbox.contained( scaled_face( offsetbox, 5, 1.3 ), TOL ) ); 00259 00260 // now do oblong box 00261 00262 // test points inside box 00263 ASSERT( oblongbox.contained( oblongbox.center, TOL ) ); 00264 ASSERT( oblongbox.contained( scaled_corner( oblongbox, 0, 0.6 ), TOL ) ); 00265 ASSERT( oblongbox.contained( scaled_corner( oblongbox, 1, 0.6 ), TOL ) ); 00266 ASSERT( oblongbox.contained( scaled_corner( oblongbox, 2, 0.6 ), TOL ) ); 00267 ASSERT( oblongbox.contained( scaled_corner( oblongbox, 3, 0.6 ), TOL ) ); 00268 ASSERT( oblongbox.contained( scaled_corner( oblongbox, 4, 0.6 ), TOL ) ); 00269 ASSERT( oblongbox.contained( scaled_corner( oblongbox, 5, 0.6 ), TOL ) ); 00270 ASSERT( oblongbox.contained( scaled_corner( oblongbox, 6, 0.6 ), TOL ) ); 00271 ASSERT( oblongbox.contained( scaled_corner( oblongbox, 7, 0.6 ), TOL ) ); 00272 00273 // test points at box corners 00274 ASSERT( oblongbox.contained( scaled_corner( oblongbox, 0, 1.0 ), TOL ) ); 00275 ASSERT( oblongbox.contained( scaled_corner( oblongbox, 1, 1.0 ), TOL ) ); 00276 ASSERT( oblongbox.contained( scaled_corner( oblongbox, 2, 1.0 ), TOL ) ); 00277 ASSERT( oblongbox.contained( scaled_corner( oblongbox, 3, 1.0 ), TOL ) ); 00278 ASSERT( oblongbox.contained( scaled_corner( oblongbox, 4, 1.0 ), TOL ) ); 00279 ASSERT( oblongbox.contained( scaled_corner( oblongbox, 5, 1.0 ), TOL ) ); 00280 ASSERT( oblongbox.contained( scaled_corner( oblongbox, 6, 1.0 ), TOL ) ); 00281 ASSERT( oblongbox.contained( scaled_corner( oblongbox, 7, 1.0 ), TOL ) ); 00282 00283 // test points at center of each face 00284 ASSERT( oblongbox.contained( scaled_face( oblongbox, 0, 1.0 ), TOL ) ); 00285 ASSERT( oblongbox.contained( scaled_face( oblongbox, 1, 1.0 ), TOL ) ); 00286 ASSERT( oblongbox.contained( scaled_face( oblongbox, 2, 1.0 ), TOL ) ); 00287 ASSERT( oblongbox.contained( scaled_face( oblongbox, 3, 1.0 ), TOL ) ); 00288 ASSERT( oblongbox.contained( scaled_face( oblongbox, 4, 1.0 ), TOL ) ); 00289 ASSERT( oblongbox.contained( scaled_face( oblongbox, 5, 1.0 ), TOL ) ); 00290 00291 // test points beyond each corner 00292 ASSERT( !oblongbox.contained( scaled_corner( oblongbox, 0, 1.2 ), TOL ) ); 00293 ASSERT( !oblongbox.contained( scaled_corner( oblongbox, 1, 1.2 ), TOL ) ); 00294 ASSERT( !oblongbox.contained( scaled_corner( oblongbox, 2, 1.2 ), TOL ) ); 00295 ASSERT( !oblongbox.contained( scaled_corner( oblongbox, 3, 1.2 ), TOL ) ); 00296 ASSERT( !oblongbox.contained( scaled_corner( oblongbox, 4, 1.2 ), TOL ) ); 00297 ASSERT( !oblongbox.contained( scaled_corner( oblongbox, 5, 1.2 ), TOL ) ); 00298 ASSERT( !oblongbox.contained( scaled_corner( oblongbox, 6, 1.2 ), TOL ) ); 00299 ASSERT( !oblongbox.contained( scaled_corner( oblongbox, 7, 1.2 ), TOL ) ); 00300 00301 // test points beyond the center of each face 00302 ASSERT( !oblongbox.contained( scaled_face( oblongbox, 0, 1.3 ), TOL ) ); 00303 ASSERT( !oblongbox.contained( scaled_face( oblongbox, 1, 1.3 ), TOL ) ); 00304 ASSERT( !oblongbox.contained( scaled_face( oblongbox, 2, 1.3 ), TOL ) ); 00305 ASSERT( !oblongbox.contained( scaled_face( oblongbox, 3, 1.3 ), TOL ) ); 00306 ASSERT( !oblongbox.contained( scaled_face( oblongbox, 4, 1.3 ), TOL ) ); 00307 ASSERT( !oblongbox.contained( scaled_face( oblongbox, 5, 1.3 ), TOL ) ); 00308 00309 // now do offset box 00310 00311 // test points inside box 00312 ASSERT( offsetbox.contained( offsetbox.center, TOL ) ); 00313 ASSERT( offsetbox.contained( scaled_corner( offsetbox, 0, 0.6 ), TOL ) ); 00314 ASSERT( offsetbox.contained( scaled_corner( offsetbox, 1, 0.6 ), TOL ) ); 00315 ASSERT( offsetbox.contained( scaled_corner( offsetbox, 2, 0.6 ), TOL ) ); 00316 ASSERT( offsetbox.contained( scaled_corner( offsetbox, 3, 0.6 ), TOL ) ); 00317 ASSERT( offsetbox.contained( scaled_corner( offsetbox, 4, 0.6 ), TOL ) ); 00318 ASSERT( offsetbox.contained( scaled_corner( offsetbox, 5, 0.6 ), TOL ) ); 00319 ASSERT( offsetbox.contained( scaled_corner( offsetbox, 6, 0.6 ), TOL ) ); 00320 ASSERT( offsetbox.contained( scaled_corner( offsetbox, 7, 0.6 ), TOL ) ); 00321 00322 // test points at box corners 00323 ASSERT( offsetbox.contained( scaled_corner( offsetbox, 0, 1.0 ), TOL ) ); 00324 ASSERT( offsetbox.contained( scaled_corner( offsetbox, 1, 1.0 ), TOL ) ); 00325 ASSERT( offsetbox.contained( scaled_corner( offsetbox, 2, 1.0 ), TOL ) ); 00326 ASSERT( offsetbox.contained( scaled_corner( offsetbox, 3, 1.0 ), TOL ) ); 00327 ASSERT( offsetbox.contained( scaled_corner( offsetbox, 4, 1.0 ), TOL ) ); 00328 ASSERT( offsetbox.contained( scaled_corner( offsetbox, 5, 1.0 ), TOL ) ); 00329 ASSERT( offsetbox.contained( scaled_corner( offsetbox, 6, 1.0 ), TOL ) ); 00330 ASSERT( offsetbox.contained( scaled_corner( offsetbox, 7, 1.0 ), TOL ) ); 00331 00332 // test points at center of each face 00333 ASSERT( offsetbox.contained( scaled_face( offsetbox, 0, 1.0 ), TOL ) ); 00334 ASSERT( offsetbox.contained( scaled_face( offsetbox, 1, 1.0 ), TOL ) ); 00335 ASSERT( offsetbox.contained( scaled_face( offsetbox, 2, 1.0 ), TOL ) ); 00336 ASSERT( offsetbox.contained( scaled_face( offsetbox, 3, 1.0 ), TOL ) ); 00337 ASSERT( offsetbox.contained( scaled_face( offsetbox, 4, 1.0 ), TOL ) ); 00338 ASSERT( offsetbox.contained( scaled_face( offsetbox, 5, 1.0 ), TOL ) ); 00339 00340 // test points beyond each corner 00341 ASSERT( !offsetbox.contained( scaled_corner( offsetbox, 0, 1.2 ), TOL ) ); 00342 ASSERT( !offsetbox.contained( scaled_corner( offsetbox, 1, 1.2 ), TOL ) ); 00343 ASSERT( !offsetbox.contained( scaled_corner( offsetbox, 2, 1.2 ), TOL ) ); 00344 ASSERT( !offsetbox.contained( scaled_corner( offsetbox, 3, 1.2 ), TOL ) ); 00345 ASSERT( !offsetbox.contained( scaled_corner( offsetbox, 4, 1.2 ), TOL ) ); 00346 ASSERT( !offsetbox.contained( scaled_corner( offsetbox, 5, 1.2 ), TOL ) ); 00347 ASSERT( !offsetbox.contained( scaled_corner( offsetbox, 6, 1.2 ), TOL ) ); 00348 ASSERT( !offsetbox.contained( scaled_corner( offsetbox, 7, 1.2 ), TOL ) ); 00349 00350 // test points beyond the center of each face 00351 ASSERT( !offsetbox.contained( scaled_face( offsetbox, 0, 1.3 ), TOL ) ); 00352 ASSERT( !offsetbox.contained( scaled_face( offsetbox, 1, 1.3 ), TOL ) ); 00353 ASSERT( !offsetbox.contained( scaled_face( offsetbox, 2, 1.3 ), TOL ) ); 00354 ASSERT( !offsetbox.contained( scaled_face( offsetbox, 3, 1.3 ), TOL ) ); 00355 ASSERT( !offsetbox.contained( scaled_face( offsetbox, 4, 1.3 ), TOL ) ); 00356 ASSERT( !offsetbox.contained( scaled_face( offsetbox, 5, 1.3 ), TOL ) ); 00357 00358 // now do rotated box 00359 00360 // test points inside box 00361 ASSERT( rotbox.contained( rotbox.center, TOL ) ); 00362 ASSERT( rotbox.contained( scaled_corner( rotbox, 0, 0.6 ), TOL ) ); 00363 ASSERT( rotbox.contained( scaled_corner( rotbox, 1, 0.6 ), TOL ) ); 00364 ASSERT( rotbox.contained( scaled_corner( rotbox, 2, 0.6 ), TOL ) ); 00365 ASSERT( rotbox.contained( scaled_corner( rotbox, 3, 0.6 ), TOL ) ); 00366 ASSERT( rotbox.contained( scaled_corner( rotbox, 4, 0.6 ), TOL ) ); 00367 ASSERT( rotbox.contained( scaled_corner( rotbox, 5, 0.6 ), TOL ) ); 00368 ASSERT( rotbox.contained( scaled_corner( rotbox, 6, 0.6 ), TOL ) ); 00369 ASSERT( rotbox.contained( scaled_corner( rotbox, 7, 0.6 ), TOL ) ); 00370 00371 // test points at box corners 00372 ASSERT( rotbox.contained( scaled_corner( rotbox, 0, 1.0 ), TOL ) ); 00373 ASSERT( rotbox.contained( scaled_corner( rotbox, 1, 1.0 ), TOL ) ); 00374 ASSERT( rotbox.contained( scaled_corner( rotbox, 2, 1.0 ), TOL ) ); 00375 ASSERT( rotbox.contained( scaled_corner( rotbox, 3, 1.0 ), TOL ) ); 00376 ASSERT( rotbox.contained( scaled_corner( rotbox, 4, 1.0 ), TOL ) ); 00377 ASSERT( rotbox.contained( scaled_corner( rotbox, 5, 1.0 ), TOL ) ); 00378 ASSERT( rotbox.contained( scaled_corner( rotbox, 6, 1.0 ), TOL ) ); 00379 ASSERT( rotbox.contained( scaled_corner( rotbox, 7, 1.0 ), TOL ) ); 00380 00381 // test points at center of each face 00382 ASSERT( rotbox.contained( scaled_face( rotbox, 0, 1.0 ), TOL ) ); 00383 ASSERT( rotbox.contained( scaled_face( rotbox, 1, 1.0 ), TOL ) ); 00384 ASSERT( rotbox.contained( scaled_face( rotbox, 2, 1.0 ), TOL ) ); 00385 ASSERT( rotbox.contained( scaled_face( rotbox, 3, 1.0 ), TOL ) ); 00386 ASSERT( rotbox.contained( scaled_face( rotbox, 4, 1.0 ), TOL ) ); 00387 ASSERT( rotbox.contained( scaled_face( rotbox, 5, 1.0 ), TOL ) ); 00388 00389 // test points beyond each corner 00390 ASSERT( !rotbox.contained( scaled_corner( rotbox, 0, 1.2 ), TOL ) ); 00391 ASSERT( !rotbox.contained( scaled_corner( rotbox, 1, 1.2 ), TOL ) ); 00392 ASSERT( !rotbox.contained( scaled_corner( rotbox, 2, 1.2 ), TOL ) ); 00393 ASSERT( !rotbox.contained( scaled_corner( rotbox, 3, 1.2 ), TOL ) ); 00394 ASSERT( !rotbox.contained( scaled_corner( rotbox, 4, 1.2 ), TOL ) ); 00395 ASSERT( !rotbox.contained( scaled_corner( rotbox, 5, 1.2 ), TOL ) ); 00396 ASSERT( !rotbox.contained( scaled_corner( rotbox, 6, 1.2 ), TOL ) ); 00397 ASSERT( !rotbox.contained( scaled_corner( rotbox, 7, 1.2 ), TOL ) ); 00398 00399 // test points beyond the center of each face 00400 ASSERT( !rotbox.contained( scaled_face( rotbox, 0, 1.3 ), TOL ) ); 00401 ASSERT( !rotbox.contained( scaled_face( rotbox, 1, 1.3 ), TOL ) ); 00402 ASSERT( !rotbox.contained( scaled_face( rotbox, 2, 1.3 ), TOL ) ); 00403 ASSERT( !rotbox.contained( scaled_face( rotbox, 3, 1.3 ), TOL ) ); 00404 ASSERT( !rotbox.contained( scaled_face( rotbox, 4, 1.3 ), TOL ) ); 00405 ASSERT( !rotbox.contained( scaled_face( rotbox, 5, 1.3 ), TOL ) ); 00406 } 00407 00408 // \test Check all closest point query on Oriented Box tests 00409 static void test_closest_point() 00410 { 00411 CartVect result; 00412 00413 // start with unit box 00414 00415 // test locations inside box 00416 unitbox.closest_location_in_box( unitbox.center, result ); 00417 ASSERT_VECTORS_EQUAL( result, unitbox.center ); 00418 double f = 0.5; 00419 unitbox.closest_location_in_box( scaled_corner( unitbox, 0, f ), result ); 00420 ASSERT_VECTORS_EQUAL( result, scaled_corner( unitbox, 0, f ) ); 00421 unitbox.closest_location_in_box( scaled_corner( unitbox, 1, f ), result ); 00422 ASSERT_VECTORS_EQUAL( result, scaled_corner( unitbox, 1, f ) ); 00423 unitbox.closest_location_in_box( scaled_corner( unitbox, 2, f ), result ); 00424 ASSERT_VECTORS_EQUAL( result, scaled_corner( unitbox, 2, f ) ); 00425 unitbox.closest_location_in_box( scaled_corner( unitbox, 3, f ), result ); 00426 ASSERT_VECTORS_EQUAL( result, scaled_corner( unitbox, 3, f ) ); 00427 unitbox.closest_location_in_box( scaled_corner( unitbox, 4, f ), result ); 00428 ASSERT_VECTORS_EQUAL( result, scaled_corner( unitbox, 4, f ) ); 00429 unitbox.closest_location_in_box( scaled_corner( unitbox, 5, f ), result ); 00430 ASSERT_VECTORS_EQUAL( result, scaled_corner( unitbox, 5, f ) ); 00431 unitbox.closest_location_in_box( scaled_corner( unitbox, 6, f ), result ); 00432 ASSERT_VECTORS_EQUAL( result, scaled_corner( unitbox, 6, f ) ); 00433 unitbox.closest_location_in_box( scaled_corner( unitbox, 7, f ), result ); 00434 ASSERT_VECTORS_EQUAL( result, scaled_corner( unitbox, 7, f ) ); 00435 00436 // test each corner 00437 f = 1.0; 00438 unitbox.closest_location_in_box( scaled_corner( unitbox, 0, f ), result ); 00439 ASSERT_VECTORS_EQUAL( result, scaled_corner( unitbox, 0, f ) ); 00440 unitbox.closest_location_in_box( scaled_corner( unitbox, 1, f ), result ); 00441 ASSERT_VECTORS_EQUAL( result, scaled_corner( unitbox, 1, f ) ); 00442 unitbox.closest_location_in_box( scaled_corner( unitbox, 2, f ), result ); 00443 ASSERT_VECTORS_EQUAL( result, scaled_corner( unitbox, 2, f ) ); 00444 unitbox.closest_location_in_box( scaled_corner( unitbox, 3, f ), result ); 00445 ASSERT_VECTORS_EQUAL( result, scaled_corner( unitbox, 3, f ) ); 00446 unitbox.closest_location_in_box( scaled_corner( unitbox, 4, f ), result ); 00447 ASSERT_VECTORS_EQUAL( result, scaled_corner( unitbox, 4, f ) ); 00448 unitbox.closest_location_in_box( scaled_corner( unitbox, 5, f ), result ); 00449 ASSERT_VECTORS_EQUAL( result, scaled_corner( unitbox, 5, f ) ); 00450 unitbox.closest_location_in_box( scaled_corner( unitbox, 6, f ), result ); 00451 ASSERT_VECTORS_EQUAL( result, scaled_corner( unitbox, 6, f ) ); 00452 unitbox.closest_location_in_box( scaled_corner( unitbox, 7, f ), result ); 00453 ASSERT_VECTORS_EQUAL( result, scaled_corner( unitbox, 7, f ) ); 00454 00455 // test outside each corner 00456 f = 1.5; 00457 unitbox.closest_location_in_box( scaled_corner( unitbox, 0, f ), result ); 00458 ASSERT_VECTORS_EQUAL( result, scaled_corner( unitbox, 0, 1 ) ); 00459 unitbox.closest_location_in_box( scaled_corner( unitbox, 1, f ), result ); 00460 ASSERT_VECTORS_EQUAL( result, scaled_corner( unitbox, 1, 1 ) ); 00461 unitbox.closest_location_in_box( scaled_corner( unitbox, 2, f ), result ); 00462 ASSERT_VECTORS_EQUAL( result, scaled_corner( unitbox, 2, 1 ) ); 00463 unitbox.closest_location_in_box( scaled_corner( unitbox, 3, f ), result ); 00464 ASSERT_VECTORS_EQUAL( result, scaled_corner( unitbox, 3, 1 ) ); 00465 unitbox.closest_location_in_box( scaled_corner( unitbox, 4, f ), result ); 00466 ASSERT_VECTORS_EQUAL( result, scaled_corner( unitbox, 4, 1 ) ); 00467 unitbox.closest_location_in_box( scaled_corner( unitbox, 5, f ), result ); 00468 ASSERT_VECTORS_EQUAL( result, scaled_corner( unitbox, 5, 1 ) ); 00469 unitbox.closest_location_in_box( scaled_corner( unitbox, 6, f ), result ); 00470 ASSERT_VECTORS_EQUAL( result, scaled_corner( unitbox, 6, 1 ) ); 00471 unitbox.closest_location_in_box( scaled_corner( unitbox, 7, f ), result ); 00472 ASSERT_VECTORS_EQUAL( result, scaled_corner( unitbox, 7, 1 ) ); 00473 00474 // test on each face 00475 f = 1.0; 00476 unitbox.closest_location_in_box( scaled_face( unitbox, 0, f ), result ); 00477 ASSERT_VECTORS_EQUAL( result, scaled_face( unitbox, 0, f ) ); 00478 unitbox.closest_location_in_box( scaled_face( unitbox, 1, f ), result ); 00479 ASSERT_VECTORS_EQUAL( result, scaled_face( unitbox, 1, f ) ); 00480 unitbox.closest_location_in_box( scaled_face( unitbox, 2, f ), result ); 00481 ASSERT_VECTORS_EQUAL( result, scaled_face( unitbox, 2, f ) ); 00482 unitbox.closest_location_in_box( scaled_face( unitbox, 3, f ), result ); 00483 ASSERT_VECTORS_EQUAL( result, scaled_face( unitbox, 3, f ) ); 00484 unitbox.closest_location_in_box( scaled_face( unitbox, 4, f ), result ); 00485 ASSERT_VECTORS_EQUAL( result, scaled_face( unitbox, 4, f ) ); 00486 unitbox.closest_location_in_box( scaled_face( unitbox, 5, f ), result ); 00487 ASSERT_VECTORS_EQUAL( result, scaled_face( unitbox, 5, f ) ); 00488 00489 // test outside each face 00490 f = 1.5; 00491 unitbox.closest_location_in_box( scaled_face( unitbox, 0, f ), result ); 00492 ASSERT_VECTORS_EQUAL( result, scaled_face( unitbox, 0, 1 ) ); 00493 unitbox.closest_location_in_box( scaled_face( unitbox, 1, f ), result ); 00494 ASSERT_VECTORS_EQUAL( result, scaled_face( unitbox, 1, 1 ) ); 00495 unitbox.closest_location_in_box( scaled_face( unitbox, 2, f ), result ); 00496 ASSERT_VECTORS_EQUAL( result, scaled_face( unitbox, 2, 1 ) ); 00497 unitbox.closest_location_in_box( scaled_face( unitbox, 3, f ), result ); 00498 ASSERT_VECTORS_EQUAL( result, scaled_face( unitbox, 3, 1 ) ); 00499 unitbox.closest_location_in_box( scaled_face( unitbox, 4, f ), result ); 00500 ASSERT_VECTORS_EQUAL( result, scaled_face( unitbox, 4, 1 ) ); 00501 unitbox.closest_location_in_box( scaled_face( unitbox, 5, f ), result ); 00502 ASSERT_VECTORS_EQUAL( result, scaled_face( unitbox, 5, 1 ) ); 00503 00504 // next offset box 00505 00506 // test locations inside box 00507 offsetbox.closest_location_in_box( offsetbox.center, result ); 00508 ASSERT_VECTORS_EQUAL( result, offsetbox.center ); 00509 f = 0.5; 00510 offsetbox.closest_location_in_box( scaled_corner( offsetbox, 0, f ), result ); 00511 ASSERT_VECTORS_EQUAL( result, scaled_corner( offsetbox, 0, f ) ); 00512 offsetbox.closest_location_in_box( scaled_corner( offsetbox, 1, f ), result ); 00513 ASSERT_VECTORS_EQUAL( result, scaled_corner( offsetbox, 1, f ) ); 00514 offsetbox.closest_location_in_box( scaled_corner( offsetbox, 2, f ), result ); 00515 ASSERT_VECTORS_EQUAL( result, scaled_corner( offsetbox, 2, f ) ); 00516 offsetbox.closest_location_in_box( scaled_corner( offsetbox, 3, f ), result ); 00517 ASSERT_VECTORS_EQUAL( result, scaled_corner( offsetbox, 3, f ) ); 00518 offsetbox.closest_location_in_box( scaled_corner( offsetbox, 4, f ), result ); 00519 ASSERT_VECTORS_EQUAL( result, scaled_corner( offsetbox, 4, f ) ); 00520 offsetbox.closest_location_in_box( scaled_corner( offsetbox, 5, f ), result ); 00521 ASSERT_VECTORS_EQUAL( result, scaled_corner( offsetbox, 5, f ) ); 00522 offsetbox.closest_location_in_box( scaled_corner( offsetbox, 6, f ), result ); 00523 ASSERT_VECTORS_EQUAL( result, scaled_corner( offsetbox, 6, f ) ); 00524 offsetbox.closest_location_in_box( scaled_corner( offsetbox, 7, f ), result ); 00525 ASSERT_VECTORS_EQUAL( result, scaled_corner( offsetbox, 7, f ) ); 00526 00527 // test each corner 00528 f = 1.0; 00529 offsetbox.closest_location_in_box( scaled_corner( offsetbox, 0, f ), result ); 00530 ASSERT_VECTORS_EQUAL( result, scaled_corner( offsetbox, 0, f ) ); 00531 offsetbox.closest_location_in_box( scaled_corner( offsetbox, 1, f ), result ); 00532 ASSERT_VECTORS_EQUAL( result, scaled_corner( offsetbox, 1, f ) ); 00533 offsetbox.closest_location_in_box( scaled_corner( offsetbox, 2, f ), result ); 00534 ASSERT_VECTORS_EQUAL( result, scaled_corner( offsetbox, 2, f ) ); 00535 offsetbox.closest_location_in_box( scaled_corner( offsetbox, 3, f ), result ); 00536 ASSERT_VECTORS_EQUAL( result, scaled_corner( offsetbox, 3, f ) ); 00537 offsetbox.closest_location_in_box( scaled_corner( offsetbox, 4, f ), result ); 00538 ASSERT_VECTORS_EQUAL( result, scaled_corner( offsetbox, 4, f ) ); 00539 offsetbox.closest_location_in_box( scaled_corner( offsetbox, 5, f ), result ); 00540 ASSERT_VECTORS_EQUAL( result, scaled_corner( offsetbox, 5, f ) ); 00541 offsetbox.closest_location_in_box( scaled_corner( offsetbox, 6, f ), result ); 00542 ASSERT_VECTORS_EQUAL( result, scaled_corner( offsetbox, 6, f ) ); 00543 offsetbox.closest_location_in_box( scaled_corner( offsetbox, 7, f ), result ); 00544 ASSERT_VECTORS_EQUAL( result, scaled_corner( offsetbox, 7, f ) ); 00545 00546 // test outside each corner 00547 f = 1.5; 00548 offsetbox.closest_location_in_box( scaled_corner( offsetbox, 0, f ), result ); 00549 ASSERT_VECTORS_EQUAL( result, scaled_corner( offsetbox, 0, 1 ) ); 00550 offsetbox.closest_location_in_box( scaled_corner( offsetbox, 1, f ), result ); 00551 ASSERT_VECTORS_EQUAL( result, scaled_corner( offsetbox, 1, 1 ) ); 00552 offsetbox.closest_location_in_box( scaled_corner( offsetbox, 2, f ), result ); 00553 ASSERT_VECTORS_EQUAL( result, scaled_corner( offsetbox, 2, 1 ) ); 00554 offsetbox.closest_location_in_box( scaled_corner( offsetbox, 3, f ), result ); 00555 ASSERT_VECTORS_EQUAL( result, scaled_corner( offsetbox, 3, 1 ) ); 00556 offsetbox.closest_location_in_box( scaled_corner( offsetbox, 4, f ), result ); 00557 ASSERT_VECTORS_EQUAL( result, scaled_corner( offsetbox, 4, 1 ) ); 00558 offsetbox.closest_location_in_box( scaled_corner( offsetbox, 5, f ), result ); 00559 ASSERT_VECTORS_EQUAL( result, scaled_corner( offsetbox, 5, 1 ) ); 00560 offsetbox.closest_location_in_box( scaled_corner( offsetbox, 6, f ), result ); 00561 ASSERT_VECTORS_EQUAL( result, scaled_corner( offsetbox, 6, 1 ) ); 00562 offsetbox.closest_location_in_box( scaled_corner( offsetbox, 7, f ), result ); 00563 ASSERT_VECTORS_EQUAL( result, scaled_corner( offsetbox, 7, 1 ) ); 00564 00565 // test on each face 00566 f = 1.0; 00567 offsetbox.closest_location_in_box( scaled_face( offsetbox, 0, f ), result ); 00568 ASSERT_VECTORS_EQUAL( result, scaled_face( offsetbox, 0, f ) ); 00569 offsetbox.closest_location_in_box( scaled_face( offsetbox, 1, f ), result ); 00570 ASSERT_VECTORS_EQUAL( result, scaled_face( offsetbox, 1, f ) ); 00571 offsetbox.closest_location_in_box( scaled_face( offsetbox, 2, f ), result ); 00572 ASSERT_VECTORS_EQUAL( result, scaled_face( offsetbox, 2, f ) ); 00573 offsetbox.closest_location_in_box( scaled_face( offsetbox, 3, f ), result ); 00574 ASSERT_VECTORS_EQUAL( result, scaled_face( offsetbox, 3, f ) ); 00575 offsetbox.closest_location_in_box( scaled_face( offsetbox, 4, f ), result ); 00576 ASSERT_VECTORS_EQUAL( result, scaled_face( offsetbox, 4, f ) ); 00577 offsetbox.closest_location_in_box( scaled_face( offsetbox, 5, f ), result ); 00578 ASSERT_VECTORS_EQUAL( result, scaled_face( offsetbox, 5, f ) ); 00579 00580 // test outside each face 00581 f = 1.5; 00582 offsetbox.closest_location_in_box( scaled_face( offsetbox, 0, f ), result ); 00583 ASSERT_VECTORS_EQUAL( result, scaled_face( offsetbox, 0, 1 ) ); 00584 offsetbox.closest_location_in_box( scaled_face( offsetbox, 1, f ), result ); 00585 ASSERT_VECTORS_EQUAL( result, scaled_face( offsetbox, 1, 1 ) ); 00586 offsetbox.closest_location_in_box( scaled_face( offsetbox, 2, f ), result ); 00587 ASSERT_VECTORS_EQUAL( result, scaled_face( offsetbox, 2, 1 ) ); 00588 offsetbox.closest_location_in_box( scaled_face( offsetbox, 3, f ), result ); 00589 ASSERT_VECTORS_EQUAL( result, scaled_face( offsetbox, 3, 1 ) ); 00590 offsetbox.closest_location_in_box( scaled_face( offsetbox, 4, f ), result ); 00591 ASSERT_VECTORS_EQUAL( result, scaled_face( offsetbox, 4, 1 ) ); 00592 offsetbox.closest_location_in_box( scaled_face( offsetbox, 5, f ), result ); 00593 ASSERT_VECTORS_EQUAL( result, scaled_face( offsetbox, 5, 1 ) ); 00594 00595 // next oblong box 00596 00597 // test locations inside box 00598 oblongbox.closest_location_in_box( oblongbox.center, result ); 00599 ASSERT_VECTORS_EQUAL( result, oblongbox.center ); 00600 f = 0.5; 00601 oblongbox.closest_location_in_box( scaled_corner( oblongbox, 0, f ), result ); 00602 ASSERT_VECTORS_EQUAL( result, scaled_corner( oblongbox, 0, f ) ); 00603 oblongbox.closest_location_in_box( scaled_corner( oblongbox, 1, f ), result ); 00604 ASSERT_VECTORS_EQUAL( result, scaled_corner( oblongbox, 1, f ) ); 00605 oblongbox.closest_location_in_box( scaled_corner( oblongbox, 2, f ), result ); 00606 ASSERT_VECTORS_EQUAL( result, scaled_corner( oblongbox, 2, f ) ); 00607 oblongbox.closest_location_in_box( scaled_corner( oblongbox, 3, f ), result ); 00608 ASSERT_VECTORS_EQUAL( result, scaled_corner( oblongbox, 3, f ) ); 00609 oblongbox.closest_location_in_box( scaled_corner( oblongbox, 4, f ), result ); 00610 ASSERT_VECTORS_EQUAL( result, scaled_corner( oblongbox, 4, f ) ); 00611 oblongbox.closest_location_in_box( scaled_corner( oblongbox, 5, f ), result ); 00612 ASSERT_VECTORS_EQUAL( result, scaled_corner( oblongbox, 5, f ) ); 00613 oblongbox.closest_location_in_box( scaled_corner( oblongbox, 6, f ), result ); 00614 ASSERT_VECTORS_EQUAL( result, scaled_corner( oblongbox, 6, f ) ); 00615 oblongbox.closest_location_in_box( scaled_corner( oblongbox, 7, f ), result ); 00616 ASSERT_VECTORS_EQUAL( result, scaled_corner( oblongbox, 7, f ) ); 00617 00618 // test each corner 00619 f = 1.0; 00620 oblongbox.closest_location_in_box( scaled_corner( oblongbox, 0, f ), result ); 00621 ASSERT_VECTORS_EQUAL( result, scaled_corner( oblongbox, 0, f ) ); 00622 oblongbox.closest_location_in_box( scaled_corner( oblongbox, 1, f ), result ); 00623 ASSERT_VECTORS_EQUAL( result, scaled_corner( oblongbox, 1, f ) ); 00624 oblongbox.closest_location_in_box( scaled_corner( oblongbox, 2, f ), result ); 00625 ASSERT_VECTORS_EQUAL( result, scaled_corner( oblongbox, 2, f ) ); 00626 oblongbox.closest_location_in_box( scaled_corner( oblongbox, 3, f ), result ); 00627 ASSERT_VECTORS_EQUAL( result, scaled_corner( oblongbox, 3, f ) ); 00628 oblongbox.closest_location_in_box( scaled_corner( oblongbox, 4, f ), result ); 00629 ASSERT_VECTORS_EQUAL( result, scaled_corner( oblongbox, 4, f ) ); 00630 oblongbox.closest_location_in_box( scaled_corner( oblongbox, 5, f ), result ); 00631 ASSERT_VECTORS_EQUAL( result, scaled_corner( oblongbox, 5, f ) ); 00632 oblongbox.closest_location_in_box( scaled_corner( oblongbox, 6, f ), result ); 00633 ASSERT_VECTORS_EQUAL( result, scaled_corner( oblongbox, 6, f ) ); 00634 oblongbox.closest_location_in_box( scaled_corner( oblongbox, 7, f ), result ); 00635 ASSERT_VECTORS_EQUAL( result, scaled_corner( oblongbox, 7, f ) ); 00636 00637 // test outside each corner 00638 f = 1.5; 00639 oblongbox.closest_location_in_box( scaled_corner( oblongbox, 0, f ), result ); 00640 ASSERT_VECTORS_EQUAL( result, scaled_corner( oblongbox, 0, 1 ) ); 00641 oblongbox.closest_location_in_box( scaled_corner( oblongbox, 1, f ), result ); 00642 ASSERT_VECTORS_EQUAL( result, scaled_corner( oblongbox, 1, 1 ) ); 00643 oblongbox.closest_location_in_box( scaled_corner( oblongbox, 2, f ), result ); 00644 ASSERT_VECTORS_EQUAL( result, scaled_corner( oblongbox, 2, 1 ) ); 00645 oblongbox.closest_location_in_box( scaled_corner( oblongbox, 3, f ), result ); 00646 ASSERT_VECTORS_EQUAL( result, scaled_corner( oblongbox, 3, 1 ) ); 00647 oblongbox.closest_location_in_box( scaled_corner( oblongbox, 4, f ), result ); 00648 ASSERT_VECTORS_EQUAL( result, scaled_corner( oblongbox, 4, 1 ) ); 00649 oblongbox.closest_location_in_box( scaled_corner( oblongbox, 5, f ), result ); 00650 ASSERT_VECTORS_EQUAL( result, scaled_corner( oblongbox, 5, 1 ) ); 00651 oblongbox.closest_location_in_box( scaled_corner( oblongbox, 6, f ), result ); 00652 ASSERT_VECTORS_EQUAL( result, scaled_corner( oblongbox, 6, 1 ) ); 00653 oblongbox.closest_location_in_box( scaled_corner( oblongbox, 7, f ), result ); 00654 ASSERT_VECTORS_EQUAL( result, scaled_corner( oblongbox, 7, 1 ) ); 00655 00656 // test on each face 00657 f = 1.0; 00658 oblongbox.closest_location_in_box( scaled_face( oblongbox, 0, f ), result ); 00659 ASSERT_VECTORS_EQUAL( result, scaled_face( oblongbox, 0, f ) ); 00660 oblongbox.closest_location_in_box( scaled_face( oblongbox, 1, f ), result ); 00661 ASSERT_VECTORS_EQUAL( result, scaled_face( oblongbox, 1, f ) ); 00662 oblongbox.closest_location_in_box( scaled_face( oblongbox, 2, f ), result ); 00663 ASSERT_VECTORS_EQUAL( result, scaled_face( oblongbox, 2, f ) ); 00664 oblongbox.closest_location_in_box( scaled_face( oblongbox, 3, f ), result ); 00665 ASSERT_VECTORS_EQUAL( result, scaled_face( oblongbox, 3, f ) ); 00666 oblongbox.closest_location_in_box( scaled_face( oblongbox, 4, f ), result ); 00667 ASSERT_VECTORS_EQUAL( result, scaled_face( oblongbox, 4, f ) ); 00668 oblongbox.closest_location_in_box( scaled_face( oblongbox, 5, f ), result ); 00669 ASSERT_VECTORS_EQUAL( result, scaled_face( oblongbox, 5, f ) ); 00670 00671 // test outside each face 00672 f = 1.5; 00673 oblongbox.closest_location_in_box( scaled_face( oblongbox, 0, f ), result ); 00674 ASSERT_VECTORS_EQUAL( result, scaled_face( oblongbox, 0, 1 ) ); 00675 oblongbox.closest_location_in_box( scaled_face( oblongbox, 1, f ), result ); 00676 ASSERT_VECTORS_EQUAL( result, scaled_face( oblongbox, 1, 1 ) ); 00677 oblongbox.closest_location_in_box( scaled_face( oblongbox, 2, f ), result ); 00678 ASSERT_VECTORS_EQUAL( result, scaled_face( oblongbox, 2, 1 ) ); 00679 oblongbox.closest_location_in_box( scaled_face( oblongbox, 3, f ), result ); 00680 ASSERT_VECTORS_EQUAL( result, scaled_face( oblongbox, 3, 1 ) ); 00681 oblongbox.closest_location_in_box( scaled_face( oblongbox, 4, f ), result ); 00682 ASSERT_VECTORS_EQUAL( result, scaled_face( oblongbox, 4, 1 ) ); 00683 oblongbox.closest_location_in_box( scaled_face( oblongbox, 5, f ), result ); 00684 ASSERT_VECTORS_EQUAL( result, scaled_face( oblongbox, 5, 1 ) ); 00685 00686 // next rotated box 00687 00688 // test locations inside box 00689 rotbox.closest_location_in_box( rotbox.center, result ); 00690 ASSERT_VECTORS_EQUAL( result, rotbox.center ); 00691 f = 0.5; 00692 rotbox.closest_location_in_box( scaled_corner( rotbox, 0, f ), result ); 00693 ASSERT_VECTORS_EQUAL( result, scaled_corner( rotbox, 0, f ) ); 00694 rotbox.closest_location_in_box( scaled_corner( rotbox, 1, f ), result ); 00695 ASSERT_VECTORS_EQUAL( result, scaled_corner( rotbox, 1, f ) ); 00696 rotbox.closest_location_in_box( scaled_corner( rotbox, 2, f ), result ); 00697 ASSERT_VECTORS_EQUAL( result, scaled_corner( rotbox, 2, f ) ); 00698 rotbox.closest_location_in_box( scaled_corner( rotbox, 3, f ), result ); 00699 ASSERT_VECTORS_EQUAL( result, scaled_corner( rotbox, 3, f ) ); 00700 rotbox.closest_location_in_box( scaled_corner( rotbox, 4, f ), result ); 00701 ASSERT_VECTORS_EQUAL( result, scaled_corner( rotbox, 4, f ) ); 00702 rotbox.closest_location_in_box( scaled_corner( rotbox, 5, f ), result ); 00703 ASSERT_VECTORS_EQUAL( result, scaled_corner( rotbox, 5, f ) ); 00704 rotbox.closest_location_in_box( scaled_corner( rotbox, 6, f ), result ); 00705 ASSERT_VECTORS_EQUAL( result, scaled_corner( rotbox, 6, f ) ); 00706 rotbox.closest_location_in_box( scaled_corner( rotbox, 7, f ), result ); 00707 ASSERT_VECTORS_EQUAL( result, scaled_corner( rotbox, 7, f ) ); 00708 00709 // test each corner 00710 f = 1.0; 00711 rotbox.closest_location_in_box( scaled_corner( rotbox, 0, f ), result ); 00712 ASSERT_VECTORS_EQUAL( result, scaled_corner( rotbox, 0, f ) ); 00713 rotbox.closest_location_in_box( scaled_corner( rotbox, 1, f ), result ); 00714 ASSERT_VECTORS_EQUAL( result, scaled_corner( rotbox, 1, f ) ); 00715 rotbox.closest_location_in_box( scaled_corner( rotbox, 2, f ), result ); 00716 ASSERT_VECTORS_EQUAL( result, scaled_corner( rotbox, 2, f ) ); 00717 rotbox.closest_location_in_box( scaled_corner( rotbox, 3, f ), result ); 00718 ASSERT_VECTORS_EQUAL( result, scaled_corner( rotbox, 3, f ) ); 00719 rotbox.closest_location_in_box( scaled_corner( rotbox, 4, f ), result ); 00720 ASSERT_VECTORS_EQUAL( result, scaled_corner( rotbox, 4, f ) ); 00721 rotbox.closest_location_in_box( scaled_corner( rotbox, 5, f ), result ); 00722 ASSERT_VECTORS_EQUAL( result, scaled_corner( rotbox, 5, f ) ); 00723 rotbox.closest_location_in_box( scaled_corner( rotbox, 6, f ), result ); 00724 ASSERT_VECTORS_EQUAL( result, scaled_corner( rotbox, 6, f ) ); 00725 rotbox.closest_location_in_box( scaled_corner( rotbox, 7, f ), result ); 00726 ASSERT_VECTORS_EQUAL( result, scaled_corner( rotbox, 7, f ) ); 00727 00728 // test outside each corner 00729 f = 1.5; 00730 rotbox.closest_location_in_box( scaled_corner( rotbox, 0, f ), result ); 00731 ASSERT_VECTORS_EQUAL( result, scaled_corner( rotbox, 0, 1 ) ); 00732 rotbox.closest_location_in_box( scaled_corner( rotbox, 1, f ), result ); 00733 ASSERT_VECTORS_EQUAL( result, scaled_corner( rotbox, 1, 1 ) ); 00734 rotbox.closest_location_in_box( scaled_corner( rotbox, 2, f ), result ); 00735 ASSERT_VECTORS_EQUAL( result, scaled_corner( rotbox, 2, 1 ) ); 00736 rotbox.closest_location_in_box( scaled_corner( rotbox, 3, f ), result ); 00737 ASSERT_VECTORS_EQUAL( result, scaled_corner( rotbox, 3, 1 ) ); 00738 rotbox.closest_location_in_box( scaled_corner( rotbox, 4, f ), result ); 00739 ASSERT_VECTORS_EQUAL( result, scaled_corner( rotbox, 4, 1 ) ); 00740 rotbox.closest_location_in_box( scaled_corner( rotbox, 5, f ), result ); 00741 ASSERT_VECTORS_EQUAL( result, scaled_corner( rotbox, 5, 1 ) ); 00742 rotbox.closest_location_in_box( scaled_corner( rotbox, 6, f ), result ); 00743 ASSERT_VECTORS_EQUAL( result, scaled_corner( rotbox, 6, 1 ) ); 00744 rotbox.closest_location_in_box( scaled_corner( rotbox, 7, f ), result ); 00745 ASSERT_VECTORS_EQUAL( result, scaled_corner( rotbox, 7, 1 ) ); 00746 00747 // test on each face 00748 f = 1.0; 00749 rotbox.closest_location_in_box( scaled_face( rotbox, 0, f ), result ); 00750 ASSERT_VECTORS_EQUAL( result, scaled_face( rotbox, 0, f ) ); 00751 rotbox.closest_location_in_box( scaled_face( rotbox, 1, f ), result ); 00752 ASSERT_VECTORS_EQUAL( result, scaled_face( rotbox, 1, f ) ); 00753 rotbox.closest_location_in_box( scaled_face( rotbox, 2, f ), result ); 00754 ASSERT_VECTORS_EQUAL( result, scaled_face( rotbox, 2, f ) ); 00755 rotbox.closest_location_in_box( scaled_face( rotbox, 3, f ), result ); 00756 ASSERT_VECTORS_EQUAL( result, scaled_face( rotbox, 3, f ) ); 00757 rotbox.closest_location_in_box( scaled_face( rotbox, 4, f ), result ); 00758 ASSERT_VECTORS_EQUAL( result, scaled_face( rotbox, 4, f ) ); 00759 rotbox.closest_location_in_box( scaled_face( rotbox, 5, f ), result ); 00760 ASSERT_VECTORS_EQUAL( result, scaled_face( rotbox, 5, f ) ); 00761 00762 // test outside each face 00763 f = 1.5; 00764 rotbox.closest_location_in_box( scaled_face( rotbox, 0, f ), result ); 00765 ASSERT_VECTORS_EQUAL( result, scaled_face( rotbox, 0, 1 ) ); 00766 rotbox.closest_location_in_box( scaled_face( rotbox, 1, f ), result ); 00767 ASSERT_VECTORS_EQUAL( result, scaled_face( rotbox, 1, 1 ) ); 00768 rotbox.closest_location_in_box( scaled_face( rotbox, 2, f ), result ); 00769 ASSERT_VECTORS_EQUAL( result, scaled_face( rotbox, 2, 1 ) ); 00770 rotbox.closest_location_in_box( scaled_face( rotbox, 3, f ), result ); 00771 ASSERT_VECTORS_EQUAL( result, scaled_face( rotbox, 3, 1 ) ); 00772 rotbox.closest_location_in_box( scaled_face( rotbox, 4, f ), result ); 00773 ASSERT_VECTORS_EQUAL( result, scaled_face( rotbox, 4, 1 ) ); 00774 rotbox.closest_location_in_box( scaled_face( rotbox, 5, f ), result ); 00775 ASSERT_VECTORS_EQUAL( result, scaled_face( rotbox, 5, 1 ) ); 00776 } 00777 00778 // \test Check all ray_intersect tests on Oriented Box 00779 void test_ray_intersect() 00780 { 00781 CartVect dir, pt; 00782 00783 // start with unit box 00784 00785 // test ray from box center towards each face 00786 dir = scaled_face( unitbox, 0, 1.0 ) - unitbox.center; 00787 dir.normalize(); 00788 ASSERT( unitbox.intersect_ray( unitbox.center, dir, TOL ) ); 00789 dir = scaled_face( unitbox, 1, 1.0 ) - unitbox.center; 00790 dir.normalize(); 00791 ASSERT( unitbox.intersect_ray( unitbox.center, dir, TOL ) ); 00792 dir = scaled_face( unitbox, 2, 1.0 ) - unitbox.center; 00793 dir.normalize(); 00794 ASSERT( unitbox.intersect_ray( unitbox.center, dir, TOL ) ); 00795 dir = scaled_face( unitbox, 3, 1.0 ) - unitbox.center; 00796 dir.normalize(); 00797 ASSERT( unitbox.intersect_ray( unitbox.center, dir, TOL ) ); 00798 dir = scaled_face( unitbox, 4, 1.0 ) - unitbox.center; 00799 dir.normalize(); 00800 ASSERT( unitbox.intersect_ray( unitbox.center, dir, TOL ) ); 00801 dir = scaled_face( unitbox, 5, 1.0 ) - unitbox.center; 00802 dir.normalize(); 00803 ASSERT( unitbox.intersect_ray( unitbox.center, dir, TOL ) ); 00804 00805 // test ray starting outside each face and pointing towards box center 00806 pt = scaled_face( unitbox, 0, 3.0 ); 00807 dir = unitbox.center - pt; 00808 dir.normalize(); 00809 ASSERT( unitbox.intersect_ray( pt, dir, TOL ) ); 00810 pt = scaled_face( unitbox, 1, 3.0 ); 00811 dir = unitbox.center - pt; 00812 dir.normalize(); 00813 ASSERT( unitbox.intersect_ray( pt, dir, TOL ) ); 00814 pt = scaled_face( unitbox, 2, 3.0 ); 00815 dir = unitbox.center - pt; 00816 dir.normalize(); 00817 ASSERT( unitbox.intersect_ray( pt, dir, TOL ) ); 00818 pt = scaled_face( unitbox, 3, 3.0 ); 00819 dir = unitbox.center - pt; 00820 dir.normalize(); 00821 ASSERT( unitbox.intersect_ray( pt, dir, TOL ) ); 00822 pt = scaled_face( unitbox, 4, 3.0 ); 00823 dir = unitbox.center - pt; 00824 dir.normalize(); 00825 ASSERT( unitbox.intersect_ray( pt, dir, TOL ) ); 00826 pt = scaled_face( unitbox, 5, 3.0 ); 00827 dir = unitbox.center - pt; 00828 dir.normalize(); 00829 ASSERT( unitbox.intersect_ray( pt, dir, TOL ) ); 00830 00831 // test ray from outside first face toward box center, with nonnegative ray length 00832 pt = scaled_face( unitbox, 0, 3.0 ); 00833 dir = unitbox.center - pt; 00834 dir.normalize(); 00835 const double short_pos = 0.99; 00836 const double short_neg = -0.99; 00837 const double long_pos = 1.01; 00838 const double long_neg = -1.01; 00839 ASSERT( unitbox.intersect_ray( pt, dir, TOL, &long_pos ) ); 00840 ASSERT( !unitbox.intersect_ray( pt, dir, TOL, &short_pos ) ); 00841 00842 // test ray from outside first face away from box center, with negative ray length 00843 ASSERT( unitbox.intersect_ray( pt, -dir, TOL, NULL, &long_neg ) ); 00844 ASSERT( !unitbox.intersect_ray( pt, -dir, TOL, NULL, &short_neg ) ); 00845 00846 // test ray from outside first face toward box center, with both ray lengths 00847 // Note that box.intersect_ray requires neg_ray_len<0 and -neg_ray_len<=nonneg_ray_len 00848 ASSERT( unitbox.intersect_ray( pt, dir, TOL, &long_pos, &long_neg ) ); 00849 ASSERT( !unitbox.intersect_ray( pt, dir, TOL, &short_pos, &long_neg ) ); 00850 ASSERT( unitbox.intersect_ray( pt, dir, TOL, &long_pos, &short_neg ) ); 00851 ASSERT( !unitbox.intersect_ray( pt, dir, TOL, &short_pos, &short_neg ) ); 00852 00853 // test ray starting inside box and passing through a corner 00854 pt = scaled_corner( unitbox, 0, 0.3 ); 00855 dir = pt - unitbox.center; 00856 dir.normalize(); 00857 ASSERT( unitbox.intersect_ray( pt, dir, TOL ) ); 00858 pt = scaled_corner( unitbox, 1, 0.3 ); 00859 dir = pt - unitbox.center; 00860 dir.normalize(); 00861 ASSERT( unitbox.intersect_ray( pt, dir, TOL ) ); 00862 pt = scaled_corner( unitbox, 2, 0.3 ); 00863 dir = pt - unitbox.center; 00864 dir.normalize(); 00865 ASSERT( unitbox.intersect_ray( pt, dir, TOL ) ); 00866 pt = scaled_corner( unitbox, 3, 0.3 ); 00867 dir = pt - unitbox.center; 00868 dir.normalize(); 00869 ASSERT( unitbox.intersect_ray( pt, dir, TOL ) ); 00870 pt = scaled_corner( unitbox, 4, 0.3 ); 00871 dir = pt - unitbox.center; 00872 dir.normalize(); 00873 ASSERT( unitbox.intersect_ray( pt, dir, TOL ) ); 00874 pt = scaled_corner( unitbox, 5, 0.3 ); 00875 dir = pt - unitbox.center; 00876 dir.normalize(); 00877 ASSERT( unitbox.intersect_ray( pt, dir, TOL ) ); 00878 pt = scaled_corner( unitbox, 6, 0.3 ); 00879 dir = pt - unitbox.center; 00880 dir.normalize(); 00881 ASSERT( unitbox.intersect_ray( pt, dir, TOL ) ); 00882 pt = scaled_corner( unitbox, 7, 0.3 ); 00883 dir = pt - unitbox.center; 00884 dir.normalize(); 00885 ASSERT( unitbox.intersect_ray( pt, dir, TOL ) ); 00886 00887 // test ray starting outside box and passing through opposite corners 00888 pt = scaled_corner( unitbox, 0, 3.0 ); 00889 dir = unitbox.center - pt; 00890 dir.normalize(); 00891 ASSERT( unitbox.intersect_ray( pt, dir, TOL ) ); 00892 pt = scaled_corner( unitbox, 1, 3.0 ); 00893 dir = unitbox.center - pt; 00894 dir.normalize(); 00895 ASSERT( unitbox.intersect_ray( pt, dir, TOL ) ); 00896 pt = scaled_corner( unitbox, 2, 3.0 ); 00897 dir = unitbox.center - pt; 00898 dir.normalize(); 00899 ASSERT( unitbox.intersect_ray( pt, dir, TOL ) ); 00900 pt = scaled_corner( unitbox, 3, 3.0 ); 00901 dir = unitbox.center - pt; 00902 dir.normalize(); 00903 ASSERT( unitbox.intersect_ray( pt, dir, TOL ) ); 00904 pt = scaled_corner( unitbox, 4, 3.0 ); 00905 dir = unitbox.center - pt; 00906 dir.normalize(); 00907 ASSERT( unitbox.intersect_ray( pt, dir, TOL ) ); 00908 pt = scaled_corner( unitbox, 5, 3.0 ); 00909 dir = unitbox.center - pt; 00910 dir.normalize(); 00911 ASSERT( unitbox.intersect_ray( pt, dir, TOL ) ); 00912 pt = scaled_corner( unitbox, 6, 3.0 ); 00913 dir = unitbox.center - pt; 00914 dir.normalize(); 00915 ASSERT( unitbox.intersect_ray( pt, dir, TOL ) ); 00916 pt = scaled_corner( unitbox, 7, 3.0 ); 00917 dir = unitbox.center - pt; 00918 dir.normalize(); 00919 ASSERT( unitbox.intersect_ray( pt, dir, TOL ) ); 00920 00921 // test ray starting outside face and pointing away from box 00922 pt = scaled_face( unitbox, 0, 3.0 ); 00923 dir = pt - unitbox.center; 00924 dir.normalize(); 00925 ASSERT( !unitbox.intersect_ray( pt, dir, TOL ) ); 00926 pt = scaled_face( unitbox, 1, 3.0 ); 00927 dir = pt - unitbox.center; 00928 dir.normalize(); 00929 ASSERT( !unitbox.intersect_ray( pt, dir, TOL ) ); 00930 pt = scaled_face( unitbox, 2, 3.0 ); 00931 dir = pt - unitbox.center; 00932 dir.normalize(); 00933 ASSERT( !unitbox.intersect_ray( pt, dir, TOL ) ); 00934 pt = scaled_face( unitbox, 3, 3.0 ); 00935 dir = pt - unitbox.center; 00936 dir.normalize(); 00937 ASSERT( !unitbox.intersect_ray( pt, dir, TOL ) ); 00938 pt = scaled_face( unitbox, 4, 3.0 ); 00939 dir = pt - unitbox.center; 00940 dir.normalize(); 00941 ASSERT( !unitbox.intersect_ray( pt, dir, TOL ) ); 00942 pt = scaled_face( unitbox, 5, 3.0 ); 00943 dir = pt - unitbox.center; 00944 dir.normalize(); 00945 ASSERT( !unitbox.intersect_ray( pt, dir, TOL ) ); 00946 00947 // test ray starting outside face and parallel to face 00948 pt = scaled_face( unitbox, 0, 3.0 ); 00949 dir = unitbox.scaled_axis( 1 ); 00950 dir.normalize(); 00951 ASSERT( !unitbox.intersect_ray( pt, dir, TOL ) ); 00952 pt = scaled_face( unitbox, 1, 3.0 ); 00953 dir = unitbox.scaled_axis( 2 ); 00954 dir.normalize(); 00955 ASSERT( !unitbox.intersect_ray( pt, dir, TOL ) ); 00956 pt = scaled_face( unitbox, 2, 3.0 ); 00957 dir = unitbox.scaled_axis( 0 ); 00958 dir.normalize(); 00959 ASSERT( !unitbox.intersect_ray( pt, dir, TOL ) ); 00960 pt = scaled_face( unitbox, 3, 3.0 ); 00961 dir = unitbox.scaled_axis( 2 ); 00962 dir.normalize(); 00963 ASSERT( !unitbox.intersect_ray( pt, dir, TOL ) ); 00964 pt = scaled_face( unitbox, 4, 3.0 ); 00965 dir = unitbox.scaled_axis( 0 ); 00966 dir.normalize(); 00967 ASSERT( !unitbox.intersect_ray( pt, dir, TOL ) ); 00968 pt = scaled_face( unitbox, 5, 3.0 ); 00969 dir = unitbox.scaled_axis( 1 ); 00970 dir.normalize(); 00971 ASSERT( !unitbox.intersect_ray( pt, dir, TOL ) ); 00972 00973 // next do offset box 00974 00975 // test ray from box center towards each face 00976 dir = scaled_face( offsetbox, 0, 1.0 ) - offsetbox.center; 00977 dir.normalize(); 00978 ASSERT( offsetbox.intersect_ray( offsetbox.center, dir, TOL ) ); 00979 dir = scaled_face( offsetbox, 1, 1.0 ) - offsetbox.center; 00980 dir.normalize(); 00981 ASSERT( offsetbox.intersect_ray( offsetbox.center, dir, TOL ) ); 00982 dir = scaled_face( offsetbox, 2, 1.0 ) - offsetbox.center; 00983 dir.normalize(); 00984 ASSERT( offsetbox.intersect_ray( offsetbox.center, dir, TOL ) ); 00985 dir = scaled_face( offsetbox, 3, 1.0 ) - offsetbox.center; 00986 dir.normalize(); 00987 ASSERT( offsetbox.intersect_ray( offsetbox.center, dir, TOL ) ); 00988 dir = scaled_face( offsetbox, 4, 1.0 ) - offsetbox.center; 00989 dir.normalize(); 00990 ASSERT( offsetbox.intersect_ray( offsetbox.center, dir, TOL ) ); 00991 dir = scaled_face( offsetbox, 5, 1.0 ) - offsetbox.center; 00992 dir.normalize(); 00993 ASSERT( offsetbox.intersect_ray( offsetbox.center, dir, TOL ) ); 00994 00995 // test ray starting outside each face and pointing towards box center 00996 pt = scaled_face( offsetbox, 0, 3.0 ); 00997 dir = offsetbox.center - pt; 00998 dir.normalize(); 00999 ASSERT( offsetbox.intersect_ray( pt, dir, TOL ) ); 01000 pt = scaled_face( offsetbox, 1, 3.0 ); 01001 dir = offsetbox.center - pt; 01002 dir.normalize(); 01003 ASSERT( offsetbox.intersect_ray( pt, dir, TOL ) ); 01004 pt = scaled_face( offsetbox, 2, 3.0 ); 01005 dir = offsetbox.center - pt; 01006 dir.normalize(); 01007 ASSERT( offsetbox.intersect_ray( pt, dir, TOL ) ); 01008 pt = scaled_face( offsetbox, 3, 3.0 ); 01009 dir = offsetbox.center - pt; 01010 dir.normalize(); 01011 ASSERT( offsetbox.intersect_ray( pt, dir, TOL ) ); 01012 pt = scaled_face( offsetbox, 4, 3.0 ); 01013 dir = offsetbox.center - pt; 01014 dir.normalize(); 01015 ASSERT( offsetbox.intersect_ray( pt, dir, TOL ) ); 01016 pt = scaled_face( offsetbox, 5, 3.0 ); 01017 dir = offsetbox.center - pt; 01018 dir.normalize(); 01019 ASSERT( offsetbox.intersect_ray( pt, dir, TOL ) ); 01020 01021 // test ray starting inside box and passing through a corner 01022 pt = scaled_corner( offsetbox, 0, 0.3 ); 01023 dir = pt - offsetbox.center; 01024 dir.normalize(); 01025 ASSERT( offsetbox.intersect_ray( pt, dir, TOL ) ); 01026 pt = scaled_corner( offsetbox, 1, 0.3 ); 01027 dir = pt - offsetbox.center; 01028 dir.normalize(); 01029 ASSERT( offsetbox.intersect_ray( pt, dir, TOL ) ); 01030 pt = scaled_corner( offsetbox, 2, 0.3 ); 01031 dir = pt - offsetbox.center; 01032 dir.normalize(); 01033 ASSERT( offsetbox.intersect_ray( pt, dir, TOL ) ); 01034 pt = scaled_corner( offsetbox, 3, 0.3 ); 01035 dir = pt - offsetbox.center; 01036 dir.normalize(); 01037 ASSERT( offsetbox.intersect_ray( pt, dir, TOL ) ); 01038 pt = scaled_corner( offsetbox, 4, 0.3 ); 01039 dir = pt - offsetbox.center; 01040 dir.normalize(); 01041 ASSERT( offsetbox.intersect_ray( pt, dir, TOL ) ); 01042 pt = scaled_corner( offsetbox, 5, 0.3 ); 01043 dir = pt - offsetbox.center; 01044 dir.normalize(); 01045 ASSERT( offsetbox.intersect_ray( pt, dir, TOL ) ); 01046 pt = scaled_corner( offsetbox, 6, 0.3 ); 01047 dir = pt - offsetbox.center; 01048 dir.normalize(); 01049 ASSERT( offsetbox.intersect_ray( pt, dir, TOL ) ); 01050 pt = scaled_corner( offsetbox, 7, 0.3 ); 01051 dir = pt - offsetbox.center; 01052 dir.normalize(); 01053 ASSERT( offsetbox.intersect_ray( pt, dir, TOL ) ); 01054 01055 // test ray starting outside box and passing through opposite corners 01056 pt = scaled_corner( offsetbox, 0, 3.0 ); 01057 dir = offsetbox.center - pt; 01058 dir.normalize(); 01059 ASSERT( offsetbox.intersect_ray( pt, dir, TOL ) ); 01060 pt = scaled_corner( offsetbox, 1, 3.0 ); 01061 dir = offsetbox.center - pt; 01062 dir.normalize(); 01063 ASSERT( offsetbox.intersect_ray( pt, dir, TOL ) ); 01064 pt = scaled_corner( offsetbox, 2, 3.0 ); 01065 dir = offsetbox.center - pt; 01066 dir.normalize(); 01067 ASSERT( offsetbox.intersect_ray( pt, dir, TOL ) ); 01068 pt = scaled_corner( offsetbox, 3, 3.0 ); 01069 dir = offsetbox.center - pt; 01070 dir.normalize(); 01071 ASSERT( offsetbox.intersect_ray( pt, dir, TOL ) ); 01072 pt = scaled_corner( offsetbox, 4, 3.0 ); 01073 dir = offsetbox.center - pt; 01074 dir.normalize(); 01075 ASSERT( offsetbox.intersect_ray( pt, dir, TOL ) ); 01076 pt = scaled_corner( offsetbox, 5, 3.0 ); 01077 dir = offsetbox.center - pt; 01078 dir.normalize(); 01079 ASSERT( offsetbox.intersect_ray( pt, dir, TOL ) ); 01080 pt = scaled_corner( offsetbox, 6, 3.0 ); 01081 dir = offsetbox.center - pt; 01082 dir.normalize(); 01083 ASSERT( offsetbox.intersect_ray( pt, dir, TOL ) ); 01084 pt = scaled_corner( offsetbox, 7, 3.0 ); 01085 dir = offsetbox.center - pt; 01086 dir.normalize(); 01087 ASSERT( offsetbox.intersect_ray( pt, dir, TOL ) ); 01088 01089 // test ray starting outside face and pointing away from box 01090 pt = scaled_face( offsetbox, 0, 3.0 ); 01091 dir = pt - offsetbox.center; 01092 dir.normalize(); 01093 ASSERT( !offsetbox.intersect_ray( pt, dir, TOL ) ); 01094 pt = scaled_face( offsetbox, 1, 3.0 ); 01095 dir = pt - offsetbox.center; 01096 dir.normalize(); 01097 ASSERT( !offsetbox.intersect_ray( pt, dir, TOL ) ); 01098 pt = scaled_face( offsetbox, 2, 3.0 ); 01099 dir = pt - offsetbox.center; 01100 dir.normalize(); 01101 ASSERT( !offsetbox.intersect_ray( pt, dir, TOL ) ); 01102 pt = scaled_face( offsetbox, 3, 3.0 ); 01103 dir = pt - offsetbox.center; 01104 dir.normalize(); 01105 ASSERT( !offsetbox.intersect_ray( pt, dir, TOL ) ); 01106 pt = scaled_face( offsetbox, 4, 3.0 ); 01107 dir = pt - offsetbox.center; 01108 dir.normalize(); 01109 ASSERT( !offsetbox.intersect_ray( pt, dir, TOL ) ); 01110 pt = scaled_face( offsetbox, 5, 3.0 ); 01111 dir = pt - offsetbox.center; 01112 dir.normalize(); 01113 ASSERT( !offsetbox.intersect_ray( pt, dir, TOL ) ); 01114 01115 // test ray starting outside face and parallel to face 01116 pt = scaled_face( offsetbox, 0, 3.0 ); 01117 dir = offsetbox.scaled_axis( 1 ); 01118 dir.normalize(); 01119 ASSERT( !offsetbox.intersect_ray( pt, dir, TOL ) ); 01120 pt = scaled_face( offsetbox, 1, 3.0 ); 01121 dir = offsetbox.scaled_axis( 2 ); 01122 dir.normalize(); 01123 ASSERT( !offsetbox.intersect_ray( pt, dir, TOL ) ); 01124 pt = scaled_face( offsetbox, 2, 3.0 ); 01125 dir = offsetbox.scaled_axis( 0 ); 01126 dir.normalize(); 01127 ASSERT( !offsetbox.intersect_ray( pt, dir, TOL ) ); 01128 pt = scaled_face( offsetbox, 3, 3.0 ); 01129 dir = offsetbox.scaled_axis( 2 ); 01130 dir.normalize(); 01131 ASSERT( !offsetbox.intersect_ray( pt, dir, TOL ) ); 01132 pt = scaled_face( offsetbox, 4, 3.0 ); 01133 dir = offsetbox.scaled_axis( 0 ); 01134 dir.normalize(); 01135 ASSERT( !offsetbox.intersect_ray( pt, dir, TOL ) ); 01136 pt = scaled_face( offsetbox, 5, 3.0 ); 01137 dir = offsetbox.scaled_axis( 1 ); 01138 dir.normalize(); 01139 ASSERT( !offsetbox.intersect_ray( pt, dir, TOL ) ); 01140 01141 // next do oblong box 01142 01143 // test ray from box center towards each face 01144 dir = scaled_face( oblongbox, 0, 1.0 ) - oblongbox.center; 01145 dir.normalize(); 01146 ASSERT( oblongbox.intersect_ray( oblongbox.center, dir, TOL ) ); 01147 dir = scaled_face( oblongbox, 1, 1.0 ) - oblongbox.center; 01148 dir.normalize(); 01149 ASSERT( oblongbox.intersect_ray( oblongbox.center, dir, TOL ) ); 01150 dir = scaled_face( oblongbox, 2, 1.0 ) - oblongbox.center; 01151 dir.normalize(); 01152 ASSERT( oblongbox.intersect_ray( oblongbox.center, dir, TOL ) ); 01153 dir = scaled_face( oblongbox, 3, 1.0 ) - oblongbox.center; 01154 dir.normalize(); 01155 ASSERT( oblongbox.intersect_ray( oblongbox.center, dir, TOL ) ); 01156 dir = scaled_face( oblongbox, 4, 1.0 ) - oblongbox.center; 01157 dir.normalize(); 01158 ASSERT( oblongbox.intersect_ray( oblongbox.center, dir, TOL ) ); 01159 dir = scaled_face( oblongbox, 5, 1.0 ) - oblongbox.center; 01160 dir.normalize(); 01161 ASSERT( oblongbox.intersect_ray( oblongbox.center, dir, TOL ) ); 01162 01163 // test ray starting outside each face and pointing towards box center 01164 pt = scaled_face( oblongbox, 0, 3.0 ); 01165 dir = oblongbox.center - pt; 01166 dir.normalize(); 01167 ASSERT( oblongbox.intersect_ray( pt, dir, TOL ) ); 01168 pt = scaled_face( oblongbox, 1, 3.0 ); 01169 dir = oblongbox.center - pt; 01170 dir.normalize(); 01171 ASSERT( oblongbox.intersect_ray( pt, dir, TOL ) ); 01172 pt = scaled_face( oblongbox, 2, 3.0 ); 01173 dir = oblongbox.center - pt; 01174 dir.normalize(); 01175 ASSERT( oblongbox.intersect_ray( pt, dir, TOL ) ); 01176 pt = scaled_face( oblongbox, 3, 3.0 ); 01177 dir = oblongbox.center - pt; 01178 dir.normalize(); 01179 ASSERT( oblongbox.intersect_ray( pt, dir, TOL ) ); 01180 pt = scaled_face( oblongbox, 4, 3.0 ); 01181 dir = oblongbox.center - pt; 01182 dir.normalize(); 01183 ASSERT( oblongbox.intersect_ray( pt, dir, TOL ) ); 01184 pt = scaled_face( oblongbox, 5, 3.0 ); 01185 dir = oblongbox.center - pt; 01186 dir.normalize(); 01187 ASSERT( oblongbox.intersect_ray( pt, dir, TOL ) ); 01188 01189 // test ray starting inside box and passing through a corner 01190 pt = scaled_corner( oblongbox, 0, 0.3 ); 01191 dir = pt - oblongbox.center; 01192 dir.normalize(); 01193 ASSERT( oblongbox.intersect_ray( pt, dir, TOL ) ); 01194 pt = scaled_corner( oblongbox, 1, 0.3 ); 01195 dir = pt - oblongbox.center; 01196 dir.normalize(); 01197 ASSERT( oblongbox.intersect_ray( pt, dir, TOL ) ); 01198 pt = scaled_corner( oblongbox, 2, 0.3 ); 01199 dir = pt - oblongbox.center; 01200 dir.normalize(); 01201 ASSERT( oblongbox.intersect_ray( pt, dir, TOL ) ); 01202 pt = scaled_corner( oblongbox, 3, 0.3 ); 01203 dir = pt - oblongbox.center; 01204 dir.normalize(); 01205 ASSERT( oblongbox.intersect_ray( pt, dir, TOL ) ); 01206 pt = scaled_corner( oblongbox, 4, 0.3 ); 01207 dir = pt - oblongbox.center; 01208 dir.normalize(); 01209 ASSERT( oblongbox.intersect_ray( pt, dir, TOL ) ); 01210 pt = scaled_corner( oblongbox, 5, 0.3 ); 01211 dir = pt - oblongbox.center; 01212 dir.normalize(); 01213 ASSERT( oblongbox.intersect_ray( pt, dir, TOL ) ); 01214 pt = scaled_corner( oblongbox, 6, 0.3 ); 01215 dir = pt - oblongbox.center; 01216 dir.normalize(); 01217 ASSERT( oblongbox.intersect_ray( pt, dir, TOL ) ); 01218 pt = scaled_corner( oblongbox, 7, 0.3 ); 01219 dir = pt - oblongbox.center; 01220 dir.normalize(); 01221 ASSERT( oblongbox.intersect_ray( pt, dir, TOL ) ); 01222 01223 // test ray starting outside box and passing through opposite corners 01224 pt = scaled_corner( oblongbox, 0, 3.0 ); 01225 dir = oblongbox.center - pt; 01226 dir.normalize(); 01227 ASSERT( oblongbox.intersect_ray( pt, dir, TOL ) ); 01228 pt = scaled_corner( oblongbox, 1, 3.0 ); 01229 dir = oblongbox.center - pt; 01230 dir.normalize(); 01231 ASSERT( oblongbox.intersect_ray( pt, dir, TOL ) ); 01232 pt = scaled_corner( oblongbox, 2, 3.0 ); 01233 dir = oblongbox.center - pt; 01234 dir.normalize(); 01235 ASSERT( oblongbox.intersect_ray( pt, dir, TOL ) ); 01236 pt = scaled_corner( oblongbox, 3, 3.0 ); 01237 dir = oblongbox.center - pt; 01238 dir.normalize(); 01239 ASSERT( oblongbox.intersect_ray( pt, dir, TOL ) ); 01240 pt = scaled_corner( oblongbox, 4, 3.0 ); 01241 dir = oblongbox.center - pt; 01242 dir.normalize(); 01243 ASSERT( oblongbox.intersect_ray( pt, dir, TOL ) ); 01244 pt = scaled_corner( oblongbox, 5, 3.0 ); 01245 dir = oblongbox.center - pt; 01246 dir.normalize(); 01247 ASSERT( oblongbox.intersect_ray( pt, dir, TOL ) ); 01248 pt = scaled_corner( oblongbox, 6, 3.0 ); 01249 dir = oblongbox.center - pt; 01250 dir.normalize(); 01251 ASSERT( oblongbox.intersect_ray( pt, dir, TOL ) ); 01252 pt = scaled_corner( oblongbox, 7, 3.0 ); 01253 dir = oblongbox.center - pt; 01254 dir.normalize(); 01255 ASSERT( oblongbox.intersect_ray( pt, dir, TOL ) ); 01256 01257 // test ray starting outside face and pointing away from box 01258 pt = scaled_face( oblongbox, 0, 3.0 ); 01259 dir = pt - oblongbox.center; 01260 dir.normalize(); 01261 ASSERT( !oblongbox.intersect_ray( pt, dir, TOL ) ); 01262 pt = scaled_face( oblongbox, 1, 3.0 ); 01263 dir = pt - oblongbox.center; 01264 dir.normalize(); 01265 ASSERT( !oblongbox.intersect_ray( pt, dir, TOL ) ); 01266 pt = scaled_face( oblongbox, 2, 3.0 ); 01267 dir = pt - oblongbox.center; 01268 dir.normalize(); 01269 ASSERT( !oblongbox.intersect_ray( pt, dir, TOL ) ); 01270 pt = scaled_face( oblongbox, 3, 3.0 ); 01271 dir = pt - oblongbox.center; 01272 dir.normalize(); 01273 ASSERT( !oblongbox.intersect_ray( pt, dir, TOL ) ); 01274 pt = scaled_face( oblongbox, 4, 3.0 ); 01275 dir = pt - oblongbox.center; 01276 dir.normalize(); 01277 ASSERT( !oblongbox.intersect_ray( pt, dir, TOL ) ); 01278 pt = scaled_face( oblongbox, 5, 3.0 ); 01279 dir = pt - oblongbox.center; 01280 dir.normalize(); 01281 ASSERT( !oblongbox.intersect_ray( pt, dir, TOL ) ); 01282 01283 // test ray starting outside face and parallel to face 01284 pt = scaled_face( oblongbox, 0, 3.0 ); 01285 dir = oblongbox.scaled_axis( 1 ); 01286 dir.normalize(); 01287 ASSERT( !oblongbox.intersect_ray( pt, dir, TOL ) ); 01288 pt = scaled_face( oblongbox, 1, 3.0 ); 01289 dir = oblongbox.scaled_axis( 2 ); 01290 dir.normalize(); 01291 ASSERT( !oblongbox.intersect_ray( pt, dir, TOL ) ); 01292 pt = scaled_face( oblongbox, 2, 3.0 ); 01293 dir = oblongbox.scaled_axis( 0 ); 01294 dir.normalize(); 01295 ASSERT( !oblongbox.intersect_ray( pt, dir, TOL ) ); 01296 pt = scaled_face( oblongbox, 3, 3.0 ); 01297 dir = oblongbox.scaled_axis( 2 ); 01298 dir.normalize(); 01299 ASSERT( !oblongbox.intersect_ray( pt, dir, TOL ) ); 01300 pt = scaled_face( oblongbox, 4, 3.0 ); 01301 dir = oblongbox.scaled_axis( 0 ); 01302 dir.normalize(); 01303 ASSERT( !oblongbox.intersect_ray( pt, dir, TOL ) ); 01304 pt = scaled_face( oblongbox, 5, 3.0 ); 01305 dir = oblongbox.scaled_axis( 1 ); 01306 dir.normalize(); 01307 ASSERT( !oblongbox.intersect_ray( pt, dir, TOL ) ); 01308 01309 // next do rotated box 01310 01311 // test ray from box center towards each face 01312 dir = scaled_face( rotbox, 0, 1.0 ) - rotbox.center; 01313 dir.normalize(); 01314 ASSERT( rotbox.intersect_ray( rotbox.center, dir, TOL ) ); 01315 dir = scaled_face( rotbox, 1, 1.0 ) - rotbox.center; 01316 dir.normalize(); 01317 ASSERT( rotbox.intersect_ray( rotbox.center, dir, TOL ) ); 01318 dir = scaled_face( rotbox, 2, 1.0 ) - rotbox.center; 01319 dir.normalize(); 01320 ASSERT( rotbox.intersect_ray( rotbox.center, dir, TOL ) ); 01321 dir = scaled_face( rotbox, 3, 1.0 ) - rotbox.center; 01322 dir.normalize(); 01323 ASSERT( rotbox.intersect_ray( rotbox.center, dir, TOL ) ); 01324 dir = scaled_face( rotbox, 4, 1.0 ) - rotbox.center; 01325 dir.normalize(); 01326 ASSERT( rotbox.intersect_ray( rotbox.center, dir, TOL ) ); 01327 dir = scaled_face( rotbox, 5, 1.0 ) - rotbox.center; 01328 dir.normalize(); 01329 ASSERT( rotbox.intersect_ray( rotbox.center, dir, TOL ) ); 01330 01331 // test ray starting outside each face and pointing towards box center 01332 pt = scaled_face( rotbox, 0, 3.0 ); 01333 dir = rotbox.center - pt; 01334 dir.normalize(); 01335 ASSERT( rotbox.intersect_ray( pt, dir, TOL ) ); 01336 pt = scaled_face( rotbox, 1, 3.0 ); 01337 dir = rotbox.center - pt; 01338 dir.normalize(); 01339 ASSERT( rotbox.intersect_ray( pt, dir, TOL ) ); 01340 pt = scaled_face( rotbox, 2, 3.0 ); 01341 dir = rotbox.center - pt; 01342 dir.normalize(); 01343 ASSERT( rotbox.intersect_ray( pt, dir, TOL ) ); 01344 pt = scaled_face( rotbox, 3, 3.0 ); 01345 dir = rotbox.center - pt; 01346 dir.normalize(); 01347 ASSERT( rotbox.intersect_ray( pt, dir, TOL ) ); 01348 pt = scaled_face( rotbox, 4, 3.0 ); 01349 dir = rotbox.center - pt; 01350 dir.normalize(); 01351 ASSERT( rotbox.intersect_ray( pt, dir, TOL ) ); 01352 pt = scaled_face( rotbox, 5, 3.0 ); 01353 dir = rotbox.center - pt; 01354 dir.normalize(); 01355 ASSERT( rotbox.intersect_ray( pt, dir, TOL ) ); 01356 01357 // test ray starting inside box and passing through a corner 01358 pt = scaled_corner( rotbox, 0, 0.3 ); 01359 dir = pt - rotbox.center; 01360 dir.normalize(); 01361 ASSERT( rotbox.intersect_ray( pt, dir, TOL ) ); 01362 pt = scaled_corner( rotbox, 1, 0.3 ); 01363 dir = pt - rotbox.center; 01364 dir.normalize(); 01365 ASSERT( rotbox.intersect_ray( pt, dir, TOL ) ); 01366 pt = scaled_corner( rotbox, 2, 0.3 ); 01367 dir = pt - rotbox.center; 01368 dir.normalize(); 01369 ASSERT( rotbox.intersect_ray( pt, dir, TOL ) ); 01370 pt = scaled_corner( rotbox, 3, 0.3 ); 01371 dir = pt - rotbox.center; 01372 dir.normalize(); 01373 ASSERT( rotbox.intersect_ray( pt, dir, TOL ) ); 01374 pt = scaled_corner( rotbox, 4, 0.3 ); 01375 dir = pt - rotbox.center; 01376 dir.normalize(); 01377 ASSERT( rotbox.intersect_ray( pt, dir, TOL ) ); 01378 pt = scaled_corner( rotbox, 5, 0.3 ); 01379 dir = pt - rotbox.center; 01380 dir.normalize(); 01381 ASSERT( rotbox.intersect_ray( pt, dir, TOL ) ); 01382 pt = scaled_corner( rotbox, 6, 0.3 ); 01383 dir = pt - rotbox.center; 01384 dir.normalize(); 01385 ASSERT( rotbox.intersect_ray( pt, dir, TOL ) ); 01386 pt = scaled_corner( rotbox, 7, 0.3 ); 01387 dir = pt - rotbox.center; 01388 dir.normalize(); 01389 ASSERT( rotbox.intersect_ray( pt, dir, TOL ) ); 01390 01391 // test ray starting outside box and passing through opposite corners 01392 pt = scaled_corner( rotbox, 0, 3.0 ); 01393 dir = rotbox.center - pt; 01394 dir.normalize(); 01395 ASSERT( rotbox.intersect_ray( pt, dir, TOL ) ); 01396 pt = scaled_corner( rotbox, 1, 3.0 ); 01397 dir = rotbox.center - pt; 01398 dir.normalize(); 01399 ASSERT( rotbox.intersect_ray( pt, dir, TOL ) ); 01400 pt = scaled_corner( rotbox, 2, 3.0 ); 01401 dir = rotbox.center - pt; 01402 dir.normalize(); 01403 ASSERT( rotbox.intersect_ray( pt, dir, TOL ) ); 01404 pt = scaled_corner( rotbox, 3, 3.0 ); 01405 dir = rotbox.center - pt; 01406 dir.normalize(); 01407 ASSERT( rotbox.intersect_ray( pt, dir, TOL ) ); 01408 pt = scaled_corner( rotbox, 4, 3.0 ); 01409 dir = rotbox.center - pt; 01410 dir.normalize(); 01411 ASSERT( rotbox.intersect_ray( pt, dir, TOL ) ); 01412 pt = scaled_corner( rotbox, 5, 3.0 ); 01413 dir = rotbox.center - pt; 01414 dir.normalize(); 01415 ASSERT( rotbox.intersect_ray( pt, dir, TOL ) ); 01416 pt = scaled_corner( rotbox, 6, 3.0 ); 01417 dir = rotbox.center - pt; 01418 dir.normalize(); 01419 ASSERT( rotbox.intersect_ray( pt, dir, TOL ) ); 01420 pt = scaled_corner( rotbox, 7, 3.0 ); 01421 dir = rotbox.center - pt; 01422 dir.normalize(); 01423 ASSERT( rotbox.intersect_ray( pt, dir, TOL ) ); 01424 01425 // test ray starting outside face and pointing away from box 01426 pt = scaled_face( rotbox, 0, 3.0 ); 01427 dir = pt - rotbox.center; 01428 dir.normalize(); 01429 ASSERT( !rotbox.intersect_ray( pt, dir, TOL ) ); 01430 pt = scaled_face( rotbox, 1, 3.0 ); 01431 dir = pt - rotbox.center; 01432 dir.normalize(); 01433 ASSERT( !rotbox.intersect_ray( pt, dir, TOL ) ); 01434 pt = scaled_face( rotbox, 2, 3.0 ); 01435 dir = pt - rotbox.center; 01436 dir.normalize(); 01437 ASSERT( !rotbox.intersect_ray( pt, dir, TOL ) ); 01438 pt = scaled_face( rotbox, 3, 3.0 ); 01439 dir = pt - rotbox.center; 01440 dir.normalize(); 01441 ASSERT( !rotbox.intersect_ray( pt, dir, TOL ) ); 01442 pt = scaled_face( rotbox, 4, 3.0 ); 01443 dir = pt - rotbox.center; 01444 dir.normalize(); 01445 ASSERT( !rotbox.intersect_ray( pt, dir, TOL ) ); 01446 pt = scaled_face( rotbox, 5, 3.0 ); 01447 dir = pt - rotbox.center; 01448 dir.normalize(); 01449 ASSERT( !rotbox.intersect_ray( pt, dir, TOL ) ); 01450 01451 // test ray starting outside face and parallel to face 01452 pt = scaled_face( rotbox, 0, 3.0 ); 01453 dir = rotbox.scaled_axis( 1 ); 01454 dir.normalize(); 01455 ASSERT( !rotbox.intersect_ray( pt, dir, TOL ) ); 01456 pt = scaled_face( rotbox, 1, 3.0 ); 01457 dir = rotbox.scaled_axis( 2 ); 01458 dir.normalize(); 01459 ASSERT( !rotbox.intersect_ray( pt, dir, TOL ) ); 01460 pt = scaled_face( rotbox, 2, 3.0 ); 01461 dir = rotbox.scaled_axis( 0 ); 01462 dir.normalize(); 01463 ASSERT( !rotbox.intersect_ray( pt, dir, TOL ) ); 01464 pt = scaled_face( rotbox, 3, 3.0 ); 01465 dir = rotbox.scaled_axis( 2 ); 01466 dir.normalize(); 01467 ASSERT( !rotbox.intersect_ray( pt, dir, TOL ) ); 01468 pt = scaled_face( rotbox, 4, 3.0 ); 01469 dir = rotbox.scaled_axis( 0 ); 01470 dir.normalize(); 01471 ASSERT( !rotbox.intersect_ray( pt, dir, TOL ) ); 01472 pt = scaled_face( rotbox, 5, 3.0 ); 01473 dir = rotbox.scaled_axis( 1 ); 01474 dir.normalize(); 01475 ASSERT( !rotbox.intersect_ray( pt, dir, TOL ) ); 01476 } 01477 01478 /*! 01479 @test 01480 Construct OBB Box from triangles 01481 @li Check building OBB box from triangles 01482 */ 01483 void test_build_from_tri() 01484 { 01485 ErrorCode rval; 01486 Core moab; 01487 int i; 01488 01489 // define a planar patch of triangles 01490 const double coords[] = { 0, 0, 0, 5, 0, 0, 5, 5, 0, 0, 5, 0, -5, 5, 0, -5, 0, 0, -5, -5, 0, 01491 0, -5, 0, 5, -5, 0, 10, 0, 0, 8, 5, 0, 5, 8, 0, 0, 10, 0, -5, 8, 0, 01492 -8, 5, 0, -10, 0, 0, -8, -5, 0, -5, -8, 0, 0, -10, 0, 5, -8, 0, 8, -5, 0 }; 01493 const int conn[] = { 3, 12, 13, 3, 11, 12, 4, 13, 14, 4, 3, 13, 3, 2, 11, 2, 10, 11, 01494 01495 5, 14, 15, 5, 4, 14, 3, 4, 5, 0, 3, 5, 0, 1, 3, 1, 2, 3, 2, 1, 10, 1, 9, 10, 01496 01497 5, 15, 16, 6, 5, 16, 5, 6, 7, 0, 5, 7, 1, 0, 7, 1, 7, 8, 1, 8, 20, 9, 1, 20, 01498 01499 6, 16, 17, 7, 6, 17, 7, 17, 18, 7, 18, 19, 8, 7, 19, 8, 19, 20 }; 01500 01501 // build triangle mesh 01502 std::vector< EntityHandle > vertices( 21 ); 01503 for( i = 0; i < 21; ++i ) 01504 { 01505 rval = moab.create_vertex( coords + 3 * i, vertices[i] ); 01506 ASSERT( MB_SUCCESS == rval ); 01507 } 01508 Range tris; 01509 for( i = 0; i < 28; ++i ) 01510 { 01511 EntityHandle tri; 01512 EntityHandle c[3] = { vertices[conn[3 * i]], vertices[conn[3 * i + 1]], vertices[conn[3 * i + 2]] }; 01513 rval = moab.create_element( MBTRI, c, 3, tri ); 01514 ASSERT( MB_SUCCESS == rval ); 01515 tris.insert( tri ); 01516 } 01517 01518 // create box from triangles 01519 OrientedBox box; 01520 rval = OrientedBox::compute_from_2d_cells( box, &moab, tris ); 01521 ASSERT( MB_SUCCESS == rval ); 01522 01523 // compute range along each box axis for input vertices 01524 const Matrix3 axis( box.scaled_axis( 0 ), box.scaled_axis( 1 ), box.scaled_axis( 2 ), false ); 01525 double min[3], max[3]; 01526 CartVect v = CartVect( coords ) - box.center; 01527 min[0] = max[0] = box.scaled_axis( 0 ) % v; 01528 min[1] = max[1] = box.scaled_axis( 1 ) % v; 01529 min[2] = max[2] = box.scaled_axis( 2 ) % v; 01530 for( i = 1; i < 21; ++i ) 01531 { 01532 CartVect vi( coords + 3 * i ); 01533 CartVect vLocal = vi - box.center; 01534 for( int j = 0; j < 3; ++j ) 01535 { 01536 double d = ( axis.col( j ) % vLocal ) / ( axis.col( j ) % axis.col( j ) ); 01537 if( d < min[j] ) min[j] = d; 01538 if( d > max[j] ) max[j] = d; 01539 } 01540 } 01541 01542 // Vrify that all points are contained in box 01543 // and that box fits points tightly. 01544 // Triangles line in xy plane, so assuming axes are 01545 // sorted by length, first axis should be zero. 01546 ASSERT_DOUBLES_EQUAL( min[1], -1 ); 01547 ASSERT_DOUBLES_EQUAL( min[2], -1 ); 01548 ASSERT_DOUBLES_EQUAL( max[1], 1 ); 01549 ASSERT_DOUBLES_EQUAL( max[2], 1 ); 01550 01551 // verify that the box is flat along first axis 01552 ASSERT( box.dimensions()[0] <= TOL ); 01553 // verify that other two axes are in XY plane 01554 const CartVect z_axis( 0.0, 0.0, 1.0 ); 01555 ASSERT( fabs( box.axis( 1 ) % z_axis ) <= TOL ); 01556 ASSERT( fabs( box.axis( 2 ) % z_axis ) <= TOL ); 01557 } 01558 01559 void test_build_from_pts() 01560 { 01561 ErrorCode rval; 01562 Core moab; 01563 Interface* const gMB = &moab; 01564 01565 const double vertex_coords[] = { 0, 0, 0, 1, 0, 0, 1, 1, 0, 0, 1, 0, 0, 0, 1, 1, 0, 1, 1, 1, 1, 0, 1, 1 }; 01566 const int num_double = sizeof( vertex_coords ) / ( sizeof( double ) ); 01567 const int num_vertex = num_double / 3; 01568 assert( 0 == num_double % 3 ); 01569 01570 // create some vertices 01571 Range vertices; 01572 double min[3] = { HUGE_VAL, HUGE_VAL, HUGE_VAL }; 01573 double max[3] = { -HUGE_VAL, -HUGE_VAL, -HUGE_VAL }; 01574 for( int i = 0; i < num_vertex; ++i ) 01575 { 01576 EntityHandle h; 01577 rval = gMB->create_vertex( vertex_coords + 3 * i, h ); 01578 ASSERT( MB_SUCCESS == rval ); 01579 vertices.insert( h ); 01580 for( int j = 0; j < 3; ++j ) 01581 { 01582 const double c = vertex_coords[3 * i + j]; 01583 if( c < min[j] ) min[j] = c; 01584 if( c > max[j] ) max[j] = c; 01585 } 01586 } 01587 01588 // create box containing vertices 01589 OrientedBox box; 01590 rval = OrientedBox::compute_from_vertices( box, gMB, vertices ); 01591 ASSERT( MB_SUCCESS == rval ); 01592 01593 for( int i = 0; i < num_vertex; ++i ) 01594 { 01595 ASSERT( box.contained( CartVect( vertex_coords[3 * i] ), 1e-6 ) ); 01596 } 01597 01598 // define a set of points otside of the box to test 01599 double center[3] = { 0.5 * ( max[0] + min[0] ), 0.5 * ( max[1] + min[1] ), 0.5 * ( max[2] + min[2] ) }; 01600 double diag[3] = { max[0] - min[0], max[1] - min[1], max[2] - min[2] }; 01601 double outside1[3] = { center[0] + diag[0], center[1] + diag[1], center[2] + diag[2] }; 01602 double outside2[3] = { center[0] + diag[0], center[1] + diag[1], center[2] }; 01603 double outside3[3] = { center[0] + diag[0], center[1], center[2] }; 01604 double* outside[3] = { outside1, outside2, outside3 }; 01605 // test 'contained' method for all points 01606 for( int i = 0; i < 3; ++i ) 01607 { 01608 ASSERT( !box.contained( CartVect( outside[i] ), 1e-6 ) ); 01609 } 01610 } 01611 01612 static void test_save() 01613 { 01614 ErrorCode rval; 01615 Core moab; 01616 OrientedBox box; 01617 01618 // create a tag to store the data in 01619 Tag tag; 01620 rval = OrientedBox::tag_handle( tag, &moab, "FOO" ); 01621 ASSERT( MB_SUCCESS == rval ); 01622 01623 // check tag size 01624 int size; 01625 rval = moab.tag_get_bytes( tag, size ); 01626 ASSERT( MB_SUCCESS == rval ); 01627 ASSERT( size == sizeof( OrientedBox ) ); 01628 } 01629 01630 /********************* Error Checking Code ***************************/ 01631 01632 static void assert_vector_element( const CartVect& a, const Matrix3& b, const char* sa, const char* sb, int lineno ) 01633 { 01634 int i; 01635 bool ismatch = false; 01636 for( i = 0; i < 3; ++i ) 01637 { 01638 if( fabs( a[0] - b( 0, i ) ) <= TOL && fabs( a[1] - b( 1, i ) ) <= TOL && fabs( a[2] - b( 2, i ) ) <= TOL ) 01639 { 01640 ismatch = true; 01641 break; 01642 } 01643 } 01644 if( !ismatch ) 01645 { 01646 ++error_count; 01647 std::cerr << "Assertion failed at line " << lineno << std::endl 01648 << "\t" << sa << " in " << sb << std::endl 01649 << "\t" << sa << " = " << a << std::endl 01650 << "\t" << sb << " = " << b << std::endl; 01651 } 01652 return; 01653 } 01654 01655 void assert_vectors_equal( const CartVect& a, const CartVect& b, const char* sa, const char* sb, int lineno ) 01656 { 01657 if( fabs( a[0] - b[0] ) > TOL || fabs( a[1] - b[1] ) > TOL || fabs( a[2] - b[2] ) > TOL ) 01658 { 01659 std::cerr << "Assertion failed at line " << lineno << std::endl 01660 << "\t" << sa << " == " << sb << std::endl 01661 << "\t[" << a[0] << ", " << a[1] << ", " << a[2] << "] == [" << b[0] << ", " << b[1] << ", " << b[2] 01662 << "]" << std::endl; 01663 ++error_count; 01664 } 01665 } 01666 01667 void assert_doubles_equal( double a, double b, const char* sa, const char* sb, int lineno ) 01668 { 01669 if( fabs( a - b ) > TOL ) 01670 { 01671 std::cerr << "Assertion failed at line " << lineno << std::endl 01672 << "\t" << sa << " == " << sb << std::endl 01673 << "\t" << a << " == " << b << std::endl; 01674 ++error_count; 01675 } 01676 } 01677 01678 void assert_bool( bool b, const char* sb, int lineno ) 01679 { 01680 if( !b ) 01681 { 01682 std::cerr << "Assertion failed at line " << lineno << std::endl << "\t" << sb << std::endl; 01683 ++error_count; 01684 } 01685 }
