MOAB: Mesh Oriented datABase
(version 5.4.1)
00001 #include "moab/ParallelComm.hpp" 00002 #include "MBParallelConventions.h" 00003 #include "moab/ParCommGraph.hpp" 00004 #include "ReadParallel.hpp" 00005 #include "moab/FileOptions.hpp" 00006 #include "MBTagConventions.hpp" 00007 #include "moab/Core.hpp" 00008 #include "moab_mpi.h" 00009 #include "TestUtil.hpp" 00010 00011 #include <iostream> 00012 #include <algorithm> 00013 #include <map> 00014 #include <sstream> 00015 #include <cassert> 00016 #if !defined( _MSC_VER ) && !defined( __MINGW32__ ) 00017 #include <unistd.h> 00018 #endif 00019 00020 using namespace moab; 00021 00022 #define CHKERR( a ) \ 00023 do \ 00024 { \ 00025 ErrorCode val = ( a ); \ 00026 if( MB_SUCCESS != val ) \ 00027 { \ 00028 std::cerr << "Error code " << val << " at " << __FILE__ << ":" << __LINE__ << std::endl; \ 00029 return val; \ 00030 } \ 00031 } while( false ) 00032 00033 #define PCHECK( A ) \ 00034 if( is_any_proc_error( !( A ) ) ) return report_error( __FILE__, __LINE__ ) 00035 00036 ErrorCode report_error( const char* file, int line ) 00037 { 00038 std::cerr << "Failure at " << file << ':' << line << std::endl; 00039 return MB_FAILURE; 00040 } 00041 00042 /************************************************************************** 00043 Utility Method Declarations 00044 **************************************************************************/ 00045 00046 // Get processors an entity is shared with. 00047 ErrorCode get_sharing_processors( Interface& moab, EntityHandle entity, std::vector< int >& other_procs_out ); 00048 00049 // Create a parallel mesh 00050 // 00051 // Each processor will create four quads. 00052 // Groups of four quads will be arranged as follows: 00053 // +------+------+------+------+------+----- 00054 // | | | 00055 // | | | 00056 // + Proc 0 + Proc 2 + Proc 4 00057 // | | | 00058 // | | | 00059 // +------+------+------+------+------+----- 00060 // | | | 00061 // | | | 00062 // + Proc 1 + Proc 3 + Proc 5 00063 // | | | 00064 // | | | 00065 // +------+------+------+------+------+----- 00066 // 00067 // Vertices will be enumerated as follows: 00068 // 1------6-----11-----16-----21-----26----- 00069 // | | | 00070 // | | | 00071 // 2 7 12 17 22 27 00072 // | | | 00073 // | | | 00074 // 3------8-----13-----18-----23-----28----- 00075 // | | | 00076 // | | | 00077 // 4 9 14 19 24 29 00078 // | | | 00079 // | | | 00080 // 5-----10-----15-----20-----25-----30----- 00081 // 00082 // Element IDs will be [4*rank+1,4*rank+5] 00083 // 00084 // If output_sets is non-null, it will be populated with 2 or 3 00085 // set handles. A set handle is created for each group of four 00086 // adjacent processes, such that one is created across procs 0 to 4, 00087 // one is created for procs 2 to 5, etc. An additional set is created 00088 // that spans all of the processes. The set spanning all procs is 00089 // returned first. The other two sets are returned in the order of the 00090 // largest contained process rank, where the last entry is zero if 00091 // there is only one additional set. 00092 ErrorCode parallel_create_mesh( Interface& mb, 00093 int output_vertx_ids[9], 00094 EntityHandle output_vertex_handles[9], 00095 Range& output_elements, 00096 EntityHandle output_sets[3] = 0 ); 00097 00098 // Test if is_my_error is non-zero on any processor in MPI_COMM_WORLD 00099 int is_any_proc_error( int is_my_error ); 00100 00101 /************************************************************************** 00102 Test Declarations 00103 **************************************************************************/ 00104 00105 // Check consistancy of sharing data. (E.g. compare sharing procs for 00106 // vertices to that of adjacent elements, compare sharing data for 00107 // interfaces with that of contained entities, etc.) 00108 ErrorCode test_elements_on_several_procs( const char* filename ); 00109 // Test correct ghosting of elements 00110 ErrorCode test_ghost_elements_3_2_1( const char* filename ); 00111 ErrorCode test_ghost_elements_3_2_2( const char* filename ); 00112 ErrorCode test_ghost_elements_3_0_1( const char* filename ); 00113 ErrorCode test_ghost_elements_2_0_1( const char* filename ); 00114 // Test exchange of tag data on ghost elements 00115 ErrorCode test_ghost_tag_exchange( const char* filename ); 00116 // Bug where exchange_tags fails if dense tag cannot be queried 00117 // for all ghost entities (e.g. no default value) 00118 ErrorCode regression_ghost_tag_exchange_no_default( const char* filename ); 00119 // Test owners for interface entities 00120 ErrorCode test_interface_owners( const char* ); 00121 // Test data for shared interface entitites with one level of ghosting 00122 ErrorCode regression_owners_with_ghosting( const char* ); 00123 // Verify all sharing data for vertices with one level of ghosting 00124 ErrorCode test_ghosted_entity_shared_data( const char* ); 00125 // Test assignment of global IDs 00126 ErrorCode test_assign_global_ids( const char* ); 00127 // Test shared sets 00128 ErrorCode test_shared_sets( const char* ); 00129 // Test reduce_tags 00130 ErrorCode test_reduce_tags( const char* ); 00131 // Test reduce_tags failures 00132 ErrorCode test_reduce_tag_failures( const char* ); 00133 // Test reduce_tags with explicit destination tag 00134 ErrorCode test_reduce_tag_explicit_dest( const char* ); 00135 // Test delete_entities 00136 ErrorCode test_delete_entities( const char* ); 00137 // Test ghosting polyhedra 00138 ErrorCode test_ghost_polyhedra( const char* ); 00139 // Test failed read with too few parts in partition 00140 ErrorCode test_too_few_parts( const char* ); 00141 // Test broken sequences due to ghosting 00142 ErrorCode test_sequences_after_ghosting( const char* ); 00143 // Test trivial partition in use by iMOAB 00144 void test_trivial_partition(); 00145 00146 /************************************************************************** 00147 Main Method 00148 **************************************************************************/ 00149 00150 #define RUN_TEST_ARG2( A, B ) run_test( &( A ), #A, B ) 00151 00152 int run_test( ErrorCode ( *func )( const char* ), const char* func_name, const char* file_name ) 00153 { 00154 ErrorCode result = ( *func )( file_name ); 00155 int is_err = is_any_proc_error( ( MB_SUCCESS != result ) ); 00156 int rank; 00157 MPI_Comm_rank( MPI_COMM_WORLD, &rank ); 00158 if( rank == 0 ) 00159 { 00160 if( is_err ) 00161 std::cout << func_name << " : FAILED!!" << std::endl; 00162 else 00163 std::cout << func_name << " : success" << std::endl; 00164 } 00165 00166 return is_err; 00167 } 00168 00169 int main( int argc, char* argv[] ) 00170 { 00171 int rank, size; 00172 MPI_Init( &argc, &argv ); 00173 MPI_Comm_rank( MPI_COMM_WORLD, &rank ); 00174 MPI_Comm_size( MPI_COMM_WORLD, &size ); 00175 00176 int pause_proc = -1; 00177 std::string filename; 00178 for( int i = 1; i < argc; ++i ) 00179 { 00180 if( !strcmp( argv[i], "-p" ) ) 00181 { 00182 ++i; 00183 assert( i < argc ); 00184 pause_proc = atoi( argv[i] ); 00185 } 00186 else if( !filename.size() ) 00187 { 00188 filename = std::string( argv[i] ); 00189 } 00190 else 00191 { 00192 std::cerr << "Invalid arg: \"" << argv[i] << '"' << std::endl 00193 << "Usage: " << argv[0] << " [-p <rank>] [<filename>]" << std::endl; 00194 exit( 1 ); 00195 } 00196 } 00197 00198 if( !filename.size() ) 00199 { 00200 #ifdef MOAB_HAVE_HDF5 00201 filename = TestDir + "unittest/64bricks_512hex.h5m"; 00202 #else 00203 filename = TestDir + "unittest/64bricks_512hex.vtk"; 00204 #endif 00205 } 00206 std::cout << "Loading " << filename << "..\n"; 00207 #ifdef MOAB_HAVE_HDF5 00208 std::string filename2 = TestDir + "unittest/64bricks_1khex.h5m"; 00209 std::string filename3 = TestDir + "unittest/twoPolyh.h5m"; 00210 std::string filename4 = TestDir + "unittest/onepart.h5m"; 00211 #endif 00212 00213 if( pause_proc != -1 ) 00214 { 00215 #if !defined( _MSC_VER ) && !defined( __MINGW32__ ) 00216 std::cout << "Processor " << rank << " of " << size << " with PID " << getpid() << std::endl; 00217 std::cout.flush(); 00218 #endif 00219 // loop forever on requested processor, giving the user time 00220 // to attach a debugger. Once the debugger in attached, user 00221 // can change 'pause'. E.g. on gdb do "set var pause = 0" 00222 if( pause_proc == rank ) 00223 { 00224 volatile int pause = 1; 00225 while( pause ) 00226 ; 00227 } 00228 00229 MPI_Barrier( MPI_COMM_WORLD ); 00230 std::cout << "Processor " << rank << " resuming" << std::endl; 00231 } 00232 00233 int num_errors = 0; 00234 #ifdef MOAB_HAVE_HDF5 00235 num_errors += RUN_TEST_ARG2( test_elements_on_several_procs, filename.c_str() ); 00236 num_errors += RUN_TEST_ARG2( test_ghost_elements_3_2_1, filename.c_str() ); 00237 num_errors += RUN_TEST_ARG2( test_ghost_elements_3_2_2, filename.c_str() ); 00238 num_errors += RUN_TEST_ARG2( test_ghost_elements_3_0_1, filename.c_str() ); 00239 num_errors += RUN_TEST_ARG2( test_ghost_elements_2_0_1, filename.c_str() ); 00240 num_errors += RUN_TEST_ARG2( test_ghost_tag_exchange, filename.c_str() ); 00241 num_errors += RUN_TEST_ARG2( regression_ghost_tag_exchange_no_default, filename.c_str() ); 00242 num_errors += RUN_TEST_ARG2( test_delete_entities, filename2.c_str() ); 00243 num_errors += RUN_TEST_ARG2( test_sequences_after_ghosting, filename2.c_str() ); 00244 if( 2 >= size ) // run this one only on one or 2 processors; the file has only 2 parts in partition 00245 num_errors += RUN_TEST_ARG2( test_ghost_polyhedra, filename3.c_str() ); 00246 num_errors += RUN_TEST_ARG2( test_too_few_parts, filename4.c_str() ); 00247 #endif 00248 num_errors += RUN_TEST_ARG2( test_assign_global_ids, 0 ); 00249 num_errors += RUN_TEST_ARG2( test_shared_sets, 0 ); 00250 num_errors += RUN_TEST_ARG2( test_reduce_tags, 0 ); 00251 num_errors += RUN_TEST_ARG2( test_reduce_tag_failures, 0 ); 00252 num_errors += RUN_TEST_ARG2( test_reduce_tag_explicit_dest, 0 ); 00253 num_errors += RUN_TEST_ARG2( test_interface_owners, 0 ); 00254 num_errors += RUN_TEST_ARG2( test_ghosted_entity_shared_data, 0 ); 00255 num_errors += RUN_TEST_ARG2( regression_owners_with_ghosting, 0 ); 00256 num_errors += RUN_TEST( test_trivial_partition ); 00257 if( rank == 0 ) 00258 { 00259 if( !num_errors ) 00260 std::cout << "All tests passed" << std::endl; 00261 else 00262 std::cout << num_errors << " TESTS FAILED!" << std::endl; 00263 } 00264 00265 MPI_Finalize(); 00266 return num_errors; 00267 } 00268 00269 /************************************************************************** 00270 Utility Method Implementations 00271 **************************************************************************/ 00272 00273 ErrorCode get_sharing_processors( Interface& moab, EntityHandle entity, std::vector< int >& other_procs_out ) 00274 { 00275 ErrorCode rval; 00276 00277 // get tags for parallel data 00278 Tag sharedp_tag, sharedps_tag, sharedh_tag, sharedhs_tag, pstatus_tag; 00279 rval = moab.tag_get_handle( PARALLEL_SHARED_PROC_TAG_NAME, 1, MB_TYPE_INTEGER, sharedp_tag );CHKERR( rval ); 00280 rval = moab.tag_get_handle( PARALLEL_SHARED_PROCS_TAG_NAME, MAX_SHARING_PROCS, MB_TYPE_INTEGER, sharedps_tag );CHKERR( rval ); 00281 rval = moab.tag_get_handle( PARALLEL_SHARED_HANDLE_TAG_NAME, 1, MB_TYPE_HANDLE, sharedh_tag );CHKERR( rval ); 00282 rval = moab.tag_get_handle( PARALLEL_SHARED_HANDLES_TAG_NAME, MAX_SHARING_PROCS, MB_TYPE_HANDLE, sharedhs_tag );CHKERR( rval ); 00283 rval = moab.tag_get_handle( PARALLEL_STATUS_TAG_NAME, 1, MB_TYPE_OPAQUE, pstatus_tag );CHKERR( rval ); 00284 00285 other_procs_out.clear(); 00286 char status; 00287 rval = moab.tag_get_data( pstatus_tag, &entity, 1, &status );CHKERR( rval ); 00288 if( !( status & PSTATUS_SHARED ) ) return MB_SUCCESS; 00289 00290 int proc_id; 00291 rval = moab.tag_get_data( sharedp_tag, &entity, 1, &proc_id );CHKERR( rval ); 00292 if( proc_id >= 0 ) 00293 { 00294 other_procs_out.push_back( proc_id ); 00295 return MB_SUCCESS; 00296 } 00297 00298 int procs[MAX_SHARING_PROCS]; 00299 rval = moab.tag_get_data( sharedps_tag, &entity, 1, procs );CHKERR( rval ); 00300 for( int i = 0; i < MAX_SHARING_PROCS && procs[i] >= 0; ++i ) 00301 other_procs_out.push_back( procs[i] ); 00302 return MB_SUCCESS; 00303 } 00304 00305 int is_any_proc_error( int is_my_error ) 00306 { 00307 int result = 0; 00308 int err = MPI_Allreduce( &is_my_error, &result, 1, MPI_INT, MPI_MAX, MPI_COMM_WORLD ); 00309 return err || result; 00310 } 00311 00312 ErrorCode parallel_create_mesh( Interface& mb, 00313 int vtx_ids[9], 00314 EntityHandle vtx_handles[9], 00315 Range& range, 00316 EntityHandle* entity_sets ) 00317 { 00318 // Each processor will create four quads. 00319 // Groups of four quads will be arranged as follows: 00320 // +------+------+------+------+------+----- 00321 // | | | 00322 // | | | 00323 // + Proc 0 + Proc 2 + Proc 4 00324 // | | | 00325 // | | | 00326 // +------+------+------+------+------+----- 00327 // | | | 00328 // | | | 00329 // + Proc 1 + Proc 3 + Proc 5 00330 // | | | 00331 // | | | 00332 // +------+------+------+------+------+----- 00333 // 00334 // Vertices will be enumerated as follows: 00335 // 1------6-----11-----16-----21-----26----- 00336 // | | | 00337 // | | | 00338 // 2 7 12 17 22 27 00339 // | | | 00340 // | | | 00341 // 3------8-----13-----18-----23-----28----- 00342 // | | | 00343 // | | | 00344 // 4 9 14 19 24 29 00345 // | | | 00346 // | | | 00347 // 5-----10-----15-----20-----25-----30----- 00348 // 00349 // Element IDs will be [4*rank+1,4*rank+5] 00350 00351 int size, rank; 00352 MPI_Comm_size( MPI_COMM_WORLD, &size ); 00353 MPI_Comm_rank( MPI_COMM_WORLD, &rank ); 00354 00355 const int first_vtx_id = 10 * ( rank / 2 ) + 2 * ( rank % 2 ) + 1; 00356 const double x = 2.0 * ( rank / 2 ); 00357 const double y = 2.0 * ( rank % 2 ); 00358 00359 // create vertices 00360 const int idoff = ( size % 2 && rank / 2 == size / 2 ) ? 0 : 2; 00361 const int idoff1 = rank ? 2 : idoff; 00362 const int idoff2 = idoff1 + idoff; 00363 const int ids[9] = { first_vtx_id, first_vtx_id + 3 + idoff1, first_vtx_id + 6 + idoff2, 00364 first_vtx_id + 1, first_vtx_id + 4 + idoff1, first_vtx_id + 7 + idoff2, 00365 first_vtx_id + 2, first_vtx_id + 5 + idoff1, first_vtx_id + 8 + idoff2 }; 00366 memcpy( vtx_ids, ids, sizeof( ids ) ); 00367 const double coords[27] = { x, y, 0, x + 1, y, 0, x + 2, y, 0, x, y + 1, 0, x + 1, y + 1, 00368 0, x + 2, y + 1, 0, x, y + 2, 0, x + 1, y + 2, 0, x + 2, y + 2, 0 }; 00369 00370 ErrorCode rval; 00371 Tag id_tag; 00372 00373 rval = mb.create_vertices( coords, 9, range );CHKERR( rval ); 00374 assert( range.size() == 9 ); 00375 std::copy( range.begin(), range.end(), vtx_handles ); 00376 range.clear(); 00377 id_tag = mb.globalId_tag(); 00378 rval = mb.tag_set_data( id_tag, vtx_handles, 9, &ids );CHKERR( rval ); 00379 00380 const EntityHandle conn[4][4] = { { vtx_handles[0], vtx_handles[3], vtx_handles[4], vtx_handles[1] }, 00381 { vtx_handles[1], vtx_handles[4], vtx_handles[5], vtx_handles[2] }, 00382 { vtx_handles[3], vtx_handles[6], vtx_handles[7], vtx_handles[4] }, 00383 { vtx_handles[4], vtx_handles[7], vtx_handles[8], vtx_handles[5] } }; 00384 for( int i = 0; i < 4; ++i ) 00385 { 00386 const int id = 4 * rank + i + 1; 00387 EntityHandle h; 00388 rval = mb.create_element( MBQUAD, conn[i], 4, h );CHKERR( rval ); 00389 range.insert( h ); 00390 rval = mb.tag_set_data( id_tag, &h, 1, &id );CHKERR( rval ); 00391 } 00392 00393 if( !entity_sets ) return MB_SUCCESS; 00394 00395 int set_ids[3] = { size + 1, rank / 2, rank / 2 + 1 }; 00396 int nsets = 0; 00397 rval = mb.create_meshset( MESHSET_SET, entity_sets[nsets++] );CHKERR( rval ); 00398 rval = mb.create_meshset( MESHSET_SET, entity_sets[nsets++] );CHKERR( rval ); 00399 entity_sets[nsets] = 0; 00400 if( rank < 2 ) 00401 { // if first (left-most) column 00402 set_ids[1] = set_ids[2]; 00403 } 00404 else if( rank / 2 < ( size - 1 ) / 2 ) 00405 { // if not last (right-most) column 00406 rval = mb.create_meshset( MESHSET_SET, entity_sets[nsets++] );CHKERR( rval ); 00407 } 00408 for( int i = 0; i < nsets; ++i ) 00409 { 00410 rval = mb.add_entities( entity_sets[0], range );CHKERR( rval ); 00411 } 00412 rval = mb.tag_set_data( id_tag, entity_sets, nsets, set_ids );CHKERR( rval ); 00413 00414 return MB_SUCCESS; 00415 } 00416 00417 /************************************************************************** 00418 Test Implementations 00419 **************************************************************************/ 00420 00421 ErrorCode test_elements_on_several_procs( const char* filename ) 00422 { 00423 Core mb_instance; 00424 Interface& moab = mb_instance; 00425 ErrorCode rval; 00426 const char* geom_names[] = { "vertex", "curve", "surface", "volume", "unknown" }; 00427 00428 rval = moab.load_file( filename, 0, 00429 "PARALLEL=READ_DELETE;" 00430 "PARTITION=GEOM_DIMENSION;PARTITION_VAL=3;" 00431 "PARTITION_DISTRIBUTE;" 00432 "PARALLEL_RESOLVE_SHARED_ENTS;" 00433 "PARALLEL_SEQUENCE_FACTOR=1.4" );CHKERR( rval ); 00434 00435 // test contents of interface sets against sharedEnts structure in pcomm; 00436 int my_error = 0; 00437 ParallelComm* pcomm = ParallelComm::get_pcomm( &moab, 0 ); 00438 rval = pcomm->check_all_shared_handles(); 00439 if( MB_SUCCESS != rval ) 00440 { 00441 my_error = 1; 00442 std::cerr << "check_all_shared_handles test failed on proc " << pcomm->proc_config().proc_rank() << std::endl; 00443 } 00444 PCHECK( !my_error ); 00445 00446 // check adjacencies just to make sure they're consistent 00447 rval = mb_instance.check_adjacencies(); 00448 if( MB_SUCCESS != rval ) my_error = 1; 00449 PCHECK( !my_error ); 00450 00451 Tag geom_tag, id_tag; 00452 rval = moab.tag_get_handle( GEOM_DIMENSION_TAG_NAME, 1, MB_TYPE_INTEGER, geom_tag );CHKERR( rval ); 00453 id_tag = moab.globalId_tag(); 00454 00455 // Because we partitioned based on geometric volume sets, then for each 00456 // lower-dimension geometric entity set all of the contained entities of 00457 // the same dimension must be shared by the same set of processors 00458 Range shared, invalid; 00459 for( int dim = 2; dim > 0; --dim ) 00460 { 00461 Range geom_sets; 00462 const void* tagvals[] = { &dim }; 00463 rval = moab.get_entities_by_type_and_tag( 0, MBENTITYSET, &geom_tag, tagvals, 1, geom_sets );CHKERR( rval ); 00464 00465 for( Range::iterator j = geom_sets.begin(); j != geom_sets.end(); ++j ) 00466 { 00467 Range ents; 00468 rval = moab.get_entities_by_dimension( *j, dim, ents );CHKERR( rval ); 00469 if( ents.empty() ) continue; 00470 00471 // get a single sharing list to compare with 00472 Range::iterator k = ents.begin(); 00473 std::vector< int > procs; 00474 rval = get_sharing_processors( moab, *k, procs );CHKERR( rval ); 00475 std::sort( procs.begin(), procs.end() ); 00476 if( procs.size() > 1 ) shared.merge( ents ); 00477 00478 // compare other elements 00479 for( ++k; k != ents.end(); ++k ) 00480 { 00481 std::vector< int > tmp_procs; 00482 rval = get_sharing_processors( moab, *k, tmp_procs );CHKERR( rval ); 00483 std::sort( tmp_procs.begin(), tmp_procs.end() ); 00484 if( tmp_procs != procs ) invalid.insert( *j ); 00485 } 00486 00487 // compare interior vertices 00488 ents.clear(); 00489 rval = moab.get_entities_by_dimension( *j, 0, ents );CHKERR( rval ); 00490 for( k = ents.begin(); k != ents.end(); ++k ) 00491 { 00492 std::vector< int > tmp_procs; 00493 rval = get_sharing_processors( moab, *k, tmp_procs );CHKERR( rval ); 00494 if( tmp_procs != procs ) invalid.insert( *j ); 00495 } 00496 } 00497 } 00498 00499 // Report any geometric sets for which sharing was inconsistent 00500 if( !invalid.empty() ) 00501 { 00502 std::cerr << "Elements or vertices owned by a single geometric entity are " 00503 << "not shared by the same set of processors for the " 00504 << "following geometric entities on process " << pcomm->proc_config().proc_rank() << ": "; 00505 for( Range::iterator i = invalid.begin(); i != invalid.end(); ++i ) 00506 { 00507 int dim; 00508 int id; 00509 rval = moab.tag_get_data( geom_tag, &*i, 1, &dim ); 00510 if( MB_SUCCESS != rval ) dim = 4; 00511 rval = moab.tag_get_data( id_tag, &*i, 1, &id ); 00512 if( MB_SUCCESS != rval ) id = -1; 00513 std::cerr << geom_names[dim] << " " << id << ", "; 00514 } 00515 std::cerr << std::endl; 00516 00517 my_error = 1; 00518 } 00519 PCHECK( !my_error ); 00520 00521 // for each shared element, check that its vertices are shared 00522 // with at least the same processes 00523 for( Range::iterator i = shared.begin(); i != shared.end(); ++i ) 00524 { 00525 std::vector< int > procs; 00526 rval = get_sharing_processors( moab, *i, procs );CHKERR( rval ); 00527 std::sort( procs.begin(), procs.end() ); 00528 00529 std::vector< EntityHandle > tmp; 00530 const EntityHandle* conn; 00531 int len; 00532 rval = moab.get_connectivity( *i, conn, len, false, &tmp );CHKERR( rval ); 00533 for( int j = 0; j < len; ++j ) 00534 { 00535 std::vector< int > vprocs; 00536 rval = get_sharing_processors( moab, conn[j], vprocs );CHKERR( rval ); 00537 std::sort( vprocs.begin(), vprocs.end() ); 00538 std::vector< int > diff( std::max( procs.size(), vprocs.size() ) ); 00539 std::vector< int >::iterator k = 00540 std::set_difference( procs.begin(), procs.end(), vprocs.begin(), vprocs.end(), diff.begin() ); 00541 if( k != diff.begin() ) // difference is not empty 00542 invalid.insert( conn[j] ); 00543 } 00544 } 00545 00546 // Report any vertices with insufficient sharing 00547 if( !invalid.empty() ) 00548 { 00549 std::cerr << "Vertices must be shared with at least the union of the processes " 00550 << "sharing the elements containing the vertex. This is NOT true for " 00551 << "the following vertices on process " << pcomm->proc_config().proc_rank() << ": " << invalid 00552 << std::endl; 00553 00554 my_error = 1; 00555 } 00556 PCHECK( !my_error ); 00557 00558 return MB_SUCCESS; 00559 } 00560 00561 ErrorCode get_ghost_entities( ParallelComm& pcomm, Range& ghost_ents ) 00562 { 00563 Range all_ents; 00564 ErrorCode rval; 00565 00566 rval = pcomm.get_moab()->get_entities_by_handle( 0, all_ents );CHKERR( rval ); 00567 std::vector< unsigned char > flags( all_ents.size() ); 00568 rval = pcomm.get_moab()->tag_get_data( pcomm.pstatus_tag(), all_ents, &flags[0] );CHKERR( rval ); 00569 00570 Range::iterator ins = ghost_ents.begin(); 00571 std::vector< unsigned char >::const_iterator f = flags.begin(); 00572 for( Range::iterator i = all_ents.begin(); i != all_ents.end(); ++i, ++f ) 00573 if( ( *f & PSTATUS_NOT_OWNED ) && !( *f & PSTATUS_INTERFACE ) ) ins = ghost_ents.insert( ins, *i, *i ); 00574 00575 return MB_SUCCESS; 00576 } 00577 00578 ErrorCode get_ents_from_geometric_sets( Interface& moab, 00579 const Tag tags[2], 00580 int dimension, 00581 const std::vector< int >& ids, 00582 Range& results ) 00583 { 00584 ErrorCode rval; 00585 for( size_t i = 0; i < ids.size(); ++i ) 00586 { 00587 const void* tag_vals[2] = { &dimension, &ids[i] }; 00588 Range sets; 00589 rval = moab.get_entities_by_type_and_tag( 0, MBENTITYSET, tags, tag_vals, 2, sets );CHKERR( rval ); 00590 for( Range::iterator j = sets.begin(); j != sets.end(); ++j ) 00591 { 00592 Range ents; 00593 rval = moab.get_entities_by_dimension( *j, dimension, ents );CHKERR( rval ); 00594 results.merge( ents ); 00595 } 00596 } 00597 return MB_SUCCESS; 00598 } 00599 00600 /**\brief Given entire file and IDs of geometric sets, get expected ghost entities 00601 * 00602 *\param moab The entire mesh, loaded in serial 00603 *\param partition_geom_ids IDs of: geometric volumes owned by this proc and interface topology 00604 *\param ghost_entity_ids output list 00605 */ 00606 ErrorCode get_expected_ghosts( Interface& moab, 00607 const std::vector< int > partition_geom_ids[4], 00608 std::vector< int >& ghost_entity_ids, 00609 int ghost_dimension, 00610 int bridge_dimension, 00611 int num_layers ) 00612 { 00613 ErrorCode rval; 00614 Tag tags[2]; 00615 rval = moab.tag_get_handle( GEOM_DIMENSION_TAG_NAME, 1, MB_TYPE_INTEGER, tags[0] );CHKERR( rval ); 00616 tags[1] = moab.globalId_tag(); 00617 00618 // get face entities defining interface 00619 Range skin; 00620 rval = get_ents_from_geometric_sets( moab, tags, 2, partition_geom_ids[2], skin );CHKERR( rval ); 00621 00622 // get adjacent entities 00623 Range iface_ghosts, iface_ents; 00624 if( bridge_dimension == 2 ) 00625 { 00626 iface_ents = skin; 00627 } 00628 else 00629 { 00630 rval = moab.get_adjacencies( skin, bridge_dimension, true, iface_ents, Interface::UNION );CHKERR( rval ); 00631 } 00632 for( int n = 0; n < num_layers; ++n ) 00633 { 00634 iface_ghosts.clear(); 00635 rval = moab.get_adjacencies( iface_ents, ghost_dimension, false, iface_ghosts, Interface::UNION );CHKERR( rval ); 00636 iface_ents.clear(); 00637 rval = moab.get_adjacencies( iface_ghosts, bridge_dimension, true, iface_ents, Interface::UNION );CHKERR( rval ); 00638 } 00639 00640 // get volume entities owned by this process 00641 Range ents; 00642 rval = get_ents_from_geometric_sets( moab, tags, 3, partition_geom_ids[3], ents );CHKERR( rval ); 00643 00644 // get entities of ghost_dimension owned by this process 00645 Range owned; 00646 if( ghost_dimension == 3 ) 00647 owned = ents; 00648 else 00649 { 00650 rval = moab.get_adjacencies( ents, ghost_dimension, false, owned, Interface::UNION );CHKERR( rval ); 00651 } 00652 00653 // remove owned entities from ghost list 00654 Range ghosts = subtract( iface_ghosts, owned ); 00655 00656 // get ids 00657 ghost_entity_ids.resize( ghosts.size() ); 00658 rval = moab.tag_get_data( tags[1], ghosts, &ghost_entity_ids[0] );CHKERR( rval ); 00659 return MB_SUCCESS; 00660 } 00661 00662 ErrorCode test_ghost_elements( const char* filename, int ghost_dimension, int bridge_dimension, int num_layers ) 00663 { 00664 Core mb_instance; 00665 Interface& moab = mb_instance; 00666 ErrorCode rval; 00667 00668 std::ostringstream file_opts; 00669 file_opts << "PARALLEL=READ_DELETE;" 00670 << "PARTITION=GEOM_DIMENSION;PARTITION_VAL=3;" 00671 << "PARTITION_DISTRIBUTE;" 00672 << "PARALLEL_RESOLVE_SHARED_ENTS;" 00673 << "PARALLEL_GHOSTS=" << ghost_dimension << '.' << bridge_dimension << '.' << num_layers; 00674 00675 rval = moab.load_file( filename, 0, file_opts.str().c_str() );CHKERR( rval ); 00676 Tag geom_tag, id_tag; 00677 rval = moab.tag_get_handle( GEOM_DIMENSION_TAG_NAME, 1, MB_TYPE_INTEGER, geom_tag );CHKERR( rval ); 00678 id_tag = moab.globalId_tag(); 00679 00680 // Get partition sets 00681 Range partition_geom[4]; 00682 ParallelComm* pcomm = ParallelComm::get_pcomm( &moab, 0 ); 00683 partition_geom[3] = pcomm->partition_sets(); 00684 PCHECK( !partition_geom[3].empty() ); 00685 00686 rval = pcomm->check_all_shared_handles();CHKERR( rval ); 00687 00688 // exchange id tags to allow comparison by id 00689 Range tmp_ents; 00690 rval = pcomm->get_shared_entities( -1, tmp_ents, -1, false, true ); 00691 rval = pcomm->exchange_tags( id_tag, tmp_ents );CHKERR( rval ); 00692 00693 // Get geometric surfaces 00694 Range surfs, tmp; 00695 for( Range::iterator i = partition_geom[3].begin(); i != partition_geom[3].end(); ++i ) 00696 { 00697 tmp.clear(); 00698 rval = moab.get_child_meshsets( *i, tmp );CHKERR( rval ); 00699 surfs.merge( tmp ); 00700 } 00701 00702 // Get the set of geometric surfaces that represent the skin 00703 // of the union of the parts for this processor. As we partition 00704 // based on geometric volumes, the interface must be represented 00705 // by some subset of the surfaces and their child geometric topology. 00706 00707 int error = 0; 00708 std::ostringstream error_msg; 00709 Range ents, iface_surfs, iface_curves, iface_vertices; 00710 for( Range::iterator i = surfs.begin(); !error && i != surfs.end(); ++i ) 00711 { 00712 ents.clear(); 00713 rval = moab.get_entities_by_dimension( *i, ghost_dimension - 1, ents );CHKERR( rval ); 00714 if( ents.empty() ) continue; 00715 00716 std::vector< int > procs, tmp_procs; 00717 Range::iterator j = ents.begin(); 00718 rval = get_sharing_processors( moab, *j, procs );CHKERR( rval ); 00719 for( ++j; !error && j != ents.end(); ++j ) 00720 { 00721 tmp_procs.clear(); 00722 rval = get_sharing_processors( moab, *j, tmp_procs );CHKERR( rval ); 00723 if( tmp_procs != procs ) 00724 { 00725 error_msg << "Failure at " << __FILE__ << ':' << __LINE__ << std::endl 00726 << "\tNot all entities in geometric surface are shared with" 00727 << " same processor." << std::endl; 00728 error = 1; 00729 break; 00730 } 00731 } 00732 00733 if( error ) break; 00734 00735 // if surface is not part of inter-proc interface, skip it. 00736 if( procs.empty() ) continue; 00737 if( procs.size() != 1 ) 00738 { 00739 error_msg << "Failure at " << __FILE__ << ':' << __LINE__ << std::endl 00740 << "\tSurface elements shared with" << procs.size() << "processors." << std::endl; 00741 error = 1; 00742 break; 00743 } 00744 int other_rank = procs[0]; 00745 if( other_rank == (int)pcomm->proc_config().proc_rank() ) continue; 00746 00747 partition_geom[2].insert( *i ); 00748 ents.clear(); 00749 rval = moab.get_child_meshsets( *i, ents );CHKERR( rval ); 00750 partition_geom[1].merge( ents ); 00751 } 00752 00753 // Don't to global communication until outside 00754 // of loops. Otherwise we will deadlock if not all 00755 // procs iterate the same number of times. 00756 if( is_any_proc_error( error ) ) 00757 { 00758 std::cerr << error_msg.str(); 00759 return MB_FAILURE; 00760 } 00761 00762 for( Range::iterator i = partition_geom[1].begin(); i != partition_geom[1].end(); ++i ) 00763 { 00764 ents.clear(); 00765 rval = moab.get_child_meshsets( *i, ents );CHKERR( rval ); 00766 partition_geom[0].merge( ents ); 00767 } 00768 00769 std::vector< int > partn_geom_ids[4]; 00770 for( int dim = 0; dim <= 3; ++dim ) 00771 { 00772 partn_geom_ids[dim].resize( partition_geom[dim].size() ); 00773 rval = moab.tag_get_data( id_tag, partition_geom[dim], &( partn_geom_ids[dim][0] ) );CHKERR( rval ); 00774 } 00775 00776 // get the global IDs of the ghosted entities 00777 Range ghost_ents; 00778 rval = get_ghost_entities( *pcomm, ghost_ents );CHKERR( rval ); 00779 std::pair< Range::iterator, Range::iterator > vtx = ghost_ents.equal_range( MBVERTEX ); 00780 ghost_ents.erase( vtx.first, vtx.second ); 00781 std::vector< int > actual_ghost_ent_ids( ghost_ents.size() ); 00782 rval = moab.tag_get_data( id_tag, ghost_ents, &actual_ghost_ent_ids[0] );CHKERR( rval ); 00783 00784 // read file in serial 00785 Core moab2; 00786 rval = moab2.load_file( filename ); 00787 PCHECK( MB_SUCCESS == rval ); 00788 00789 // get the global IDs of the entities we expect to be ghosted 00790 std::vector< int > expected_ghost_ent_ids; 00791 rval = get_expected_ghosts( moab2, partn_geom_ids, expected_ghost_ent_ids, ghost_dimension, bridge_dimension, 00792 num_layers ); 00793 PCHECK( MB_SUCCESS == rval ); 00794 00795 // check that the correct entities were ghosted 00796 std::sort( actual_ghost_ent_ids.begin(), actual_ghost_ent_ids.end() ); 00797 std::sort( expected_ghost_ent_ids.begin(), expected_ghost_ent_ids.end() ); 00798 PCHECK( expected_ghost_ent_ids == actual_ghost_ent_ids ); 00799 00800 // check we only have the partitioned and ghosted entities 00801 // on this processor. 00802 Range myents; 00803 for( Range::iterator i = partition_geom[3].begin(); i != partition_geom[3].end(); ++i ) 00804 { 00805 ents.clear(); 00806 rval = moab.get_entities_by_dimension( *i, 3, ents );CHKERR( rval ); 00807 myents.merge( ents ); 00808 } 00809 if( ghost_dimension != 3 ) 00810 { 00811 ents.clear(); 00812 rval = moab.get_adjacencies( myents, ghost_dimension, false, ents, Interface::UNION ); 00813 PCHECK( MB_SUCCESS == rval ); 00814 myents.swap( ents ); 00815 } 00816 myents.merge( ghost_ents ); 00817 ents.clear(); 00818 rval = moab.get_entities_by_dimension( 0, ghost_dimension, ents ); 00819 PCHECK( ents == myents ); 00820 00821 rval = pcomm->check_all_shared_handles(); 00822 if( MB_SUCCESS != rval ) error = 1; 00823 PCHECK( !error ); 00824 00825 // done 00826 return MB_SUCCESS; 00827 } 00828 00829 ErrorCode test_ghost_elements_3_2_1( const char* filename ) 00830 { 00831 return test_ghost_elements( filename, 3, 2, 1 ); 00832 } 00833 00834 ErrorCode test_ghost_elements_3_2_2( const char* filename ) 00835 { 00836 return test_ghost_elements( filename, 3, 2, 2 ); 00837 } 00838 00839 ErrorCode test_ghost_elements_3_0_1( const char* filename ) 00840 { 00841 return test_ghost_elements( filename, 3, 0, 1 ); 00842 } 00843 00844 ErrorCode test_ghost_elements_2_0_1( const char* filename ) 00845 { 00846 return test_ghost_elements( filename, 2, 0, 1 ); 00847 } 00848 00849 ErrorCode get_owner_handles( ParallelComm* pcomm, const Range& ents, EntityHandle* handle_arr ) 00850 { 00851 size_t i = 0; 00852 int junk; 00853 for( Range::iterator j = ents.begin(); j != ents.end(); ++i, ++j ) 00854 { 00855 ErrorCode rval = pcomm->get_owner_handle( *j, junk, handle_arr[i] ); 00856 if( MB_SUCCESS != rval ) return rval; 00857 } 00858 return MB_SUCCESS; 00859 } 00860 00861 ErrorCode test_ghost_tag_exchange( const char* filename ) 00862 { 00863 Core mb_instance; 00864 Interface& moab = mb_instance; 00865 ErrorCode rval; 00866 00867 rval = moab.load_file( filename, 0, 00868 "PARALLEL=READ_DELETE;" 00869 "PARTITION=GEOM_DIMENSION;PARTITION_VAL=3;" 00870 "PARTITION_DISTRIBUTE;" 00871 "PARALLEL_RESOLVE_SHARED_ENTS;" 00872 "PARALLEL_GHOSTS=3.2.1;" 00873 "PARALLEL_SEQUENCE_FACTOR=1.5" );CHKERR( rval ); 00874 00875 // Get ghost elements 00876 ParallelComm* pcomm = ParallelComm::get_pcomm( &moab, 0 ); 00877 Range local, ghosts; 00878 rval = moab.get_entities_by_dimension( 0, 3, local );CHKERR( rval ); 00879 Range::iterator i = local.begin(); 00880 while( i != local.end() ) 00881 { 00882 int rank; 00883 rval = pcomm->get_owner( *i, rank );CHKERR( rval ); 00884 if( rank == (int)pcomm->proc_config().proc_rank() ) 00885 { 00886 ++i; 00887 } 00888 else 00889 { 00890 ghosts.insert( *i ); 00891 i = local.erase( i ); 00892 } 00893 } 00894 00895 // create a tag to exchange 00896 Tag dense_test_tag; 00897 EntityHandle defval = 0; 00898 // rval = moab.tag_get_handle( "TEST-TAG", sizeof(EntityHandle), MB_TAG_DENSE, 00899 // dense_test_tag, &defval ); CHKERR(rval); 00900 rval = moab.tag_get_handle( "TEST-TAG", 1, MB_TYPE_HANDLE, dense_test_tag, MB_TAG_DENSE | MB_TAG_EXCL, &defval );CHKERR( rval ); 00901 00902 // for all entities that I own, set tag to handle value 00903 std::vector< EntityHandle > handles( local.size() ), handles2; 00904 std::copy( local.begin(), local.end(), handles.begin() ); 00905 rval = moab.tag_set_data( dense_test_tag, local, &handles[0] );CHKERR( rval ); 00906 00907 // exchange tag data 00908 Range tmp_range; 00909 rval = pcomm->exchange_tags( dense_test_tag, tmp_range );CHKERR( rval ); 00910 00911 // make sure local values are unchanged 00912 handles2.resize( local.size() ); 00913 rval = moab.tag_get_data( dense_test_tag, local, &handles2[0] );CHKERR( rval ); 00914 PCHECK( handles == handles2 ); 00915 00916 // compare values on ghost entities 00917 handles.resize( ghosts.size() ); 00918 handles2.resize( ghosts.size() ); 00919 rval = moab.tag_get_data( dense_test_tag, ghosts, &handles2[0] );CHKERR( rval ); 00920 rval = get_owner_handles( pcomm, ghosts, &handles[0] );CHKERR( rval ); 00921 PCHECK( handles == handles2 ); 00922 00923 // now do it all again for a sparse tag 00924 Tag sparse_test_tag; 00925 // rval = moab.tag_get_handle( "TEST-TAG-2", sizeof(int), MB_TAG_DENSE, 00926 // MB_TYPE_INTEGER, sparse_test_tag, 0 ); CHKERR(rval); 00927 rval = moab.tag_get_handle( "TEST-TAG-2", 1, MB_TYPE_INTEGER, sparse_test_tag, MB_TAG_DENSE | MB_TAG_EXCL );CHKERR( rval ); 00928 00929 // for all entiites that I own, set tag to my rank 00930 std::vector< int > procs1( local.size(), pcomm->proc_config().proc_rank() ); 00931 rval = moab.tag_set_data( sparse_test_tag, local, &procs1[0] );CHKERR( rval ); 00932 00933 // exchange tag data 00934 tmp_range.clear(); 00935 rval = pcomm->exchange_tags( sparse_test_tag, tmp_range ); 00936 PCHECK( MB_SUCCESS == rval ); 00937 00938 // make sure local values are unchanged 00939 std::vector< int > procs2( local.size() ); 00940 rval = moab.tag_get_data( sparse_test_tag, local, &procs2[0] );CHKERR( rval ); 00941 PCHECK( procs1 == procs2 ); 00942 00943 // compare values on ghost entities 00944 procs1.resize( ghosts.size() ); 00945 procs2.resize( ghosts.size() ); 00946 rval = moab.tag_get_data( sparse_test_tag, ghosts, &procs2[0] );CHKERR( rval ); 00947 std::vector< int >::iterator j = procs1.begin(); 00948 for( i = ghosts.begin(); i != ghosts.end(); ++i, ++j ) 00949 { 00950 rval = pcomm->get_owner( *i, *j );CHKERR( rval ); 00951 } 00952 PCHECK( procs1 == procs2 ); 00953 00954 return MB_SUCCESS; 00955 } 00956 00957 ErrorCode regression_ghost_tag_exchange_no_default( const char* filename ) 00958 { 00959 Core mb_instance; 00960 Interface& moab = mb_instance; 00961 ErrorCode rval; 00962 00963 #ifdef MOAB_HAVE_HDF5 00964 rval = moab.load_file( filename, 0, 00965 "PARALLEL=READ_DELETE;" 00966 "PARTITION=GEOM_DIMENSION;PARTITION_VAL=3;" 00967 "PARTITION_DISTRIBUTE;" 00968 "PARALLEL_RESOLVE_SHARED_ENTS;" 00969 "PARALLEL_GHOSTS=3.2.1" ); 00970 #else 00971 rval = moab.load_file( filename, 0, 00972 "PARALLEL=READ_BCAST;" 00973 "PARTITION=GEOM_DIMENSION;PARTITION_VAL=3;" 00974 "PARTITION_DISTRIBUTE;" 00975 "PARALLEL_RESOLVE_SHARED_ENTS;" 00976 "PARALLEL_GHOSTS=3.2.1" ); 00977 #endif 00978 CHKERR( rval ); 00979 00980 // create a tag to exchange 00981 Tag dense_test_tag; 00982 // rval = moab.tag_get_handle( "TEST-TAG", sizeof(EntityHandle), MB_TAG_DENSE, 00983 // dense_test_tag, 0 ); CHKERR(rval); 00984 rval = moab.tag_get_handle( "TEST-TAG", 1, MB_TYPE_HANDLE, dense_test_tag, MB_TAG_DENSE | MB_TAG_EXCL );CHKERR( rval ); 00985 00986 // exchange tag data 00987 ParallelComm* pcomm = ParallelComm::get_pcomm( &moab, 0 ); 00988 Range tmp_range; 00989 rval = pcomm->exchange_tags( dense_test_tag, tmp_range ); 00990 PCHECK( MB_SUCCESS == rval ); 00991 00992 return MB_SUCCESS; 00993 } 00994 00995 // Helper for exhange_sharing_data 00996 // Swap contens of buffer with specified processor. 00997 int MPI_swap( void* buffer, int num_val, MPI_Datatype val_type, int other_proc ) 00998 { 00999 int err, rank, bytes; 01000 MPI_Comm_rank( MPI_COMM_WORLD, &rank ); 01001 MPI_Type_size( val_type, &bytes ); 01002 bytes *= num_val; 01003 std::vector< unsigned char > buffer2( bytes ); 01004 01005 for( int i = 0; i < 2; ++i ) 01006 { 01007 if( i == ( rank < other_proc ) ) 01008 { 01009 err = MPI_Send( buffer, num_val, val_type, other_proc, 0, MPI_COMM_WORLD ); 01010 if( err ) return err; 01011 } 01012 else 01013 { 01014 MPI_Status status; 01015 err = MPI_Recv( &buffer2[0], num_val, val_type, other_proc, 0, MPI_COMM_WORLD, &status ); 01016 if( err ) return err; 01017 } 01018 } 01019 01020 memcpy( buffer, &buffer2[0], bytes ); 01021 return 0; 01022 } 01023 01024 int valid_ghosting_owners( int comm_size, const int* ids, const int* owners ) 01025 { 01026 // for each vertex ID, build list of {rank,owner} tuples 01027 std::map< int, std::vector< int > > verts; 01028 for( int p = 0; p < comm_size; ++p ) 01029 { 01030 for( int i = 0; i < 9; ++i ) 01031 { // nine verts per proc 01032 int idx = 9 * p + i; 01033 verts[ids[idx]].push_back( p ); 01034 verts[ids[idx]].push_back( owners[idx] ); 01035 } 01036 } 01037 01038 // now check for each vertex that the owner from 01039 // each processor is the same 01040 bool print_desc = true; 01041 int error_count = 0; 01042 std::map< int, std::vector< int > >::iterator it; 01043 for( it = verts.begin(); it != verts.end(); ++it ) 01044 { 01045 int id = it->first; 01046 std::vector< int >& list = it->second; 01047 bool all_same = true; 01048 for( size_t i = 2; i < list.size(); i += 2 ) 01049 if( list[i + 1] != list[1] ) all_same = false; 01050 if( all_same ) continue; 01051 01052 ++error_count; 01053 01054 if( print_desc ) 01055 { 01056 print_desc = false; 01057 std::cerr << "ERROR at " __FILE__ ":" << __LINE__ << std::endl 01058 << " Processors have inconsistant ideas of vertex ownership:" << std::endl; 01059 } 01060 01061 std::cerr << " Vertex " << id << ": " << std::endl; 01062 for( size_t i = 0; i < list.size(); i += 2 ) 01063 std::cerr << " Proc " << list[i] << " thinks owner is " << list[i + 1] << std::endl; 01064 } 01065 01066 return error_count; 01067 } 01068 01069 ErrorCode test_interface_owners_common( int num_ghost_layers ) 01070 { 01071 ErrorCode rval; 01072 Core moab_instance; 01073 Interface& mb = moab_instance; 01074 ParallelComm pcomm( &mb, MPI_COMM_WORLD ); 01075 01076 // build distributed quad mesh 01077 Range quads; 01078 EntityHandle verts[9]; 01079 int ids[9]; 01080 rval = parallel_create_mesh( mb, ids, verts, quads ); 01081 PCHECK( MB_SUCCESS == rval ); 01082 rval = pcomm.resolve_shared_ents( 0, quads, 2, 1 ); 01083 PCHECK( MB_SUCCESS == rval ); 01084 if( num_ghost_layers ) 01085 { 01086 rval = pcomm.exchange_ghost_cells( 2, 0, num_ghost_layers, 0, true ); 01087 PCHECK( MB_SUCCESS == rval ); 01088 } 01089 01090 // get vertex owners 01091 int owner[9]; 01092 for( int i = 0; i < 9; ++i ) 01093 { 01094 rval = pcomm.get_owner( verts[i], owner[i] ); 01095 if( MB_SUCCESS != rval ) break; 01096 } 01097 PCHECK( MB_SUCCESS == rval ); 01098 01099 // exchange vertex owners amongst all processors 01100 int rank, size, ierr; 01101 MPI_Comm_rank( MPI_COMM_WORLD, &rank ); 01102 MPI_Comm_size( MPI_COMM_WORLD, &size ); 01103 std::vector< int > all_ids( 9 * size ), all_owner( 9 * size ); 01104 ierr = MPI_Gather( ids, 9, MPI_INT, &all_ids[0], 9, MPI_INT, 0, MPI_COMM_WORLD ); 01105 if( ierr ) return MB_FAILURE; 01106 ierr = MPI_Gather( owner, 9, MPI_INT, &all_owner[0], 9, MPI_INT, 0, MPI_COMM_WORLD ); 01107 if( ierr ) return MB_FAILURE; 01108 01109 int errors = rank ? 0 : valid_ghosting_owners( size, &all_ids[0], &all_owner[0] ); 01110 MPI_Bcast( &errors, 1, MPI_INT, 0, MPI_COMM_WORLD ); 01111 return errors ? MB_FAILURE : MB_SUCCESS; 01112 } 01113 01114 // Common implementation for both: 01115 // test_interface 01116 // regression_interface_with_ghosting 01117 ErrorCode test_interface_owners( const char* ) 01118 { 01119 return test_interface_owners_common( 0 ); 01120 } 01121 01122 ErrorCode regression_owners_with_ghosting( const char* ) 01123 { 01124 return test_interface_owners_common( 1 ); 01125 } 01126 01127 struct VtxData 01128 { 01129 std::vector< int > procs; 01130 std::vector< int > owners; 01131 std::vector< EntityHandle > handles; 01132 }; 01133 01134 ErrorCode test_ghosted_entity_shared_data( const char* ) 01135 { 01136 ErrorCode rval; 01137 Core moab_instance; 01138 Interface& mb = moab_instance; 01139 ParallelComm pcomm( &mb, MPI_COMM_WORLD ); 01140 01141 int rank, size; 01142 MPI_Comm_rank( MPI_COMM_WORLD, &rank ); 01143 MPI_Comm_size( MPI_COMM_WORLD, &size ); 01144 01145 // build distributed quad mesh 01146 Range quads; 01147 EntityHandle verts[9]; 01148 int ids[9]; 01149 rval = parallel_create_mesh( mb, ids, verts, quads ); 01150 PCHECK( MB_SUCCESS == rval ); 01151 rval = pcomm.resolve_shared_ents( 0, quads, 2, 1 ); 01152 PCHECK( MB_SUCCESS == rval ); 01153 rval = pcomm.exchange_ghost_cells( 2, 1, 1, 0, true ); 01154 PCHECK( MB_SUCCESS == rval ); 01155 01156 rval = pcomm.check_all_shared_handles(); 01157 PCHECK( MB_SUCCESS == rval ); 01158 01159 return MB_SUCCESS; 01160 } 01161 01162 ErrorCode check_consistent_ids( Interface& mb, 01163 const EntityHandle* entities, 01164 const int* orig_ids, 01165 int num_ents, 01166 const char* singular_name, 01167 const char* plural_name ) 01168 { 01169 ErrorCode rval; 01170 int rank, size, ierr; 01171 MPI_Comm_rank( MPI_COMM_WORLD, &rank ); 01172 MPI_Comm_size( MPI_COMM_WORLD, &size ); 01173 01174 Tag id_tag = mb.globalId_tag(); 01175 std::vector< int > new_ids( num_ents ); 01176 rval = mb.tag_get_data( id_tag, entities, num_ents, &new_ids[0] );CHKERR( rval ); 01177 // This test is wrong. a) The caller can select a start ID so there's 01178 // no guarantee that the IDs will be in any specific range and b) There 01179 // is no reason to expect the global number of entities to be num_ents*size 01180 // if there are any shared entities. J.Kraftcheck 2010-12-22 01181 // rval = MB_SUCCESS; 01182 // for (int i = 0; i < num_ents; ++i) 01183 // if (new_ids[i] < 0 || new_ids[i] >= num_ents*size) { 01184 // std::cerr << "ID out of bounds on proc " << rank 01185 // << " : " << new_ids[i] << " not in [0," << num_ents*size-1 01186 // << "]" << std::endl; 01187 // rval = MB_FAILURE; 01188 // } 01189 // if (MB_SUCCESS != rval) 01190 // return rval; 01191 01192 // Gather up all data on root proc for consistency check 01193 std::vector< int > all_orig_ids( num_ents * size ), all_new_ids( num_ents * size ); 01194 ierr = MPI_Gather( (void*)orig_ids, num_ents, MPI_INT, &all_orig_ids[0], num_ents, MPI_INT, 0, MPI_COMM_WORLD ); 01195 if( ierr ) return MB_FAILURE; 01196 ierr = MPI_Gather( &new_ids[0], num_ents, MPI_INT, &all_new_ids[0], num_ents, MPI_INT, 0, MPI_COMM_WORLD ); 01197 if( ierr ) return MB_FAILURE; 01198 01199 // build a local map from original ID to new ID and use it 01200 // to check for consistancy between all procs 01201 rval = MB_SUCCESS; 01202 ; 01203 if( 0 == rank ) 01204 { 01205 // check for two processors having different global ID for same entity 01206 std::map< int, int > idmap; // index by original ID and contains new ID 01207 std::map< int, int > owner; // index by original ID and contains owning rank 01208 for( int i = 0; i < num_ents * size; ++i ) 01209 { 01210 std::map< int, int >::iterator it = idmap.find( all_orig_ids[i] ); 01211 if( it == idmap.end() ) 01212 { 01213 idmap[all_orig_ids[i]] = all_new_ids[i]; 01214 owner[all_orig_ids[i]] = i / num_ents; 01215 } 01216 else if( it->second != all_new_ids[i] ) 01217 { 01218 std::cerr << "Inconsistant " << singular_name << " IDs between processors " << owner[all_orig_ids[i]] 01219 << " and " << i / num_ents << " : " << it->second << " and " << all_new_ids[i] 01220 << " respectively." << std::endl; 01221 rval = MB_FAILURE; 01222 } 01223 } 01224 // check for two processors having same global ID for different entities 01225 idmap.clear(); 01226 owner.clear(); 01227 for( int i = 0; i < num_ents * size; ++i ) 01228 { 01229 std::map< int, int >::iterator it = idmap.find( all_new_ids[i] ); 01230 if( it == idmap.end() ) 01231 { 01232 idmap[all_new_ids[i]] = all_orig_ids[i]; 01233 owner[all_new_ids[i]] = i / num_ents; 01234 } 01235 else if( it->second != all_orig_ids[i] ) 01236 { 01237 std::cerr << "ID " << all_new_ids[i] << " assigned to different " << plural_name << " on processors " 01238 << owner[all_new_ids[i]] << " and " << i / num_ents << std::endl; 01239 rval = MB_FAILURE; 01240 } 01241 } 01242 } 01243 return rval; 01244 } 01245 01246 ErrorCode test_assign_global_ids( const char* ) 01247 { 01248 ErrorCode rval; 01249 Core moab_instance; 01250 Interface& mb = moab_instance; 01251 ParallelComm pcomm( &mb, MPI_COMM_WORLD ); 01252 01253 int rank, size; 01254 MPI_Comm_rank( MPI_COMM_WORLD, &rank ); 01255 MPI_Comm_size( MPI_COMM_WORLD, &size ); 01256 01257 // build distributed quad mesh 01258 Range quad_range; 01259 EntityHandle verts[9]; 01260 int vert_ids[9]; 01261 rval = parallel_create_mesh( mb, vert_ids, verts, quad_range ); 01262 PCHECK( MB_SUCCESS == rval ); 01263 rval = pcomm.resolve_shared_ents( 0, quad_range, 2, 1 ); 01264 PCHECK( MB_SUCCESS == rval ); 01265 01266 // get global ids for quads 01267 Tag id_tag = mb.globalId_tag(); 01268 assert( 4u == quad_range.size() ); 01269 EntityHandle quads[4]; 01270 std::copy( quad_range.begin(), quad_range.end(), quads ); 01271 int quad_ids[4]; 01272 rval = mb.tag_get_data( id_tag, quads, 4, quad_ids );CHKERR( rval ); 01273 01274 // clear GLOBAL_ID tag 01275 int zero[9] = { 0 }; 01276 rval = mb.tag_set_data( id_tag, verts, 9, zero );CHKERR( rval ); 01277 rval = mb.tag_set_data( id_tag, quads, 4, zero );CHKERR( rval ); 01278 01279 // assign new global IDs 01280 rval = pcomm.assign_global_ids( 0, 2 ); 01281 PCHECK( MB_SUCCESS == rval ); 01282 01283 rval = check_consistent_ids( mb, verts, vert_ids, 9, "vertex", "vertices" ); 01284 PCHECK( MB_SUCCESS == rval ); 01285 rval = check_consistent_ids( mb, quads, quad_ids, 4, "quad", "quads" ); 01286 PCHECK( MB_SUCCESS == rval ); 01287 return rval; 01288 } 01289 01290 ErrorCode test_shared_sets( const char* ) 01291 { 01292 ErrorCode rval; 01293 Core moab_instance; 01294 Interface& mb = moab_instance; 01295 ParallelComm pcomm( &mb, MPI_COMM_WORLD ); 01296 01297 int rank_i, size_i; 01298 MPI_Comm_rank( MPI_COMM_WORLD, &rank_i ); 01299 MPI_Comm_size( MPI_COMM_WORLD, &size_i ); 01300 const unsigned rank = rank_i; 01301 const unsigned nproc = size_i; 01302 01303 // build distributed quad mesh 01304 Range quads, sets; 01305 EntityHandle verts[9], set_arr[3]; 01306 int ids[9]; 01307 rval = parallel_create_mesh( mb, ids, verts, quads, set_arr ); 01308 PCHECK( MB_SUCCESS == rval ); 01309 rval = pcomm.resolve_shared_ents( 0, quads, 2, 1 ); 01310 PCHECK( MB_SUCCESS == rval ); 01311 sets.insert( set_arr[0] ); 01312 sets.insert( set_arr[1] ); 01313 if( set_arr[2] ) 01314 { 01315 sets.insert( set_arr[2] ); 01316 } 01317 else 01318 { 01319 set_arr[2] = set_arr[1]; 01320 } 01321 01322 Tag id_tag = mb.globalId_tag(); 01323 rval = pcomm.resolve_shared_sets( sets, id_tag ); 01324 PCHECK( MB_SUCCESS == rval ); 01325 01326 // check that set data is consistent 01327 ErrorCode ok = MB_SUCCESS; 01328 for( size_t i = 0; i < 3; ++i ) 01329 { 01330 unsigned owner; 01331 EntityHandle owner_handle, local; 01332 rval = pcomm.get_entityset_owner( set_arr[i], owner, &owner_handle ); 01333 if( MB_SUCCESS != rval ) 01334 ok = rval; 01335 else if( owner == rank ) 01336 { 01337 if( owner_handle != set_arr[i] ) 01338 { 01339 std::cerr << __FILE__ << ":" << __LINE__ << " rank " << rank << "invalid remote handle for owned set" 01340 << std::endl; 01341 ok = MB_FAILURE; 01342 } 01343 } 01344 else if( MB_SUCCESS != pcomm.get_entityset_local_handle( owner, owner_handle, local ) ) 01345 ok = MB_FAILURE; 01346 else if( local != set_arr[i] ) 01347 { 01348 std::cerr << __FILE__ << ":" << __LINE__ << " rank " << rank << "invalid local handle for remote data" 01349 << std::endl; 01350 ok = MB_FAILURE; 01351 } 01352 } 01353 PCHECK( MB_SUCCESS == ok ); 01354 01355 const unsigned col = rank / 2; // which column is proc in 01356 const unsigned colrank = 01357 2 * col; // rank of first of two procs in col (rank if rank is even, rank-1 if rank is odd) 01358 unsigned mins[3] = { 0, 0, 0 }; 01359 unsigned maxs[3] = { nproc - 1, 0, 0 }; 01360 if( rank < 2 ) 01361 { // if in first (left-most) column, then 01362 mins[1] = mins[2] = 0; 01363 maxs[1] = maxs[2] = std::min( 3u, nproc - 1 ); 01364 } 01365 else if( col == ( nproc - 1 ) / 2 ) 01366 { // else if last (right-most) column, then 01367 mins[1] = mins[2] = colrank - 2; 01368 maxs[1] = maxs[2] = std::min( colrank + 1, nproc - 1 ); 01369 } 01370 else 01371 { // if inside column, then 01372 mins[1] = colrank - 2; 01373 mins[2] = colrank; 01374 maxs[1] = std::min( colrank + 1, nproc - 1 ); 01375 maxs[2] = std::min( colrank + 3, nproc - 1 ); 01376 } 01377 01378 // check expected sharing lists 01379 // set 0 is shared between all procs in the range [ mins[0], maxs[0] ] 01380 std::vector< unsigned > expected, list; 01381 for( size_t i = 0; i < 3; ++i ) 01382 { 01383 expected.clear(); 01384 for( unsigned r = mins[i]; r <= std::min( maxs[i], nproc - 1 ); ++r ) 01385 if( r != rank ) expected.push_back( r ); 01386 list.clear(); 01387 rval = pcomm.get_entityset_procs( set_arr[i], list ); 01388 if( MB_SUCCESS != rval ) 01389 ok = rval; 01390 else 01391 { 01392 std::sort( list.begin(), list.end() ); 01393 if( expected != list ) 01394 { 01395 std::cerr << __FILE__ << ":" << __LINE__ << " rank " << rank << " incorrect sharing list for entity set" 01396 << std::endl; 01397 ok = MB_FAILURE; 01398 } 01399 } 01400 } 01401 PCHECK( MB_SUCCESS == ok ); 01402 01403 // check consistent owners 01404 unsigned send_list[6], set_owners[3]; 01405 std::vector< unsigned > recv_list( 6 * nproc ); 01406 for( size_t i = 0; i < 3; ++i ) 01407 { 01408 mb.tag_get_data( id_tag, set_arr + i, 1, &send_list[2 * i] ); 01409 pcomm.get_entityset_owner( set_arr[i], set_owners[i] ); 01410 send_list[2 * i + 1] = set_owners[i]; 01411 } 01412 MPI_Allgather( send_list, 6, MPI_UNSIGNED, &recv_list[0], 6, MPI_UNSIGNED, MPI_COMM_WORLD ); 01413 std::map< unsigned, unsigned > owners; 01414 for( unsigned i = 0; i < 6 * nproc; i += 2 ) 01415 { 01416 unsigned id = recv_list[i]; 01417 unsigned owner = recv_list[i + 1]; 01418 if( owners.find( id ) == owners.end() ) 01419 owners[id] = owner; 01420 else if( owners[id] != owner ) 01421 { 01422 std::cerr << __FILE__ << ":" << __LINE__ << " rank " << rank << " mismatched owners (" << owners[id] 01423 << " and " << owner << ") for set with ID " << id << std::endl; 01424 ok = MB_FAILURE; 01425 } 01426 } 01427 PCHECK( MB_SUCCESS == ok ); 01428 01429 // test PComm::get_entityset_owners 01430 std::vector< unsigned > act_owners, exp_owners; 01431 for( size_t i = 0; i < 3; ++i ) 01432 { 01433 exp_owners.push_back( set_owners[i] ); 01434 } 01435 ok = pcomm.get_entityset_owners( act_owners ); 01436 PCHECK( MB_SUCCESS == ok ); 01437 // PCHECK(std::find(act_owners.begin(),act_owners.end(),rank) == act_owners.end()); 01438 std::sort( act_owners.begin(), act_owners.end() ); 01439 std::sort( exp_owners.begin(), exp_owners.end() ); 01440 exp_owners.erase( std::unique( exp_owners.begin(), exp_owners.end() ), exp_owners.end() ); 01441 PCHECK( exp_owners == act_owners ); 01442 01443 // test PComm::get_owned_sets 01444 ok = MB_SUCCESS; 01445 for( unsigned i = 0; i < nproc; ++i ) 01446 { 01447 sets.clear(); 01448 if( MB_SUCCESS != pcomm.get_owned_sets( i, sets ) ) 01449 { 01450 std::cerr << __FILE__ << ":" << __LINE__ << " rank " << rank 01451 << " failed to get shared set list for sets owned by rank " << set_owners[i] << std::endl; 01452 continue; 01453 } 01454 01455 Range expected_range; 01456 for( size_t j = 0; j < 3; ++j ) 01457 if( set_owners[j] == i ) expected_range.insert( set_arr[j] ); 01458 01459 if( expected_range != sets ) 01460 { 01461 std::cerr << __FILE__ << ":" << __LINE__ << " rank " << rank 01462 << " has incorrect shared set list for sets owned by rank " << set_owners[i] << std::endl 01463 << "Expected: " << expected_range << std::endl 01464 << "Actual: " << sets << std::endl; 01465 ok = MB_FAILURE; 01466 } 01467 } 01468 PCHECK( MB_SUCCESS == ok ); 01469 01470 return MB_SUCCESS; 01471 } 01472 01473 template < typename T > 01474 ErrorCode check_shared_ents( ParallelComm& pcomm, Tag tagh, T fact, MPI_Op mpi_op ) 01475 { 01476 // get the shared entities 01477 Range shared_ents; 01478 ErrorCode rval = pcomm.get_shared_entities( -1, shared_ents );CHKERR( rval ); 01479 01480 std::vector< int > shprocs( MAX_SHARING_PROCS ); 01481 std::vector< EntityHandle > shhandles( MAX_SHARING_PROCS ); 01482 std::vector< T > dum_vals( shared_ents.size() ); 01483 int np; 01484 unsigned char pstatus; 01485 01486 rval = pcomm.get_moab()->tag_get_data( tagh, shared_ents, &dum_vals[0] );CHKERR( rval ); 01487 01488 // for each, compare number of sharing procs against tag value, should be 1/fact the tag value 01489 Range::iterator rit; 01490 int i = 0; 01491 for( rit = shared_ents.begin(); rit != shared_ents.end(); ++rit, i++ ) 01492 { 01493 rval = pcomm.get_sharing_data( *rit, &shprocs[0], &shhandles[0], pstatus, np );CHKERR( rval ); 01494 if( 1 == np && shprocs[0] != (int)pcomm.proc_config().proc_rank() ) np++; 01495 bool with_root = std::find( &shprocs[0], &shprocs[np], 0 ) - &shprocs[0] != np || !pcomm.rank(); 01496 if( mpi_op == MPI_SUM ) 01497 { 01498 if( dum_vals[i] != fact * np ) return MB_FAILURE; 01499 } 01500 else if( mpi_op == MPI_PROD ) 01501 { 01502 if( dum_vals[i] != pow( fact, np ) ) return MB_FAILURE; 01503 } 01504 else if( mpi_op == MPI_MAX ) 01505 { 01506 if( with_root && dum_vals[i] != fact ) return MB_FAILURE; 01507 } 01508 else if( mpi_op == MPI_MIN ) 01509 { 01510 if( with_root && dum_vals[i] != fact ) return MB_FAILURE; 01511 } 01512 else 01513 return MB_FAILURE; 01514 } 01515 01516 return MB_SUCCESS; 01517 } 01518 01519 template < typename T > 01520 ErrorCode test_reduce_tags( const char*, DataType tp ) 01521 { 01522 ErrorCode rval; 01523 Core moab_instance; 01524 Interface& mb = moab_instance; 01525 ParallelComm pcomm( &mb, MPI_COMM_WORLD ); 01526 01527 int rank, size; 01528 MPI_Comm_rank( MPI_COMM_WORLD, &rank ); 01529 MPI_Comm_size( MPI_COMM_WORLD, &size ); 01530 01531 // build distributed quad mesh 01532 Range quad_range; 01533 EntityHandle verts[9]; 01534 int vert_ids[9]; 01535 rval = parallel_create_mesh( mb, vert_ids, verts, quad_range ); 01536 PCHECK( MB_SUCCESS == rval ); 01537 rval = pcomm.resolve_shared_ents( 0, quad_range, 2, 1 ); 01538 PCHECK( MB_SUCCESS == rval ); 01539 01540 Tag test_tag; 01541 T def_val = 2; 01542 Range dum_range; 01543 std::vector< T > dum_vals; 01544 01545 // T, MPI_SUM 01546 rval = mb.tag_get_handle( "test_tag", 1, tp, test_tag, MB_TAG_DENSE | MB_TAG_CREAT, &def_val );CHKERR( rval ); 01547 rval = pcomm.reduce_tags( test_tag, MPI_SUM, dum_range );CHKERR( rval ); 01548 rval = check_shared_ents( pcomm, test_tag, (T)2, MPI_SUM );CHKERR( rval ); 01549 rval = mb.tag_delete( test_tag ); 01550 01551 // T, MPI_PROD 01552 rval = mb.tag_get_handle( "test_tag", 1, tp, test_tag, MB_TAG_DENSE | MB_TAG_CREAT, &def_val );CHKERR( rval ); 01553 rval = pcomm.reduce_tags( test_tag, MPI_PROD, dum_range );CHKERR( rval ); 01554 rval = check_shared_ents( pcomm, test_tag, (T)2, MPI_PROD );CHKERR( rval ); 01555 rval = mb.tag_delete( test_tag ); 01556 01557 // T, MPI_MAX 01558 rval = mb.tag_get_handle( "test_tag", 1, tp, test_tag, MB_TAG_DENSE | MB_TAG_CREAT, &def_val );CHKERR( rval ); 01559 // get owned entities and set a different value on them 01560 rval = pcomm.get_shared_entities( -1, dum_range, -1, false, false );CHKERR( rval ); 01561 if( pcomm.rank() == 0 ) 01562 { 01563 dum_vals.resize( dum_range.size(), (T)3 ); 01564 rval = mb.tag_set_data( test_tag, dum_range, &dum_vals[0] );CHKERR( rval ); 01565 } 01566 rval = pcomm.reduce_tags( test_tag, MPI_MAX, dum_range );CHKERR( rval ); 01567 rval = check_shared_ents( pcomm, test_tag, (T)3, MPI_MAX );CHKERR( rval ); 01568 rval = mb.tag_delete( test_tag ); 01569 01570 // T, MPI_MIN 01571 rval = mb.tag_get_handle( "test_tag", 1, tp, test_tag, MB_TAG_DENSE | MB_TAG_CREAT, &def_val );CHKERR( rval ); 01572 // get owned entities and set a different value on them 01573 if( pcomm.rank() == 0 ) 01574 { 01575 std::fill( dum_vals.begin(), dum_vals.end(), (T)-1 ); 01576 rval = mb.tag_set_data( test_tag, dum_range, &dum_vals[0] );CHKERR( rval ); 01577 } 01578 rval = pcomm.reduce_tags( test_tag, MPI_MIN, dum_range );CHKERR( rval ); 01579 rval = check_shared_ents( pcomm, test_tag, (T)-1, MPI_MIN );CHKERR( rval ); 01580 rval = mb.tag_delete( test_tag ); 01581 01582 return MB_SUCCESS; 01583 } 01584 01585 ErrorCode test_reduce_tag_failures( const char* ) 01586 { 01587 // test things that should fail 01588 ErrorCode rval; 01589 Core moab_instance; 01590 Interface& mb = moab_instance; 01591 ParallelComm pcomm( &mb, MPI_COMM_WORLD ); 01592 01593 int rank, size; 01594 MPI_Comm_rank( MPI_COMM_WORLD, &rank ); 01595 MPI_Comm_size( MPI_COMM_WORLD, &size ); 01596 01597 // build distributed quad mesh 01598 Range quad_range; 01599 EntityHandle verts[9]; 01600 int vert_ids[9]; 01601 rval = parallel_create_mesh( mb, vert_ids, verts, quad_range ); 01602 PCHECK( MB_SUCCESS == rval ); 01603 rval = pcomm.resolve_shared_ents( 0, quad_range, 2, 1 ); 01604 PCHECK( MB_SUCCESS == rval ); 01605 01606 Tag test_tag; 01607 Range dum_range; 01608 int def_int; 01609 double def_dbl; 01610 01611 // explicit destination tag of different type 01612 Tag test_dest; 01613 std::vector< Tag > src_tags, dest_tags; 01614 rval = mb.tag_get_handle( "test_tag", 1, MB_TYPE_INTEGER, test_tag, MB_TAG_DENSE | MB_TAG_CREAT, &def_int );CHKERR( rval ); 01615 src_tags.push_back( test_tag ); 01616 rval = mb.tag_get_handle( "dtest_tag", 1, MB_TYPE_DOUBLE, test_dest, MB_TAG_DENSE | MB_TAG_CREAT, &def_dbl );CHKERR( rval ); 01617 dest_tags.push_back( test_dest ); 01618 rval = pcomm.reduce_tags( src_tags, dest_tags, MPI_MIN, dum_range ); 01619 PCHECK( rval == MB_FAILURE ); 01620 rval = mb.tag_delete( test_dest );CHKERR( rval ); 01621 rval = mb.tag_delete( test_tag );CHKERR( rval ); 01622 01623 // tag w/ no default value 01624 rval = mb.tag_get_handle( "test_tag", 1, MB_TYPE_INTEGER, test_tag, MB_TAG_DENSE | MB_TAG_CREAT );CHKERR( rval ); 01625 rval = pcomm.reduce_tags( test_tag, MPI_MIN, dum_range ); 01626 PCHECK( rval == MB_ENTITY_NOT_FOUND ); 01627 rval = mb.tag_delete( test_tag ); 01628 01629 return MB_SUCCESS; 01630 } 01631 01632 ErrorCode test_reduce_tags( const char* ) 01633 { 01634 ErrorCode rval = MB_SUCCESS, tmp_rval; 01635 01636 tmp_rval = test_reduce_tags< int >( "test_reduce_tags (int)", MB_TYPE_INTEGER ); 01637 if( MB_SUCCESS != tmp_rval ) 01638 { 01639 std::cout << "test_reduce_tags failed for int data type." << std::endl; 01640 rval = tmp_rval; 01641 } 01642 01643 tmp_rval = test_reduce_tags< double >( "test_reduce_tags (dbl)", MB_TYPE_DOUBLE ); 01644 if( MB_SUCCESS != tmp_rval ) 01645 { 01646 std::cout << "test_reduce_tags failed for double data type." << std::endl; 01647 rval = tmp_rval; 01648 } 01649 01650 return rval; 01651 } 01652 01653 ErrorCode test_reduce_tag_explicit_dest( const char* ) 01654 { 01655 // test tag_reduce stuff with explicit destination tag 01656 ErrorCode rval; 01657 Core moab_instance; 01658 Interface& mb = moab_instance; 01659 ParallelComm pcomm( &mb, MPI_COMM_WORLD ); 01660 01661 int rank, size; 01662 MPI_Comm_rank( MPI_COMM_WORLD, &rank ); 01663 MPI_Comm_size( MPI_COMM_WORLD, &size ); 01664 01665 // build distributed quad mesh 01666 Range quad_range; 01667 EntityHandle verts[9]; 01668 int vert_ids[9]; 01669 rval = parallel_create_mesh( mb, vert_ids, verts, quad_range ); 01670 PCHECK( MB_SUCCESS == rval ); 01671 rval = pcomm.resolve_shared_ents( 0, quad_range, 2, 1 ); 01672 PCHECK( MB_SUCCESS == rval ); 01673 01674 Tag src_tag, dest_tag; 01675 Range dum_range; 01676 double def_dbl = 5.0; 01677 01678 // src tag has one value, pre-existing dest tag has another; should get MPI_Op of src values 01679 std::vector< Tag > src_tags, dest_tags; 01680 // create the tags 01681 rval = mb.tag_get_handle( "src_tag", 1, MB_TYPE_DOUBLE, src_tag, MB_TAG_DENSE | MB_TAG_CREAT, &def_dbl );CHKERR( rval ); 01682 src_tags.push_back( src_tag ); 01683 rval = mb.tag_get_handle( "dest_tag", 1, MB_TYPE_DOUBLE, dest_tag, MB_TAG_DENSE | MB_TAG_CREAT, &def_dbl );CHKERR( rval ); 01684 dest_tags.push_back( dest_tag ); 01685 // set values for src tag to one value, dest tag to another 01686 rval = pcomm.get_shared_entities( -1, dum_range, -1, false, false );CHKERR( rval ); 01687 std::vector< double > tag_vals( dum_range.size(), 1.0 ); 01688 rval = mb.tag_set_data( src_tag, dum_range, &tag_vals[0] );CHKERR( rval ); 01689 std::fill( tag_vals.begin(), tag_vals.end(), 2.0 ); 01690 rval = mb.tag_set_data( dest_tag, dum_range, &tag_vals[0] );CHKERR( rval ); 01691 // do the reduce 01692 rval = pcomm.reduce_tags( src_tags, dest_tags, MPI_SUM, dum_range );CHKERR( rval ); 01693 // check the reduced value 01694 rval = check_shared_ents< double >( pcomm, dest_tag, (double)1.0, MPI_SUM );CHKERR( rval ); 01695 01696 rval = mb.tag_delete( src_tag );CHKERR( rval ); 01697 rval = mb.tag_delete( dest_tag );CHKERR( rval ); 01698 01699 return MB_SUCCESS; 01700 } 01701 01702 ErrorCode test_delete_entities( const char* filename ) 01703 { 01704 Core mb_instance; 01705 Interface& moab = mb_instance; 01706 ErrorCode rval; 01707 01708 rval = moab.load_file( filename, 0, 01709 "PARALLEL=READ_PART;" 01710 "PARTITION=PARALLEL_PARTITION;" 01711 "PARALLEL_RESOLVE_SHARED_ENTS" );CHKERR( rval ); 01712 01713 // Get ghost elements 01714 ParallelComm* pcomm = ParallelComm::get_pcomm( &moab, 0 ); 01715 // get some edges and faces, and delete some 01716 Range local; 01717 rval = moab.get_entities_by_dimension( 0, 1, local );CHKERR( rval ); 01718 rval = moab.get_entities_by_dimension( 0, 2, local );CHKERR( rval ); // it is appending to range 01719 01720 Range local2; // extract about half of those 01721 std::copy( local.begin(), local.begin() + local.size() / 2, range_inserter( local2 ) ); 01722 01723 // delete local 2 01724 rval = pcomm->delete_entities( local2 );CHKERR( rval ); 01725 01726 for( Range::iterator it = local2.begin(); it != local2.end(); ++it ) 01727 { 01728 if( mb_instance.is_valid( *it ) ) return MB_FAILURE; 01729 } 01730 const char* opt = "PARALLEL=WRITE_PART"; 01731 rval = moab.write_file( "tmpx.h5m", 0, opt );CHKERR( rval ); 01732 if( pcomm->proc_config().proc_rank() == 0 ) remove( "tmpx.h5m" ); 01733 01734 return MB_SUCCESS; 01735 } 01736 01737 ErrorCode test_ghost_polyhedra( const char* filename ) 01738 { 01739 Core mb_instance; 01740 Interface& moab = mb_instance; 01741 ErrorCode rval; 01742 01743 rval = moab.load_file( filename, 0, 01744 "PARALLEL=READ_PART;" 01745 "PARTITION=PARALLEL_PARTITION;" 01746 "PARALLEL_RESOLVE_SHARED_ENTS;" 01747 "PARALLEL_GHOSTS=3.0.1" );CHKERR( rval ); 01748 01749 return MB_SUCCESS; 01750 } 01751 ErrorCode test_too_few_parts( const char* filename ) 01752 { 01753 Core mb_instance; 01754 Interface& moab = mb_instance; 01755 ErrorCode rval; 01756 01757 rval = moab.load_file( filename, 0, 01758 "PARALLEL=READ_PART;" 01759 "PARTITION=PARALLEL_PARTITION;" 01760 "PARALLEL_RESOLVE_SHARED_ENTS;" ); 01761 // if(rval==MB_SUCCESS) 01762 // return MB_FAILURE; 01763 01764 return rval; 01765 } 01766 01767 ErrorCode test_sequences_after_ghosting( const char* filename ) 01768 { 01769 Core mb_instance; 01770 Interface& moab = mb_instance; 01771 ErrorCode rval; 01772 01773 rval = moab.load_file( filename, 0, 01774 "PARALLEL=READ_PART;" 01775 "PARTITION=PARALLEL_PARTITION;" 01776 "PARALLEL_RESOLVE_SHARED_ENTS;" 01777 "PARALLEL_GHOSTS=3.2.1;" 01778 "PARALLEL_SEQUENCE_FACTOR=1.5" );CHKERR( rval ); 01779 01780 // get all elements of dimension 3, and check they are on one sequence, with connect_iterate 01781 Range elems; 01782 rval = moab.get_entities_by_dimension( 0, 3, elems );CHKERR( rval ); 01783 if( elems.psize() != 1 ) 01784 { 01785 std::cout << " elems.psize() = " << elems.psize() << "\n"; 01786 return MB_FAILURE; 01787 } 01788 // we want only one sequence 01789 int count, vpere; 01790 EntityHandle* conn_ptr; 01791 rval = moab.connect_iterate( elems.begin(), elems.end(), conn_ptr, vpere, count );CHKERR( rval ); 01792 01793 if( count != (int)elems.size() ) 01794 { 01795 std::cout << " more than one sequence: elems.size() = " << elems.size() << " count:" << count << "\n"; 01796 return MB_FAILURE; 01797 } 01798 // check also global id tag, which is dense 01799 Tag id_tag = moab.globalId_tag(); 01800 void* globalid_data = NULL; 01801 rval = moab.tag_iterate( id_tag, elems.begin(), elems.end(), count, globalid_data );CHKERR( rval ); 01802 if( count != (int)elems.size() ) 01803 { 01804 std::cout << " more than one tag sequence: elems.size() = " << elems.size() << " count:" << count << "\n"; 01805 return MB_FAILURE; 01806 } 01807 01808 // repeat the tests for vertex sequences 01809 // get all elements of dimension 3, and check they are on one sequence, with coords_iterate 01810 Range verts; 01811 rval = moab.get_entities_by_dimension( 0, 0, verts );CHKERR( rval ); 01812 if( verts.psize() != 1 ) 01813 { 01814 std::cout << " verts.psize() = " << verts.psize() << "\n"; 01815 return MB_FAILURE; 01816 } 01817 // 01818 double *x_ptr, *y_ptr, *z_ptr; 01819 rval = moab.coords_iterate( verts.begin(), verts.end(), x_ptr, y_ptr, z_ptr, count );CHKERR( rval ); 01820 01821 if( count != (int)verts.size() ) 01822 { 01823 std::cout << " more than one sequence: verts.size() = " << verts.size() << " count:" << count << "\n"; 01824 return MB_FAILURE; 01825 } 01826 01827 rval = moab.tag_iterate( id_tag, verts.begin(), verts.end(), count, globalid_data );CHKERR( rval ); 01828 if( count != (int)verts.size() ) 01829 { 01830 std::cout << " more than one tag sequence: verts.size() = " << verts.size() << " count:" << count << "\n"; 01831 return MB_FAILURE; 01832 } 01833 return MB_SUCCESS; 01834 } 01835 01836 // test trivial partition as used by iMOAB send/receive mesh methods 01837 // it is hooked to ParCommGraph, but it is really not dependent on anything from MOAB 01838 // these methods that are tested are just utilities 01839 01840 void test_trivial_partition() 01841 { 01842 // nothing is modified inside moab 01843 // by these methods; 01844 // to instantiate par com graph, we just need 2 groups! 01845 // they can be overlapping !!!! we do not test that yet 01846 01847 // create 2 groups; one over task 0 and 1, one over 2 01848 MPI_Group worldg; 01849 MPI_Comm duplicate; 01850 MPI_Comm_dup( MPI_COMM_WORLD, &duplicate ); 01851 MPI_Comm_group( duplicate, &worldg ); 01852 01853 // this is usually run on 2 processes 01854 01855 int rank[2] = { 0, 1 }; 01856 MPI_Group gr1, gr2; 01857 MPI_Group_incl( worldg, 2, rank, &gr1 ); // will contain 2 ranks, 0 and 1 01858 MPI_Group_incl( worldg, 1, &rank[1], &gr2 ); // will contain 1 rank only (1) 01859 01860 int comp1 = 10, comp2 = 12; 01861 ParCommGraph* pgr = new ParCommGraph( duplicate, gr1, gr2, comp1, comp2 ); 01862 01863 std::map< int, Range > ranges_to_send; 01864 std::vector< int > number_elems_per_part; 01865 number_elems_per_part.push_back( 6 ); 01866 number_elems_per_part.push_back( 10 ); 01867 01868 std::cout << " send sizes "; 01869 for( int k = 0; k < (int)number_elems_per_part.size(); k++ ) 01870 { 01871 std::cout << " " << number_elems_per_part[k]; 01872 } 01873 std::cout << "\n"; 01874 01875 std::cout << "\n"; 01876 pgr->compute_trivial_partition( number_elems_per_part ); 01877 01878 Range verts( 10, 20 ); 01879 pgr->split_owned_range( 0, verts ); 01880 01881 for( std::map< int, Range >::iterator it = ranges_to_send.begin(); it != ranges_to_send.end(); it++ ) 01882 { 01883 Range& ran = it->second; 01884 std::cout << " receiver " << it->first << " receive range: [" << ran[0] << ", " << ran[ran.size() - 1] 01885 << "] \n"; 01886 } 01887 01888 delete( pgr ); 01889 01890 MPI_Group_free( &worldg ); 01891 MPI_Group_free( &gr1 ); 01892 MPI_Group_free( &gr2 ); 01893 MPI_Comm_free( &duplicate ); 01894 }
