read_cgm_group_test.cpp File Reference
#include <iostream>
#include "moab/Interface.hpp"
#include "TestUtil.hpp"
#include "Internals.hpp"
#include "moab/Core.hpp"
#include "MBTagConventions.hpp"
#include "InitCGMA.hpp"
#include "GeometryQueryTool.hpp"
+ Include dependency graph for read_cgm_group_test.cpp:
Defines
#define IS_BUILDING_MB
#define CHKERR(A)
Functions
void read_file (Interface *moab, const char *input_file)
int geom_id_by_handle (Interface *moab, const EntityHandle set)
void check_group_data (std::vector< int > &group_ids, std::vector< std::string > &group_names, std::vector< int > &group_ent_ids)
void load_group_references (std::vector< int > &ids, std::vector< std::string > &names, std::vector< int > &ent_ids)
void read_cylcube_groups_test ()
int main (int, char **)
Variables
std::string input_cylcube = "unittest/io/cylcube.sat"
Define Documentation
#define CHKERR (   A)
Value:
do        \
        if( MB_SUCCESS != ( A ) )        \
            std::cerr << "Failure (error code " << ( A ) << ") at " __FILE__ ":" << __LINE__ << std::endl; \
            return A;        \
    } while( false )
Definition at line 15 of file read_cgm_group_test.cpp.
Definition at line 4 of file read_cgm_group_test.cpp.
Function Documentation
void check_group_data ( std::vector< int > &  group_ids,
std::vector< std::string > &  group_names,
std::vector< int > &  group_ent_ids
Definition at line 122 of file read_cgm_group_test.cpp.
References CHECK_EQUAL, and load_group_references().
Referenced by read_cylcube_groups_test().
    // Step files do not contain group data, MOAB shouldn't return errors when trying to access
    // this data but there shouldn't be any found.
#ifdef HAVE_OCC_STEP
    int num_g_ids   = group_ids.size();
    int num_g_names = group_names.size();
    CHECK_EQUAL( 0, num_g_ids );
    CHECK_EQUAL( 0, num_g_names );
#else
    // Initialize reference data
    std::vector< int > group_ref_ids;
    std::vector< std::string > group_ref_names;
    std::vector< int > group_ref_ent_ids;
    load_group_references( group_ref_ids, group_ref_names, group_ref_ent_ids );
    // check that the correct number of entities were found
    CHECK_EQUAL( group_ref_ids.size(), group_ids.size() );
    CHECK_EQUAL( group_ref_names.size(), group_names.size() );
    CHECK_EQUAL( group_ref_ent_ids.size(), group_ent_ids.size() );
    // now make sure that each group has a matching group
    for( unsigned int i = 0; i < group_ids.size(); i++ )
        for( unsigned int j = 0; j < group_ref_ids.size(); j++ )
            if( group_ids[i] == group_ref_ids[j] && group_names[i] == group_ref_names[j] &&
                group_ent_ids[i] == group_ref_ent_ids[j] )
                group_ref_ids.erase( group_ref_ids.begin() + j );
                group_ref_names.erase( group_ref_names.begin() + j );
                group_ref_ent_ids.erase( group_ref_ent_ids.begin() + j );
                continue;
    // Check sizes of reference vectors after matching
    // (all should be zero)
    int leftovers = group_ref_ids.size();
    CHECK_EQUAL( 0, leftovers );
    leftovers = group_ref_names.size();
    leftovers = group_ref_ent_ids.size();
#endif
int geom_id_by_handle ( Interface *  moab,
Definition at line 191 of file read_cgm_group_test.cpp.
References CHECK_ERR, ErrorCode, moab::Interface::globalId_tag(), id_tag, and moab::Interface::tag_get_data().
Referenced by check_sense_data(), load_precgm14_stp_curve_sense_data(), load_precgm14_stp_surf_sense_data(), load_sat_curve_sense_data(), load_sat_surf_sense_data(), load_stp_curve_sense_data(), load_stp_surf_sense_data(), and read_cylcube_groups_test().
    ErrorCode rval;
    // Get the id_tag handle
    Tag id_tag = moab->globalId_tag();
    // Load the ID for the EntHandle given to the function
    int id;
    rval = moab->tag_get_data( id_tag, &set, 1, &id );CHECK_ERR( rval );
    return id;
void load_group_references ( std::vector< int > &  ids,
std::vector< std::string > &  names,
std::vector< int > &  ent_ids
Definition at line 178 of file read_cgm_group_test.cpp.
Referenced by check_group_data().
    // First set of group info
    names.push_back( "Group 3" );
    ids.push_back( 3 );
    ent_ids.push_back( 2 );
    // Second set of group info
    names.push_back( "Group 2" );
    ids.push_back( 2 );
    ent_ids.push_back( 1 );
int main ( int  ,
char **
Definition at line 52 of file read_cgm_group_test.cpp.
References read_cylcube_groups_test(), and RUN_TEST.
    int result = 0;
    result += RUN_TEST( read_cylcube_groups_test );
    return result;
Definition at line 73 of file read_cgm_group_test.cpp.
References moab::Range::begin(), category_tag, CATEGORY_TAG_NAME, CATEGORY_TAG_SIZE, CHECK, CHECK_ERR, check_group_data(), moab::Range::end(), ErrorCode, geom_id_by_handle(), moab::Interface::get_entities_by_type(), moab::Interface::get_entities_by_type_and_tag(), input_cylcube, mb, MB_TAG_CREAT, MB_TAG_SPARSE, MB_TYPE_OPAQUE, MBENTITYSET, name_tag, NAME_TAG_NAME, NAME_TAG_SIZE, read_file(), moab::Range::size(), moab::Interface::tag_get_data(), and moab::Interface::tag_get_handle().
Referenced by main().
    ErrorCode rval;
    // Open the test file
    Core moab;
    Interface* mb = &moab;
    read_file( mb, input_cylcube.c_str() );
    // Get (or create) the name and category tags
    Tag name_tag, category_tag;
    rval = mb->tag_get_handle( NAME_TAG_NAME, NAME_TAG_SIZE, MB_TYPE_OPAQUE, name_tag,
                               moab::MB_TAG_SPARSE | moab::MB_TAG_CREAT );CHECK_ERR( rval );
    rval = mb->tag_get_handle( CATEGORY_TAG_NAME, CATEGORY_TAG_SIZE, MB_TYPE_OPAQUE, category_tag,
    // Get the group entity handles
    Range group_sets;
    char query[CATEGORY_TAG_SIZE] = "Group\0";
    // Has to be this way because of the way tags are created
    void* val[] = { &query };
    rval        = mb->get_entities_by_type_and_tag( 0, MBENTITYSET, &category_tag, val, 1, group_sets );CHECK_ERR( rval );
    // Get group names and IDs
    std::vector< int > g_ids;
    std::vector< std::string > g_names;
    std::vector< int > g_ent_ids;
    for( Range::iterator i = group_sets.begin(); i != group_sets.end(); ++i )
        int group_id = geom_id_by_handle( mb, *i );
        g_ids.push_back( group_id );
        // Get the group name
        char group_name[NAME_TAG_SIZE + 1];
        rval = mb->tag_get_data( name_tag, &( *i ), 1, &group_name );CHECK_ERR( rval );
        // Store group name
        std::string temp( group_name );
        g_names.push_back( temp );
        // Get all entities in the group
        Range group_ents;
        rval = mb->get_entities_by_type( *i, MBENTITYSET, group_ents, false );CHECK_ERR( rval );
        if( group_ents.size() != 1 ) CHECK( false );
        int grp_ent_id = geom_id_by_handle( mb, group_ents[0] );
        g_ent_ids.push_back( grp_ent_id );
    check_group_data( g_ids, g_names, g_ent_ids );
void read_file ( Interface *  moab,
const char *  input_file
Definition at line 57 of file read_cgm_basic_test.cpp.
    InitCGMA::initialize_cgma();
    GeometryQueryTool::instance()->delete_geometry();
    ErrorCode rval = moab->load_file( input_file );CHECK_ERR( rval );
Variable Documentation
