MOAB: Mesh Oriented datABase
(version 5.4.1)
00001 #include "TestUtil.hpp" 00002 #include "moab/Core.hpp" 00003 #include "MBTagConventions.hpp" 00004 #include "moab/CN.hpp" 00005 #include "moab/Range.hpp" 00006 #include "moab/GeomTopoTool.hpp" 00007 #include <cmath> 00008 #include <algorithm> 00009 00010 using namespace moab; 00011 00012 /**\brief Input test file: test.cub 00013 * Cubit 10.2 file. 00014 * File contains: 00015 * Two merged 10x10x10 bricks sharing a single surface (surface 6). 00016 * - Each brick is meshed with 8 5x5x5 hexes. 00017 * - Each surface is meshed with 4 5x5 quads. 00018 * - Each curve is meshed with 2 5-unit edges. 00019 * A single block containing both bricks. 00020 * Two side sets 00021 * - sideset 1: surfaces 1 and 7 00022 * - sideset 2: surfaces 5 and 11 00023 * Two node sets: 00024 * - nodeset 1: surfaces 2 and 8 00025 * - nodeset 2: surfaces 3 and 9 00026 * 00027 * Surfaces: 00028 * 2 8 00029 * / / 00030 * o----------o----------o 00031 * /. / /. / /| 00032 * / . (5)/ / . (11)/ / | 00033 * / . L / . L / | 00034 * o----------o----------o | 00035 * | . | . |(12) 00036 * 4--|-> o . . .|. .o. . . | . o 00037 * | . (1) | . (9) | / 00038 * | . ^ | . ^ | / 00039 * |. | |. | |/ 00040 * o----------o----------o 00041 * | | 00042 * 3 9 00043 * 00044 * Curves: 00045 * 00046 * o----8-----o----20----o 00047 * /. /. /| 00048 * 12 . 11 . 24 | 00049 * / 7 / 5 / 17 00050 * o----2-----o----14----o | 00051 * | . | . | | 00052 * | o . .6.|. .o. . 18| . o 00053 * 3 . 1 . 13 / 00054 * | 9 | 10 | 22 00055 * |. |. |/ 00056 * o----4-----o----16----o 00057 * 00058 * Vertices: 00059 * 00060 * 8----------5----------13 00061 * /. /. /| 00062 * / . / . / | 00063 * / . / . / | 00064 * 3----------2----------10 | 00065 * | . | . | | 00066 * | 7 . . .|. .6. . . | . 14 00067 * | . | . | / 00068 * | . | . | / 00069 * |. |. |/ 00070 * 4----------1----------9 00071 */ 00072 00073 /* Input test file: ho_test.cub 00074 * 00075 * File is expected to contain at least one block for every 00076 * supported higher-order element type. The coordinates of 00077 * every higher-order node are expected to be the mean of the 00078 * adjacent corner vertices of the element. 00079 */ 00080 static const std::string input_file_1 = std::string( TestDir + "unittest/io/test.cub" ); 00081 static const std::string ho_file = std::string( TestDir + "unittest/io/ho_test.cub" ); 00082 static const std::string cubit12_file = std::string( TestDir + "unittest/io/cubtest12.cub" ); 00083 static const std::string cubit14_file = std::string( TestDir + "unittest/io/cubtest14.cub" ); 00084 00085 void read_file( Interface& moab, const std::string& input_file ); 00086 00087 // Check that adjacent lower-order entities have 00088 // higher-order nodes consitent with input entity. 00089 void check_adj_ho_nodes( Interface& moab, EntityHandle entity ); 00090 00091 // Check that element has expected higher-order nodes 00092 // and that each higher-order node is at the center 00093 // of the sub-entity it is on. 00094 void check_ho_element( Interface& moab, EntityHandle entity, int mid_nodes[4] ); 00095 00096 // Validate elements of specified type. 00097 // Looks for a block containing the specified entity type 00098 // and with the specified mid-node flags set in its 00099 // HAS_MID_NODES_TAG. 00100 void test_ho_elements( EntityType type, int num_nodes ); 00101 00102 void test_vertices(); 00103 00104 void test_edges(); 00105 00106 void test_quads(); 00107 00108 void test_hexes(); 00109 00110 void test_geometric_topology(); 00111 00112 void test_geometric_sets(); 00113 00114 void test_blocks(); 00115 00116 void test_side_sets(); 00117 00118 void test_node_sets(); 00119 00120 void test_tri6() 00121 { 00122 test_ho_elements( MBTRI, 6 ); 00123 } 00124 void test_tri7() 00125 { 00126 test_ho_elements( MBTRI, 7 ); 00127 } 00128 00129 void test_quad5() 00130 { 00131 test_ho_elements( MBQUAD, 5 ); 00132 } 00133 void test_quad8() 00134 { 00135 test_ho_elements( MBQUAD, 8 ); 00136 } 00137 void test_quad9() 00138 { 00139 test_ho_elements( MBQUAD, 9 ); 00140 } 00141 00142 void test_tet8() 00143 { 00144 test_ho_elements( MBTET, 8 ); 00145 } 00146 void test_tet10() 00147 { 00148 test_ho_elements( MBTET, 10 ); 00149 } 00150 void test_tet14() 00151 { 00152 test_ho_elements( MBTET, 14 ); 00153 } 00154 00155 void test_hex9() 00156 { 00157 test_ho_elements( MBHEX, 9 ); 00158 } 00159 void test_hex20() 00160 { 00161 test_ho_elements( MBHEX, 20 ); 00162 } 00163 void test_hex27() 00164 { 00165 test_ho_elements( MBHEX, 27 ); 00166 } 00167 00168 void test_multiple_files(); 00169 00170 void test_cubit12(); 00171 void test_cubit14(); 00172 00173 int main() 00174 { 00175 int result = 0; 00176 00177 result += RUN_TEST( test_vertices ); 00178 result += RUN_TEST( test_edges ); 00179 result += RUN_TEST( test_quads ); 00180 result += RUN_TEST( test_hexes ); 00181 result += RUN_TEST( test_geometric_topology ); 00182 result += RUN_TEST( test_geometric_sets ); 00183 result += RUN_TEST( test_blocks ); 00184 result += RUN_TEST( test_side_sets ); 00185 result += RUN_TEST( test_node_sets ); 00186 result += RUN_TEST( test_tri6 ); 00187 result += RUN_TEST( test_tri7 ); 00188 result += RUN_TEST( test_quad5 ); 00189 result += RUN_TEST( test_quad8 ); 00190 result += RUN_TEST( test_quad9 ); 00191 result += RUN_TEST( test_tet8 ); 00192 result += RUN_TEST( test_tet10 ); 00193 result += RUN_TEST( test_tet14 ); 00194 result += RUN_TEST( test_hex9 ); 00195 result += RUN_TEST( test_hex20 ); 00196 result += RUN_TEST( test_hex27 ); 00197 result += RUN_TEST( test_multiple_files ); 00198 result += RUN_TEST( test_cubit12 ); 00199 result += RUN_TEST( test_cubit14 ); 00200 return result; 00201 } 00202 00203 void read_file( Interface& moab, const std::string& input_file ) 00204 { 00205 ErrorCode rval = moab.load_file( input_file.c_str() );CHECK_ERR( rval ); 00206 } 00207 00208 void test_vertices() 00209 { 00210 /* Node coordinates, in order of node ID, beginning with 1. */ 00211 const double node_coords[] = { 00212 5, -5, 5, // 1 00213 5, 5, 5, 5, 0, 5, -5, 5, 5, 0, 5, 5, // 5 00214 -5, -5, 5, -5, 0, 5, 0, -5, 5, 0, 0, 5, 5, 5, -5, // 10 00215 5, -5, -5, 5, 0, -5, -5, -5, -5, 0, -5, -5, -5, 5, -5, // 15 00216 -5, 0, -5, 0, 5, -5, 0, 0, -5, -5, -5, 0, 5, -5, 0, // 20 00217 0, -5, 0, -5, 5, 0, -5, 0, 0, 5, 5, 0, 0, 5, 0, // 25 00218 5, 0, 0, 0, 0, 0, 15, -5, 5, 15, 5, 5, 15, 0, 5, // 30 00219 10, 5, 5, 10, -5, 5, 10, 0, 5, 15, 5, -5, 15, -5, -5, // 35 00220 15, 0, -5, 10, -5, -5, 10, 5, -5, 10, 0, -5, 15, -5, 0, // 40 00221 10, -5, 0, 15, 5, 0, 10, 5, 0, 15, 0, 0, 10, 0, 0 // 45 00222 }; 00223 00224 ErrorCode rval; 00225 Core mb_impl; 00226 Interface& mb = mb_impl; 00227 read_file( mb, input_file_1 ); 00228 00229 // get vertex handles and check correct number of vertices 00230 const size_t num_nodes = sizeof( node_coords ) / ( 3 * sizeof( double ) ); 00231 Range verts; 00232 rval = mb.get_entities_by_type( 0, MBVERTEX, verts );CHECK_ERR( rval ); 00233 CHECK_EQUAL( num_nodes, (size_t)verts.size() ); 00234 00235 // check global ids (should be 1 to 45 for vertices.) 00236 Tag gid_tag; 00237 rval = mb.tag_get_handle( "GLOBAL_ID", 1, MB_TYPE_INTEGER, gid_tag );CHECK_ERR( rval ); 00238 std::vector< int > ids( num_nodes ); 00239 rval = mb.tag_get_data( gid_tag, verts, &ids[0] );CHECK_ERR( rval ); 00240 std::vector< int > sorted( ids ); 00241 std::sort( sorted.begin(), sorted.end() ); 00242 for( size_t i = 0; i < num_nodes; ++i ) 00243 CHECK_EQUAL( (int)( i + 1 ), sorted[i] ); 00244 00245 // check coordinates of each vertex 00246 std::vector< double > coords( 3 * num_nodes ); 00247 rval = mb.get_coords( verts, &coords[0] );CHECK_ERR( rval ); 00248 for( size_t i = 0; i < num_nodes; ++i ) 00249 { 00250 const double* exp = node_coords + 3 * ( ids[i] - 1 ); 00251 const double* act = &coords[3 * i]; 00252 CHECK_REAL_EQUAL( exp[0], act[0], 1e-8 ); 00253 CHECK_REAL_EQUAL( exp[1], act[1], 1e-8 ); 00254 CHECK_REAL_EQUAL( exp[2], act[2], 1e-8 ); 00255 } 00256 } 00257 00258 void test_element( const std::string& filename, EntityType type, int num_elem, int node_per_elem, const int* conn_list ) 00259 { 00260 ErrorCode rval; 00261 Core mb_impl; 00262 Interface& mb = mb_impl; 00263 read_file( mb, filename ); 00264 00265 Range elems; 00266 rval = mb.get_entities_by_type( 0, type, elems );CHECK_ERR( rval ); 00267 CHECK_EQUAL( num_elem, (int)elems.size() ); 00268 00269 // get global ids 00270 Tag gid_tag; 00271 rval = mb.tag_get_handle( "GLOBAL_ID", 1, MB_TYPE_INTEGER, gid_tag );CHECK_ERR( rval ); 00272 std::vector< int > ids( num_elem ); 00273 rval = mb.tag_get_data( gid_tag, elems, &ids[0] );CHECK_ERR( rval ); 00274 00275 // check that global ids are consecutive, beginning with 1 00276 std::vector< int > sorted( ids ); 00277 std::sort( sorted.begin(), sorted.end() ); 00278 for( int i = 0; i < num_elem; ++i ) 00279 CHECK_EQUAL( i + 1, sorted[i] ); 00280 00281 // check connectivity of each element 00282 std::vector< int > conn_ids( node_per_elem ); 00283 std::vector< EntityHandle > conn_h; 00284 Range::iterator j = elems.begin(); 00285 for( int i = 0; i < num_elem; ++i, ++j ) 00286 { 00287 conn_h.clear(); 00288 rval = mb.get_connectivity( &*j, 1, conn_h );CHECK_ERR( rval ); 00289 CHECK_EQUAL( node_per_elem, (int)conn_h.size() ); 00290 rval = mb.tag_get_data( gid_tag, &conn_h[0], node_per_elem, &conn_ids[0] );CHECK_ERR( rval ); 00291 const int* exp = conn_list + node_per_elem * ( ids[i] - 1 ); 00292 for( int k = 0; k < node_per_elem; ++k ) 00293 CHECK_EQUAL( exp[k], conn_ids[k] ); 00294 } 00295 } 00296 00297 void test_edges() 00298 { 00299 const int edge_conn[] = { 1, 3, // 1 00300 3, 2, 2, 5, 5, 4, 4, 7, 7, 6, 6, 8, 8, 1, 3, 9, 9, 8, // 10 00301 5, 9, 9, 7, 10, 12, 12, 11, 11, 14, 14, 13, 13, 16, 16, 15, 15, 17, 17, 10, // 20 00302 12, 18, 18, 17, 14, 18, 18, 16, 6, 19, 19, 13, 1, 20, 20, 11, 19, 21, 21, 8, // 30 00303 14, 21, 21, 20, 4, 22, 22, 15, 22, 23, 23, 7, 16, 23, 23, 19, 2, 24, 24, 10, // 40 00304 24, 25, 25, 5, 17, 25, 25, 22, 20, 26, 26, 3, 12, 26, 26, 24, 28, 30, 30, 29, // 50 00305 29, 31, 31, 2, 1, 32, 32, 28, 30, 33, 33, 32, 31, 33, 33, 3, 34, 36, 36, 35, // 60 00306 35, 37, 37, 11, 10, 38, 38, 34, 36, 39, 39, 38, 37, 39, 39, 12, 28, 40, 40, 35, // 70 00307 20, 41, 41, 32, 37, 41, 41, 40, 29, 42, 42, 34, 42, 43, 43, 31, 38, 43, 43, 24, // 80 00308 40, 44, 44, 30, 36, 44, 44, 42 }; 00309 test_element( input_file_1, MBEDGE, 84, 2, edge_conn ); 00310 } 00311 00312 void test_quads() 00313 { 00314 const int quad_conn[] = { 00315 1, 3, 9, 8, // 1 00316 3, 2, 5, 9, 8, 9, 7, 6, 9, 5, 4, 7, 10, 12, 18, 17, 12, 11, 14, 18, 00317 17, 18, 16, 15, 18, 14, 13, 16, 6, 19, 21, 8, 19, 13, 14, 21, // 10 00318 8, 21, 20, 1, 21, 14, 11, 20, 4, 22, 23, 7, 22, 15, 16, 23, 7, 23, 19, 6, 00319 23, 16, 13, 19, 2, 24, 25, 5, 24, 10, 17, 25, 5, 25, 22, 4, 25, 17, 15, 22, // 20 00320 1, 20, 26, 3, 20, 11, 12, 26, 3, 26, 24, 2, 26, 12, 10, 24, 28, 30, 33, 32, 00321 30, 29, 31, 33, 32, 33, 3, 1, 33, 31, 2, 3, 34, 36, 39, 38, 36, 35, 37, 39, // 30 00322 38, 39, 12, 10, 39, 37, 11, 12, 1, 20, 41, 32, 20, 11, 37, 41, 32, 41, 40, 28, 00323 41, 37, 35, 40, 29, 42, 43, 31, 42, 34, 38, 43, 31, 43, 24, 2, 43, 38, 10, 24, // 40 00324 28, 40, 44, 30, 40, 35, 36, 44, 30, 44, 42, 29, 44, 36, 34, 42, 00325 }; 00326 test_element( input_file_1, MBQUAD, 44, 4, quad_conn ); 00327 } 00328 00329 void test_hexes() 00330 { 00331 const int hex_conn[] = { 6, 19, 23, 7, 8, 21, 27, 9, 19, 13, 16, 23, 21, 14, 18, 27, 7, 23, 22, 4, 9, 27, 00332 25, 5, 23, 16, 15, 22, 27, 18, 17, 25, 8, 21, 27, 9, 1, 20, 26, 3, 21, 14, 18, 27, 00333 20, 11, 12, 26, 9, 27, 25, 5, 3, 26, 24, 2, 27, 18, 17, 25, 26, 12, 10, 24, 1, 20, 00334 26, 3, 32, 41, 45, 33, 20, 11, 12, 26, 41, 37, 39, 45, 3, 26, 24, 2, 33, 45, 43, 31, 00335 26, 12, 10, 24, 45, 39, 38, 43, 32, 41, 45, 33, 28, 40, 44, 30, 41, 37, 39, 45, 40, 35, 00336 36, 44, 33, 45, 43, 31, 30, 44, 42, 29, 45, 39, 38, 43, 44, 36, 34, 42 }; 00337 test_element( input_file_1, MBHEX, 16, 8, hex_conn ); 00338 } 00339 00340 template < int L > 00341 std::vector< int > find_parents( const int parent_conn[][L], int num_parent, int id ) 00342 { 00343 std::vector< int > results; 00344 for( int i = 0; i < num_parent; ++i ) 00345 { 00346 for( int j = 0; j < L; ++j ) 00347 { 00348 if( parent_conn[i][j] == id ) results.push_back( i + 1 ); 00349 } 00350 } 00351 return results; 00352 } 00353 00354 int check_geometric_set( Interface& moab, 00355 int dim, 00356 int id, 00357 const int* children, 00358 int num_children, 00359 std::vector< int > parents ) 00360 { 00361 ErrorCode rval; 00362 Tag gid_tag, dim_tag; 00363 00364 rval = moab.tag_get_handle( "GLOBAL_ID", 1, MB_TYPE_INTEGER, gid_tag );CHECK_ERR( rval ); 00365 rval = moab.tag_get_handle( "GEOM_DIMENSION", 1, MB_TYPE_INTEGER, dim_tag );CHECK_ERR( rval ); 00366 void* tag_vals[] = { &dim, &id }; 00367 Tag tags[] = { dim_tag, gid_tag }; 00368 Range ents; 00369 rval = moab.get_entities_by_type_and_tag( 0, MBENTITYSET, tags, tag_vals, 2, ents );CHECK_ERR( rval ); 00370 CHECK_EQUAL( 1u, (unsigned)ents.size() ); 00371 00372 const EntityHandle geom = ents.front(); 00373 std::vector< int > exp_rel, act_rel; 00374 std::vector< EntityHandle > rel; 00375 00376 if( num_children ) 00377 { 00378 exp_rel.resize( num_children ); 00379 std::copy( children, children + num_children, exp_rel.begin() ); 00380 std::sort( exp_rel.begin(), exp_rel.end() ); 00381 rel.clear(); 00382 rval = moab.get_child_meshsets( geom, rel );CHECK_ERR( rval ); 00383 CHECK_EQUAL( num_children, (int)rel.size() ); 00384 act_rel.resize( rel.size() ); 00385 rval = moab.tag_get_data( gid_tag, &rel[0], rel.size(), &act_rel[0] );CHECK_ERR( rval ); 00386 std::sort( act_rel.begin(), act_rel.end() ); 00387 CHECK( exp_rel == act_rel ); 00388 } 00389 00390 if( !parents.empty() ) 00391 { 00392 exp_rel = parents; 00393 std::sort( exp_rel.begin(), exp_rel.end() ); 00394 rel.clear(); 00395 rval = moab.get_parent_meshsets( geom, rel );CHECK_ERR( rval ); 00396 CHECK_EQUAL( parents.size(), rel.size() ); 00397 act_rel.resize( rel.size() ); 00398 rval = moab.tag_get_data( gid_tag, &rel[0], rel.size(), &act_rel[0] );CHECK_ERR( rval ); 00399 std::sort( act_rel.begin(), act_rel.end() ); 00400 CHECK( exp_rel == act_rel ); 00401 } 00402 00403 return 0; 00404 } 00405 00406 void test_geometric_topology() 00407 { 00408 Core mb_impl; 00409 Interface& mb = mb_impl; 00410 read_file( mb, input_file_1 ); 00411 // expected geometric vertices, specified by global ID 00412 const int vertex_ids[] = { 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 13, 14 }; 00413 // List of global IDs of surfacs in geometric volumes, indexed by ID-1 00414 const int volume_surfs[2][6] = { { 1, 2, 3, 4, 5, 6 }, { 7, 8, 9, 6, 11, 12 } }; 00415 // List of global IDs of curves in geometric surfaces, indexed by ID-1 00416 // Curve IDs of zero indicates that corresponding surface doesn't exist. 00417 const int surf_curves[12][4] = { { 1, 2, 3, 4 }, { 5, 6, 7, 8 }, { 9, 6, 10, 4 }, { 11, 7, 9, 3 }, 00418 { 12, 8, 11, 2 }, { 10, 5, 12, 1 }, { 13, 14, 1, 16 }, { 17, 18, 5, 20 }, 00419 { 10, 18, 22, 16 }, { 0, 0, 0, 0 }, // no surf 10 00420 { 24, 20, 12, 14 }, { 22, 17, 24, 13 } }; 00421 // List of global IDs of vertices in geometric curves, indexed by ID-1 00422 // Vertex IDs of zero indicates that corresponding curve doesn't exist. 00423 const int curve_verts[24][2] = { { 1, 2 }, { 2, 3 }, { 3, 4 }, { 4, 1 }, { 5, 6 }, // 5 00424 { 6, 7 }, { 7, 8 }, { 8, 5 }, { 4, 7 }, { 1, 6 }, // 10 00425 { 3, 8 }, { 2, 5 }, { 9, 10 }, // 13 00426 { 10, 2 }, { 0, 0 }, // no curve 15 00427 { 1, 9 }, { 13, 14 }, { 14, 6 }, { 0, 0 }, // no curve 19 00428 { 5, 13 }, { 0, 0 }, // no curve 21 00429 { 9, 14 }, { 0, 0 }, // no curve 23 00430 { 10, 13 } }; 00431 00432 // check all vertices 00433 for( unsigned i = 0; i < ( sizeof( vertex_ids ) / sizeof( vertex_ids[0] ) ); ++i ) 00434 check_geometric_set( mb, 0, vertex_ids[i], 0, 0, find_parents< 2 >( curve_verts, 24, vertex_ids[i] ) ); 00435 00436 // check all curves 00437 for( int i = 1; i <= 24; ++i ) 00438 if( curve_verts[i - 1][0] ) 00439 check_geometric_set( mb, 1, i, curve_verts[i - 1], 2, find_parents< 4 >( surf_curves, 12, i ) ); 00440 00441 // check all surfs 00442 for( int i = 1; i <= 12; ++i ) 00443 if( surf_curves[i - 1][0] ) 00444 check_geometric_set( mb, 2, i, surf_curves[i - 1], 4, find_parents< 6 >( volume_surfs, 2, i ) ); 00445 00446 // check all volumes 00447 std::vector< int > empty; 00448 for( int i = 1; i <= 2; ++i ) 00449 check_geometric_set( mb, 3, i, volume_surfs[i - 1], 6, empty ); 00450 } 00451 00452 void test_geometric_sets() 00453 { 00454 ErrorCode rval; 00455 Core mb_impl; 00456 Interface& mb = mb_impl; 00457 read_file( mb, input_file_1 ); 00458 Tag gid_tag, dim_tag; 00459 rval = mb.tag_get_handle( "GLOBAL_ID", 1, MB_TYPE_INTEGER, gid_tag );CHECK_ERR( rval ); 00460 rval = mb.tag_get_handle( "GEOM_DIMENSION", 1, MB_TYPE_INTEGER, dim_tag );CHECK_ERR( rval ); 00461 00462 // verify mesh entity counts 00463 Range verts, curves, surfs, vols; 00464 int dim = 0; 00465 // Cppcheck warning (false positive): variable dim is assigned a value that is never used 00466 // Cppcheck warning (false positive): variable dim is reassigned a value before the old one has 00467 // been used 00468 const void* vals[] = { &dim }; 00469 rval = mb.get_entities_by_type_and_tag( 0, MBENTITYSET, &dim_tag, vals, 1, verts );CHECK_ERR( rval ); 00470 dim = 1; 00471 rval = mb.get_entities_by_type_and_tag( 0, MBENTITYSET, &dim_tag, vals, 1, curves );CHECK_ERR( rval ); 00472 dim = 2; 00473 rval = mb.get_entities_by_type_and_tag( 0, MBENTITYSET, &dim_tag, vals, 1, surfs );CHECK_ERR( rval ); 00474 dim = 3; 00475 rval = mb.get_entities_by_type_and_tag( 0, MBENTITYSET, &dim_tag, vals, 1, vols );CHECK_ERR( rval ); 00476 00477 CHECK_EQUAL( 12u, (unsigned)verts.size() ); 00478 CHECK_EQUAL( 20u, (unsigned)curves.size() ); 00479 CHECK_EQUAL( 11u, (unsigned)surfs.size() ); 00480 CHECK_EQUAL( 2u, (unsigned)vols.size() ); 00481 00482 // check that each vertex has a single node, and that the 00483 // node is also contained in any parent curve 00484 Range ents; 00485 Range::iterator i; 00486 for( i = verts.begin(); i != verts.end(); ++i ) 00487 { 00488 ents.clear(); 00489 rval = mb.get_entities_by_handle( *i, ents );CHECK_ERR( rval ); 00490 CHECK_EQUAL( 1u, (unsigned)ents.size() ); 00491 CHECK( ents.all_of_type( MBVERTEX ) ); 00492 } 00493 00494 // check that each curve has one node and two edges 00495 for( i = curves.begin(); i != curves.end(); ++i ) 00496 { 00497 ents.clear(); 00498 rval = mb.get_entities_by_handle( *i, ents );CHECK_ERR( rval ); 00499 CHECK_EQUAL( 1u, (unsigned)ents.num_of_type( MBVERTEX ) ); 00500 CHECK_EQUAL( 2u, (unsigned)ents.num_of_type( MBEDGE ) ); 00501 CHECK_EQUAL( 3u, (unsigned)ents.size() ); 00502 } 00503 00504 // check that each surface has 1 node, 4 edges, 4 quads 00505 for( i = surfs.begin(); i != surfs.end(); ++i ) 00506 { 00507 ents.clear(); 00508 rval = mb.get_entities_by_handle( *i, ents );CHECK_ERR( rval ); 00509 CHECK_EQUAL( 1u, (unsigned)ents.num_of_type( MBVERTEX ) ); 00510 CHECK_EQUAL( 4u, (unsigned)ents.num_of_type( MBEDGE ) ); 00511 CHECK_EQUAL( 4u, (unsigned)ents.num_of_type( MBQUAD ) ); 00512 CHECK_EQUAL( 9u, (unsigned)ents.size() ); 00513 } 00514 00515 // check that each volume has 1 node and 8 hexes. 00516 for( i = vols.begin(); i != vols.end(); ++i ) 00517 { 00518 ents.clear(); 00519 rval = mb.get_entities_by_handle( *i, ents );CHECK_ERR( rval ); 00520 CHECK_EQUAL( 1u, (unsigned)ents.num_of_type( MBVERTEX ) ); 00521 CHECK_EQUAL( 8u, (unsigned)ents.num_of_type( MBHEX ) ); 00522 CHECK_EQUAL( 9u, (unsigned)ents.size() ); 00523 } 00524 00525 // Check that for each geometric entity, any contained vertices 00526 // are adjacent to some entity in one of its parents. 00527 Range parents, geom, nodes, tmp; 00528 for( int d = 0; d < 3; ++d ) 00529 { 00530 const void* vals1[] = { &d }; 00531 rval = mb.get_entities_by_type_and_tag( 0, MBENTITYSET, &dim_tag, vals1, 1, geom );CHECK_ERR( rval ); 00532 00533 for( i = geom.begin(); i != geom.end(); ++i ) 00534 { 00535 nodes.clear(); 00536 ents.clear(); 00537 parents.clear(); 00538 rval = mb.get_entities_by_type( *i, MBVERTEX, nodes );CHECK_ERR( rval ); 00539 rval = mb.get_parent_meshsets( *i, parents );CHECK_ERR( rval ); 00540 for( Range::iterator j = parents.begin(); j != parents.end(); ++j ) 00541 { 00542 tmp.clear(); 00543 rval = mb.get_entities_by_dimension( *j, d + 1, tmp );CHECK_ERR( rval ); 00544 ents.merge( tmp ); 00545 } 00546 tmp.clear(); 00547 rval = mb.get_adjacencies( ents, 0, false, tmp, Interface::UNION );CHECK_ERR( rval ); 00548 nodes = subtract( nodes, tmp ); 00549 CHECK( nodes.empty() ); 00550 } 00551 } 00552 } 00553 00554 // expect one block containing entire mesh, with id == 1 00555 void test_blocks() 00556 { 00557 ErrorCode rval; 00558 Core mb_impl; 00559 Interface& mb = mb_impl; 00560 read_file( mb, input_file_1 ); 00561 Tag mat_tag; 00562 rval = mb.tag_get_handle( MATERIAL_SET_TAG_NAME, 1, MB_TYPE_INTEGER, mat_tag );CHECK_ERR( rval ); 00563 00564 Range blocks; 00565 rval = mb.get_entities_by_type_and_tag( 0, MBENTITYSET, &mat_tag, 0, 1, blocks );CHECK_ERR( rval ); 00566 CHECK_EQUAL( 1u, (unsigned)blocks.size() ); 00567 EntityHandle block = blocks.front(); 00568 int id; 00569 rval = mb.tag_get_data( mat_tag, &block, 1, &id );CHECK_ERR( rval ); 00570 CHECK_EQUAL( 1, id ); 00571 00572 Range block_hexes, mesh_hexes; 00573 rval = mb.get_entities_by_dimension( 0, 3, mesh_hexes );CHECK_ERR( rval ); 00574 rval = mb.get_entities_by_dimension( block, 3, block_hexes, true );CHECK_ERR( rval ); 00575 CHECK( mesh_hexes == block_hexes ); 00576 } 00577 00578 // Common code for test_side_sets and test_node sets 00579 //\param tag_name NEUMANN_SET_TAG_NAME or DIRICHLET_SET_TAG_NAME 00580 //\param count Number of expected sets 00581 //\param ids Expected IDs of sets 00582 //\param set_surfs One list for each id in "ids" containing the 00583 // ids of the geometric surfaces expected to be 00584 // contained in the boundary condition set. 00585 void test_bc_sets( const char* tag_name, unsigned count, const int* ids, const std::vector< int > set_surfs[] ) 00586 { 00587 ErrorCode rval; 00588 Core mb_impl; 00589 Interface& mb = mb_impl; 00590 read_file( mb, input_file_1 ); 00591 Tag ss_tag, gid_tag, dim_tag; 00592 rval = mb.tag_get_handle( tag_name, 1, MB_TYPE_INTEGER, ss_tag );CHECK_ERR( rval ); 00593 rval = mb.tag_get_handle( "GLOBAL_ID", 1, MB_TYPE_INTEGER, gid_tag );CHECK_ERR( rval ); 00594 rval = mb.tag_get_handle( "GEOM_DIMENSION", 1, MB_TYPE_INTEGER, dim_tag );CHECK_ERR( rval ); 00595 00596 // check number of sidesets and IDs 00597 Range sidesets; 00598 rval = mb.get_entities_by_type_and_tag( 0, MBENTITYSET, &ss_tag, 0, 1, sidesets );CHECK_ERR( rval ); 00599 CHECK_EQUAL( count, (unsigned)sidesets.size() ); 00600 std::vector< EntityHandle > handles( count, 0 ); 00601 for( Range::iterator i = sidesets.begin(); i != sidesets.end(); ++i ) 00602 { 00603 int id; 00604 rval = mb.tag_get_data( ss_tag, &*i, 1, &id );CHECK_ERR( rval ); 00605 unsigned idx; 00606 for( idx = 0; idx < count; ++idx ) 00607 if( ids[idx] == id ) break; 00608 CHECK( idx != count ); 00609 CHECK( handles[idx] == 0 ); 00610 handles[idx] = *i; 00611 } 00612 00613 // get surface faces 00614 std::vector< Range > exp( count ); 00615 Range surfs, tmp; 00616 Tag tags[] = { dim_tag, gid_tag }; 00617 for( unsigned i = 0; i < count; ++i ) 00618 { 00619 exp[i].clear(); 00620 surfs.clear(); 00621 const int two = 2; 00622 for( unsigned j = 0; j < set_surfs[i].size(); ++j ) 00623 { 00624 const void* vals[] = { &two, &set_surfs[i][j] }; 00625 surfs.clear(); 00626 rval = mb.get_entities_by_type_and_tag( 0, MBENTITYSET, tags, vals, 2, surfs );CHECK_ERR( rval ); 00627 CHECK_EQUAL( 1u, (unsigned)surfs.size() ); 00628 tmp.clear(); 00629 rval = mb.get_entities_by_dimension( surfs.front(), 2, tmp, true );CHECK_ERR( rval ); 00630 exp[i].merge( tmp ); 00631 } 00632 } 00633 00634 // check each bc set 00635 Range act; 00636 for( unsigned i = 0; i < count; ++i ) 00637 { 00638 act.clear(); 00639 rval = mb.get_entities_by_dimension( handles[i], 2, act, true );CHECK_ERR( rval ); 00640 CHECK( exp[i] == act ); 00641 } 00642 } 00643 00644 // expect two sidesets containing two geometric surfaces each: 00645 // sideset 1 : surfaces 1 and 7 00646 // sideset 2 : surfaces 5 and 11 00647 void test_side_sets() 00648 { 00649 int ids[] = { 1, 2 }; 00650 std::vector< int > surfs[2]; 00651 surfs[0].push_back( 1 ); 00652 surfs[0].push_back( 7 ); 00653 surfs[1].push_back( 5 ); 00654 surfs[1].push_back( 11 ); 00655 test_bc_sets( NEUMANN_SET_TAG_NAME, 2, ids, surfs ); 00656 } 00657 00658 void test_node_sets() 00659 { 00660 int ids[] = { 1, 2 }; 00661 std::vector< int > surfs[2]; 00662 surfs[0].push_back( 2 ); 00663 surfs[0].push_back( 8 ); 00664 surfs[1].push_back( 3 ); 00665 surfs[1].push_back( 9 ); 00666 test_bc_sets( DIRICHLET_SET_TAG_NAME, 2, ids, surfs ); 00667 } 00668 00669 static EntityHandle find_side( Interface& moab, EntityHandle entity, int side_dim, int side_num ) 00670 { 00671 ErrorCode rval; 00672 00673 std::vector< EntityHandle > adj; 00674 rval = moab.get_adjacencies( &entity, 1, side_dim, false, adj );CHECK_ERR( rval ); 00675 00676 int sub_ent_indices[4]; 00677 CN::SubEntityVertexIndices( TYPE_FROM_HANDLE( entity ), side_dim, side_num, sub_ent_indices ); 00678 EntityType subtype = CN::SubEntityType( TYPE_FROM_HANDLE( entity ), side_dim, side_num ); 00679 int sub_ent_corners = CN::VerticesPerEntity( subtype ); 00680 00681 const EntityHandle* conn; 00682 int conn_len; 00683 rval = moab.get_connectivity( entity, conn, conn_len );CHECK_ERR( rval ); 00684 00685 for( size_t i = 0; i < adj.size(); ++i ) 00686 { 00687 if( TYPE_FROM_HANDLE( adj[i] ) != subtype ) continue; 00688 00689 const EntityHandle* sub_conn; 00690 int sub_len; 00691 rval = moab.get_connectivity( adj[i], sub_conn, sub_len );CHECK_ERR( rval ); 00692 00693 int n = std::find( sub_conn, sub_conn + sub_len, conn[sub_ent_indices[0]] ) - sub_conn; 00694 if( n == sub_len ) // no vertex in common 00695 continue; 00696 00697 // check forward direction 00698 int j; 00699 for( j = 1; j < sub_ent_corners; ++j ) 00700 if( conn[sub_ent_indices[j]] != sub_conn[( j + n ) % sub_ent_corners] ) break; 00701 if( j == sub_ent_corners ) return adj[i]; 00702 00703 // check reverse direction 00704 for( j = 1; j < sub_ent_corners; ++j ) 00705 if( conn[sub_ent_indices[j]] != sub_conn[( n + sub_ent_corners - j ) % sub_ent_corners] ) break; 00706 if( j == sub_ent_corners ) return adj[i]; 00707 } 00708 00709 // no match 00710 return 0; 00711 } 00712 00713 void check_adj_ho_nodes( Interface& moab, EntityHandle entity ) 00714 { 00715 EntityType type = TYPE_FROM_HANDLE( entity ); 00716 const EntityHandle* conn; 00717 int conn_len; 00718 ErrorCode rval = moab.get_connectivity( entity, conn, conn_len );CHECK_ERR( rval ); 00719 00720 int ho[4]; 00721 CN::HasMidNodes( type, conn_len, ho ); 00722 for( int dim = CN::Dimension( type ) - 1; dim > 0; --dim ) 00723 { 00724 if( !ho[dim] ) continue; 00725 00726 for( int j = 0; j < CN::NumSubEntities( type, dim ); ++j ) 00727 { 00728 EntityHandle side = find_side( moab, entity, dim, j ); 00729 if( !side ) continue; 00730 00731 const EntityHandle* side_conn; 00732 int side_len; 00733 rval = moab.get_connectivity( side, side_conn, side_len );CHECK_ERR( rval ); 00734 00735 int this_idx = CN::HONodeIndex( type, conn_len, dim, j ); 00736 int side_idx = CN::HONodeIndex( TYPE_FROM_HANDLE( side ), side_len, dim, 0 ); 00737 CHECK_EQUAL( side_conn[side_idx], conn[this_idx] ); 00738 } 00739 } 00740 } 00741 00742 // Check that element has expected higher-order nodes 00743 // and that each higher-order node is at the center 00744 // of the sub-entity it is on. 00745 void check_ho_element( Interface& moab, EntityHandle entity, int mid_nodes[4] ) 00746 { 00747 // get element info 00748 const EntityType type = TYPE_FROM_HANDLE( entity ); 00749 const EntityHandle* conn; 00750 int conn_len; 00751 ErrorCode rval = moab.get_connectivity( entity, conn, conn_len );CHECK_ERR( rval ); 00752 std::vector< double > coords( 3 * conn_len ); 00753 rval = moab.get_coords( conn, conn_len, &coords[0] );CHECK_ERR( rval ); 00754 00755 // calculate and verify expected number of mid nodes 00756 int num_nodes = CN::VerticesPerEntity( type ); 00757 for( int d = 1; d <= CN::Dimension( type ); ++d ) 00758 if( mid_nodes[d] ) num_nodes += CN::NumSubEntities( type, d ); 00759 CHECK_EQUAL( num_nodes, conn_len ); 00760 00761 // verify that each higher-order node is at the center 00762 // of its respective sub-entity. 00763 for( int i = CN::VerticesPerEntity( type ); i < num_nodes; ++i ) 00764 { 00765 // get sub-entity owning ho-node 00766 int sub_dim, sub_num; 00767 CN::HONodeParent( type, num_nodes, i, sub_dim, sub_num ); 00768 // get corner vertex indices 00769 int sub_conn[8], num_sub; 00770 if( sub_dim < CN::Dimension( type ) ) 00771 { 00772 CN::SubEntityVertexIndices( type, sub_dim, sub_num, sub_conn ); 00773 EntityType sub_type = CN::SubEntityType( type, sub_dim, sub_num ); 00774 num_sub = CN::VerticesPerEntity( sub_type ); 00775 } 00776 else 00777 { 00778 num_sub = CN::VerticesPerEntity( type ); 00779 for( int j = 0; j < num_sub; ++j ) 00780 sub_conn[j] = j; 00781 } 00782 // calculate mean of corner vertices 00783 double mean[3] = { 0, 0, 0 }; 00784 for( int j = 0; j < num_sub; ++j ) 00785 { 00786 int co = 3 * sub_conn[j]; 00787 mean[0] += coords[co]; 00788 mean[1] += coords[co + 1]; 00789 mean[2] += coords[co + 2]; 00790 } 00791 mean[0] /= num_sub; 00792 mean[1] /= num_sub; 00793 mean[2] /= num_sub; 00794 // verify that higher-order node is at expected location 00795 CHECK_REAL_EQUAL( mean[0], coords[3 * i], 1e-6 ); 00796 CHECK_REAL_EQUAL( mean[1], coords[3 * i + 1], 1e-6 ); 00797 CHECK_REAL_EQUAL( mean[2], coords[3 * i + 2], 1e-6 ); 00798 } 00799 } 00800 00801 // Validate elements of specified type. 00802 // Looks for a block containing the specified entity type 00803 // and with the specified mid-node flags set in its 00804 // HAS_MID_NODES_TAG. 00805 void test_ho_elements( EntityType type, int num_nodes ) 00806 { 00807 Core mb_impl; 00808 Interface& mb = mb_impl; 00809 read_file( mb, ho_file ); 00810 00811 ErrorCode rval; 00812 Tag ho_tag, block_tag; 00813 rval = mb.tag_get_handle( MATERIAL_SET_TAG_NAME, 1, MB_TYPE_INTEGER, block_tag );CHECK_ERR( rval ); 00814 rval = mb.tag_get_handle( HAS_MID_NODES_TAG_NAME, 4, MB_TYPE_INTEGER, ho_tag );CHECK_ERR( rval ); 00815 00816 // get material sets with expected higher-order nodes 00817 Range blocks; 00818 int ho_flags[4]; 00819 CN::HasMidNodes( type, num_nodes, ho_flags ); 00820 Tag tags[2] = { ho_tag, block_tag }; 00821 void* vals[2] = { ho_flags, NULL }; 00822 rval = mb.get_entities_by_type_and_tag( 0, MBENTITYSET, tags, vals, 2, blocks );CHECK_ERR( rval ); 00823 00824 Range::iterator i; 00825 Range entities; 00826 for( i = blocks.begin(); i != blocks.end(); ++i ) 00827 { 00828 rval = mb.get_entities_by_type( *i, type, entities, true );CHECK_ERR( rval ); 00829 } 00830 // test file should contain all types of HO entities 00831 CHECK( !entities.empty() ); 00832 // test ho node positions -- expect to be at center of adj corners 00833 for( i = entities.begin(); i != entities.end(); ++i ) 00834 check_ho_element( mb, *i, ho_flags ); 00835 // test ho node handles consistent with adjacent entities 00836 for( i = entities.begin(); i != entities.end(); ++i ) 00837 check_adj_ho_nodes( mb, *i ); 00838 } 00839 00840 void test_multiple_files() 00841 { 00842 // load two surface meshes, one at z=+5 at z=-5. 00843 ErrorCode rval; 00844 Core mb_impl; 00845 Interface& mb = mb_impl; 00846 Range file1_ents, file2_ents; 00847 read_file( mb, input_file_1 ); 00848 mb.get_entities_by_handle( 0, file1_ents ); 00849 read_file( mb, input_file_1 ); 00850 mb.get_entities_by_handle( 0, file2_ents ); 00851 file2_ents = subtract( file2_ents, file1_ents ); 00852 EntityHandle file1, file2; 00853 mb.create_meshset( MESHSET_SET, file1 ); 00854 mb.create_meshset( MESHSET_SET, file2 ); 00855 mb.add_entities( file1, file1_ents ); 00856 mb.add_entities( file2, file2_ents ); 00857 00858 // first check that we get the same number of verts from 00859 // each file and that they are distinct vertices 00860 Range file1_verts, file2_verts; 00861 rval = mb.get_entities_by_type( file1, MBVERTEX, file1_verts );CHECK_ERR( rval ); 00862 CHECK( !file1_verts.empty() ); 00863 rval = mb.get_entities_by_type( file2, MBVERTEX, file2_verts );CHECK_ERR( rval ); 00864 CHECK( !file2_verts.empty() ); 00865 CHECK_EQUAL( file1_verts.size(), file2_verts.size() ); 00866 CHECK( intersect( file1_verts, file2_verts ).empty() ); 00867 00868 // now check that we get the same number of elements from 00869 // each file and that they are distinct 00870 Range file1_elems, file2_elems; 00871 rval = mb.get_entities_by_dimension( file1, 3, file1_elems );CHECK_ERR( rval ); 00872 CHECK( !file1_elems.empty() ); 00873 rval = mb.get_entities_by_dimension( file2, 3, file2_elems );CHECK_ERR( rval ); 00874 CHECK( !file2_elems.empty() ); 00875 CHECK_EQUAL( file1_elems.size(), file2_elems.size() ); 00876 CHECK( intersect( file1_elems, file2_elems ).empty() ); 00877 00878 // now check that the connectivity for each element is 00879 // defined using the appropriate vertex instances 00880 Range file1_elem_verts, file2_elem_verts; 00881 rval = mb.get_adjacencies( file1_elems, 0, false, file1_elem_verts, Interface::UNION );CHECK_ERR( rval ); 00882 rval = mb.get_adjacencies( file2_elems, 0, false, file2_elem_verts, Interface::UNION );CHECK_ERR( rval ); 00883 CHECK_EQUAL( file1_elem_verts.size(), file2_elem_verts.size() ); 00884 CHECK( intersect( file1_elem_verts, file1_verts ) == file1_elem_verts ); 00885 CHECK( intersect( file2_elem_verts, file2_verts ) == file2_elem_verts ); 00886 } 00887 00888 void test_cubit12() 00889 { 00890 Core mb_impl; 00891 Interface& mb = mb_impl; 00892 read_file( mb, cubit12_file ); 00893 } 00894 00895 void test_cubit14() 00896 { 00897 Core mb_impl; 00898 Interface& mb = mb_impl; 00899 read_file( mb, cubit14_file ); 00900 // check the global id for some geometry sets 00901 GeomTopoTool gtt( &mb_impl ); 00902 Range ranges[5]; 00903 ErrorCode rval = gtt.find_geomsets( ranges );CHECK_ERR( rval ); 00904 EntityHandle set0 = ranges[0][0]; // does it have a global id > 0? 00905 Tag gid_tag; 00906 rval = mb.tag_get_handle( "GLOBAL_ID", 1, MB_TYPE_INTEGER, gid_tag );CHECK_ERR( rval ); 00907 00908 int val; 00909 rval = mb.tag_get_data( gid_tag, &set0, 1, &val ); 00910 CHECK( val != 0 ); 00911 }
