MOAB: Mesh Oriented datABase
(version 5.4.1)
Functions | |
| int | main (int argc, char *argv[]) |
| int main | ( | int | argc, |
| char * | argv[] | ||
Definition at line 26 of file addConnec.cpp.
ProgOptions opts;
std::string inputfile, outfile( "out.h5m" ), sourcefile;
opts.addOpt< std::string >( "input,i", "input mesh filename", &inputfile );
opts.addOpt< std::string >( "source,s", "h5m file aligned with the mesh input file", &sourcefile );
opts.addOpt< std::string >( "output,o", "output mesh filename", &outfile );
opts.parseCommandLine( argc, argv );
std::cout << "input mesh file: " << inputfile << "\n";
std::cout << "source file: " << sourcefile << "\n";
std::cout << "output file: " << outfile << "\n";
if( inputfile.empty() )
opts.printHelp();
return 0;
ErrorCode rval;
Core* mb = new Core();
rval = mb->load_file( inputfile.c_str() );MB_CHK_SET_ERR( rval, "can't load input file" );
Core* mb2 = new Core();
rval = mb2->load_file( sourcefile.c_str() );MB_CHK_SET_ERR( rval, "can't load source file" );
// get vertices on ini mesh; get global id on ini mesh
// get global id on source mesh
Tag gid;
Tag gid2;
rval = mb->tag_get_handle( "GLOBAL_ID", gid );MB_CHK_SET_ERR( rval, "can't get GLOBAL_ID tag on ini mesh " );
rval = mb2->tag_get_handle( "GLOBAL_ID", gid2 );MB_CHK_SET_ERR( rval, "can't get GLOBAL_ID tag on source mesh " );
// get vertices on ini mesh; build
Range iniVerts;
rval = mb->get_entities_by_dimension( 0, 0, iniVerts );MB_CHK_SET_ERR( rval, "can't get verts on initial mesh " );
std::vector< int > gids;
gids.resize( iniVerts.size() );
rval = mb->tag_get_data( gid, iniVerts, &( gids[0] ) );MB_CHK_SET_ERR( rval, "can't get gid on initial verts " );
// build now the map
std::map< int, EntityHandle > fromGidToEh;
int i = 0;
for( Range::iterator vit = iniVerts.begin(); vit != iniVerts.end(); ++vit, i++ )
fromGidToEh[gids[i]] = *vit;
// now get the source verts, and tags, and set it on new mesh
Range sourceVerts;
rval = mb2->get_entities_by_dimension( 0, 0, sourceVerts );MB_CHK_SET_ERR( rval, "can't get verts on source mesh " );
std::vector< int > gids2;
gids2.resize( sourceVerts.size() );
rval = mb2->tag_get_data( gid2, sourceVerts, &( gids2[0] ) );MB_CHK_SET_ERR( rval, "can't get gid2 on cloud mesh " );
std::map< int, EntityHandle > fromGid2ToEh;
i = 0;
for( Range::iterator vit = sourceVerts.begin(); vit != sourceVerts.end(); ++vit, i++ )
fromGid2ToEh[gids2[i]] = *vit;
Range usedVerts;
for( size_t i = 0; i < gids2.size(); i++ )
int globalId = gids2[i];
EntityHandle usedVert = fromGidToEh[globalId];
usedVerts.insert( usedVert );
Range cells;
rval = mb->get_adjacencies( usedVerts, 2, false, cells, Interface::UNION );MB_CHK_SET_ERR( rval, "can't get adj cells " );
// now create a new cell in mb2 for each one in mb
for( Range::iterator cit = cells.begin(); cit != cells.end(); ++cit )
EntityHandle cell = *cit;
int nnodes = 0;
const EntityHandle* conn = NULL;
rval = mb->get_connectivity( cell, conn, nnodes );MB_CHK_SET_ERR( rval, "can't get connectivity " );
std::vector< EntityHandle > nconn( nnodes );
bool goodCell = true;
for( int i = 0; i < nnodes; i++ )
EntityHandle v = conn[i];
int index = iniVerts.index( v );
if( index < 0 ) goodCell = false;
int id = gids[index];
if( fromGid2ToEh.find( id ) == fromGid2ToEh.end() )
goodCell = false;
else
nconn[i] = fromGid2ToEh[id];
if( !goodCell ) continue;
EntityType type = MBTRI;
if( nnodes == 3 )
type = MBTRI;
else if( nnodes == 4 )
type = MBQUAD;
else if( nnodes > 4 )
type = MBPOLYGON;
EntityHandle nel;
rval = mb2->create_element( type, &nconn[0], nnodes, nel );MB_CHK_SET_ERR( rval, "can't create new cell " );
// save file
rval = mb2->write_file( outfile.c_str() );MB_CHK_SET_ERR( rval, "can't write file" );
delete mb;
delete mb2;
return 0;
