MOAB: Mesh Oriented datABase
(version 5.4.1)
00001 /* 00002 * 00003 * 00004 /** @example addConnec.cpp Add connectivity to point cloud data, for better view in visit 00005 * this tool will take an existing h5m fine point cloud data (phys grid or land pc) 00006 * and add 2d cells from a fine atm mesh 00007 * 00008 * example of usage: 00009 * ./addConnec -i wholeFineATM.h5m -s wholeLND_proj01.h5m -o wholeLndM.h5m 00010 * 00011 * Basically, will output a new h5m file (wholeLndM.h5m), which has also cell connectivity copied from fine atm 00012 * matching is based on the global ids 00013 * between what we think is the order on the original file (wholeFineATM.h5m) 00014 * 00015 * file wholeFineATM.h5m is obtained from a coupled run in e3sm, with the ne 11, np 4, 00016 * 00017 */ 00018 #include "moab/ProgOptions.hpp" 00019 #include "moab/Core.hpp" 00020 00021 #include <cmath> 00022 #include <sstream> 00023 00024 using namespace moab; 00025 00026 int main( int argc, char* argv[] ) 00027 { 00028 00029 ProgOptions opts; 00030 00031 std::string inputfile, outfile( "out.h5m" ), sourcefile; 00032 00033 opts.addOpt< std::string >( "input,i", "input mesh filename", &inputfile ); 00034 opts.addOpt< std::string >( "source,s", "h5m file aligned with the mesh input file", &sourcefile ); 00035 opts.addOpt< std::string >( "output,o", "output mesh filename", &outfile ); 00036 00037 opts.parseCommandLine( argc, argv ); 00038 00039 std::cout << "input mesh file: " << inputfile << "\n"; 00040 std::cout << "source file: " << sourcefile << "\n"; 00041 std::cout << "output file: " << outfile << "\n"; 00042 00043 if( inputfile.empty() ) 00044 { 00045 opts.printHelp(); 00046 return 0; 00047 } 00048 ErrorCode rval; 00049 Core* mb = new Core(); 00050 00051 rval = mb->load_file( inputfile.c_str() );MB_CHK_SET_ERR( rval, "can't load input file" ); 00052 00053 Core* mb2 = new Core(); 00054 rval = mb2->load_file( sourcefile.c_str() );MB_CHK_SET_ERR( rval, "can't load source file" ); 00055 00056 // get vertices on ini mesh; get global id on ini mesh 00057 // get global id on source mesh 00058 Tag gid; 00059 Tag gid2; 00060 rval = mb->tag_get_handle( "GLOBAL_ID", gid );MB_CHK_SET_ERR( rval, "can't get GLOBAL_ID tag on ini mesh " ); 00061 rval = mb2->tag_get_handle( "GLOBAL_ID", gid2 );MB_CHK_SET_ERR( rval, "can't get GLOBAL_ID tag on source mesh " ); 00062 00063 // get vertices on ini mesh; build 00064 Range iniVerts; 00065 rval = mb->get_entities_by_dimension( 0, 0, iniVerts );MB_CHK_SET_ERR( rval, "can't get verts on initial mesh " ); 00066 00067 std::vector< int > gids; 00068 gids.resize( iniVerts.size() ); 00069 rval = mb->tag_get_data( gid, iniVerts, &( gids[0] ) );MB_CHK_SET_ERR( rval, "can't get gid on initial verts " ); 00070 // build now the map 00071 std::map< int, EntityHandle > fromGidToEh; 00072 int i = 0; 00073 for( Range::iterator vit = iniVerts.begin(); vit != iniVerts.end(); ++vit, i++ ) 00074 { 00075 fromGidToEh[gids[i]] = *vit; 00076 } 00077 // now get the source verts, and tags, and set it on new mesh 00078 00079 Range sourceVerts; 00080 rval = mb2->get_entities_by_dimension( 0, 0, sourceVerts );MB_CHK_SET_ERR( rval, "can't get verts on source mesh " ); 00081 std::vector< int > gids2; 00082 gids2.resize( sourceVerts.size() ); 00083 rval = mb2->tag_get_data( gid2, sourceVerts, &( gids2[0] ) );MB_CHK_SET_ERR( rval, "can't get gid2 on cloud mesh " ); 00084 std::map< int, EntityHandle > fromGid2ToEh; 00085 i = 0; 00086 for( Range::iterator vit = sourceVerts.begin(); vit != sourceVerts.end(); ++vit, i++ ) 00087 { 00088 fromGid2ToEh[gids2[i]] = *vit; 00089 } 00090 00091 Range usedVerts; 00092 for( size_t i = 0; i < gids2.size(); i++ ) 00093 { 00094 int globalId = gids2[i]; 00095 EntityHandle usedVert = fromGidToEh[globalId]; 00096 usedVerts.insert( usedVert ); 00097 } 00098 Range cells; 00099 rval = mb->get_adjacencies( usedVerts, 2, false, cells, Interface::UNION );MB_CHK_SET_ERR( rval, "can't get adj cells " ); 00100 00101 // now create a new cell in mb2 for each one in mb 00102 for( Range::iterator cit = cells.begin(); cit != cells.end(); ++cit ) 00103 { 00104 EntityHandle cell = *cit; 00105 int nnodes = 0; 00106 const EntityHandle* conn = NULL; 00107 rval = mb->get_connectivity( cell, conn, nnodes );MB_CHK_SET_ERR( rval, "can't get connectivity " ); 00108 00109 std::vector< EntityHandle > nconn( nnodes ); 00110 bool goodCell = true; 00111 for( int i = 0; i < nnodes; i++ ) 00112 { 00113 EntityHandle v = conn[i]; 00114 int index = iniVerts.index( v ); 00115 if( index < 0 ) goodCell = false; 00116 int id = gids[index]; 00117 if( fromGid2ToEh.find( id ) == fromGid2ToEh.end() ) 00118 goodCell = false; 00119 else 00120 nconn[i] = fromGid2ToEh[id]; 00121 } 00122 if( !goodCell ) continue; 00123 EntityType type = MBTRI; 00124 if( nnodes == 3 ) 00125 type = MBTRI; 00126 else if( nnodes == 4 ) 00127 type = MBQUAD; 00128 else if( nnodes > 4 ) 00129 type = MBPOLYGON; 00130 EntityHandle nel; 00131 rval = mb2->create_element( type, &nconn[0], nnodes, nel );MB_CHK_SET_ERR( rval, "can't create new cell " ); 00132 } 00133 // save file 00134 rval = mb2->write_file( outfile.c_str() );MB_CHK_SET_ERR( rval, "can't write file" ); 00135 00136 delete mb; 00137 delete mb2; 00138 00139 return 0; 00140 }
