MOAB: Mesh Oriented datABase
(version 5.4.1)
00001 /* 00002 * MOAB, a Mesh-Oriented datABase, is a software component for creating, 00003 * storing and accessing finite element mesh data. 00004 * 00005 * Copyright 2004 Sandia Corporation. Under the terms of Contract 00006 * DE-AC04-94AL85000 with Sandia Corporation, the U.S. Government 00007 * retains certain rights in this software. 00008 * 00009 * This library is free software; you can redistribute it and/or 00010 * modify it under the terms of the GNU Lesser General Public 00011 * License as published by the Free Software Foundation; either 00012 * version 2.1 of the License, or (at your option) any later version. 00013 */ 00014 00015 /**\file Matrix3.hpp 00016 *\author Jason Kraftcheck ([email protected]) 00017 *\date 2006-07-18 00018 *\date 2012-08-2 Updated by rhl to be more generic. less code that does more! 00019 * TODO: Remove all 'inline' keywords as it is only a suggestion to the compiler 00020 * anyways, and it will ignore it or add it when it thinks its necessary. 00021 *\date 2016-08-03 Updated to use Eigen3 support underneath to improve performance 00022 */ 00023 00024 #ifndef MOAB_MATRIX3_HPP 00025 #define MOAB_MATRIX3_HPP 00026 00027 #include <iostream> 00028 #include <iosfwd> 00029 #include <limits> 00030 #include <cmath> 00031 #include <cassert> 00032 00033 #include "moab/MOABConfig.h" 00034 #include "moab/ErrorHandler.hpp" 00035 #include "moab/Util.hpp" 00036 #include "moab/Types.hpp" 00037 #include "moab/CartVect.hpp" 00038 00039 #ifndef MOAB_HAVE_LAPACK 00040 00041 #ifndef MOAB_HAVE_EIGEN3 00042 #error Need either Eigen3 or BLAS/LAPACK libraries 00043 #endif 00044 00045 #ifdef __GNUC__ 00046 // save diagnostic state 00047 #pragma GCC diagnostic push 00048 // turn off the specific warning. Can also use "-Wshadow" 00049 #pragma GCC diagnostic ignored "-Wshadow" 00050 #endif 00051 00052 #define EIGEN_DEFAULT_TO_ROW_MAJOR 00053 #define EIGEN_INITIALIZE_MATRICES_BY_ZERO 00054 // #define EIGEN_NO_STATIC_ASSERT 00055 #include "Eigen/Dense" 00056 00057 #ifdef __GNUC__ 00058 // turn the warnings back on 00059 #pragma GCC diagnostic pop 00060 #endif 00061 00062 #else 00063 00064 #if defined( MOAB_FC_FUNC_ ) 00065 #define MOAB_FC_WRAPPER MOAB_FC_FUNC_ 00066 #elif defined( MOAB_FC_FUNC ) 00067 #define MOAB_FC_WRAPPER MOAB_FC_FUNC 00068 #else 00069 #define MOAB_FC_WRAPPER( name, NAME ) name##_ 00070 #endif 00071 00072 // We will rely on LAPACK directly 00073 00074 #ifdef WIN32 00075 00076 // Should use second form below for windows but 00077 // needed to do this to make it work. 00078 // TODO: Need to clean this up 00079 #define MOAB_dsyevd MOAB_FC_FUNC( dsyevd, DSYEVD ) 00080 #define MOAB_dsyevr MOAB_FC_FUNC( dsyevr, DSYEVR ) 00081 #define MOAB_dgeev MOAB_FC_FUNC( dgeev, DGEEV ) 00082 #define MOAB_dgetrf MOAB_FC_FUNC( dgetrf, DGETRF ) 00083 #define MOAB_dgetri MOAB_FC_FUNC( dgetri, DGETRI ) 00084 00085 #else 00086 00087 #define MOAB_dsyevd MOAB_FC_WRAPPER( dsyevd, DSYEVD ) 00088 #define MOAB_dsyevr MOAB_FC_WRAPPER( dsyevr, DSYEVR ) 00089 #define MOAB_dgeev MOAB_FC_WRAPPER( dgeev, DGEEV ) 00090 #define MOAB_dgetrf MOAB_FC_WRAPPER( dgetrf, DGETRF ) 00091 #define MOAB_dgetri MOAB_FC_WRAPPER( dgetri, DGETRI ) 00092 00093 #endif 00094 00095 extern "C" { 00096 00097 // Computes all eigenvalues and, optionally, eigenvectors of a 00098 // real symmetric matrix A. If eigenvectors are desired, it uses a 00099 // divide and conquer algorithm. 00100 void MOAB_dsyevd( char* jobz, 00101 char* uplo, 00102 int* n, 00103 double a[], 00104 int* lda, 00105 double w[], 00106 double work[], 00107 int* lwork, 00108 int iwork[], 00109 int* liwork, 00110 int* info ); 00111 00112 // Computes selected eigenvalues and, optionally, eigenvectors 00113 // of a real symmetric matrix A. Eigenvalues and eigenvectors can be 00114 // selected by specifying either a range of values or a range of 00115 // indices for the desired eigenvalues. 00116 void MOAB_dsyevr( char* jobz, 00117 char* range, 00118 char* uplo, 00119 int* n, 00120 double* a, 00121 int* lda, 00122 double* vl, 00123 double* vu, 00124 int* il, 00125 int* iu, 00126 double* abstol, 00127 int* m, 00128 double* w, 00129 double* z, 00130 int* ldz, 00131 int* isuppz, 00132 double* work, 00133 int* lwork, 00134 int* iwork, 00135 int* liwork, 00136 int* info ); 00137 00138 // Computes for an N-by-N real nonsymmetric matrix A, the 00139 // eigenvalues and, optionally, the left and/or right eigenvectors. 00140 void MOAB_dgeev( char* jobvl, 00141 char* jobvr, 00142 int* n, 00143 double* a, 00144 int* lda, 00145 double* wr, 00146 double* wi, 00147 double* vl, 00148 int* ldvl, 00149 double* vr, 00150 int* ldvr, 00151 double* work, 00152 int* lwork, 00153 int* info ); 00154 00155 // Computes an LU factorization of a general M-by-N matrix A 00156 // using partial pivoting with row interchanges. 00157 void MOAB_dgetrf( int* M, int* N, double* A, int* lda, int* IPIV, int* INFO ); 00158 00159 // Computes the inverse of a matrix using the LU factorization 00160 // computed by DGETRF. 00161 void MOAB_dgetri( int* N, double* A, int* lda, int* IPIV, double* WORK, int* lwork, int* INFO ); 00162 } 00163 00164 #include <cstring> 00165 #define MOAB_DMEMZERO( a, b ) memset( a, 0, ( b ) * sizeof( double ) ) 00166 00167 #endif 00168 00169 namespace moab 00170 { 00171 00172 namespace Matrix 00173 { 00174 00175 template < typename Matrix > 00176 inline Matrix mmult3( const Matrix& a, const Matrix& b ) 00177 { 00178 return Matrix( a( 0, 0 ) * b( 0, 0 ) + a( 0, 1 ) * b( 1, 0 ) + a( 0, 2 ) * b( 2, 0 ), 00179 a( 0, 0 ) * b( 0, 1 ) + a( 0, 1 ) * b( 1, 1 ) + a( 0, 2 ) * b( 2, 1 ), 00180 a( 0, 0 ) * b( 0, 2 ) + a( 0, 1 ) * b( 1, 2 ) + a( 0, 2 ) * b( 2, 2 ), 00181 a( 1, 0 ) * b( 0, 0 ) + a( 1, 1 ) * b( 1, 0 ) + a( 1, 2 ) * b( 2, 0 ), 00182 a( 1, 0 ) * b( 0, 1 ) + a( 1, 1 ) * b( 1, 1 ) + a( 1, 2 ) * b( 2, 1 ), 00183 a( 1, 0 ) * b( 0, 2 ) + a( 1, 1 ) * b( 1, 2 ) + a( 1, 2 ) * b( 2, 2 ), 00184 a( 2, 0 ) * b( 0, 0 ) + a( 2, 1 ) * b( 1, 0 ) + a( 2, 2 ) * b( 2, 0 ), 00185 a( 2, 0 ) * b( 0, 1 ) + a( 2, 1 ) * b( 1, 1 ) + a( 2, 2 ) * b( 2, 1 ), 00186 a( 2, 0 ) * b( 0, 2 ) + a( 2, 1 ) * b( 1, 2 ) + a( 2, 2 ) * b( 2, 2 ) ); 00187 } 00188 00189 template < typename Matrix > 00190 inline const Matrix inverse( const Matrix& d ) 00191 { 00192 const double det = 1.0 / determinant3( d ); 00193 return inverse( d, det ); 00194 } 00195 00196 template < typename Vector, typename Matrix > 00197 inline Vector vector_matrix( const Vector& v, const Matrix& m ) 00198 { 00199 return Vector( v[0] * m( 0, 0 ) + v[1] * m( 1, 0 ) + v[2] * m( 2, 0 ), 00200 v[0] * m( 0, 1 ) + v[1] * m( 1, 1 ) + v[2] * m( 2, 1 ), 00201 v[0] * m( 0, 2 ) + v[1] * m( 1, 2 ) + v[2] * m( 2, 2 ) ); 00202 } 00203 00204 template < typename Vector, typename Matrix > 00205 inline Vector matrix_vector( const Matrix& m, const Vector& v ) 00206 { 00207 Vector res = v; 00208 res[0] = v[0] * m( 0, 0 ) + v[1] * m( 0, 1 ) + v[2] * m( 0, 2 ); 00209 res[1] = v[0] * m( 1, 0 ) + v[1] * m( 1, 1 ) + v[2] * m( 1, 2 ); 00210 res[2] = v[0] * m( 2, 0 ) + v[1] * m( 2, 1 ) + v[2] * m( 2, 2 ); 00211 return res; 00212 } 00213 00214 } // namespace Matrix 00215 00216 class Matrix3 00217 { 00218 00219 public: 00220 const static int size = 9; 00221 00222 private: 00223 #ifndef MOAB_HAVE_LAPACK 00224 Eigen::Matrix3d _mat; 00225 #else 00226 double _mat[size]; 00227 #endif 00228 00229 public: 00230 // Default Constructor 00231 inline Matrix3() 00232 { 00233 #ifndef MOAB_HAVE_LAPACK 00234 _mat.fill( 0.0 ); 00235 #else 00236 MOAB_DMEMZERO( _mat, Matrix3::size ); 00237 #endif 00238 } 00239 00240 #ifndef MOAB_HAVE_LAPACK 00241 inline Matrix3( Eigen::Matrix3d mat ) : _mat( mat ) {} 00242 #endif 00243 00244 // TODO: Deprecate this. 00245 // Then we can go from three Constructors to one. 00246 inline Matrix3( double diagonal ) 00247 { 00248 #ifndef MOAB_HAVE_LAPACK 00249 _mat << diagonal, 0.0, 0.0, 0.0, diagonal, 0.0, 0.0, 0.0, diagonal; 00250 #else 00251 MOAB_DMEMZERO( _mat, Matrix3::size ); 00252 _mat[0] = _mat[4] = _mat[8] = diagonal; 00253 #endif 00254 } 00255 00256 inline Matrix3( const CartVect& diagonal ) 00257 { 00258 #ifndef MOAB_HAVE_LAPACK 00259 _mat << diagonal[0], 0.0, 0.0, 0.0, diagonal[1], 0.0, 0.0, 0.0, diagonal[2]; 00260 #else 00261 MOAB_DMEMZERO( _mat, Matrix3::size ); 00262 _mat[0] = diagonal[0]; 00263 _mat[4] = diagonal[1]; 00264 _mat[8] = diagonal[2]; 00265 #endif 00266 } 00267 00268 // TODO: not strictly correct as the Matrix3 object 00269 // is a double d[ 9] so the only valid model of T is 00270 // double, or any refinement (int, float) 00271 //*but* it doesn't really matter anything else 00272 // will fail to compile. 00273 inline Matrix3( const std::vector< double >& diagonal ) 00274 { 00275 #ifndef MOAB_HAVE_LAPACK 00276 _mat << diagonal[0], 0.0, 0.0, 0.0, diagonal[1], 0.0, 0.0, 0.0, diagonal[2]; 00277 #else 00278 MOAB_DMEMZERO( _mat, Matrix3::size ); 00279 _mat[0] = diagonal[0]; 00280 _mat[4] = diagonal[1]; 00281 _mat[8] = diagonal[2]; 00282 #endif 00283 } 00284 00285 inline Matrix3( double v00, 00286 double v01, 00287 double v02, 00288 double v10, 00289 double v11, 00290 double v12, 00291 double v20, 00292 double v21, 00293 double v22 ) 00294 { 00295 #ifndef MOAB_HAVE_LAPACK 00296 _mat << v00, v01, v02, v10, v11, v12, v20, v21, v22; 00297 #else 00298 MOAB_DMEMZERO( _mat, Matrix3::size ); 00299 _mat[0] = v00; 00300 _mat[1] = v01; 00301 _mat[2] = v02; 00302 _mat[3] = v10; 00303 _mat[4] = v11; 00304 _mat[5] = v12; 00305 _mat[6] = v20; 00306 _mat[7] = v21; 00307 _mat[8] = v22; 00308 #endif 00309 } 00310 00311 // Copy constructor 00312 Matrix3( const Matrix3& f ) 00313 { 00314 #ifndef MOAB_HAVE_LAPACK 00315 _mat = f._mat; 00316 #else 00317 memcpy( _mat, f._mat, size * sizeof( double ) ); 00318 #endif 00319 } 00320 00321 // Weird constructors 00322 template < typename Vector > 00323 inline Matrix3( const Vector& row0, const Vector& row1, const Vector& row2, const bool isRow ) 00324 { 00325 #ifndef MOAB_HAVE_LAPACK 00326 if( isRow ) 00327 { 00328 _mat << row0[0], row0[1], row0[2], row1[0], row1[1], row1[2], row2[0], row2[1], row2[2]; 00329 } 00330 else 00331 { 00332 _mat << row0[0], row1[0], row2[0], row0[1], row1[1], row2[1], row0[2], row1[2], row2[2]; 00333 } 00334 #else 00335 MOAB_DMEMZERO( _mat, Matrix3::size ); 00336 if( isRow ) 00337 { 00338 _mat[0] = row0[0]; 00339 _mat[1] = row0[1]; 00340 _mat[2] = row0[2]; 00341 _mat[3] = row1[0]; 00342 _mat[4] = row1[1]; 00343 _mat[5] = row1[2]; 00344 _mat[6] = row2[0]; 00345 _mat[7] = row2[1]; 00346 _mat[8] = row2[2]; 00347 } 00348 else 00349 { 00350 _mat[0] = row0[0]; 00351 _mat[1] = row1[0]; 00352 _mat[2] = row2[0]; 00353 _mat[3] = row0[1]; 00354 _mat[4] = row1[1]; 00355 _mat[5] = row2[1]; 00356 _mat[6] = row0[2]; 00357 _mat[7] = row1[2]; 00358 _mat[8] = row2[2]; 00359 } 00360 #endif 00361 } 00362 00363 #ifndef DEPRECATED 00364 #ifdef __GNUC__ 00365 #define DEPRECATED __attribute__( ( deprecated ) ) 00366 #else 00367 #pragma message( "WARNING: You need to implement DEPRECATED for this compiler" ) 00368 #define DEPRECATED 00369 #endif 00370 #endif 00371 00372 /* 00373 * \deprecated { Use instead the constructor with explicit fourth argument, bool isRow, above } 00374 * 00375 */ 00376 inline Matrix3( const double v[size] ) 00377 { 00378 #ifndef MOAB_HAVE_LAPACK 00379 _mat << v[0], v[1], v[2], v[3], v[4], v[5], v[6], v[7], v[8]; 00380 #else 00381 memcpy( _mat, v, size * sizeof( double ) ); 00382 #endif 00383 } 00384 00385 inline void copyto( double v[Matrix3::size] ) 00386 { 00387 #ifndef MOAB_HAVE_LAPACK 00388 std::copy( _mat.data(), _mat.data() + size, v ); 00389 #else 00390 memcpy( v, _mat, size * sizeof( double ) ); 00391 #endif 00392 } 00393 00394 inline Matrix3& operator=( const Matrix3& m ) 00395 { 00396 #ifndef MOAB_HAVE_LAPACK 00397 _mat = m._mat; 00398 #else 00399 memcpy( _mat, m._mat, size * sizeof( double ) ); 00400 #endif 00401 return *this; 00402 } 00403 00404 inline Matrix3& operator=( const double v[size] ) 00405 { 00406 #ifndef MOAB_HAVE_LAPACK 00407 _mat << v[0], v[1], v[2], v[3], v[4], v[5], v[6], v[7], v[8]; 00408 #else 00409 memcpy( _mat, v, size * sizeof( double ) ); 00410 #endif 00411 return *this; 00412 } 00413 00414 inline double* operator[]( unsigned i ) 00415 { 00416 #ifndef MOAB_HAVE_LAPACK 00417 return _mat.row( i ).data(); 00418 #else 00419 return &_mat[i * 3]; // Row Major 00420 #endif 00421 } 00422 00423 inline const double* operator[]( unsigned i ) const 00424 { 00425 #ifndef MOAB_HAVE_LAPACK 00426 return _mat.row( i ).data(); 00427 #else 00428 return &_mat[i * 3]; 00429 #endif 00430 } 00431 00432 inline double& operator()( unsigned r, unsigned c ) 00433 { 00434 #ifndef MOAB_HAVE_LAPACK 00435 return _mat( r, c ); 00436 #else 00437 return _mat[r * 3 + c]; 00438 #endif 00439 } 00440 00441 inline double operator()( unsigned r, unsigned c ) const 00442 { 00443 #ifndef MOAB_HAVE_LAPACK 00444 return _mat( r, c ); 00445 #else 00446 return _mat[r * 3 + c]; 00447 #endif 00448 } 00449 00450 inline double& operator()( unsigned i ) 00451 { 00452 #ifndef MOAB_HAVE_LAPACK 00453 return _mat( i ); 00454 #else 00455 return _mat[i]; 00456 #endif 00457 } 00458 00459 inline double operator()( unsigned i ) const 00460 { 00461 #ifndef MOAB_HAVE_LAPACK 00462 return _mat( i ); 00463 #else 00464 return _mat[i]; 00465 #endif 00466 } 00467 00468 // get pointer to array of nine doubles 00469 inline double* array() 00470 { 00471 #ifndef MOAB_HAVE_LAPACK 00472 return _mat.data(); 00473 #else 00474 return _mat; 00475 #endif 00476 } 00477 00478 inline const double* array() const 00479 { 00480 #ifndef MOAB_HAVE_LAPACK 00481 return _mat.data(); 00482 #else 00483 return _mat; 00484 #endif 00485 } 00486 00487 inline Matrix3& operator+=( const Matrix3& m ) 00488 { 00489 #ifndef MOAB_HAVE_LAPACK 00490 _mat += m._mat; 00491 #else 00492 for( int i = 0; i < Matrix3::size; ++i ) 00493 _mat[i] += m._mat[i]; 00494 #endif 00495 return *this; 00496 } 00497 00498 inline Matrix3& operator-=( const Matrix3& m ) 00499 { 00500 #ifndef MOAB_HAVE_LAPACK 00501 _mat -= m._mat; 00502 #else 00503 for( int i = 0; i < Matrix3::size; ++i ) 00504 _mat[i] -= m._mat[i]; 00505 #endif 00506 return *this; 00507 } 00508 00509 inline Matrix3& operator*=( double s ) 00510 { 00511 #ifndef MOAB_HAVE_LAPACK 00512 _mat *= s; 00513 #else 00514 for( int i = 0; i < Matrix3::size; ++i ) 00515 _mat[i] *= s; 00516 #endif 00517 return *this; 00518 } 00519 00520 inline Matrix3& operator/=( double s ) 00521 { 00522 #ifndef MOAB_HAVE_LAPACK 00523 _mat /= s; 00524 #else 00525 for( int i = 0; i < Matrix3::size; ++i ) 00526 _mat[i] /= s; 00527 #endif 00528 return *this; 00529 } 00530 00531 inline Matrix3& operator*=( const Matrix3& m ) 00532 { 00533 #ifndef MOAB_HAVE_LAPACK 00534 _mat *= m._mat; 00535 #else 00536 // Uncomment below if you want point-wise multiplication instead (.*) 00537 // for (int i=0; i < Matrix3::size; ++i) _mat[i] *= m._mat[i]; 00538 std::vector< double > dmat; 00539 dmat.assign( _mat, _mat + size ); 00540 _mat[0] = dmat[0] * m._mat[0] + dmat[1] * m._mat[3] + dmat[2] * m._mat[6]; 00541 _mat[1] = dmat[0] * m._mat[1] + dmat[1] * m._mat[4] + dmat[2] * m._mat[7]; 00542 _mat[2] = dmat[0] * m._mat[2] + dmat[1] * m._mat[5] + dmat[2] * m._mat[8]; 00543 _mat[3] = dmat[3] * m._mat[0] + dmat[4] * m._mat[3] + dmat[5] * m._mat[6]; 00544 _mat[4] = dmat[3] * m._mat[1] + dmat[4] * m._mat[4] + dmat[5] * m._mat[7]; 00545 _mat[5] = dmat[3] * m._mat[2] + dmat[4] * m._mat[5] + dmat[5] * m._mat[8]; 00546 _mat[6] = dmat[6] * m._mat[0] + dmat[7] * m._mat[3] + dmat[8] * m._mat[6]; 00547 _mat[7] = dmat[6] * m._mat[1] + dmat[7] * m._mat[4] + dmat[8] * m._mat[7]; 00548 _mat[8] = dmat[6] * m._mat[2] + dmat[7] * m._mat[5] + dmat[8] * m._mat[8]; 00549 #endif 00550 return *this; 00551 } 00552 00553 inline bool is_symmetric() 00554 { 00555 const double EPS = 1e-13; 00556 #ifndef MOAB_HAVE_LAPACK 00557 if( ( fabs( _mat( 1 ) - _mat( 3 ) ) < EPS ) && ( fabs( _mat( 2 ) - _mat( 6 ) ) < EPS ) && 00558 ( fabs( _mat( 5 ) - _mat( 7 ) ) < EPS ) ) 00559 return true; 00560 #else 00561 if( ( fabs( _mat[1] - _mat[3] ) < EPS ) && ( fabs( _mat[2] - _mat[6] ) < EPS ) && 00562 ( fabs( _mat[5] - _mat[7] ) < EPS ) ) 00563 return true; 00564 #endif 00565 else 00566 return false; 00567 } 00568 00569 inline bool is_positive_definite() 00570 { 00571 #ifndef MOAB_HAVE_LAPACK 00572 double subdet6 = _mat( 1 ) * _mat( 5 ) - _mat( 2 ) * _mat( 4 ); 00573 double subdet7 = _mat( 2 ) * _mat( 3 ) - _mat( 0 ) * _mat( 5 ); 00574 double subdet8 = _mat( 0 ) * _mat( 4 ) - _mat( 1 ) * _mat( 3 ); 00575 // Determinant:= d(6)*subdet6 + d(7)*subdet7 + d(8)*subdet8; 00576 const double det = _mat( 6 ) * subdet6 + _mat( 7 ) * subdet7 + _mat( 8 ) * subdet8; 00577 return _mat( 0 ) > 0 && subdet8 > 0 && det > 0; 00578 #else 00579 double subdet6 = _mat[1] * _mat[5] - _mat[2] * _mat[4]; 00580 double subdet7 = _mat[2] * _mat[3] - _mat[0] * _mat[5]; 00581 double subdet8 = _mat[0] * _mat[4] - _mat[1] * _mat[3]; 00582 // Determinant:= d(6)*subdet6 + d(7)*subdet7 + d(8)*subdet8; 00583 const double det = _mat[6] * subdet6 + _mat[7] * subdet7 + _mat[8] * subdet8; 00584 return _mat[0] > 0 && subdet8 > 0 && det > 0; 00585 #endif 00586 } 00587 00588 template < typename Vector > 00589 inline ErrorCode eigen_decomposition( Vector& evals, Matrix3& evecs ) 00590 { 00591 const bool bisSymmetric = this->is_symmetric(); 00592 #ifndef MOAB_HAVE_LAPACK 00593 if( bisSymmetric ) 00594 { 00595 Eigen::SelfAdjointEigenSolver< Eigen::Matrix3d > eigensolver( this->_mat ); 00596 if( eigensolver.info() != Eigen::Success ) return MB_FAILURE; 00597 const Eigen::SelfAdjointEigenSolver< Eigen::Matrix3d >::RealVectorType& e3evals = eigensolver.eigenvalues(); 00598 evals[0] = e3evals( 0 ); 00599 evals[1] = e3evals( 1 ); 00600 evals[2] = e3evals( 2 ); 00601 evecs._mat = eigensolver.eigenvectors(); //.col(1) 00602 return MB_SUCCESS; 00603 } 00604 else 00605 { 00606 MB_CHK_SET_ERR( MB_FAILURE, "Unsymmetric matrix implementation with Eigen3 is currently not provided." ); 00607 // Eigen::EigenSolver<Eigen::Matrix3d> eigensolver(this->_mat, true); 00608 // if (eigensolver.info() != Eigen::Success) 00609 // return MB_FAILURE; 00610 // const Eigen::EigenSolver<Eigen::Matrix3d>::EigenvalueType& e3evals = 00611 // eigensolver.eigenvalues().real(); evals[0] = e3evals(0); evals[1] = e3evals(1); 00612 // evals[2] = e3evals(2); evecs._mat = eigensolver.eigenvectors().real(); //.col(1) 00613 // return MB_SUCCESS; 00614 } 00615 #else 00616 int info; 00617 /* Solve eigenproblem */ 00618 double devreal[3], drevecs[9]; 00619 if( !bisSymmetric ) 00620 { 00621 double devimag[3], dlevecs[9], dwork[102]; 00622 char dgeev_opts[2] = { 'N', 'V' }; 00623 int N = 3, LWORK = 102, NL = 1, NR = N; 00624 std::vector< double > devmat; 00625 devmat.assign( _mat, _mat + size ); 00626 MOAB_dgeev( &dgeev_opts[0], &dgeev_opts[1], &N, &devmat[0], &N, devreal, devimag, dlevecs, &NL, drevecs, 00627 &NR, dwork, &LWORK, &info ); 00628 // The result eigenvalues are ordered as high-->low 00629 evals[0] = devreal[2]; 00630 evals[1] = devreal[1]; 00631 evals[2] = devreal[0]; 00632 evecs._mat[0] = drevecs[6]; 00633 evecs._mat[1] = drevecs[3]; 00634 evecs._mat[2] = drevecs[0]; 00635 evecs._mat[3] = drevecs[7]; 00636 evecs._mat[4] = drevecs[4]; 00637 evecs._mat[5] = drevecs[1]; 00638 evecs._mat[6] = drevecs[8]; 00639 evecs._mat[7] = drevecs[5]; 00640 evecs._mat[8] = drevecs[2]; 00641 std::cout << "DGEEV: Optimal work vector: dsize = " << dwork[0] << ".\n"; 00642 } 00643 else 00644 { 00645 char dgeev_opts[2] = { 'V', 'L' }; 00646 const bool find_optimal = false; 00647 std::vector< int > iwork( 18 ); 00648 std::vector< double > devmat( 9, 0.0 ); 00649 std::vector< double > dwork( 38 ); 00650 int N = 3, lwork = 38, liwork = 18; 00651 devmat[0] = _mat[0]; 00652 devmat[1] = _mat[1]; 00653 devmat[2] = _mat[2]; 00654 devmat[4] = _mat[4]; 00655 devmat[5] = _mat[5]; 00656 devmat[8] = _mat[8]; 00657 if( find_optimal ) 00658 { 00659 int _lwork = -1; 00660 int _liwork = -1; 00661 double query_work_size = 0; 00662 int query_iwork_size = 0; 00663 // Make an empty call to find the optimal work vector size 00664 MOAB_dsyevd( &dgeev_opts[0], &dgeev_opts[1], &N, NULL, &N, NULL, &query_work_size, &_lwork, 00665 &query_iwork_size, &_liwork, &info ); 00666 lwork = (int)query_work_size; 00667 dwork.resize( lwork ); 00668 liwork = query_iwork_size; 00669 iwork.resize( liwork ); 00670 std::cout << "DSYEVD: Optimal work vector: dsize = " << lwork << ", and isize = " << liwork << ".\n"; 00671 } 00672 00673 MOAB_dsyevd( &dgeev_opts[0], &dgeev_opts[1], &N, &devmat[0], &N, devreal, &dwork[0], &lwork, &iwork[0], 00674 &liwork, &info ); 00675 for( int i = 0; i < 9; ++i ) 00676 drevecs[i] = devmat[i]; 00677 // The result eigenvalues are ordered as low-->high, but vectors are in rows of A. 00678 evals[0] = devreal[0]; 00679 evals[1] = devreal[1]; 00680 evals[2] = devreal[2]; 00681 evecs._mat[0] = drevecs[0]; 00682 evecs._mat[3] = drevecs[1]; 00683 evecs._mat[6] = drevecs[2]; 00684 evecs._mat[1] = drevecs[3]; 00685 evecs._mat[4] = drevecs[4]; 00686 evecs._mat[7] = drevecs[5]; 00687 evecs._mat[2] = drevecs[6]; 00688 evecs._mat[5] = drevecs[7]; 00689 evecs._mat[8] = drevecs[8]; 00690 } 00691 00692 if( !info ) 00693 { 00694 return MB_SUCCESS; 00695 } 00696 else 00697 { 00698 std::cout << "Failure in LAPACK_" << ( bisSymmetric ? "DSYEVD" : "DGEEV" ) 00699 << " call for eigen decomposition.\n"; 00700 std::cout << "Failed with error = " << info << ".\n"; 00701 return MB_FAILURE; 00702 } 00703 #endif 00704 } 00705 00706 inline void transpose_inplace() 00707 { 00708 #ifndef MOAB_HAVE_LAPACK 00709 _mat.transposeInPlace(); 00710 #else 00711 Matrix3 mtmp( *this ); 00712 _mat[1] = mtmp._mat[3]; 00713 _mat[3] = mtmp._mat[1]; 00714 _mat[2] = mtmp._mat[6]; 00715 _mat[6] = mtmp._mat[2]; 00716 _mat[5] = mtmp._mat[7]; 00717 _mat[7] = mtmp._mat[5]; 00718 #endif 00719 } 00720 00721 inline Matrix3 transpose() const 00722 { 00723 #ifndef MOAB_HAVE_LAPACK 00724 return Matrix3( _mat.transpose() ); 00725 #else 00726 Matrix3 mtmp( *this ); 00727 mtmp._mat[1] = _mat[3]; 00728 mtmp._mat[3] = _mat[1]; 00729 mtmp._mat[2] = _mat[6]; 00730 mtmp._mat[6] = _mat[2]; 00731 mtmp._mat[5] = _mat[7]; 00732 mtmp._mat[7] = _mat[5]; 00733 return mtmp; 00734 #endif 00735 } 00736 00737 template < typename Vector > 00738 inline void copycol( int index, Vector& vol ) 00739 { 00740 #ifndef MOAB_HAVE_LAPACK 00741 _mat.col( index ).swap( vol ); 00742 #else 00743 switch( index ) 00744 { 00745 case 0: 00746 _mat[0] = vol[0]; 00747 _mat[3] = vol[1]; 00748 _mat[6] = vol[2]; 00749 break; 00750 case 1: 00751 _mat[1] = vol[0]; 00752 _mat[4] = vol[1]; 00753 _mat[7] = vol[2]; 00754 break; 00755 case 2: 00756 _mat[2] = vol[0]; 00757 _mat[5] = vol[1]; 00758 _mat[8] = vol[2]; 00759 break; 00760 } 00761 #endif 00762 } 00763 00764 inline void swapcol( int srcindex, int destindex ) 00765 { 00766 assert( srcindex < Matrix3::size ); 00767 assert( destindex < Matrix3::size ); 00768 #ifndef MOAB_HAVE_LAPACK 00769 _mat.col( srcindex ).swap( _mat.col( destindex ) ); 00770 #else 00771 CartVect svol = this->vcol< CartVect >( srcindex ); 00772 CartVect dvol = this->vcol< CartVect >( destindex ); 00773 switch( srcindex ) 00774 { 00775 case 0: 00776 _mat[0] = dvol[0]; 00777 _mat[3] = dvol[1]; 00778 _mat[6] = dvol[2]; 00779 break; 00780 case 1: 00781 _mat[1] = dvol[0]; 00782 _mat[4] = dvol[1]; 00783 _mat[7] = dvol[2]; 00784 break; 00785 case 2: 00786 _mat[2] = dvol[0]; 00787 _mat[5] = dvol[1]; 00788 _mat[8] = dvol[2]; 00789 break; 00790 } 00791 switch( destindex ) 00792 { 00793 case 0: 00794 _mat[0] = svol[0]; 00795 _mat[3] = svol[1]; 00796 _mat[6] = svol[2]; 00797 break; 00798 case 1: 00799 _mat[1] = svol[0]; 00800 _mat[4] = svol[1]; 00801 _mat[7] = svol[2]; 00802 break; 00803 case 2: 00804 _mat[2] = svol[0]; 00805 _mat[5] = svol[1]; 00806 _mat[8] = svol[2]; 00807 break; 00808 } 00809 #endif 00810 } 00811 00812 template < typename Vector > 00813 inline Vector vcol( int index ) const 00814 { 00815 assert( index < Matrix3::size ); 00816 #ifndef MOAB_HAVE_LAPACK 00817 return _mat.col( index ); 00818 #else 00819 switch( index ) 00820 { 00821 case 0: 00822 return Vector( _mat[0], _mat[3], _mat[6] ); 00823 case 1: 00824 return Vector( _mat[1], _mat[4], _mat[7] ); 00825 case 2: 00826 return Vector( _mat[2], _mat[5], _mat[8] ); 00827 } 00828 return Vector( 0.0 ); 00829 #endif 00830 } 00831 00832 inline void colscale( int index, double scale ) 00833 { 00834 assert( index < Matrix3::size ); 00835 #ifndef MOAB_HAVE_LAPACK 00836 _mat.col( index ) *= scale; 00837 #else 00838 switch( index ) 00839 { 00840 case 0: 00841 _mat[0] *= scale; 00842 _mat[3] *= scale; 00843 _mat[6] *= scale; 00844 break; 00845 case 1: 00846 _mat[1] *= scale; 00847 _mat[4] *= scale; 00848 _mat[7] *= scale; 00849 break; 00850 case 2: 00851 _mat[2] *= scale; 00852 _mat[5] *= scale; 00853 _mat[8] *= scale; 00854 break; 00855 } 00856 #endif 00857 } 00858 00859 inline void rowscale( int index, double scale ) 00860 { 00861 assert( index < Matrix3::size ); 00862 #ifndef MOAB_HAVE_LAPACK 00863 _mat.row( index ) *= scale; 00864 #else 00865 switch( index ) 00866 { 00867 case 0: 00868 _mat[0] *= scale; 00869 _mat[1] *= scale; 00870 _mat[2] *= scale; 00871 break; 00872 case 1: 00873 _mat[3] *= scale; 00874 _mat[4] *= scale; 00875 _mat[5] *= scale; 00876 break; 00877 case 2: 00878 _mat[6] *= scale; 00879 _mat[7] *= scale; 00880 _mat[8] *= scale; 00881 break; 00882 } 00883 #endif 00884 } 00885 00886 inline CartVect col( int index ) const 00887 { 00888 assert( index < Matrix3::size ); 00889 #ifndef MOAB_HAVE_LAPACK 00890 Eigen::Vector3d mvec = _mat.col( index ); 00891 return CartVect( mvec[0], mvec[1], mvec[2] ); 00892 #else 00893 switch( index ) 00894 { 00895 case 0: 00896 return CartVect( _mat[0], _mat[3], _mat[6] ); 00897 case 1: 00898 return CartVect( _mat[1], _mat[4], _mat[7] ); 00899 case 2: 00900 return CartVect( _mat[2], _mat[5], _mat[8] ); 00901 } 00902 return CartVect( 0.0 ); 00903 #endif 00904 } 00905 00906 inline CartVect row( int index ) const 00907 { 00908 assert( index < Matrix3::size ); 00909 #ifndef MOAB_HAVE_LAPACK 00910 Eigen::Vector3d mvec = _mat.row( index ); 00911 return CartVect( mvec[0], mvec[1], mvec[2] ); 00912 #else 00913 switch( index ) 00914 { 00915 case 0: 00916 return CartVect( _mat[0], _mat[1], _mat[2] ); 00917 case 1: 00918 return CartVect( _mat[3], _mat[4], _mat[5] ); 00919 case 2: 00920 return CartVect( _mat[6], _mat[7], _mat[8] ); 00921 } 00922 return CartVect( 0.0 ); 00923 #endif 00924 } 00925 00926 friend Matrix3 operator+( const Matrix3& a, const Matrix3& b ); 00927 friend Matrix3 operator-( const Matrix3& a, const Matrix3& b ); 00928 friend Matrix3 operator*( const Matrix3& a, const Matrix3& b ); 00929 00930 inline double determinant() const 00931 { 00932 #ifndef MOAB_HAVE_LAPACK 00933 return _mat.determinant(); 00934 #else 00935 return ( _mat[0] * _mat[4] * _mat[8] + _mat[1] * _mat[5] * _mat[6] + _mat[2] * _mat[3] * _mat[7] - 00936 _mat[0] * _mat[5] * _mat[7] - _mat[1] * _mat[3] * _mat[8] - _mat[2] * _mat[4] * _mat[6] ); 00937 #endif 00938 } 00939 00940 inline Matrix3 inverse() const 00941 { 00942 #ifndef MOAB_HAVE_LAPACK 00943 return Matrix3( _mat.inverse() ); 00944 #else 00945 // return Matrix::compute_inverse( *this, this->determinant() ); 00946 Matrix3 m( 0.0 ); 00947 const double d_determinant = 1.0 / this->determinant(); 00948 m._mat[0] = d_determinant * ( _mat[4] * _mat[8] - _mat[5] * _mat[7] ); 00949 m._mat[1] = d_determinant * ( _mat[2] * _mat[7] - _mat[8] * _mat[1] ); 00950 m._mat[2] = d_determinant * ( _mat[1] * _mat[5] - _mat[4] * _mat[2] ); 00951 m._mat[3] = d_determinant * ( _mat[5] * _mat[6] - _mat[8] * _mat[3] ); 00952 m._mat[4] = d_determinant * ( _mat[0] * _mat[8] - _mat[6] * _mat[2] ); 00953 m._mat[5] = d_determinant * ( _mat[2] * _mat[3] - _mat[5] * _mat[0] ); 00954 m._mat[6] = d_determinant * ( _mat[3] * _mat[7] - _mat[6] * _mat[4] ); 00955 m._mat[7] = d_determinant * ( _mat[1] * _mat[6] - _mat[7] * _mat[0] ); 00956 m._mat[8] = d_determinant * ( _mat[0] * _mat[4] - _mat[3] * _mat[1] ); 00957 return m; 00958 #endif 00959 } 00960 00961 inline bool invert() 00962 { 00963 bool invertible = false; 00964 double d_determinant; 00965 #ifndef MOAB_HAVE_LAPACK 00966 Eigen::Matrix3d invMat; 00967 _mat.computeInverseAndDetWithCheck( invMat, d_determinant, invertible ); 00968 if( !Util::is_finite( d_determinant ) ) return false; 00969 _mat = invMat; 00970 return invertible; 00971 #else 00972 d_determinant = this->determinant(); 00973 if( d_determinant > 1e-13 ) invertible = true; 00974 d_determinant = 1.0 / d_determinant; // invert the determinant 00975 std::vector< double > _m; 00976 _m.assign( _mat, _mat + size ); 00977 _mat[0] = d_determinant * ( _m[4] * _m[8] - _m[5] * _m[7] ); 00978 _mat[1] = d_determinant * ( _m[2] * _m[7] - _m[8] * _m[1] ); 00979 _mat[2] = d_determinant * ( _m[1] * _m[5] - _m[4] * _m[2] ); 00980 _mat[3] = d_determinant * ( _m[5] * _m[6] - _m[8] * _m[3] ); 00981 _mat[4] = d_determinant * ( _m[0] * _m[8] - _m[6] * _m[2] ); 00982 _mat[5] = d_determinant * ( _m[2] * _m[3] - _m[5] * _m[0] ); 00983 _mat[6] = d_determinant * ( _m[3] * _m[7] - _m[6] * _m[4] ); 00984 _mat[7] = d_determinant * ( _m[1] * _m[6] - _m[7] * _m[0] ); 00985 _mat[8] = d_determinant * ( _m[0] * _m[4] - _m[3] * _m[1] ); 00986 #endif 00987 return invertible; 00988 } 00989 00990 // Calculate determinant of 2x2 submatrix composed of the 00991 // elements not in the passed row or column. 00992 inline double subdet( int r, int c ) const 00993 { 00994 assert( r >= 0 && c >= 0 ); 00995 if( r < 0 || c < 0 ) return DBL_MAX; 00996 #ifndef MOAB_HAVE_LAPACK 00997 const int r1 = ( r + 1 ) % 3, r2 = ( r + 2 ) % 3; 00998 const int c1 = ( c + 1 ) % 3, c2 = ( c + 2 ) % 3; 00999 return _mat( r1, c1 ) * _mat( r2, c2 ) - _mat( r1, c2 ) * _mat( r2, c1 ); 01000 #else 01001 const int r1 = Matrix3::size * ( ( r + 1 ) % 3 ), r2 = Matrix3::size * ( ( r + 2 ) % 3 ); 01002 const int c1 = ( c + 1 ) % 3, c2 = ( c + 2 ) % 3; 01003 return _mat[r1 + c1] * _mat[r2 + c2] - _mat[r1 + c2] * _mat[r2 + c1]; 01004 #endif 01005 } 01006 01007 inline void print( std::ostream& s ) const 01008 { 01009 #ifndef MOAB_HAVE_LAPACK 01010 s << "| " << _mat( 0 ) << " " << _mat( 1 ) << " " << _mat( 2 ) << " | " << _mat( 3 ) << " " << _mat( 4 ) << " " 01011 << _mat( 5 ) << " | " << _mat( 6 ) << " " << _mat( 7 ) << " " << _mat( 8 ) << " |"; 01012 #else 01013 s << "| " << _mat[0] << " " << _mat[1] << " " << _mat[2] << " | " << _mat[3] << " " << _mat[4] << " " << _mat[5] 01014 << " | " << _mat[6] << " " << _mat[7] << " " << _mat[8] << " |"; 01015 #endif 01016 } 01017 01018 }; // class Matrix3 01019 01020 template < typename Vector > 01021 inline Matrix3 outer_product( const Vector& u, const Vector& v ) 01022 { 01023 return Matrix3( u[0] * v[0], u[0] * v[1], u[0] * v[2], u[1] * v[0], u[1] * v[1], u[1] * v[2], u[2] * v[0], 01024 u[2] * v[1], u[2] * v[2] ); 01025 } 01026 01027 inline Matrix3 operator+( const Matrix3& a, const Matrix3& b ) 01028 { 01029 #ifndef MOAB_HAVE_LAPACK 01030 return Matrix3( a._mat + b._mat ); 01031 #else 01032 Matrix3 s( a ); 01033 for( int i = 0; i < Matrix3::size; ++i ) 01034 s( i ) += b._mat[i]; 01035 return s; 01036 #endif 01037 } 01038 01039 inline Matrix3 operator-( const Matrix3& a, const Matrix3& b ) 01040 { 01041 #ifndef MOAB_HAVE_LAPACK 01042 return Matrix3( a._mat - b._mat ); 01043 #else 01044 Matrix3 s( a ); 01045 for( int i = 0; i < Matrix3::size; ++i ) 01046 s( i ) -= b._mat[i]; 01047 return s; 01048 #endif 01049 } 01050 01051 inline Matrix3 operator*( const Matrix3& a, const Matrix3& b ) 01052 { 01053 #ifndef MOAB_HAVE_LAPACK 01054 return Matrix3( a._mat * b._mat ); 01055 #else 01056 return Matrix::mmult3( a, b ); 01057 #endif 01058 } 01059 01060 template < typename T > 01061 inline std::vector< T > operator*( const Matrix3& m, const std::vector< T >& v ) 01062 { 01063 return moab::Matrix::matrix_vector( m, v ); 01064 } 01065 01066 template < typename T > 01067 inline std::vector< T > operator*( const std::vector< T >& v, const Matrix3& m ) 01068 { 01069 return moab::Matrix::vector_matrix( v, m ); 01070 } 01071 01072 inline CartVect operator*( const Matrix3& m, const CartVect& v ) 01073 { 01074 return moab::Matrix::matrix_vector( m, v ); 01075 } 01076 01077 inline CartVect operator*( const CartVect& v, const Matrix3& m ) 01078 { 01079 return moab::Matrix::vector_matrix( v, m ); 01080 } 01081 01082 } // namespace moab 01083 01084 #ifdef MOAB_HAVE_LAPACK 01085 #undef MOAB_DMEMZERO 01086 #endif 01087 01088 #ifndef MOAB_MATRIX3_OPERATORLESS 01089 #define MOAB_MATRIX3_OPERATORLESS 01090 inline std::ostream& operator<<( std::ostream& s, const moab::Matrix3& m ) 01091 { 01092 return s << "| " << m( 0, 0 ) << " " << m( 0, 1 ) << " " << m( 0, 2 ) << " | " << m( 1, 0 ) << " " << m( 1, 1 ) 01093 << " " << m( 1, 2 ) << " | " << m( 2, 0 ) << " " << m( 2, 1 ) << " " << m( 2, 2 ) << " |"; 01094 } 01095 #endif // MOAB_MATRIX3_OPERATORLESS 01096 #endif // MOAB_MATRIX3_HPP
