moab::Util Class Reference
Utility functions for computational geometry and mathematical calculations. More...
#include <Util.hpp>
Static Public Member Functions
template<typename T >
static bool is_finite (T value)
static void normal (Interface *MB, EntityHandle handle, double &x, double &y, double &z)
static void centroid (Interface *MB, EntityHandle handle, CartVect &coord)
Private Member Functions
 Util ()
Detailed Description
Definition at line 42 of file Util.hpp.
moab::Util::Util ( ) [inline, private]
Definition at line 59 of file Util.hpp.
Member Function Documentation
void moab::Util::centroid ( Interface *  MB,
CartVect &  coord
) [static]
Definition at line 78 of file Util.cpp.
References ErrorCode, moab::Interface::get_connectivity(), moab::Interface::get_coords(), and MB_CHK_SET_ERR_RET.
    const EntityHandle* connectivity = NULL;
    int number_nodes                 = 0;
    // TODO make the return value nonvoid
    ErrorCode rval = MB->get_connectivity( handle, connectivity, number_nodes, true );MB_CHK_SET_ERR_RET( rval, "can't get_connectivity" );
    coord[0] = coord[1] = coord[2] = 0.0;
    for( int i = 0; i < number_nodes; i++ )
        double node_coords[3];
        MB->get_coords( &( connectivity[i] ), 1, node_coords );
        coord[0] += node_coords[0];
        coord[1] += node_coords[1];
        coord[2] += node_coords[2];
    coord[0] /= (double)number_nodes;
    coord[1] /= (double)number_nodes;
    coord[2] /= (double)number_nodes;
void moab::Util::normal ( Interface *  MB,
double &  x,
double &  y,
double &  z
) [static]
temporary normal function for MBEntities. This should be moved to an appropriate MB algorithms file
Definition at line 42 of file Util.cpp.
Referenced by moab::Skinner::has_larger_angle().
    // get connectivity
    assert( number_nodes >= 3 );
    // get_coordinates
    double coords[3][3];
    MB->get_coords( &( connectivity[0] ), 1, coords[0] );
    MB->get_coords( &( connectivity[1] ), 1, coords[1] );
    MB->get_coords( &( connectivity[2] ), 1, coords[2] );
    double vecs[2][3];
    vecs[0][0] = coords[1][0] - coords[0][0];
    vecs[0][1] = coords[1][1] - coords[0][1];
    vecs[0][2] = coords[1][2] - coords[0][2];
    vecs[1][0] = coords[2][0] - coords[0][0];
    vecs[1][1] = coords[2][1] - coords[0][1];
    vecs[1][2] = coords[2][2] - coords[0][2];
    x = vecs[0][1] * vecs[1][2] - vecs[0][2] * vecs[1][1];
    y = vecs[0][2] * vecs[1][0] - vecs[0][0] * vecs[1][2];
    z = vecs[0][0] * vecs[1][1] - vecs[0][1] * vecs[1][0];
    double mag = sqrt( x * x + y * y + z * z );
    if( mag > std::numeric_limits< double >::epsilon() )
        x /= mag;
        y /= mag;
        z /= mag;
List of all members.
