MOAB: Mesh Oriented datABase
(version 5.4.1)
00001 /** 00002 * MOAB, a Mesh-Oriented datABase, is a software component for creating, 00003 * storing and accessing finite element mesh data. 00004 * 00005 * Copyright 2004 Sandia Corporation. Under the terms of Contract 00006 * DE-AC04-94AL85000 with Sandia Corporation, the U.S. Government 00007 * retains certain rights in this software. 00008 * 00009 * This library is free software; you can redistribute it and/or 00010 * modify it under the terms of the GNU Lesser General Public 00011 * License as published by the Free Software Foundation; either 00012 * version 2.1 of the License, or (at your option) any later version. 00013 * 00014 */ 00015 00016 #include "ReadMCNP5.hpp" 00017 #include "moab/Interface.hpp" 00018 #include "moab/ReadUtilIface.hpp" 00019 #include "Internals.hpp" // For MB_START_ID 00020 #include "moab/Range.hpp" 00021 #include "moab/FileOptions.hpp" 00022 #include "moab/Util.hpp" 00023 00024 #include <iostream> 00025 #include <sstream> 00026 #include <fstream> 00027 #include <vector> 00028 #include <cstdlib> 00029 #include <cmath> 00030 #include <cassert> 00031 00032 namespace moab 00033 { 00034 00035 // Parameters 00036 const double ReadMCNP5::PI = 3.141592653589793; 00037 const double ReadMCNP5::C2PI = 0.1591549430918954; 00038 const double ReadMCNP5::CPI = 0.3183098861837907; 00039 00040 ReaderIface* ReadMCNP5::factory( Interface* iface ) 00041 { 00042 return new ReadMCNP5( iface ); 00043 } 00044 00045 // Constructor 00046 ReadMCNP5::ReadMCNP5( Interface* impl ) : MBI( impl ), fileIDTag( NULL ), nodeId( 0 ), elemId( 0 ) 00047 { 00048 assert( NULL != impl ); 00049 MBI->query_interface( readMeshIface ); 00050 assert( NULL != readMeshIface ); 00051 } 00052 00053 // Destructor 00054 ReadMCNP5::~ReadMCNP5() 00055 { 00056 if( readMeshIface ) 00057 { 00058 MBI->release_interface( readMeshIface ); 00059 readMeshIface = 0; 00060 } 00061 } 00062 00063 ErrorCode ReadMCNP5::read_tag_values( const char* /* file_name */, 00064 const char* /* tag_name */, 00065 const FileOptions& /* opts */, 00066 std::vector< int >& /* tag_values_out */, 00067 const SubsetList* /* subset_list */ ) 00068 { 00069 return MB_NOT_IMPLEMENTED; 00070 } 00071 00072 // Load the file as called by the Interface function 00073 ErrorCode ReadMCNP5::load_file( const char* filename, 00074 const EntityHandle* input_meshset, 00075 const FileOptions& options, 00076 const ReaderIface::SubsetList* subset_list, 00077 const Tag* file_id_tag ) 00078 { 00079 // At this time there is no support for reading a subset of the file 00080 if( subset_list ) 00081 { 00082 MB_SET_ERR( MB_UNSUPPORTED_OPERATION, "Reading subset of files not supported for meshtal" ); 00083 } 00084 00085 nodeId = elemId = 0; 00086 fileIDTag = file_id_tag; 00087 00088 // Average several meshtal files if the AVERAGE_TALLY option is given. 00089 // In this case, the integer value is the number of files to average. 00090 // If averaging, the filename passed to load_file is assumed to be the 00091 // root filename. The files are indexed as "root_filename""index".meshtal. 00092 // Indices start with 1. 00093 int n_files; 00094 bool average = false; 00095 ErrorCode result; 00096 if( MB_SUCCESS == options.get_int_option( "AVERAGE_TALLY", n_files ) ) 00097 { 00098 // Read the first file (but do not average -> can't average a single file) 00099 result = load_one_file( filename, input_meshset, options, average ); 00100 if( MB_SUCCESS != result ) return result; 00101 00102 // Get the root filename 00103 std::string root_filename( filename ); 00104 int length = root_filename.length(); 00105 root_filename.erase( length - sizeof( ".meshtal" ) ); 00106 00107 // Average the first file with the rest of the files 00108 average = true; 00109 for( int i = 2; i <= n_files; i++ ) 00110 { 00111 std::stringstream index; 00112 index << i; 00113 std::string subsequent_filename = root_filename + index.str() + ".meshtal"; 00114 result = load_one_file( subsequent_filename.c_str(), input_meshset, options, average ); 00115 if( MB_SUCCESS != result ) return result; 00116 } 00117 00118 // If not averaging, read a single file 00119 } 00120 else 00121 { 00122 result = load_one_file( filename, input_meshset, options, average ); 00123 if( MB_SUCCESS != result ) return result; 00124 } 00125 00126 return MB_SUCCESS; 00127 } 00128 00129 // This actually reads the file. It creates the mesh elements unless 00130 // the file is being averaged with a pre-existing mesh. 00131 ErrorCode ReadMCNP5::load_one_file( const char* fname, 00132 const EntityHandle* input_meshset, 00133 const FileOptions& options, 00134 const bool average ) 00135 { 00136 bool debug = false; 00137 if( debug ) std::cout << "begin ReadMCNP5::load_one_file" << std::endl; 00138 00139 ErrorCode result; 00140 std::fstream file; 00141 file.open( fname, std::fstream::in ); 00142 char line[10000]; 00143 00144 // Create tags 00145 Tag date_and_time_tag, title_tag, nps_tag, tally_number_tag, tally_comment_tag, tally_particle_tag, 00146 tally_coord_sys_tag, tally_tag, error_tag; 00147 00148 result = create_tags( date_and_time_tag, title_tag, nps_tag, tally_number_tag, tally_comment_tag, 00149 tally_particle_tag, tally_coord_sys_tag, tally_tag, error_tag ); 00150 if( MB_SUCCESS != result ) return result; 00151 00152 // ****************************************************************** 00153 // This info exists only at the top of each meshtal file 00154 // ****************************************************************** 00155 00156 // Define characteristics of the entire file 00157 char date_and_time[100] = ""; 00158 char title[100] = ""; 00159 // This file's number of particles 00160 unsigned long int nps; 00161 // Sum of this file's and existing file's nps for averaging 00162 unsigned long int new_nps; 00163 00164 // Read the file header 00165 result = read_file_header( file, debug, date_and_time, title, nps ); 00166 if( MB_SUCCESS != result ) return result; 00167 00168 // Blank line 00169 file.getline( line, 10000 ); 00170 00171 // Everything stored in the file being read will be in the input_meshset. 00172 // If this is being saved in MOAB, set header tags 00173 if( !average && 0 != input_meshset ) 00174 { 00175 result = set_header_tags( *input_meshset, date_and_time, title, nps, date_and_time_tag, title_tag, nps_tag ); 00176 if( MB_SUCCESS != result ) return result; 00177 } 00178 00179 // ****************************************************************** 00180 // This info is repeated for each tally in the meshtal file. 00181 // ****************************************************************** 00182 00183 // If averaging, nps will hold the sum of particles simulated in both tallies. 00184 while( !file.eof() ) 00185 { 00186 // Define characteristics of this tally 00187 unsigned int tally_number; 00188 char tally_comment[100] = ""; 00189 particle tally_particle; 00190 coordinate_system tally_coord_sys; 00191 std::vector< double > planes[3]; 00192 unsigned int n_chopped_x0_planes; 00193 unsigned int n_chopped_x2_planes; 00194 00195 // Read tally header 00196 result = read_tally_header( file, debug, tally_number, tally_comment, tally_particle ); 00197 if( MB_SUCCESS != result ) return result; 00198 00199 // Blank line 00200 file.getline( line, 10000 ); 00201 std::string l = line; 00202 // if this string is present then skip the following blank line 00203 if( std::string::npos != l.find( "This mesh tally is modified by a dose response function." ) ) 00204 { 00205 file.getline( line, 10000 ); 00206 } 00207 00208 // Read mesh planes 00209 result = read_mesh_planes( file, debug, planes, tally_coord_sys ); 00210 if( MB_SUCCESS != result ) return result; 00211 00212 // Get energy boundaries 00213 file.getline( line, 10000 ); 00214 std::string a = line; 00215 if( debug ) std::cout << "Energy bin boundaries:=| " << a << std::endl; 00216 00217 // Blank 00218 file.getline( line, 10000 ); 00219 00220 // Column headers 00221 file.getline( line, 10000 ); 00222 00223 // If using cylindrical mesh, it may be necessary to chop off the last theta element. 00224 // We chop off the last theta plane because the elements will be wrong and skew up 00225 // the tree building code. This is 00226 // because the hex elements are a linear approximation to the cylindrical elements. 00227 // Chopping off the last plane is problem-dependent, and due to MCNP5's mandate 00228 // that the cylindrical mesh must span 360 degrees. 00229 if( CYLINDRICAL == tally_coord_sys && MB_SUCCESS == options.get_null_option( "REMOVE_LAST_AZIMUTHAL_PLANE" ) ) 00230 { 00231 planes[2].pop_back(); 00232 n_chopped_x2_planes = 1; 00233 if( debug ) std::cout << "remove last cylindrical plane option found" << std::endl; 00234 } 00235 else 00236 { 00237 n_chopped_x2_planes = 0; 00238 } 00239 00240 // If using cylindrical mesh, it may be necessary to chop off the first radial element. 00241 // These elements extend from the axis and often do not cover areas of interest. For 00242 // example, if the mesh was meant to cover r=390-400, the first layer will go from 00243 // 0-390 and serve as incorrect source elements for interpolation. 00244 if( CYLINDRICAL == tally_coord_sys && MB_SUCCESS == options.get_null_option( "REMOVE_FIRST_RADIAL_PLANE" ) ) 00245 { 00246 std::vector< double >::iterator front = planes[0].begin(); 00247 planes[0].erase( front ); 00248 n_chopped_x0_planes = 1; 00249 if( debug ) std::cout << "remove first radial plane option found" << std::endl; 00250 } 00251 else 00252 { 00253 n_chopped_x0_planes = 0; 00254 } 00255 00256 // Read the values and errors of each element from the file. 00257 // Do not read values that are chopped off. 00258 unsigned int n_elements = ( planes[0].size() - 1 ) * ( planes[1].size() - 1 ) * ( planes[2].size() - 1 ); 00259 double* values = new double[n_elements]; 00260 double* errors = new double[n_elements]; 00261 result = read_element_values_and_errors( file, debug, planes, n_chopped_x0_planes, n_chopped_x2_planes, 00262 tally_particle, values, errors ); 00263 if( MB_SUCCESS != result ) return result; 00264 00265 // Blank line 00266 file.getline( line, 10000 ); 00267 00268 // **************************************************************** 00269 // This tally has been read. If it is not being averaged, build tags, 00270 // vertices and elements. If it is being averaged, average the data 00271 // with a tally already existing in the MOAB instance. 00272 // **************************************************************** 00273 if( !average ) 00274 { 00275 EntityHandle tally_meshset; 00276 result = MBI->create_meshset( MESHSET_SET, tally_meshset ); 00277 if( MB_SUCCESS != result ) return result; 00278 00279 // Set tags on the tally 00280 result = set_tally_tags( tally_meshset, tally_number, tally_comment, tally_particle, tally_coord_sys, 00281 tally_number_tag, tally_comment_tag, tally_particle_tag, tally_coord_sys_tag ); 00282 if( MB_SUCCESS != result ) return result; 00283 00284 // The only info needed to build elements is the mesh plane boundaries. 00285 // Build vertices... 00286 EntityHandle start_vert = 0; 00287 result = create_vertices( planes, debug, start_vert, tally_coord_sys, tally_meshset ); 00288 if( MB_SUCCESS != result ) return result; 00289 00290 // Build elements and tag them with tally values and errors, then add 00291 // them to the tally_meshset. 00292 result = create_elements( debug, planes, n_chopped_x0_planes, n_chopped_x2_planes, start_vert, values, 00293 errors, tally_tag, error_tag, tally_meshset, tally_coord_sys ); 00294 if( MB_SUCCESS != result ) return result; 00295 00296 // Add this tally's meshset to the output meshset 00297 if( debug ) std::cout << "not averaging tally" << std::endl; 00298 00299 // Average the tally values, then delete stuff that was created 00300 } 00301 else 00302 { 00303 if( debug ) std::cout << "averaging tally" << std::endl; 00304 result = average_with_existing_tally( debug, new_nps, nps, tally_number, tally_number_tag, nps_tag, 00305 tally_tag, error_tag, values, errors, n_elements ); 00306 if( MB_SUCCESS != result ) return result; 00307 } 00308 00309 // Clean up 00310 delete[] values; 00311 delete[] errors; 00312 } 00313 00314 // If we are averaging, delete the remainder of this file's information. 00315 // Add the new nps to the existing file's nps if we are averaging. 00316 // This is calculated during every tally averaging but only used after the last one. 00317 if( average ) 00318 { 00319 Range matching_nps_sets; 00320 result = MBI->get_entities_by_type_and_tag( 0, MBENTITYSET, &nps_tag, 0, 1, matching_nps_sets ); 00321 if( MB_SUCCESS != result ) return result; 00322 if( debug ) std::cout << "number of matching nps meshsets=" << matching_nps_sets.size() << std::endl; 00323 assert( 1 == matching_nps_sets.size() ); 00324 result = MBI->tag_set_data( nps_tag, matching_nps_sets, &new_nps ); 00325 if( MB_SUCCESS != result ) return result; 00326 00327 // If this file is not being averaged, return the output meshset. 00328 } 00329 00330 file.close(); 00331 return MB_SUCCESS; 00332 } 00333 00334 // create tags needed for this reader 00335 ErrorCode ReadMCNP5::create_tags( Tag& date_and_time_tag, 00336 Tag& title_tag, 00337 Tag& nps_tag, 00338 Tag& tally_number_tag, 00339 Tag& tally_comment_tag, 00340 Tag& tally_particle_tag, 00341 Tag& tally_coord_sys_tag, 00342 Tag& tally_tag, 00343 Tag& error_tag ) 00344 { 00345 ErrorCode result; 00346 result = MBI->tag_get_handle( "DATE_AND_TIME_TAG", 100, MB_TYPE_OPAQUE, date_and_time_tag, 00347 MB_TAG_SPARSE | MB_TAG_CREAT ); 00348 if( MB_SUCCESS != result ) return result; 00349 result = MBI->tag_get_handle( "TITLE_TAG", 100, MB_TYPE_OPAQUE, title_tag, MB_TAG_SPARSE | MB_TAG_CREAT ); 00350 if( MB_SUCCESS != result ) return result; 00351 result = MBI->tag_get_handle( "NPS_TAG", sizeof( unsigned long int ), MB_TYPE_OPAQUE, nps_tag, 00352 MB_TAG_SPARSE | MB_TAG_CREAT ); 00353 if( MB_SUCCESS != result ) return result; 00354 result = 00355 MBI->tag_get_handle( "TALLY_NUMBER_TAG", 1, MB_TYPE_INTEGER, tally_number_tag, MB_TAG_SPARSE | MB_TAG_CREAT ); 00356 if( MB_SUCCESS != result ) return result; 00357 result = MBI->tag_get_handle( "TALLY_COMMENT_TAG", 100, MB_TYPE_OPAQUE, tally_comment_tag, 00358 MB_TAG_SPARSE | MB_TAG_CREAT ); 00359 if( MB_SUCCESS != result ) return result; 00360 result = MBI->tag_get_handle( "TALLY_PARTICLE_TAG", sizeof( particle ), MB_TYPE_OPAQUE, tally_particle_tag, 00361 MB_TAG_SPARSE | MB_TAG_CREAT ); 00362 if( MB_SUCCESS != result ) return result; 00363 result = MBI->tag_get_handle( "TALLY_COORD_SYS_TAG", sizeof( coordinate_system ), MB_TYPE_OPAQUE, 00364 tally_coord_sys_tag, MB_TAG_SPARSE | MB_TAG_CREAT ); 00365 if( MB_SUCCESS != result ) return result; 00366 result = MBI->tag_get_handle( "TALLY_TAG", 1, MB_TYPE_DOUBLE, tally_tag, MB_TAG_DENSE | MB_TAG_CREAT ); 00367 if( MB_SUCCESS != result ) return result; 00368 result = MBI->tag_get_handle( "ERROR_TAG", 1, MB_TYPE_DOUBLE, error_tag, MB_TAG_DENSE | MB_TAG_CREAT ); 00369 if( MB_SUCCESS != result ) return result; 00370 00371 return MB_SUCCESS; 00372 } 00373 00374 ErrorCode ReadMCNP5::read_file_header( std::fstream& file, 00375 bool debug, 00376 char date_and_time[100], 00377 char title[100], 00378 unsigned long int& nps ) 00379 { 00380 // Get simulation date and time 00381 // mcnp version 5 ld=11242008 probid = 03/23/09 13:38:56 00382 char line[100]; 00383 file.getline( line, 100 ); 00384 date_and_time = line; 00385 if( debug ) std::cout << "date_and_time=| " << date_and_time << std::endl; 00386 00387 // Get simulation title 00388 // iter Module 4 00389 file.getline( line, 100 ); 00390 title = line; 00391 if( debug ) std::cout << "title=| " << title << std::endl; 00392 00393 // Get number of histories 00394 // Number of histories used for normalizing tallies = 50000000.00 00395 file.getline( line, 100 ); 00396 std::string a = line; 00397 std::string::size_type b = a.find( "Number of histories used for normalizing tallies =" ); 00398 if( std::string::npos != b ) 00399 { 00400 std::istringstream nps_ss( 00401 a.substr( b + sizeof( "Number of histories used for normalizing tallies =" ), 100 ) ); 00402 nps_ss >> nps; 00403 if( debug ) std::cout << "nps=| " << nps << std::endl; 00404 } 00405 else 00406 return MB_FAILURE; 00407 00408 return MB_SUCCESS; 00409 } 00410 00411 ErrorCode ReadMCNP5::set_header_tags( EntityHandle output_meshset, 00412 char date_and_time[100], 00413 char title[100], 00414 unsigned long int nps, 00415 Tag data_and_time_tag, 00416 Tag title_tag, 00417 Tag nps_tag ) 00418 { 00419 ErrorCode result; 00420 result = MBI->tag_set_data( data_and_time_tag, &output_meshset, 1, &date_and_time ); 00421 if( MB_SUCCESS != result ) return result; 00422 result = MBI->tag_set_data( title_tag, &output_meshset, 1, &title ); 00423 if( MB_SUCCESS != result ) return result; 00424 result = MBI->tag_set_data( nps_tag, &output_meshset, 1, &nps ); 00425 if( MB_SUCCESS != result ) return result; 00426 00427 return MB_SUCCESS; 00428 } 00429 00430 ErrorCode ReadMCNP5::read_tally_header( std::fstream& file, 00431 bool debug, 00432 unsigned int& tally_number, 00433 char tally_comment[100], 00434 particle& tally_particle ) 00435 { 00436 // Get tally number 00437 // Mesh Tally Number 104 00438 ErrorCode result; 00439 char line[100]; 00440 file.getline( line, 100 ); 00441 std::string a = line; 00442 std::string::size_type b = a.find( "Mesh Tally Number" ); 00443 if( std::string::npos != b ) 00444 { 00445 std::istringstream tally_number_ss( a.substr( b + sizeof( "Mesh Tally Number" ), 100 ) ); 00446 tally_number_ss >> tally_number; 00447 if( debug ) std::cout << "tally_number=| " << tally_number << std::endl; 00448 } 00449 else 00450 { 00451 std::cout << "tally number not found" << std::endl; 00452 return MB_FAILURE; 00453 } 00454 00455 // Next get the tally comment (optional) and particle type 00456 // 3mm neutron heating in Be (W/cc) 00457 // This is a neutron mesh tally. 00458 // std::string tally_comment; 00459 00460 // Get tally particle 00461 file.getline( line, 100 ); 00462 a = line; 00463 result = get_tally_particle( a, debug, tally_particle ); 00464 if( MB_FAILURE == result ) 00465 { 00466 // If this line does not specify the particle type, then it is a tally comment. 00467 // Get the comment, then get the particle type from the next line. 00468 tally_comment = line; 00469 file.getline( line, 100 ); 00470 a = line; 00471 result = get_tally_particle( a, debug, tally_particle ); 00472 if( MB_SUCCESS != result ) return result; 00473 } 00474 if( debug ) std::cout << "tally_comment=| " << tally_comment << std::endl; 00475 00476 return MB_SUCCESS; 00477 } 00478 00479 ErrorCode ReadMCNP5::get_tally_particle( std::string a, bool debug, particle& tally_particle ) 00480 { 00481 if( std::string::npos != a.find( "This is a neutron mesh tally." ) ) 00482 { 00483 tally_particle = NEUTRON; 00484 } 00485 else if( std::string::npos != a.find( "This is a photon mesh tally." ) ) 00486 { 00487 tally_particle = PHOTON; 00488 } 00489 else if( std::string::npos != a.find( "This is an electron mesh tally." ) ) 00490 { 00491 tally_particle = ELECTRON; 00492 } 00493 else 00494 return MB_FAILURE; 00495 00496 if( debug ) std::cout << "tally_particle=| " << tally_particle << std::endl; 00497 00498 return MB_SUCCESS; 00499 } 00500 00501 ErrorCode ReadMCNP5::read_mesh_planes( std::fstream& file, 00502 bool debug, 00503 std::vector< double > planes[3], 00504 coordinate_system& coord_sys ) 00505 { 00506 // Tally bin boundaries: 00507 ErrorCode result; 00508 char line[10000]; 00509 file.getline( line, 10000 ); 00510 std::string a = line; 00511 if( std::string::npos == a.find( "Tally bin boundaries:" ) ) return MB_FAILURE; 00512 00513 // Decide what coordinate system the tally is using 00514 // first check for Cylindrical coordinates: 00515 file.getline( line, 10000 ); 00516 a = line; 00517 std::string::size_type b = a.find( "Cylinder origin at" ); 00518 if( std::string::npos != b ) 00519 { 00520 coord_sys = CYLINDRICAL; 00521 if( debug ) std::cout << "origin, axis, direction=| " << a << std::endl; 00522 std::istringstream ss( a.substr( b + sizeof( "Cylinder origin at" ), 10000 ) ); 00523 // The meshtal file does not contain sufficient information to transform 00524 // the particle. Although origin, axs, and vec is needed only origin and 00525 // axs appear in the meshtal file. Why was vec omitted?. 00526 // get origin (not used) 00527 // Cylinder origin at 0.00E+00 0.00E+00 0.00E+00, 00528 // axis in 0.000E+00 0.000E+00 1.000E+00 direction 00529 double origin[3]; 00530 if( debug ) std::cout << "origin=| "; 00531 for( int i = 0; i < 3; i++ ) 00532 { 00533 ss >> origin[i]; 00534 if( debug ) std::cout << origin[i] << " "; 00535 } 00536 if( debug ) std::cout << std::endl; 00537 int length_of_string = 10; 00538 ss.ignore( length_of_string, ' ' ); 00539 ss.ignore( length_of_string, ' ' ); 00540 ss.ignore( length_of_string, ' ' ); 00541 // Get axis (not used) 00542 double axis[3]; 00543 if( debug ) std::cout << "axis=| "; 00544 for( int i = 0; i < 3; i++ ) 00545 { 00546 ss >> axis[i]; 00547 if( debug ) std::cout << axis[i] << " "; 00548 } 00549 if( debug ) std::cout << std::endl; 00550 file.getline( line, 10000 ); 00551 a = line; 00552 00553 // Get r planes 00554 if( debug ) std::cout << "R direction:=| "; 00555 b = a.find( "R direction:" ); 00556 if( std::string::npos != b ) 00557 { 00558 std::istringstream ss2( a.substr( b + sizeof( "R direction" ), 10000 ) ); 00559 result = get_mesh_plane( ss2, debug, planes[0] ); 00560 if( MB_SUCCESS != result ) return result; 00561 } 00562 else 00563 return MB_FAILURE; 00564 00565 // Get z planes 00566 file.getline( line, 10000 ); 00567 a = line; 00568 if( debug ) std::cout << "Z direction:=| "; 00569 b = a.find( "Z direction:" ); 00570 if( std::string::npos != b ) 00571 { 00572 std::istringstream ss2( a.substr( b + sizeof( "Z direction" ), 10000 ) ); 00573 result = get_mesh_plane( ss2, debug, planes[1] ); 00574 if( MB_SUCCESS != result ) return result; 00575 } 00576 else 00577 return MB_FAILURE; 00578 00579 // Get theta planes 00580 file.getline( line, 10000 ); 00581 a = line; 00582 if( debug ) std::cout << "Theta direction:=| "; 00583 b = a.find( "Theta direction (revolutions):" ); 00584 if( std::string::npos != b ) 00585 { 00586 std::istringstream ss2( a.substr( b + sizeof( "Theta direction (revolutions):" ), 10000 ) ); 00587 result = get_mesh_plane( ss2, debug, planes[2] ); 00588 if( MB_SUCCESS != result ) return result; 00589 } 00590 else 00591 return MB_FAILURE; 00592 00593 // Cartesian coordinate system: 00594 } 00595 else if( std::string::npos != a.find( "X direction:" ) ) 00596 { 00597 coord_sys = CARTESIAN; 00598 // Get x planes 00599 if( debug ) std::cout << "X direction:=| "; 00600 b = a.find( "X direction:" ); 00601 if( std::string::npos != b ) 00602 { 00603 std::istringstream ss2( a.substr( b + sizeof( "X direction" ), 10000 ) ); 00604 result = get_mesh_plane( ss2, debug, planes[0] ); 00605 if( MB_SUCCESS != result ) return result; 00606 } 00607 else 00608 return MB_FAILURE; 00609 00610 // Get y planes 00611 file.getline( line, 10000 ); 00612 a = line; 00613 if( debug ) std::cout << "Y direction:=| "; 00614 b = a.find( "Y direction:" ); 00615 if( std::string::npos != b ) 00616 { 00617 std::istringstream ss2( a.substr( b + sizeof( "Y direction" ), 10000 ) ); 00618 result = get_mesh_plane( ss2, debug, planes[1] ); 00619 if( MB_SUCCESS != result ) return result; 00620 } 00621 else 00622 return MB_FAILURE; 00623 00624 // Get z planes 00625 file.getline( line, 10000 ); 00626 a = line; 00627 if( debug ) std::cout << "Z direction:=| "; 00628 b = a.find( "Z direction:" ); 00629 if( std::string::npos != b ) 00630 { 00631 std::istringstream ss2( a.substr( b + sizeof( "Z direction" ), 10000 ) ); 00632 result = get_mesh_plane( ss2, debug, planes[2] ); 00633 if( MB_SUCCESS != result ) return result; 00634 } 00635 else 00636 return MB_FAILURE; 00637 00638 // Spherical coordinate system not yet implemented: 00639 } 00640 else 00641 return MB_FAILURE; 00642 00643 return MB_SUCCESS; 00644 } 00645 00646 // Given a stringstream, return a vector of values in the string. 00647 ErrorCode ReadMCNP5::get_mesh_plane( std::istringstream& ss, bool debug, std::vector< double >& plane ) 00648 { 00649 double value; 00650 plane.clear(); 00651 while( !ss.eof() ) 00652 { 00653 ss >> value; 00654 plane.push_back( value ); 00655 if( debug ) std::cout << value << " "; 00656 } 00657 if( debug ) std::cout << std::endl; 00658 00659 return MB_SUCCESS; 00660 } 00661 00662 ErrorCode ReadMCNP5::read_element_values_and_errors( std::fstream& file, 00663 bool /* debug */, 00664 std::vector< double > planes[3], 00665 unsigned int n_chopped_x0_planes, 00666 unsigned int n_chopped_x2_planes, 00667 particle tally_particle, 00668 double values[], 00669 double errors[] ) 00670 { 00671 unsigned int index = 0; 00672 // Need to read every line in the file, even if we chop off some elements 00673 for( unsigned int i = 0; i < planes[0].size() - 1 + n_chopped_x0_planes; i++ ) 00674 { 00675 for( unsigned int j = 0; j < planes[1].size() - 1; j++ ) 00676 { 00677 for( unsigned int k = 0; k < planes[2].size() - 1 + n_chopped_x2_planes; k++ ) 00678 { 00679 char line[100]; 00680 file.getline( line, 100 ); 00681 // If this element has been chopped off, skip it 00682 if( i < n_chopped_x0_planes ) continue; 00683 if( k >= planes[2].size() - 1 && k < planes[2].size() - 1 + n_chopped_x2_planes ) continue; 00684 std::string a = line; 00685 std::stringstream ss( a ); 00686 double centroid[3]; 00687 double energy; 00688 // For some reason, photon tallies print the energy in the first column 00689 if( PHOTON == tally_particle ) ss >> energy; 00690 // The centroid is not used in this reader 00691 ss >> centroid[0]; 00692 ss >> centroid[1]; 00693 ss >> centroid[2]; 00694 // Only the tally values and errors are used 00695 ss >> values[index]; 00696 ss >> errors[index]; 00697 00698 // Make sure that input data is good 00699 if( !Util::is_finite( errors[index] ) ) 00700 { 00701 std::cerr << "found nan error while reading file" << std::endl; 00702 errors[index] = 1.0; 00703 } 00704 if( !Util::is_finite( values[index] ) ) 00705 { 00706 std::cerr << "found nan value while reading file" << std::endl; 00707 values[index] = 0.0; 00708 } 00709 00710 index++; 00711 } 00712 } 00713 } 00714 00715 return MB_SUCCESS; 00716 } 00717 00718 ErrorCode ReadMCNP5::set_tally_tags( EntityHandle tally_meshset, 00719 unsigned int tally_number, 00720 char tally_comment[100], 00721 particle tally_particle, 00722 coordinate_system tally_coord_sys, 00723 Tag tally_number_tag, 00724 Tag tally_comment_tag, 00725 Tag tally_particle_tag, 00726 Tag tally_coord_sys_tag ) 00727 { 00728 ErrorCode result; 00729 result = MBI->tag_set_data( tally_number_tag, &tally_meshset, 1, &tally_number ); 00730 if( MB_SUCCESS != result ) return result; 00731 result = MBI->tag_set_data( tally_comment_tag, &tally_meshset, 1, &tally_comment ); 00732 if( MB_SUCCESS != result ) return result; 00733 result = MBI->tag_set_data( tally_particle_tag, &tally_meshset, 1, &tally_particle ); 00734 if( MB_SUCCESS != result ) return result; 00735 result = MBI->tag_set_data( tally_coord_sys_tag, &tally_meshset, 1, &tally_coord_sys ); 00736 if( MB_SUCCESS != result ) return result; 00737 00738 return MB_SUCCESS; 00739 } 00740 00741 ErrorCode ReadMCNP5::create_vertices( std::vector< double > planes[3], 00742 bool debug, 00743 EntityHandle& start_vert, 00744 coordinate_system coord_sys, 00745 EntityHandle tally_meshset ) 00746 { 00747 // The only info needed to build elements is the mesh plane boundaries. 00748 ErrorCode result; 00749 int n_verts = planes[0].size() * planes[1].size() * planes[2].size(); 00750 if( debug ) std::cout << "n_verts=" << n_verts << std::endl; 00751 std::vector< double* > coord_arrays( 3 ); 00752 result = readMeshIface->get_node_coords( 3, n_verts, MB_START_ID, start_vert, coord_arrays ); 00753 if( MB_SUCCESS != result ) return result; 00754 assert( 0 != start_vert ); // Check for NULL 00755 00756 for( unsigned int k = 0; k < planes[2].size(); k++ ) 00757 { 00758 for( unsigned int j = 0; j < planes[1].size(); j++ ) 00759 { 00760 for( unsigned int i = 0; i < planes[0].size(); i++ ) 00761 { 00762 unsigned int idx = ( k * planes[0].size() * planes[1].size() + j * planes[0].size() + i ); 00763 double in[3], out[3]; 00764 00765 in[0] = planes[0][i]; 00766 in[1] = planes[1][j]; 00767 in[2] = planes[2][k]; 00768 result = transform_point_to_cartesian( in, out, coord_sys ); 00769 if( MB_SUCCESS != result ) return result; 00770 00771 // Cppcheck warning (false positive): variable coord_arrays is assigned a value that 00772 // is never used 00773 coord_arrays[0][idx] = out[0]; 00774 coord_arrays[1][idx] = out[1]; 00775 coord_arrays[2][idx] = out[2]; 00776 } 00777 } 00778 } 00779 Range vert_range( start_vert, start_vert + n_verts - 1 ); 00780 result = MBI->add_entities( tally_meshset, vert_range ); 00781 if( MB_SUCCESS != result ) return result; 00782 00783 if( fileIDTag ) 00784 { 00785 result = readMeshIface->assign_ids( *fileIDTag, vert_range, nodeId ); 00786 if( MB_SUCCESS != result ) return result; 00787 nodeId += vert_range.size(); 00788 } 00789 00790 return MB_SUCCESS; 00791 } 00792 00793 ErrorCode ReadMCNP5::create_elements( bool debug, 00794 std::vector< double > planes[3], 00795 unsigned int /*n_chopped_x0_planes*/, 00796 unsigned int /*n_chopped_x2_planes*/, 00797 EntityHandle start_vert, 00798 double* values, 00799 double* errors, 00800 Tag tally_tag, 00801 Tag error_tag, 00802 EntityHandle tally_meshset, 00803 coordinate_system tally_coord_sys ) 00804 { 00805 ErrorCode result; 00806 unsigned int index; 00807 EntityHandle start_element = 0; 00808 unsigned int n_elements = ( planes[0].size() - 1 ) * ( planes[1].size() - 1 ) * ( planes[2].size() - 1 ); 00809 EntityHandle* connect; 00810 result = readMeshIface->get_element_connect( n_elements, 8, MBHEX, MB_START_ID, start_element, connect ); 00811 if( MB_SUCCESS != result ) return result; 00812 assert( 0 != start_element ); // Check for NULL 00813 00814 unsigned int counter = 0; 00815 for( unsigned int i = 0; i < planes[0].size() - 1; i++ ) 00816 { 00817 for( unsigned int j = 0; j < planes[1].size() - 1; j++ ) 00818 { 00819 for( unsigned int k = 0; k < planes[2].size() - 1; k++ ) 00820 { 00821 index = start_vert + i + j * planes[0].size() + k * planes[0].size() * planes[1].size(); 00822 // For rectangular mesh, the file prints: x y z 00823 // z changes the fastest and x changes the slowest. 00824 // This means that the connectivity ordering is not consistent between 00825 // rectangular and cylindrical mesh. 00826 if( CARTESIAN == tally_coord_sys ) 00827 { 00828 connect[0] = index; 00829 connect[1] = index + 1; 00830 connect[2] = index + 1 + planes[0].size(); 00831 connect[3] = index + planes[0].size(); 00832 connect[4] = index + planes[0].size() * planes[1].size(); 00833 connect[5] = index + 1 + planes[0].size() * planes[1].size(); 00834 connect[6] = index + 1 + planes[0].size() + planes[0].size() * planes[1].size(); 00835 connect[7] = index + planes[0].size() + planes[0].size() * planes[1].size(); 00836 // For cylindrical mesh, the file prints: r z theta 00837 // Theta changes the fastest and r changes the slowest. 00838 } 00839 else if( CYLINDRICAL == tally_coord_sys ) 00840 { 00841 connect[0] = index; 00842 connect[1] = index + 1; 00843 connect[2] = index + 1 + planes[0].size() * planes[1].size(); 00844 connect[3] = index + planes[0].size() * planes[1].size(); 00845 connect[4] = index + planes[0].size(); 00846 connect[5] = index + 1 + planes[0].size(); 00847 connect[6] = index + 1 + planes[0].size() + planes[0].size() * planes[1].size(); 00848 connect[7] = index + planes[0].size() + planes[0].size() * planes[1].size(); 00849 } 00850 else 00851 return MB_NOT_IMPLEMENTED; 00852 00853 connect += 8; 00854 counter++; 00855 } 00856 } 00857 } 00858 if( counter != n_elements ) std::cout << "counter=" << counter << " n_elements=" << n_elements << std::endl; 00859 00860 Range element_range( start_element, start_element + n_elements - 1 ); 00861 result = MBI->tag_set_data( tally_tag, element_range, values ); 00862 if( MB_SUCCESS != result ) return result; 00863 result = MBI->tag_set_data( error_tag, element_range, errors ); 00864 if( MB_SUCCESS != result ) return result; 00865 00866 // Add the elements to the tally set 00867 result = MBI->add_entities( tally_meshset, element_range ); 00868 if( MB_SUCCESS != result ) return result; 00869 if( debug ) std::cout << "Read " << n_elements << " elements from tally." << std::endl; 00870 00871 if( fileIDTag ) 00872 { 00873 result = readMeshIface->assign_ids( *fileIDTag, element_range, elemId ); 00874 if( MB_SUCCESS != result ) return result; 00875 elemId += element_range.size(); 00876 } 00877 00878 return MB_SUCCESS; 00879 } 00880 00881 // Average a tally that was recently read in with one that already exists in 00882 // the interface. Only the existing values will be updated. 00883 ErrorCode ReadMCNP5::average_with_existing_tally( bool debug, 00884 unsigned long int& new_nps, 00885 unsigned long int nps1, 00886 unsigned int tally_number, 00887 Tag tally_number_tag, 00888 Tag nps_tag, 00889 Tag tally_tag, 00890 Tag error_tag, 00891 double* values1, 00892 double* errors1, 00893 unsigned int n_elements ) 00894 { 00895 // Get the tally number 00896 ErrorCode result; 00897 00898 // Match the tally number with one from the existing meshtal file 00899 Range matching_tally_number_sets; 00900 const void* const tally_number_val[] = { &tally_number }; 00901 result = MBI->get_entities_by_type_and_tag( 0, MBENTITYSET, &tally_number_tag, tally_number_val, 1, 00902 matching_tally_number_sets ); 00903 if( MB_SUCCESS != result ) return result; 00904 if( debug ) std::cout << "number of matching meshsets=" << matching_tally_number_sets.size() << std::endl; 00905 assert( 1 == matching_tally_number_sets.size() ); 00906 00907 // Identify which of the meshsets is existing 00908 EntityHandle existing_meshset; 00909 existing_meshset = matching_tally_number_sets.front(); 00910 00911 // Get the existing elements from the set 00912 Range existing_elements; 00913 result = MBI->get_entities_by_type( existing_meshset, MBHEX, existing_elements ); 00914 if( MB_SUCCESS != result ) return result; 00915 assert( existing_elements.size() == n_elements ); 00916 00917 // Get the nps of the existing and new tally 00918 unsigned long int nps0; 00919 Range sets_with_this_tag; 00920 result = MBI->get_entities_by_type_and_tag( 0, MBENTITYSET, &nps_tag, 0, 1, sets_with_this_tag ); 00921 if( MB_SUCCESS != result ) return result; 00922 if( debug ) std::cout << "number of nps sets=" << sets_with_this_tag.size() << std::endl; 00923 assert( 1 == sets_with_this_tag.size() ); 00924 result = MBI->tag_get_data( nps_tag, &sets_with_this_tag.front(), 1, &nps0 ); 00925 if( MB_SUCCESS != result ) return result; 00926 if( debug ) std::cout << "nps0=" << nps0 << " nps1=" << nps1 << std::endl; 00927 new_nps = nps0 + nps1; 00928 00929 // Get tally values from the existing elements 00930 double* values0 = new double[existing_elements.size()]; 00931 double* errors0 = new double[existing_elements.size()]; 00932 result = MBI->tag_get_data( tally_tag, existing_elements, values0 ); 00933 if( MB_SUCCESS != result ) 00934 { 00935 delete[] values0; 00936 delete[] errors0; 00937 return result; 00938 } 00939 result = MBI->tag_get_data( error_tag, existing_elements, errors0 ); 00940 if( MB_SUCCESS != result ) 00941 { 00942 delete[] values0; 00943 delete[] errors0; 00944 return result; 00945 } 00946 00947 // Average the values and errors 00948 result = average_tally_values( nps0, nps1, values0, values1, errors0, errors1, n_elements ); 00949 if( MB_SUCCESS != result ) 00950 { 00951 delete[] values0; 00952 delete[] errors0; 00953 return result; 00954 } 00955 00956 // Set the averaged information back onto the existing elements 00957 result = MBI->tag_set_data( tally_tag, existing_elements, values0 ); 00958 if( MB_SUCCESS != result ) 00959 { 00960 delete[] values0; 00961 delete[] errors0; 00962 return result; 00963 } 00964 result = MBI->tag_set_data( error_tag, existing_elements, errors0 ); 00965 if( MB_SUCCESS != result ) 00966 { 00967 delete[] values0; 00968 delete[] errors0; 00969 return result; 00970 } 00971 00972 // Cleanup 00973 delete[] values0; 00974 delete[] errors0; 00975 00976 return MB_SUCCESS; 00977 } 00978 00979 ErrorCode ReadMCNP5::transform_point_to_cartesian( double* in, double* out, coordinate_system coord_sys ) 00980 { 00981 // Transform coordinate system 00982 switch( coord_sys ) 00983 { 00984 case CARTESIAN: 00985 out[0] = in[0]; // x 00986 out[1] = in[1]; // y 00987 out[2] = in[2]; // z 00988 break; 00989 // theta is in rotations 00990 case CYLINDRICAL: 00991 out[0] = in[0] * cos( 2 * PI * in[2] ); // x 00992 out[1] = in[0] * sin( 2 * PI * in[2] ); // y 00993 out[2] = in[1]; // z 00994 break; 00995 case SPHERICAL: 00996 return MB_NOT_IMPLEMENTED; 00997 default: 00998 return MB_NOT_IMPLEMENTED; 00999 } 01000 01001 return MB_SUCCESS; 01002 } 01003 01004 // Average two tally values and their error. Return average values in the 01005 // place of first tally values. 01006 ErrorCode ReadMCNP5::average_tally_values( const unsigned long int nps0, 01007 const unsigned long int nps1, 01008 double* values0, 01009 const double* values1, 01010 double* errors0, 01011 const double* errors1, 01012 const unsigned long int n_values ) 01013 { 01014 for( unsigned long int i = 0; i < n_values; i++ ) 01015 { 01016 // std::cout << " values0=" << values0[i] << " values1=" << values1[i] 01017 // << " errors0=" << errors0[i] << " errors1=" << errors1[i] 01018 // << " nps0=" << nps0 << " nps1=" << nps1 << std::endl; 01019 errors0[i] = sqrt( pow( values0[i] * errors0[i] * nps0, 2 ) + pow( values1[i] * errors1[i] * nps1, 2 ) ) / 01020 ( values0[i] * nps0 + values1[i] * nps1 ); 01021 01022 // It is possible to introduce nans if the values are zero. 01023 if( !Util::is_finite( errors0[i] ) ) errors0[i] = 1.0; 01024 01025 values0[i] = ( values0[i] * nps0 + values1[i] * nps1 ) / ( nps0 + nps1 ); 01026 01027 // std::cout << " values0=" << values0[i] << " errors0=" << errors0[i] << std::endl; 01028 } 01029 // REMEMBER TO UPDATE NPS0 = NPS0 + NPS1 after this 01030 01031 return MB_SUCCESS; 01032 } 01033 01034 } // namespace moab
